[PATCH] tools: mksunxiboot: Use sunxi_image header directly
When adding eGON support to mkimage, the struct boot_file_head definition was moved to its own header. This is the only thing mksunxiboot needed out of asm/arch/spl.h. Clean up the relative include by switching to new header.
Signed-off-by: Samuel Holland samuel@sholland.org --- We switched from using mksunxiboot to mkimage in January, so maybe it is about time to consider dropping this tool?
tools/mksunxiboot.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/mksunxiboot.c b/tools/mksunxiboot.c index a18c9d98bc..becc36565b 100644 --- a/tools/mksunxiboot.c +++ b/tools/mksunxiboot.c @@ -12,10 +12,10 @@ #include <stdlib.h> #include <string.h> #include <errno.h> +#include <sunxi_image.h> #include <sys/types.h> #include <sys/stat.h> #include "imagetool.h" -#include "../arch/arm/include/asm/arch-sunxi/spl.h"
#define STAMP_VALUE 0x5F0A6C39
Reviewed-by: Andre Przywara andre.przywara@arm.com
Well, is there a reason to remove it? Otherwise I don't see a problem to keep it around for a while, 9 months is not a terribly long time for some people.
Cheers, Andre.
No, there's not a particular reason. I was reminded that this file still exists because I tried refactoring some things to isolate SPL code, and I broke it. Now that it's fixed, leaving it is not too much trouble.
Regards, Samuel
Andre Przywara
Samuel Holland
