[PATCH v1] imxtract: add support for zstd-compressed images
Allow extraction of zstd-compressed images from FIT using imxtract command. This is especially useful when one has to load an image via some interface (e.g. SPI) rather that just to the memory.
Signed-off-by: Dmitry Gerasimov di.gerasimov@gmail.com ---
cmd/ximg.c | 23 +++++++++++++++++++++++ 1 file changed, 23 insertions(+)
diff --git a/cmd/ximg.c b/cmd/ximg.c index 0e7eead8d1..25a15fa184 100644 --- a/cmd/ximg.c +++ b/cmd/ximg.c @@ -16,6 +16,9 @@ #include <cpu_func.h> #include <env.h> #include <gzip.h> +#if IS_ENABLED(CONFIG_ZSTD) +#include <linux/zstd.h> +#endif #include <image.h> #include <malloc.h> #include <mapmem.h> @@ -238,6 +241,26 @@ do_imgextract(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) } break; #endif /* CONFIG_BZIP2 */ +#if IS_ENABLED(CONFIG_ZSTD) + case IH_COMP_ZSTD: + { + int ret; + struct abuf in, out; + + printf(" Uncompressing part %d ... ", part); + + abuf_init_set(&in, (void *)data, len); + abuf_init_set(&out, (void *)dest, unc_len); + ret = zstd_decompress(&in, &out); + if (ret < 0) { + printf("ZSTD ERROR %d - " + "image not loaded\n", ret); + return 1; + } + len = ret; + } + break; +#endif default: printf("Unimplemented compression type %d\n", comp); return 1;
Dmitry Gerasimov
