[U-Boot-Users] U-BOOT for MPC885 Eval board - i2c problem
We are using MPC885ADS Eval. board ,we are porting U-Boot 1.1.1 on it and working fine,
we have following query :
We are connected an EEPROM (CHIP ADDRESS : 0X50) on I2C bus, when we trying to check with "iprobe" command its displaying a message like :
Valid chip addresses: 00 01 02 03 04 05 06 07 ............ 80
Its talking a lots of time and not working.
Has anyone faced same problem?
thanks and regards, Sachin mehta
I understand that you rae using the CPM implementation of the driver?
You are aware of the differences between MPC885 and other (older) processors of the MPC8xx family (like MPC860), aren't you? Did you modify the I2C driver accordingly (especially the handling of the iic_rpbase filed in the parameter RAM) ?
Is it really displaying exactly such a row of dots ?
It's normal that the ip[robe command takes very long with the CPM implementation; is there any good reason for not using soft-I2C?
Did you search the mailing list archive?
Sachin S Mehta
