[U-Boot] About convert to LIVE DT
Hi Simon, Philipp,
When I try to convert to live dt, I fount there are many APIs work in fdt are missing in live dt,
do you have any suggestion to add these APIs in live dt quickly? I need:
fdtdec_get_addr_size_auto_noparent fdt_alloc_phandle fdt_device_is_available fdt_for_each_subnode fdt_getprop fdt_getprop_u32_default_node fdt_get_named_resource fdt_get_name fdt_get_path fdt_get_phandle fdt_node_depth fdt_node_offset_by_phandle fdt_node_offset_by_phandle_node fdt_path_offset fdt_set_phandle fdt_stringlist_get fdt_stringlist_search fdt_subnode_offset fdt_supernode_atdepth_offset
Thanks,
- Kever
Hi Kever,
On 4 February 2018 at 00:44, Kever Yang kever.yang@rock-chips.com wrote:
Hi Simon, Philipp,
dev_read_addr_size() - not having a parent doesn't happen with livetree
fdt_alloc_phandle
We don't support changing the live tree yet.
dev_read_enabled()
dev_for_each_subnode()
fdt_getprop
dev_read_prop()
This is an odd function. Can you first check that the property exists, and then use a dev_read_...() function to read it?
dev_read_resource_byname()
fdt_get_name
dev_read_name() - although I see that the comment is wrong
fdt_get_path
Not available but you can add it
fdt_get_phandle
Why do you need this?
uclass_get_device_by_phandle() or similar?
fdt_path_offset
ofnode_path() although it does not return a device. Best avoided.
fdt_set_phandle
You can't change the livtree at present.
fdt_stringlist_get
dev_read_string_index()
dev_read_stringlist_search()
fdt_subnode_offset
Why do you want that?
This should be found by scanning, generally using separate drivers for each DT node.
If you like you could send a patch with the info above, to doc/driver-model/livetree.txt to help others.
On 02/04/2018 09:40 PM, Simon Glass wrote:
Hi Kever,
Hi Simon, Philipp,
fdt_alloc_phandle
dev_read_enabled()
fdt_getprop
dev_read_prop()
fdt_get_name
fdt_get_path
fdt_get_phandle
Most of the APIs are used in this file or other files in this folder, https://github.com/rockchip-linux/u-boot/blob/release/drivers/video/drm/rock... It needs to handle quite complicated dts node for display system in rockchip drm display driver(not upstream yet): https://github.com/rockchip-linux/u-boot/blob/release/arch/arm/dts/rk3128.dt... https://github.com/rockchip-linux/u-boot/blob/release/arch/arm/dts/rk3126-bn...
Thanks, - Kever
fdt_path_offset
fdt_set_phandle
fdt_stringlist_get
fdt_subnode_offset
Hi Kever,
Hi Kever,
Hi Simon, Philipp,
fdt_alloc_phandle
dev_read_enabled()
fdt_getprop
dev_read_prop()
fdt_get_name
fdt_get_path
fdt_get_phandle
One difference I see with Linux is that U-Boot creates devices for all nodes automatically, provided that they have a compatible string and matching driver. This should simplify things in U-Boot.
The supernode-at-depth function looks like it just takes the parent of the parent when an argument of -2 is used.
The existing rockchip driver in U-Boot handles a similar binding, doesn't it? It has phandles and multiple nodes and subnodes.
Thanks,
- Kever
fdt_path_offset
fdt_set_phandle
fdt_stringlist_get
fdt_subnode_offset
Simon,
On 02/12/2018 10:35 PM, Simon Glass wrote:
Hi Kever,
Hi Kever,
Hi Simon, Philipp,
fdt_alloc_phandle
dev_read_enabled()
fdt_getprop
dev_read_prop()
fdt_get_name
fdt_get_path
fdt_get_phandle
Yes, but it does not able to migrate to support both live dt and fdt, because there is no same api in live dt, and here is what I do locally for live dt: 823 phandle = ofnode_read_u32_default(node, "connect", -1); 824 if (phandle < 0) { 825 printf("Warn: can't find connect node's handle\n"); 826 continue; 827 } 828 ep_node = of_find_node_by_phandle(phandle); 829 if (!ofnode_valid(np_to_ofnode(ep_node))) { 830 printf("Warn: can't find endpoint node from phandle\n"); 831 continue; 832 } 833 port_node = of_get_parent(ep_node); 834 if (!ofnode_valid(np_to_ofnode(port_node))) { 835 printf("Warn: can't find port node from phandle\n"); 836 continue; 837 } 838 vop_node = of_get_parent(port_node); 839 if (!ofnode_valid(np_to_ofnode(vop_node))) { 840 printf("Warn: can't find crtc node from phandle\n"); 841 continue; 842 } 843 ret = uclass_get_device_by_ofnode(UCLASS_VIDEO_CRTC, 844 np_to_ofnode(vop_node), 845 &crtc_dev);
In usb phy, we have similar requirement, but only need find "-1" depth parent.
Thanks, - Kever
Thanks,
- Kever
fdt_path_offset
fdt_set_phandle
fdt_stringlist_get
fdt_subnode_offset
Kever,
On 13 Feb 2018, at 09:04, Kever Yang kever.yang@rock-chips.com wrote:
Simon,
Hi Kever,
Hi Kever,
Hi Simon, Philipp,
fdt_alloc_phandle
dev_read_enabled()
fdt_getprop
dev_read_prop()
fdt_get_name
fdt_get_path
fdt_get_phandle
Can you use dev_get_parent() to get the parent and then use dev_read_*() on the parent?
Thanks,
- Kever
Thanks,
- Kever
fdt_path_offset
fdt_set_phandle
fdt_stringlist_get
fdt_subnode_offset
Dr. Philipp Tomsich
Kever Yang
