[U-Boot] [PATCH 00/25] sunxi: Enable DM_MMC for U-Boot proper
Enabling DM_MMC is not straight forward for Allwinner SoC's to make proper compatibility in mmc driver vs DT nodes.
Existing dm code for ahb gate clock will be suitable to handle sun4i,5i,6i and 7i U-Boot specific mmc dt nodes, which are different from Linux in terms of clocks phandle notation.
U-Boot DT clocks phandle follow direct ahb and clock address on node definition with specific bit position, but Linux clocks phandle follow macros to define AHB and MMC clocks so-that the ccu driver will set the bits accordingly.
Clocks phandle notations in U-Boot for higher Allwinner SoC start from sun8i, sun50i are following Linux notation so-that both Linux and U-Boot can have common node definition.
This series will address the ahb gate, clock setup to handle all type of Allwinner SoCs. and sync mmc node definitions from Linux for sun4i and sun5i.
Note: - sun6i, A23, A33, V3S were untested these need to have a closer look on dt nodes along with default ENV_FAT device.
All these changes available at u-boot-sunxi/next
Let me know if any questions or missings, Jagan.
Jagan Teki (25): ARM: dts: sun4i: Sync A10 MMC nodes from Linux ARM: dts: sun4i: Sync A10 board dts mmc0 node from Linux ARM: dts: sun4i: Add mmc0 node for iNet 3F ARM: dts: sun4i: Add mmc0 node for iNet 3W dm: mmc: sunxi: Refactor ahb gate and clock setup dm: mmc: sunxi: Add ahb reset0 register write ARM: dts: sun7i: Sync A20 MMC nodes from Linux ARM: dts: sun7i: Add mmc0 node for Primo73 tablet ARM: dts: sun7i: Add mmc0 node for Ainol AW1 ARM: dts: sun7i: Add mmc0 node for Mele M5 ARM: dts: sun7i: Add mmc0 node for Toptech BD1078 sunxi: A20: Enable DM_MMC mmc: sunxi: Add mmc, emmc H5/A64 compatible sunxi: H3_H5: Enable DM_MMC sunxi: A64: Enable DM_MMC ARM: dts: sun8i: Update A83T dts(i) files from Linux mmc: sunxi: Add A83T emmc compatible sunxi: A83T: Enable DM_MMC ARM: dts: sun8i: Update R40 dts(i) files from Linux sunxi: V40: Enable DM_MMC fastboot: sunxi: Update fastboot mmc default device env: sunxi: Update default env fat device sunxi: Use mmc_bootdev=2 for MMC2 boot [DO NOT MERGE] sunxi: A13/A31: Enable DM_MMC [DO NOT MERGE] sunxi: A23/A33/V3S: Enable DM_MMC
arch/arm/dts/axp81x.dtsi | 169 ++++ arch/arm/dts/sun4i-a10-a1000.dts | 5 +- arch/arm/dts/sun4i-a10-ba10-tvbox.dts | 5 +- arch/arm/dts/sun4i-a10-chuwi-v7-cw0825.dts | 5 +- arch/arm/dts/sun4i-a10-cubieboard.dts | 5 +- arch/arm/dts/sun4i-a10-dserve-dsrv9703c.dts | 5 +- arch/arm/dts/sun4i-a10-gemei-g9.dts | 5 +- arch/arm/dts/sun4i-a10-hackberry.dts | 5 +- arch/arm/dts/sun4i-a10-hyundai-a7hd.dts | 5 +- arch/arm/dts/sun4i-a10-inet-3f.dts | 9 + arch/arm/dts/sun4i-a10-inet-3w.dts | 9 + arch/arm/dts/sun4i-a10-inet1.dts | 5 +- arch/arm/dts/sun4i-a10-inet97fv2.dts | 5 +- arch/arm/dts/sun4i-a10-inet9f-rev03.dts | 5 +- .../dts/sun4i-a10-itead-iteaduino-plus.dts | 5 +- arch/arm/dts/sun4i-a10-jesurun-q5.dts | 5 +- arch/arm/dts/sun4i-a10-marsboard.dts | 5 +- arch/arm/dts/sun4i-a10-mini-xplus.dts | 5 +- arch/arm/dts/sun4i-a10-mk802.dts | 5 +- arch/arm/dts/sun4i-a10-mk802ii.dts | 5 +- arch/arm/dts/sun4i-a10-olinuxino-lime.dts | 5 +- arch/arm/dts/sun4i-a10-pcduino.dts | 5 +- arch/arm/dts/sun4i-a10-pov-protab2-ips9.dts | 5 +- arch/arm/dts/sun4i-a10.dtsi | 112 +-- arch/arm/dts/sun7i-a20-ainol-aw1.dts | 13 + arch/arm/dts/sun7i-a20-m5.dts | 12 + arch/arm/dts/sun7i-a20-primo73.dts | 20 +- .../dts/sun7i-a20-yones-toptech-bd1078.dts | 13 + arch/arm/dts/sun7i-a20.dtsi | 102 +- .../dts/sun8i-a83t-allwinner-h8homlet-v2.dts | 195 +++- arch/arm/dts/sun8i-a83t-bananapi-m3.dts | 298 +++++- arch/arm/dts/sun8i-a83t-cubietruck-plus.dts | 322 ++++++- arch/arm/dts/sun8i-a83t-tbs-a711.dts | 355 ++++++- arch/arm/dts/sun8i-a83t.dtsi | 885 ++++++++++++++++-- arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts | 197 +++- arch/arm/dts/sun8i-r40.dtsi | 616 +++++++++++- arch/arm/dts/sun8i-v40-bananapi-m2-berry.dts | 50 + arch/arm/mach-sunxi/Kconfig | 10 + board/sunxi/board.c | 2 +- configs/A20-OLinuXino-Lime2-eMMC_defconfig | 2 + configs/A20-OLinuXino_MICRO-eMMC_defconfig | 1 + configs/A20-OLinuXino_MICRO_defconfig | 1 + configs/A20-Olimex-SOM-EVB_defconfig | 1 + configs/A20-Olimex-SOM204-EVB-eMMC_defconfig | 1 + configs/Mele_M3_defconfig | 1 + configs/Orangepi_mini_defconfig | 1 + configs/Sinlinx_SinA33_defconfig | 2 + configs/Yones_Toptech_BD1078_defconfig | 1 + configs/amarula_a64_relic_defconfig | 2 + drivers/fastboot/Kconfig | 3 +- drivers/mmc/sunxi_mmc.c | 81 +- env/Kconfig | 3 +- include/configs/sunxi-common.h | 4 +- include/dt-bindings/clock/sun4i-a10-ccu.h | 202 ++++ include/dt-bindings/clock/sun7i-a20-ccu.h | 53 ++ include/dt-bindings/clock/sun8i-a83t-ccu.h | 140 +++ include/dt-bindings/reset/sun8i-a83t-ccu.h | 98 ++ 57 files changed, 3715 insertions(+), 371 deletions(-) create mode 100644 arch/arm/dts/axp81x.dtsi create mode 100644 include/dt-bindings/clock/sun4i-a10-ccu.h create mode 100644 include/dt-bindings/clock/sun7i-a20-ccu.h create mode 100644 include/dt-bindings/clock/sun8i-a83t-ccu.h create mode 100644 include/dt-bindings/reset/sun8i-a83t-ccu.h
DM_MMC need MMC nodes in dtsi need to update and follow Linux notation to support dm driven mmc driver. So sync mmc nodes for sun4i-a10 from Linux. This will also useful for CLK driver handling in future.
Last linux commit for sun4i-a10.dtsi: commit 590b0c0cfc6162aeebbf43eaafb9753b56df1532 Author: Pascal Roeleven dev@pascalroeleven.nl Date: Fri Apr 20 12:21:12 2018 +0200
ARM: dts: sun4i: Fix incorrect clocks for displays
Last linux commit for sun4i-a10-ccu.h: commit 4328a2186e5120cfd34c4f04c6e4b7e74fb8b7b4 Author: Jonathan Liu net147@gmail.com Date: Tue Oct 17 20:18:03 2017 +0800
clk: sunxi-ng: sun4i: Export video PLLs
Cc: Adam Sampson ats@offog.org Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/sun4i-a10.dtsi | 112 ++++-------- include/dt-bindings/clock/sun4i-a10-ccu.h | 202 ++++++++++++++++++++++ 2 files changed, 232 insertions(+), 82 deletions(-) create mode 100644 include/dt-bindings/clock/sun4i-a10-ccu.h
diff --git a/arch/arm/dts/sun4i-a10.dtsi b/arch/arm/dts/sun4i-a10.dtsi index 7e7dfc2b43..b58252934b 100644 --- a/arch/arm/dts/sun4i-a10.dtsi +++ b/arch/arm/dts/sun4i-a10.dtsi @@ -47,6 +47,7 @@
#include <dt-bindings/clock/sun4i-a10-pll2.h> #include <dt-bindings/dma/sun4i-a10.h> +#include <dt-bindings/clock/sun4i-a10-ccu.h> #include <dt-bindings/pinctrl/sun4i-a10.h>
/ { @@ -420,46 +421,6 @@ clock-output-names = "ms"; };
- mmc0_clk: clk@01c20088 { - #clock-cells = <1>; - compatible = "allwinner,sun4i-a10-mmc-clk"; - reg = <0x01c20088 0x4>; - clocks = <&osc24M>, <&pll6 1>, <&pll5 1>; - clock-output-names = "mmc0", - "mmc0_output", - "mmc0_sample"; - }; - - mmc1_clk: clk@01c2008c { - #clock-cells = <1>; - compatible = "allwinner,sun4i-a10-mmc-clk"; - reg = <0x01c2008c 0x4>; - clocks = <&osc24M>, <&pll6 1>, <&pll5 1>; - clock-output-names = "mmc1", - "mmc1_output", - "mmc1_sample"; - }; - - mmc2_clk: clk@01c20090 { - #clock-cells = <1>; - compatible = "allwinner,sun4i-a10-mmc-clk"; - reg = <0x01c20090 0x4>; - clocks = <&osc24M>, <&pll6 1>, <&pll5 1>; - clock-output-names = "mmc2", - "mmc2_output", - "mmc2_sample"; - }; - - mmc3_clk: clk@01c20094 { - #clock-cells = <1>; - compatible = "allwinner,sun4i-a10-mmc-clk"; - reg = <0x01c20094 0x4>; - clocks = <&osc24M>, <&pll6 1>, <&pll5 1>; - clock-output-names = "mmc3", - "mmc3_output", - "mmc3_sample"; - }; - ts_clk: clk@01c20098 { #clock-cells = <0>; compatible = "allwinner,sun4i-a10-mod0-clk"; @@ -779,68 +740,46 @@ #size-cells = <0>; };
- mmc0: mmc@01c0f000 { + mmc0: mmc@1c0f000 { compatible = "allwinner,sun4i-a10-mmc"; reg = <0x01c0f000 0x1000>; - clocks = <&ahb_gates 8>, - <&mmc0_clk 0>, - <&mmc0_clk 1>, - <&mmc0_clk 2>; - clock-names = "ahb", - "mmc", - "output", - "sample"; + clocks = <&ccu CLK_AHB_MMC0>, <&ccu CLK_MMC0>; + clock-names = "ahb", "mmc"; interrupts = <32>; + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; };
- mmc1: mmc@01c10000 { + mmc1: mmc@1c10000 { compatible = "allwinner,sun4i-a10-mmc"; reg = <0x01c10000 0x1000>; - clocks = <&ahb_gates 9>, - <&mmc1_clk 0>, - <&mmc1_clk 1>, - <&mmc1_clk 2>; - clock-names = "ahb", - "mmc", - "output", - "sample"; + clocks = <&ccu CLK_AHB_MMC1>, <&ccu CLK_MMC1>; + clock-names = "ahb", "mmc"; interrupts = <33>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; };
- mmc2: mmc@01c11000 { + mmc2: mmc@1c11000 { compatible = "allwinner,sun4i-a10-mmc"; reg = <0x01c11000 0x1000>; - clocks = <&ahb_gates 10>, - <&mmc2_clk 0>, - <&mmc2_clk 1>, - <&mmc2_clk 2>; - clock-names = "ahb", - "mmc", - "output", - "sample"; + clocks = <&ccu CLK_AHB_MMC2>, <&ccu CLK_MMC2>; + clock-names = "ahb", "mmc"; interrupts = <34>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; };
- mmc3: mmc@01c12000 { + mmc3: mmc@1c12000 { compatible = "allwinner,sun4i-a10-mmc"; reg = <0x01c12000 0x1000>; - clocks = <&ahb_gates 11>, - <&mmc3_clk 0>, - <&mmc3_clk 1>, - <&mmc3_clk 2>; - clock-names = "ahb", - "mmc", - "output", - "sample"; + clocks = <&ccu CLK_AHB_MMC3>, <&ccu CLK_MMC3>; + clock-names = "ahb", "mmc"; interrupts = <35>; status = "disabled"; #address-cells = <1>; @@ -956,6 +895,15 @@ #size-cells = <0>; };
+ ccu: clock@1c20000 { + compatible = "allwinner,sun4i-a10-ccu"; + reg = <0x01c20000 0x400>; + clocks = <&osc24M>, <&osc32k>; + clock-names = "hosc", "losc"; + #clock-cells = <1>; + #reset-cells = <1>; + }; + intc: interrupt-controller@01c20400 { compatible = "allwinner,sun4i-a10-ic"; reg = <0x01c20400 0x400>; @@ -1033,12 +981,12 @@ allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; };
- mmc0_pins_a: mmc0@0 { - allwinner,pins = "PF0", "PF1", "PF2", - "PF3", "PF4", "PF5"; - allwinner,function = "mmc0"; - allwinner,drive = <SUN4I_PINCTRL_30_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + mmc0_pins: mmc0-pins { + pins = "PF0", "PF1", "PF2", + "PF3", "PF4", "PF5"; + function = "mmc0"; + drive-strength = <30>; + bias-pull-up; };
mmc0_cd_pin_reference_design: mmc0_cd_pin@0 { diff --git a/include/dt-bindings/clock/sun4i-a10-ccu.h b/include/dt-bindings/clock/sun4i-a10-ccu.h new file mode 100644 index 0000000000..e4fa61be5c --- /dev/null +++ b/include/dt-bindings/clock/sun4i-a10-ccu.h @@ -0,0 +1,202 @@ +/* + * Copyright (C) 2017 Priit Laes plaes@plaes.org + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#ifndef _DT_BINDINGS_CLK_SUN4I_A10_H_ +#define _DT_BINDINGS_CLK_SUN4I_A10_H_ + +#define CLK_HOSC 1 +#define CLK_PLL_VIDEO0_2X 9 +#define CLK_PLL_VIDEO1_2X 18 +#define CLK_CPU 20 + +/* AHB Gates */ +#define CLK_AHB_OTG 26 +#define CLK_AHB_EHCI0 27 +#define CLK_AHB_OHCI0 28 +#define CLK_AHB_EHCI1 29 +#define CLK_AHB_OHCI1 30 +#define CLK_AHB_SS 31 +#define CLK_AHB_DMA 32 +#define CLK_AHB_BIST 33 +#define CLK_AHB_MMC0 34 +#define CLK_AHB_MMC1 35 +#define CLK_AHB_MMC2 36 +#define CLK_AHB_MMC3 37 +#define CLK_AHB_MS 38 +#define CLK_AHB_NAND 39 +#define CLK_AHB_SDRAM 40 +#define CLK_AHB_ACE 41 +#define CLK_AHB_EMAC 42 +#define CLK_AHB_TS 43 +#define CLK_AHB_SPI0 44 +#define CLK_AHB_SPI1 45 +#define CLK_AHB_SPI2 46 +#define CLK_AHB_SPI3 47 +#define CLK_AHB_PATA 48 +#define CLK_AHB_SATA 49 +#define CLK_AHB_GPS 50 +#define CLK_AHB_HSTIMER 51 +#define CLK_AHB_VE 52 +#define CLK_AHB_TVD 53 +#define CLK_AHB_TVE0 54 +#define CLK_AHB_TVE1 55 +#define CLK_AHB_LCD0 56 +#define CLK_AHB_LCD1 57 +#define CLK_AHB_CSI0 58 +#define CLK_AHB_CSI1 59 +#define CLK_AHB_HDMI0 60 +#define CLK_AHB_HDMI1 61 +#define CLK_AHB_DE_BE0 62 +#define CLK_AHB_DE_BE1 63 +#define CLK_AHB_DE_FE0 64 +#define CLK_AHB_DE_FE1 65 +#define CLK_AHB_GMAC 66 +#define CLK_AHB_MP 67 +#define CLK_AHB_GPU 68 + +/* APB0 Gates */ +#define CLK_APB0_CODEC 69 +#define CLK_APB0_SPDIF 70 +#define CLK_APB0_I2S0 71 +#define CLK_APB0_AC97 72 +#define CLK_APB0_I2S1 73 +#define CLK_APB0_PIO 74 +#define CLK_APB0_IR0 75 +#define CLK_APB0_IR1 76 +#define CLK_APB0_I2S2 77 +#define CLK_APB0_KEYPAD 78 + +/* APB1 Gates */ +#define CLK_APB1_I2C0 79 +#define CLK_APB1_I2C1 80 +#define CLK_APB1_I2C2 81 +#define CLK_APB1_I2C3 82 +#define CLK_APB1_CAN 83 +#define CLK_APB1_SCR 84 +#define CLK_APB1_PS20 85 +#define CLK_APB1_PS21 86 +#define CLK_APB1_I2C4 87 +#define CLK_APB1_UART0 88 +#define CLK_APB1_UART1 89 +#define CLK_APB1_UART2 90 +#define CLK_APB1_UART3 91 +#define CLK_APB1_UART4 92 +#define CLK_APB1_UART5 93 +#define CLK_APB1_UART6 94 +#define CLK_APB1_UART7 95 + +/* IP clocks */ +#define CLK_NAND 96 +#define CLK_MS 97 +#define CLK_MMC0 98 +#define CLK_MMC0_OUTPUT 99 +#define CLK_MMC0_SAMPLE 100 +#define CLK_MMC1 101 +#define CLK_MMC1_OUTPUT 102 +#define CLK_MMC1_SAMPLE 103 +#define CLK_MMC2 104 +#define CLK_MMC2_OUTPUT 105 +#define CLK_MMC2_SAMPLE 106 +#define CLK_MMC3 107 +#define CLK_MMC3_OUTPUT 108 +#define CLK_MMC3_SAMPLE 109 +#define CLK_TS 110 +#define CLK_SS 111 +#define CLK_SPI0 112 +#define CLK_SPI1 113 +#define CLK_SPI2 114 +#define CLK_PATA 115 +#define CLK_IR0 116 +#define CLK_IR1 117 +#define CLK_I2S0 118 +#define CLK_AC97 119 +#define CLK_SPDIF 120 +#define CLK_KEYPAD 121 +#define CLK_SATA 122 +#define CLK_USB_OHCI0 123 +#define CLK_USB_OHCI1 124 +#define CLK_USB_PHY 125 +#define CLK_GPS 126 +#define CLK_SPI3 127 +#define CLK_I2S1 128 +#define CLK_I2S2 129 + +/* DRAM Gates */ +#define CLK_DRAM_VE 130 +#define CLK_DRAM_CSI0 131 +#define CLK_DRAM_CSI1 132 +#define CLK_DRAM_TS 133 +#define CLK_DRAM_TVD 134 +#define CLK_DRAM_TVE0 135 +#define CLK_DRAM_TVE1 136 +#define CLK_DRAM_OUT 137 +#define CLK_DRAM_DE_FE1 138 +#define CLK_DRAM_DE_FE0 139 +#define CLK_DRAM_DE_BE0 140 +#define CLK_DRAM_DE_BE1 141 +#define CLK_DRAM_MP 142 +#define CLK_DRAM_ACE 143 + +/* Display Engine Clocks */ +#define CLK_DE_BE0 144 +#define CLK_DE_BE1 145 +#define CLK_DE_FE0 146 +#define CLK_DE_FE1 147 +#define CLK_DE_MP 148 +#define CLK_TCON0_CH0 149 +#define CLK_TCON1_CH0 150 +#define CLK_CSI_SCLK 151 +#define CLK_TVD_SCLK2 152 +#define CLK_TVD 153 +#define CLK_TCON0_CH1_SCLK2 154 +#define CLK_TCON0_CH1 155 +#define CLK_TCON1_CH1_SCLK2 156 +#define CLK_TCON1_CH1 157 +#define CLK_CSI0 158 +#define CLK_CSI1 159 +#define CLK_CODEC 160 +#define CLK_VE 161 +#define CLK_AVS 162 +#define CLK_ACE 163 +#define CLK_HDMI 164 +#define CLK_GPU 165 + +#endif /* _DT_BINDINGS_CLK_SUN4I_A10_H_ */
Can't we just sync all the A10 DTs in one go to the latest kernel release, instead of half doing the work with a random commit?
Maxime
On Mon, Jul 16, 2018 at 3:00 PM, Maxime Ripard maxime.ripard@bootlin.com wrote:
Now we need only minimal changes in dtsi, no need for board dts files to update for sun4i. All DT sync from Linux not require here at this point of time. even the subsequent patches will add only mmc0 node in dts files which are not available in Linux.
Why? A DT is an hardware description, the hardware doesn't change between U-Boot and Linux.
Maxime
Since sun4i-a10.dtsi synced from Linux, for compatibility sync sun4i-a10 board mmc0 nodes from Linux.
Last linux commit for sun4i-a10*.dts commit 190e3138f9577885691540dca59c2f07540bde04 Merge: cafc87023b0d a7affb13b271 Author: Arnd Bergmann arnd@arndb.de Date: Tue Mar 27 14:58:00 2018 +0200
Merge tag 'sunxi-h3-h5-for-4.17' of ssh://gitolite.kernel.org/pub/scm/linux/kernel/git/sunxi/linux into next/dt
Cc: Adam Sampson ats@offog.org Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/sun4i-a10-a1000.dts | 5 +---- arch/arm/dts/sun4i-a10-ba10-tvbox.dts | 5 +---- arch/arm/dts/sun4i-a10-chuwi-v7-cw0825.dts | 5 +---- arch/arm/dts/sun4i-a10-cubieboard.dts | 5 +---- arch/arm/dts/sun4i-a10-dserve-dsrv9703c.dts | 5 +---- arch/arm/dts/sun4i-a10-gemei-g9.dts | 5 +---- arch/arm/dts/sun4i-a10-hackberry.dts | 5 +---- arch/arm/dts/sun4i-a10-hyundai-a7hd.dts | 5 +---- arch/arm/dts/sun4i-a10-inet1.dts | 5 +---- arch/arm/dts/sun4i-a10-inet97fv2.dts | 5 +---- arch/arm/dts/sun4i-a10-inet9f-rev03.dts | 5 +---- arch/arm/dts/sun4i-a10-itead-iteaduino-plus.dts | 5 +---- arch/arm/dts/sun4i-a10-jesurun-q5.dts | 5 +---- arch/arm/dts/sun4i-a10-marsboard.dts | 5 +---- arch/arm/dts/sun4i-a10-mini-xplus.dts | 5 +---- arch/arm/dts/sun4i-a10-mk802.dts | 5 +---- arch/arm/dts/sun4i-a10-mk802ii.dts | 5 +---- arch/arm/dts/sun4i-a10-olinuxino-lime.dts | 5 +---- arch/arm/dts/sun4i-a10-pcduino.dts | 5 +---- arch/arm/dts/sun4i-a10-pov-protab2-ips9.dts | 5 +---- 20 files changed, 20 insertions(+), 80 deletions(-)
diff --git a/arch/arm/dts/sun4i-a10-a1000.dts b/arch/arm/dts/sun4i-a10-a1000.dts index 39e368ec34..52ce35508f 100644 --- a/arch/arm/dts/sun4i-a10-a1000.dts +++ b/arch/arm/dts/sun4i-a10-a1000.dts @@ -167,12 +167,9 @@ };
&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_reference_design>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; - cd-gpios = <&pio 7 1 GPIO_ACTIVE_HIGH>; /* PH1 */ - cd-inverted; + cd-gpios = <&pio 7 1 GPIO_ACTIVE_LOW>; /* PH1 */ status = "okay"; };
diff --git a/arch/arm/dts/sun4i-a10-ba10-tvbox.dts b/arch/arm/dts/sun4i-a10-ba10-tvbox.dts index f3cb297fd1..414db62310 100644 --- a/arch/arm/dts/sun4i-a10-ba10-tvbox.dts +++ b/arch/arm/dts/sun4i-a10-ba10-tvbox.dts @@ -108,12 +108,9 @@ };
diff --git a/arch/arm/dts/sun4i-a10-chuwi-v7-cw0825.dts b/arch/arm/dts/sun4i-a10-chuwi-v7-cw0825.dts index 023b03efa5..14ad14bfbe 100644 --- a/arch/arm/dts/sun4i-a10-chuwi-v7-cw0825.dts +++ b/arch/arm/dts/sun4i-a10-chuwi-v7-cw0825.dts @@ -127,12 +127,9 @@ };
diff --git a/arch/arm/dts/sun4i-a10-cubieboard.dts b/arch/arm/dts/sun4i-a10-cubieboard.dts index 710e2ef516..713157d967 100644 --- a/arch/arm/dts/sun4i-a10-cubieboard.dts +++ b/arch/arm/dts/sun4i-a10-cubieboard.dts @@ -142,12 +142,9 @@ };
diff --git a/arch/arm/dts/sun4i-a10-dserve-dsrv9703c.dts b/arch/arm/dts/sun4i-a10-dserve-dsrv9703c.dts index 893497e397..f5334056ca 100644 --- a/arch/arm/dts/sun4i-a10-dserve-dsrv9703c.dts +++ b/arch/arm/dts/sun4i-a10-dserve-dsrv9703c.dts @@ -163,12 +163,9 @@ };
diff --git a/arch/arm/dts/sun4i-a10-gemei-g9.dts b/arch/arm/dts/sun4i-a10-gemei-g9.dts index ac64781a0a..a4e2d45249 100644 --- a/arch/arm/dts/sun4i-a10-gemei-g9.dts +++ b/arch/arm/dts/sun4i-a10-gemei-g9.dts @@ -145,12 +145,9 @@ };
&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_reference_design>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; - cd-gpios = <&pio 7 1 GPIO_ACTIVE_HIGH>; /* PH01 */ - cd-inverted; + cd-gpios = <&pio 7 1 GPIO_ACTIVE_LOW>; /* PH01 */ status = "okay"; };
diff --git a/arch/arm/dts/sun4i-a10-hackberry.dts b/arch/arm/dts/sun4i-a10-hackberry.dts index 6de83a6187..ac8939f985 100644 --- a/arch/arm/dts/sun4i-a10-hackberry.dts +++ b/arch/arm/dts/sun4i-a10-hackberry.dts @@ -107,12 +107,9 @@ };
diff --git a/arch/arm/dts/sun4i-a10-hyundai-a7hd.dts b/arch/arm/dts/sun4i-a10-hyundai-a7hd.dts index 9103864fef..6904c55e74 100644 --- a/arch/arm/dts/sun4i-a10-hyundai-a7hd.dts +++ b/arch/arm/dts/sun4i-a10-hyundai-a7hd.dts @@ -78,12 +78,9 @@ };
diff --git a/arch/arm/dts/sun4i-a10-inet1.dts b/arch/arm/dts/sun4i-a10-inet1.dts index e09053bf5e..542816a8dc 100644 --- a/arch/arm/dts/sun4i-a10-inet1.dts +++ b/arch/arm/dts/sun4i-a10-inet1.dts @@ -161,12 +161,9 @@ };
diff --git a/arch/arm/dts/sun4i-a10-inet97fv2.dts b/arch/arm/dts/sun4i-a10-inet97fv2.dts index 04b0d2d1ae..8624fe1fa3 100644 --- a/arch/arm/dts/sun4i-a10-inet97fv2.dts +++ b/arch/arm/dts/sun4i-a10-inet97fv2.dts @@ -146,12 +146,9 @@ };
diff --git a/arch/arm/dts/sun4i-a10-inet9f-rev03.dts b/arch/arm/dts/sun4i-a10-inet9f-rev03.dts index bba4f9cf9b..3d36c0e060 100644 --- a/arch/arm/dts/sun4i-a10-inet9f-rev03.dts +++ b/arch/arm/dts/sun4i-a10-inet9f-rev03.dts @@ -305,12 +305,9 @@ };
diff --git a/arch/arm/dts/sun4i-a10-itead-iteaduino-plus.dts b/arch/arm/dts/sun4i-a10-itead-iteaduino-plus.dts index 4e798f014c..0336333908 100644 --- a/arch/arm/dts/sun4i-a10-itead-iteaduino-plus.dts +++ b/arch/arm/dts/sun4i-a10-itead-iteaduino-plus.dts @@ -99,12 +99,9 @@ };
diff --git a/arch/arm/dts/sun4i-a10-jesurun-q5.dts b/arch/arm/dts/sun4i-a10-jesurun-q5.dts index e28f080b1f..3218a45e81 100644 --- a/arch/arm/dts/sun4i-a10-jesurun-q5.dts +++ b/arch/arm/dts/sun4i-a10-jesurun-q5.dts @@ -140,12 +140,9 @@ };
diff --git a/arch/arm/dts/sun4i-a10-marsboard.dts b/arch/arm/dts/sun4i-a10-marsboard.dts index 8e50723dbe..5c82b639c3 100644 --- a/arch/arm/dts/sun4i-a10-marsboard.dts +++ b/arch/arm/dts/sun4i-a10-marsboard.dts @@ -141,12 +141,9 @@ };
diff --git a/arch/arm/dts/sun4i-a10-mini-xplus.dts b/arch/arm/dts/sun4i-a10-mini-xplus.dts index a7dd86d30f..958b6b984e 100644 --- a/arch/arm/dts/sun4i-a10-mini-xplus.dts +++ b/arch/arm/dts/sun4i-a10-mini-xplus.dts @@ -97,12 +97,9 @@ };
diff --git a/arch/arm/dts/sun4i-a10-mk802.dts b/arch/arm/dts/sun4i-a10-mk802.dts index ee46ea8548..beac451356 100644 --- a/arch/arm/dts/sun4i-a10-mk802.dts +++ b/arch/arm/dts/sun4i-a10-mk802.dts @@ -72,12 +72,9 @@ };
diff --git a/arch/arm/dts/sun4i-a10-mk802ii.dts b/arch/arm/dts/sun4i-a10-mk802ii.dts index c861fa7e35..857384ad78 100644 --- a/arch/arm/dts/sun4i-a10-mk802ii.dts +++ b/arch/arm/dts/sun4i-a10-mk802ii.dts @@ -82,12 +82,9 @@ };
diff --git a/arch/arm/dts/sun4i-a10-olinuxino-lime.dts b/arch/arm/dts/sun4i-a10-olinuxino-lime.dts index b350448c72..3e93ebc93e 100644 --- a/arch/arm/dts/sun4i-a10-olinuxino-lime.dts +++ b/arch/arm/dts/sun4i-a10-olinuxino-lime.dts @@ -145,12 +145,9 @@ };
diff --git a/arch/arm/dts/sun4i-a10-pcduino.dts b/arch/arm/dts/sun4i-a10-pcduino.dts index 39034aa8e1..aa3ffb2b2b 100644 --- a/arch/arm/dts/sun4i-a10-pcduino.dts +++ b/arch/arm/dts/sun4i-a10-pcduino.dts @@ -147,12 +147,9 @@ };
diff --git a/arch/arm/dts/sun4i-a10-pov-protab2-ips9.dts b/arch/arm/dts/sun4i-a10-pov-protab2-ips9.dts index ea90634e48..6bd3bc0863 100644 --- a/arch/arm/dts/sun4i-a10-pov-protab2-ips9.dts +++ b/arch/arm/dts/sun4i-a10-pov-protab2-ips9.dts @@ -156,12 +156,9 @@ };
Since SUN4I moved to DM_MMC, we need to have mmc node in iNet 3F DT otherwise it will not probe.
Cc: Paul Kocialkowski contact@paulk.fr Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/sun4i-a10-inet-3f.dts | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/arm/dts/sun4i-a10-inet-3f.dts b/arch/arm/dts/sun4i-a10-inet-3f.dts index f815b83157..4ebf206c4a 100644 --- a/arch/arm/dts/sun4i-a10-inet-3f.dts +++ b/arch/arm/dts/sun4i-a10-inet-3f.dts @@ -7,6 +7,8 @@
/dts-v1/; #include "sun4i-a10.dtsi" +#include "sunxi-common-regulators.dtsi" +#include <dt-bindings/gpio/gpio.h>
/ { model = "iNet 3F"; @@ -21,6 +23,13 @@ }; };
+&mmc0 { + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + cd-gpios = <&pio 7 1 GPIO_ACTIVE_LOW>; /* PH1 */ + status = "okay"; +}; + &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_pins_a>;
Since SUN4I moved to DM_MMC, we need to have mmc node in iNet 3W DT otherwise it will not probe.
Cc: Paul Kocialkowski contact@paulk.fr Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/sun4i-a10-inet-3w.dts | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/arm/dts/sun4i-a10-inet-3w.dts b/arch/arm/dts/sun4i-a10-inet-3w.dts index d0267ceee9..4168e2c0d0 100644 --- a/arch/arm/dts/sun4i-a10-inet-3w.dts +++ b/arch/arm/dts/sun4i-a10-inet-3w.dts @@ -7,6 +7,8 @@
/ { model = "iNet 3W"; @@ -21,6 +23,13 @@ }; };
+&mmc0 { + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + cd-gpios = <&pio 7 20 GPIO_ACTIVE_LOW>; /* PH20 */ + status = "okay"; +}; + &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_pins_a>;
Clocks phandle notations in U-Boot for higher Allwinner SoC start from sun8i, sun50i are following Linux notation to sync with common node definition along with proper clock driver handling.
So refactor the ahb gate, clock setup to handle all type of Allwinner SoCs. Since we don't have proper CLK driver yet, this code using driver data to differentiate require SoC specific data.
This require existing U-Boot mmc DT nodes need to sync with Linux and the subsequent patches are doing the same.
Cc: Simon Glass sjg@chromium.org Cc: Jaehoon Chung jh80.chung@samsung.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/mmc/sunxi_mmc.c | 39 ++++++++++++++++++++++++++++----------- 1 file changed, 28 insertions(+), 11 deletions(-)
diff --git a/drivers/mmc/sunxi_mmc.c b/drivers/mmc/sunxi_mmc.c index 7fa1ae8b16..38171b81f3 100644 --- a/drivers/mmc/sunxi_mmc.c +++ b/drivers/mmc/sunxi_mmc.c @@ -569,8 +569,8 @@ static int sunxi_mmc_probe(struct udevice *dev) struct sunxi_mmc_plat *plat = dev_get_platdata(dev); struct sunxi_mmc_priv *priv = dev_get_priv(dev); struct mmc_config *cfg = &plat->cfg; + struct sunxi_ccm_reg *ccm; struct ofnode_phandle_args args; - u32 *gate_reg; int bus_width, ret;
cfg->name = dev->name; @@ -589,21 +589,38 @@ static int sunxi_mmc_probe(struct udevice *dev) cfg->f_max = 52000000;
priv->reg = (void *)dev_read_addr(dev); + priv->mmc_no = (((uintptr_t)priv->reg / 0x1000) - 0x1C0F);
- /* We don't have a sunxi clock driver so find the clock address here */ ret = dev_read_phandle_with_args(dev, "clocks", "#clock-cells", 0, - 1, &args); + 0, &args); if (ret) return ret; - priv->mclkreg = (u32 *)ofnode_get_addr(args.node);
- ret = dev_read_phandle_with_args(dev, "clocks", "#clock-cells", 0, - 0, &args); - if (ret) - return ret; - gate_reg = (u32 *)ofnode_get_addr(args.node); - setbits_le32(gate_reg, 1 << args.args[0]); - priv->mmc_no = args.args[0] - 8; + ccm = (struct sunxi_ccm_reg *)ofnode_get_addr(args.node); + if (IS_ERR(ccm)) + return PTR_ERR(ccm); + + /* enable ahb gate */ + setbits_le32(&ccm->ahb_gate0, BIT(AHB_GATE_OFFSET_MMC(priv->mmc_no))); + + /* find clock reg */ + switch (priv->mmc_no) { + case 0: + priv->mclkreg = &ccm->sd0_clk_cfg; + break; + case 1: + priv->mclkreg = &ccm->sd1_clk_cfg; + break; + case 2: + priv->mclkreg = &ccm->sd2_clk_cfg; + break; + case 3: + priv->mclkreg = &ccm->sd3_clk_cfg; + break; + default: + printf("Wrong mmc number %d\n", priv->mmc_no); + return -EINVAL; + }
ret = mmc_set_mod_clk(priv, 24000000); if (ret)
AHB reset0 is needed for Allwinner start from sun6i, so add driver data configuration for ahb reset0 and update the register bits during probe.
Cc: Jaehoon Chung jh80.chung@samsung.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/mmc/sunxi_mmc.c | 36 +++++++++++++++++++++++++++++++++--- 1 file changed, 33 insertions(+), 3 deletions(-)
diff --git a/drivers/mmc/sunxi_mmc.c b/drivers/mmc/sunxi_mmc.c index 38171b81f3..beeded50af 100644 --- a/drivers/mmc/sunxi_mmc.c +++ b/drivers/mmc/sunxi_mmc.c @@ -30,6 +30,7 @@ struct sunxi_mmc_priv { unsigned fatal_err; struct gpio_desc cd_gpio; /* Change Detect GPIO */ int cd_inverted; /* Inverted Card Detect */ + u32 *reg_reset0; struct sunxi_mmc *reg; struct mmc_config cfg; }; @@ -528,6 +529,14 @@ struct mmc *sunxi_mmc_init(int sdc_no) } #else
+#define OFF_SUN6I_AHB_RESET0 0x2c0 + +struct sunxi_mmc_config { + bool has_reset0; + u8 pos_reset0; + u32 off_reset0; +}; + static int sunxi_mmc_set_ios(struct udevice *dev) { struct sunxi_mmc_plat *plat = dev_get_platdata(dev); @@ -569,6 +578,7 @@ static int sunxi_mmc_probe(struct udevice *dev) struct sunxi_mmc_plat *plat = dev_get_platdata(dev); struct sunxi_mmc_priv *priv = dev_get_priv(dev); struct mmc_config *cfg = &plat->cfg; + const struct sunxi_mmc_config *data; struct sunxi_ccm_reg *ccm; struct ofnode_phandle_args args; int bus_width, ret; @@ -588,6 +598,7 @@ static int sunxi_mmc_probe(struct udevice *dev) cfg->f_min = 400000; cfg->f_max = 52000000;
+ data = (struct sunxi_mmc_config *)dev_get_driver_data(dev); priv->reg = (void *)dev_read_addr(dev); priv->mmc_no = (((uintptr_t)priv->reg / 0x1000) - 0x1C0F);
@@ -600,9 +611,15 @@ static int sunxi_mmc_probe(struct udevice *dev) if (IS_ERR(ccm)) return PTR_ERR(ccm);
+ priv->reg_reset0 = (void *)ccm + data->off_reset0; + /* enable ahb gate */ setbits_le32(&ccm->ahb_gate0, BIT(AHB_GATE_OFFSET_MMC(priv->mmc_no)));
+ /* unassert reset */ + if (data->has_reset0) + setbits_le32(priv->reg_reset0, BIT(data->pos_reset0 + priv->mmc_no)); + /* find clock reg */ switch (priv->mmc_no) { case 0: @@ -653,10 +670,23 @@ static int sunxi_mmc_bind(struct udevice *dev) return mmc_bind(dev, &plat->mmc, &plat->cfg); }
+static const struct sunxi_mmc_config sun4i_a10_cfg = { + .has_reset0 = false, +}; + +static const struct sunxi_mmc_config sun7i_a20_cfg = { + .has_reset0 = true, + .pos_reset0 = 8, + .off_reset0 = OFF_SUN6I_AHB_RESET0, +}; + static const struct udevice_id sunxi_mmc_ids[] = { - { .compatible = "allwinner,sun4i-a10-mmc" }, - { .compatible = "allwinner,sun5i-a13-mmc" }, - { .compatible = "allwinner,sun7i-a20-mmc" }, + { .compatible = "allwinner,sun4i-a10-mmc", + .data = (ulong)&sun4i_a10_cfg }, + { .compatible = "allwinner,sun5i-a13-mmc", + .data = (ulong)&sun4i_a10_cfg }, + { .compatible = "allwinner,sun7i-a20-mmc", + .data = (ulong)&sun7i_a20_cfg }, { } };
- u32 *reg_reset0; struct sunxi_mmc *reg; struct mmc_config cfg;
- bool has_reset0;
- u8 pos_reset0;
- u32 off_reset0;
- const struct sunxi_mmc_config *data; struct sunxi_ccm_reg *ccm; struct ofnode_phandle_args args; int bus_width, ret;
- data = (struct sunxi_mmc_config *)dev_get_driver_data(dev); priv->reg = (void *)dev_read_addr(dev); priv->mmc_no = (((uintptr_t)priv->reg / 0x1000) - 0x1C0F);
- .has_reset0 = false,
- .has_reset0 = true,
- .pos_reset0 = 8,
- .off_reset0 = OFF_SUN6I_AHB_RESET0,
Nope. The A20 doesn't have any reset line.
Maxime
On Mon, Jul 16, 2018 at 3:09 PM, Maxime Ripard maxime.ripard@bootlin.com wrote:
bool has_reset0;
u8 pos_reset0;
u32 off_reset0;
.has_reset0 = true,
.pos_reset0 = 8,
Yes, I know. but sun6i-a31 has it and share same compatible allwinner,sun7i-a20-mmc ie reason I've attached driver data.
bool has_reset0;
u8 pos_reset0;
u32 off_reset0;
.has_reset0 = true,
.pos_reset0 = 8,
That doesn't make it more correct. The A20 doesn't have a reset line, I don't see any good reason to imply this.
Maxime
On Mon, Jul 16, 2018 at 3:32 PM, Maxime Ripard maxime.ripard@bootlin.com wrote:
bool has_reset0;
u8 pos_reset0;
u32 off_reset0;
.has_reset0 = true,
.pos_reset0 = 8,
OK, let me know if you have any suggestion on this I will remove this for A20.
bool has_reset0;
u8 pos_reset0;
u32 off_reset0;
.has_reset0 = true,
.pos_reset0 = 8,
Use the A31 name and tie it to the matching compatible instead?
DM_MMC need MMC nodes in dtsi need to update and follow Linux notation to support dm driven mmc driver. So sync mmc nodes for sun7i-a20 from Linux. This will also useful for CLK driver handling in future.
Last linux commit for sun7i-a20.dtsi: commit e3b742026b92a141b43560858b089921953a63de Author: Viresh Kumar viresh.kumar@linaro.org Date: Tue Jun 5 10:17:49 2018 +0530
ARM: dts: sunxi: Add missing cooling device properties for CPUs
Last linux commit for sun7i-a20-ccu.h: commit c84f5683f6e9fee78e054431d89121225ccb7464 Author: Priit Laes plaes@plaes.org Date: Wed Aug 23 20:23:29 2017 +0300
clk: sunxi-ng: Add sun4i/sun7i CCU driver
Cc: Stefan Mavrodiev stefan@olimex.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/sun7i-a20.dtsi | 102 ++++++++-------------- include/dt-bindings/clock/sun7i-a20-ccu.h | 53 +++++++++++ 2 files changed, 87 insertions(+), 68 deletions(-) create mode 100644 include/dt-bindings/clock/sun7i-a20-ccu.h
diff --git a/arch/arm/dts/sun7i-a20.dtsi b/arch/arm/dts/sun7i-a20.dtsi index 4394711e5a..620e4d5a21 100644 --- a/arch/arm/dts/sun7i-a20.dtsi +++ b/arch/arm/dts/sun7i-a20.dtsi @@ -49,6 +49,7 @@
#include <dt-bindings/clock/sun4i-a10-pll2.h> #include <dt-bindings/dma/sun4i-a10.h> +#include <dt-bindings/clock/sun7i-a20-ccu.h> #include <dt-bindings/pinctrl/sun4i-a10.h>
/ { @@ -419,46 +420,6 @@ clock-output-names = "ms"; };
- mmc0_clk: clk@01c20088 { - #clock-cells = <1>; - compatible = "allwinner,sun4i-a10-mmc-clk"; - reg = <0x01c20088 0x4>; - clocks = <&osc24M>, <&pll6 1>, <&pll5 1>; - clock-output-names = "mmc0", - "mmc0_output", - "mmc0_sample"; - }; - - mmc1_clk: clk@01c2008c { - #clock-cells = <1>; - compatible = "allwinner,sun4i-a10-mmc-clk"; - reg = <0x01c2008c 0x4>; - clocks = <&osc24M>, <&pll6 1>, <&pll5 1>; - clock-output-names = "mmc1", - "mmc1_output", - "mmc1_sample"; - }; - - mmc2_clk: clk@01c20090 { - #clock-cells = <1>; - compatible = "allwinner,sun4i-a10-mmc-clk"; - reg = <0x01c20090 0x4>; - clocks = <&osc24M>, <&pll6 1>, <&pll5 1>; - clock-output-names = "mmc2", - "mmc2_output", - "mmc2_sample"; - }; - - mmc3_clk: clk@01c20094 { - #clock-cells = <1>; - compatible = "allwinner,sun4i-a10-mmc-clk"; - reg = <0x01c20094 0x4>; - clocks = <&osc24M>, <&pll6 1>, <&pll5 1>; - clock-output-names = "mmc3", - "mmc3_output", - "mmc3_sample"; - }; - ts_clk: clk@01c20098 { #clock-cells = <0>; compatible = "allwinner,sun4i-a10-mod0-clk"; @@ -904,14 +865,13 @@ #size-cells = <0>; };
- mmc0: mmc@01c0f000 { - compatible = "allwinner,sun7i-a20-mmc", - "allwinner,sun5i-a13-mmc"; + mmc0: mmc@1c0f000 { + compatible = "allwinner,sun7i-a20-mmc"; reg = <0x01c0f000 0x1000>; - clocks = <&ahb_gates 8>, - <&mmc0_clk 0>, - <&mmc0_clk 1>, - <&mmc0_clk 2>; + clocks = <&ccu CLK_AHB_MMC0>, + <&ccu CLK_MMC0>, + <&ccu CLK_MMC0_OUTPUT>, + <&ccu CLK_MMC0_SAMPLE>; clock-names = "ahb", "mmc", "output", @@ -922,14 +882,13 @@ #size-cells = <0>; };
- mmc1: mmc@01c10000 { - compatible = "allwinner,sun7i-a20-mmc", - "allwinner,sun5i-a13-mmc"; + mmc1: mmc@1c10000 { + compatible = "allwinner,sun7i-a20-mmc"; reg = <0x01c10000 0x1000>; - clocks = <&ahb_gates 9>, - <&mmc1_clk 0>, - <&mmc1_clk 1>, - <&mmc1_clk 2>; + clocks = <&ccu CLK_AHB_MMC1>, + <&ccu CLK_MMC1>, + <&ccu CLK_MMC1_OUTPUT>, + <&ccu CLK_MMC1_SAMPLE>; clock-names = "ahb", "mmc", "output", @@ -940,14 +899,13 @@ #size-cells = <0>; };
- mmc2: mmc@01c11000 { - compatible = "allwinner,sun7i-a20-mmc", - "allwinner,sun5i-a13-mmc"; + mmc2: mmc@1c11000 { + compatible = "allwinner,sun7i-a20-mmc"; reg = <0x01c11000 0x1000>; - clocks = <&ahb_gates 10>, - <&mmc2_clk 0>, - <&mmc2_clk 1>, - <&mmc2_clk 2>; + clocks = <&ccu CLK_AHB_MMC2>, + <&ccu CLK_MMC2>, + <&ccu CLK_MMC2_OUTPUT>, + <&ccu CLK_MMC2_SAMPLE>; clock-names = "ahb", "mmc", "output", @@ -958,14 +916,13 @@ #size-cells = <0>; };
- mmc3: mmc@01c12000 { - compatible = "allwinner,sun7i-a20-mmc", - "allwinner,sun5i-a13-mmc"; + mmc3: mmc@1c12000 { + compatible = "allwinner,sun7i-a20-mmc"; reg = <0x01c12000 0x1000>; - clocks = <&ahb_gates 11>, - <&mmc3_clk 0>, - <&mmc3_clk 1>, - <&mmc3_clk 2>; + clocks = <&ccu CLK_AHB_MMC3>, + <&ccu CLK_MMC3>, + <&ccu CLK_MMC3_OUTPUT>, + <&ccu CLK_MMC3_SAMPLE>; clock-names = "ahb", "mmc", "output", @@ -1085,6 +1042,15 @@ #size-cells = <0>; };
+ ccu: clock@1c20000 { + compatible = "allwinner,sun7i-a20-ccu"; + reg = <0x01c20000 0x400>; + clocks = <&osc24M>, <&osc32k>; + clock-names = "hosc", "losc"; + #clock-cells = <1>; + #reset-cells = <1>; + }; + pio: pinctrl@01c20800 { compatible = "allwinner,sun7i-a20-pinctrl"; reg = <0x01c20800 0x400>; diff --git a/include/dt-bindings/clock/sun7i-a20-ccu.h b/include/dt-bindings/clock/sun7i-a20-ccu.h new file mode 100644 index 0000000000..045a5178da --- /dev/null +++ b/include/dt-bindings/clock/sun7i-a20-ccu.h @@ -0,0 +1,53 @@ +/* + * Copyright (C) 2017 Priit Laes plaes@plaes.org + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#ifndef _DT_BINDINGS_CLK_SUN7I_A20_H_ +#define _DT_BINDINGS_CLK_SUN7I_A20_H_ + +#include <dt-bindings/clock/sun4i-a10-ccu.h> + +#define CLK_MBUS 166 +#define CLK_HDMI1_SLOW 167 +#define CLK_HDMI1 168 +#define CLK_OUT_A 169 +#define CLK_OUT_B 170 + +#endif /* _DT_BINDINGS_CLK_SUN7I_A20_H_ */
Reuse mmc0 node from sun7i-a20.dtsi like other board dts files for Primo73 tablet dts file, and drop in dts mmc0 definition.
Cc: Siarhei Siamashka siarhei.siamashka@gmail.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/sun7i-a20-primo73.dts | 20 ++++++++++---------- 1 file changed, 10 insertions(+), 10 deletions(-)
diff --git a/arch/arm/dts/sun7i-a20-primo73.dts b/arch/arm/dts/sun7i-a20-primo73.dts index 0658f82675..942a955309 100644 --- a/arch/arm/dts/sun7i-a20-primo73.dts +++ b/arch/arm/dts/sun7i-a20-primo73.dts @@ -62,16 +62,6 @@ };
soc@01c00000 { - mmc0: mmc@01c0f000 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_reference_design>; - vmmc-supply = <®_vcc3v3>; - bus-width = <4>; - cd-gpios = <&pio 7 1 0>; /* PH1 */ - cd-inverted; - status = "okay"; - }; - usbphy: phy@01c13400 { usb2_vbus-supply = <®_usb2_vbus>; status = "okay"; @@ -100,3 +90,13 @@ status = "okay"; }; }; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_reference_design>; + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + cd-gpios = <&pio 7 1 GPIO_ACTIVE_HIGH>; /* PH1 */ + cd-inverted; + status = "okay"; +};
soc@01c00000 {
bus-width = <4>;
cd-inverted;
status = "okay";
+&mmc0 {
- bus-width = <4>;
- cd-inverted;
- status = "okay";
You're not adding the node, you're just moving it around.
Maxime
On Mon, Jul 16, 2018 at 3:10 PM, Maxime Ripard maxime.ripard@bootlin.com wrote:
soc@01c00000 {
bus-width = <4>;
cd-inverted;
status = "okay";
+&mmc0 {
bus-width = <4>;
cd-inverted;
status = "okay";
ie what I mentioned on the commit message. adding mmc0 node like other board dts files and removing in dts mmc0 node definition.
soc@01c00000 {
bus-width = <4>;
cd-inverted;
status = "okay";
+&mmc0 {
bus-width = <4>;
cd-inverted;
status = "okay";
If you understand the device tree, you'll know that they are one and the same. They compile down to the same node. Otherwise the original pattern wouldn't work.
The commit message should read something more like:
xxx: Convert to DT label based syntax
In order to lessen the amount of duplication of the DT tree, ease the new and follow the trend that prefers to use label based references when overriding DTSI nodes, convert the board to this syntax
This was the commit message in a whole slew of patches that Maxime did to convert all the sunxi device tree files in the kernel.
Better yet, just drop all these conversion patches and just sync up to Linux 4.18-rc1.
ChenYu
Since SUN7I moved to DM_MMC, we need to have mmc node in Ainol AW1 DT otherwise it will not probe.
Cc: Paul Kocialkowski contact@paulk.fr Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/sun7i-a20-ainol-aw1.dts | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/arch/arm/dts/sun7i-a20-ainol-aw1.dts b/arch/arm/dts/sun7i-a20-ainol-aw1.dts index 57fe0066cb..3831adc88d 100644 --- a/arch/arm/dts/sun7i-a20-ainol-aw1.dts +++ b/arch/arm/dts/sun7i-a20-ainol-aw1.dts @@ -7,6 +7,9 @@
/dts-v1/; #include "sun7i-a20.dtsi" +#include "sunxi-common-regulators.dtsi" + +#include <dt-bindings/gpio/gpio.h>
/ { model = "Ainol AW1"; @@ -21,6 +24,16 @@ }; };
+&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_reference_design>; + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + cd-gpios = <&pio 7 1 GPIO_ACTIVE_HIGH>; /* PH1 */ + cd-inverted; + status = "okay"; +}; + &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_pins_a>;
Since SUN7I moved to DM_MMC, we need to have mmc node in Mele M5 DT otherwise it will not probe.
Cc: Ian Campbell ijc@hellion.org.uk Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/sun7i-a20-m5.dts | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/arch/arm/dts/sun7i-a20-m5.dts b/arch/arm/dts/sun7i-a20-m5.dts index 00c3ffd323..8014ebc310 100644 --- a/arch/arm/dts/sun7i-a20-m5.dts +++ b/arch/arm/dts/sun7i-a20-m5.dts @@ -7,6 +7,8 @@
/dts-v1/; #include "sun7i-a20.dtsi" +#include "sunxi-common-regulators.dtsi" +#include <dt-bindings/gpio/gpio.h>
/ { model = "Mele M5"; @@ -41,6 +43,16 @@ }; };
+&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_reference_design>; + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + cd-gpios = <&pio 7 1 GPIO_ACTIVE_HIGH>; /* PH1 */ + cd-inverted; + status = "okay"; +}; + &ohci0 { status = "okay"; };
Since SUN7I moved to DM_MMC, we need to have mmc node in Toptech BD1078 DT otherwise it will not probe.
Cc: Paul Kocialkowski contact@paulk.fr Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/sun7i-a20-yones-toptech-bd1078.dts | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/arch/arm/dts/sun7i-a20-yones-toptech-bd1078.dts b/arch/arm/dts/sun7i-a20-yones-toptech-bd1078.dts index f1fb97d3fb..89c8cf60b1 100644 --- a/arch/arm/dts/sun7i-a20-yones-toptech-bd1078.dts +++ b/arch/arm/dts/sun7i-a20-yones-toptech-bd1078.dts @@ -7,6 +7,9 @@
/dts-v1/; #include "sun7i-a20.dtsi" +#include "sunxi-common-regulators.dtsi" +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/pinctrl/sun4i-a10.h>
/ { model = "Yones Toptech BD1078"; @@ -21,6 +24,16 @@ }; };
Enable DM_MMC for Allwinner A20 SoC.
Tested on A20-OLinuXino-LIME2.
Cc: Stefan Mavrodiev stefan@olimex.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/mach-sunxi/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 678e33dd40..7d1184306f 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -180,6 +180,7 @@ config MACH_SUN7I select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI select DRAM_SUN4I + select DM_MMC if MMC select PHY_SUN4I_USB select SUNXI_GEN_SUN4I select SUPPORT_SPL
Added H5, A64 compatible for mmc and emmc.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/mmc/sunxi_mmc.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/mmc/sunxi_mmc.c b/drivers/mmc/sunxi_mmc.c index beeded50af..16e94cf4b7 100644 --- a/drivers/mmc/sunxi_mmc.c +++ b/drivers/mmc/sunxi_mmc.c @@ -687,6 +687,10 @@ static const struct udevice_id sunxi_mmc_ids[] = { .data = (ulong)&sun4i_a10_cfg }, { .compatible = "allwinner,sun7i-a20-mmc", .data = (ulong)&sun7i_a20_cfg }, + { .compatible = "allwinner,sun50i-a64-mmc", + .data = (ulong)&sun7i_a20_cfg }, + { .compatible = "allwinner,sun50i-a64-emmc", + .data = (ulong)&sun7i_a20_cfg }, { } };
Enable DM_MMC for Allwinner H3/H5 SoCs.
Tested on H3: BPI-M2+ H5: Orangepi pc2, prime, zero+2
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 7d1184306f..a1ee431700 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -127,6 +127,7 @@ endif config MACH_SUNXI_H3_H5 bool select DM_I2C + select DM_MMC if MMC select PHY_SUN4I_USB select SUNXI_DE2 select SUNXI_DRAM_DW
Enable DM_MMC for Allwinner A64 SoCs.
Tested on BPI-M64, Amarula A64-Relic
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index a1ee431700..3b790e39dd 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -268,6 +268,7 @@ config MACH_SUN50I bool "sun50i (Allwinner A64)" select ARM64 select DM_I2C + select DM_MMC if MMC select PHY_SUN4I_USB select SUNXI_DE2 select SUNXI_GEN_SUN6I
Update all A83T devicetree dtsi and dtsi files from Linux with below commit: commit 221cb9fd2ee3042689fe0e6613d0f34eb46a5af6 Author: Mylène Josserand mylene.josserand@bootlin.com Date: Fri May 4 21:05:44 2018 +0200
ARM: dts: sun8i: Add enable-method for SMP support for the A83T SoC
Note: bananapi-m3 and cubietruck-plus board dts files has usb_otg enabled in U-Boot which were not present in Linux.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/axp81x.dtsi | 169 ++++ .../dts/sun8i-a83t-allwinner-h8homlet-v2.dts | 195 +++- arch/arm/dts/sun8i-a83t-bananapi-m3.dts | 298 +++++- arch/arm/dts/sun8i-a83t-cubietruck-plus.dts | 322 ++++++- arch/arm/dts/sun8i-a83t-tbs-a711.dts | 355 ++++++- arch/arm/dts/sun8i-a83t.dtsi | 885 ++++++++++++++++-- include/dt-bindings/clock/sun8i-a83t-ccu.h | 140 +++ include/dt-bindings/reset/sun8i-a83t-ccu.h | 98 ++ 8 files changed, 2382 insertions(+), 80 deletions(-) create mode 100644 arch/arm/dts/axp81x.dtsi create mode 100644 include/dt-bindings/clock/sun8i-a83t-ccu.h create mode 100644 include/dt-bindings/reset/sun8i-a83t-ccu.h
diff --git a/arch/arm/dts/axp81x.dtsi b/arch/arm/dts/axp81x.dtsi new file mode 100644 index 0000000000..043c717dce --- /dev/null +++ b/arch/arm/dts/axp81x.dtsi @@ -0,0 +1,169 @@ +/* + * Copyright 2017 Chen-Yu Tsai + * + * Chen-Yu Tsai wens@csie.org + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/* AXP813/818 Integrated Power Management Chip */ + +&axp81x { + interrupt-controller; + #interrupt-cells = <1>; + + axp_adc: adc { + compatible = "x-powers,axp813-adc"; + #io-channel-cells = <1>; + }; + + axp_gpio: gpio { + compatible = "x-powers,axp813-gpio"; + gpio-controller; + #gpio-cells = <2>; + + gpio0_ldo: gpio0-ldo { + pins = "GPIO0"; + function = "ldo"; + }; + + gpio1_ldo: gpio1-ldo { + pins = "GPIO1"; + function = "ldo"; + }; + }; + + battery_power_supply: battery-power-supply { + compatible = "x-powers,axp813-battery-power-supply"; + status = "disabled"; + }; + + regulators { + /* Default work frequency for buck regulators */ + x-powers,dcdc-freq = <3000>; + + reg_dcdc1: dcdc1 { + }; + + reg_dcdc2: dcdc2 { + }; + + reg_dcdc3: dcdc3 { + }; + + reg_dcdc4: dcdc4 { + }; + + reg_dcdc5: dcdc5 { + }; + + reg_dcdc6: dcdc6 { + }; + + reg_dcdc7: dcdc7 { + }; + + reg_aldo1: aldo1 { + }; + + reg_aldo2: aldo2 { + }; + + reg_aldo3: aldo3 { + }; + + reg_dldo1: dldo1 { + }; + + reg_dldo2: dldo2 { + }; + + reg_dldo3: dldo3 { + }; + + reg_dldo4: dldo4 { + }; + + reg_eldo1: eldo1 { + }; + + reg_eldo2: eldo2 { + }; + + reg_eldo3: eldo3 { + }; + + reg_fldo1: fldo1 { + }; + + reg_fldo2: fldo2 { + }; + + reg_fldo3: fldo3 { + }; + + reg_ldo_io0: ldo-io0 { + pinctrl-names = "default"; + pinctrl-0 = <&gpio0_ldo>; + /* Disable by default to avoid conflicts with GPIO */ + status = "disabled"; + }; + + reg_ldo_io1: ldo-io1 { + pinctrl-names = "default"; + pinctrl-0 = <&gpio1_ldo>; + /* Disable by default to avoid conflicts with GPIO */ + status = "disabled"; + }; + + reg_rtc_ldo: rtc-ldo { + /* RTC_LDO is a fixed, always-on regulator */ + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + reg_sw: sw { + }; + + reg_drivevbus: drivevbus { + status = "disabled"; + }; + }; +}; diff --git a/arch/arm/dts/sun8i-a83t-allwinner-h8homlet-v2.dts b/arch/arm/dts/sun8i-a83t-allwinner-h8homlet-v2.dts index c8495d7624..36ecebaff3 100644 --- a/arch/arm/dts/sun8i-a83t-allwinner-h8homlet-v2.dts +++ b/arch/arm/dts/sun8i-a83t-allwinner-h8homlet-v2.dts @@ -44,6 +44,8 @@ /dts-v1/; #include "sun8i-a83t.dtsi"
+#include <dt-bindings/gpio/gpio.h> + / { model = "Allwinner A83T H8Homlet Proto Dev Board v2.0"; compatible = "allwinner,h8homlet-v2", "allwinner,sun8i-a83t"; @@ -55,22 +57,213 @@ chosen { stdout-path = "serial0:115200n8"; }; + + reg_usb0_vbus: reg-usb0-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb0-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-boot-on; + enable-active-high; + gpio = <&r_pio 0 5 GPIO_ACTIVE_HIGH>; /* PL5 */ + }; + + reg_usb1_vbus: reg-usb1-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb1-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-boot-on; + enable-active-high; + gpio = <&r_pio 0 6 GPIO_ACTIVE_HIGH>; /* PL6 */ + }; };
&ehci0 { status = "okay"; };
+&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins>; + vmmc-supply = <®_dcdc1>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 */ + bus-width = <4>; + status = "okay"; +}; + +&mmc2 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_8bit_emmc_pins>; + vmmc-supply = <®_dcdc1>; + vqmmc-supply = <®_dcdc1>; + bus-width = <8>; + non-removable; + cap-mmc-hw-reset; + status = "okay"; +}; + &ohci0 { status = "okay"; };
+&r_rsb { + status = "okay"; + + axp81x: pmic@3a3 { + compatible = "x-powers,axp818", "x-powers,axp813"; + reg = <0x3a3>; + interrupt-parent = <&r_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + eldoin-supply = <®_dcdc1>; + swin-supply = <®_dcdc1>; + }; + + ac100: codec@e89 { + compatible = "x-powers,ac100"; + reg = <0xe89>; + + ac100_codec: codec { + compatible = "x-powers,ac100-codec"; + interrupt-parent = <&r_pio>; + interrupts = <0 11 IRQ_TYPE_LEVEL_LOW>; /* PL11 */ + #clock-cells = <0>; + clock-output-names = "4M_adda"; + }; + + ac100_rtc: rtc { + compatible = "x-powers,ac100-rtc"; + interrupt-parent = <&r_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + clocks = <&ac100_codec>; + #clock-cells = <1>; + clock-output-names = "cko1_rtc", + "cko2_rtc", + "cko3_rtc"; + }; + }; +}; + +#include "axp81x.dtsi" + +®_aldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-1v8"; +}; + +®_aldo2 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "dram-pll"; +}; + +®_aldo3 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "avcc"; +}; + +®_dcdc1 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-3v3"; +}; + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-cpua"; +}; + +®_dcdc3 { + regulator-always-on; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-cpub"; +}; + +®_dcdc4 { + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-gpu"; +}; + +®_dcdc5 { + regulator-always-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-name = "vcc-dram"; +}; + +®_dcdc6 { + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + regulator-name = "vdd-sys"; +}; + +®_dldo2 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-mipi"; +}; + +®_dldo4 { + /* + * The PHY requires 20ms after all voltages are applied until core + * logic is ready and 30ms after the reset pin is de-asserted. + * Set a 100ms delay to account for PMIC ramp time and board traces. + */ + regulator-enable-ramp-delay = <100000>; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-ephy"; +}; + +®_fldo1 { + regulator-min-microvolt = <1080000>; + regulator-max-microvolt = <1320000>; + regulator-name = "vdd12-hsic"; +}; + +®_fldo2 { + /* + * Despite the embedded CPUs core not being used in any way, + * this must remain on or the system will hang. + */ + regulator-always-on; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-cpus"; +}; + +®_rtc_ldo { + regulator-name = "vcc-rtc"; +}; + +®_sw { + regulator-name = "vcc-wifi"; +}; + &uart0 { pinctrl-names = "default"; - pinctrl-0 = <&uart0_pins_b>; + pinctrl-0 = <&uart0_pb_pins>; + status = "okay"; +}; + +&usbphy { + usb0_vbus-supply = <®_usb0_vbus>; + usb1_vbus-supply = <®_usb1_vbus>; status = "okay"; };
&usb_otg { + dr_mode = "host"; status = "okay"; }; diff --git a/arch/arm/dts/sun8i-a83t-bananapi-m3.dts b/arch/arm/dts/sun8i-a83t-bananapi-m3.dts index dfc16a0272..eaff6fa401 100644 --- a/arch/arm/dts/sun8i-a83t-bananapi-m3.dts +++ b/arch/arm/dts/sun8i-a83t-bananapi-m3.dts @@ -1,6 +1,7 @@ /* - * Copyright 2015 Vishnu Patekar - * Vishnu Patekar vishnupatekar0510@gmail.com + * Copyright 2017 Chen-Yu Tsai + * + * Chen-Yu Tsai wens@csie.org * * This file is dual-licensed: you can use it either under the terms * of the GPL or the X11 license, at your option. Note that this dual @@ -44,29 +45,316 @@ /dts-v1/; #include "sun8i-a83t.dtsi"
+#include <dt-bindings/gpio/gpio.h> + / { - model = "Allwinner A83T BananaPi M3 Board v1.2"; - compatible = "bananapi,m3v1.2", "allwinner,sun8i-a83t"; + model = "Banana Pi BPI-M3"; + compatible = "sinovoip,bpi-m3", "allwinner,sun8i-a83t";
aliases { + ethernet0 = &emac; serial0 = &uart0; };
chosen { stdout-path = "serial0:115200n8"; }; + + connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + + leds { + compatible = "gpio-leds"; + + blue { + label = "bananapi-m3:blue:usr"; + gpios = <&axp_gpio 1 GPIO_ACTIVE_HIGH>; + }; + + green { + label = "bananapi-m3:green:usr"; + gpios = <&axp_gpio 0 GPIO_ACTIVE_HIGH>; + }; + }; + + reg_usb1_vbus: reg-usb1-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb1-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-boot-on; + enable-active-high; + gpio = <&pio 3 24 GPIO_ACTIVE_HIGH>; /* PD24 */ + }; + + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&ac100_rtc 1>; + clock-names = "ext_clock"; + /* The WiFi low power clock must be 32768 Hz */ + assigned-clocks = <&ac100_rtc 1>; + assigned-clock-rates = <32768>; + /* enables internal regulator and de-asserts reset */ + reset-gpios = <&r_pio 0 2 GPIO_ACTIVE_LOW>; /* PL2 WL-PMU-EN */ + }; +}; + +&de { + status = "okay"; };
&ehci0 { + /* Terminus Tech FE 1.1s 4-port USB 2.0 hub here */ status = "okay"; + + /* TODO GL830 USB-to-SATA bridge downstream w/ GPIO power controls */ +}; + +&emac { + pinctrl-names = "default"; + pinctrl-0 = <&emac_rgmii_pins>; + phy-supply = <®_sw>; + phy-handle = <&rgmii_phy>; + phy-mode = "rgmii"; + allwinner,rx-delay-ps = <700>; + allwinner,tx-delay-ps = <700>; + status = "okay"; +}; + +&hdmi { + status = "okay"; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + +&mdio { + rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + }; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins>; + vmmc-supply = <®_dcdc1>; + bus-width = <4>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 */ + status = "okay"; +}; + +&mmc1 { + vmmc-supply = <®_dldo1>; + vqmmc-supply = <®_dldo1>; + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; + + brcmf: wifi@1 { + reg = <1>; + compatible = "brcm,bcm4329-fmac"; + interrupt-parent = <&r_pio>; + interrupts = <0 3 IRQ_TYPE_LEVEL_LOW>; + interrupt-names = "host-wake"; + }; +}; + +&mmc2 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_8bit_emmc_pins>; + vmmc-supply = <®_dcdc1>; + vqmmc-supply = <®_dcdc1>; + bus-width = <8>; + non-removable; + cap-mmc-hw-reset; + status = "okay"; +}; + +&r_rsb { + status = "okay"; + + axp81x: pmic@3a3 { + compatible = "x-powers,axp813"; + reg = <0x3a3>; + interrupt-parent = <&r_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + eldoin-supply = <®_dcdc1>; + fldoin-supply = <®_dcdc5>; + swin-supply = <®_dcdc1>; + x-powers,drive-vbus-en; + }; + + ac100: codec@e89 { + compatible = "x-powers,ac100"; + reg = <0xe89>; + + ac100_codec: codec { + compatible = "x-powers,ac100-codec"; + interrupt-parent = <&r_pio>; + interrupts = <0 11 IRQ_TYPE_LEVEL_LOW>; /* PL11 */ + #clock-cells = <0>; + clock-output-names = "4M_adda"; + }; + + ac100_rtc: rtc { + compatible = "x-powers,ac100-rtc"; + interrupt-parent = <&r_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + clocks = <&ac100_codec>; + #clock-cells = <1>; + clock-output-names = "cko1_rtc", + "cko2_rtc", + "cko3_rtc"; + }; + }; +}; + +#include "axp81x.dtsi" + +®_aldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-1v8"; +}; + +®_aldo2 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "dram-pll"; +}; + +®_aldo3 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "avcc"; +}; + +®_dcdc1 { + /* schematics says 3.1V but FEX file says 3.3V */ + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-3v3"; +}; + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-cpua"; +}; + +®_dcdc3 { + regulator-always-on; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-cpub"; +}; + +®_dcdc4 { + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-gpu"; +}; + +®_dcdc5 { + regulator-always-on; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "vcc-dram"; +}; + +®_dcdc6 { + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + regulator-name = "vdd-sys"; +}; + +®_dldo1 { + /* + * This powers both the WiFi/BT module's main power, I/O supply, + * and external pull-ups on all the data lines. It should be set + * to the same voltage as the I/O supply (DCDC1 in this case) to + * avoid any leakage or mismatch. + */ + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-wifi"; +}; + +®_dldo3 { + regulator-always-on; + regulator-min-microvolt = <2500000>; + regulator-max-microvolt = <2500000>; + regulator-name = "vcc-pd"; +}; + +®_drivevbus { + regulator-name = "usb0-vbus"; + status = "okay"; +}; + +®_fldo1 { + regulator-min-microvolt = <1080000>; + regulator-max-microvolt = <1320000>; + regulator-name = "vdd12-hsic"; +}; + +®_fldo2 { + /* + * Despite the embedded CPUs core not being used in any way, + * this must remain on or the system will hang. + */ + regulator-always-on; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-cpus"; +}; + +®_rtc_ldo { + regulator-name = "vcc-rtc"; +}; + +®_sw { + /* + * The PHY requires 20ms after all voltages + * are applied until core logic is ready and + * 30ms after the reset pin is de-asserted. + * Set a 100ms delay to account for PMIC + * ramp time and board traces. + */ + regulator-enable-ramp-delay = <100000>; + regulator-name = "vcc-ephy"; };
&uart0 { pinctrl-names = "default"; - pinctrl-0 = <&uart0_pins_b>; + pinctrl-0 = <&uart0_pb_pins>; status = "okay"; };
&usb_otg { status = "okay"; }; + +&usbphy { + usb1_vbus-supply = <®_usb1_vbus>; + status = "okay"; +}; diff --git a/arch/arm/dts/sun8i-a83t-cubietruck-plus.dts b/arch/arm/dts/sun8i-a83t-cubietruck-plus.dts index 8437c8f59e..5dba4fc310 100644 --- a/arch/arm/dts/sun8i-a83t-cubietruck-plus.dts +++ b/arch/arm/dts/sun8i-a83t-cubietruck-plus.dts @@ -45,33 +45,353 @@ /dts-v1/; #include "sun8i-a83t.dtsi"
+#include <dt-bindings/gpio/gpio.h> + / { model = "Cubietech Cubietruck Plus"; compatible = "cubietech,cubietruck-plus", "allwinner,sun8i-a83t";
chosen { stdout-path = "serial0:115200n8"; }; + + leds { + compatible = "gpio-leds"; + + blue { + label = "cubietruck-plus:blue:usr"; + gpios = <&pio 3 25 GPIO_ACTIVE_HIGH>; /* PD25 */ + }; + + orange { + label = "cubietruck-plus:orange:usr"; + gpios = <&pio 3 26 GPIO_ACTIVE_HIGH>; /* PD26 */ + }; + + white { + label = "cubietruck-plus:white:usr"; + gpios = <&pio 3 27 GPIO_ACTIVE_HIGH>; /* PD27 */ + }; + + green { + label = "cubietruck-plus:green:usr"; + gpios = <&pio 4 4 GPIO_ACTIVE_HIGH>; /* PE4 */ + }; + }; + + usb-hub { + /* I2C is not connected */ + compatible = "smsc,usb3503"; + initial-mode = <1>; /* initialize in HUB mode */ + disabled-ports = <1>; + intn-gpios = <&pio 7 5 GPIO_ACTIVE_HIGH>; /* PH5 */ + reset-gpios = <&pio 4 16 GPIO_ACTIVE_HIGH>; /* PE16 */ + connect-gpios = <&pio 4 17 GPIO_ACTIVE_HIGH>; /* PE17 */ + refclk-frequency = <19200000>; + }; + + reg_usb1_vbus: reg-usb1-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb1-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-boot-on; + enable-active-high; + gpio = <&pio 3 29 GPIO_ACTIVE_HIGH>; /* PD29 */ + }; + + reg_usb2_vbus: reg-usb2-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb2-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-boot-on; + enable-active-high; + gpio = <&r_pio 0 6 GPIO_ACTIVE_HIGH>; /* PL6 */ + }; + + sound { + compatible = "simple-audio-card"; + simple-audio-card,name = "On-board SPDIF"; + + simple-audio-card,cpu { + sound-dai = <&spdif>; + }; + + simple-audio-card,codec { + sound-dai = <&spdif_out>; + }; + }; + + spdif_out: spdif-out { + #sound-dai-cells = <0>; + compatible = "linux,spdif-dit"; + }; + + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&ac100_rtc 1>; + clock-names = "ext_clock"; + /* The WiFi low power clock must be 32768 Hz */ + assigned-clocks = <&ac100_rtc 1>; + assigned-clock-rates = <32768>; + /* enables internal regulator and de-asserts reset */ + reset-gpios = <&r_pio 0 2 GPIO_ACTIVE_LOW>; /* PL2 WL-PMU-EN */ + }; };
&ehci0 { + /* GL830 USB-to-SATA bridge here */ status = "okay"; };
&ehci1 { + /* USB3503 HSIC USB 2.0 hub here */ + status = "okay"; +}; + +&emac { + pinctrl-names = "default"; + pinctrl-0 = <&emac_rgmii_pins>; + phy-supply = <®_dldo4>; + phy-handle = <&rgmii_phy>; + phy-mode = "rgmii"; + status = "okay"; +}; + +&mdio { + rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + }; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins>; + vmmc-supply = <®_dcdc1>; + bus-width = <4>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 */ + status = "okay"; +}; + +&mmc1 { + vmmc-supply = <®_dcdc1>; + vqmmc-supply = <®_sw>; + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; +}; + +&mmc2 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_8bit_emmc_pins>; + vmmc-supply = <®_dcdc1>; + bus-width = <8>; + non-removable; + cap-mmc-hw-reset; + status = "okay"; +}; + +&r_rsb { + status = "okay"; + + axp81x: pmic@3a3 { + compatible = "x-powers,axp818", "x-powers,axp813"; + reg = <0x3a3>; + interrupt-parent = <&r_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + eldoin-supply = <®_dcdc1>; + swin-supply = <®_dcdc1>; + x-powers,drive-vbus-en; + }; + + ac100: codec@e89 { + compatible = "x-powers,ac100"; + reg = <0xe89>; + + ac100_codec: codec { + compatible = "x-powers,ac100-codec"; + interrupt-parent = <&r_pio>; + interrupts = <0 11 IRQ_TYPE_LEVEL_LOW>; /* PL11 */ + #clock-cells = <0>; + clock-output-names = "4M_adda"; + }; + + ac100_rtc: rtc { + compatible = "x-powers,ac100-rtc"; + interrupt-parent = <&r_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + clocks = <&ac100_codec>; + #clock-cells = <1>; + clock-output-names = "cko1_rtc", + "cko2_rtc", + "cko3_rtc"; + }; + }; +}; + +#include "axp81x.dtsi" + +®_aldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-1v8"; +}; + +®_aldo2 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "dram-pll"; +}; + +®_aldo3 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "avcc"; +}; + +®_dcdc1 { + /* + * The schematics say this should be 3.3V, but the FEX file says + * it should be 3V. The latter makes sense, as the WiFi module's + * I/O is indirectly powered from DCDC1, through SW. It is rated + * at 2.98V maximum. + */ + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcc-3v"; +}; + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-cpua"; +}; + +®_dcdc3 { + regulator-always-on; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-cpub"; +}; + +®_dcdc4 { + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-gpu"; +}; + +®_dcdc5 { + regulator-always-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-name = "vcc-dram"; +}; + +®_dcdc6 { + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + regulator-name = "vdd-sys"; +}; + +®_dldo2 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "dp-pwr"; +}; + +®_dldo3 { + regulator-always-on; + regulator-min-microvolt = <2500000>; + regulator-max-microvolt = <2500000>; + regulator-name = "ephy-io"; +}; + +®_dldo4 { + /* + * The PHY requires 20ms after all voltages are applied until core + * logic is ready and 30ms after the reset pin is de-asserted. + * Set a 100ms delay to account for PMIC ramp time and board traces. + */ + regulator-enable-ramp-delay = <100000>; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "ephy"; +}; + +®_drivevbus { + regulator-name = "usb0-vbus"; + status = "okay"; +}; + +®_eldo1 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "dp-bridge-1"; +}; + +®_eldo2 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "dp-bridge-2"; +}; + +®_fldo1 { + /* TODO should be handled by USB PHY */ + regulator-always-on; + regulator-min-microvolt = <1080000>; + regulator-max-microvolt = <1320000>; + regulator-name = "vdd12-hsic"; +}; + +®_fldo2 { + /* + * Despite the embedded CPUs core not being used in any way, + * this must remain on or the system will hang. + */ + regulator-always-on; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-cpus"; +}; + +®_rtc_ldo { + regulator-name = "vcc-rtc"; +}; + +®_sw { + regulator-name = "vcc-wifi-io"; +}; + +&spdif { status = "okay"; };
&usb_otg { status = "okay"; }; + +&usbphy { + usb1_vbus-supply = <®_usb1_vbus>; + usb2_vbus-supply = <®_usb2_vbus>; + status = "okay"; +}; diff --git a/arch/arm/dts/sun8i-a83t-tbs-a711.dts b/arch/arm/dts/sun8i-a83t-tbs-a711.dts index 80e8b1cc90..1537ce148c 100644 --- a/arch/arm/dts/sun8i-a83t-tbs-a711.dts +++ b/arch/arm/dts/sun8i-a83t-tbs-a711.dts @@ -1,6 +1,6 @@ /* - * Copyright 2017 Ondřej Jirman - * Ondřej Jirman megous@megous.com + * Copyright (C) 2017 Touchless Biometric Systems AG + * Tomas Novotny tomas@novotny.cz * * This file is dual-licensed: you can use it either under the terms * of the GPL or the X11 license, at your option. Note that this dual @@ -44,33 +44,380 @@ /dts-v1/; #include "sun8i-a83t.dtsi"
+#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/pwm/pwm.h> + / { model = "TBS A711 Tablet"; compatible = "tbs-biometrics,a711", "allwinner,sun8i-a83t";
aliases { serial0 = &uart0; + serial1 = &uart1; };
chosen { stdout-path = "serial0:115200n8"; }; + + backlight: backlight { + compatible = "pwm-backlight"; + pwms = <&pwm 0 50000 PWM_POLARITY_INVERTED>; + enable-gpios = <&pio 3 29 GPIO_ACTIVE_HIGH>; + + brightness-levels = <0 1 2 4 8 16 32 64 128 255>; + default-brightness-level = <9>; + }; + + panel { + compatible = "tbs,a711-panel", "panel-lvds"; + backlight = <&backlight>; + power-supply = <®_sw>; + + width-mm = <153>; + height-mm = <90>; + data-mapping = "vesa-24"; + + panel-timing { + /* 1024x600 @60Hz */ + clock-frequency = <52000000>; + hactive = <1024>; + vactive = <600>; + hsync-len = <20>; + hfront-porch = <180>; + hback-porch = <160>; + vfront-porch = <12>; + vback-porch = <23>; + vsync-len = <5>; + }; + + port { + panel_input: endpoint { + remote-endpoint = <&tcon0_out_lcd>; + }; + }; + }; + + reg_vbat: reg-vbat { + compatible = "regulator-fixed"; + regulator-name = "vbat"; + regulator-min-microvolt = <3700000>; + regulator-max-microvolt = <3700000>; + }; + + reg_vmain: reg-vmain { + compatible = "regulator-fixed"; + regulator-name = "vmain"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&r_pio 0 9 GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <®_vbat>; + }; + + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&r_pio 0 2 GPIO_ACTIVE_LOW>; /* PL2 WL-PMU-EN */ + + /* + * This is actually Bluetooth's clock, but we have to + * hook it up somewheere + */ + clocks = <&ac100_rtc 1>; + clock-names = "ext_clock"; + }; +}; + +&cpu0 { + cpu-supply = <®_dcdc2>; +}; + +&cpu100 { + cpu-supply = <®_dcdc3>; +}; + +&de { + status = "okay"; };
+/* + * An USB-2 hub is connected here, which also means we don't need to + * enable the OHCI controller. + */ &ehci0 { status = "okay"; };
-&ohci0 { +/* + * There's a modem connected here that needs to be initialised before + * being able to be enumerated. + */ +&ehci1 { + status = "okay"; +}; + +&mmc0 { + vmmc-supply = <®_dcdc1>; + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&mmc1 { + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + vmmc-supply = <®_dldo1>; + vqmmc-supply = <®_dldo1>; + non-removable; + wakeup-source; + status = "okay"; + + brcmf: wifi@1 { + reg = <1>; + compatible = "brcm,bcm4329-fmac"; + interrupt-parent = <&r_pio>; + interrupts = <0 3 IRQ_TYPE_LEVEL_LOW>; /* PL3 WL_WAKE_UP */ + interrupt-names = "host-wake"; + }; +}; + +&mmc2 { + pinctrl-0 = <&mmc2_8bit_emmc_pins>; + pinctrl-names = "default"; + vmmc-supply = <®_dcdc1>; + vqmmc-supply = <®_dcdc1>; + bus-width = <8>; + non-removable; + cap-mmc-hw-reset; + status = "okay"; +}; + +&pwm { + pinctrl-names = "default"; + pinctrl-0 = <&pwm_pin>; + status = "okay"; +}; + +&r_rsb { + status = "okay"; + + axp81x: pmic@3a3 { + compatible = "x-powers,axp813"; + reg = <0x3a3>; + interrupt-parent = <&r_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + swin-supply = <®_dcdc1>; + x-powers,drive-vbus-en; + }; + + ac100: codec@e89 { + compatible = "x-powers,ac100"; + reg = <0xe89>; + + ac100_codec: codec { + compatible = "x-powers,ac100-codec"; + interrupt-parent = <&r_pio>; + interrupts = <0 12 IRQ_TYPE_LEVEL_LOW>; /* PL12 */ + #clock-cells = <0>; + clock-output-names = "4M_adda"; + }; + + ac100_rtc: rtc { + compatible = "x-powers,ac100-rtc"; + interrupt-parent = <&r_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + clocks = <&ac100_codec>; + #clock-cells = <1>; + clock-output-names = "cko1_rtc", + "cko2_rtc", + "cko3_rtc"; + }; + }; + +}; + +#include "axp81x.dtsi" + +&battery_power_supply { + status = "okay"; +}; + +®_aldo1 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-1.8"; +}; + +®_aldo2 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-name = "vdd-drampll"; +}; + +®_aldo3 { + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-always-on; + regulator-name = "avcc"; +}; + +®_dcdc1 { + regulator-min-microvolt = <3100000>; + regulator-max-microvolt = <3100000>; + regulator-always-on; + regulator-name = "vcc-io"; +}; + +®_dcdc2 { + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1100000>; + regulator-always-on; + regulator-name = "vdd-cpu-A"; +}; + +®_dcdc3 { + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1100000>; + regulator-always-on; + regulator-name = "vdd-cpu-B"; +}; + +®_dcdc4 { + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-gpu"; +}; + +®_dcdc5 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1500000>; + regulator-always-on; + regulator-name = "vcc-dram"; +}; + +®_dcdc6 { + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + regulator-always-on; + regulator-name = "vdd-sys"; +}; + +®_dldo1 { + regulator-min-microvolt = <3100000>; + regulator-max-microvolt = <3100000>; + regulator-name = "vcc-wifi-io"; +}; + +®_dldo2 { + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <4200000>; + regulator-name = "vcc-mipi"; +}; + +®_dldo3 { + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-name = "vdd-csi"; +}; + +®_dldo4 { + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-name = "avdd-csi"; +}; + +®_drivevbus { + regulator-name = "usb0-vbus"; status = "okay"; };
+®_eldo1 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1800000>; + regulator-name = "dvdd-csi-r"; +}; + +®_eldo2 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-dsi"; +}; + +®_eldo3 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1800000>; + regulator-name = "dvdd-csi-f"; +}; + +®_fldo1 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "vcc-hsic"; +}; + +®_fldo2 { + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1100000>; + regulator-always-on; + regulator-name = "vdd-cpus"; +}; + +®_ldo_io0 { + regulator-min-microvolt = <3100000>; + regulator-max-microvolt = <3100000>; + regulator-name = "vcc-ctp"; + status = "okay"; +}; + +®_ldo_io1 { + regulator-min-microvolt = <3100000>; + regulator-max-microvolt = <3100000>; + regulator-name = "vcc-vb"; + status = "okay"; +}; + +®_sw { + regulator-min-microvolt = <3100000>; + regulator-max-microvolt = <3100000>; + regulator-name = "vcc-lcd"; +}; + +&tcon0 { + pinctrl-names = "default"; + pinctrl-0 = <&lcd_lvds_pins>; +}; + +&tcon0_out { + tcon0_out_lcd: endpoint@0 { + reg = <0>; + remote-endpoint = <&panel_input>; + }; +}; + &uart0 { pinctrl-names = "default"; - pinctrl-0 = <&uart0_pins_b>; + pinctrl-0 = <&uart0_pb_pins>; + status = "okay"; +}; + +/* There's the BT part of the AP6210 connected to that UART */ +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins>, <&uart1_rts_cts_pins>; status = "okay"; };
&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + +&usbphy { + usb0_id_det-gpios = <&pio 7 11 GPIO_ACTIVE_HIGH>; /* PH11 */ + usb0_vbus-supply = <®_drivevbus>; + usb1_vbus_supply = <®_vmain>; + usb2_vbus_supply = <®_vmain>; status = "okay"; }; diff --git a/arch/arm/dts/sun8i-a83t.dtsi b/arch/arm/dts/sun8i-a83t.dtsi index 2953e0fdac..2be23d6009 100644 --- a/arch/arm/dts/sun8i-a83t.dtsi +++ b/arch/arm/dts/sun8i-a83t.dtsi @@ -40,67 +40,99 @@ * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR * OTHER DEALINGS IN THE SOFTWARE. - */
-#include "skeleton.dtsi" - #include <dt-bindings/interrupt-controller/arm-gic.h>
-#include <dt-bindings/pinctrl/sun4i-a10.h> +#include <dt-bindings/clock/sun8i-a83t-ccu.h> +#include <dt-bindings/clock/sun8i-de2.h> +#include <dt-bindings/clock/sun8i-r-ccu.h> +#include <dt-bindings/reset/sun8i-a83t-ccu.h> +#include <dt-bindings/reset/sun8i-de2.h> +#include <dt-bindings/reset/sun8i-r-ccu.h>
/ { interrupt-parent = <&gic>; + #address-cells = <1>; + #size-cells = <1>;
cpus { #address-cells = <1>; #size-cells = <0>;
- cpu@0 { + cpu0: cpu@0 { + clocks = <&ccu CLK_C0CPUX>; + clock-names = "cpu"; compatible = "arm,cortex-a7"; device_type = "cpu"; + operating-points-v2 = <&cpu0_opp_table>; + cci-control-port = <&cci_control0>; + enable-method = "allwinner,sun8i-a83t-smp"; reg = <0>; };
cpu@1 { compatible = "arm,cortex-a7"; device_type = "cpu"; + operating-points-v2 = <&cpu0_opp_table>; + cci-control-port = <&cci_control0>; + enable-method = "allwinner,sun8i-a83t-smp"; reg = <1>; };
cpu@2 { compatible = "arm,cortex-a7"; device_type = "cpu"; + operating-points-v2 = <&cpu0_opp_table>; + cci-control-port = <&cci_control0>; + enable-method = "allwinner,sun8i-a83t-smp"; reg = <2>; };
cpu@3 { compatible = "arm,cortex-a7"; device_type = "cpu"; + operating-points-v2 = <&cpu0_opp_table>; + cci-control-port = <&cci_control0>; + enable-method = "allwinner,sun8i-a83t-smp"; reg = <3>; };
- cpu@100 { + cpu100: cpu@100 { + clocks = <&ccu CLK_C1CPUX>; + clock-names = "cpu"; compatible = "arm,cortex-a7"; device_type = "cpu"; + operating-points-v2 = <&cpu1_opp_table>; + cci-control-port = <&cci_control1>; + enable-method = "allwinner,sun8i-a83t-smp"; reg = <0x100>; };
cpu@101 { compatible = "arm,cortex-a7"; device_type = "cpu"; + operating-points-v2 = <&cpu1_opp_table>; + cci-control-port = <&cci_control1>; + enable-method = "allwinner,sun8i-a83t-smp"; reg = <0x101>; };
cpu@102 { compatible = "arm,cortex-a7"; device_type = "cpu"; + operating-points-v2 = <&cpu1_opp_table>; + cci-control-port = <&cci_control1>; + enable-method = "allwinner,sun8i-a83t-smp"; reg = <0x102>; };
cpu@103 { compatible = "arm,cortex-a7"; device_type = "cpu"; + operating-points-v2 = <&cpu1_opp_table>; + cci-control-port = <&cci_control1>; + enable-method = "allwinner,sun8i-a83t-smp"; reg = <0x103>; }; }; @@ -123,6 +155,7 @@ #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <24000000>; + clock-accuracy = <50000>; clock-output-names = "osc24M"; };
@@ -148,48 +181,575 @@ }; };
+ de: display-engine { + compatible = "allwinner,sun8i-a83t-display-engine"; + allwinner,pipelines = <&mixer0>, <&mixer1>; + status = "disabled"; + }; + + memory { + reg = <0x40000000 0x80000000>; + device_type = "memory"; + }; + + cpu0_opp_table: opp_table0 { + compatible = "operating-points-v2"; + opp-shared; + + opp-480000000 { + opp-hz = /bits/ 64 <480000000>; + opp-microvolt = <840000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-600000000 { + opp-hz = /bits/ 64 <600000000>; + opp-microvolt = <840000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-720000000 { + opp-hz = /bits/ 64 <720000000>; + opp-microvolt = <840000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-864000000 { + opp-hz = /bits/ 64 <864000000>; + opp-microvolt = <840000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-912000000 { + opp-hz = /bits/ 64 <912000000>; + opp-microvolt = <840000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-1008000000 { + opp-hz = /bits/ 64 <1008000000>; + opp-microvolt = <840000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-1128000000 { + opp-hz = /bits/ 64 <1128000000>; + opp-microvolt = <840000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-1200000000 { + opp-hz = /bits/ 64 <1200000000>; + opp-microvolt = <840000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + }; + + cpu1_opp_table: opp_table1 { + compatible = "operating-points-v2"; + opp-shared; + + opp-480000000 { + opp-hz = /bits/ 64 <480000000>; + opp-microvolt = <840000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-600000000 { + opp-hz = /bits/ 64 <600000000>; + opp-microvolt = <840000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-720000000 { + opp-hz = /bits/ 64 <720000000>; + opp-microvolt = <840000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-864000000 { + opp-hz = /bits/ 64 <864000000>; + opp-microvolt = <840000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-912000000 { + opp-hz = /bits/ 64 <912000000>; + opp-microvolt = <840000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-1008000000 { + opp-hz = /bits/ 64 <1008000000>; + opp-microvolt = <840000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-1128000000 { + opp-hz = /bits/ 64 <1128000000>; + opp-microvolt = <840000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-1200000000 { + opp-hz = /bits/ 64 <1200000000>; + opp-microvolt = <840000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + }; + soc { compatible = "simple-bus"; #address-cells = <1>; #size-cells = <1>; ranges;
- pio: pinctrl@01c20800 { + display_clocks: clock@1000000 { + compatible = "allwinner,sun8i-a83t-de2-clk"; + reg = <0x01000000 0x100000>; + clocks = <&ccu CLK_PLL_DE>, + <&ccu CLK_BUS_DE>; + clock-names = "mod", + "bus"; + resets = <&ccu RST_BUS_DE>; + #clock-cells = <1>; + #reset-cells = <1>; + }; + + mixer0: mixer@1100000 { + compatible = "allwinner,sun8i-a83t-de2-mixer-0"; + reg = <0x01100000 0x100000>; + clocks = <&display_clocks CLK_BUS_MIXER0>, + <&display_clocks CLK_MIXER0>; + clock-names = "bus", + "mod"; + resets = <&display_clocks RST_MIXER0>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + mixer0_out: port@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + + mixer0_out_tcon0: endpoint@0 { + reg = <0>; + remote-endpoint = <&tcon0_in_mixer0>; + }; + }; + }; + }; + + mixer1: mixer@1200000 { + compatible = "allwinner,sun8i-a83t-de2-mixer-1"; + reg = <0x01200000 0x100000>; + clocks = <&display_clocks CLK_BUS_MIXER1>, + <&display_clocks CLK_MIXER1>; + clock-names = "bus", + "mod"; + resets = <&display_clocks RST_WB>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + mixer1_out: port@1 { + reg = <1>; + + mixer1_out_tcon1: endpoint { + remote-endpoint = <&tcon1_in_mixer1>; + }; + }; + }; + }; + + cpucfg@1700000 { + compatible = "allwinner,sun8i-a83t-cpucfg"; + reg = <0x01700000 0x400>; + }; + + cci@1790000 { + compatible = "arm,cci-400"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x01790000 0x10000>; + ranges = <0x0 0x01790000 0x10000>; + + cci_control0: slave-if@4000 { + compatible = "arm,cci-400-ctrl-if"; + interface-type = "ace"; + reg = <0x4000 0x1000>; + }; + + cci_control1: slave-if@5000 { + compatible = "arm,cci-400-ctrl-if"; + interface-type = "ace"; + reg = <0x5000 0x1000>; + }; + + pmu@9000 { + compatible = "arm,cci-400-pmu,r1"; + reg = <0x9000 0x5000>; + interrupts = <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 134 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 135 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 151 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + syscon: syscon@1c00000 { + compatible = "allwinner,sun8i-a83t-system-controller", + "syscon"; + reg = <0x01c00000 0x1000>; + }; + + dma: dma-controller@1c02000 { + compatible = "allwinner,sun8i-a83t-dma"; + reg = <0x01c02000 0x1000>; + interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_DMA>; + resets = <&ccu RST_BUS_DMA>; + #dma-cells = <1>; + }; + + tcon0: lcd-controller@1c0c000 { + compatible = "allwinner,sun8i-a83t-tcon-lcd"; + reg = <0x01c0c000 0x1000>; + interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_TCON0>, <&ccu CLK_TCON0>; + clock-names = "ahb", "tcon-ch0"; + clock-output-names = "tcon-pixel-clock"; + resets = <&ccu RST_BUS_TCON0>, <&ccu RST_BUS_LVDS>; + reset-names = "lcd", "lvds"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + tcon0_in: port@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0>; + + tcon0_in_mixer0: endpoint@0 { + reg = <0>; + remote-endpoint = <&mixer0_out_tcon0>; + }; + }; + + tcon0_out: port@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + }; + }; + }; + + tcon1: lcd-controller@1c0d000 { + compatible = "allwinner,sun8i-a83t-tcon-tv"; + reg = <0x01c0d000 0x1000>; + interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_TCON1>, <&ccu CLK_TCON1>; + clock-names = "ahb", "tcon-ch1"; + resets = <&ccu RST_BUS_TCON1>; + reset-names = "lcd"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + tcon1_in: port@0 { + reg = <0>; + + tcon1_in_mixer1: endpoint { + remote-endpoint = <&mixer1_out_tcon1>; + }; + }; + + tcon1_out: port@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + + tcon1_out_hdmi: endpoint@1 { + reg = <1>; + remote-endpoint = <&hdmi_in_tcon1>; + }; + }; + }; + }; + + mmc0: mmc@1c0f000 { + compatible = "allwinner,sun8i-a83t-mmc", + "allwinner,sun7i-a20-mmc"; + reg = <0x01c0f000 0x1000>; + clocks = <&ccu CLK_BUS_MMC0>, + <&ccu CLK_MMC0>, + <&ccu CLK_MMC0_OUTPUT>, + <&ccu CLK_MMC0_SAMPLE>; + clock-names = "ahb", + "mmc", + "output", + "sample"; + resets = <&ccu RST_BUS_MMC0>; + reset-names = "ahb"; + interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + mmc1: mmc@1c10000 { + compatible = "allwinner,sun8i-a83t-mmc", + "allwinner,sun7i-a20-mmc"; + reg = <0x01c10000 0x1000>; + clocks = <&ccu CLK_BUS_MMC1>, + <&ccu CLK_MMC1>, + <&ccu CLK_MMC1_OUTPUT>, + <&ccu CLK_MMC1_SAMPLE>; + clock-names = "ahb", + "mmc", + "output", + "sample"; + resets = <&ccu RST_BUS_MMC1>; + reset-names = "ahb"; + interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + mmc2: mmc@1c11000 { + compatible = "allwinner,sun8i-a83t-emmc"; + reg = <0x01c11000 0x1000>; + clocks = <&ccu CLK_BUS_MMC2>, + <&ccu CLK_MMC2>, + <&ccu CLK_MMC2_OUTPUT>, + <&ccu CLK_MMC2_SAMPLE>; + clock-names = "ahb", + "mmc", + "output", + "sample"; + resets = <&ccu RST_BUS_MMC2>; + reset-names = "ahb"; + interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + sid: eeprom@1c14000 { + compatible = "allwinner,sun8i-a83t-sid"; + reg = <0x1c14000 0x400>; + }; + + usb_otg: usb@1c19000 { + compatible = "allwinner,sun8i-a83t-musb", + "allwinner,sun8i-a33-musb"; + reg = <0x01c19000 0x0400>; + clocks = <&ccu CLK_BUS_OTG>; + resets = <&ccu RST_BUS_OTG>; + interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "mc"; + phys = <&usbphy 0>; + phy-names = "usb"; + extcon = <&usbphy 0>; + status = "disabled"; + }; + + usbphy: phy@1c19400 { + compatible = "allwinner,sun8i-a83t-usb-phy"; + reg = <0x01c19400 0x10>, + <0x01c1a800 0x14>, + <0x01c1b800 0x14>; + reg-names = "phy_ctrl", + "pmu1", + "pmu2"; + clocks = <&ccu CLK_USB_PHY0>, + <&ccu CLK_USB_PHY1>, + <&ccu CLK_USB_HSIC>, + <&ccu CLK_USB_HSIC_12M>; + clock-names = "usb0_phy", + "usb1_phy", + "usb2_phy", + "usb2_hsic_12M"; + resets = <&ccu RST_USB_PHY0>, + <&ccu RST_USB_PHY1>, + <&ccu RST_USB_HSIC>; + reset-names = "usb0_reset", + "usb1_reset", + "usb2_reset"; + status = "disabled"; + #phy-cells = <1>; + }; + + ehci0: usb@1c1a000 { + compatible = "allwinner,sun8i-a83t-ehci", + "generic-ehci"; + reg = <0x01c1a000 0x100>; + interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_EHCI0>; + resets = <&ccu RST_BUS_EHCI0>; + phys = <&usbphy 1>; + phy-names = "usb"; + status = "disabled"; + }; + + ohci0: usb@1c1a400 { + compatible = "allwinner,sun8i-a83t-ohci", + "generic-ohci"; + reg = <0x01c1a400 0x100>; + interrupts = <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_OHCI0>, <&ccu CLK_USB_OHCI0>; + resets = <&ccu RST_BUS_OHCI0>; + phys = <&usbphy 1>; + phy-names = "usb"; + status = "disabled"; + }; + + ehci1: usb@1c1b000 { + compatible = "allwinner,sun8i-a83t-ehci", + "generic-ehci"; + reg = <0x01c1b000 0x100>; + interrupts = <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_EHCI1>; + resets = <&ccu RST_BUS_EHCI1>; + phys = <&usbphy 2>; + phy-names = "usb"; + status = "disabled"; + }; + + ccu: clock@1c20000 { + compatible = "allwinner,sun8i-a83t-ccu"; + reg = <0x01c20000 0x400>; + clocks = <&osc24M>, <&osc16Md512>; + clock-names = "hosc", "losc"; + #clock-cells = <1>; + #reset-cells = <1>; + }; + + pio: pinctrl@1c20800 { compatible = "allwinner,sun8i-a83t-pinctrl"; interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; reg = <0x01c20800 0x400>; - clocks = <&osc24M>; + clocks = <&ccu CLK_BUS_PIO>, <&osc24M>, <&osc16Md512>; + clock-names = "apb", "hosc", "losc"; gpio-controller; interrupt-controller; #interrupt-cells = <3>; #gpio-cells = <3>;
- mmc0_pins_a: mmc0@0 { - allwinner,pins = "PF0", "PF1", "PF2", - "PF3", "PF4", "PF5"; - allwinner,function = "mmc0"; - allwinner,drive = <SUN4I_PINCTRL_30_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + emac_rgmii_pins: emac-rgmii-pins { + pins = "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", + "PD11", "PD12", "PD13", "PD14", "PD18", + "PD19", "PD21", "PD22", "PD23"; + function = "gmac"; + /* + * data lines in RGMII mode use DDR mode + * and need a higher signal drive strength + */ + drive-strength = <40>; + }; + + hdmi_pins: hdmi-pins { + pins = "PH6", "PH7", "PH8"; + function = "hdmi"; + }; + + i2c0_pins: i2c0-pins { + pins = "PH0", "PH1"; + function = "i2c0"; + }; + + i2c1_pins: i2c1-pins { + pins = "PH2", "PH3"; + function = "i2c1"; + }; + + i2c2_ph_pins: i2c2-ph-pins { + pins = "PH4", "PH5"; + function = "i2c2"; + }; + + i2s1_pins: i2s1-pins { + /* I2S1 does not have external MCLK pin */ + pins = "PG10", "PG11", "PG12", "PG13"; + function = "i2s1"; + }; + + lcd_lvds_pins: lcd-lvds-pins { + pins = "PD18", "PD19", "PD20", "PD21", "PD22", + "PD23", "PD24", "PD25", "PD26", "PD27"; + function = "lvds0"; + }; + + mmc0_pins: mmc0-pins { + pins = "PF0", "PF1", "PF2", + "PF3", "PF4", "PF5"; + function = "mmc0"; + drive-strength = <30>; + bias-pull-up; + }; + + mmc1_pins: mmc1-pins { + pins = "PG0", "PG1", "PG2", + "PG3", "PG4", "PG5"; + function = "mmc1"; + drive-strength = <30>; + bias-pull-up; + }; + + mmc2_8bit_emmc_pins: mmc2-8bit-emmc-pins { + pins = "PC5", "PC6", "PC8", "PC9", + "PC10", "PC11", "PC12", "PC13", + "PC14", "PC15", "PC16"; + function = "mmc2"; + drive-strength = <30>; + bias-pull-up; + }; + + pwm_pin: pwm-pin { + pins = "PD28"; + function = "pwm"; + }; + + spdif_tx_pin: spdif-tx-pin { + pins = "PE18"; + function = "spdif"; + }; + + uart0_pb_pins: uart0-pb-pins { + pins = "PB9", "PB10"; + function = "uart0"; + }; + + uart0_pf_pins: uart0-pf-pins { + pins = "PF2", "PF4"; + function = "uart0"; };
- uart0_pins_a: uart0@0 { - allwinner,pins = "PF2", "PF4"; - allwinner,function = "uart0"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + uart1_pins: uart1-pins { + pins = "PG6", "PG7"; + function = "uart1"; };
- uart0_pins_b: uart0@1 { - allwinner,pins = "PB9", "PB10"; - allwinner,function = "uart0"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + uart1_rts_cts_pins: uart1-rts-cts-pins { + pins = "PG8", "PG9"; + function = "uart1"; }; };
- timer@01c20c00 { + timer@1c20c00 { compatible = "allwinner,sun4i-a10-timer"; reg = <0x01c20c00 0xa0>; interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>, @@ -197,27 +757,166 @@ clocks = <&osc24M>; };
- watchdog@01c20ca0 { + watchdog@1c20ca0 { compatible = "allwinner,sun6i-a31-wdt"; reg = <0x01c20ca0 0x20>; interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; clocks = <&osc24M>; };
- uart0: serial@01c28000 { + spdif: spdif@1c21000 { + #sound-dai-cells = <0>; + compatible = "allwinner,sun8i-a83t-spdif", + "allwinner,sun8i-h3-spdif"; + reg = <0x01c21000 0x400>; + interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_SPDIF>, <&ccu CLK_SPDIF>; + resets = <&ccu RST_BUS_SPDIF>; + clock-names = "apb", "spdif"; + dmas = <&dma 2>; + dma-names = "tx"; + pinctrl-names = "default"; + pinctrl-0 = <&spdif_tx_pin>; + status = "disabled"; + }; + + i2s0: i2s@1c22000 { + #sound-dai-cells = <0>; + compatible = "allwinner,sun8i-a83t-i2s"; + reg = <0x01c22000 0x400>; + interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2S0>, <&ccu CLK_I2S0>; + clock-names = "apb", "mod"; + dmas = <&dma 3>, <&dma 3>; + resets = <&ccu RST_BUS_I2S0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + i2s1: i2s@1c22400 { + #sound-dai-cells = <0>; + compatible = "allwinner,sun8i-a83t-i2s"; + reg = <0x01c22400 0x400>; + interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2S1>, <&ccu CLK_I2S1>; + clock-names = "apb", "mod"; + dmas = <&dma 4>, <&dma 4>; + resets = <&ccu RST_BUS_I2S1>; + dma-names = "rx", "tx"; + pinctrl-names = "default"; + pinctrl-0 = <&i2s1_pins>; + status = "disabled"; + }; + + i2s2: i2s@1c22800 { + #sound-dai-cells = <0>; + compatible = "allwinner,sun8i-a83t-i2s"; + reg = <0x01c22800 0x400>; + interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2S2>, <&ccu CLK_I2S2>; + clock-names = "apb", "mod"; + dmas = <&dma 27>; + resets = <&ccu RST_BUS_I2S2>; + dma-names = "tx"; + status = "disabled"; + }; + + pwm: pwm@1c21400 { + compatible = "allwinner,sun8i-a83t-pwm", + "allwinner,sun8i-h3-pwm"; + reg = <0x01c21400 0x400>; + clocks = <&osc24M>; + #pwm-cells = <3>; + status = "disabled"; + }; + + uart0: serial@1c28000 { compatible = "snps,dw-apb-uart"; reg = <0x01c28000 0x400>; interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clocks = <&osc24M>; + clocks = <&ccu CLK_BUS_UART0>; + resets = <&ccu RST_BUS_UART0>; status = "disabled"; };
- gic: interrupt-controller@01c81000 { + uart1: serial@1c28400 { + compatible = "snps,dw-apb-uart"; + reg = <0x01c28400 0x400>; + interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&ccu CLK_BUS_UART1>; + resets = <&ccu RST_BUS_UART1>; + status = "disabled"; + }; + + i2c0: i2c@1c2ac00 { + compatible = "allwinner,sun8i-a83t-i2c", + "allwinner,sun6i-a31-i2c"; + reg = <0x01c2ac00 0x400>; + interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2C0>; + resets = <&ccu RST_BUS_I2C0>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_pins>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c1: i2c@1c2b000 { + compatible = "allwinner,sun8i-a83t-i2c", + "allwinner,sun6i-a31-i2c"; + reg = <0x01c2b000 0x400>; + interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2C1>; + resets = <&ccu RST_BUS_I2C1>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c2: i2c@1c2b400 { + compatible = "allwinner,sun8i-a83t-i2c", + "allwinner,sun6i-a31-i2c"; + reg = <0x01c2b400 0x400>; + interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2C2>; + resets = <&ccu RST_BUS_I2C2>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + emac: ethernet@1c30000 { + compatible = "allwinner,sun8i-a83t-emac"; + syscon = <&syscon>; + reg = <0x01c30000 0x104>; + interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq"; + resets = <&ccu 13>; + reset-names = "stmmaceth"; + clocks = <&ccu 27>; + clock-names = "stmmaceth"; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + + mdio: mdio { + compatible = "snps,dwmac-mdio"; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + gic: interrupt-controller@1c81000 { compatible = "arm,cortex-a7-gic", "arm,cortex-a15-gic"; reg = <0x01c81000 0x1000>, - <0x01c82000 0x1000>, + <0x01c82000 0x2000>, <0x01c84000 0x2000>, <0x01c86000 0x2000>; interrupt-controller; @@ -225,59 +924,107 @@ interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_HIGH)>; };
- usb_otg: usb@01c19000 { - compatible = "allwinner,sun8i-a33-musb"; - reg = <0x01c19000 0x400>; - interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "mc"; - phys = <&usbphy 0>; - phy-names = "usb"; + hdmi: hdmi@1ee0000 { + compatible = "allwinner,sun8i-a83t-dw-hdmi"; + reg = <0x01ee0000 0x10000>; + reg-io-width = <1>; + interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_HDMI>, <&ccu CLK_HDMI_SLOW>, + <&ccu CLK_HDMI>; + clock-names = "iahb", "isfr", "tmds"; + resets = <&ccu RST_BUS_HDMI1>; + reset-names = "ctrl"; + phys = <&hdmi_phy>; + phy-names = "hdmi-phy"; + pinctrl-names = "default"; + pinctrl-0 = <&hdmi_pins>; status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + hdmi_in: port@0 { + reg = <0>; + + hdmi_in_tcon1: endpoint { + remote-endpoint = <&tcon1_out_hdmi>; + }; + }; + + hdmi_out: port@1 { + reg = <1>; + }; + }; };
- usbphy: phy@1c19400 { - compatible = "allwinner,sun8i-a83t-usb-phy"; - reg = <0x01c19400 0x10>, - <0x01c1a800 0x14>, - <0x01c1b800 0x14>; - reg-names = "phy_ctrl", - "pmu1", - "pmu2"; - status = "disabled"; - #phy-cells = <1>; + hdmi_phy: hdmi-phy@1ef0000 { + compatible = "allwinner,sun8i-a83t-hdmi-phy"; + reg = <0x01ef0000 0x10000>; + clocks = <&ccu CLK_BUS_HDMI>, <&ccu CLK_HDMI_SLOW>; + clock-names = "bus", "mod"; + resets = <&ccu RST_BUS_HDMI0>; + reset-names = "phy"; + #phy-cells = <0>; };
- ehci0: usb@01c1a000 { - compatible = "allwinner,sun8i-a83t-ehci", "generic-ehci"; - reg = <0x01c1a000 0x100>; - interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>; - phys = <&usbphy 1>; - phy-names = "usb"; - status = "disabled"; + r_intc: interrupt-controller@1f00c00 { + compatible = "allwinner,sun8i-a83t-r-intc", + "allwinner,sun6i-a31-r-intc"; + interrupt-controller; + #interrupt-cells = <2>; + reg = <0x01f00c00 0x400>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; };
- ohci0: usb@01c1a400 { - compatible = "allwinner,sun8i-a83t-ohci", "generic-ohci"; - reg = <0x01c1a400 0x100>; - interrupts = <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; - phys = <&usbphy 1>; - phy-names = "usb"; - status = "disabled"; + r_ccu: clock@1f01400 { + compatible = "allwinner,sun8i-a83t-r-ccu"; + reg = <0x01f01400 0x400>; + clocks = <&osc24M>, <&osc16Md512>, <&osc16M>, + <&ccu 6>; + clock-names = "hosc", "losc", "iosc", "pll-periph"; + #clock-cells = <1>; + #reset-cells = <1>; };
- ehci1: usb@01c1b000 { - compatible = "allwinner,sun8i-a83t-ehci", "generic-ehci"; - reg = <0x01c1b000 0x100>; - interrupts = <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>; - phys = <&usbphy 2>; - phy-names = "usb"; - status = "disabled"; + r_cpucfg@1f01c00 { + compatible = "allwinner,sun8i-a83t-r-cpucfg"; + reg = <0x1f01c00 0x400>; };
- r_pio: pinctrl@01f02c00 { + r_pio: pinctrl@1f02c00 { compatible = "allwinner,sun8i-a83t-r-pinctrl"; reg = <0x01f02c00 0x400>; interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&r_ccu CLK_APB0_PIO>, <&osc24M>, + <&osc16Md512>; + clock-names = "apb", "hosc", "losc"; + gpio-controller; + #gpio-cells = <3>; + interrupt-controller; + #interrupt-cells = <3>; + + r_rsb_pins: r-rsb-pins { + pins = "PL0", "PL1"; + function = "s_rsb"; + drive-strength = <20>; + bias-pull-up; + }; + }; + + r_rsb: rsb@1f03400 { + compatible = "allwinner,sun8i-a83t-rsb", + "allwinner,sun8i-a23-rsb"; + reg = <0x01f03400 0x400>; + interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&r_ccu CLK_APB0_RSB>; + clock-frequency = <3000000>; + resets = <&r_ccu RST_APB0_RSB>; + pinctrl-names = "default"; + pinctrl-0 = <&r_rsb_pins>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; }; }; }; diff --git a/include/dt-bindings/clock/sun8i-a83t-ccu.h b/include/dt-bindings/clock/sun8i-a83t-ccu.h new file mode 100644 index 0000000000..78af5085f6 --- /dev/null +++ b/include/dt-bindings/clock/sun8i-a83t-ccu.h @@ -0,0 +1,140 @@ +/* + * Copyright (C) 2017 Chen-Yu Tsai wens@csie.org + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#ifndef _DT_BINDINGS_CLOCK_SUN8I_A83T_CCU_H_ +#define _DT_BINDINGS_CLOCK_SUN8I_A83T_CCU_H_ + +#define CLK_PLL_PERIPH 6 + +#define CLK_PLL_DE 9 + +#define CLK_C0CPUX 11 +#define CLK_C1CPUX 12 + +#define CLK_BUS_MIPI_DSI 19 +#define CLK_BUS_SS 20 +#define CLK_BUS_DMA 21 +#define CLK_BUS_MMC0 22 +#define CLK_BUS_MMC1 23 +#define CLK_BUS_MMC2 24 +#define CLK_BUS_NAND 25 +#define CLK_BUS_DRAM 26 +#define CLK_BUS_EMAC 27 +#define CLK_BUS_HSTIMER 28 +#define CLK_BUS_SPI0 29 +#define CLK_BUS_SPI1 30 +#define CLK_BUS_OTG 31 +#define CLK_BUS_EHCI0 32 +#define CLK_BUS_EHCI1 33 +#define CLK_BUS_OHCI0 34 + +#define CLK_BUS_VE 35 +#define CLK_BUS_TCON0 36 +#define CLK_BUS_TCON1 37 +#define CLK_BUS_CSI 38 +#define CLK_BUS_HDMI 39 +#define CLK_BUS_DE 40 +#define CLK_BUS_GPU 41 +#define CLK_BUS_MSGBOX 42 +#define CLK_BUS_SPINLOCK 43 + +#define CLK_BUS_SPDIF 44 +#define CLK_BUS_PIO 45 +#define CLK_BUS_I2S0 46 +#define CLK_BUS_I2S1 47 +#define CLK_BUS_I2S2 48 +#define CLK_BUS_TDM 49 + +#define CLK_BUS_I2C0 50 +#define CLK_BUS_I2C1 51 +#define CLK_BUS_I2C2 52 +#define CLK_BUS_UART0 53 +#define CLK_BUS_UART1 54 +#define CLK_BUS_UART2 55 +#define CLK_BUS_UART3 56 +#define CLK_BUS_UART4 57 + +#define CLK_NAND 59 +#define CLK_MMC0 60 +#define CLK_MMC0_SAMPLE 61 +#define CLK_MMC0_OUTPUT 62 +#define CLK_MMC1 63 +#define CLK_MMC1_SAMPLE 64 +#define CLK_MMC1_OUTPUT 65 +#define CLK_MMC2 66 +#define CLK_MMC2_SAMPLE 67 +#define CLK_MMC2_OUTPUT 68 +#define CLK_SS 69 +#define CLK_SPI0 70 +#define CLK_SPI1 71 +#define CLK_I2S0 72 +#define CLK_I2S1 73 +#define CLK_I2S2 74 +#define CLK_TDM 75 +#define CLK_SPDIF 76 +#define CLK_USB_PHY0 77 +#define CLK_USB_PHY1 78 +#define CLK_USB_HSIC 79 +#define CLK_USB_HSIC_12M 80 +#define CLK_USB_OHCI0 81 + +#define CLK_DRAM_VE 83 +#define CLK_DRAM_CSI 84 + +#define CLK_TCON0 85 +#define CLK_TCON1 86 +#define CLK_CSI_MISC 87 +#define CLK_MIPI_CSI 88 +#define CLK_CSI_MCLK 89 +#define CLK_CSI_SCLK 90 +#define CLK_VE 91 +#define CLK_AVS 92 +#define CLK_HDMI 93 +#define CLK_HDMI_SLOW 94 + +#define CLK_MIPI_DSI0 96 +#define CLK_MIPI_DSI1 97 +#define CLK_GPU_CORE 98 +#define CLK_GPU_MEMORY 99 +#define CLK_GPU_HYD 100 + +#endif /* _DT_BINDINGS_CLOCK_SUN8I_A83T_CCU_H_ */ diff --git a/include/dt-bindings/reset/sun8i-a83t-ccu.h b/include/dt-bindings/reset/sun8i-a83t-ccu.h new file mode 100644 index 0000000000..784f6e1166 --- /dev/null +++ b/include/dt-bindings/reset/sun8i-a83t-ccu.h @@ -0,0 +1,98 @@ +/* + * Copyright (C) 2017 Chen-Yu Tsai wens@csie.org + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#ifndef _DT_BINDINGS_RESET_SUN8I_A83T_CCU_H_ +#define _DT_BINDINGS_RESET_SUN8I_A83T_CCU_H_ + +#define RST_USB_PHY0 0 +#define RST_USB_PHY1 1 +#define RST_USB_HSIC 2 + +#define RST_DRAM 3 +#define RST_MBUS 4 + +#define RST_BUS_MIPI_DSI 5 +#define RST_BUS_SS 6 +#define RST_BUS_DMA 7 +#define RST_BUS_MMC0 8 +#define RST_BUS_MMC1 9 +#define RST_BUS_MMC2 10 +#define RST_BUS_NAND 11 +#define RST_BUS_DRAM 12 +#define RST_BUS_EMAC 13 +#define RST_BUS_HSTIMER 14 +#define RST_BUS_SPI0 15 +#define RST_BUS_SPI1 16 +#define RST_BUS_OTG 17 +#define RST_BUS_EHCI0 18 +#define RST_BUS_EHCI1 19 +#define RST_BUS_OHCI0 20 + +#define RST_BUS_VE 21 +#define RST_BUS_TCON0 22 +#define RST_BUS_TCON1 23 +#define RST_BUS_CSI 24 +#define RST_BUS_HDMI0 25 +#define RST_BUS_HDMI1 26 +#define RST_BUS_DE 27 +#define RST_BUS_GPU 28 +#define RST_BUS_MSGBOX 29 +#define RST_BUS_SPINLOCK 30 + +#define RST_BUS_LVDS 31 + +#define RST_BUS_SPDIF 32 +#define RST_BUS_I2S0 33 +#define RST_BUS_I2S1 34 +#define RST_BUS_I2S2 35 +#define RST_BUS_TDM 36 + +#define RST_BUS_I2C0 37 +#define RST_BUS_I2C1 38 +#define RST_BUS_I2C2 39 +#define RST_BUS_UART0 40 +#define RST_BUS_UART1 41 +#define RST_BUS_UART2 42 +#define RST_BUS_UART3 43 +#define RST_BUS_UART4 44 + +#endif /* _DT_BINDINGS_RESET_SUN8I_A83T_CCU_H_ */
Add emmc compatible for A83T SoC.
Cc: VishnuPatekar vishnupatekar0510@gmail.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/mmc/sunxi_mmc.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/mmc/sunxi_mmc.c b/drivers/mmc/sunxi_mmc.c index 16e94cf4b7..1e7bea4d5a 100644 --- a/drivers/mmc/sunxi_mmc.c +++ b/drivers/mmc/sunxi_mmc.c @@ -687,6 +687,8 @@ static const struct udevice_id sunxi_mmc_ids[] = { .data = (ulong)&sun4i_a10_cfg }, { .compatible = "allwinner,sun7i-a20-mmc", .data = (ulong)&sun7i_a20_cfg }, + { .compatible = "allwinner,sun8i-a83t-emmc", + .data = (ulong)&sun7i_a20_cfg }, { .compatible = "allwinner,sun50i-a64-mmc", .data = (ulong)&sun7i_a20_cfg }, { .compatible = "allwinner,sun50i-a64-emmc",
Enable DM_MMC for Allwinner A83T SoC.
Tested on BPI-M3.
Cc: VishnuPatekar vishnupatekar0510@gmail.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/mach-sunxi/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 3b790e39dd..d5b0700e13 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -216,6 +216,7 @@ config MACH_SUN8I_A33 config MACH_SUN8I_A83T bool "sun8i (Allwinner A83T)" select CPU_V7A + select DM_MMC if MMC select DRAM_SUN8I_A83T select PHY_SUN4I_USB select SUNXI_GEN_SUN6I
Update all R40 devicetree dtsi and dtsi files from Linux with below commit: commit 6a7556f604f94461ca802ab69a6dad317c014d30 Author: Jernej Skrabec jernej.skrabec@siol.net Date: Tue Jul 10 22:35:09 2018 +0200
ARM: dts: sun8i: r40: Disable TCONs by default.
and BPI-M2 berry commit c5f0bb472795170ab5c33be12e29ce7465fb31ed Author: Icenowy Zheng icenowy@aosc.io Date: Fri Apr 6 22:03:44 2018 +0800
ARM: sun8i: v40: enable USB host ports for Banana Pi M2 Berry
Cc: Lothar Felten lothar.felten@gmail.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts | 197 +++++- arch/arm/dts/sun8i-r40.dtsi | 616 ++++++++++++++++++- arch/arm/dts/sun8i-v40-bananapi-m2-berry.dts | 50 ++ 3 files changed, 830 insertions(+), 33 deletions(-)
diff --git a/arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts b/arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts index 28c9158302..c39b9169ea 100644 --- a/arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts +++ b/arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts @@ -1,5 +1,6 @@ /* - * Copyright (C) 2016 Chen-Yu Tsai wens@csie.org + * Copyright (C) 2017 Chen-Yu Tsai wens@csie.org + * Copyright (C) 2017 Icenowy Zheng icenowy@aosc.io * * This file is dual-licensed: you can use it either under the terms * of the GPL or the X11 license, at your option. Note that this dual @@ -43,6 +44,8 @@ /dts-v1/; #include "sun8i-r40.dtsi"
+#include <dt-bindings/gpio/gpio.h> + / { model = "Banana Pi BPI-M2-Ultra"; compatible = "sinovoip,bpi-m2-ultra", "allwinner,sun8i-r40"; @@ -55,17 +58,62 @@ chosen { stdout-path = "serial0:115200n8"; }; + + connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + + leds { + compatible = "gpio-leds"; + + pwr-led { + label = "bananapi:red:pwr"; + gpios = <&pio 7 20 GPIO_ACTIVE_HIGH>; + default-state = "on"; + }; + + user-led-green { + label = "bananapi:green:user"; + gpios = <&pio 7 21 GPIO_ACTIVE_HIGH>; + }; + + user-led-blue { + label = "bananapi:blue:user"; + gpios = <&pio 7 22 GPIO_ACTIVE_HIGH>; + }; + }; + + reg_vcc5v0: vcc5v0 { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&pio 7 23 GPIO_ACTIVE_HIGH>; /* PH23 */ + enable-active-high; + }; + + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&pio 6 10 GPIO_ACTIVE_LOW>; /* PG10 WIFI_EN */ + }; };
-&i2c0 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c0_pins>; +&de { status = "okay"; };
-&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_pb_pins>; +&ehci1 { + status = "okay"; +}; + +&ehci2 { status = "okay"; };
@@ -74,6 +122,7 @@ pinctrl-0 = <&gmac_rgmii_pins>; phy-handle = <&phy1>; phy-mode = "rgmii"; + phy-supply = <®_dc1sw>; status = "okay"; };
@@ -83,3 +132,137 @@ reg = <1>; }; }; + +&hdmi { + status = "okay"; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + +&i2c0 { + status = "okay"; + + axp22x: pmic@34 { + compatible = "x-powers,axp221"; + reg = <0x34>; + interrupt-parent = <&nmi_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + }; +}; + +#include "axp22x.dtsi" + +&mmc0 { + vmmc-supply = <®_dcdc1>; + bus-width = <4>; + cd-gpios = <&pio 7 13 GPIO_ACTIVE_HIGH>; /* PH13 */ + cd-inverted; + status = "okay"; +}; + +&mmc1 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pg_pins>; + vmmc-supply = <®_dldo2>; + vqmmc-supply = <®_dldo1>; + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; +}; + +&mmc2 { + vmmc-supply = <®_dcdc1>; + vqmmc-supply = <®_dcdc1>; + bus-width = <8>; + non-removable; + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + +&ohci2 { + status = "okay"; +}; + +®_aldo2 { + regulator-always-on; + regulator-min-microvolt = <2500000>; + regulator-max-microvolt = <2500000>; + regulator-name = "vcc-pa"; +}; + +®_aldo3 { + regulator-always-on; + regulator-min-microvolt = <2700000>; + regulator-max-microvolt = <3300000>; + regulator-name = "avcc"; +}; + +®_dc1sw { + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcc-gmac-phy"; +}; + +®_dcdc1 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcc-3v0"; +}; + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1300000>; + regulator-name = "vdd-cpu"; +}; + +®_dcdc3 { + regulator-always-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1300000>; + regulator-name = "vdd-sys"; +}; + +®_dcdc5 { + regulator-always-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-name = "vcc-dram"; +}; + +®_dldo1 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-wifi-io"; +}; + +®_dldo2 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-wifi"; +}; + +&tcon_tv0 { + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pb_pins>; + status = "okay"; +}; + +&usbphy { + usb1_vbus-supply = <®_vcc5v0>; + usb2_vbus-supply = <®_vcc5v0>; + status = "okay"; +}; diff --git a/arch/arm/dts/sun8i-r40.dtsi b/arch/arm/dts/sun8i-r40.dtsi index 2cdfb54282..e2cbd4f645 100644 --- a/arch/arm/dts/sun8i-r40.dtsi +++ b/arch/arm/dts/sun8i-r40.dtsi @@ -1,7 +1,6 @@ /* - * Copyright 2016 Chen-Yu Tsai - * - * Chen-Yu Tsai wens@csie.org + * Copyright 2017 Chen-Yu Tsai wens@csie.org + * Copyright 2017 Icenowy Zheng icenowy@aosc.io * * This file is dual-licensed: you can use it either under the terms * of the GPL or the X11 license, at your option. Note that this dual @@ -43,32 +42,29 @@ */
#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/clock/sun8i-de2.h> #include <dt-bindings/clock/sun8i-r40-ccu.h> #include <dt-bindings/reset/sun8i-r40-ccu.h> +#include <dt-bindings/reset/sun8i-de2.h>
/ { #address-cells = <1>; #size-cells = <1>; interrupt-parent = <&gic>;
- aliases { - }; - - chosen { - }; - clocks { #address-cells = <1>; #size-cells = <1>; ranges;
- osc24M: osc24M_clk { + osc24M: osc24M { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <24000000>; + clock-output-names = "osc24M"; };
- osc32k: osc32k_clk { + osc32k: osc32k { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <32768>; @@ -80,7 +76,7 @@ #address-cells = <1>; #size-cells = <0>;
- cpu0: cpu@0 { + cpu@0 { compatible = "arm,cortex-a7"; device_type = "cpu"; reg = <0>; @@ -105,9 +101,10 @@ }; };
- memory@40000000 { - device_type = "memory"; - reg = <0x40000000 0x80000000>; + de: display-engine { + compatible = "allwinner,sun8i-r40-display-engine"; + allwinner,pipelines = <&mixer0>, <&mixer1>; + status = "disabled"; };
soc { @@ -116,6 +113,63 @@ #size-cells = <1>; ranges;
+ display_clocks: clock@1000000 { + compatible = "allwinner,sun8i-r40-de2-clk", + "allwinner,sun8i-h3-de2-clk"; + reg = <0x01000000 0x100000>; + clocks = <&ccu CLK_DE>, + <&ccu CLK_BUS_DE>; + clock-names = "mod", + "bus"; + resets = <&ccu RST_BUS_DE>; + #clock-cells = <1>; + #reset-cells = <1>; + }; + + mixer0: mixer@1100000 { + compatible = "allwinner,sun8i-r40-de2-mixer-0"; + reg = <0x01100000 0x100000>; + clocks = <&display_clocks CLK_BUS_MIXER0>, + <&display_clocks CLK_MIXER0>; + clock-names = "bus", + "mod"; + resets = <&display_clocks RST_MIXER0>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + mixer0_out: port@1 { + reg = <1>; + mixer0_out_tcon_top: endpoint { + remote-endpoint = <&tcon_top_mixer0_in_mixer0>; + }; + }; + }; + }; + + mixer1: mixer@1200000 { + compatible = "allwinner,sun8i-r40-de2-mixer-1"; + reg = <0x01200000 0x100000>; + clocks = <&display_clocks CLK_BUS_MIXER1>, + <&display_clocks CLK_MIXER1>; + clock-names = "bus", + "mod"; + resets = <&display_clocks RST_WB>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + mixer1_out: port@1 { + reg = <1>; + mixer1_out_tcon_top: endpoint { + remote-endpoint = <&tcon_top_mixer1_in_mixer1>; + }; + }; + }; + }; + nmi_intc: interrupt-controller@1c00030 { compatible = "allwinner,sun7i-a20-sc-nmi"; interrupt-controller; @@ -140,6 +194,122 @@ #size-cells = <0>; };
+ mmc1: mmc@1c10000 { + compatible = "allwinner,sun8i-r40-mmc", + "allwinner,sun50i-a64-mmc"; + reg = <0x01c10000 0x1000>; + clocks = <&ccu CLK_BUS_MMC1>, <&ccu CLK_MMC1>; + clock-names = "ahb", "mmc"; + resets = <&ccu RST_BUS_MMC1>; + reset-names = "ahb"; + interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + mmc2: mmc@1c11000 { + compatible = "allwinner,sun8i-r40-emmc", + "allwinner,sun50i-a64-emmc"; + reg = <0x01c11000 0x1000>; + clocks = <&ccu CLK_BUS_MMC2>, <&ccu CLK_MMC2>; + clock-names = "ahb", "mmc"; + resets = <&ccu RST_BUS_MMC2>; + reset-names = "ahb"; + pinctrl-0 = <&mmc2_pins>; + pinctrl-names = "default"; + interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + mmc3: mmc@1c12000 { + compatible = "allwinner,sun8i-r40-mmc", + "allwinner,sun50i-a64-mmc"; + reg = <0x01c12000 0x1000>; + clocks = <&ccu CLK_BUS_MMC3>, <&ccu CLK_MMC3>; + clock-names = "ahb", "mmc"; + resets = <&ccu RST_BUS_MMC3>; + reset-names = "ahb"; + interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + usbphy: phy@1c13400 { + compatible = "allwinner,sun8i-r40-usb-phy"; + reg = <0x01c13400 0x14>, + <0x01c14800 0x4>, + <0x01c19800 0x4>, + <0x01c1c800 0x4>; + reg-names = "phy_ctrl", + "pmu0", + "pmu1", + "pmu2"; + clocks = <&ccu CLK_USB_PHY0>, + <&ccu CLK_USB_PHY1>, + <&ccu CLK_USB_PHY2>; + clock-names = "usb0_phy", + "usb1_phy", + "usb2_phy"; + resets = <&ccu RST_USB_PHY0>, + <&ccu RST_USB_PHY1>, + <&ccu RST_USB_PHY2>; + reset-names = "usb0_reset", + "usb1_reset", + "usb2_reset"; + status = "disabled"; + #phy-cells = <1>; + }; + + ehci1: usb@1c19000 { + compatible = "allwinner,sun8i-r40-ehci", "generic-ehci"; + reg = <0x01c19000 0x100>; + interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_EHCI1>; + resets = <&ccu RST_BUS_EHCI1>; + phys = <&usbphy 1>; + phy-names = "usb"; + status = "disabled"; + }; + + ohci1: usb@1c19400 { + compatible = "allwinner,sun8i-r40-ohci", "generic-ohci"; + reg = <0x01c19400 0x100>; + interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_OHCI1>, + <&ccu CLK_USB_OHCI1>; + resets = <&ccu RST_BUS_OHCI1>; + phys = <&usbphy 1>; + phy-names = "usb"; + status = "disabled"; + }; + + ehci2: usb@1c1c000 { + compatible = "allwinner,sun8i-r40-ehci", "generic-ehci"; + reg = <0x01c1c000 0x100>; + interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_EHCI2>; + resets = <&ccu RST_BUS_EHCI2>; + phys = <&usbphy 2>; + phy-names = "usb"; + status = "disabled"; + }; + + ohci2: usb@1c1c400 { + compatible = "allwinner,sun8i-r40-ohci", "generic-ohci"; + reg = <0x01c1c400 0x100>; + interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_OHCI2>, + <&ccu CLK_USB_OHCI2>; + resets = <&ccu RST_BUS_OHCI2>; + phys = <&usbphy 2>; + phy-names = "usb"; + status = "disabled"; + }; + ccu: clock@1c20000 { compatible = "allwinner,sun8i-r40-ccu"; reg = <0x01c20000 0x400>; @@ -153,8 +323,7 @@ compatible = "allwinner,sun8i-r40-pinctrl"; reg = <0x01c20800 0x400>; interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; - /* apb should be replaced once CCU is implemented */ - clocks = <&osc24M>, <&osc24M>, <&osc32k>; + clocks = <&ccu CLK_BUS_PIO>, <&osc24M>, <&osc32k>; clock-names = "apb", "hosc", "losc"; gpio-controller; interrupt-controller; @@ -174,10 +343,9 @@ drive-strength = <40>; };
- i2c0_pins: i2c0_pins { + i2c0_pins: i2c0-pins { pins = "PB0", "PB1"; function = "i2c0"; - bias-pull-up; };
mmc0_pins: mmc0-pins { @@ -188,20 +356,119 @@ bias-pull-up; };
- uart0_pb_pins: uart0_pb_pins { + mmc1_pg_pins: mmc1-pg-pins { + pins = "PG0", "PG1", "PG2", + "PG3", "PG4", "PG5"; + function = "mmc1"; + drive-strength = <30>; + bias-pull-up; + }; + + mmc2_pins: mmc2-pins { + pins = "PC5", "PC6", "PC7", "PC8", "PC9", + "PC10", "PC11", "PC12", "PC13", "PC14", + "PC15", "PC24"; + function = "mmc2"; + drive-strength = <30>; + bias-pull-up; + }; + + uart0_pb_pins: uart0-pb-pins { pins = "PB22", "PB23"; function = "uart0"; - bias-pull-up; }; };
+ wdt: watchdog@1c20c90 { + compatible = "allwinner,sun4i-a10-wdt"; + reg = <0x01c20c90 0x10>; + }; + uart0: serial@1c28000 { compatible = "snps,dw-apb-uart"; reg = <0x01c28000 0x400>; interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clocks = <&osc24M>; + clocks = <&ccu CLK_BUS_UART0>; + resets = <&ccu RST_BUS_UART0>; + status = "disabled"; + }; + + uart1: serial@1c28400 { + compatible = "snps,dw-apb-uart"; + reg = <0x01c28400 0x400>; + interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&ccu CLK_BUS_UART1>; + resets = <&ccu RST_BUS_UART1>; + status = "disabled"; + }; + + uart2: serial@1c28800 { + compatible = "snps,dw-apb-uart"; + reg = <0x01c28800 0x400>; + interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&ccu CLK_BUS_UART2>; + resets = <&ccu RST_BUS_UART2>; + status = "disabled"; + }; + + uart3: serial@1c28c00 { + compatible = "snps,dw-apb-uart"; + reg = <0x01c28c00 0x400>; + interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&ccu CLK_BUS_UART3>; + resets = <&ccu RST_BUS_UART3>; + status = "disabled"; + }; + + uart4: serial@1c29000 { + compatible = "snps,dw-apb-uart"; + reg = <0x01c29000 0x400>; + interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&ccu CLK_BUS_UART4>; + resets = <&ccu RST_BUS_UART4>; + status = "disabled"; + }; + + uart5: serial@1c29400 { + compatible = "snps,dw-apb-uart"; + reg = <0x01c29400 0x400>; + interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&ccu CLK_BUS_UART5>; + resets = <&ccu RST_BUS_UART5>; + status = "disabled"; + }; + + uart6: serial@1c29800 { + compatible = "snps,dw-apb-uart"; + reg = <0x01c29800 0x400>; + interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&ccu CLK_BUS_UART6>; + resets = <&ccu RST_BUS_UART6>; + status = "disabled"; + }; + + uart7: serial@1c29c00 { + compatible = "snps,dw-apb-uart"; + reg = <0x01c29c00 0x400>; + interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&ccu CLK_BUS_UART7>; + resets = <&ccu RST_BUS_UART7>; status = "disabled"; };
@@ -209,7 +476,54 @@ compatible = "allwinner,sun6i-a31-i2c"; reg = <0x01c2ac00 0x400>; interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&osc24M>; + clocks = <&ccu CLK_BUS_I2C0>; + resets = <&ccu RST_BUS_I2C0>; + pinctrl-0 = <&i2c0_pins>; + pinctrl-names = "default"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c1: i2c@1c2b000 { + compatible = "allwinner,sun6i-a31-i2c"; + reg = <0x01c2b000 0x400>; + interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2C1>; + resets = <&ccu RST_BUS_I2C1>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c2: i2c@1c2b400 { + compatible = "allwinner,sun6i-a31-i2c"; + reg = <0x01c2b400 0x400>; + interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2C2>; + resets = <&ccu RST_BUS_I2C2>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c3: i2c@1c2b800 { + compatible = "allwinner,sun6i-a31-i2c"; + reg = <0x01c2b800 0x400>; + interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2C3>; + resets = <&ccu RST_BUS_I2C3>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c4: i2c@1c2c000 { + compatible = "allwinner,sun6i-a31-i2c"; + reg = <0x01c2c000 0x400>; + interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2C4>; + resets = <&ccu RST_BUS_I2C4>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; @@ -236,8 +550,215 @@ }; };
+ tcon_top: tcon-top@1c70000 { + compatible = "allwinner,sun8i-r40-tcon-top"; + reg = <0x01c70000 0x1000>; + clocks = <&ccu CLK_BUS_TCON_TOP>, + <&ccu CLK_TCON_TV0>, + <&ccu CLK_TVE0>, + <&ccu CLK_TCON_TV1>, + <&ccu CLK_TVE1>, + <&ccu CLK_DSI_DPHY>; + clock-names = "bus", + "tcon-tv0", + "tve0", + "tcon-tv1", + "tve1", + "dsi"; + clock-output-names = "tcon-top-tv0", + "tcon-top-tv1", + "tcon-top-dsi"; + resets = <&ccu RST_BUS_TCON_TOP>; + #clock-cells = <1>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + tcon_top_mixer0_in: port@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0>; + + tcon_top_mixer0_in_mixer0: endpoint@0 { + reg = <0>; + remote-endpoint = <&mixer0_out_tcon_top>; + }; + }; + + tcon_top_mixer0_out: port@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + + tcon_top_mixer0_out_tcon_lcd0: endpoint@0 { + reg = <0>; + }; + + tcon_top_mixer0_out_tcon_lcd1: endpoint@1 { + reg = <1>; + }; + + tcon_top_mixer0_out_tcon_tv0: endpoint@2 { + reg = <2>; + remote-endpoint = <&tcon_tv0_in_tcon_top_mixer0>; + }; + + tcon_top_mixer0_out_tcon_tv1: endpoint@3 { + reg = <3>; + remote-endpoint = <&tcon_tv1_in_tcon_top_mixer0>; + }; + }; + + tcon_top_mixer1_in: port@2 { + #address-cells = <1>; + #size-cells = <0>; + reg = <2>; + + tcon_top_mixer1_in_mixer1: endpoint@1 { + reg = <1>; + remote-endpoint = <&mixer1_out_tcon_top>; + }; + }; + + tcon_top_mixer1_out: port@3 { + #address-cells = <1>; + #size-cells = <0>; + reg = <3>; + + tcon_top_mixer1_out_tcon_lcd0: endpoint@0 { + reg = <0>; + }; + + tcon_top_mixer1_out_tcon_lcd1: endpoint@1 { + reg = <1>; + }; + + tcon_top_mixer1_out_tcon_tv0: endpoint@2 { + reg = <2>; + remote-endpoint = <&tcon_tv0_in_tcon_top_mixer1>; + }; + + tcon_top_mixer1_out_tcon_tv1: endpoint@3 { + reg = <3>; + remote-endpoint = <&tcon_tv1_in_tcon_top_mixer1>; + }; + }; + + tcon_top_hdmi_in: port@4 { + #address-cells = <1>; + #size-cells = <0>; + reg = <4>; + + tcon_top_hdmi_in_tcon_tv0: endpoint@0 { + reg = <0>; + remote-endpoint = <&tcon_tv0_out_tcon_top>; + }; + + tcon_top_hdmi_in_tcon_tv1: endpoint@1 { + reg = <1>; + remote-endpoint = <&tcon_tv1_out_tcon_top>; + }; + }; + + tcon_top_hdmi_out: port@5 { + reg = <5>; + + tcon_top_hdmi_out_hdmi: endpoint { + remote-endpoint = <&hdmi_in_tcon_top>; + }; + }; + }; + }; + + tcon_tv0: lcd-controller@1c73000 { + compatible = "allwinner,sun8i-r40-tcon-tv"; + reg = <0x01c73000 0x1000>; + interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_TCON_TV0>, <&tcon_top 0>; + clock-names = "ahb", "tcon-ch1"; + resets = <&ccu RST_BUS_TCON_TV0>; + reset-names = "lcd"; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + tcon_tv0_in: port@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0>; + + tcon_tv0_in_tcon_top_mixer0: endpoint@0 { + reg = <0>; + remote-endpoint = <&tcon_top_mixer0_out_tcon_tv0>; + }; + + tcon_tv0_in_tcon_top_mixer1: endpoint@1 { + reg = <1>; + remote-endpoint = <&tcon_top_mixer1_out_tcon_tv0>; + }; + }; + + tcon_tv0_out: port@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + + tcon_tv0_out_tcon_top: endpoint@1 { + reg = <1>; + remote-endpoint = <&tcon_top_hdmi_in_tcon_tv0>; + }; + }; + }; + }; + + tcon_tv1: lcd-controller@1c74000 { + compatible = "allwinner,sun8i-r40-tcon-tv"; + reg = <0x01c74000 0x1000>; + interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_TCON_TV1>, <&tcon_top 1>; + clock-names = "ahb", "tcon-ch1"; + resets = <&ccu RST_BUS_TCON_TV1>; + reset-names = "lcd"; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + tcon_tv1_in: port@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0>; + + tcon_tv1_in_tcon_top_mixer0: endpoint@0 { + reg = <0>; + remote-endpoint = <&tcon_top_mixer0_out_tcon_tv1>; + }; + + tcon_tv1_in_tcon_top_mixer1: endpoint@1 { + reg = <1>; + remote-endpoint = <&tcon_top_mixer1_out_tcon_tv1>; + }; + }; + + tcon_tv1_out: port@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + + tcon_tv1_out_tcon_top: endpoint@1 { + reg = <1>; + remote-endpoint = <&tcon_top_hdmi_in_tcon_tv1>; + }; + }; + }; + }; + gic: interrupt-controller@1c81000 { - compatible = "arm,cortex-a7-gic", "arm,cortex-a15-gic"; + compatible = "arm,gic-400"; reg = <0x01c81000 0x1000>, <0x01c82000 0x1000>, <0x01c84000 0x2000>, @@ -246,6 +767,51 @@ #interrupt-cells = <3>; interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; }; + + hdmi: hdmi@1ee0000 { + compatible = "allwinner,sun8i-r40-dw-hdmi", + "allwinner,sun8i-a83t-dw-hdmi"; + reg = <0x01ee0000 0x10000>; + reg-io-width = <1>; + interrupts = <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_HDMI0>, <&ccu CLK_HDMI_SLOW>, + <&ccu CLK_HDMI>; + clock-names = "iahb", "isfr", "tmds"; + resets = <&ccu RST_BUS_HDMI1>; + reset-names = "ctrl"; + phys = <&hdmi_phy>; + phy-names = "hdmi-phy"; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + hdmi_in: port@0 { + reg = <0>; + + hdmi_in_tcon_top: endpoint { + remote-endpoint = <&tcon_top_hdmi_out_hdmi>; + }; + }; + + hdmi_out: port@1 { + reg = <1>; + }; + }; + }; + + hdmi_phy: hdmi-phy@1ef0000 { + compatible = "allwinner,sun8i-r40-hdmi-phy", + "allwinner,sun50i-a64-hdmi-phy"; + reg = <0x01ef0000 0x10000>; + clocks = <&ccu CLK_BUS_HDMI1>, <&ccu CLK_HDMI_SLOW>, + <&ccu 7>, <&ccu 16>; + clock-names = "bus", "mod", "pll-0", "pll-1"; + resets = <&ccu RST_BUS_HDMI0>; + reset-names = "phy"; + #phy-cells = <0>; + }; };
timer { @@ -254,7 +820,5 @@ <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; - clock-frequency = <24000000>; - arm,cpu-registers-not-fw-configured; }; }; diff --git a/arch/arm/dts/sun8i-v40-bananapi-m2-berry.dts b/arch/arm/dts/sun8i-v40-bananapi-m2-berry.dts index 193d9b29ec..35859d8f32 100644 --- a/arch/arm/dts/sun8i-v40-bananapi-m2-berry.dts +++ b/arch/arm/dts/sun8i-v40-bananapi-m2-berry.dts @@ -56,6 +56,40 @@ chosen { stdout-path = "serial0:115200n8"; }; + + leds { + compatible = "gpio-leds"; + + pwr-led { + label = "bananapi:red:pwr"; + gpios = <&pio 7 20 GPIO_ACTIVE_HIGH>; + default-state = "on"; + }; + + user-led { + label = "bananapi:green:user"; + gpios = <&pio 7 21 GPIO_ACTIVE_HIGH>; + }; + }; + + reg_vcc5v0: vcc5v0 { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&pio 7 23 GPIO_ACTIVE_HIGH>; /* PH23 */ + enable-active-high; + }; + + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&pio 6 10 GPIO_ACTIVE_LOW>; /* PG10 WIFI_EN */ + }; +}; + +&ehci1 { + /* Terminus Tech FE 1.1s 4-port USB 2.0 hub here */ + status = "okay"; };
&i2c0 { @@ -125,8 +159,24 @@ status = "okay"; };
+&mmc1 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pg_pins>; + vmmc-supply = <®_dldo2>; + vqmmc-supply = <®_dldo1>; + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; +}; + &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_pb_pins>; status = "okay"; }; + +&usbphy { + usb1_vbus-supply = <®_vcc5v0>; + status = "okay"; +};
Enable DM_MMC for Allwinner V40 SoC.
Tested on BPI-M2 Ultra, BPI-M2 Berry.
Cc: Lothar Felten lothar.felten@gmail.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/mach-sunxi/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index d5b0700e13..f3d7c8b67d 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -238,6 +238,7 @@ config MACH_SUN8I_R40 select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI + select DM_MMC if MMC select SUNXI_GEN_SUN6I select SUPPORT_SPL select SUNXI_DRAM_DW
Usually eMMC is default env fat device for environment, if MMC_SUNXI_SLOT_EXTRA != 1 Sunxi always probed emmc device as 1. but with DM_MMC it can be more possible to probe eMMC as device 2 since for most of the sunxi platforms eMMC is configured mmc2.
So update the fastboot mmc default device as 2 if DM_MMC and MMC_SUNXI_SLOT_EXTRA != 1 slot is 2 defined but some boards may not use all possible mmc devices or partly disabled in DT, for those update the device in board specific defconfig.
Cc: Olliver Schinagl oliver@schinagl.nl Cc: Chen-Yu Tsai wens@csie.org Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- configs/A20-OLinuXino-Lime2-eMMC_defconfig | 1 + configs/Sinlinx_SinA33_defconfig | 1 + configs/amarula_a64_relic_defconfig | 1 + drivers/fastboot/Kconfig | 3 ++- 4 files changed, 5 insertions(+), 1 deletion(-)
diff --git a/configs/A20-OLinuXino-Lime2-eMMC_defconfig b/configs/A20-OLinuXino-Lime2-eMMC_defconfig index 5657fc2594..20ea254191 100644 --- a/configs/A20-OLinuXino-Lime2-eMMC_defconfig +++ b/configs/A20-OLinuXino-Lime2-eMMC_defconfig @@ -29,4 +29,5 @@ CONFIG_AXP_ALDO4_VOLT=2800 CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=1 CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Sinlinx_SinA33_defconfig b/configs/Sinlinx_SinA33_defconfig index 394534b8b5..7841219a65 100644 --- a/configs/Sinlinx_SinA33_defconfig +++ b/configs/Sinlinx_SinA33_defconfig @@ -21,5 +21,6 @@ CONFIG_DFU_RAM=y CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=1 CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y CONFIG_USB_FUNCTION_MASS_STORAGE=y diff --git a/configs/amarula_a64_relic_defconfig b/configs/amarula_a64_relic_defconfig index b72cbfabc6..caeb3f6008 100644 --- a/configs/amarula_a64_relic_defconfig +++ b/configs/amarula_a64_relic_defconfig @@ -12,4 +12,5 @@ CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-amarula-relic" # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_MUSB_GADGET=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/drivers/fastboot/Kconfig b/drivers/fastboot/Kconfig index bc25ea1d9c..4a1bfd119c 100644 --- a/drivers/fastboot/Kconfig +++ b/drivers/fastboot/Kconfig @@ -88,7 +88,8 @@ config FASTBOOT_FLASH_MMC_DEV int "Define FASTBOOT MMC FLASH default device" depends on FASTBOOT_FLASH_MMC default 0 if ARCH_SUNXI && MMC_SUNXI_SLOT_EXTRA = -1 - default 1 if ARCH_SUNXI && MMC_SUNXI_SLOT_EXTRA != -1 + default 1 if ARCH_SUNXI && !DM_MMC && MMC_SUNXI_SLOT_EXTRA != -1 + default 2 if ARCH_SUNXI && DM_MMC && MMC_SUNXI_SLOT_EXTRA != -1 help The fastboot "flash" command requires additional information regarding the non-volatile storage device. Define this to
Your commit doesn't make any sense: the SinaA33 and the Lime2 both have the eMMC on MMC2, and you claim you want to update the default to point to MMC2, but you're changing both these boards to point to MMC1 instead?
- default 1 if ARCH_SUNXI && !DM_MMC && MMC_SUNXI_SLOT_EXTRA != -1
- default 2 if ARCH_SUNXI && DM_MMC && MMC_SUNXI_SLOT_EXTRA != -1
It'd be better to be fixed properly, instead of just relying on a broken index.
Maxime
On Mon, Jul 16, 2018 at 3:16 PM, Maxime Ripard maxime.ripard@bootlin.com wrote:
If DM_MMC and SLOT != 1 => default device 2 which is updated by kconfig, this is with all relevant mmc nodes are enabled but these two boards mmc1 is not enabled so emmc will detected in device 1
I don't think we can't do anything with this now, since this INDEX more rely on SPL for pinctrl enablement. if you have any suggestion please share.
Would another answer (at least for this specific case) to change the fastboot code so it doesn't need the device number in advance? Given we get device names along the lines of 'mmcsda1', we could parse out the 'a' to figure out the device number (and then use the alias code so your board can expose a portable name).
That sounds like a pretty good solution. I guess we would have some corner cases when we have a NAND and an MMC card for example that can be flashed using fastboot, but I'm not sure we have boards in that setup at the moment (for Allwinner SoCs at least).
Maxime
On Tue, Jul 17, 2018 at 12:57 PM Maxime Ripard maxime.ripard@bootlin.com wrote:
It's not something I need right now, but having spent so much time refactoring the fastboot code I'd like to get to this! Support for `getvar all` is also on my todo list.
The NAND stuff is a good call, I'm not sure how that fits in (not least not having a board which has a NAND part).
Maybe we can hack something at the partition level though: instead of having the partition name itself, what about prefixing it by the device name? ie having something like mmc1:rootfs and nand0:rootfs, as partition name.
maxime
On Thu, Jul 19, 2018 at 6:56 PM, Maxime Ripard maxime.ripard@bootlin.com wrote:
On Mon, Jul 16, 2018 at 01:49:52PM +0530, Jagan Teki wrote: > Usually eMMC is default env fat device for environment, > if MMC_SUNXI_SLOT_EXTRA != 1 Sunxi always probed emmc > device as 1. but with DM_MMC it can be more possible to > probe eMMC as device 2 since for most of the sunxi platforms > eMMC is configured mmc2. > > So update the fastboot mmc default device as 2 if DM_MMC and > MMC_SUNXI_SLOT_EXTRA != 1 slot is 2 defined but some boards > may not use all possible mmc devices or partly disabled in DT, > for those update the device in board specific defconfig. > > Cc: Olliver Schinagl oliver@schinagl.nl > Cc: Chen-Yu Tsai wens@csie.org > Signed-off-by: Jagan Teki jagan@amarulasolutions.com > --- > configs/A20-OLinuXino-Lime2-eMMC_defconfig | 1 + > configs/Sinlinx_SinA33_defconfig | 1 + > configs/amarula_a64_relic_defconfig | 1 + > drivers/fastboot/Kconfig | 3 ++- > 4 files changed, 5 insertions(+), 1 deletion(-) > > diff --git a/configs/A20-OLinuXino-Lime2-eMMC_defconfig b/configs/A20-OLinuXino-Lime2-eMMC_defconfig > index 5657fc2594..20ea254191 100644 > --- a/configs/A20-OLinuXino-Lime2-eMMC_defconfig > +++ b/configs/A20-OLinuXino-Lime2-eMMC_defconfig > @@ -29,4 +29,5 @@ CONFIG_AXP_ALDO4_VOLT=2800 > CONFIG_SCSI=y > CONFIG_USB_EHCI_HCD=y > CONFIG_USB_MUSB_GADGET=y > +CONFIG_FASTBOOT_FLASH_MMC_DEV=1 > CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y > diff --git a/configs/Sinlinx_SinA33_defconfig b/configs/Sinlinx_SinA33_defconfig > index 394534b8b5..7841219a65 100644 > --- a/configs/Sinlinx_SinA33_defconfig > +++ b/configs/Sinlinx_SinA33_defconfig > @@ -21,5 +21,6 @@ CONFIG_DFU_RAM=y > CONFIG_FASTBOOT_CMD_OEM_FORMAT=y > CONFIG_USB_EHCI_HCD=y > CONFIG_USB_MUSB_GADGET=y > +CONFIG_FASTBOOT_FLASH_MMC_DEV=1
> CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y > CONFIG_USB_FUNCTION_MASS_STORAGE=y > diff --git a/configs/amarula_a64_relic_defconfig b/configs/amarula_a64_relic_defconfig > index b72cbfabc6..caeb3f6008 100644 > --- a/configs/amarula_a64_relic_defconfig > +++ b/configs/amarula_a64_relic_defconfig > @@ -12,4 +12,5 @@ CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-amarula-relic" > # CONFIG_SPL_DOS_PARTITION is not set > # CONFIG_SPL_EFI_PARTITION is not set > CONFIG_USB_MUSB_GADGET=y > +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 > CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y > diff --git a/drivers/fastboot/Kconfig b/drivers/fastboot/Kconfig > index bc25ea1d9c..4a1bfd119c 100644 > --- a/drivers/fastboot/Kconfig > +++ b/drivers/fastboot/Kconfig > @@ -88,7 +88,8 @@ config FASTBOOT_FLASH_MMC_DEV > int "Define FASTBOOT MMC FLASH default device" > depends on FASTBOOT_FLASH_MMC > default 0 if ARCH_SUNXI && MMC_SUNXI_SLOT_EXTRA = -1 > - default 1 if ARCH_SUNXI && MMC_SUNXI_SLOT_EXTRA != -1 > + default 1 if ARCH_SUNXI && !DM_MMC && MMC_SUNXI_SLOT_EXTRA != -1 > + default 2 if ARCH_SUNXI && DM_MMC && MMC_SUNXI_SLOT_EXTRA != -1
How about giving an input during command 'fastboot <controller> [dev_type] <dev[:part]>' it can be fastboot 0 mmc 1 similar like ums did 'ums 0 mmc 1'
On Mon, Jul 16, 2018 at 3:16 PM, Maxime Ripard maxime.ripard@bootlin.com wrote: > On Mon, Jul 16, 2018 at 01:49:52PM +0530, Jagan Teki wrote: >> Usually eMMC is default env fat device for environment, >> if MMC_SUNXI_SLOT_EXTRA != 1 Sunxi always probed emmc >> device as 1. but with DM_MMC it can be more possible to >> probe eMMC as device 2 since for most of the sunxi platforms >> eMMC is configured mmc2. >> >> So update the fastboot mmc default device as 2 if DM_MMC and >> MMC_SUNXI_SLOT_EXTRA != 1 slot is 2 defined but some boards >> may not use all possible mmc devices or partly disabled in DT, >> for those update the device in board specific defconfig. >> >> Cc: Olliver Schinagl oliver@schinagl.nl >> Cc: Chen-Yu Tsai wens@csie.org >> Signed-off-by: Jagan Teki jagan@amarulasolutions.com >> --- >> configs/A20-OLinuXino-Lime2-eMMC_defconfig | 1 + >> configs/Sinlinx_SinA33_defconfig | 1 + >> configs/amarula_a64_relic_defconfig | 1 + >> drivers/fastboot/Kconfig | 3 ++- >> 4 files changed, 5 insertions(+), 1 deletion(-) >> >> diff --git a/configs/A20-OLinuXino-Lime2-eMMC_defconfig b/configs/A20-OLinuXino-Lime2-eMMC_defconfig >> index 5657fc2594..20ea254191 100644 >> --- a/configs/A20-OLinuXino-Lime2-eMMC_defconfig >> +++ b/configs/A20-OLinuXino-Lime2-eMMC_defconfig >> @@ -29,4 +29,5 @@ CONFIG_AXP_ALDO4_VOLT=2800 >> CONFIG_SCSI=y >> CONFIG_USB_EHCI_HCD=y >> CONFIG_USB_MUSB_GADGET=y >> +CONFIG_FASTBOOT_FLASH_MMC_DEV=1 >> CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y >> diff --git a/configs/Sinlinx_SinA33_defconfig b/configs/Sinlinx_SinA33_defconfig >> index 394534b8b5..7841219a65 100644 >> --- a/configs/Sinlinx_SinA33_defconfig >> +++ b/configs/Sinlinx_SinA33_defconfig >> @@ -21,5 +21,6 @@ CONFIG_DFU_RAM=y >> CONFIG_FASTBOOT_CMD_OEM_FORMAT=y >> CONFIG_USB_EHCI_HCD=y >> CONFIG_USB_MUSB_GADGET=y >> +CONFIG_FASTBOOT_FLASH_MMC_DEV=1 > > Your commit doesn't make any sense: the SinaA33 and the Lime2 both > have the eMMC on MMC2, and you claim you want to update the default to > point to MMC2, but you're changing both these boards to point to MMC1 > instead?
> >> CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y >> CONFIG_USB_FUNCTION_MASS_STORAGE=y >> diff --git a/configs/amarula_a64_relic_defconfig b/configs/amarula_a64_relic_defconfig >> index b72cbfabc6..caeb3f6008 100644 >> --- a/configs/amarula_a64_relic_defconfig >> +++ b/configs/amarula_a64_relic_defconfig >> @@ -12,4 +12,5 @@ CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-amarula-relic" >> # CONFIG_SPL_DOS_PARTITION is not set >> # CONFIG_SPL_EFI_PARTITION is not set >> CONFIG_USB_MUSB_GADGET=y >> +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 >> CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y >> diff --git a/drivers/fastboot/Kconfig b/drivers/fastboot/Kconfig >> index bc25ea1d9c..4a1bfd119c 100644 >> --- a/drivers/fastboot/Kconfig >> +++ b/drivers/fastboot/Kconfig >> @@ -88,7 +88,8 @@ config FASTBOOT_FLASH_MMC_DEV >> int "Define FASTBOOT MMC FLASH default device" >> depends on FASTBOOT_FLASH_MMC >> default 0 if ARCH_SUNXI && MMC_SUNXI_SLOT_EXTRA = -1 >> - default 1 if ARCH_SUNXI && MMC_SUNXI_SLOT_EXTRA != -1 >> + default 1 if ARCH_SUNXI && !DM_MMC && MMC_SUNXI_SLOT_EXTRA != -1 >> + default 2 if ARCH_SUNXI && DM_MMC && MMC_SUNXI_SLOT_EXTRA != -1 > > It'd be better to be fixed properly, instead of just relying on a > broken index.
The dev ID doesn't have much sense with the DM either though.
Maxime
On Thu, Jul 19, 2018 at 2:26 PM Maxime Ripard maxime.ripard@bootlin.com wrote:
Just looking at the code, I suspect NAND already works, just use the name that mtd knows. And mmc looks trivial to implement.
I guess one question is if you want to be able to filter out which devices you can address from the fastboot client.
Yeah, that's what I meant. NAND definitely works as long as you stick to partitions defined in mtdparts
So it purely relies on luck and the fact that we don't have a wifi device enabled yet? It seems pretty fragile, doesn't it?
Maxime
So update the env default device as 2 if DM_MMC and MMC_SUNXI_SLOT_EXTRA != 1 but some boards may not use all possible mmc devices or partly disabled in DT, for those update the device in board specific defconfig.
Cc: Olliver Schinagl oliver@schinagl.nl Cc: Hans de Goede hdegoede@redhat.com Cc: Marcus Cooper codekipper@gmail.com Cc: Stefan Mavrodiev stefan@olimex.com Cc: Paul Kocialkowski contact@paulk.fr Cc: Chen-Yu Tsai wens@csie.org Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- configs/A20-OLinuXino-Lime2-eMMC_defconfig | 1 + configs/A20-OLinuXino_MICRO-eMMC_defconfig | 1 + configs/A20-OLinuXino_MICRO_defconfig | 1 + configs/A20-Olimex-SOM-EVB_defconfig | 1 + configs/A20-Olimex-SOM204-EVB-eMMC_defconfig | 1 + configs/Mele_M3_defconfig | 1 + configs/Orangepi_mini_defconfig | 1 + configs/Sinlinx_SinA33_defconfig | 1 + configs/Yones_Toptech_BD1078_defconfig | 1 + configs/amarula_a64_relic_defconfig | 1 + env/Kconfig | 3 ++- 11 files changed, 12 insertions(+), 1 deletion(-)
diff --git a/configs/A20-OLinuXino-Lime2-eMMC_defconfig b/configs/A20-OLinuXino-Lime2-eMMC_defconfig index 20ea254191..98a8ceb178 100644 --- a/configs/A20-OLinuXino-Lime2-eMMC_defconfig +++ b/configs/A20-OLinuXino-Lime2-eMMC_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 CONFIG_MMC0_CD_PIN="PH1" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_ENV_FAT_DEVICE_AND_PART="1:auto" CONFIG_USB0_VBUS_PIN="PC17" CONFIG_USB0_VBUS_DET="PH5" CONFIG_I2C1_ENABLE=y diff --git a/configs/A20-OLinuXino_MICRO-eMMC_defconfig b/configs/A20-OLinuXino_MICRO-eMMC_defconfig index f7e7cbab0a..1552960d88 100644 --- a/configs/A20-OLinuXino_MICRO-eMMC_defconfig +++ b/configs/A20-OLinuXino_MICRO-eMMC_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 CONFIG_MMC0_CD_PIN="PH1" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_ENV_FAT_DEVICE_AND_PART="1:auto" CONFIG_I2C1_ENABLE=y CONFIG_VIDEO_VGA=y CONFIG_SATAPWR="PB8" diff --git a/configs/A20-OLinuXino_MICRO_defconfig b/configs/A20-OLinuXino_MICRO_defconfig index 8dcbdc08f9..b5f1b7efe2 100644 --- a/configs/A20-OLinuXino_MICRO_defconfig +++ b/configs/A20-OLinuXino_MICRO_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=384 CONFIG_MMC0_CD_PIN="PH1" CONFIG_MMC3_CD_PIN="PH11" CONFIG_MMC_SUNXI_SLOT_EXTRA=3 +CONFIG_ENV_FAT_DEVICE_AND_PART="1:auto" CONFIG_I2C1_ENABLE=y CONFIG_VIDEO_VGA=y CONFIG_SATAPWR="PB8" diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index a06499e2d0..58f6fbad91 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -7,6 +7,7 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_MMC3_CD_PIN="PH0" CONFIG_MMC3_PINS="PH" CONFIG_MMC_SUNXI_SLOT_EXTRA=3 +CONFIG_ENV_FAT_DEVICE_AND_PART="1:auto" CONFIG_USB0_VBUS_PIN="PB9" CONFIG_USB0_VBUS_DET="PH5" CONFIG_SATAPWR="PC3" diff --git a/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig b/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig index 3bb8c4c7e6..ac4f841c4e 100644 --- a/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig +++ b/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 CONFIG_MMC0_CD_PIN="PH1" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_ENV_FAT_DEVICE_AND_PART="1:auto" CONFIG_USB0_VBUS_PIN="PC17" CONFIG_USB0_VBUS_DET="PH5" CONFIG_I2C1_ENABLE=y diff --git a/configs/Mele_M3_defconfig b/configs/Mele_M3_defconfig index 9f48bd91e0..93a2395aee 100644 --- a/configs/Mele_M3_defconfig +++ b/configs/Mele_M3_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 CONFIG_MMC0_CD_PIN="PH1" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_ENV_FAT_DEVICE_AND_PART="1:auto" CONFIG_VIDEO_VGA=y CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-m3" diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index 46f27be254..d562273bef 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -7,6 +7,7 @@ CONFIG_MACPWR="PH23" CONFIG_MMC0_CD_PIN="PH10" CONFIG_MMC3_CD_PIN="PH11" CONFIG_MMC_SUNXI_SLOT_EXTRA=3 +CONFIG_ENV_FAT_DEVICE_AND_PART="1:auto" CONFIG_USB1_VBUS_PIN="PH26" CONFIG_USB2_VBUS_PIN="PH22" CONFIG_VIDEO_COMPOSITE=y diff --git a/configs/Sinlinx_SinA33_defconfig b/configs/Sinlinx_SinA33_defconfig index 7841219a65..061f27c9db 100644 --- a/configs/Sinlinx_SinA33_defconfig +++ b/configs/Sinlinx_SinA33_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=552 CONFIG_DRAM_ZQ=15291 CONFIG_MMC0_CD_PIN="PB4" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_ENV_FAT_DEVICE_AND_PART="1:auto" CONFIG_USB0_ID_DET="PH8" CONFIG_VIDEO_LCD_MODE="x:1024,y:600,depth:18,pclk_khz:66000,le:90,ri:160,up:3,lo:127,hs:70,vs:20,sync:3,vmode:0" CONFIG_VIDEO_LCD_DCLK_PHASE=0 diff --git a/configs/Yones_Toptech_BD1078_defconfig b/configs/Yones_Toptech_BD1078_defconfig index c49cbcbc3c..cad5618d54 100644 --- a/configs/Yones_Toptech_BD1078_defconfig +++ b/configs/Yones_Toptech_BD1078_defconfig @@ -7,6 +7,7 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_MMC1_CD_PIN="PH2" CONFIG_MMC1_PINS="PH" CONFIG_MMC_SUNXI_SLOT_EXTRA=1 +CONFIG_ENV_FAT_DEVICE_AND_PART="1:auto" CONFIG_USB0_VBUS_PIN="PB9" CONFIG_USB0_VBUS_DET="AXP0-VBUS-DETECT" CONFIG_AXP_GPIO=y diff --git a/configs/amarula_a64_relic_defconfig b/configs/amarula_a64_relic_defconfig index caeb3f6008..bb5c0ff7b2 100644 --- a/configs/amarula_a64_relic_defconfig +++ b/configs/amarula_a64_relic_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN50I=y CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER=y CONFIG_DRAM_ODT_EN=y CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_ENV_FAT_DEVICE_AND_PART="0:auto" # CONFIG_VIDEO_DE2 is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-amarula-relic" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/env/Kconfig b/env/Kconfig index 8618376f25..2be16893b6 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -374,7 +374,8 @@ config ENV_FAT_DEVICE_AND_PART default "0:1" if TI_COMMON_CMD_OPTIONS default "0:auto" if ARCH_ZYNQMP default "0:auto" if ARCH_SUNXI && MMC_SUNXI_SLOT_EXTRA = -1 - default "1:auto" if ARCH_SUNXI && MMC_SUNXI_SLOT_EXTRA != -1 + default "1:auto" if ARCH_SUNXI && !DM_MMC && MMC_SUNXI_SLOT_EXTRA != -1 + default "2:auto" if ARCH_SUNXI && DM_MMC && MMC_SUNXI_SLOT_EXTRA != -1 default "0" if ARCH_AT91 help Define this to a string to specify the partition of the device. It can
Again, you're breaking all these boards while saying you want to fix them.
Maxime
On Mon, Jul 16, 2018 at 3:17 PM, Maxime Ripard maxime.ripard@bootlin.com wrote:
Let me know what is breaking here, I'm trying to update the env device like before even if the order or detection follow as per DT.
If the number is the one coming from the DT, then with DM_MMC, the ID will change for them as well and they will have the FAT device become 2 if they have an eMMC. Which is why you're changing the default.
However, you're also changing the defconfig so that the number remain the same, so you'll end up with the previous id being used, 1, which is not the eMMC one.
A proper fix would be to simply changing the default.
Maxime
On Tue, Jul 17, 2018 at 5:24 PM, Maxime Ripard maxime.ripard@bootlin.com wrote:
ie what I'm trying here. Say for example A20-OLinuXino-LIME2-eMMC board based on the kconfig with 2 SLOTS and DM_MMC defined the default fat device is 2 but since the sun7i-a20-olinuxino-lime2-emmc.dts has only mmc0 and mmc2 (which is eMMC) due to missing mmc1 the eMMC will probed on device 1 ie what I'm trying to update in defconfig.
No idea how can we support this, how about give device input to saveenv command.
With DM_MMC the mmc devices are probed as per dt status and eMMC can probed maximum device of 2, if all nodes like mmc0, mmc1 and mmc2 status are 'okay'.
So update mmc_bootdev to 2 and add boot order as 2, 1, 0 devices. so-that it can to boot any identified device even if the respective device status disabled or unsupported.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/sunxi/board.c | 2 +- include/configs/sunxi-common.h | 4 +++- 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 5ed1b8bae1..7edc468185 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -768,7 +768,7 @@ int misc_init_r(void) } else if (boot == BOOT_DEVICE_MMC1) { env_set("mmc_bootdev", "0"); } else if (boot == BOOT_DEVICE_MMC2) { - env_set("mmc_bootdev", "1"); + env_set("mmc_bootdev", "2"); }
setup_environment(gd->fdt_blob); diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 21371f4919..abf10f6dcf 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -373,8 +373,10 @@ extern int soft_i2c_gpio_scl; #define BOOTENV_DEV_MMC_AUTO(devtypeu, devtypel, instance) \ BOOTENV_DEV_MMC(MMC, mmc, 0) \ BOOTENV_DEV_MMC(MMC, mmc, 1) \ + BOOTENV_DEV_MMC(MMC, mmc, 2) \ "bootcmd_mmc_auto=" \ - "if test ${mmc_bootdev} -eq 1; then " \ + "if test ${mmc_bootdev} -eq 2; then " \ + "run bootcmd_mmc2; " \ "run bootcmd_mmc1; " \ "run bootcmd_mmc0; " \ "elif test ${mmc_bootdev} -eq 0; then " \
Isn't that broken too? I guess we should return MMC3 in that case.
Also, what about bisectability?
Maxime
On Mon, Jul 16, 2018 at 3:18 PM, Maxime Ripard maxime.ripard@bootlin.com wrote:
Yes, A10 has maximum of mmc3 will fix.
are you referring order check while booting, ie reason I've update the ordering with device 2, 1, 0
No, I'm referring to the fact that each and every commit of your serie should be bootable and fully working without any regression. Selecting DM_MMC and then fixing the IDs in that case breaks that assumption.
Maxime
Enable DM_MMC for Allwinner A13/A31 SoC.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/mach-sunxi/Kconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index f3d7c8b67d..0d277f9e2b 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -155,6 +155,7 @@ config MACH_SUN5I select CPU_V7A select ARM_CORTEX_CPU_IS_UP select DRAM_SUN4I + select DM_MMC if MMC select PHY_SUN4I_USB select SUNXI_GEN_SUN4I select SUPPORT_SPL @@ -167,6 +168,7 @@ config MACH_SUN6I select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI select DRAM_SUN6I + select DM_MMC if MMC select PHY_SUN4I_USB select SUN6I_P2WI select SUN6I_PRCM
Enable DM_MMC for Allwinner A23/A33/V3S SoC.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/mach-sunxi/Kconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 0d277f9e2b..be1ff10212 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -196,6 +196,7 @@ config MACH_SUN8I_A23 select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI select DRAM_SUN8I_A23 + select DM_MMC if MMC select PHY_SUN4I_USB select SUNXI_GEN_SUN6I select SUPPORT_SPL @@ -209,6 +210,7 @@ config MACH_SUN8I_A33 select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI select DRAM_SUN8I_A33 + select DM_MMC if MMC select PHY_SUN4I_USB select SUNXI_GEN_SUN6I select SUPPORT_SPL @@ -252,6 +254,7 @@ config MACH_SUN8I_V3S select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI + select DM_MMC if MMC select SUNXI_GEN_SUN6I select SUNXI_DRAM_DW select SUNXI_DRAM_DW_16BIT
On Mon, Jul 16, 2018 at 4:19 PM, Jagan Teki jagan@amarulasolutions.com wrote:
Enabling DM_MMC is not straight forward for Allwinner SoC's to make proper compatibility in mmc driver vs DT nodes.
Existing dm code for ahb gate clock will be suitable to handle sun4i,5i,6i and 7i U-Boot specific mmc dt nodes, which are different from Linux in terms of clocks phandle notation.
U-Boot DT clocks phandle follow direct ahb and clock address on node definition with specific bit position, but Linux clocks phandle follow macros to define AHB and MMC clocks so-that the ccu driver will set the bits accordingly.
And that has been deprecated upstream.
Clocks phandle notations in U-Boot for higher Allwinner SoC start from sun8i, sun50i are following Linux notation so-that both Linux and U-Boot can have common node definition.
So basically you're saying the additional code for clock/reset handling through the device tree only works for half of the SoCs, based on a deprecated device tree binding. Which means we're going to throw it out some time in the future. Is it worth the churn of driver and device tree changes?
IMHO the new clock handling code is no better than the old. The only thing that has changed is how the clock register address is derived. Not even the index numbers, which BTW are actual bit offsets, for the AHB gates from the device tree are used. Neither is the device tree used for the AHB resets.
If we remove that portion from the series, and also sync up all device tree files to Linux 4.17 (or a later -rc or -next), instead of manually adding device nodes based on the old device tree binding, it probably would still work.
Regards ChenYu
This series will address the ahb gate, clock setup to handle all type of Allwinner SoCs. and sync mmc node definitions from Linux for sun4i and sun5i.
Note:
- sun6i, A23, A33, V3S were untested these need to have a closer look on dt nodes along with default ENV_FAT device.
All these changes available at u-boot-sunxi/next
Let me know if any questions or missings, Jagan.
Jagan Teki (25): ARM: dts: sun4i: Sync A10 MMC nodes from Linux ARM: dts: sun4i: Sync A10 board dts mmc0 node from Linux ARM: dts: sun4i: Add mmc0 node for iNet 3F ARM: dts: sun4i: Add mmc0 node for iNet 3W dm: mmc: sunxi: Refactor ahb gate and clock setup dm: mmc: sunxi: Add ahb reset0 register write ARM: dts: sun7i: Sync A20 MMC nodes from Linux ARM: dts: sun7i: Add mmc0 node for Primo73 tablet ARM: dts: sun7i: Add mmc0 node for Ainol AW1 ARM: dts: sun7i: Add mmc0 node for Mele M5 ARM: dts: sun7i: Add mmc0 node for Toptech BD1078 sunxi: A20: Enable DM_MMC mmc: sunxi: Add mmc, emmc H5/A64 compatible sunxi: H3_H5: Enable DM_MMC sunxi: A64: Enable DM_MMC ARM: dts: sun8i: Update A83T dts(i) files from Linux mmc: sunxi: Add A83T emmc compatible sunxi: A83T: Enable DM_MMC ARM: dts: sun8i: Update R40 dts(i) files from Linux sunxi: V40: Enable DM_MMC fastboot: sunxi: Update fastboot mmc default device env: sunxi: Update default env fat device sunxi: Use mmc_bootdev=2 for MMC2 boot [DO NOT MERGE] sunxi: A13/A31: Enable DM_MMC [DO NOT MERGE] sunxi: A23/A33/V3S: Enable DM_MMC
arch/arm/dts/axp81x.dtsi | 169 ++++ arch/arm/dts/sun4i-a10-a1000.dts | 5 +- arch/arm/dts/sun4i-a10-ba10-tvbox.dts | 5 +- arch/arm/dts/sun4i-a10-chuwi-v7-cw0825.dts | 5 +- arch/arm/dts/sun4i-a10-cubieboard.dts | 5 +- arch/arm/dts/sun4i-a10-dserve-dsrv9703c.dts | 5 +- arch/arm/dts/sun4i-a10-gemei-g9.dts | 5 +- arch/arm/dts/sun4i-a10-hackberry.dts | 5 +- arch/arm/dts/sun4i-a10-hyundai-a7hd.dts | 5 +- arch/arm/dts/sun4i-a10-inet-3f.dts | 9 + arch/arm/dts/sun4i-a10-inet-3w.dts | 9 + arch/arm/dts/sun4i-a10-inet1.dts | 5 +- arch/arm/dts/sun4i-a10-inet97fv2.dts | 5 +- arch/arm/dts/sun4i-a10-inet9f-rev03.dts | 5 +- .../dts/sun4i-a10-itead-iteaduino-plus.dts | 5 +- arch/arm/dts/sun4i-a10-jesurun-q5.dts | 5 +- arch/arm/dts/sun4i-a10-marsboard.dts | 5 +- arch/arm/dts/sun4i-a10-mini-xplus.dts | 5 +- arch/arm/dts/sun4i-a10-mk802.dts | 5 +- arch/arm/dts/sun4i-a10-mk802ii.dts | 5 +- arch/arm/dts/sun4i-a10-olinuxino-lime.dts | 5 +- arch/arm/dts/sun4i-a10-pcduino.dts | 5 +- arch/arm/dts/sun4i-a10-pov-protab2-ips9.dts | 5 +- arch/arm/dts/sun4i-a10.dtsi | 112 +-- arch/arm/dts/sun7i-a20-ainol-aw1.dts | 13 + arch/arm/dts/sun7i-a20-m5.dts | 12 + arch/arm/dts/sun7i-a20-primo73.dts | 20 +- .../dts/sun7i-a20-yones-toptech-bd1078.dts | 13 + arch/arm/dts/sun7i-a20.dtsi | 102 +- .../dts/sun8i-a83t-allwinner-h8homlet-v2.dts | 195 +++- arch/arm/dts/sun8i-a83t-bananapi-m3.dts | 298 +++++- arch/arm/dts/sun8i-a83t-cubietruck-plus.dts | 322 ++++++- arch/arm/dts/sun8i-a83t-tbs-a711.dts | 355 ++++++- arch/arm/dts/sun8i-a83t.dtsi | 885 ++++++++++++++++-- arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts | 197 +++- arch/arm/dts/sun8i-r40.dtsi | 616 +++++++++++- arch/arm/dts/sun8i-v40-bananapi-m2-berry.dts | 50 + arch/arm/mach-sunxi/Kconfig | 10 + board/sunxi/board.c | 2 +- configs/A20-OLinuXino-Lime2-eMMC_defconfig | 2 + configs/A20-OLinuXino_MICRO-eMMC_defconfig | 1 + configs/A20-OLinuXino_MICRO_defconfig | 1 + configs/A20-Olimex-SOM-EVB_defconfig | 1 + configs/A20-Olimex-SOM204-EVB-eMMC_defconfig | 1 + configs/Mele_M3_defconfig | 1 + configs/Orangepi_mini_defconfig | 1 + configs/Sinlinx_SinA33_defconfig | 2 + configs/Yones_Toptech_BD1078_defconfig | 1 + configs/amarula_a64_relic_defconfig | 2 + drivers/fastboot/Kconfig | 3 +- drivers/mmc/sunxi_mmc.c | 81 +- env/Kconfig | 3 +- include/configs/sunxi-common.h | 4 +- include/dt-bindings/clock/sun4i-a10-ccu.h | 202 ++++ include/dt-bindings/clock/sun7i-a20-ccu.h | 53 ++ include/dt-bindings/clock/sun8i-a83t-ccu.h | 140 +++ include/dt-bindings/reset/sun8i-a83t-ccu.h | 98 ++ 57 files changed, 3715 insertions(+), 371 deletions(-) create mode 100644 arch/arm/dts/axp81x.dtsi create mode 100644 include/dt-bindings/clock/sun4i-a10-ccu.h create mode 100644 include/dt-bindings/clock/sun7i-a20-ccu.h create mode 100644 include/dt-bindings/clock/sun8i-a83t-ccu.h create mode 100644 include/dt-bindings/reset/sun8i-a83t-ccu.h
-- 2.17.1
I'd say that it's even worse. We want an actual, common, clock driver. Not a quick hack that doesn't solve any of the issues we're facing.
Maxime
So is the purpose of this whole series to just comply with the deprecation of non-DM_MMC configurations? As mentioned before I am wondering how useful this is, and if we could ever get rid of those hardcoded hacks for the SPL anyway (so the driver would technically be DM_MMC compliant, but still had non-DM_MMC code in). So I would suggest we push the clock DM driver forward first [1], implementing the new CCU binding, then possibly convert over the pre-H3 boards. And meanwhile we try to appease the maintainers to not remove any boards which don't support DM_MMC, because the purpose of U-Boot should be to get boards booting and not to have some fancy driver model just for the sake of it.
Cheers, Andre.
On Mon, Jul 16, 2018 at 4:38 PM, Andre Przywara andre.przywara@arm.com wrote:
The migration idea about DM_MMC would be for U-Boot proper[2] (not for SPL as of now). Even if we put the migration aside, we have a problem with SPL size for DM_MMC for arm64 SoCs. indeed we need to wait for this to fix for having full DM_MMC code.
participants (6)
Alex Kiernan
Andre Przywara
Chen-Yu Tsai
Jagan Teki
Jagan Teki
Maxime Ripard
