[PATCH] pinctrl: renesas: Add support for R8A774C0
Renesas RZ/G2E (a.k.a. r8a774c0) is pin compatible with R-Car E3 (a.k.a. r8a77990), however it doesn't have several automotive specific peripherals.
This patch hooks R8A774C0 SoC with the pfc driver.
Signed-off-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com Reviewed-by: Biju Das biju.das.jz@bp.renesas.com --- arch/arm/mach-rmobile/Kconfig.64 | 1 + drivers/pinctrl/renesas/Kconfig | 10 ++++++++++ drivers/pinctrl/renesas/Makefile | 1 + drivers/pinctrl/renesas/pfc.c | 11 +++++++++++ drivers/pinctrl/renesas/sh_pfc.h | 1 + 5 files changed, 24 insertions(+)
diff --git a/arch/arm/mach-rmobile/Kconfig.64 b/arch/arm/mach-rmobile/Kconfig.64 index 56c522596a..90bc4acd08 100644 --- a/arch/arm/mach-rmobile/Kconfig.64 +++ b/arch/arm/mach-rmobile/Kconfig.64 @@ -15,6 +15,7 @@ config R8A774B1 config R8A774C0 bool "Renesas SoC R8A774C0" imply CLK_R8A774C0 + imply PINCTRL_PFC_R8A774C0
config R8A774E1 bool "Renesas SoC R8A774E1" diff --git a/drivers/pinctrl/renesas/Kconfig b/drivers/pinctrl/renesas/Kconfig index d2be4c84ba..8fb9cba387 100644 --- a/drivers/pinctrl/renesas/Kconfig +++ b/drivers/pinctrl/renesas/Kconfig @@ -77,6 +77,16 @@ config PINCTRL_PFC_R8A774B1 the GPIO definitions and pin control functions for each available multiplex function.
+config PINCTRL_PFC_R8A774C0 + bool "Renesas RZ/G2 R8A774C0 pin control driver" + depends on PINCTRL_PFC + help + Support pin multiplexing control on Renesas RZ/G2E R8A774C0 SoCs. + + The driver is controlled by a device tree node which contains both + the GPIO definitions and pin control functions for each available + multiplex function. + config PINCTRL_PFC_R8A774E1 bool "Renesas RZ/G2 R8A774E1 pin control driver" depends on PINCTRL_PFC diff --git a/drivers/pinctrl/renesas/Makefile b/drivers/pinctrl/renesas/Makefile index 1d00752051..0e2ac3c513 100644 --- a/drivers/pinctrl/renesas/Makefile +++ b/drivers/pinctrl/renesas/Makefile @@ -1,6 +1,7 @@ obj-$(CONFIG_PINCTRL_PFC) += pfc.o obj-$(CONFIG_PINCTRL_PFC_R8A774A1) += pfc-r8a7796.o obj-$(CONFIG_PINCTRL_PFC_R8A774B1) += pfc-r8a77965.o +obj-$(CONFIG_PINCTRL_PFC_R8A774C0) += pfc-r8a77990.o obj-$(CONFIG_PINCTRL_PFC_R8A774E1) += pfc-r8a7795.o obj-$(CONFIG_PINCTRL_PFC_R8A7790) += pfc-r8a7790.o obj-$(CONFIG_PINCTRL_PFC_R8A7791) += pfc-r8a7791.o diff --git a/drivers/pinctrl/renesas/pfc.c b/drivers/pinctrl/renesas/pfc.c index 4c1e770422..8a566f7139 100644 --- a/drivers/pinctrl/renesas/pfc.c +++ b/drivers/pinctrl/renesas/pfc.c @@ -34,6 +34,7 @@ enum sh_pfc_model { SH_PFC_R8A7796, SH_PFC_R8A774A1, SH_PFC_R8A774B1, + SH_PFC_R8A774C0, SH_PFC_R8A774E1, SH_PFC_R8A77965, SH_PFC_R8A77970, @@ -909,6 +910,10 @@ static int sh_pfc_pinctrl_probe(struct udevice *dev) if (model == SH_PFC_R8A774B1) priv->pfc.info = &r8a774b1_pinmux_info; #endif +#ifdef CONFIG_PINCTRL_PFC_R8A774C0 + if (model == SH_PFC_R8A774C0) + priv->pfc.info = &r8a774c0_pinmux_info; +#endif #ifdef CONFIG_PINCTRL_PFC_R8A774E1 if (model == SH_PFC_R8A774E1) priv->pfc.info = &r8a774e1_pinmux_info; @@ -996,6 +1001,12 @@ static const struct udevice_id sh_pfc_pinctrl_ids[] = { .data = SH_PFC_R8A774B1, }, #endif +#ifdef CONFIG_PINCTRL_PFC_R8A774C0 + { + .compatible = "renesas,pfc-r8a774c0", + .data = SH_PFC_R8A774C0, + }, +#endif #ifdef CONFIG_PINCTRL_PFC_R8A774E1 { .compatible = "renesas,pfc-r8a774e1", diff --git a/drivers/pinctrl/renesas/sh_pfc.h b/drivers/pinctrl/renesas/sh_pfc.h index 22cc860f29..f563916f10 100644 --- a/drivers/pinctrl/renesas/sh_pfc.h +++ b/drivers/pinctrl/renesas/sh_pfc.h @@ -295,6 +295,7 @@ sh_pfc_pin_to_bias_reg(const struct sh_pfc *pfc, unsigned int pin,
extern const struct sh_pfc_soc_info r8a774a1_pinmux_info; extern const struct sh_pfc_soc_info r8a774b1_pinmux_info; +extern const struct sh_pfc_soc_info r8a774c0_pinmux_info; extern const struct sh_pfc_soc_info r8a774e1_pinmux_info; extern const struct sh_pfc_soc_info r8a7790_pinmux_info; extern const struct sh_pfc_soc_info r8a7791_pinmux_info;
Lad Prabhakar
