[PATCH v2 1/1] efi_loader: simplify efi_uninstall_protocol()
The call to efi_search_obj() is redundant as the function is called in efi_search_protocol() too.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- v2: Use handle instead of efiobj to invoke efi_disconnect_all_drivers() --- lib/efi_loader/efi_boottime.c | 9 +-------- 1 file changed, 1 insertion(+), 8 deletions(-)
diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index d5065f296a..00f1dd0f56 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -1336,24 +1336,17 @@ static efi_status_t efi_uninstall_protocol (efi_handle_t handle, const efi_guid_t *protocol, void *protocol_interface) { - struct efi_object *efiobj; struct efi_handler *handler; struct efi_open_protocol_info_item *item; struct efi_open_protocol_info_item *pos; efi_status_t r;
- /* Check handle */ - efiobj = efi_search_obj(handle); - if (!efiobj) { - r = EFI_INVALID_PARAMETER; - goto out; - } /* Find the protocol on the handle */ r = efi_search_protocol(handle, protocol, &handler); if (r != EFI_SUCCESS) goto out; /* Disconnect controllers */ - efi_disconnect_all_drivers(efiobj, protocol, NULL); + efi_disconnect_all_drivers(handle, protocol, NULL); /* Close protocol */ list_for_each_entry_safe(item, pos, &handler->open_infos, link) { if (item->info.attributes ==
Hi Heinrich
/* Check handle */
if (!efiobj) {
goto out;
- efi_disconnect_all_drivers(handle, protocol, NULL);
Mind dropping this one ? I've already sent a fix for this here[0].
You can add my reviewed-by on v1 instead
[0] https://lore.kernel.org/u-boot/20230615143941.416924-3-ilias.apalodimas@lina...
Thanks /Ilias
/* Close protocol */ list_for_each_entry_safe(item, pos, &handler->open_infos, link) { if (item->info.attributes == -- 2.40.1
On Sun, 18 Jun 2023 at 17:02, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Heinrich
/* Check handle */
if (!efiobj) {
goto out;
Thanks /Ilias
As we discussed over IRC, just add this and I'll drop it from my patches
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
-- 2.40.1
Ilias Apalodimas
