[U-Boot] [PATCH v3 1/2] mx6sabresd: Make SPL DDR configuration to match the DCD table
When using SPL on i.mx6 we frequently notice some DDR initialization mismatches between the SPL code and the non-SPL code.
This causes stability issues like the ones reported at 7dbda25ecd6d7c ("mx6ul_14x14_evk: Pass refsel and refr fields to avoid hang") and also: http://lists.denx.de/pipermail/u-boot/2016-September/266355.html .
As the non-SPL code have been tested for long time and proves to be reliable, let's configure the DDR in the exact same way as the non-SPL case.
The idea is simple: just use the DCD table and write directly to the DDR registers.
Retrieved the DCD tables from: board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg and board/freescale/mx6sabresd/mx6qp.cfg (NXP U-Boot branch imx_v2015.04_4.1.15_1.0.0_ga)
This method makes it easier for people converting from non-SPL to SPL code.
Other benefit is that the SPL binary size is reduced from 44 kB to 39.9 kB.
Signed-off-by: Fabio Estevam fabio.estevam@nxp.com --- Changes since v1: - Use the correct mx6qp dcd table - Create ddr_init() to write the DCD values - Specify where the DCD tables come from
board/freescale/mx6sabresd/mx6sabresd.c | 351 ++++++++++++++++++-------------- 1 file changed, 197 insertions(+), 154 deletions(-)
diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index f836ecb..3c36395 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -682,125 +682,6 @@ int checkboard(void) #include <spl.h> #include <libfdt.h>
-const struct mx6dq_iomux_ddr_regs mx6_ddr_ioregs = { - .dram_sdclk_0 = 0x00020030, - .dram_sdclk_1 = 0x00020030, - .dram_cas = 0x00020030, - .dram_ras = 0x00020030, - .dram_reset = 0x00020030, - .dram_sdcke0 = 0x00003000, - .dram_sdcke1 = 0x00003000, - .dram_sdba2 = 0x00000000, - .dram_sdodt0 = 0x00003030, - .dram_sdodt1 = 0x00003030, - .dram_sdqs0 = 0x00000030, - .dram_sdqs1 = 0x00000030, - .dram_sdqs2 = 0x00000030, - .dram_sdqs3 = 0x00000030, - .dram_sdqs4 = 0x00000030, - .dram_sdqs5 = 0x00000030, - .dram_sdqs6 = 0x00000030, - .dram_sdqs7 = 0x00000030, - .dram_dqm0 = 0x00020030, - .dram_dqm1 = 0x00020030, - .dram_dqm2 = 0x00020030, - .dram_dqm3 = 0x00020030, - .dram_dqm4 = 0x00020030, - .dram_dqm5 = 0x00020030, - .dram_dqm6 = 0x00020030, - .dram_dqm7 = 0x00020030, -}; - -const struct mx6dq_iomux_ddr_regs mx6dqp_ddr_ioregs = { - .dram_sdclk_0 = 0x00000030, - .dram_sdclk_1 = 0x00000030, - .dram_cas = 0x00000030, - .dram_ras = 0x00000030, - .dram_reset = 0x00000030, - .dram_sdcke0 = 0x00003000, - .dram_sdcke1 = 0x00003000, - .dram_sdba2 = 0x00000000, - .dram_sdodt0 = 0x00003030, - .dram_sdodt1 = 0x00003030, - .dram_sdqs0 = 0x00000030, - .dram_sdqs1 = 0x00000030, - .dram_sdqs2 = 0x00000030, - .dram_sdqs3 = 0x00000030, - .dram_sdqs4 = 0x00000030, - .dram_sdqs5 = 0x00000030, - .dram_sdqs6 = 0x00000030, - .dram_sdqs7 = 0x00000030, - .dram_dqm0 = 0x00000030, - .dram_dqm1 = 0x00000030, - .dram_dqm2 = 0x00000030, - .dram_dqm3 = 0x00000030, - .dram_dqm4 = 0x00000030, - .dram_dqm5 = 0x00000030, - .dram_dqm6 = 0x00000030, - .dram_dqm7 = 0x00000030, -}; - -const struct mx6dq_iomux_grp_regs mx6_grp_ioregs = { - .grp_ddr_type = 0x000C0000, - .grp_ddrmode_ctl = 0x00020000, - .grp_ddrpke = 0x00000000, - .grp_addds = 0x00000030, - .grp_ctlds = 0x00000030, - .grp_ddrmode = 0x00020000, - .grp_b0ds = 0x00000030, - .grp_b1ds = 0x00000030, - .grp_b2ds = 0x00000030, - .grp_b3ds = 0x00000030, - .grp_b4ds = 0x00000030, - .grp_b5ds = 0x00000030, - .grp_b6ds = 0x00000030, - .grp_b7ds = 0x00000030, -}; - -const struct mx6_mmdc_calibration mx6_mmcd_calib = { - .p0_mpwldectrl0 = 0x001F001F, - .p0_mpwldectrl1 = 0x001F001F, - .p1_mpwldectrl0 = 0x00440044, - .p1_mpwldectrl1 = 0x00440044, - .p0_mpdgctrl0 = 0x434B0350, - .p0_mpdgctrl1 = 0x034C0359, - .p1_mpdgctrl0 = 0x434B0350, - .p1_mpdgctrl1 = 0x03650348, - .p0_mprddlctl = 0x4436383B, - .p1_mprddlctl = 0x39393341, - .p0_mpwrdlctl = 0x35373933, - .p1_mpwrdlctl = 0x48254A36, -}; - -const struct mx6_mmdc_calibration mx6dqp_mmcd_calib = { - .p0_mpwldectrl0 = 0x001B001E, - .p0_mpwldectrl1 = 0x002E0029, - .p1_mpwldectrl0 = 0x001B002A, - .p1_mpwldectrl1 = 0x0019002C, - .p0_mpdgctrl0 = 0x43240334, - .p0_mpdgctrl1 = 0x0324031A, - .p1_mpdgctrl0 = 0x43340344, - .p1_mpdgctrl1 = 0x03280276, - .p0_mprddlctl = 0x44383A3E, - .p1_mprddlctl = 0x3C3C3846, - .p0_mpwrdlctl = 0x2E303230, - .p1_mpwrdlctl = 0x38283E34, -}; - -/* MT41K128M16JT-125 */ -static struct mx6_ddr3_cfg mem_ddr = { - .mem_speed = 1600, - .density = 2, - .width = 16, - .banks = 8, - .rowaddr = 14, - .coladdr = 10, - .pagesz = 2, - .trcd = 1375, - .trcmin = 4875, - .trasmin = 3500, -}; - static void ccgr_init(void) { struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; @@ -831,44 +712,209 @@ static void gpr_init(void) } }
-/* - * This section requires the differentiation between iMX6 Sabre boards, but - * for now, it will configure only for the mx6q variant. - */ -static void spl_dram_init(void) +static int mx6q_dcd_table[] = { + 0x020e0798, 0x000C0000, + 0x020e0758, 0x00000000, + 0x020e0588, 0x00000030, + 0x020e0594, 0x00000030, + 0x020e056c, 0x00000030, + 0x020e0578, 0x00000030, + 0x020e074c, 0x00000030, + 0x020e057c, 0x00000030, + 0x020e058c, 0x00000000, + 0x020e059c, 0x00000030, + 0x020e05a0, 0x00000030, + 0x020e078c, 0x00000030, + 0x020e0750, 0x00020000, + 0x020e05a8, 0x00000030, + 0x020e05b0, 0x00000030, + 0x020e0524, 0x00000030, + 0x020e051c, 0x00000030, + 0x020e0518, 0x00000030, + 0x020e050c, 0x00000030, + 0x020e05b8, 0x00000030, + 0x020e05c0, 0x00000030, + 0x020e0774, 0x00020000, + 0x020e0784, 0x00000030, + 0x020e0788, 0x00000030, + 0x020e0794, 0x00000030, + 0x020e079c, 0x00000030, + 0x020e07a0, 0x00000030, + 0x020e07a4, 0x00000030, + 0x020e07a8, 0x00000030, + 0x020e0748, 0x00000030, + 0x020e05ac, 0x00000030, + 0x020e05b4, 0x00000030, + 0x020e0528, 0x00000030, + 0x020e0520, 0x00000030, + 0x020e0514, 0x00000030, + 0x020e0510, 0x00000030, + 0x020e05bc, 0x00000030, + 0x020e05c4, 0x00000030, + 0x021b0800, 0xa1390003, + 0x021b080c, 0x001F001F, + 0x021b0810, 0x001F001F, + 0x021b480c, 0x001F001F, + 0x021b4810, 0x001F001F, + 0x021b083c, 0x43270338, + 0x021b0840, 0x03200314, + 0x021b483c, 0x431A032F, + 0x021b4840, 0x03200263, + 0x021b0848, 0x4B434748, + 0x021b4848, 0x4445404C, + 0x021b0850, 0x38444542, + 0x021b4850, 0x4935493A, + 0x021b081c, 0x33333333, + 0x021b0820, 0x33333333, + 0x021b0824, 0x33333333, + 0x021b0828, 0x33333333, + 0x021b481c, 0x33333333, + 0x021b4820, 0x33333333, + 0x021b4824, 0x33333333, + 0x021b4828, 0x33333333, + 0x021b08b8, 0x00000800, + 0x021b48b8, 0x00000800, + 0x021b0004, 0x00020036, + 0x021b0008, 0x09444040, + 0x021b000c, 0x555A7975, + 0x021b0010, 0xFF538F64, + 0x021b0014, 0x01FF00DB, + 0x021b0018, 0x00001740, + 0x021b001c, 0x00008000, + 0x021b002c, 0x000026d2, + 0x021b0030, 0x005A1023, + 0x021b0040, 0x00000027, + 0x021b0000, 0x831A0000, + 0x021b001c, 0x04088032, + 0x021b001c, 0x00008033, + 0x021b001c, 0x00048031, + 0x021b001c, 0x09408030, + 0x021b001c, 0x04008040, + 0x021b0020, 0x00005800, + 0x021b0818, 0x00011117, + 0x021b4818, 0x00011117, + 0x021b0004, 0x00025576, + 0x021b0404, 0x00011006, + 0x021b001c, 0x00000000, +}; + +static int mx6qp_dcd_table[] = { + 0x020e0798, 0x000c0000, + 0x020e0758, 0x00000000, + 0x020e0588, 0x00000030, + 0x020e0594, 0x00000030, + 0x020e056c, 0x00000030, + 0x020e0578, 0x00000030, + 0x020e074c, 0x00000030, + 0x020e057c, 0x00000030, + 0x020e058c, 0x00000000, + 0x020e059c, 0x00000030, + 0x020e05a0, 0x00000030, + 0x020e078c, 0x00000030, + 0x020e0750, 0x00020000, + 0x020e05a8, 0x00000030, + 0x020e05b0, 0x00000030, + 0x020e0524, 0x00000030, + 0x020e051c, 0x00000030, + 0x020e0518, 0x00000030, + 0x020e050c, 0x00000030, + 0x020e05b8, 0x00000030, + 0x020e05c0, 0x00000030, + 0x020e0774, 0x00020000, + 0x020e0784, 0x00000030, + 0x020e0788, 0x00000030, + 0x020e0794, 0x00000030, + 0x020e079c, 0x00000030, + 0x020e07a0, 0x00000030, + 0x020e07a4, 0x00000030, + 0x020e07a8, 0x00000030, + 0x020e0748, 0x00000030, + 0x020e05ac, 0x00000030, + 0x020e05b4, 0x00000030, + 0x020e0528, 0x00000030, + 0x020e0520, 0x00000030, + 0x020e0514, 0x00000030, + 0x020e0510, 0x00000030, + 0x020e05bc, 0x00000030, + 0x020e05c4, 0x00000030, + 0x021b0800, 0xa1390003, + 0x021b080c, 0x001b001e, + 0x021b0810, 0x002e0029, + 0x021b480c, 0x001b002a, + 0x021b4810, 0x0019002c, + 0x021b083c, 0x43240334, + 0x021b0840, 0x0324031a, + 0x021b483c, 0x43340344, + 0x021b4840, 0x03280276, + 0x021b0848, 0x44383A3E, + 0x021b4848, 0x3C3C3846, + 0x021b0850, 0x2e303230, + 0x021b4850, 0x38283E34, + 0x021b081c, 0x33333333, + 0x021b0820, 0x33333333, + 0x021b0824, 0x33333333, + 0x021b0828, 0x33333333, + 0x021b481c, 0x33333333, + 0x021b4820, 0x33333333, + 0x021b4824, 0x33333333, + 0x021b4828, 0x33333333, + 0x021b08c0, 0x24912249, + 0x021b48c0, 0x24914289, + 0x021b08b8, 0x00000800, + 0x021b48b8, 0x00000800, + 0x021b0004, 0x00020036, + 0x021b0008, 0x24444040, + 0x021b000c, 0x555A7955, + 0x021b0010, 0xFF320F64, + 0x021b0014, 0x01ff00db, + 0x021b0018, 0x00001740, + 0x021b001c, 0x00008000, + 0x021b002c, 0x000026d2, + 0x021b0030, 0x005A1023, + 0x021b0040, 0x00000027, + 0x021b0400, 0x14420000, + 0x021b0000, 0x831A0000, + 0x021b0890, 0x00400C58, + 0x00bb0008, 0x00000000, + 0x00bb000c, 0x2891E41A, + 0x00bb0038, 0x00000564, + 0x00bb0014, 0x00000040, + 0x00bb0028, 0x00000020, + 0x00bb002c, 0x00000020, + 0x021b001c, 0x04088032, + 0x021b001c, 0x00008033, + 0x021b001c, 0x00048031, + 0x021b001c, 0x09408030, + 0x021b001c, 0x04008040, + 0x021b0020, 0x00005800, + 0x021b0818, 0x00011117, + 0x021b4818, 0x00011117, + 0x021b0004, 0x00025576, + 0x021b0404, 0x00011006, + 0x021b001c, 0x00000000, +}; + +static void ddr_init(int *table, int size) { - struct mx6_ddr_sysinfo sysinfo = { - /* width of data bus:0=16,1=32,2=64 */ - .dsize = 2, - /* config for full 4GB range so that get_mem_size() works */ - .cs_density = 32, /* 32Gb per CS */ - /* single chip select */ - .ncs = 1, - .cs1_mirror = 0, - .rtt_wr = 1 /*DDR3_RTT_60_OHM*/, /* RTT_Wr = RZQ/4 */ - .rtt_nom = 1 /*DDR3_RTT_60_OHM*/, /* RTT_Nom = RZQ/4 */ - .walat = 1, /* Write additional latency */ - .ralat = 5, /* Read additional latency */ - .mif3_mode = 3, /* Command prediction working mode */ - .bi_on = 1, /* Bank interleaving enabled */ - .sde_to_rst = 0x10, /* 14 cycles, 200us (JEDEC default) */ - .rst_to_cke = 0x23, /* 33 cycles, 500us (JEDEC default) */ - .ddr_type = DDR_TYPE_DDR3, - .refsel = 1, /* Refresh cycles at 32KHz */ - .refr = 7, /* 8 refresh commands per refresh cycle */ - }; + int i;
- if (is_mx6dqp()) { - mx6dq_dram_iocfg(64, &mx6dqp_ddr_ioregs, &mx6_grp_ioregs); - mx6_dram_cfg(&sysinfo, &mx6dqp_mmcd_calib, &mem_ddr); - } else { - mx6dq_dram_iocfg(64, &mx6_ddr_ioregs, &mx6_grp_ioregs); - mx6_dram_cfg(&sysinfo, &mx6_mmcd_calib, &mem_ddr); - } + for (i = 0; i < size / 2 ; i++) + writel(table[2 * i + 1], table[2 * i]); +} + +static void spl_dram_init(void) +{ + if (is_mx6dq()) + ddr_init(mx6q_dcd_table, ARRAY_SIZE(mx6q_dcd_table)); + else if (is_mx6dqp()) + ddr_init(mx6qp_dcd_table, ARRAY_SIZE(mx6qp_dcd_table)); }
void board_init_f(ulong dummy) { + /* DDR initialization */ + spl_dram_init(); + /* setup AIPS and disable watchdog */ arch_cpu_init();
@@ -884,9 +930,6 @@ void board_init_f(ulong dummy) /* UART clocks enabled and gd valid - init serial console */ preloader_console_init();
- /* DDR initialization */ - spl_dram_init(); - /* Clear the BSS. */ memset(__bss_start, 0, __bss_end - __bss_start);
Add support for the mx6dlsabresd board in SPL.
Retrieved the DCD table from: board/freescale/mx6sabresd/mx6dlsabresd.cfg (NXP U-Boot branch imx_v2015.04_4.1.15_1.0.0_ga)
Signed-off-by: Fabio Estevam fabio.estevam@nxp.com --- Changes since v2: - Newly introduced in this series
board/freescale/mx6sabresd/mx6sabresd.c | 88 +++++++++++++++++++++++++++++++++ 1 file changed, 88 insertions(+)
diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index 3c36395..986a82b 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -894,6 +894,92 @@ static int mx6qp_dcd_table[] = { 0x021b001c, 0x00000000, };
+static int mx6dl_dcd_table[] = { + 0x020e0774, 0x000C0000, + 0x020e0754, 0x00000000, + 0x020e04ac, 0x00000030, + 0x020e04b0, 0x00000030, + 0x020e0464, 0x00000030, + 0x020e0490, 0x00000030, + 0x020e074c, 0x00000030, + 0x020e0494, 0x00000030, + 0x020e04a0, 0x00000000, + 0x020e04b4, 0x00000030, + 0x020e04b8, 0x00000030, + 0x020e076c, 0x00000030, + 0x020e0750, 0x00020000, + 0x020e04bc, 0x00000030, + 0x020e04c0, 0x00000030, + 0x020e04c4, 0x00000030, + 0x020e04c8, 0x00000030, + 0x020e04cc, 0x00000030, + 0x020e04d0, 0x00000030, + 0x020e04d4, 0x00000030, + 0x020e04d8, 0x00000030, + 0x020e0760, 0x00020000, + 0x020e0764, 0x00000030, + 0x020e0770, 0x00000030, + 0x020e0778, 0x00000030, + 0x020e077c, 0x00000030, + 0x020e0780, 0x00000030, + 0x020e0784, 0x00000030, + 0x020e078c, 0x00000030, + 0x020e0748, 0x00000030, + 0x020e0470, 0x00000030, + 0x020e0474, 0x00000030, + 0x020e0478, 0x00000030, + 0x020e047c, 0x00000030, + 0x020e0480, 0x00000030, + 0x020e0484, 0x00000030, + 0x020e0488, 0x00000030, + 0x020e048c, 0x00000030, + 0x021b0800, 0xa1390003, + 0x021b080c, 0x001F001F, + 0x021b0810, 0x001F001F, + 0x021b480c, 0x001F001F, + 0x021b4810, 0x001F001F, + 0x021b083c, 0x4220021F, + 0x021b0840, 0x0207017E, + 0x021b483c, 0x4201020C, + 0x021b4840, 0x01660172, + 0x021b0848, 0x4A4D4E4D, + 0x021b4848, 0x4A4F5049, + 0x021b0850, 0x3F3C3D31, + 0x021b4850, 0x3238372B, + 0x021b081c, 0x33333333, + 0x021b0820, 0x33333333, + 0x021b0824, 0x33333333, + 0x021b0828, 0x33333333, + 0x021b481c, 0x33333333, + 0x021b4820, 0x33333333, + 0x021b4824, 0x33333333, + 0x021b4828, 0x33333333, + 0x021b08b8, 0x00000800, + 0x021b48b8, 0x00000800, + 0x021b0004, 0x0002002D, + 0x021b0008, 0x00333030, + 0x021b000c, 0x3F435313, + 0x021b0010, 0xB66E8B63, + 0x021b0014, 0x01FF00DB, + 0x021b0018, 0x00001740, + 0x021b001c, 0x00008000, + 0x021b002c, 0x000026d2, + 0x021b0030, 0x00431023, + 0x021b0040, 0x00000027, + 0x021b0000, 0x831A0000, + 0x021b001c, 0x04008032, + 0x021b001c, 0x00008033, + 0x021b001c, 0x00048031, + 0x021b001c, 0x05208030, + 0x021b001c, 0x04008040, + 0x021b0020, 0x00005800, + 0x021b0818, 0x00011117, + 0x021b4818, 0x00011117, + 0x021b0004, 0x0002556D, + 0x021b0404, 0x00011006, + 0x021b001c, 0x00000000, + +}; static void ddr_init(int *table, int size) { int i; @@ -908,6 +994,8 @@ static void spl_dram_init(void) ddr_init(mx6q_dcd_table, ARRAY_SIZE(mx6q_dcd_table)); else if (is_mx6dqp()) ddr_init(mx6qp_dcd_table, ARRAY_SIZE(mx6qp_dcd_table)); + else if (is_mx6sdl()) + ddr_init(mx6dl_dcd_table, ARRAY_SIZE(mx6dl_dcd_table)); }
Hi Stefano,
Patch 1/2 works fine, but I saw an issue with this one and will rework it. Please do not apply 2/2.
Thanks
Hi Fabio,
On 28/09/2016 20:56, Fabio Estevam wrote:
Hi Stefano,
Ok - I merged 1/2, and drop 2/2.
Regards, Stefano
Hi Fabio,
Changes since v1:
.mem_speed = 1600,
.density = 2,
.width = 16,
.banks = 8,
.rowaddr = 14,
.coladdr = 10,
.pagesz = 2,
.trcd = 1375,
.trcmin = 4875,
.trasmin = 3500,
- This section requires the differentiation between iMX6 Sabre boards, but
- for now, it will configure only for the mx6q variant.
I believe, this is a random reg-pick from mx6q_4x_mt41j128.cfg. Do we need to follow any specific order to assign these dcd reg-init?
thanks!
Any help?
On Wed, Mar 29, 2017 at 8:45 PM, Jagan Teki jagannadh.teki@gmail.com wrote:
Hi Fabio,
Changes since v1:
.mem_speed = 1600,
.density = 2,
.width = 16,
.banks = 8,
.rowaddr = 14,
.coladdr = 10,
.pagesz = 2,
.trcd = 1375,
.trcmin = 4875,
.trasmin = 3500,
thanks!
Jagan Teki Free Software Engineer | www.openedev.com U-Boot, Linux | Upstream Maintainer Hyderabad, India.
On Tue, Apr 4, 2017 at 12:47 PM, Jagan Teki jagannadh.teki@gmail.com wrote:
Any help?
Sorry, didn't have time to look at this issue.
At least SPL U-Boot boots fine in this board. Can you also try U-Boot from NXP and try to debug it?
Any help?
No, this isn't issue, just want to understand how you create reg init in SPL in mx6q_dcd_table, means did you follow any order. because I'm planning move *dl.cfg DCD to SPL
thanks!
Hi Jagan,
Ok, got it. I thought you were asking about mx6qp sabreauto not booting.
On this patch I just did a 1:1 translation from DCD to SPL code.
On Wed, Apr 5, 2017 at 5:29 AM, Fabio Estevam festevam@gmail.com wrote:
Hi Jagan,
I saw the reg with respective values same from *.cfg but the sequence of registers are not direct compared to DCD from *.cfg? am I correct?
thanks!
Fabio Estevam
Jagan Teki
Stefano Babic
