[U-Boot] [PATCH 0/4 v7] Add ACE HW support for SHA256 and SHA1
This patch set adds hardware acceleration for SHA 256 with the help of ACE.
Changes since v1: - Patch-1: Fixed few nits. - Patch-2: Removed not required config. - Patch-3: Added sha256 to hash command instead of new sha256 command.
Changes since v2: - Patch-1: - Added falling back to software sha256 in case length exceeds buffer limit. - Reduced one tab at lines 533, 559 and 571 in the patch. - Removed space after a cast at line 506 in the patch. - Removed blank line at line 561 in the patch. - Removed space before semicolon at line 576 in the patch. - Patch-2: - Added "SHA1" in the comment for config. - Patch-3: - Added new nodes for SHA1 and SHA256 in struct hash_algo for the case when ACE is enabled. - Added new declaration for function pointer hash_func_ws with different return type. - Patch-4: - New patch to enable config for hash command.
Changes since v3: - Patch-1: - Removed buffer limit since there are 2 regs for address hash_msg_size_high and low. That means buffer length could go upto 2^64 bits which is practically - Removed falling back to software sha256 because there is no buffer limit. - Removed "/ 4" to sha1 and sha256 lengths and added increment to 4 in for loop at line 573. - Timed out still kept to be 100 ms since this is enough for hardware to switch status to idle from busy. In case it couldn't that means h/w is faulty. - Patch-2: - Added "Acked-by: Simon Glass sjg@chromium.org". - Patch-3: - New patch. - Patch-4: - Changed command names to lower case in algo struct. - Added generic ace_sha config. - Patch-5: Added acked-by Simon Glass - Added new generic config for ace_sha to enable ace support in hash.c.
Changes since v4: - Patch-1: - Added include for clk.h. - Added define for MAX_FREQ. - Added timeout calculation as per frequency. - Changed "i+=4" to "i++" and "len" to "len/4" in for loop at line 591 in this patch. - Added two new functions ace_sha256 and ace_sha1. - Patch-2: None. - Patch-3: - Changed function names in struct algo. - Replaced ACE_SHA_TYPE to CHUNSZ in struct algo. - Patch-4: Added "Acked-by: Simon Glass sjg@chromium.org".
Changes since v5: - Patch-1: - Removed ace_sha.h. - Renamed ace_sfr.h as ace_sha.h. - Removed timeout and checking for PRNG_ERROR bit in HASH_STATUS register. PRNG_ERROR bit high means setup was not done properly. Since there is no way to detect faulty h/w, we consider the possible fact that h/w should not be able to setup feed properly if it's faulty. - Renamed function name ace_sha256 to hw_sha256 and ace_sha1 to hw_sha1. - Patch-2: None. - Patch-3: - Added file hw_sha.h. - Changed CONFIG_ACE_SHA to CONFIG_SHA_HW_ACCEL. - Renamed function names ace_sha1 and ace_sha256 to hw_sha1 and hw_sha256 respectively. - Patch-4: - Removed "Acked-by: Simon Glass sjg@chromium.org" because of a change. - Changed CONFIG_ACE_SHA to CONFIG_SHA_HW_ACCEL.
Changes since v6: - Patch-1: Added "Acked-by: Simon Glass sjg@chromium.org". - Patch-2: None. - Patch-3: - Changed position of "hw_sha.h" among includes (alpha order). - Rebased patch. - Patch-4: Added "Acked-by: Simon Glass sjg@chromium.org".
Akshay Saraswat (4): Exynos: Add hardware accelerated SHA256 and SHA1 Exynos: config: Enable ACE HW for SHA 256 for Exynos gen: Add sha h/w acceleration to hash Exynos: config: Enable hash command
Makefile | 1 + arch/arm/include/asm/arch-exynos/ace_sha.h | 327 +++++++++++++++++++++++++++++ arch/arm/include/asm/arch-exynos/cpu.h | 4 + common/hash.c | 18 ++ drivers/crypto/Makefile | 47 +++++ drivers/crypto/ace_sha.c | 129 ++++++++++++ include/configs/exynos5250-dt.h | 5 + include/hw_sha.h | 50 +++++ 8 files changed, 581 insertions(+) create mode 100644 arch/arm/include/asm/arch-exynos/ace_sha.h create mode 100644 drivers/crypto/Makefile create mode 100644 drivers/crypto/ace_sha.c create mode 100644 include/hw_sha.h
SHA-256 and SHA-1 accelerated using ACE hardware.
Signed-off-by: ARUN MANKUZHI arun.m@samsung.com Signed-off-by: Akshay Saraswat akshay.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes since v1: - Moved code to drivers/crypto. - Fixed few other nits.
Changes since v2: - Added falling back to software sha256 in case length exceeds buffer limit. - Reduced one tab at lines 533, 559 and 571 in this patch. - Removed space after a cast at line 506 in this patch. - Removed blank line at line 561 in this patch. - Removed space before semicolon at line 576 in this patch.
Changes since v3: - Removed buffer limit since there are 2 regs for address hash_msg_size_high and low. That means buffer length could go upto 2^64 bits which is practically - Removed falling back to software sha256 because there is no buffer limit. - Removed "/ 4" to sha1 and sha256 lengths and added increment to 4 in for loop at line 573. - Timed out still kept to be 100 ms since this is enough for hardware to switch status to idle from busy. In case it couldn't that means h/w is faulty.
Changes since v4: - Added include for clk.h. - Added define for MAX_FREQ. - Added timeout calculation as per frequency. - Changed "i+=4" to "i++" and "len" to "len/4" in for loop at line 591 in this patch. - Added two new functions ace_sha256 and ace_sha1.
Changes since v5: - Removed ace_sha.h. - Renamed ace_sfr.h as ace_sha.h. - Removed timeout and checking for PRNG_ERROR bit in HASH_STATUS register. PRNG_ERROR bit high means setup was not done properly. Since there is no way to detect faulty h/w, we consider the possible fact that h/w should not be able to setup feed properly if it's faulty. - Renamed function name ace_sha256 to hw_sha256 and ace_sha1 to hw_sha1.
Changes since v6: - Added "Acked-by: Simon Glass sjg@chromium.org".
Makefile | 1 + arch/arm/include/asm/arch-exynos/ace_sha.h | 327 +++++++++++++++++++++++++++++ arch/arm/include/asm/arch-exynos/cpu.h | 4 + drivers/crypto/Makefile | 47 +++++ drivers/crypto/ace_sha.c | 129 ++++++++++++ 5 files changed, 508 insertions(+) create mode 100644 arch/arm/include/asm/arch-exynos/ace_sha.h create mode 100644 drivers/crypto/Makefile create mode 100644 drivers/crypto/ace_sha.c
diff --git a/Makefile b/Makefile index 55bd55c..54f86d8 100644 --- a/Makefile +++ b/Makefile @@ -273,6 +273,7 @@ LIBS-y += disk/libdisk.o LIBS-y += drivers/bios_emulator/libatibiosemu.o LIBS-y += drivers/block/libblock.o LIBS-$(CONFIG_BOOTCOUNT_LIMIT) += drivers/bootcount/libbootcount.o +LIBS-y += drivers/crypto/libcrypto.o LIBS-y += drivers/dma/libdma.o LIBS-y += drivers/fpga/libfpga.o LIBS-y += drivers/gpio/libgpio.o diff --git a/arch/arm/include/asm/arch-exynos/ace_sha.h b/arch/arm/include/asm/arch-exynos/ace_sha.h new file mode 100644 index 0000000..259f3d9 --- /dev/null +++ b/arch/arm/include/asm/arch-exynos/ace_sha.h @@ -0,0 +1,327 @@ +/* + * Header file for Advanced Crypto Engine - SFR definitions + * + * Copyright (c) 2012 Samsung Electronics + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __ACE_SHA_H +#define __ACE_SHA_H + +struct exynos_ace_sfr { + unsigned int fc_intstat; /* base + 0 */ + unsigned int fc_intenset; + unsigned int fc_intenclr; + unsigned int fc_intpend; + unsigned int fc_fifostat; + unsigned int fc_fifoctrl; + unsigned int fc_global; + unsigned int res1; + unsigned int fc_brdmas; + unsigned int fc_brdmal; + unsigned int fc_brdmac; + unsigned int res2; + unsigned int fc_btdmas; + unsigned int fc_btdmal; + unsigned int fc_btdmac; + unsigned int res3; + unsigned int fc_hrdmas; + unsigned int fc_hrdmal; + unsigned int fc_hrdmac; + unsigned int res4; + unsigned int fc_pkdmas; + unsigned int fc_pkdmal; + unsigned int fc_pkdmac; + unsigned int fc_pkdmao; + unsigned char res5[0x1a0]; + + unsigned int aes_control; /* base + 0x200 */ + unsigned int aes_status; + unsigned char res6[0x8]; + unsigned int aes_in[4]; + unsigned int aes_out[4]; + unsigned int aes_iv[4]; + unsigned int aes_cnt[4]; + unsigned char res7[0x30]; + unsigned int aes_key[8]; + unsigned char res8[0x60]; + + unsigned int tdes_control; /* base + 0x300 */ + unsigned int tdes_status; + unsigned char res9[0x8]; + unsigned int tdes_key[6]; + unsigned int tdes_iv[2]; + unsigned int tdes_in[2]; + unsigned int tdes_out[2]; + unsigned char res10[0xc0]; + + unsigned int hash_control; /* base + 0x400 */ + unsigned int hash_control2; + unsigned int hash_fifo_mode; + unsigned int hash_byteswap; + unsigned int hash_status; + unsigned char res11[0xc]; + unsigned int hash_msgsize_low; + unsigned int hash_msgsize_high; + unsigned int hash_prelen_low; + unsigned int hash_prelen_high; + unsigned int hash_in[16]; + unsigned int hash_key_in[16]; + unsigned int hash_iv[8]; + unsigned char res12[0x30]; + unsigned int hash_result[8]; + unsigned char res13[0x20]; + unsigned int hash_seed[8]; + unsigned int hash_prng[8]; + unsigned char res14[0x180]; + + unsigned int pka_sfr[5]; /* base + 0x700 */ +}; + +/* ACE_FC_INT */ +#define ACE_FC_PKDMA (1 << 0) +#define ACE_FC_HRDMA (1 << 1) +#define ACE_FC_BTDMA (1 << 2) +#define ACE_FC_BRDMA (1 << 3) +#define ACE_FC_PRNG_ERROR (1 << 4) +#define ACE_FC_MSG_DONE (1 << 5) +#define ACE_FC_PRNG_DONE (1 << 6) +#define ACE_FC_PARTIAL_DONE (1 << 7) + +/* ACE_FC_FIFOSTAT */ +#define ACE_FC_PKFIFO_EMPTY (1 << 0) +#define ACE_FC_PKFIFO_FULL (1 << 1) +#define ACE_FC_HRFIFO_EMPTY (1 << 2) +#define ACE_FC_HRFIFO_FULL (1 << 3) +#define ACE_FC_BTFIFO_EMPTY (1 << 4) +#define ACE_FC_BTFIFO_FULL (1 << 5) +#define ACE_FC_BRFIFO_EMPTY (1 << 6) +#define ACE_FC_BRFIFO_FULL (1 << 7) + +/* ACE_FC_FIFOCTRL */ +#define ACE_FC_SELHASH_MASK (3 << 0) +#define ACE_FC_SELHASH_EXOUT (0 << 0) /* independent source */ +#define ACE_FC_SELHASH_BCIN (1 << 0) /* blk cipher input */ +#define ACE_FC_SELHASH_BCOUT (2 << 0) /* blk cipher output */ +#define ACE_FC_SELBC_MASK (1 << 2) +#define ACE_FC_SELBC_AES (0 << 2) /* AES */ +#define ACE_FC_SELBC_DES (1 << 2) /* DES */ + +/* ACE_FC_GLOBAL */ +#define ACE_FC_SSS_RESET (1 << 0) +#define ACE_FC_DMA_RESET (1 << 1) +#define ACE_FC_AES_RESET (1 << 2) +#define ACE_FC_DES_RESET (1 << 3) +#define ACE_FC_HASH_RESET (1 << 4) +#define ACE_FC_AXI_ENDIAN_MASK (3 << 6) +#define ACE_FC_AXI_ENDIAN_LE (0 << 6) +#define ACE_FC_AXI_ENDIAN_BIBE (1 << 6) +#define ACE_FC_AXI_ENDIAN_WIBE (2 << 6) + +/* Feed control - BRDMA control */ +#define ACE_FC_BRDMACFLUSH_OFF (0 << 0) +#define ACE_FC_BRDMACFLUSH_ON (1 << 0) +#define ACE_FC_BRDMACSWAP_ON (1 << 1) +#define ACE_FC_BRDMACARPROT_MASK (0x7 << 2) +#define ACE_FC_BRDMACARPROT_OFS (2) +#define ACE_FC_BRDMACARCACHE_MASK (0xf << 5) +#define ACE_FC_BRDMACARCACHE_OFS (5) + +/* Feed control - BTDMA control */ +#define ACE_FC_BTDMACFLUSH_OFF (0 << 0) +#define ACE_FC_BTDMACFLUSH_ON (1 << 0) +#define ACE_FC_BTDMACSWAP_ON (1 << 1) +#define ACE_FC_BTDMACAWPROT_MASK (0x7 << 2) +#define ACE_FC_BTDMACAWPROT_OFS (2) +#define ACE_FC_BTDMACAWCACHE_MASK (0xf << 5) +#define ACE_FC_BTDMACAWCACHE_OFS (5) + +/* Feed control - HRDMA control */ +#define ACE_FC_HRDMACFLUSH_OFF (0 << 0) +#define ACE_FC_HRDMACFLUSH_ON (1 << 0) +#define ACE_FC_HRDMACSWAP_ON (1 << 1) +#define ACE_FC_HRDMACARPROT_MASK (0x7 << 2) +#define ACE_FC_HRDMACARPROT_OFS (2) +#define ACE_FC_HRDMACARCACHE_MASK (0xf << 5) +#define ACE_FC_HRDMACARCACHE_OFS (5) + +/* Feed control - PKDMA control */ +#define ACE_FC_PKDMACBYTESWAP_ON (1 << 3) +#define ACE_FC_PKDMACDESEND_ON (1 << 2) +#define ACE_FC_PKDMACTRANSMIT_ON (1 << 1) +#define ACE_FC_PKDMACFLUSH_ON (1 << 0) + +/* Feed control - PKDMA offset */ +#define ACE_FC_SRAMOFFSET_MASK (0xfff) + +/* AES control */ +#define ACE_AES_MODE_MASK (1 << 0) +#define ACE_AES_MODE_ENC (0 << 0) +#define ACE_AES_MODE_DEC (1 << 0) +#define ACE_AES_OPERMODE_MASK (3 << 1) +#define ACE_AES_OPERMODE_ECB (0 << 1) +#define ACE_AES_OPERMODE_CBC (1 << 1) +#define ACE_AES_OPERMODE_CTR (2 << 1) +#define ACE_AES_FIFO_MASK (1 << 3) +#define ACE_AES_FIFO_OFF (0 << 3) /* CPU mode */ +#define ACE_AES_FIFO_ON (1 << 3) /* FIFO mode */ +#define ACE_AES_KEYSIZE_MASK (3 << 4) +#define ACE_AES_KEYSIZE_128 (0 << 4) +#define ACE_AES_KEYSIZE_192 (1 << 4) +#define ACE_AES_KEYSIZE_256 (2 << 4) +#define ACE_AES_KEYCNGMODE_MASK (1 << 6) +#define ACE_AES_KEYCNGMODE_OFF (0 << 6) +#define ACE_AES_KEYCNGMODE_ON (1 << 6) +#define ACE_AES_SWAP_MASK (0x1f << 7) +#define ACE_AES_SWAPKEY_OFF (0 << 7) +#define ACE_AES_SWAPKEY_ON (1 << 7) +#define ACE_AES_SWAPCNT_OFF (0 << 8) +#define ACE_AES_SWAPCNT_ON (1 << 8) +#define ACE_AES_SWAPIV_OFF (0 << 9) +#define ACE_AES_SWAPIV_ON (1 << 9) +#define ACE_AES_SWAPDO_OFF (0 << 10) +#define ACE_AES_SWAPDO_ON (1 << 10) +#define ACE_AES_SWAPDI_OFF (0 << 11) +#define ACE_AES_SWAPDI_ON (1 << 11) +#define ACE_AES_COUNTERSIZE_MASK (3 << 12) +#define ACE_AES_COUNTERSIZE_128 (0 << 12) +#define ACE_AES_COUNTERSIZE_64 (1 << 12) +#define ACE_AES_COUNTERSIZE_32 (2 << 12) +#define ACE_AES_COUNTERSIZE_16 (3 << 12) + +/* AES status */ +#define ACE_AES_OUTRDY_MASK (1 << 0) +#define ACE_AES_OUTRDY_OFF (0 << 0) +#define ACE_AES_OUTRDY_ON (1 << 0) +#define ACE_AES_INRDY_MASK (1 << 1) +#define ACE_AES_INRDY_OFF (0 << 1) +#define ACE_AES_INRDY_ON (1 << 1) +#define ACE_AES_BUSY_MASK (1 << 2) +#define ACE_AES_BUSY_OFF (0 << 2) +#define ACE_AES_BUSY_ON (1 << 2) + +/* TDES control */ +#define ACE_TDES_MODE_MASK (1 << 0) +#define ACE_TDES_MODE_ENC (0 << 0) +#define ACE_TDES_MODE_DEC (1 << 0) +#define ACE_TDES_OPERMODE_MASK (1 << 1) +#define ACE_TDES_OPERMODE_ECB (0 << 1) +#define ACE_TDES_OPERMODE_CBC (1 << 1) +#define ACE_TDES_SEL_MASK (3 << 3) +#define ACE_TDES_SEL_DES (0 << 3) +#define ACE_TDES_SEL_TDESEDE (1 << 3) /* TDES EDE mode */ +#define ACE_TDES_SEL_TDESEEE (3 << 3) /* TDES EEE mode */ +#define ACE_TDES_FIFO_MASK (1 << 5) +#define ACE_TDES_FIFO_OFF (0 << 5) /* CPU mode */ +#define ACE_TDES_FIFO_ON (1 << 5) /* FIFO mode */ +#define ACE_TDES_SWAP_MASK (0xf << 6) +#define ACE_TDES_SWAPKEY_OFF (0 << 6) +#define ACE_TDES_SWAPKEY_ON (1 << 6) +#define ACE_TDES_SWAPIV_OFF (0 << 7) +#define ACE_TDES_SWAPIV_ON (1 << 7) +#define ACE_TDES_SWAPDO_OFF (0 << 8) +#define ACE_TDES_SWAPDO_ON (1 << 8) +#define ACE_TDES_SWAPDI_OFF (0 << 9) +#define ACE_TDES_SWAPDI_ON (1 << 9) + +/* TDES status */ +#define ACE_TDES_OUTRDY_MASK (1 << 0) +#define ACE_TDES_OUTRDY_OFF (0 << 0) +#define ACE_TDES_OUTRDY_ON (1 << 0) +#define ACE_TDES_INRDY_MASK (1 << 1) +#define ACE_TDES_INRDY_OFF (0 << 1) +#define ACE_TDES_INRDY_ON (1 << 1) +#define ACE_TDES_BUSY_MASK (1 << 2) +#define ACE_TDES_BUSY_OFF (0 << 2) +#define ACE_TDES_BUSY_ON (1 << 2) + +/* Hash control */ +#define ACE_HASH_ENGSEL_MASK (0xf << 0) +#define ACE_HASH_ENGSEL_SHA1HASH (0x0 << 0) +#define ACE_HASH_ENGSEL_SHA1HMAC (0x1 << 0) +#define ACE_HASH_ENGSEL_SHA1HMACIN (0x1 << 0) +#define ACE_HASH_ENGSEL_SHA1HMACOUT (0x9 << 0) +#define ACE_HASH_ENGSEL_MD5HASH (0x2 << 0) +#define ACE_HASH_ENGSEL_MD5HMAC (0x3 << 0) +#define ACE_HASH_ENGSEL_MD5HMACIN (0x3 << 0) +#define ACE_HASH_ENGSEL_MD5HMACOUT (0xb << 0) +#define ACE_HASH_ENGSEL_SHA256HASH (0x4 << 0) +#define ACE_HASH_ENGSEL_SHA256HMAC (0x5 << 0) +#define ACE_HASH_ENGSEL_PRNG (0x8 << 0) +#define ACE_HASH_STARTBIT_ON (1 << 4) +#define ACE_HASH_USERIV_EN (1 << 5) + +/* Hash control 2 */ +#define ACE_HASH_PAUSE_ON (1 << 0) + +/* Hash control - FIFO mode */ +#define ACE_HASH_FIFO_MASK (1 << 0) +#define ACE_HASH_FIFO_OFF (0 << 0) +#define ACE_HASH_FIFO_ON (1 << 0) + +/* Hash control - byte swap */ +#define ACE_HASH_SWAP_MASK (0xf << 0) +#define ACE_HASH_SWAPKEY_OFF (0 << 0) +#define ACE_HASH_SWAPKEY_ON (1 << 0) +#define ACE_HASH_SWAPIV_OFF (0 << 1) +#define ACE_HASH_SWAPIV_ON (1 << 1) +#define ACE_HASH_SWAPDO_OFF (0 << 2) +#define ACE_HASH_SWAPDO_ON (1 << 2) +#define ACE_HASH_SWAPDI_OFF (0 << 3) +#define ACE_HASH_SWAPDI_ON (1 << 3) + +/* Hash status */ +#define ACE_HASH_BUFRDY_MASK (1 << 0) +#define ACE_HASH_BUFRDY_OFF (0 << 0) +#define ACE_HASH_BUFRDY_ON (1 << 0) +#define ACE_HASH_SEEDSETTING_MASK (1 << 1) +#define ACE_HASH_SEEDSETTING_OFF (0 << 1) +#define ACE_HASH_SEEDSETTING_ON (1 << 1) +#define ACE_HASH_PRNGBUSY_MASK (1 << 2) +#define ACE_HASH_PRNGBUSY_OFF (0 << 2) +#define ACE_HASH_PRNGBUSY_ON (1 << 2) +#define ACE_HASH_PARTIALDONE_MASK (1 << 4) +#define ACE_HASH_PARTIALDONE_OFF (0 << 4) +#define ACE_HASH_PARTIALDONE_ON (1 << 4) +#define ACE_HASH_PRNGDONE_MASK (1 << 5) +#define ACE_HASH_PRNGDONE_OFF (0 << 5) +#define ACE_HASH_PRNGDONE_ON (1 << 5) +#define ACE_HASH_MSGDONE_MASK (1 << 6) +#define ACE_HASH_MSGDONE_OFF (0 << 6) +#define ACE_HASH_MSGDONE_ON (1 << 6) +#define ACE_HASH_PRNGERROR_MASK (1 << 7) +#define ACE_HASH_PRNGERROR_OFF (0 << 7) +#define ACE_HASH_PRNGERROR_ON (1 << 7) + +#define ACE_SHA_TYPE_SHA1 1 +#define ACE_SHA_TYPE_SHA256 2 + +/** + * Computes hash value of input pbuf using ACE + * + * @param in_addr A pointer to the input buffer + * @param bufleni Byte length of input buffer + * @param out_addr A pointer to the output buffer. When complete + * 32 bytes are copied to pout[0]...pout[31]. Thus, a user + * should allocate at least 32 bytes at pOut in advance. + * @param hash_type SHA1 or SHA256 + * + * @return 0 on Success, -1 on Failure (Timeout) + */ +int ace_sha_hash_digest(const uchar *in_addr, uint buflen, + uchar *out_addr, uint hash_type); +#endif diff --git a/arch/arm/include/asm/arch-exynos/cpu.h b/arch/arm/include/asm/arch-exynos/cpu.h index eb34422..2a20558 100644 --- a/arch/arm/include/asm/arch-exynos/cpu.h +++ b/arch/arm/include/asm/arch-exynos/cpu.h @@ -62,6 +62,7 @@ #define EXYNOS4_GPIO_PART4_BASE DEVICE_NOT_AVAILABLE #define EXYNOS4_DP_BASE DEVICE_NOT_AVAILABLE #define EXYNOS4_SPI_ISP_BASE DEVICE_NOT_AVAILABLE +#define EXYNOS4_ACE_SFR_BASE DEVICE_NOT_AVAILABLE
/* EXYNOS4X12 */ #define EXYNOS4X12_GPIO_PART3_BASE 0x03860000 @@ -95,6 +96,7 @@ #define EXYNOS4X12_I2S_BASE DEVICE_NOT_AVAILABLE #define EXYNOS4X12_SPI_BASE DEVICE_NOT_AVAILABLE #define EXYNOS4X12_SPI_ISP_BASE DEVICE_NOT_AVAILABLE +#define EXYNOS4X12_ACE_SFR_BASE DEVICE_NOT_AVAILABLE
/* EXYNOS5 Common*/ #define EXYNOS5_I2C_SPACING 0x10000 @@ -106,6 +108,7 @@ #define EXYNOS5_SWRESET 0x10040400 #define EXYNOS5_SYSREG_BASE 0x10050000 #define EXYNOS5_WATCHDOG_BASE 0x101D0000 +#define EXYNOS5_ACE_SFR_BASE 0x10830000 #define EXYNOS5_DMC_PHY0_BASE 0x10C00000 #define EXYNOS5_DMC_PHY1_BASE 0x10C10000 #define EXYNOS5_GPIO_PART3_BASE 0x10D10000 @@ -205,6 +208,7 @@ static inline unsigned int samsung_get_base_##device(void) \
SAMSUNG_BASE(adc, ADC_BASE) SAMSUNG_BASE(clock, CLOCK_BASE) +SAMSUNG_BASE(ace_sfr, ACE_SFR_BASE) SAMSUNG_BASE(dp, DP_BASE) SAMSUNG_BASE(sysreg, SYSREG_BASE) SAMSUNG_BASE(fimd, FIMD_BASE) diff --git a/drivers/crypto/Makefile b/drivers/crypto/Makefile new file mode 100644 index 0000000..2c54793 --- /dev/null +++ b/drivers/crypto/Makefile @@ -0,0 +1,47 @@ +# +# Copyright (c) 2013 Samsung Electronics Co., Ltd. +# http://www.samsung.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB := $(obj)libcrypto.o + +COBJS-$(CONFIG_EXYNOS_ACE_SHA) += ace_sha.o + +COBJS := $(COBJS-y) +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +all: $(LIB) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################## diff --git a/drivers/crypto/ace_sha.c b/drivers/crypto/ace_sha.c new file mode 100644 index 0000000..e8d9b2d --- /dev/null +++ b/drivers/crypto/ace_sha.c @@ -0,0 +1,129 @@ +/* + * Advanced Crypto Engine - SHA Firmware + * Copyright (c) 2012 Samsung Electronics + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ +#include <common.h> +#include <sha256.h> +#include <sha1.h> +#include <asm/errno.h> +#include <asm/arch/clk.h> +#include <asm/arch/ace_sha.h> + +/* Maximum frequency supported by the SoC*/ +#define MAX_FREQ (1.7 * 1000 * 1000 * 1000) + +/* SHA1 value for the message of zero length */ +static const unsigned char sha1_digest_emptymsg[SHA1_SUM_LEN] = { + 0xDA, 0x39, 0xA3, 0xEE, 0x5E, 0x6B, 0x4B, 0x0D, + 0x32, 0x55, 0xBF, 0xFF, 0x95, 0x60, 0x18, 0x90, + 0xAF, 0xD8, 0x07, 0x09}; + +/* SHA256 value for the message of zero length */ +static const unsigned char sha256_digest_emptymsg[SHA256_SUM_LEN] = { + 0xE3, 0xB0, 0xC4, 0x42, 0x98, 0xFC, 0x1C, 0x14, + 0x9A, 0xFB, 0xF4, 0xC8, 0x99, 0x6F, 0xB9, 0x24, + 0x27, 0xAE, 0x41, 0xE4, 0x64, 0x9B, 0x93, 0x4C, + 0xA4, 0x95, 0x99, 0x1B, 0x78, 0x52, 0xB8, 0x55}; + +int ace_sha_hash_digest(const unsigned char *pbuf, unsigned int buf_len, + unsigned char *pout, unsigned int hash_type) +{ + unsigned int i, reg, len; + unsigned int *pdigest; + struct exynos_ace_sfr *ace_sha_reg = + (struct exynos_ace_sfr *)samsung_get_base_ace_sfr(); + + if (buf_len == 0) { + /* ACE H/W cannot compute hash value for empty string */ + if (hash_type == ACE_SHA_TYPE_SHA1) + memcpy(pout, sha1_digest_emptymsg, SHA1_SUM_LEN); + else + memcpy(pout, sha256_digest_emptymsg, SHA256_SUM_LEN); + return 0; + } + + /* Flush HRDMA */ + writel(ACE_FC_HRDMACFLUSH_ON, &ace_sha_reg->fc_hrdmac); + writel(ACE_FC_HRDMACFLUSH_OFF, &ace_sha_reg->fc_hrdmac); + + /* Set byte swap of data in */ + writel(ACE_HASH_SWAPDI_ON | ACE_HASH_SWAPDO_ON | ACE_HASH_SWAPIV_ON, + &ace_sha_reg->hash_byteswap); + + /* Select Hash input mux as external source */ + reg = readl(&ace_sha_reg->fc_fifoctrl); + reg = (reg & ~ACE_FC_SELHASH_MASK) | ACE_FC_SELHASH_EXOUT; + writel(reg, &ace_sha_reg->fc_fifoctrl); + + /* Set Hash as SHA1 or SHA256 and start Hash engine */ + reg = (hash_type == ACE_SHA_TYPE_SHA1) ? + ACE_HASH_ENGSEL_SHA1HASH : ACE_HASH_ENGSEL_SHA256HASH; + reg |= ACE_HASH_STARTBIT_ON; + writel(reg, &ace_sha_reg->hash_control); + + /* Enable FIFO mode */ + writel(ACE_HASH_FIFO_ON, &ace_sha_reg->hash_fifo_mode); + + /* Set message length */ + writel(buf_len, &ace_sha_reg->hash_msgsize_low); + writel(0, &ace_sha_reg->hash_msgsize_high); + + /* Set HRDMA */ + writel((unsigned int)pbuf, &ace_sha_reg->fc_hrdmas); + writel(buf_len, &ace_sha_reg->fc_hrdmal); + + /* Check if status changes within given time limit */ + while ((readl(&ace_sha_reg->hash_status) & ACE_HASH_MSGDONE_MASK) == + ACE_HASH_MSGDONE_OFF) { + /* + * PRNG error bit goes HIGH if a PRNG request occurs without + * a complete seed setup. We are using this bit to check h/w + * because proper setup is not expected in that case. + */ + if ((readl(&ace_sha_reg->hash_status) + & ACE_HASH_PRNGERROR_MASK) == ACE_HASH_PRNGERROR_ON) + break; + } + + /* Clear MSG_DONE bit */ + writel(ACE_HASH_MSGDONE_ON, &ace_sha_reg->hash_status); + + /* Read hash result */ + pdigest = (unsigned int *)pout; + len = (hash_type == ACE_SHA_TYPE_SHA1) ? SHA1_SUM_LEN : SHA256_SUM_LEN; + + for (i = 0; i < len / 4; i++) + pdigest[i] = readl(&ace_sha_reg->hash_result[i]); + + /* Clear HRDMA pending bit */ + writel(ACE_FC_HRDMA, &ace_sha_reg->fc_intpend); + + return 0; +} + +void hw_sha256(const unsigned char *pbuf, unsigned int buf_len, + unsigned char *pout, unsigned int chunk_size) +{ + ace_sha_hash_digest(pbuf, buf_len, pout, ACE_SHA_TYPE_SHA256); +} + +void hw_sha1(const unsigned char *pbuf, unsigned int buf_len, + unsigned char *pout, unsigned int chunk_size) +{ + ace_sha_hash_digest(pbuf, buf_len, pout, ACE_SHA_TYPE_SHA1); +}
On Mon, 18 Mar 2013 02:06:15 -0400 Akshay Saraswat akshay.s@samsung.com wrote:
ace_sha.h belongs in drivers/crypto/
nit: comments seem a bit redundant
+#define ACE_FC_BRDMACARPROT_OFS (2) +#define ACE_FC_BRDMACARCACHE_OFS (5) +#define ACE_FC_BTDMACAWPROT_OFS (2) +#define ACE_FC_BTDMACAWCACHE_OFS (5) +#define ACE_FC_HRDMACARPROT_OFS (2) +#define ACE_FC_HRDMACARCACHE_OFS (5) +#define ACE_FC_SRAMOFFSET_MASK (0xfff)
no parens.
- Computes hash value of input pbuf using ACE
- @param in_addr A pointer to the input buffer
- @param bufleni Byte length of input buffer
- @param out_addr A pointer to the output buffer. When complete
- @param hash_type SHA1 or SHA256
- @return 0 on Success, -1 on Failure (Timeout)
- /* Check if status changes within given time limit */
leftovers from timeout implementation?
- while ((readl(&ace_sha_reg->hash_status) & ACE_HASH_MSGDONE_MASK) ==
break;
so we have:
whilst (not_done) if (PRNGERROR_ON) break;
...and then success-assuming code flow continues after this. What value is this check for PRNGERROR_ON, if the code isn't going to do anything differently? And what does the status of the RNG have to do with keyless hashing? It sounds like a check for proper initialization (RNG got seeded) is in order here, but only if it's required for the given hash operations (I doubt it, but the h/w might be fussy).
Kim
This enables SHA 256 for exynos.
Signed-off-by: ARUN MANKUZHI arun.m@samsung.com Signed-off-by: Akshay Saraswat akshay.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes since v1: - Removed not required config.
Changes sice v2: - Added "SHA1" in the comment for config.
Changes sice v3: - Added "Acked-by: Simon Glass sjg@chromium.org".
Changes sice v4: - None.
Changes sice v5: - None.
Changes sice v6: - None.
include/configs/exynos5250-dt.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/include/configs/exynos5250-dt.h b/include/configs/exynos5250-dt.h index 1c624d4..1fb47a0 100644 --- a/include/configs/exynos5250-dt.h +++ b/include/configs/exynos5250-dt.h @@ -46,6 +46,9 @@ /* Keep L2 Cache Disabled */ #define CONFIG_SYS_DCACHE_OFF
+/* Enable ACE acceleration for SHA1 and SHA256 */ +#define CONFIG_EXYNOS_ACE_SHA + #define CONFIG_SYS_SDRAM_BASE 0x40000000 #define CONFIG_SYS_TEXT_BASE 0x43E00000
Adding H/W acceleration support to hash which can be used to test SHA 256 hash algorithm.
Signed-off-by: ARUN MANKUZHI arun.m@samsung.com Signed-off-by: Akshay Saraswat akshay.s@samsung.com --- Changes since v1: - Added sha256 support to "hash" command instead of new sha256 command.
Changes sice v2: - Added new nodes for SHA1 and SHA256 in struct hash_algo for the case when ACE is enabled. - Added new declaration for function pointer hash_func_ws with different return type.
Changes sice v3: - Changed command names to lower case in algo struct. - Added generic ace_sha config.
Changes sice v4: - Changed function names in struct algo. - Replaced ACE_SHA_TYPE to CHUNSZ in struct algo.
Changes sice v5: - Added file hw_sha.h. - Changed CONFIG_ACE_SHA to CONFIG_SHA_HW_ACCEL. - Renamed function names ace_sha1 and ace_sha256 to hw_sha1 and hw_sha256 respectively.
Changes sice v6: - Changed position of "hw_sha.h" among includes (alpha order). - Rebased patch.
common/hash.c | 18 ++++++++++++++++++ include/hw_sha.h | 50 ++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 68 insertions(+) create mode 100644 include/hw_sha.h
diff --git a/common/hash.c b/common/hash.c index f5badcb..5f46dc6 100644 --- a/common/hash.c +++ b/common/hash.c @@ -25,6 +25,7 @@
#include <common.h> #include <command.h> +#include <hw_sha.h> #include <hash.h> #include <sha1.h> #include <sha256.h> @@ -37,6 +38,23 @@ */ static struct hash_algo hash_algo[] = { /* + * CONFIG_SHA_HW_ACCEL is defined if hardware acceleration is + * available. + */ +#ifdef CONFIG_SHA_HW_ACCEL + { + "sha1", + SHA1_SUM_LEN, + hw_sha1, + CHUNKSZ_SHA1, + }, { + "sha256", + SHA256_SUM_LEN, + hw_sha256, + CHUNKSZ_SHA256, + }, +#endif + /* * This is CONFIG_CMD_SHA1SUM instead of CONFIG_SHA1 since otherwise * it bloats the code for boards which use SHA1 but not the 'hash' * or 'sha1sum' commands. diff --git a/include/hw_sha.h b/include/hw_sha.h new file mode 100644 index 0000000..565e5a0 --- /dev/null +++ b/include/hw_sha.h @@ -0,0 +1,50 @@ +/* + * Header file for SHA hardware acceleration + * + * Copyright (c) 2012 Samsung Electronics + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ +#ifndef __HW_SHA_H +#define __HW_SHA_H + + +/** + * Computes hash value of input pbuf using h/w acceleration + * + * @param in_addr A pointer to the input buffer + * @param bufleni Byte length of input buffer + * @param out_addr A pointer to the output buffer. When complete + * 32 bytes are copied to pout[0]...pout[31]. Thus, a user + * should allocate at least 32 bytes at pOut in advance. + * @param chunk_size chunk size for sha256 + */ +void hw_sha256(const uchar *in_addr, uint buflen, + uchar *out_addr, uint chunk_size); + +/** + * Computes hash value of input pbuf using h/w acceleration + * + * @param in_addr A pointer to the input buffer + * @param bufleni Byte length of input buffer + * @param out_addr A pointer to the output buffer. When complete + * 32 bytes are copied to pout[0]...pout[31]. Thus, a user + * should allocate at least 32 bytes at pOut in advance. + * @param chunk_size chunk_size for sha1 + */ +void hw_sha1(const uchar *in_addr, uint buflen, + uchar *out_addr, uint chunk_size); +#endif
On Sun, Mar 17, 2013 at 11:06 PM, Akshay Saraswat akshay.s@samsung.com wrote:
Your alphabetical order looks slightly different to mine :-) Anyway:
This enables hash command.
Tested with command "hash sha256 0x40008000 0x2B 0x40009000". Used mm and md to write a standard string to memory location 0x40008000 and ran the above command to verify the output.
Signed-off-by: ARUN MANKUZHI arun.m@samsung.com Signed-off-by: Akshay Saraswat akshay.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes since v2: - New patch to enable config for hash command.
Changes since v3: - Added new generic config for ace_sha to enable ace support in hash.c.
Changes since v4: - Added "Acked-by: Simon Glass sjg@chromium.org".
Changes since v5: - Removed "Acked-by: Simon Glass sjg@chromium.org" because of a change. - Changed CONFIG_ACE_SHA to CONFIG_SHA_HW_ACCEL.
include/configs/exynos5250-dt.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/exynos5250-dt.h b/include/configs/exynos5250-dt.h index 1fb47a0..9680b9d 100644 --- a/include/configs/exynos5250-dt.h +++ b/include/configs/exynos5250-dt.h @@ -48,6 +48,7 @@
/* Enable ACE acceleration for SHA1 and SHA256 */ #define CONFIG_EXYNOS_ACE_SHA +#define CONFIG_SHA_HW_ACCEL
#define CONFIG_SYS_SDRAM_BASE 0x40000000 #define CONFIG_SYS_TEXT_BASE 0x43E00000 @@ -117,6 +118,7 @@ #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT #define CONFIG_CMD_NET +#define CONFIG_CMD_HASH
#define CONFIG_BOOTDELAY 3 #define CONFIG_ZERO_BOOTDELAY_CHECK
Akshay Saraswat
Kim Phillips
