[PATCH v2 0/2] PinePhone: enable LED on boot for improved
As the PinePhone doesn't provide any visual feedback when booting, these patches take advantage of the built-in RGB LED to indicate the device is indeed powered on.
I've been carrying those downstream in Mobian for some time now, allowing users to see their phone is booting (otherwise it can be several seconds before the kernel is loaded and able to show a sign of life).
Best regards, Arnaud
-- Changes in v2: - limit the amount of #ifdef's in board.c - add a Reviewed-by record
Arnaud Ferraris (2): board: sunxi: enable status LED early pinephone_defconfig: add support for early-boot status LED
board/sunxi/board.c | 6 ++++++ configs/pinephone_defconfig | 6 ++++++ 2 files changed, 12 insertions(+)
For some systems, such as the PinePhone, there is no way for the end user to make sure the system is indeed booting before the boot script is executed, which takes several seconds. Therefore, it can be useful to provide early visual feedback as soon as possible.
In order achieve this goal, this patch initializes the status LED (if configured) in the SPL.
Signed-off-by: Arnaud Ferraris arnaud.ferraris@collabora.com --- Changes in v2: - limit the amount of #ifdef's in board.c
board/sunxi/board.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 1a46100e40..2249374fba 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -46,6 +46,7 @@ #include <spl.h> #include <sy8106a.h> #include <asm/setup.h> +#include <status_led.h>
#if defined CONFIG_VIDEO_LCD_PANEL_I2C && !(defined CONFIG_SPL_BUILD) /* So that we can use pin names in Kconfig and sunxi_name_to_gpio() */ @@ -672,6 +673,11 @@ void sunxi_board_init(void) { int power_failed = 0;
+#ifdef CONFIG_LED_STATUS + if (IS_ENABLED(CONFIG_SPL_DRIVERS_MISC)) + status_led_init(); +#endif + #ifdef CONFIG_SY8106A_POWER power_failed = sy8106a_set_vout1(CONFIG_SY8106A_VOUT1_VOLT); #endif
Reviewed-by: Samuel Holland samuel@sholland.org
This commit enables the green status LED (PD18/GPIO 114) on boot in the SPL, in order to provide visual feedback that the PinePhone is booting.
Signed-off-by: Arnaud Ferraris arnaud.ferraris@collabora.com Reviewed-by: Andre Przywara andre.przywara@arm.com --- Changes in v2: - add a Reviewed-by record
configs/pinephone_defconfig | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/configs/pinephone_defconfig b/configs/pinephone_defconfig index 64e13d3132..9d39204a43 100644 --- a/configs/pinephone_defconfig +++ b/configs/pinephone_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_SUNXI=y CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-pinephone-1.2" +CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_MACH_SUN50I=y CONFIG_SUNXI_DRAM_LPDDR3_STOCK=y @@ -10,3 +11,8 @@ CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_PINEPHONE_DT_SELECTION=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_OF_LIST="sun50i-a64-pinephone-1.1 sun50i-a64-pinephone-1.2" +CONFIG_LED_STATUS=y +CONFIG_LED_STATUS_GPIO=y +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=114 +CONFIG_LED_STATUS_STATE=2
Reviewed-by: Samuel Holland samuel@sholland.org Tested-by: Samuel Holland samuel@sholland.org
Thanks for the patch! Samuel
Arnaud Ferraris
Samuel Holland
