[PATCH v2] PCI: zynqmp: Add ZynqMP NWL PCIe root port driver
This patch adds the PCIe controller driver for the Xilinx / AMD ZynqMP NWL PCIe Bridge as root port. The driver source is partly copied from the Linux PCI driver and modified to enable usage in U-Boot (e.g. simplified and interrupt support removed).
Signed-off-by: Stefan Roese sr@denx.de Cc: Simon Glass sjg@chromium.org Cc: Pali Rohár pali@kernel.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Michal Simek michal.simek@amd.com --- v2: - Remove some unused members from struct nwl_pcie - Fix usage of dev_seq() in nwl_pcie_config_address() - Remove writing to PCI_PRIMARY_BUS reg as this is done by the common U-Boot PCI code later
MAINTAINERS | 1 + drivers/pci/Kconfig | 7 + drivers/pci/Makefile | 1 + drivers/pci/pcie-xilinx-nwl.c | 352 ++++++++++++++++++++++++++++++++++ 4 files changed, 361 insertions(+) create mode 100644 drivers/pci/pcie-xilinx-nwl.c
diff --git a/MAINTAINERS b/MAINTAINERS index c8f72e9ec6a2..2bc19d9daa75 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -343,6 +343,7 @@ F: drivers/rtc/armada38x.c F: drivers/spi/kirkwood_spi.c F: drivers/spi/mvebu_a3700_spi.c F: drivers/pci/pcie_dw_mvebu.c +F: drivers/pci/pcie-xilinx-nwl.c F: drivers/watchdog/armada-37xx-wdt.c F: drivers/watchdog/orion_wdt.c F: include/configs/mv-common.h diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index ef328d26525b..60d98d14640d 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -374,4 +374,11 @@ config PCIE_UNIPHIER Say Y here if you want to enable PCIe controller support on UniPhier SoCs.
+config PCIE_XILINX_NWL + bool "Xilinx NWL PCIe controller" + depends on ARCH_ZYNQMP + help + Say 'Y' here if you want support for Xilinx / AMD NWL PCIe + controller as Root Port. + endif diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index 49506e7ba59b..11f60c6991d9 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -49,3 +49,4 @@ obj-$(CONFIG_PCI_OCTEONTX) += pci_octeontx.o obj-$(CONFIG_PCIE_OCTEON) += pcie_octeon.o obj-$(CONFIG_PCIE_DW_SIFIVE) += pcie_dw_sifive.o obj-$(CONFIG_PCIE_UNIPHIER) += pcie_uniphier.o +obj-$(CONFIG_PCIE_XILINX_NWL) += pcie-xilinx-nwl.o diff --git a/drivers/pci/pcie-xilinx-nwl.c b/drivers/pci/pcie-xilinx-nwl.c new file mode 100644 index 000000000000..7ef2bdf57b56 --- /dev/null +++ b/drivers/pci/pcie-xilinx-nwl.c @@ -0,0 +1,352 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * PCIe host bridge driver for Xilinx / AMD ZynqMP NWL PCIe Bridge + * + * Based on the Linux driver which is: + * (C) Copyright 2014 - 2015, Xilinx, Inc. + * + * Author: Stefan Roese sr@denx.de + */ + +#include <clk.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <dm/devres.h> +#include <mapmem.h> +#include <pci.h> +#include <linux/delay.h> +#include <linux/io.h> +#include <linux/ioport.h> + +/* Bridge core config registers */ +#define BRCFG_PCIE_RX0 0x00000000 +#define BRCFG_PCIE_RX1 0x00000004 +#define BRCFG_INTERRUPT 0x00000010 +#define BRCFG_PCIE_RX_MSG_FILTER 0x00000020 + +/* Egress - Bridge translation registers */ +#define E_BREG_CAPABILITIES 0x00000200 +#define E_BREG_CONTROL 0x00000208 +#define E_BREG_BASE_LO 0x00000210 +#define E_BREG_BASE_HI 0x00000214 +#define E_ECAM_CAPABILITIES 0x00000220 +#define E_ECAM_CONTROL 0x00000228 +#define E_ECAM_BASE_LO 0x00000230 +#define E_ECAM_BASE_HI 0x00000234 + +#define I_ISUB_CONTROL 0x000003E8 +#define SET_ISUB_CONTROL BIT(0) +/* Rxed msg fifo - Interrupt status registers */ +#define MSGF_MISC_STATUS 0x00000400 +#define MSGF_MISC_MASK 0x00000404 +#define MSGF_LEG_STATUS 0x00000420 +#define MSGF_LEG_MASK 0x00000424 +#define MSGF_MSI_STATUS_LO 0x00000440 +#define MSGF_MSI_STATUS_HI 0x00000444 +#define MSGF_MSI_MASK_LO 0x00000448 +#define MSGF_MSI_MASK_HI 0x0000044C + +/* Msg filter mask bits */ +#define CFG_ENABLE_PM_MSG_FWD BIT(1) +#define CFG_ENABLE_INT_MSG_FWD BIT(2) +#define CFG_ENABLE_ERR_MSG_FWD BIT(3) +#define CFG_ENABLE_MSG_FILTER_MASK (CFG_ENABLE_PM_MSG_FWD | \ + CFG_ENABLE_INT_MSG_FWD | \ + CFG_ENABLE_ERR_MSG_FWD) + +/* Misc interrupt status mask bits */ +#define MSGF_MISC_SR_RXMSG_AVAIL BIT(0) +#define MSGF_MISC_SR_RXMSG_OVER BIT(1) +#define MSGF_MISC_SR_SLAVE_ERR BIT(4) +#define MSGF_MISC_SR_MASTER_ERR BIT(5) +#define MSGF_MISC_SR_I_ADDR_ERR BIT(6) +#define MSGF_MISC_SR_E_ADDR_ERR BIT(7) +#define MSGF_MISC_SR_FATAL_AER BIT(16) +#define MSGF_MISC_SR_NON_FATAL_AER BIT(17) +#define MSGF_MISC_SR_CORR_AER BIT(18) +#define MSGF_MISC_SR_UR_DETECT BIT(20) +#define MSGF_MISC_SR_NON_FATAL_DEV BIT(22) +#define MSGF_MISC_SR_FATAL_DEV BIT(23) +#define MSGF_MISC_SR_LINK_DOWN BIT(24) +#define MSGF_MSIC_SR_LINK_AUTO_BWIDTH BIT(25) +#define MSGF_MSIC_SR_LINK_BWIDTH BIT(26) + +#define MSGF_MISC_SR_MASKALL (MSGF_MISC_SR_RXMSG_AVAIL | \ + MSGF_MISC_SR_RXMSG_OVER | \ + MSGF_MISC_SR_SLAVE_ERR | \ + MSGF_MISC_SR_MASTER_ERR | \ + MSGF_MISC_SR_I_ADDR_ERR | \ + MSGF_MISC_SR_E_ADDR_ERR | \ + MSGF_MISC_SR_FATAL_AER | \ + MSGF_MISC_SR_NON_FATAL_AER | \ + MSGF_MISC_SR_CORR_AER | \ + MSGF_MISC_SR_UR_DETECT | \ + MSGF_MISC_SR_NON_FATAL_DEV | \ + MSGF_MISC_SR_FATAL_DEV | \ + MSGF_MISC_SR_LINK_DOWN | \ + MSGF_MSIC_SR_LINK_AUTO_BWIDTH | \ + MSGF_MSIC_SR_LINK_BWIDTH) + +/* Legacy interrupt status mask bits */ +#define MSGF_LEG_SR_INTA BIT(0) +#define MSGF_LEG_SR_INTB BIT(1) +#define MSGF_LEG_SR_INTC BIT(2) +#define MSGF_LEG_SR_INTD BIT(3) +#define MSGF_LEG_SR_MASKALL (MSGF_LEG_SR_INTA | MSGF_LEG_SR_INTB | \ + MSGF_LEG_SR_INTC | MSGF_LEG_SR_INTD) + +/* MSI interrupt status mask bits */ +#define MSGF_MSI_SR_LO_MASK GENMASK(31, 0) +#define MSGF_MSI_SR_HI_MASK GENMASK(31, 0) + +/* Bridge config interrupt mask */ +#define BRCFG_INTERRUPT_MASK BIT(0) +#define BREG_PRESENT BIT(0) +#define BREG_ENABLE BIT(0) +#define BREG_ENABLE_FORCE BIT(1) + +/* E_ECAM status mask bits */ +#define E_ECAM_PRESENT BIT(0) +#define E_ECAM_CR_ENABLE BIT(0) +#define E_ECAM_SIZE_LOC GENMASK(20, 16) +#define E_ECAM_SIZE_SHIFT 16 +#define NWL_ECAM_VALUE_DEFAULT 12 + +#define CFG_DMA_REG_BAR GENMASK(2, 0) +#define CFG_PCIE_CACHE GENMASK(7, 0) + +/* Readin the PS_LINKUP */ +#define PS_LINKUP_OFFSET 0x00000238 +#define PCIE_PHY_LINKUP_BIT BIT(0) +#define PHY_RDY_LINKUP_BIT BIT(1) + +/* Parameters for the waiting for link up routine */ +#define LINK_WAIT_MAX_RETRIES 10 +#define LINK_WAIT_USLEEP_MIN 90000 +#define LINK_WAIT_USLEEP_MAX 100000 + +struct nwl_pcie { + struct udevice *dev; + void __iomem *breg_base; + void __iomem *pcireg_base; + void __iomem *ecam_base; + phys_addr_t phys_breg_base; /* Physical Bridge Register Base */ + phys_addr_t phys_ecam_base; /* Physical Configuration Base */ + u32 ecam_value; +}; + +static int nwl_pcie_config_address(const struct udevice *bus, + pci_dev_t bdf, uint offset, + void **paddress) +{ + struct nwl_pcie *pcie = dev_get_priv(bus); + void *addr; + + addr = pcie->ecam_base; + addr += PCIE_ECAM_OFFSET(PCI_BUS(bdf) - dev_seq(bus), + PCI_DEV(bdf), PCI_FUNC(bdf), offset); + *paddress = addr; + + return 0; +} + +static int nwl_pcie_read_config(const struct udevice *bus, pci_dev_t bdf, + uint offset, ulong *valuep, + enum pci_size_t size) +{ + return pci_generic_mmap_read_config(bus, nwl_pcie_config_address, + bdf, offset, valuep, size); +} + +static int nwl_pcie_write_config(struct udevice *bus, pci_dev_t bdf, + uint offset, ulong value, + enum pci_size_t size) +{ + return pci_generic_mmap_write_config(bus, nwl_pcie_config_address, + bdf, offset, value, size); +} + +static const struct dm_pci_ops nwl_pcie_ops = { + .read_config = nwl_pcie_read_config, + .write_config = nwl_pcie_write_config, +}; + +static inline u32 nwl_bridge_readl(struct nwl_pcie *pcie, u32 off) +{ + return readl(pcie->breg_base + off); +} + +static inline void nwl_bridge_writel(struct nwl_pcie *pcie, u32 val, u32 off) +{ + writel(val, pcie->breg_base + off); +} + +static bool nwl_pcie_link_up(struct nwl_pcie *pcie) +{ + if (readl(pcie->pcireg_base + PS_LINKUP_OFFSET) & PCIE_PHY_LINKUP_BIT) + return true; + return false; +} + +static bool nwl_phy_link_up(struct nwl_pcie *pcie) +{ + if (readl(pcie->pcireg_base + PS_LINKUP_OFFSET) & PHY_RDY_LINKUP_BIT) + return true; + return false; +} + +static int nwl_wait_for_link(struct nwl_pcie *pcie) +{ + struct udevice *dev = pcie->dev; + int retries; + + /* check if the link is up or not */ + for (retries = 0; retries < LINK_WAIT_MAX_RETRIES; retries++) { + if (nwl_phy_link_up(pcie)) + return 0; + udelay(LINK_WAIT_USLEEP_MIN); + } + + dev_warn(dev, "PHY link never came up\n"); + return -ETIMEDOUT; +} + +static int nwl_pcie_bridge_init(struct nwl_pcie *pcie) +{ + struct udevice *dev = pcie->dev; + u32 breg_val, ecam_val; + int err; + + breg_val = nwl_bridge_readl(pcie, E_BREG_CAPABILITIES) & BREG_PRESENT; + if (!breg_val) { + dev_err(dev, "BREG is not present\n"); + return breg_val; + } + + /* Write bridge_off to breg base */ + nwl_bridge_writel(pcie, lower_32_bits(pcie->phys_breg_base), + E_BREG_BASE_LO); + nwl_bridge_writel(pcie, upper_32_bits(pcie->phys_breg_base), + E_BREG_BASE_HI); + + /* Enable BREG */ + nwl_bridge_writel(pcie, ~BREG_ENABLE_FORCE & BREG_ENABLE, + E_BREG_CONTROL); + + /* Disable DMA channel registers */ + nwl_bridge_writel(pcie, nwl_bridge_readl(pcie, BRCFG_PCIE_RX0) | + CFG_DMA_REG_BAR, BRCFG_PCIE_RX0); + + /* Enable Ingress subtractive decode translation */ + nwl_bridge_writel(pcie, SET_ISUB_CONTROL, I_ISUB_CONTROL); + + /* Enable msg filtering details */ + nwl_bridge_writel(pcie, CFG_ENABLE_MSG_FILTER_MASK, + BRCFG_PCIE_RX_MSG_FILTER); + + err = nwl_wait_for_link(pcie); + if (err) + return err; + + ecam_val = nwl_bridge_readl(pcie, E_ECAM_CAPABILITIES) & E_ECAM_PRESENT; + if (!ecam_val) { + dev_err(dev, "ECAM is not present\n"); + return ecam_val; + } + + /* Enable ECAM */ + nwl_bridge_writel(pcie, nwl_bridge_readl(pcie, E_ECAM_CONTROL) | + E_ECAM_CR_ENABLE, E_ECAM_CONTROL); + + nwl_bridge_writel(pcie, nwl_bridge_readl(pcie, E_ECAM_CONTROL) | + (pcie->ecam_value << E_ECAM_SIZE_SHIFT), + E_ECAM_CONTROL); + + nwl_bridge_writel(pcie, lower_32_bits(pcie->phys_ecam_base), + E_ECAM_BASE_LO); + nwl_bridge_writel(pcie, upper_32_bits(pcie->phys_ecam_base), + E_ECAM_BASE_HI); + + if (nwl_pcie_link_up(pcie)) + dev_info(dev, "Link is UP\n"); + else + dev_info(dev, "Link is DOWN\n"); + + /* Disable all misc interrupts */ + nwl_bridge_writel(pcie, (u32)~MSGF_MISC_SR_MASKALL, MSGF_MISC_MASK); + + /* Clear pending misc interrupts */ + nwl_bridge_writel(pcie, nwl_bridge_readl(pcie, MSGF_MISC_STATUS) & + MSGF_MISC_SR_MASKALL, MSGF_MISC_STATUS); + + /* Disable all legacy interrupts */ + nwl_bridge_writel(pcie, (u32)~MSGF_LEG_SR_MASKALL, MSGF_LEG_MASK); + + /* Clear pending legacy interrupts */ + nwl_bridge_writel(pcie, nwl_bridge_readl(pcie, MSGF_LEG_STATUS) & + MSGF_LEG_SR_MASKALL, MSGF_LEG_STATUS); + + return 0; +} + +static int nwl_pcie_parse_dt(struct nwl_pcie *pcie) +{ + struct udevice *dev = pcie->dev; + struct resource res; + int ret; + + ret = dev_read_resource_byname(dev, "breg", &res); + if (ret) + return ret; + pcie->breg_base = devm_ioremap(dev, res.start, resource_size(&res)); + if (IS_ERR(pcie->breg_base)) + return PTR_ERR(pcie->breg_base); + pcie->phys_breg_base = res.start; + + ret = dev_read_resource_byname(dev, "cfg", &res); + if (ret) + return ret; + pcie->ecam_base = devm_ioremap(dev, res.start, resource_size(&res)); + if (IS_ERR(pcie->ecam_base)) + return PTR_ERR(pcie->ecam_base); + pcie->phys_ecam_base = res.start; + + return 0; +} + +static int nwl_pcie_probe(struct udevice *dev) +{ + struct nwl_pcie *pcie = dev_get_priv(dev); + int err; + + pcie->dev = dev; + pcie->ecam_value = NWL_ECAM_VALUE_DEFAULT; + + err = nwl_pcie_parse_dt(pcie); + if (err) { + dev_err(dev, "Parsing DT failed\n"); + return err; + } + + err = nwl_pcie_bridge_init(pcie); + if (err) { + dev_err(dev, "HW Initialization failed\n"); + return err; + } + + return 0; +} + +static const struct udevice_id nwl_pcie_of_match[] = { + { .compatible = "xlnx,nwl-pcie-2.11", }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(nwl_pcie) = { + .name = "nwl-pcie", + .id = UCLASS_PCI, + .of_match = nwl_pcie_of_match, + .probe = nwl_pcie_probe, + .priv_auto = sizeof(struct nwl_pcie), + .ops = &nwl_pcie_ops, +};
v2:
Tested-by: Michal Simek michal.simek@amd.com Acked-by: Michal Simek michal.simek@amd.com
I am happy to take this via my tree if you like. We should also enable this driver by default in xilinx_zynqmp_virt_defconfig and likely any pcie driver to be able to test it. I used e1000 based card and it works as expected.
Thanks, Michal
Hi Michal,
v2:
Thanks for testing.
Please do so.
Perfect. Please do this.
Good.
Thanks, Stefan
Hi Pali,
v2:
- bool "Xilinx NWL PCIe controller"
- depends on ARCH_ZYNQMP
- help
- endif
- PCIe host bridge driver for Xilinx / AMD ZynqMP NWL PCIe Bridge
- Based on the Linux driver which is:
- (C) Copyright 2014 - 2015, Xilinx, Inc.
- Author: Stefan Roese sr@denx.de
+struct nwl_pcie {
- struct udevice *dev;
- void __iomem *breg_base;
- void __iomem *pcireg_base;
- void __iomem *ecam_base;
- phys_addr_t phys_breg_base; /* Physical Bridge Register Base */
- phys_addr_t phys_ecam_base; /* Physical Configuration Base */
- u32 ecam_value;
void **paddress)
- struct nwl_pcie *pcie = dev_get_priv(bus);
- void *addr;
- addr = pcie->ecam_base;
- addr += PCIE_ECAM_OFFSET(PCI_BUS(bdf) - dev_seq(bus),
- *paddress = addr;
- return pci_generic_mmap_read_config(bus, nwl_pcie_config_address,
- return pci_generic_mmap_write_config(bus, nwl_pcie_config_address,
- .read_config = nwl_pcie_read_config,
- .write_config = nwl_pcie_write_config,
- return readl(pcie->breg_base + off);
- writel(val, pcie->breg_base + off);
- if (readl(pcie->pcireg_base + PS_LINKUP_OFFSET) & PCIE_PHY_LINKUP_BIT)
return true;
- return false;
- if (readl(pcie->pcireg_base + PS_LINKUP_OFFSET) & PHY_RDY_LINKUP_BIT)
return true;
- return false;
- struct udevice *dev = pcie->dev;
- int retries;
- /* check if the link is up or not */
- for (retries = 0; retries < LINK_WAIT_MAX_RETRIES; retries++) {
- dev_warn(dev, "PHY link never came up\n");
- return -ETIMEDOUT;
- u32 breg_val, ecam_val;
- int err;
- breg_val = nwl_bridge_readl(pcie, E_BREG_CAPABILITIES) & BREG_PRESENT;
- if (!breg_val) {
return breg_val;
- /* Write bridge_off to breg base */
- nwl_bridge_writel(pcie, lower_32_bits(pcie->phys_breg_base),
E_BREG_BASE_LO);
- nwl_bridge_writel(pcie, upper_32_bits(pcie->phys_breg_base),
E_BREG_BASE_HI);
- /* Enable BREG */
- nwl_bridge_writel(pcie, ~BREG_ENABLE_FORCE & BREG_ENABLE,
E_BREG_CONTROL);
- /* Disable DMA channel registers */
- nwl_bridge_writel(pcie, nwl_bridge_readl(pcie, BRCFG_PCIE_RX0) |
- /* Enable Ingress subtractive decode translation */
- nwl_bridge_writel(pcie, SET_ISUB_CONTROL, I_ISUB_CONTROL);
- /* Enable msg filtering details */
- nwl_bridge_writel(pcie, CFG_ENABLE_MSG_FILTER_MASK,
- err = nwl_wait_for_link(pcie);
- if (err)
return err;
- ecam_val = nwl_bridge_readl(pcie, E_ECAM_CAPABILITIES) & E_ECAM_PRESENT;
- if (!ecam_val) {
return ecam_val;
- /* Enable ECAM */
- nwl_bridge_writel(pcie, nwl_bridge_readl(pcie, E_ECAM_CONTROL) |
E_ECAM_CONTROL);
- nwl_bridge_writel(pcie, lower_32_bits(pcie->phys_ecam_base),
E_ECAM_BASE_LO);
- nwl_bridge_writel(pcie, upper_32_bits(pcie->phys_ecam_base),
E_ECAM_BASE_HI);
- if (nwl_pcie_link_up(pcie))
- else
- /* Disable all misc interrupts */
- nwl_bridge_writel(pcie, (u32)~MSGF_MISC_SR_MASKALL, MSGF_MISC_MASK);
- /* Clear pending misc interrupts */
- nwl_bridge_writel(pcie, nwl_bridge_readl(pcie, MSGF_MISC_STATUS) &
- /* Disable all legacy interrupts */
- nwl_bridge_writel(pcie, (u32)~MSGF_LEG_SR_MASKALL, MSGF_LEG_MASK);
- /* Clear pending legacy interrupts */
- nwl_bridge_writel(pcie, nwl_bridge_readl(pcie, MSGF_LEG_STATUS) &
- struct resource res;
- int ret;
- ret = dev_read_resource_byname(dev, "breg", &res);
- if (ret)
return ret;
- pcie->breg_base = devm_ioremap(dev, res.start, resource_size(&res));
- if (IS_ERR(pcie->breg_base))
- pcie->phys_breg_base = res.start;
- ret = dev_read_resource_byname(dev, "cfg", &res);
- if (ret)
return ret;
- pcie->ecam_base = devm_ioremap(dev, res.start, resource_size(&res));
- if (IS_ERR(pcie->ecam_base))
- pcie->phys_ecam_base = res.start;
- struct nwl_pcie *pcie = dev_get_priv(dev);
- int err;
- pcie->dev = dev;
- pcie->ecam_value = NWL_ECAM_VALUE_DEFAULT;
- err = nwl_pcie_parse_dt(pcie);
- if (err) {
return err;
- err = nwl_pcie_bridge_init(pcie);
- if (err) {
return err;
- { .compatible = "xlnx,nwl-pcie-2.11", },
- { /* sentinel */ }
- .name = "nwl-pcie",
- .id = UCLASS_PCI,
- .of_match = nwl_pcie_of_match,
- .probe = nwl_pcie_probe,
- .priv_auto = sizeof(struct nwl_pcie),
- .ops = &nwl_pcie_ops,
Any comment about the driver itself?
Thanks, Michal
On Friday 02 June 2023 15:30:43 Michal Simek wrote:
Hi Pali,
On 5/25/23 11:49, Stefan Roese wrote: Any comment about the driver itself?
Thanks, Michal
Why you are so impatient? It is common that people have to wait months or year for review and you unhappy with needed to wait for just week...
Hi Pali,
Thanks, Michal
Sorry if this was too fast but it is not about impatience. On v1 you reacted the same day. This was 2 weeks after initial sent. I have no problem to wait much longer time but I need to know that any reaction will come. In kernel I see quite fast reaction time for example in networking subsystem. And then others which take ages to get patch through. I prefer shorter time when developers still have setup on their desks and images ready that they are able to retest it easily. When it takes a lot weeks people switch topics and it is much harder to finish it.
Thanks, Michal
v2:
- help
- endif
+struct nwl_pcie {
- u32 ecam_value;
void **paddress)
- void *addr;
- *paddress = addr;
return true;
- return false;
return true;
- return false;
- int retries;
- int err;
- if (!breg_val) {
return breg_val;
E_BREG_BASE_LO);
E_BREG_BASE_HI);
- /* Enable BREG */
E_BREG_CONTROL);
- if (err)
return err;
- if (!ecam_val) {
return ecam_val;
- /* Enable ECAM */
E_ECAM_CONTROL);
E_ECAM_BASE_LO);
E_ECAM_BASE_HI);
- else
- int ret;
- if (ret)
return ret;
- if (ret)
return ret;
- int err;
- pcie->dev = dev;
- if (err) {
return err;
- if (err) {
return err;
- .id = UCLASS_PCI,
Applied. If there is any chagne needed it can be done on the top of this patch.
Thanks, Michal
Looks good,
Reviewed-by: Pali Rohár pali@kernel.org
v2:
- help
+struct nwl_pcie {
- u32 ecam_value;
void **paddress)
- void *addr;
- *paddress = addr;
return true;
- return false;
return true;
- return false;
- int retries;
- int err;
- if (!breg_val) {
return breg_val;
E_BREG_BASE_LO);
E_BREG_BASE_HI);
- /* Enable BREG */
E_BREG_CONTROL);
- if (err)
return err;
- if (!ecam_val) {
return ecam_val;
- /* Enable ECAM */
E_ECAM_CONTROL);
E_ECAM_BASE_LO);
E_ECAM_BASE_HI);
- else
- int ret;
- if (ret)
return ret;
- if (ret)
return ret;
- int err;
- pcie->dev = dev;
- if (err) {
return err;
- if (err) {
return err;
- .id = UCLASS_PCI,
2.40.1
Michal Simek
Pali Rohár
Stefan Roese
