[U-Boot] [PATCH 1/1] tools: mxsboot: calculate ECC block level dynamically
For pages of 2048 bytes the current setting of the ECC Error Correction Level is only true for an oob size of 64 bytes and wrong for all others.
Instead of hard-coding every possible combination of page size and oob size use the dynamic calculation of the ECC strength introduced in commit 6121560d7714d6d8e41ce1687a1388a1a8fea4cb.
Cc: Marek Vasut marex@denx.de Signed-off-by: Jörg Krause joerg.krause@embedded.rocks --- tools/mxsboot.c | 21 ++++----------------- 1 file changed, 4 insertions(+), 17 deletions(-)
diff --git a/tools/mxsboot.c b/tools/mxsboot.c index 185b327..15eec91 100644 --- a/tools/mxsboot.c +++ b/tools/mxsboot.c @@ -271,23 +271,10 @@ static struct mx28_nand_fcb *mx28_nand_get_fcb(uint32_t size) fcb->ecc_block_0_size = 512; fcb->ecc_block_n_size = 512; fcb->metadata_bytes = 10; - - if (nand_writesize == 2048) { - fcb->ecc_block_n_ecc_type = 4; - fcb->ecc_block_0_ecc_type = 4; - } else if (nand_writesize == 4096) { - if (nand_oobsize == 128) { - fcb->ecc_block_n_ecc_type = 4; - fcb->ecc_block_0_ecc_type = 4; - } else if (nand_oobsize == 218) { - fcb->ecc_block_n_ecc_type = 8; - fcb->ecc_block_0_ecc_type = 8; - } else if (nand_oobsize == 224) { - fcb->ecc_block_n_ecc_type = 8; - fcb->ecc_block_0_ecc_type = 8; - } - } - + fcb->ecc_block_n_ecc_type = mx28_nand_get_ecc_strength( + nand_writesize, nand_oobsize) >> 1; + fcb->ecc_block_0_ecc_type = mx28_nand_get_ecc_strength( + nand_writesize, nand_oobsize) >> 1; if (fcb->ecc_block_n_ecc_type == 0) { printf("MX28 NAND: Unsupported NAND geometry\n"); goto err;
Acked-by: Marek Vasut marex@denx.de
Best regards, Marek Vasut
Best regards, Stefano Babic
- fcb->ecc_block_n_ecc_type = mx28_nand_get_ecc_strength(
- fcb->ecc_block_0_ecc_type = mx28_nand_get_ecc_strength(
if (fcb->ecc_block_n_ecc_type == 0) { printf("MX28 NAND: Unsupported NAND geometry\n"); goto err;nand_writesize, nand_oobsize) >> 1;
Reviewed-by: Stefano Babic sbabic@denx.de
Jörg Krause
Stefano Babic
