[U-Boot] [PATCH 0/8] ZYNQ CLK update + driver changes
this series provide patches for adding clock support for Zynq. I am sending them separately because there are several changes together. 1. Adding DIV_ROUND_CLOSEST macro 2. ARM zynq changes 3. driver changes
This series is based on 7 zynq patches I have sent today.
Thanks, Michal
Michal Simek (2): zynq: Update CLK in bdinfo zynq: timer: Fix hangs if network activity attempted after about one hour
Soren Brinkmann (6): common: Provide DIV_ROUND_CLOSEST macro zynq: Provide a framework to read clock frequencies zynq: timer: Migrate to zynq clock framework net: zynq_gem: Move RCLK details out of driver net: zynq_gem: Calculate clock dividers dynamically serial_zynq: Migrate to Zynq clock framework
arch/arm/cpu/armv7/zynq/Makefile | 1 + arch/arm/cpu/armv7/zynq/clk.c | 643 +++++++++++++++++++++++++++++ arch/arm/cpu/armv7/zynq/cpu.c | 2 + arch/arm/cpu/armv7/zynq/slcr.c | 17 +- arch/arm/cpu/armv7/zynq/timer.c | 13 +- arch/arm/include/asm/arch-zynq/clk.h | 29 ++ arch/arm/include/asm/arch-zynq/hardware.h | 32 +- arch/arm/include/asm/arch-zynq/sys_proto.h | 2 +- drivers/net/zynq_gem.c | 20 +- drivers/serial/serial_zynq.c | 13 +- include/common.h | 16 + include/configs/zynq-common.h | 1 + 12 files changed, 754 insertions(+), 35 deletions(-) create mode 100644 arch/arm/cpu/armv7/zynq/clk.c create mode 100644 arch/arm/include/asm/arch-zynq/clk.h
-- 1.8.2.3
Provide the DIV_ROUND_CLOSEST macro - taken from the Linux kernel - in common.h
Signed-off-by: Soren Brinkmann soren.brinkmann@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
include/common.h | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/include/common.h b/include/common.h index d49c514..ae45836 100644 --- a/include/common.h +++ b/include/common.h @@ -964,6 +964,22 @@ static inline phys_addr_t map_to_sysmem(const void *ptr) #define DIV_ROUND_UP(n,d) (((n) + (d) - 1) / (d)) #define roundup(x, y) ((((x) + ((y) - 1)) / (y)) * (y))
+/* + * Divide positive or negative dividend by positive divisor and round + * to closest integer. Result is undefined for negative divisors and + * for negative dividends if the divisor variable type is unsigned. + */ +#define DIV_ROUND_CLOSEST(x, divisor)( \ +{ \ + typeof(x) __x = x; \ + typeof(divisor) __d = divisor; \ + (((typeof(x))-1) > 0 || \ + ((typeof(divisor))-1) > 0 || (__x) > 0) ? \ + (((__x) + ((__d) / 2)) / (__d)) : \ + (((__x) - ((__d) / 2)) / (__d)); \ +} \ +) + #define ALIGN(x,a) __ALIGN_MASK((x),(typeof(x))(a)-1) #define __ALIGN_MASK(x,mask) (((x)+(mask))&~(mask))
-- 1.8.2.3
arch/arm/cpu/armv7/zynq/Makefile | 1 + arch/arm/cpu/armv7/zynq/clk.c | 638 ++++++++++++++++++++++++++++++ arch/arm/cpu/armv7/zynq/cpu.c | 2 + arch/arm/include/asm/arch-zynq/clk.h | 29 ++ arch/arm/include/asm/arch-zynq/hardware.h | 32 +- include/configs/zynq-common.h | 1 + 6 files changed, 701 insertions(+), 2 deletions(-) create mode 100644 arch/arm/cpu/armv7/zynq/clk.c create mode 100644 arch/arm/include/asm/arch-zynq/clk.h
diff --git a/arch/arm/cpu/armv7/zynq/Makefile b/arch/arm/cpu/armv7/zynq/Makefile index d382d49..3374789 100644 --- a/arch/arm/cpu/armv7/zynq/Makefile +++ b/arch/arm/cpu/armv7/zynq/Makefile @@ -12,3 +12,4 @@ obj-y := timer.o obj-y += cpu.o obj-y += ddrc.o obj-y += slcr.o +obj-y += clk.o diff --git a/arch/arm/cpu/armv7/zynq/clk.c b/arch/arm/cpu/armv7/zynq/clk.c new file mode 100644 index 0000000..0891a23 --- /dev/null +++ b/arch/arm/cpu/armv7/zynq/clk.c @@ -0,0 +1,638 @@ +/* + * Copyright (C) 2013 Soren Brinkmann soren.brinkmann@xilinx.com + * Copyright (C) 2013 Xilinx, Inc. All rights reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <errno.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> +#include <asm/arch/clk.h> + +/* Board oscillator frequency */ +#ifndef CONFIG_ZYNQ_PS_CLK_FREQ +# define CONFIG_ZYNQ_PS_CLK_FREQ 33333333UL +#endif + +/* Register bitfield defines */ +#define PLLCTRL_FBDIV_MASK 0x7f000 +#define PLLCTRL_FBDIV_SHIFT 12 +#define PLLCTRL_BPFORCE_MASK (1 << 4) +#define PLLCTRL_PWRDWN_MASK 2 +#define PLLCTRL_PWRDWN_SHIFT 1 +#define PLLCTRL_RESET_MASK 1 +#define PLLCTRL_RESET_SHIFT 0 + +#define ZYNQ_CLK_MAXDIV 0x3f +#define CLK_CTRL_DIV1_SHIFT 20 +#define CLK_CTRL_DIV1_MASK (ZYNQ_CLK_MAXDIV << CLK_CTRL_DIV1_SHIFT) +#define CLK_CTRL_DIV0_SHIFT 8 +#define CLK_CTRL_DIV0_MASK (ZYNQ_CLK_MAXDIV << CLK_CTRL_DIV0_SHIFT) +#define CLK_CTRL_SRCSEL_SHIFT 4 +#define CLK_CTRL_SRCSEL_MASK (0x3 << CLK_CTRL_SRCSEL_SHIFT) + +#define CLK_CTRL_DIV2X_SHIFT 26 +#define CLK_CTRL_DIV2X_MASK (ZYNQ_CLK_MAXDIV << CLK_CTRL_DIV2X_SHIFT) +#define CLK_CTRL_DIV3X_SHIFT 20 +#define CLK_CTRL_DIV3X_MASK (ZYNQ_CLK_MAXDIV << CLK_CTRL_DIV3X_SHIFT) + +#define ZYNQ_CLKMUX_SEL_0 0 +#define ZYNQ_CLKMUX_SEL_1 1 +#define ZYNQ_CLKMUX_SEL_2 2 +#define ZYNQ_CLKMUX_SEL_3 3 + +DECLARE_GLOBAL_DATA_PTR; + +struct clk; + +/** + * struct clk_ops: + * @set_rate: Function pointer to set_rate() implementation + * @get_rate: Function pointer to get_rate() implementation + */ +struct clk_ops { + int (*set_rate)(struct clk *clk, unsigned long rate); + unsigned long (*get_rate)(struct clk *clk); +}; + +/** + * struct clk: + * @name: Clock name + * @frequency: Currenct frequency + * @parent: Parent clock + * @flags: Clock flags + * @reg: Clock control register + * @ops: Clock operations + */ +struct clk { + char *name; + unsigned long frequency; + enum zynq_clk parent; + unsigned int flags; + u32 *reg; + struct clk_ops ops; +}; +#define ZYNQ_CLK_FLAGS_HAS_2_DIVS 1 + +static struct clk clks[clk_max]; + +/** + * __zynq_clk_cpu_get_parent() - Decode clock multiplexer + * @srcsel: Mux select value + * Returns the clock identifier associated with the selected mux input. + */ +static int __zynq_clk_cpu_get_parent(unsigned int srcsel) +{ + unsigned int ret; + + switch (srcsel) { + case ZYNQ_CLKMUX_SEL_0: + case ZYNQ_CLKMUX_SEL_1: + ret = armpll_clk; + break; + case ZYNQ_CLKMUX_SEL_2: + ret = ddrpll_clk; + break; + case ZYNQ_CLKMUX_SEL_3: + ret = iopll_clk; + break; + default: + ret = armpll_clk; + break; + } + + return ret; +} + +/** + * ddr2x_get_rate() - Get clock rate of DDR2x clock + * @clk: Clock handle + * Returns the current clock rate of @clk. + */ +static unsigned long ddr2x_get_rate(struct clk *clk) +{ + u32 clk_ctrl = readl(clk->reg); + u32 div = (clk_ctrl & CLK_CTRL_DIV2X_MASK) >> CLK_CTRL_DIV2X_SHIFT; + + return DIV_ROUND_CLOSEST(zynq_clk_get_rate(clk->parent), div); +} + +/** + * ddr3x_get_rate() - Get clock rate of DDR3x clock + * @clk: Clock handle + * Returns the current clock rate of @clk. + */ +static unsigned long ddr3x_get_rate(struct clk *clk) +{ + u32 clk_ctrl = readl(clk->reg); + u32 div = (clk_ctrl & CLK_CTRL_DIV3X_MASK) >> CLK_CTRL_DIV3X_SHIFT; + + return DIV_ROUND_CLOSEST(zynq_clk_get_rate(clk->parent), div); +} + +static void init_ddr_clocks(void) +{ + u32 div0, div1; + unsigned long prate = zynq_clk_get_rate(ddrpll_clk); + u32 clk_ctrl = readl(&slcr_base->ddr_clk_ctrl); + + /* DDR2x */ + clks[ddr2x_clk].reg = &slcr_base->ddr_clk_ctrl; + clks[ddr2x_clk].parent = ddrpll_clk; + clks[ddr2x_clk].name = "ddr_2x"; + clks[ddr2x_clk].frequency = ddr2x_get_rate(&clks[ddr2x_clk]); + clks[ddr2x_clk].ops.get_rate = ddr2x_get_rate; + + /* DDR3x */ + clks[ddr3x_clk].reg = &slcr_base->ddr_clk_ctrl; + clks[ddr3x_clk].parent = ddrpll_clk; + clks[ddr3x_clk].name = "ddr_3x"; + clks[ddr3x_clk].frequency = ddr3x_get_rate(&clks[ddr3x_clk]); + clks[ddr3x_clk].ops.get_rate = ddr3x_get_rate; + + /* DCI */ + clk_ctrl = readl(&slcr_base->dci_clk_ctrl); + div0 = (clk_ctrl & CLK_CTRL_DIV0_MASK) >> CLK_CTRL_DIV0_SHIFT; + div1 = (clk_ctrl & CLK_CTRL_DIV1_MASK) >> CLK_CTRL_DIV1_SHIFT; + clks[dci_clk].reg = &slcr_base->dci_clk_ctrl; + clks[dci_clk].parent = ddrpll_clk; + clks[dci_clk].frequency = DIV_ROUND_CLOSEST( + DIV_ROUND_CLOSEST(prate, div0), div1); + clks[dci_clk].name = "dci"; +} + +static void init_cpu_clocks(void) +{ + int clk_621; + u32 reg, div, srcsel; + enum zynq_clk parent; + + reg = readl(&slcr_base->arm_clk_ctrl); + clk_621 = readl(&slcr_base->clk_621_true) & 1; + div = (reg & CLK_CTRL_DIV0_MASK) >> CLK_CTRL_DIV0_SHIFT; + srcsel = (reg & CLK_CTRL_SRCSEL_MASK) >> CLK_CTRL_SRCSEL_SHIFT; + parent = __zynq_clk_cpu_get_parent(srcsel); + + /* cpu clocks */ + clks[cpu_6or4x_clk].reg = &slcr_base->arm_clk_ctrl; + clks[cpu_6or4x_clk].parent = parent; + clks[cpu_6or4x_clk].frequency = DIV_ROUND_CLOSEST( + zynq_clk_get_rate(parent), div); + clks[cpu_6or4x_clk].name = "cpu_6or4x"; + + clks[cpu_3or2x_clk].reg = &slcr_base->arm_clk_ctrl; + clks[cpu_3or2x_clk].parent = cpu_6or4x_clk; + clks[cpu_3or2x_clk].frequency = zynq_clk_get_rate(cpu_6or4x_clk) / 2; + clks[cpu_3or2x_clk].name = "cpu_3or2x"; + + clks[cpu_2x_clk].reg = &slcr_base->arm_clk_ctrl; + clks[cpu_2x_clk].parent = cpu_6or4x_clk; + clks[cpu_2x_clk].frequency = zynq_clk_get_rate(cpu_6or4x_clk) / + (2 + clk_621); + clks[cpu_2x_clk].name = "cpu_2x"; + + clks[cpu_1x_clk].reg = &slcr_base->arm_clk_ctrl; + clks[cpu_1x_clk].parent = cpu_6or4x_clk; + clks[cpu_1x_clk].frequency = zynq_clk_get_rate(cpu_6or4x_clk) / + (4 + 2 * clk_621); + clks[cpu_1x_clk].name = "cpu_1x"; +} + +/** + * periph_calc_two_divs() - Calculate clock dividers + * @cur_rate: Current clock rate + * @tgt_rate: Target clock rate + * @prate: Parent clock rate + * @div0: First divider (output) + * @div1: Second divider (output) + * Returns the actual clock rate possible. + * + * Calculates clock dividers for clocks with two 6-bit dividers. + */ +static unsigned long periph_calc_two_divs(unsigned long cur_rate, + unsigned long tgt_rate, unsigned long prate, u32 *div0, + u32 *div1) +{ + long err, best_err = (long)(~0UL >> 1); + unsigned long rate, best_rate = 0; + u32 d0, d1; + + for (d0 = 1; d0 <= ZYNQ_CLK_MAXDIV; d0++) { + for (d1 = 1; d1 <= ZYNQ_CLK_MAXDIV >> 1; d1++) { + rate = DIV_ROUND_CLOSEST(DIV_ROUND_CLOSEST(prate, d0), + d1); + err = abs(rate - tgt_rate); + + if (err < best_err) { + *div0 = d0; + *div1 = d1; + best_err = err; + best_rate = rate; + } + } + } + + return best_rate; +} + +/** + * zynq_clk_periph_set_rate() - Set clock rate + * @clk: Handle of the peripheral clock + * @rate: New clock rate + * Sets the clock frequency of @clk to @rate. Returns zero on success. + */ +static int zynq_clk_periph_set_rate(struct clk *clk, + unsigned long rate) +{ + u32 ctrl, div0 = 0, div1 = 0; + unsigned long prate, new_rate, cur_rate = clk->frequency; + + ctrl = readl(clk->reg); + prate = zynq_clk_get_rate(clk->parent); + ctrl &= ~CLK_CTRL_DIV0_MASK; + + if (clk->flags & ZYNQ_CLK_FLAGS_HAS_2_DIVS) { + ctrl &= ~CLK_CTRL_DIV1_MASK; + new_rate = periph_calc_two_divs(cur_rate, rate, prate, &div0, + &div1); + ctrl |= div1 << CLK_CTRL_DIV1_SHIFT; + } else { + div0 = DIV_ROUND_CLOSEST(prate, rate); + div0 &= ZYNQ_CLK_MAXDIV; + new_rate = DIV_ROUND_CLOSEST(rate, div0); + } + + /* write new divs to hardware */ + ctrl |= div0 << CLK_CTRL_DIV0_SHIFT; + writel(ctrl, clk->reg); + + /* update frequency in clk framework */ + clk->frequency = new_rate; + + return 0; +} + +/** + * zynq_clk_periph_get_rate() - Get clock rate + * @clk: Handle of the peripheral clock + * Returns the current clock rate of @clk. + */ +static unsigned long zynq_clk_periph_get_rate(struct clk *clk) +{ + u32 clk_ctrl = readl(clk->reg); + u32 div0 = (clk_ctrl & CLK_CTRL_DIV0_MASK) >> CLK_CTRL_DIV0_SHIFT; + u32 div1 = 1; + + if (clk->flags & ZYNQ_CLK_FLAGS_HAS_2_DIVS) + div1 = (clk_ctrl & CLK_CTRL_DIV1_MASK) >> CLK_CTRL_DIV1_SHIFT; + + /* a register value of zero == division by 1 */ + if (!div0) + div0 = 1; + if (!div1) + div1 = 1; + + return + DIV_ROUND_CLOSEST( + DIV_ROUND_CLOSEST(zynq_clk_get_rate(clk->parent), div0), + div1); +} + +/** + * __zynq_clk_periph_get_parent() - Decode clock multiplexer + * @srcsel: Mux select value + * Returns the clock identifier associated with the selected mux input. + */ +static enum zynq_clk __zynq_clk_periph_get_parent(u32 srcsel) +{ + switch (srcsel) { + case ZYNQ_CLKMUX_SEL_0: + case ZYNQ_CLKMUX_SEL_1: + return iopll_clk; + case ZYNQ_CLKMUX_SEL_2: + return armpll_clk; + case ZYNQ_CLKMUX_SEL_3: + return ddrpll_clk; + default: + return 0; + } +} + +/** + * zynq_clk_periph_get_parent() - Decode clock multiplexer + * @clk: Clock handle + * Returns the clock identifier associated with the selected mux input. + */ +static enum zynq_clk zynq_clk_periph_get_parent(struct clk *clk) +{ + u32 clk_ctrl = readl(clk->reg); + u32 srcsel = (clk_ctrl & CLK_CTRL_SRCSEL_MASK) >> CLK_CTRL_SRCSEL_SHIFT; + + return __zynq_clk_periph_get_parent(srcsel); +} + +/** + * zynq_clk_register_periph_clk() - Set up a peripheral clock with the framework + * @clk: Pointer to struct clk for the clock + * @ctrl: Clock control register + * @name: PLL name + * @two_divs: Indicates whether the clock features one or two dividers + */ +static int zynq_clk_register_periph_clk(struct clk *clk, u32 *ctrl, char *name, + bool two_divs) +{ + clk->name = name; + clk->reg = ctrl; + if (two_divs) + clk->flags = ZYNQ_CLK_FLAGS_HAS_2_DIVS; + clk->parent = zynq_clk_periph_get_parent(clk); + clk->frequency = zynq_clk_periph_get_rate(clk); + clk->ops.get_rate = zynq_clk_periph_get_rate; + clk->ops.set_rate = zynq_clk_periph_set_rate; + + return 0; +} + +static void init_periph_clocks(void) +{ + zynq_clk_register_periph_clk(&clks[gem0_clk], &slcr_base->gem0_clk_ctrl, + "gem0", 1); + zynq_clk_register_periph_clk(&clks[gem1_clk], &slcr_base->gem1_clk_ctrl, + "gem1", 1); + + zynq_clk_register_periph_clk(&clks[smc_clk], &slcr_base->smc_clk_ctrl, + "smc", 0); + + zynq_clk_register_periph_clk(&clks[lqspi_clk], + &slcr_base->lqspi_clk_ctrl, "lqspi", 0); + + zynq_clk_register_periph_clk(&clks[sdio0_clk], + &slcr_base->sdio_clk_ctrl, "sdio0", 0); + zynq_clk_register_periph_clk(&clks[sdio1_clk], + &slcr_base->sdio_clk_ctrl, "sdio1", 0); + + zynq_clk_register_periph_clk(&clks[spi0_clk], &slcr_base->spi_clk_ctrl, + "spi0", 0); + zynq_clk_register_periph_clk(&clks[spi1_clk], &slcr_base->spi_clk_ctrl, + "spi1", 0); + + zynq_clk_register_periph_clk(&clks[uart0_clk], + &slcr_base->uart_clk_ctrl, "uart0", 0); + zynq_clk_register_periph_clk(&clks[uart1_clk], + &slcr_base->uart_clk_ctrl, "uart1", 0); + + zynq_clk_register_periph_clk(&clks[dbg_trc_clk], + &slcr_base->dbg_clk_ctrl, "dbg_trc", 0); + zynq_clk_register_periph_clk(&clks[dbg_apb_clk], + &slcr_base->dbg_clk_ctrl, "dbg_apb", 0); + + zynq_clk_register_periph_clk(&clks[pcap_clk], + &slcr_base->pcap_clk_ctrl, "pcap", 0); + + zynq_clk_register_periph_clk(&clks[fclk0_clk], + &slcr_base->fpga0_clk_ctrl, "fclk0", 1); + zynq_clk_register_periph_clk(&clks[fclk1_clk], + &slcr_base->fpga1_clk_ctrl, "fclk1", 1); + zynq_clk_register_periph_clk(&clks[fclk2_clk], + &slcr_base->fpga2_clk_ctrl, "fclk2", 1); + zynq_clk_register_periph_clk(&clks[fclk3_clk], + &slcr_base->fpga3_clk_ctrl, "fclk3", 1); +} + +/** + * zynq_clk_register_aper_clk() - Set up a APER clock with the framework + * @clk: Pointer to struct clk for the clock + * @ctrl: Clock control register + * @name: PLL name + */ +static void zynq_clk_register_aper_clk(struct clk *clk, u32 *ctrl, char *name) +{ + clk->name = name; + clk->reg = ctrl; + clk->parent = cpu_1x_clk; + clk->frequency = zynq_clk_get_rate(clk->parent); +} + +static void init_aper_clocks(void) +{ + zynq_clk_register_aper_clk(&clks[usb0_aper_clk], + &slcr_base->aper_clk_ctrl, "usb0_aper"); + zynq_clk_register_aper_clk(&clks[usb1_aper_clk], + &slcr_base->aper_clk_ctrl, "usb1_aper"); + + zynq_clk_register_aper_clk(&clks[gem0_aper_clk], + &slcr_base->aper_clk_ctrl, "gem0_aper"); + zynq_clk_register_aper_clk(&clks[gem1_aper_clk], + &slcr_base->aper_clk_ctrl, "gem1_aper"); + + zynq_clk_register_aper_clk(&clks[sdio0_aper_clk], + &slcr_base->aper_clk_ctrl, "sdio0_aper"); + zynq_clk_register_aper_clk(&clks[sdio1_aper_clk], + &slcr_base->aper_clk_ctrl, "sdio1_aper"); + + zynq_clk_register_aper_clk(&clks[spi0_aper_clk], + &slcr_base->aper_clk_ctrl, "spi0_aper"); + zynq_clk_register_aper_clk(&clks[spi1_aper_clk], + &slcr_base->aper_clk_ctrl, "spi1_aper"); + + zynq_clk_register_aper_clk(&clks[can0_aper_clk], + &slcr_base->aper_clk_ctrl, "can0_aper"); + zynq_clk_register_aper_clk(&clks[can1_aper_clk], + &slcr_base->aper_clk_ctrl, "can1_aper"); + + zynq_clk_register_aper_clk(&clks[i2c0_aper_clk], + &slcr_base->aper_clk_ctrl, "i2c0_aper"); + zynq_clk_register_aper_clk(&clks[i2c1_aper_clk], + &slcr_base->aper_clk_ctrl, "i2c1_aper"); + + zynq_clk_register_aper_clk(&clks[uart0_aper_clk], + &slcr_base->aper_clk_ctrl, "uart0_aper"); + zynq_clk_register_aper_clk(&clks[uart1_aper_clk], + &slcr_base->aper_clk_ctrl, "uart1_aper"); + + zynq_clk_register_aper_clk(&clks[gpio_aper_clk], + &slcr_base->aper_clk_ctrl, "gpio_aper"); + + zynq_clk_register_aper_clk(&clks[lqspi_aper_clk], + &slcr_base->aper_clk_ctrl, "lqspi_aper"); + + zynq_clk_register_aper_clk(&clks[smc_aper_clk], + &slcr_base->aper_clk_ctrl, "smc_aper"); +} + +/** + * __zynq_clk_pll_get_rate() - Get PLL rate + * @addr: Address of the PLL's control register + * Returns the current PLL output rate. + */ +static unsigned long __zynq_clk_pll_get_rate(u32 *addr) +{ + u32 reg, mul, bypass; + + reg = readl(addr); + bypass = reg & PLLCTRL_BPFORCE_MASK; + if (bypass) + mul = 1; + else + mul = (reg & PLLCTRL_FBDIV_MASK) >> PLLCTRL_FBDIV_SHIFT; + + return CONFIG_ZYNQ_PS_CLK_FREQ * mul; +} + +/** + * zynq_clk_pll_get_rate() - Get PLL rate + * @pll: Handle of the PLL + * Returns the current clock rate of @pll. + */ +static unsigned long zynq_clk_pll_get_rate(struct clk *pll) +{ + return __zynq_clk_pll_get_rate(pll->reg); +} + +/** + * zynq_clk_register_pll() - Set up a PLL with the framework + * @clk: Pointer to struct clk for the PLL + * @ctrl: PLL control register + * @name: PLL name + * @prate: PLL input clock rate + */ +static void zynq_clk_register_pll(struct clk *clk, u32 *ctrl, char *name, + unsigned long prate) +{ + clk->name = name; + clk->reg = ctrl; + clk->frequency = zynq_clk_pll_get_rate(clk); + clk->ops.get_rate = zynq_clk_pll_get_rate; +} + +/** + * clkid_2_register() - Get clock control register + * @id: Clock identifier of one of the PLLs + * Returns the address of the requested PLL's control register. + */ +static u32 *clkid_2_register(enum zynq_clk id) +{ + switch (id) { + case armpll_clk: + return &slcr_base->arm_pll_ctrl; + case ddrpll_clk: + return &slcr_base->ddr_pll_ctrl; + case iopll_clk: + return &slcr_base->io_pll_ctrl; + default: + return &slcr_base->io_pll_ctrl; + } +} + +/* API */ +/** + * zynq_clk_early_init() - Early init for the clock framework + * + * This function is called from before relocation and sets up the CPU clock + * frequency in the global data struct. + */ +void zynq_clk_early_init(void) +{ + u32 reg = readl(&slcr_base->arm_clk_ctrl); + u32 div = (reg & CLK_CTRL_DIV0_MASK) >> CLK_CTRL_DIV0_SHIFT; + u32 srcsel = (reg & CLK_CTRL_SRCSEL_MASK) >> CLK_CTRL_SRCSEL_SHIFT; + enum zynq_clk parent = __zynq_clk_cpu_get_parent(srcsel); + u32 *pllreg = clkid_2_register(parent); + unsigned long prate = __zynq_clk_pll_get_rate(pllreg); + + if (!div) + div = 1; + + gd->cpu_clk = DIV_ROUND_CLOSEST(prate, div); +} + +/** + * get_uart_clk() - Get UART input frequency + * @dev_index: UART ID + * Returns UART input clock frequency in Hz. + * + * Compared to zynq_clk_get_rate() this function is designed to work before + * relocation and can be called when the serial UART is set up. + */ +unsigned long get_uart_clk(int dev_index) +{ + u32 reg = readl(&slcr_base->uart_clk_ctrl); + u32 div = (reg & CLK_CTRL_DIV0_MASK) >> CLK_CTRL_DIV0_SHIFT; + u32 srcsel = (reg & CLK_CTRL_SRCSEL_MASK) >> CLK_CTRL_SRCSEL_SHIFT; + enum zynq_clk parent = __zynq_clk_periph_get_parent(srcsel); + u32 *pllreg = clkid_2_register(parent); + unsigned long prate = __zynq_clk_pll_get_rate(pllreg); + + if (!div) + div = 1; + + return DIV_ROUND_CLOSEST(prate, div); +} + +/** + * set_cpu_clk_info() - Initialize clock framework + * Always returns zero. + * + * This function is called from common code after relocation and sets up the + * clock framework. The framework must not be used before this function had been + * called. + */ +int set_cpu_clk_info(void) +{ + zynq_clk_register_pll(&clks[armpll_clk], &slcr_base->arm_pll_ctrl, + "armpll", CONFIG_ZYNQ_PS_CLK_FREQ); + zynq_clk_register_pll(&clks[ddrpll_clk], &slcr_base->ddr_pll_ctrl, + "ddrpll", CONFIG_ZYNQ_PS_CLK_FREQ); + zynq_clk_register_pll(&clks[iopll_clk], &slcr_base->io_pll_ctrl, + "iopll", CONFIG_ZYNQ_PS_CLK_FREQ); + + init_ddr_clocks(); + init_cpu_clocks(); + init_periph_clocks(); + init_aper_clocks(); + + return 0; +} + +/** + * zynq_clk_get_rate() - Get clock rate + * @clk: Clock identifier + * Returns the current clock rate of @clk on success or zero for an invalid + * clock id. + */ +unsigned long zynq_clk_get_rate(enum zynq_clk clk) +{ + if (clk < 0 || clk >= clk_max) + return 0; + + return clks[clk].frequency; +} + +/** + * zynq_clk_set_rate() - Set clock rate + * @clk: Clock identifier + * @rate: Requested clock rate + * Passes on the return value from the clock's set_rate() function or negative + * errno. + */ +int zynq_clk_set_rate(enum zynq_clk clk, unsigned long rate) +{ + if (clk < 0 || clk >= clk_max) + return -ENODEV; + + if (clks[clk].ops.set_rate) + return clks[clk].ops.set_rate(&clks[clk], rate); + + return -ENXIO; +} + +/** + * zynq_clk_get_name() - Get clock name + * @clk: Clock identifier + * Returns the name of @clk. + */ +const char *zynq_clk_get_name(enum zynq_clk clk) +{ + return clks[clk].name; +} diff --git a/arch/arm/cpu/armv7/zynq/cpu.c b/arch/arm/cpu/armv7/zynq/cpu.c index c771759..5d505dd 100644 --- a/arch/arm/cpu/armv7/zynq/cpu.c +++ b/arch/arm/cpu/armv7/zynq/cpu.c @@ -6,6 +6,7 @@ */ #include <common.h> #include <asm/io.h> +#include <asm/arch/clk.h> #include <asm/arch/sys_proto.h> #include <asm/arch/hardware.h>
@@ -35,6 +36,7 @@ int arch_cpu_init(void) writel(0xC, &slcr_base->ddr_urgent); #endif
+ zynq_clk_early_init(); zynq_slcr_lock();
return 0; diff --git a/arch/arm/include/asm/arch-zynq/clk.h b/arch/arm/include/asm/arch-zynq/clk.h new file mode 100644 index 0000000..250c5bc --- /dev/null +++ b/arch/arm/include/asm/arch-zynq/clk.h @@ -0,0 +1,29 @@ +/* + * Copyright (c) 2013 Xilinx Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _ZYNQ_CLK_H_ +#define _ZYNQ_CLK_H_ + +enum zynq_clk { + armpll_clk, ddrpll_clk, iopll_clk, + cpu_6or4x_clk, cpu_3or2x_clk, cpu_2x_clk, cpu_1x_clk, + ddr2x_clk, ddr3x_clk, dci_clk, + lqspi_clk, smc_clk, pcap_clk, gem0_clk, gem1_clk, + fclk0_clk, fclk1_clk, fclk2_clk, fclk3_clk, can0_clk, can1_clk, + sdio0_clk, sdio1_clk, uart0_clk, uart1_clk, spi0_clk, spi1_clk, dma_clk, + usb0_aper_clk, usb1_aper_clk, gem0_aper_clk, gem1_aper_clk, + sdio0_aper_clk, sdio1_aper_clk, spi0_aper_clk, spi1_aper_clk, + can0_aper_clk, can1_aper_clk, i2c0_aper_clk, i2c1_aper_clk, + uart0_aper_clk, uart1_aper_clk, gpio_aper_clk, lqspi_aper_clk, + smc_aper_clk, swdt_clk, dbg_trc_clk, dbg_apb_clk, clk_max}; + +void zynq_clk_early_init(void); +int zynq_clk_set_rate(enum zynq_clk clk, unsigned long rate); +unsigned long zynq_clk_get_rate(enum zynq_clk clk); +const char *zynq_clk_get_name(enum zynq_clk clk); +unsigned long get_uart_clk(int dev_id); + +#endif diff --git a/arch/arm/include/asm/arch-zynq/hardware.h b/arch/arm/include/asm/arch-zynq/hardware.h index d0fba64..39184da 100644 --- a/arch/arm/include/asm/arch-zynq/hardware.h +++ b/arch/arm/include/asm/arch-zynq/hardware.h @@ -34,12 +34,40 @@ struct slcr_regs { u32 scl; /* 0x0 */ u32 slcr_lock; /* 0x4 */ u32 slcr_unlock; /* 0x8 */ - u32 reserved0[75]; + u32 reserved0_1[61]; + u32 arm_pll_ctrl; /* 0x100 */ + u32 ddr_pll_ctrl; /* 0x104 */ + u32 io_pll_ctrl; /* 0x108 */ + u32 reserved0_2[5]; + u32 arm_clk_ctrl; /* 0x120 */ + u32 ddr_clk_ctrl; /* 0x124 */ + u32 dci_clk_ctrl; /* 0x128 */ + u32 aper_clk_ctrl; /* 0x12c */ + u32 reserved0_3[2]; u32 gem0_rclk_ctrl; /* 0x138 */ u32 gem1_rclk_ctrl; /* 0x13c */ u32 gem0_clk_ctrl; /* 0x140 */ u32 gem1_clk_ctrl; /* 0x144 */ - u32 reserved1[46]; + u32 smc_clk_ctrl; /* 0x148 */ + u32 lqspi_clk_ctrl; /* 0x14c */ + u32 sdio_clk_ctrl; /* 0x150 */ + u32 uart_clk_ctrl; /* 0x154 */ + u32 spi_clk_ctrl; /* 0x158 */ + u32 can_clk_ctrl; /* 0x15c */ + u32 can_mioclk_ctrl; /* 0x160 */ + u32 dbg_clk_ctrl; /* 0x164 */ + u32 pcap_clk_ctrl; /* 0x168 */ + u32 reserved0_4[1]; + u32 fpga0_clk_ctrl; /* 0x170 */ + u32 reserved0_5[3]; + u32 fpga1_clk_ctrl; /* 0x180 */ + u32 reserved0_6[3]; + u32 fpga2_clk_ctrl; /* 0x190 */ + u32 reserved0_7[3]; + u32 fpga3_clk_ctrl; /* 0x1a0 */ + u32 reserved0_8[8]; + u32 clk_621_true; /* 0x1c4 */ + u32 reserved1[14]; u32 pss_rst_ctrl; /* 0x200 */ u32 reserved2[15]; u32 fpga_rst_ctrl; /* 0x240 */ diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index dfa337f..9666f88 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -163,6 +163,7 @@ #define CONFIG_AUTO_COMPLETE #define CONFIG_BOARD_LATE_INIT #define CONFIG_SYS_LONGHELP +#define CONFIG_CLOCKS #define CONFIG_SYS_MAXARGS 15 /* max number of command args */ #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ -- 1.8.2.3
ARM has specific clk entries which should be also setup.
arch/arm/cpu/armv7/zynq/clk.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/cpu/armv7/zynq/clk.c b/arch/arm/cpu/armv7/zynq/clk.c index 0891a23..ea7a677 100644 --- a/arch/arm/cpu/armv7/zynq/clk.c +++ b/arch/arm/cpu/armv7/zynq/clk.c @@ -160,6 +160,8 @@ static void init_ddr_clocks(void) clks[dci_clk].frequency = DIV_ROUND_CLOSEST( DIV_ROUND_CLOSEST(prate, div0), div1); clks[dci_clk].name = "dci"; + + gd->bd->bi_ddr_freq = clks[dci_clk].frequency; }
static void init_cpu_clocks(void) @@ -592,6 +594,9 @@ int set_cpu_clk_info(void) init_periph_clocks(); init_aper_clocks();
+ gd->bd->bi_arm_freq = gd->cpu_clk; + gd->bd->bi_dsp_freq = 0; + return 0; }
-- 1.8.2.3
Remove hardcoded frequencies in favor of Zynq clock framework.
arch/arm/cpu/armv7/zynq/timer.c | 11 +++++++---- 1 file changed, 7 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/armv7/zynq/timer.c b/arch/arm/cpu/armv7/zynq/timer.c index 2be253c..78e30a6 100644 --- a/arch/arm/cpu/armv7/zynq/timer.c +++ b/arch/arm/cpu/armv7/zynq/timer.c @@ -29,6 +29,7 @@ #include <div64.h> #include <asm/io.h> #include <asm/arch/hardware.h> +#include <asm/arch/clk.h>
@@ -48,7 +49,6 @@ static struct scu_timer *timer_base =
#define TIMER_LOAD_VAL 0xFFFFFFFF #define TIMER_PRESCALE 255 -#define TIMER_TICK_HZ (CONFIG_CPU_FREQ_HZ / 2 / TIMER_PRESCALE)
int timer_init(void) { @@ -56,6 +56,8 @@ int timer_init(void) (TIMER_PRESCALE << SCUTIMER_CONTROL_PRESCALER_SHIFT) | SCUTIMER_CONTROL_ENABLE_MASK;
+ gd->arch.timer_rate_hz = (gd->cpu_clk / 2) / TIMER_PRESCALE; + /* Load the timer counter register */ writel(0xFFFFFFFF, &timer_base->load);
@@ -69,7 +71,7 @@ int timer_init(void)
/* Reset time */ gd->arch.lastinc = readl(&timer_base->counter) / - (TIMER_TICK_HZ / CONFIG_SYS_HZ); + (gd->arch.timer_rate_hz / CONFIG_SYS_HZ); gd->arch.tbl = 0;
return 0; @@ -83,7 +85,8 @@ ulong get_timer_masked(void) { ulong now;
- now = readl(&timer_base->counter) / (TIMER_TICK_HZ / CONFIG_SYS_HZ); + now = readl(&timer_base->counter) / + (gd->arch.timer_rate_hz / CONFIG_SYS_HZ);
if (gd->arch.lastinc >= now) { /* Normal mode */ @@ -107,7 +110,7 @@ void __udelay(unsigned long usec) if (usec == 0) return;
- countticks = lldiv(TIMER_TICK_HZ * usec, 1000000); + countticks = lldiv(gd->arch.timer_rate_hz * usec, 1000000);
/* decrementing timer */ timeend = readl(&timer_base->counter) - countticks; -- 1.8.2.3
Cortex-A9 MPCore TRM' from ARM (ARM DDI 0407G ID072711) describes in the section 4.1.1 how this value calculation should be done.
This patch fixes the problem if network activity such as ping or tftp is attempted after u-boot has been idle for an hour, it hangs, and cannot control-C out of it.
Signed-off-by: Uday Hegde udayh@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/arm/cpu/armv7/zynq/timer.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/zynq/timer.c b/arch/arm/cpu/armv7/zynq/timer.c index 78e30a6..174e5a1 100644 --- a/arch/arm/cpu/armv7/zynq/timer.c +++ b/arch/arm/cpu/armv7/zynq/timer.c @@ -56,7 +56,7 @@ int timer_init(void) (TIMER_PRESCALE << SCUTIMER_CONTROL_PRESCALER_SHIFT) | SCUTIMER_CONTROL_ENABLE_MASK;
- gd->arch.timer_rate_hz = (gd->cpu_clk / 2) / TIMER_PRESCALE; + gd->arch.timer_rate_hz = (gd->cpu_clk / 2) / (TIMER_PRESCALE + 1);
/* Load the timer counter register */ writel(0xFFFFFFFF, &timer_base->load); @@ -93,7 +93,7 @@ ulong get_timer_masked(void) gd->arch.tbl += gd->arch.lastinc - now; } else { /* We have an overflow ... */ - gd->arch.tbl += gd->arch.lastinc + TIMER_LOAD_VAL - now; + gd->arch.tbl += gd->arch.lastinc + TIMER_LOAD_VAL - now + 1; } gd->arch.lastinc = now;
-- 1.8.2.3
The GEM driver should not need to know about Zynq specific details of RCLK related registers and bitfields in the SLCR. Move those details to the slcr driver.
arch/arm/cpu/armv7/zynq/slcr.c | 6 +++--- arch/arm/include/asm/arch-zynq/sys_proto.h | 2 +- drivers/net/zynq_gem.c | 7 ++----- 3 files changed, 6 insertions(+), 9 deletions(-)
diff --git a/arch/arm/cpu/armv7/zynq/slcr.c b/arch/arm/cpu/armv7/zynq/slcr.c index b4c11c3..6710d92 100644 --- a/arch/arm/cpu/armv7/zynq/slcr.c +++ b/arch/arm/cpu/armv7/zynq/slcr.c @@ -50,7 +50,7 @@ void zynq_slcr_cpu_reset(void) }
/* Setup clk for network */ -void zynq_slcr_gem_clk_setup(u32 gem_id, u32 rclk, u32 clk) +void zynq_slcr_gem_clk_setup(u32 gem_id, u32 clk) { zynq_slcr_unlock();
@@ -63,12 +63,12 @@ void zynq_slcr_gem_clk_setup(u32 gem_id, u32 rclk, u32 clk) /* Set divisors for appropriate frequency in GEM_CLK_CTRL */ writel(clk, &slcr_base->gem1_clk_ctrl); /* Configure GEM_RCLK_CTRL */ - writel(rclk, &slcr_base->gem1_rclk_ctrl); + writel(1, &slcr_base->gem1_rclk_ctrl); } else { /* Set divisors for appropriate frequency in GEM_CLK_CTRL */ writel(clk, &slcr_base->gem0_clk_ctrl); /* Configure GEM_RCLK_CTRL */ - writel(rclk, &slcr_base->gem0_rclk_ctrl); + writel(1, &slcr_base->gem0_rclk_ctrl); } udelay(100000); out: diff --git a/arch/arm/include/asm/arch-zynq/sys_proto.h b/arch/arm/include/asm/arch-zynq/sys_proto.h index 8f925af..a485d79 100644 --- a/arch/arm/include/asm/arch-zynq/sys_proto.h +++ b/arch/arm/include/asm/arch-zynq/sys_proto.h @@ -10,7 +10,7 @@ extern void zynq_slcr_lock(void); extern void zynq_slcr_unlock(void); extern void zynq_slcr_cpu_reset(void); -extern void zynq_slcr_gem_clk_setup(u32 gem_id, u32 rclk, u32 clk); +extern void zynq_slcr_gem_clk_setup(u32 gem_id, u32 clk); extern void zynq_slcr_devcfg_disable(void); extern void zynq_slcr_devcfg_enable(void); extern u32 zynq_slcr_get_boot_mode(void); diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c index 6a017a8..53b7c6f 100644 --- a/drivers/net/zynq_gem.c +++ b/drivers/net/zynq_gem.c @@ -270,7 +270,7 @@ static int zynq_gem_setup_mac(struct eth_device *dev)
static int zynq_gem_init(struct eth_device *dev, bd_t * bis) { - u32 i, rclk, clk = 0; + u32 i, clk = 0; struct phy_device *phydev; const u32 stat_size = (sizeof(struct zynq_gem_regs) - offsetof(struct zynq_gem_regs, stat)) / 4; @@ -343,17 +343,14 @@ static int zynq_gem_init(struct eth_device *dev, bd_t * bis) case SPEED_1000: writel(ZYNQ_GEM_NWCFG_INIT | ZYNQ_GEM_NWCFG_SPEED1000, ®s->nwcfg); - rclk = (0 << 4) | (1 << 0); clk = (1 << 20) | (8 << 8) | (0 << 4) | (1 << 0); break; case SPEED_100: clrsetbits_le32(®s->nwcfg, ZYNQ_GEM_NWCFG_SPEED1000, ZYNQ_GEM_NWCFG_INIT | ZYNQ_GEM_NWCFG_SPEED100); - rclk = 1 << 0; clk = (5 << 20) | (8 << 8) | (0 << 4) | (1 << 0); break; case SPEED_10: - rclk = 1 << 0; /* FIXME untested */ clk = (5 << 20) | (8 << 8) | (0 << 4) | (1 << 0); break; @@ -362,7 +359,7 @@ static int zynq_gem_init(struct eth_device *dev, bd_t * bis) /* Change the rclk and clk only not using EMIO interface */ if (!priv->emio) zynq_slcr_gem_clk_setup(dev->iobase != - ZYNQ_GEM_BASEADDR0, rclk, clk); + ZYNQ_GEM_BASEADDR0, clk);
setbits_le32(®s->nwctrl, ZYNQ_GEM_NWCTRL_RXEN_MASK | ZYNQ_GEM_NWCTRL_TXEN_MASK); -- 1.8.2.3
Remove hard coded clock divider setting and use the Zynq clock framework to dynamically calculate appropriate dividers at run time.
arch/arm/cpu/armv7/zynq/slcr.c | 13 ++++++++----- arch/arm/include/asm/arch-zynq/sys_proto.h | 2 +- drivers/net/zynq_gem.c | 17 +++++++++++------ 3 files changed, 20 insertions(+), 12 deletions(-)
diff --git a/arch/arm/cpu/armv7/zynq/slcr.c b/arch/arm/cpu/armv7/zynq/slcr.c index 6710d92..d7c1882 100644 --- a/arch/arm/cpu/armv7/zynq/slcr.c +++ b/arch/arm/cpu/armv7/zynq/slcr.c @@ -8,6 +8,7 @@ #include <asm/io.h> #include <malloc.h> #include <asm/arch/hardware.h> +#include <asm/arch/clk.h>
#define SLCR_LOCK_MAGIC 0x767B #define SLCR_UNLOCK_MAGIC 0xDF0D @@ -50,8 +51,10 @@ void zynq_slcr_cpu_reset(void) }
/* Setup clk for network */ -void zynq_slcr_gem_clk_setup(u32 gem_id, u32 clk) +void zynq_slcr_gem_clk_setup(u32 gem_id, unsigned long clk_rate) { + int ret; + zynq_slcr_unlock();
if (gem_id > 1) { @@ -59,14 +62,14 @@ void zynq_slcr_gem_clk_setup(u32 gem_id, u32 clk) goto out; }
+ ret = zynq_clk_set_rate(gem0_clk + gem_id, clk_rate); + if (ret) + goto out; + if (gem_id) { - /* Set divisors for appropriate frequency in GEM_CLK_CTRL */ - writel(clk, &slcr_base->gem1_clk_ctrl); /* Configure GEM_RCLK_CTRL */ writel(1, &slcr_base->gem1_rclk_ctrl); } else { - /* Set divisors for appropriate frequency in GEM_CLK_CTRL */ - writel(clk, &slcr_base->gem0_clk_ctrl); /* Configure GEM_RCLK_CTRL */ writel(1, &slcr_base->gem0_rclk_ctrl); } diff --git a/arch/arm/include/asm/arch-zynq/sys_proto.h b/arch/arm/include/asm/arch-zynq/sys_proto.h index a485d79..0a2ba05 100644 --- a/arch/arm/include/asm/arch-zynq/sys_proto.h +++ b/arch/arm/include/asm/arch-zynq/sys_proto.h @@ -10,7 +10,7 @@ extern void zynq_slcr_lock(void); extern void zynq_slcr_unlock(void); extern void zynq_slcr_cpu_reset(void); -extern void zynq_slcr_gem_clk_setup(u32 gem_id, u32 clk); +extern void zynq_slcr_gem_clk_setup(u32 gem_id, unsigned long clk_rate); extern void zynq_slcr_devcfg_disable(void); extern void zynq_slcr_devcfg_enable(void); extern u32 zynq_slcr_get_boot_mode(void); diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c index 53b7c6f..f4c5134 100644 --- a/drivers/net/zynq_gem.c +++ b/drivers/net/zynq_gem.c @@ -90,6 +90,11 @@ #define ZYNQ_GEM_TXBUF_EXHAUSTED 0x08000000 #define ZYNQ_GEM_TXBUF_UNDERRUN 0x10000000
+/* Clock frequencies for different speeds */ +#define ZYNQ_GEM_FREQUENCY_10 2500000UL +#define ZYNQ_GEM_FREQUENCY_100 25000000UL +#define ZYNQ_GEM_FREQUENCY_1000 125000000UL + /* Device registers */ struct zynq_gem_regs { u32 nwctrl; /* Network Control reg */ @@ -270,7 +275,8 @@ static int zynq_gem_setup_mac(struct eth_device *dev)
static int zynq_gem_init(struct eth_device *dev, bd_t * bis) { - u32 i, clk = 0; + u32 i; + unsigned long clk_rate = 0; struct phy_device *phydev; const u32 stat_size = (sizeof(struct zynq_gem_regs) - offsetof(struct zynq_gem_regs, stat)) / 4; @@ -343,23 +349,22 @@ static int zynq_gem_init(struct eth_device *dev, bd_t * bis) case SPEED_1000: writel(ZYNQ_GEM_NWCFG_INIT | ZYNQ_GEM_NWCFG_SPEED1000, ®s->nwcfg); - clk = (1 << 20) | (8 << 8) | (0 << 4) | (1 << 0); + clk_rate = ZYNQ_GEM_FREQUENCY_1000; break; case SPEED_100: clrsetbits_le32(®s->nwcfg, ZYNQ_GEM_NWCFG_SPEED1000, ZYNQ_GEM_NWCFG_INIT | ZYNQ_GEM_NWCFG_SPEED100); - clk = (5 << 20) | (8 << 8) | (0 << 4) | (1 << 0); + clk_rate = ZYNQ_GEM_FREQUENCY_100; break; case SPEED_10: - /* FIXME untested */ - clk = (5 << 20) | (8 << 8) | (0 << 4) | (1 << 0); + clk_rate = ZYNQ_GEM_FREQUENCY_10; break; }
/* Change the rclk and clk only not using EMIO interface */ if (!priv->emio) zynq_slcr_gem_clk_setup(dev->iobase != - ZYNQ_GEM_BASEADDR0, clk); + ZYNQ_GEM_BASEADDR0, clk_rate);
Remove hard coded frequencies and use Zynq's clock framework to obtain the UART clock frequency.
drivers/serial/serial_zynq.c | 13 ++----------- 1 file changed, 2 insertions(+), 11 deletions(-)
diff --git a/drivers/serial/serial_zynq.c b/drivers/serial/serial_zynq.c index 9a1ee00..22c6bf0 100644 --- a/drivers/serial/serial_zynq.c +++ b/drivers/serial/serial_zynq.c @@ -10,6 +10,7 @@ #include <asm/io.h> #include <linux/compiler.h> #include <serial.h> +#include <asm/arch/clk.h> #include <asm/arch/hardware.h>
#define ZYNQ_UART_SR_TXFULL 0x00000010 /* TX FIFO full */ @@ -45,23 +46,13 @@ static struct uart_zynq *uart_zynq_ports[2] = { # define CONFIG_ZYNQ_SERIAL_BAUDRATE1 CONFIG_BAUDRATE #endif
-#if !defined(CONFIG_ZYNQ_SERIAL_CLOCK0) -# define CONFIG_ZYNQ_SERIAL_CLOCK0 50000000 -#endif -#if !defined(CONFIG_ZYNQ_SERIAL_CLOCK1) -# define CONFIG_ZYNQ_SERIAL_CLOCK1 50000000 -#endif - struct uart_zynq_params { u32 baudrate; - u32 clock; };
static struct uart_zynq_params uart_zynq_ports_param[2] = { [0].baudrate = CONFIG_ZYNQ_SERIAL_BAUDRATE0, - [0].clock = CONFIG_ZYNQ_SERIAL_CLOCK0, [1].baudrate = CONFIG_ZYNQ_SERIAL_BAUDRATE1, - [1].clock = CONFIG_ZYNQ_SERIAL_CLOCK1, };
/* Set up the baud rate in gd struct */ @@ -71,7 +62,7 @@ static void uart_zynq_serial_setbrg(const int port) unsigned int calc_bauderror, bdiv, bgen; unsigned long calc_baud = 0; unsigned long baud = uart_zynq_ports_param[port].baudrate; - unsigned long clock = uart_zynq_ports_param[port].clock; + unsigned long clock = get_uart_clk(port); struct uart_zynq *regs = uart_zynq_ports[port];
/* master clock -- 1.8.2.3
Michal Simek
