[PATCH] board: amlogic: vim3: fix setup ethernet mac from efuse
Fix reading built-in ethernet MAC address from efuse
NOTE: MAC is stored in ASCII format, 1bytes = 2characters by 0 offset
if mac from efuse not valid we use meson_generate_serial_ethaddr
NOTE: remake odroid-n2.c from Neil Armstrong narmstrong@baylibre.com
Signed-off-by: Artem Lapkin art@khadas.com --- board/amlogic/vim3/vim3.c | 22 +++++++++++++++++++--- 1 file changed, 19 insertions(+), 3 deletions(-)
diff --git a/board/amlogic/vim3/vim3.c b/board/amlogic/vim3/vim3.c index 824fff8262..87d9fe1f02 100644 --- a/board/amlogic/vim3/vim3.c +++ b/board/amlogic/vim3/vim3.c @@ -139,26 +139,42 @@ int meson_ft_board_setup(void *blob, struct bd_info *bd) }
#define EFUSE_MAC_OFFSET 0 -#define EFUSE_MAC_SIZE 6 +#define EFUSE_MAC_SIZE 12 +#define MAC_ADDR_LEN 6
int misc_init_r(void) { - uint8_t mac_addr[EFUSE_MAC_SIZE]; + u8 mac_addr[MAC_ADDR_LEN]; + char efuse_mac_addr[EFUSE_MAC_SIZE], tmp[3]; ssize_t len;
meson_eth_init(PHY_INTERFACE_MODE_RGMII, 0);
if (!eth_env_get_enetaddr("ethaddr", mac_addr)) { len = meson_sm_read_efuse(EFUSE_MAC_OFFSET, - mac_addr, EFUSE_MAC_SIZE); + efuse_mac_addr, EFUSE_MAC_SIZE); if (len != EFUSE_MAC_SIZE) return 0;
+ /* MAC is stored in ASCII format, 1bytes = 2characters */ + for (int i = 0; i < 6; i++) { + tmp[0] = efuse_mac_addr[i * 2]; + tmp[1] = efuse_mac_addr[i * 2 + 1]; + tmp[2] = '\0'; + mac_addr[i] = simple_strtoul(tmp, NULL, 16); + } + if (is_valid_ethaddr(mac_addr)) eth_env_set_enetaddr("ethaddr", mac_addr); else meson_generate_serial_ethaddr(); + + eth_env_get_enetaddr("ethaddr", mac_addr); + printf("[i] setup onboard mac %02X:%02X:%02X:%02X:%02X:%02X\n", + mac_addr[0], mac_addr[1], mac_addr[2], + mac_addr[3], mac_addr[4], mac_addr[5]); }
return 0; } +
Hi Artem,
tmp[2] = '\0';
Yes, it's not necessary to print the MAC, I'll drop while applying.
return 0; }
Applying to u-boot-amlogic
Neil
Artem Lapkin
Neil Armstrong
