[U-Boot-Users] [PATCH] PPC4xx: Simplified post_word_{load,store}
This patch simplifies post_word_{load,store} by using the preprocessor to eliminate redundant, copy-and-pasted code.
Signed-off-by: Grant Erickson gerickson@nuovations.com --- cpu/ppc4xx/commproc.c | 26 +++++++++++--------------- 1 files changed, 11 insertions(+), 15 deletions(-)
diff --git a/cpu/ppc4xx/commproc.c b/cpu/ppc4xx/commproc.c index 22156dd..7d5ef46 100644 --- a/cpu/ppc4xx/commproc.c +++ b/cpu/ppc4xx/commproc.c @@ -30,29 +30,25 @@
#if defined(CONFIG_POST) || defined(CONFIG_LOGBUFFER)
-#if defined(CFG_POST_ALT_WORD_ADDR) -void post_word_store (ulong a) -{ - out_be32((void *)CFG_POST_ALT_WORD_ADDR, a); -} +#if defined(CFG_POST_WORD_ADDR) +# define _POST_ADDR CFG_OCM_DATA_ADDR + CFG_POST_WORD_ADDR +#elif defined(CFG_POST_ALT_WORD_ADDR) +# define _POST_ADDR CFG_POST_ALT_WORD_ADDR +#endif
-ulong post_word_load (void) -{ - return in_be32((void *)CFG_POST_ALT_WORD_ADDR); -} -#else /* CFG_POST_ALT_WORD_ADDR */ void post_word_store (ulong a) { - volatile void *save_addr = (volatile void *)(CFG_OCM_DATA_ADDR + CFG_POST_WORD_ADDR); - *(volatile ulong *) save_addr = a; + volatile void *save_addr = (volatile void *)(_POST_ADDR); + + out_be32(save_addr, a); }
ulong post_word_load (void) { - volatile void *save_addr = (volatile void *)(CFG_OCM_DATA_ADDR + CFG_POST_WORD_ADDR); - return *(volatile ulong *) save_addr; + volatile void *save_addr = (volatile void *)(_POST_ADDR); + + return in_be32(save_addr); } -#endif /* CFG_POST_ALT_WORD_ADDR */
#endif /* CONFIG_POST || CONFIG_LOGBUFFER*/
In message 1211394262-26658-1-git-send-email-gerickson@nuovations.com you wrote:
Please make this
# define _POST_ADDR ((CFG_OCM_DATA_ADDR) + (CFG_POST_WORD_ADDR))
# define _POST_ADDR (CFG_POST_ALT_WORD_ADDR)
diff --git a/cpu/ppc4xx/commproc.c b/cpu/ppc4xx/commproc.c index 22156dd..a6940e2 100644 --- a/cpu/ppc4xx/commproc.c +++ b/cpu/ppc4xx/commproc.c @@ -30,29 +30,25 @@
-#if defined(CFG_POST_ALT_WORD_ADDR) -void post_word_store (ulong a) -{ - out_be32((void *)CFG_POST_ALT_WORD_ADDR, a); -} +#if defined(CFG_POST_WORD_ADDR) +# define _POST_ADDR (CFG_OCM_DATA_ADDR + CFG_POST_WORD_ADDR) +#elif defined(CFG_POST_ALT_WORD_ADDR) +# define _POST_ADDR (CFG_POST_ALT_WORD_ADDR) +#endif
-- 1.5.4.3
In message 1211398998-30954-1-git-send-email-gerickson@nuovations.com you wrote:
Please make this
This *is* important. Assume
#define CFG_OCM_DATA_ADDR 8 | 1 #define CFG_POST_WORD_ADDR 16 | 3
Then ((CFG_OCM_DATA_ADDR) + (CFG_POST_WORD_ADDR)) gives 28 as intended, but (CFG_OCM_DATA_ADDR + CFG_POST_WORD_ADDR) gives 27.
Please make this
Agreed and I will make the change; however, were that the case, I would tend to favor the approach that the responsibility is on the definer of '8 | 1' and '16 | 3' to wrap those in parens. Thankfully, parens are a free resource.
Regards,
Grant
-#if defined(CFG_POST_ALT_WORD_ADDR) -void post_word_store (ulong a) -{ - out_be32((void *)CFG_POST_ALT_WORD_ADDR, a); -} +#if defined(CFG_POST_WORD_ADDR) +# define _POST_ADDR ((CFG_OCM_DATA_ADDR) + (CFG_POST_WORD_ADDR)) +#elif defined(CFG_POST_ALT_WORD_ADDR) +# define _POST_ADDR (CFG_POST_ALT_WORD_ADDR) +#endif
-- 1.5.4.3
Applied to u-boot-ppc4xx repo. Thanks.
Best regards, Stefan
In message 1211401710-31902-1-git-send-email-gerickson@nuovations.com you wrote:
Applied, thanks.
Grant Erickson
Stefan Roese
