[PATCH 1/2] mpc83xx: Remove stale CONFIG_SYS_LBLAWBAR{4/5/6/7}_PRELIM
Last (incorrect) use of those CONFIG items was removed by commit 9fd9abedcc ("TQM834x: remove defines causing gcc4.4 warnings")
Those items are invalid and should have been removed at the same time because lblaw[] has only 4 elements.
And they were removed from the whitelist by commit 9c5df7a2a9 ("mpc83xx: Migrate LBLAW_* to Kconfig")
Signed-off-by: Christophe Leroy christophe.leroy@csgroup.eu Fixes: 9fd9abedcc ("TQM834x: remove defines causing gcc4.4 warnings") --- arch/powerpc/cpu/mpc83xx/cpu_init.c | 16 ---------------- 1 file changed, 16 deletions(-)
diff --git a/arch/powerpc/cpu/mpc83xx/cpu_init.c b/arch/powerpc/cpu/mpc83xx/cpu_init.c index 2af5c89ae5..14df59bb8e 100644 --- a/arch/powerpc/cpu/mpc83xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc83xx/cpu_init.c @@ -227,22 +227,6 @@ void cpu_init_f (volatile immap_t * im) im->sysconf.lblaw[3].bar = CFG_SYS_LBLAWBAR3_PRELIM; im->sysconf.lblaw[3].ar = CFG_SYS_LBLAWAR3_PRELIM; #endif -#if defined(CONFIG_SYS_LBLAWBAR4_PRELIM) && defined(CONFIG_SYS_LBLAWAR4_PRELIM) - im->sysconf.lblaw[4].bar = CONFIG_SYS_LBLAWBAR4_PRELIM; - im->sysconf.lblaw[4].ar = CONFIG_SYS_LBLAWAR4_PRELIM; -#endif -#if defined(CONFIG_SYS_LBLAWBAR5_PRELIM) && defined(CONFIG_SYS_LBLAWAR5_PRELIM) - im->sysconf.lblaw[5].bar = CONFIG_SYS_LBLAWBAR5_PRELIM; - im->sysconf.lblaw[5].ar = CONFIG_SYS_LBLAWAR5_PRELIM; -#endif -#if defined(CONFIG_SYS_LBLAWBAR6_PRELIM) && defined(CONFIG_SYS_LBLAWAR6_PRELIM) - im->sysconf.lblaw[6].bar = CONFIG_SYS_LBLAWBAR6_PRELIM; - im->sysconf.lblaw[6].ar = CONFIG_SYS_LBLAWAR6_PRELIM; -#endif -#if defined(CONFIG_SYS_LBLAWBAR7_PRELIM) && defined(CONFIG_SYS_LBLAWAR7_PRELIM) - im->sysconf.lblaw[7].bar = CONFIG_SYS_LBLAWBAR7_PRELIM; - im->sysconf.lblaw[7].ar = CONFIG_SYS_LBLAWAR7_PRELIM; -#endif #ifdef CONFIG_SYS_GPIO1_PRELIM im->gpio[0].dat = CONFIG_SYS_GPIO1_DAT; im->gpio[0].dir = CONFIG_SYS_GPIO1_DIR;
Last use of CONFIG_SYS_GPIO1_PRELIM was removed by commit fae2ea5951 ("ppc: Remove MPC8349EMDS board and ARCH_MPC8349 support").
Last use of CONFIG_SYS_GPIO2_PRELIM was removed even before by commit 6843862342 ("ppc: Remove caddy2 / vme8349 boards")
Those two items were removed from whitelist by commit 8cca60a2cb ("Kconfig: Remove some symbols from the whitelist")
Signed-off-by: Christophe Leroy christophe.leroy@csgroup.eu Fixes: fae2ea5951 ("ppc: Remove MPC8349EMDS board and ARCH_MPC8349 support") --- arch/powerpc/cpu/mpc83xx/cpu_init.c | 8 -------- 1 file changed, 8 deletions(-)
diff --git a/arch/powerpc/cpu/mpc83xx/cpu_init.c b/arch/powerpc/cpu/mpc83xx/cpu_init.c index 14df59bb8e..f5cb000de6 100644 --- a/arch/powerpc/cpu/mpc83xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc83xx/cpu_init.c @@ -227,14 +227,6 @@ void cpu_init_f (volatile immap_t * im) im->sysconf.lblaw[3].bar = CFG_SYS_LBLAWBAR3_PRELIM; im->sysconf.lblaw[3].ar = CFG_SYS_LBLAWAR3_PRELIM; #endif -#ifdef CONFIG_SYS_GPIO1_PRELIM - im->gpio[0].dat = CONFIG_SYS_GPIO1_DAT; - im->gpio[0].dir = CONFIG_SYS_GPIO1_DIR; -#endif -#ifdef CONFIG_SYS_GPIO2_PRELIM - im->gpio[1].dat = CONFIG_SYS_GPIO2_DAT; - im->gpio[1].dir = CONFIG_SYS_GPIO2_DIR; -#endif }
int cpu_init_r (void)
Christophe Leroy
