[U-Boot] [PATCHv2 0/3] Add support for the IGEP v2 board.
Hello,
This is the second version of patch series to add initial support for OMAP3 IGEP v2 board. Thanks Steve for your comments.
Changes since v1: - [2/3] fix parens in NUMONYX_V_ACTIMB_165 define - [3/3] add extra space after first &ctrl_base in file igep0020.c - [3/3] add a space after the 57600 comma in file igep0020.h - [3/3] remove CONFIG_SYS_ARM_WITHOUT_RELOC undef
$ git diff --stat origin/master MAKEALL | 1 + arch/arm/include/asm/arch-omap3/mem.h | 42 ++++++ board/isee/igep0020/Makefile | 49 +++++++ board/isee/igep0020/config.mk | 33 +++++ board/isee/igep0020/igep0020.c | 128 ++++++++++++++++++ board/isee/igep0020/igep0020.h | 156 ++++++++++++++++++++++ boards.cfg | 1 + drivers/mtd/onenand/onenand_base.c | 1 + include/configs/igep0020.h | 228 +++++++++++++++++++++++++++++++++ include/linux/mtd/onenand.h | 1 + 10 files changed, 640 insertions(+), 0 deletions(-)
This patch adds the Numonyx manufacturer code (0x20) to onenand manufacturers.
Signed-off-by: Enric Balletbo i Serra eballetbo@gmail.com --- drivers/mtd/onenand/onenand_base.c | 1 + include/linux/mtd/onenand.h | 1 + 2 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/drivers/mtd/onenand/onenand_base.c b/drivers/mtd/onenand/onenand_base.c index f9273ab..c978420 100644 --- a/drivers/mtd/onenand/onenand_base.c +++ b/drivers/mtd/onenand/onenand_base.c @@ -2214,6 +2214,7 @@ char *onenand_print_device_info(int device, int version)
static const struct onenand_manufacturers onenand_manuf_ids[] = { {ONENAND_MFR_SAMSUNG, "Samsung"}, + {ONENAND_MFR_NUMONYX, "Numonyx"}, };
/** diff --git a/include/linux/mtd/onenand.h b/include/linux/mtd/onenand.h index 68e174e..0025fd0 100644 --- a/include/linux/mtd/onenand.h +++ b/include/linux/mtd/onenand.h @@ -155,6 +155,7 @@ struct onenand_chip { * OneNAND Flash Manufacturer ID Codes */ #define ONENAND_MFR_SAMSUNG 0xec +#define ONENAND_MFR_NUMONYX 0x20
/** * struct nand_manufacturers - NAND Flash Manufacturer ID Structure
Dear Enric Balletbo i Serra,
- {ONENAND_MFR_NUMONYX, "Numonyx"},
Can we please keep lists like this...
- OneNAND Flash Manufacturer ID Codes
...and this sorted? Thanks.
Introduce Numonyx DDR timings and provide CONFIG_OMAP3_NUMONYX_DDR config options to allow for platform files to setup their timings.
Signed-off-by: Enric Balletbo i Serra eballetbo@gmail.com --- arch/arm/include/asm/arch-omap3/mem.h | 42 +++++++++++++++++++++++++++++++++ 1 files changed, 42 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-omap3/mem.h b/arch/arm/include/asm/arch-omap3/mem.h index a78cf9f..d574f89 100644 --- a/arch/arm/include/asm/arch-omap3/mem.h +++ b/arch/arm/include/asm/arch-omap3/mem.h @@ -128,6 +128,44 @@ enum { (MICRON_XSR_165 << 0) | (MICRON_TXP_165 << 8) | \ (MICRON_TWTR_165 << 16))
+/* NUMONYX part of IGEP v2 (165MHz optimized) 6.06ns + * ACTIMA + * TDAL = Twr/Tck + Trp/tck = 15/6 + 18/6 = 2.5 + 3 = 5.5 -> 6 + * TDPL (Twr) = 15/6 = 2.5 -> 3 + * TRRD = 12/6 = 2 + * TRCD = 22.5/6 = 3.75 -> 4 + * TRP = 18/6 = 3 + * TRAS = 42/6 = 7 + * TRC = 60/6 = 10 + * TRFC = 140/6 = 23.3 -> 24 + * ACTIMB + * TWTR = 2 + * TCKE = 2 + * TXSR = 200/6 = 33.3 -> 34 + * TXP = 1.0 + 1.1 = 2.1 -> 3 + */ +#define NUMONYX_TDAL_165 6 +#define NUMONYX_TDPL_165 3 +#define NUMONYX_TRRD_165 2 +#define NUMONYX_TRCD_165 4 +#define NUMONYX_TRP_165 3 +#define NUMONYX_TRAS_165 7 +#define NUMONYX_TRC_165 10 +#define NUMONYX_TRFC_165 24 +#define NUMONYX_V_ACTIMA_165 ((NUMONYX_TRFC_165 << 27) | \ + (NUMONYX_TRC_165 << 22) | (NUMONYX_TRAS_165 << 18) | \ + (NUMONYX_TRP_165 << 15) | (NUMONYX_TRCD_165 << 12) | \ + (NUMONYX_TRRD_165 << 9) | (NUMONYX_TDPL_165 << 6) | \ + (NUMONYX_TDAL_165)) + +#define NUMONYX_TWTR_165 2 +#define NUMONYX_TCKE_165 2 +#define NUMONYX_TXP_165 3 +#define NUMONYX_XSR_165 34 +#define NUMONYX_V_ACTIMB_165 ((NUMONYX_TCKE_165 << 12) | \ + (NUMONYX_XSR_165 << 0) | (NUMONYX_TXP_165 << 8) | \ + (NUMONYX_TWTR_165 << 16)) + #ifdef CONFIG_OMAP3_INFINEON_DDR #define V_ACTIMA_165 INFINEON_V_ACTIMA_165 #define V_ACTIMB_165 INFINEON_V_ACTIMB_165 @@ -136,6 +174,10 @@ enum { #define V_ACTIMA_165 MICRON_V_ACTIMA_165 #define V_ACTIMB_165 MICRON_V_ACTIMB_165 #endif +#ifdef CONFIG_OMAP3_NUMONYX_DDR +#define V_ACTIMA_165 NUMONYX_V_ACTIMA_165 +#define V_ACTIMB_165 NUMONYX_V_ACTIMB_165 +#endif
#if !defined(V_ACTIMA_165) || !defined(V_ACTIMB_165) #error "Please choose the right DDR type in config header"
- ACTIMA
Incorrect multiline comment style. Please break into:
/* * NUMONYX part ...
TRRD = 12/6 = 2
TRP = 18/6 = 3
TRAS = 42/6 = 7
TRC = 60/6 = 10
- ACTIMB
- TWTR = 2
- TCKE = 2
- TXSR = 200/6 = 33.3 -> 34
- TXP = 1.0 + 1.1 = 2.1 -> 3
(NUMONYX_TDAL_165))
You are using exactly the same settings as for the #ifdef CONFIG_OMAP3_MICRON_DDR above. Why do you repeat the lines then? Rather use a "#if defined(...) || defined(...)"
Hi Wolfgang
2010/10/10 Wolfgang Denk wd@denx.de:
- ACTIMA
I'll fix in version 3
- TDAL = Twr/Tck + Trp/tck = 15/6 + 18/6 = 2.5 + 3 = 5.5 -> 6
- TDPL (Twr) = 15/6 = 2.5 -> 3
- TRRD = 12/6 = 2
- TRCD = 22.5/6 = 3.75 -> 4
- TRP = 18/6 = 3
- TRAS = 42/6 = 7
- TRC = 60/6 = 10
- TRFC = 140/6 = 23.3 -> 24
- ACTIMB
- TWTR = 2
- TCKE = 2
- (NUMONYX_TRC_165 << 22) | (NUMONYX_TRAS_165 << 18) | \
- (NUMONYX_TRP_165 << 15) | (NUMONYX_TRCD_165 << 12) | \
- (NUMONYX_TRRD_165 << 9) | (NUMONYX_TDPL_165 << 6) | \
- (NUMONYX_TDAL_165))
- (NUMONYX_XSR_165 << 0) | (NUMONYX_TXP_165 << 8) | \
- (NUMONYX_TWTR_165 << 16))
I'm not agree the timmings are not the same, here a list of differences
MICRON_TRCD_165(3) != NUMONYX_TRCD_165(4) MICRON_TRFC_165(21) != NUMONYX_TRFC_165(24) MICRON_TWTR_165(1) != NUMONYX_TWTR_165(2) MICRON_TCKE_165(1) != NUMONYX_TCKE_165(2) MICRON_XSR_165(23) != NUMONYX_XSR_165(34) MICRON_TXP_165(5) != NUMONYX_TXP_165(3)
I'll send the version 3 with all your comments except this.
Cheers, Enric
Dear =?UTF-8?Q?Enric_Balletb=C3=B2_i_Serra?=,
In message AANLkTin9UM8UC7saYB9di0UB3D04r+hZuK5Z-xXJmmSn@mail.gmail.com you wrote:
Oops. I misread this. Sorry for the confusion.
The IGEP v2 board is a low-cost, fan-less and industrial temperature range single board computer that unleashes laptop-like performance and expandability without the bulk, expense, or noise of typical desktop machines. Its architecture shares much in common with other OMAP3 boards.
Signed-off-by: Enric Balletbo i Serra eballetbo@gmail.com --- MAKEALL | 1 + board/isee/igep0020/Makefile | 49 +++++++++ board/isee/igep0020/config.mk | 33 ++++++ board/isee/igep0020/igep0020.c | 128 ++++++++++++++++++++++ board/isee/igep0020/igep0020.h | 156 +++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/igep0020.h | 228 ++++++++++++++++++++++++++++++++++++++++ 7 files changed, 596 insertions(+), 0 deletions(-) create mode 100644 board/isee/igep0020/Makefile create mode 100644 board/isee/igep0020/config.mk create mode 100644 board/isee/igep0020/igep0020.c create mode 100644 board/isee/igep0020/igep0020.h create mode 100644 include/configs/igep0020.h
diff --git a/MAKEALL b/MAKEALL index 1b506d6..78dce8b 100755 --- a/MAKEALL +++ b/MAKEALL @@ -490,6 +490,7 @@ LIST_ARM11=" \ LIST_ARMV7=" \ am3517_evm \ devkit8000 \ + igep0020 \ mx51evk \ omap3_beagle \ omap3_overo \ diff --git a/board/isee/igep0020/Makefile b/board/isee/igep0020/Makefile new file mode 100644 index 0000000..2f11879 --- /dev/null +++ b/board/isee/igep0020/Makefile @@ -0,0 +1,49 @@ +# +# (C) Copyright 2000, 2001, 2002 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := igep0020.o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +clean: + rm -f $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/isee/igep0020/config.mk b/board/isee/igep0020/config.mk new file mode 100644 index 0000000..b8812f9 --- /dev/null +++ b/board/isee/igep0020/config.mk @@ -0,0 +1,33 @@ +# +# (C) Copyright 2009 +# ISEE 2007 SL, <www.iseebcn.com> +# +# IGEP0020 uses OMAP3 (ARM-CortexA8) cpu +# see http://www.ti.com/ for more information on Texas Instruments +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +# Physical Address: +# 8000'0000 (bank0) +# A000/0000 (bank1) +# Linux-Kernel is expected to be at 8000'8000, entry 8000'8000 +# (mem base + reserved) + +# For use with external or internal boots. +TEXT_BASE = 0x80008000 diff --git a/board/isee/igep0020/igep0020.c b/board/isee/igep0020/igep0020.c new file mode 100644 index 0000000..24876f9 --- /dev/null +++ b/board/isee/igep0020/igep0020.c @@ -0,0 +1,128 @@ +/* + * (C) Copyright 2010 + * ISEE 2007 SL, <www.iseebcn.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <twl4030.h> +#include <asm/io.h> +#include <asm/arch/gpio.h> +#include <asm/arch/mem.h> +#include <asm/arch/mux.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-types.h> +#include "igep0020.h" + +/* GPMC definitions for LAN9221 chips */ +static const u32 gpmc_lan_config[] = { + NET_LAN9221_GPMC_CONFIG1, + NET_LAN9221_GPMC_CONFIG2, + NET_LAN9221_GPMC_CONFIG3, + NET_LAN9221_GPMC_CONFIG4, + NET_LAN9221_GPMC_CONFIG5, + NET_LAN9221_GPMC_CONFIG6, +}; + +/* + * Routine: board_init + * Description: Early hardware init. + */ +int board_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + + gpmc_init(); /* in SRAM or SDRAM, finish GPMC */ + /* board id for Linux */ + gd->bd->bi_arch_number = MACH_TYPE_IGEP0020; + /* boot param addr */ + gd->bd->bi_boot_params = (OMAP34XX_SDRC_CS0 + 0x100); + + return 0; +} + +/* + * Routine: setup_net_chip + * Description: Setting up the configuration GPMC registers specific to the + * Ethernet hardware. + */ +#if defined(CONFIG_CMD_NET) +static void setup_net_chip(void) +{ + struct ctrl *ctrl_base = (struct ctrl *)OMAP34XX_CTRL_BASE; + + enable_gpmc_cs_config(gpmc_lan_config, &gpmc_cfg->cs[5], 0x2C000000, + GPMC_SIZE_16M); + + /* Enable off mode for NWE in PADCONF_GPMC_NWE register */ + writew(readw(&ctrl_base->gpmc_nwe) | 0x0E00, &ctrl_base->gpmc_nwe); + /* Enable off mode for NOE in PADCONF_GPMC_NADV_ALE register */ + writew(readw(&ctrl_base->gpmc_noe) | 0x0E00, &ctrl_base->gpmc_noe); + /* Enable off mode for ALE in PADCONF_GPMC_NADV_ALE register */ + writew(readw(&ctrl_base->gpmc_nadv_ale) | 0x0E00, + &ctrl_base->gpmc_nadv_ale); + + /* Make GPIO 64 as output pin and send a magic pulse through it */ + if (!omap_request_gpio(64)) { + omap_set_gpio_direction(64, 0); + omap_set_gpio_dataout(64, 1); + udelay(1); + omap_set_gpio_dataout(64, 0); + udelay(1); + omap_set_gpio_dataout(64, 1); + } +} +#endif + +/* + * Routine: misc_init_r + * Description: Configure board specific parts + */ +int misc_init_r(void) +{ + twl4030_power_init(); + +#if defined(CONFIG_CMD_NET) + setup_net_chip(); +#endif + + dieid_num_r(); + + return 0; +} + +/* + * Routine: set_muxconf_regs + * Description: Setting up the configuration Mux registers specific to the + * hardware. Many pins need to be moved from protect to primary + * mode. + */ +void set_muxconf_regs(void) +{ + MUX_DEFAULT(); +} + +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_SMC911X + rc = smc911x_initialize(0, CONFIG_SMC911X_BASE); +#endif + return rc; +} diff --git a/board/isee/igep0020/igep0020.h b/board/isee/igep0020/igep0020.h new file mode 100644 index 0000000..c08d758 --- /dev/null +++ b/board/isee/igep0020/igep0020.h @@ -0,0 +1,156 @@ +/* + * (C) Copyright 2010 + * ISEE 2007 SL, <www.iseebcn.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _IGEP0020_H_ +#define _IGEP0020_H_ + +const omap3_sysinfo sysinfo = { + DDR_STACKED, + "IGEP v2 board", + "ONENAND", +}; + +/* GPMC CS 5 connected to an SMSC LAN9221 ethernet controller */ +#define NET_LAN9221_GPMC_CONFIG1 0x00001000 +#define NET_LAN9221_GPMC_CONFIG2 0x00080701 +#define NET_LAN9221_GPMC_CONFIG3 0x00020201 +#define NET_LAN9221_GPMC_CONFIG4 0x08030703 +#define NET_LAN9221_GPMC_CONFIG5 0x00060908 +#define NET_LAN9221_GPMC_CONFIG6 0x87030000 +#define NET_LAN9221_GPMC_CONFIG7 0x00000f6c + +static void setup_net_chip(void); + +/* + * IEN - Input Enable + * IDIS - Input Disable + * PTD - Pull type Down + * PTU - Pull type Up + * DIS - Pull type selection is inactive + * EN - Pull type selection is active + * M0 - Mode 0 + * The commented string gives the final mux configuration for that pin + */ +#define MUX_DEFAULT()\ + MUX_VAL(CP(SDRC_D0), (IEN | PTD | DIS | M0)) /* SDRC_D0 */\ + MUX_VAL(CP(SDRC_D1), (IEN | PTD | DIS | M0)) /* SDRC_D1 */\ + MUX_VAL(CP(SDRC_D2), (IEN | PTD | DIS | M0)) /* SDRC_D2 */\ + MUX_VAL(CP(SDRC_D3), (IEN | PTD | DIS | M0)) /* SDRC_D3 */\ + MUX_VAL(CP(SDRC_D4), (IEN | PTD | DIS | M0)) /* SDRC_D4 */\ + MUX_VAL(CP(SDRC_D5), (IEN | PTD | DIS | M0)) /* SDRC_D5 */\ + MUX_VAL(CP(SDRC_D6), (IEN | PTD | DIS | M0)) /* SDRC_D6 */\ + MUX_VAL(CP(SDRC_D7), (IEN | PTD | DIS | M0)) /* SDRC_D7 */\ + MUX_VAL(CP(SDRC_D8), (IEN | PTD | DIS | M0)) /* SDRC_D8 */\ + MUX_VAL(CP(SDRC_D9), (IEN | PTD | DIS | M0)) /* SDRC_D9 */\ + MUX_VAL(CP(SDRC_D10), (IEN | PTD | DIS | M0)) /* SDRC_D10 */\ + MUX_VAL(CP(SDRC_D11), (IEN | PTD | DIS | M0)) /* SDRC_D11 */\ + MUX_VAL(CP(SDRC_D12), (IEN | PTD | DIS | M0)) /* SDRC_D12 */\ + MUX_VAL(CP(SDRC_D13), (IEN | PTD | DIS | M0)) /* SDRC_D13 */\ + MUX_VAL(CP(SDRC_D14), (IEN | PTD | DIS | M0)) /* SDRC_D14 */\ + MUX_VAL(CP(SDRC_D15), (IEN | PTD | DIS | M0)) /* SDRC_D15 */\ + MUX_VAL(CP(SDRC_D16), (IEN | PTD | DIS | M0)) /* SDRC_D16 */\ + MUX_VAL(CP(SDRC_D17), (IEN | PTD | DIS | M0)) /* SDRC_D17 */\ + MUX_VAL(CP(SDRC_D18), (IEN | PTD | DIS | M0)) /* SDRC_D18 */\ + MUX_VAL(CP(SDRC_D19), (IEN | PTD | DIS | M0)) /* SDRC_D19 */\ + MUX_VAL(CP(SDRC_D20), (IEN | PTD | DIS | M0)) /* SDRC_D20 */\ + MUX_VAL(CP(SDRC_D21), (IEN | PTD | DIS | M0)) /* SDRC_D21 */\ + MUX_VAL(CP(SDRC_D22), (IEN | PTD | DIS | M0)) /* SDRC_D22 */\ + MUX_VAL(CP(SDRC_D23), (IEN | PTD | DIS | M0)) /* SDRC_D23 */\ + MUX_VAL(CP(SDRC_D24), (IEN | PTD | DIS | M0)) /* SDRC_D24 */\ + MUX_VAL(CP(SDRC_D25), (IEN | PTD | DIS | M0)) /* SDRC_D25 */\ + MUX_VAL(CP(SDRC_D26), (IEN | PTD | DIS | M0)) /* SDRC_D26 */\ + MUX_VAL(CP(SDRC_D27), (IEN | PTD | DIS | M0)) /* SDRC_D27 */\ + MUX_VAL(CP(SDRC_D28), (IEN | PTD | DIS | M0)) /* SDRC_D28 */\ + MUX_VAL(CP(SDRC_D29), (IEN | PTD | DIS | M0)) /* SDRC_D29 */\ + MUX_VAL(CP(SDRC_D30), (IEN | PTD | DIS | M0)) /* SDRC_D30 */\ + MUX_VAL(CP(SDRC_D31), (IEN | PTD | DIS | M0)) /* SDRC_D31 */\ + MUX_VAL(CP(SDRC_CLK), (IEN | PTD | DIS | M0)) /* SDRC_CLK */\ + MUX_VAL(CP(SDRC_DQS0), (IEN | PTD | DIS | M0)) /* SDRC_DQS0 */\ + MUX_VAL(CP(SDRC_DQS1), (IEN | PTD | DIS | M0)) /* SDRC_DQS1 */\ + MUX_VAL(CP(SDRC_DQS2), (IEN | PTD | DIS | M0)) /* SDRC_DQS2 */\ + MUX_VAL(CP(SDRC_DQS3), (IEN | PTD | DIS | M0)) /* SDRC_DQS3 */\ + MUX_VAL(CP(GPMC_A1), (IDIS | PTD | DIS | M0)) /* GPMC_A1 */\ + MUX_VAL(CP(GPMC_A2), (IDIS | PTD | DIS | M0)) /* GPMC_A2 */\ + MUX_VAL(CP(GPMC_A3), (IDIS | PTD | DIS | M0)) /* GPMC_A3 */\ + MUX_VAL(CP(GPMC_A4), (IDIS | PTD | DIS | M0)) /* GPMC_A4 */\ + MUX_VAL(CP(GPMC_A5), (IDIS | PTD | DIS | M0)) /* GPMC_A5 */\ + MUX_VAL(CP(GPMC_A6), (IDIS | PTD | DIS | M0)) /* GPMC_A6 */\ + MUX_VAL(CP(GPMC_A7), (IDIS | PTD | DIS | M0)) /* GPMC_A7 */\ + MUX_VAL(CP(GPMC_A8), (IDIS | PTD | DIS | M0)) /* GPMC_A8 */\ + MUX_VAL(CP(GPMC_A9), (IDIS | PTD | DIS | M0)) /* GPMC_A9 */\ + MUX_VAL(CP(GPMC_A10), (IDIS | PTD | DIS | M0)) /* GPMC_A10 */\ + MUX_VAL(CP(GPMC_D0), (IEN | PTD | DIS | M0)) /* GPMC_D0 */\ + MUX_VAL(CP(GPMC_D1), (IEN | PTD | DIS | M0)) /* GPMC_D1 */\ + MUX_VAL(CP(GPMC_D2), (IEN | PTD | DIS | M0)) /* GPMC_D2 */\ + MUX_VAL(CP(GPMC_D3), (IEN | PTD | DIS | M0)) /* GPMC_D3 */\ + MUX_VAL(CP(GPMC_D4), (IEN | PTD | DIS | M0)) /* GPMC_D4 */\ + MUX_VAL(CP(GPMC_D5), (IEN | PTD | DIS | M0)) /* GPMC_D5 */\ + MUX_VAL(CP(GPMC_D6), (IEN | PTD | DIS | M0)) /* GPMC_D6 */\ + MUX_VAL(CP(GPMC_D7), (IEN | PTD | DIS | M0)) /* GPMC_D7 */\ + MUX_VAL(CP(GPMC_D8), (IEN | PTD | DIS | M0)) /* GPMC_D8 */\ + MUX_VAL(CP(GPMC_D9), (IEN | PTD | DIS | M0)) /* GPMC_D9 */\ + MUX_VAL(CP(GPMC_D10), (IEN | PTD | DIS | M0)) /* GPMC_D10 */\ + MUX_VAL(CP(GPMC_D11), (IEN | PTD | DIS | M0)) /* GPMC_D11 */\ + MUX_VAL(CP(GPMC_D12), (IEN | PTD | DIS | M0)) /* GPMC_D12 */\ + MUX_VAL(CP(GPMC_D13), (IEN | PTD | DIS | M0)) /* GPMC_D13 */\ + MUX_VAL(CP(GPMC_D14), (IEN | PTD | DIS | M0)) /* GPMC_D14 */\ + MUX_VAL(CP(GPMC_D15), (IEN | PTD | DIS | M0)) /* GPMC_D15 */\ + MUX_VAL(CP(GPMC_NCS0), (IDIS | PTU | EN | M0)) /* GPMC_nCS0 */\ + MUX_VAL(CP(GPMC_NCS1), (IDIS | PTU | EN | M0)) /* GPMC_nCS1 */\ + MUX_VAL(CP(GPMC_NCS2), (IDIS | PTU | EN | M0)) /* GPIO_nCS2 */\ + MUX_VAL(CP(GPMC_NCS3), (IDIS | PTU | EN | M0)) /* GPIO_nCS3 */\ + MUX_VAL(CP(GPMC_NCS4), (IDIS | PTU | EN | M0)) /* GPMC_nCS4 */\ + MUX_VAL(CP(GPMC_NCS5), (IDIS | PTU | EN | M0)) /* GPMC_nCS5 */\ + MUX_VAL(CP(GPMC_NCS6), (IDIS | PTU | EN | M0)) /* GPMC_nCS6 */\ + MUX_VAL(CP(GPMC_NCS7), (IDIS | PTU | EN | M0)) /* GPMC_nCS7 */\ + MUX_VAL(CP(GPMC_CLK), (IDIS | PTD | DIS | M0)) /* GPMC_CLK */\ + MUX_VAL(CP(GPMC_NADV_ALE), (IDIS | PTD | DIS | M0)) /* GPMC_nADV_ALE */\ + MUX_VAL(CP(GPMC_NOE), (IDIS | PTD | DIS | M0)) /* GPMC_nOE */\ + MUX_VAL(CP(GPMC_NWE), (IDIS | PTD | DIS | M0)) /* GPMC_nWE */\ + MUX_VAL(CP(GPMC_NBE0_CLE), (IDIS | PTD | DIS | M0)) /* GPMC_nBE0_CLE */\ + MUX_VAL(CP(GPMC_NBE1), (IEN | PTD | DIS | M0)) /* GPMC_nBE1 */\ + MUX_VAL(CP(GPMC_NWP), (IEN | PTD | DIS | M0)) /* GPMC_nWP */\ + MUX_VAL(CP(GPMC_WAIT0), (IEN | PTU | EN | M0)) /* GPMC_WAIT0 */\ + MUX_VAL(CP(GPMC_WAIT2), (IEN | PTU | DIS | M4)) /* GPIO_64-ETH_NRST */\ + MUX_VAL(CP(MMC1_CLK), (IDIS | PTU | EN | M0)) /* MMC1_CLK */\ + MUX_VAL(CP(MMC1_CMD), (IEN | PTU | EN | M0)) /* MMC1_CMD */\ + MUX_VAL(CP(MMC1_DAT0), (IEN | PTU | EN | M0)) /* MMC1_DAT0 */\ + MUX_VAL(CP(MMC1_DAT1), (IEN | PTU | EN | M0)) /* MMC1_DAT1 */\ + MUX_VAL(CP(MMC1_DAT2), (IEN | PTU | EN | M0)) /* MMC1_DAT2 */\ + MUX_VAL(CP(MMC1_DAT3), (IEN | PTU | EN | M0)) /* MMC1_DAT3 */\ + MUX_VAL(CP(UART3_TX_IRTX), (IDIS | PTD | DIS | M0)) /* UART3_TX */\ + MUX_VAL(CP(UART3_RX_IRRX), (IEN | PTD | DIS | M0)) /* UART3_RX */\ + MUX_VAL(CP(I2C1_SCL), (IEN | PTU | EN | M0)) /* I2C1_SCL */\ + MUX_VAL(CP(I2C1_SDA), (IEN | PTU | EN | M0)) /* I2C1_SDA */\ + MUX_VAL(CP(I2C4_SCL), (IEN | PTU | EN | M0)) /* I2C4_SCL */\ + MUX_VAL(CP(I2C4_SDA), (IEN | PTU | EN | M0)) /* I2C4_SDA */\ + MUX_VAL(CP(SYS_32K), (IEN | PTD | DIS | M0)) /* SYS_32K */\ + MUX_VAL(CP(SYS_BOOT0), (IEN | PTD | DIS | M4)) /* GPIO_2 */\ + MUX_VAL(CP(SYS_BOOT1), (IEN | PTD | DIS | M4)) /* GPIO_3 */\ + MUX_VAL(CP(SYS_BOOT2), (IEN | PTD | DIS | M4)) /* GPIO_4 */\ + MUX_VAL(CP(SYS_BOOT3), (IEN | PTD | DIS | M4)) /* GPIO_5 */\ + MUX_VAL(CP(SYS_BOOT4), (IEN | PTD | DIS | M4)) /* GPIO_6 */\ + MUX_VAL(CP(SYS_BOOT5), (IEN | PTD | DIS | M4)) /* GPIO_7 */\ + MUX_VAL(CP(SYS_BOOT6), (IEN | PTD | DIS | M4)) /* GPIO_8 */\ + MUX_VAL(CP(SDRC_CKE0), (IDIS | PTU | EN | M0)) /* SDRC_CKE0 */\ + MUX_VAL(CP(SDRC_CKE1), (IDIS | PTU | EN | M0)) /* SDRC_CKE1 */ +#endif diff --git a/boards.cfg b/boards.cfg index 202de1a..6f8db44 100644 --- a/boards.cfg +++ b/boards.cfg @@ -262,6 +262,7 @@ omap4_panda arm armv7 panda ti omap4 omap4_sdp4430 arm armv7 sdp4430 ti omap4 am3517_evm arm armv7 am3517evm logicpd omap3 devkit8000 arm armv7 devkit8000 timll omap3 +igep0020 arm armv7 igep0020 isee omap3 s5p_goni arm armv7 goni samsung s5pc1xx smdkc100 arm armv7 smdkc100 samsung s5pc1xx ixdpg425 arm ixp diff --git a/include/configs/igep0020.h b/include/configs/igep0020.h new file mode 100644 index 0000000..34e8a57 --- /dev/null +++ b/include/configs/igep0020.h @@ -0,0 +1,228 @@ +/* + * (C) Copyright 2010 + * ISEE 2007 SL, <www.iseebcn.com> + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H +#include <asm/sizes.h> + +/* + * High Level Configuration Options + */ +#define CONFIG_ARMV7 1 /* This is an ARM V7 CPU core */ +#define CONFIG_OMAP 1 /* in a TI OMAP core */ +#define CONFIG_OMAP34XX 1 /* which is a 34XX */ +#define CONFIG_OMAP3430 1 /* which is in a 3430 */ +#define CONFIG_OMAP3_IGEP0020 1 /* working with IGEP0020 */ + +#define CONFIG_SDRC /* The chip has SDRC controller */ + +#include <asm/arch/cpu.h> +#include <asm/arch/omap3.h> + +/* + * Display CPU and Board information + */ +#define CONFIG_DISPLAY_CPUINFO 1 +#define CONFIG_DISPLAY_BOARDINFO 1 + +/* Clock Defines */ +#define V_OSCK 26000000 /* Clock output from T2 */ +#define V_SCLK (V_OSCK >> 1) + +#define CONFIG_MISC_INIT_R + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 +#define CONFIG_REVISION_TAG 1 + +/* + * NS16550 Configuration + */ + +#define V_NS16550_CLK 48000000 /* 48MHz (APLL96/2) */ + +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK V_NS16550_CLK + +/* select serial console configuration */ +#define CONFIG_CONS_INDEX 3 +#define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 +#define CONFIG_SERIAL3 3 + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600, 115200} +#define CONFIG_MMC 1 +#define CONFIG_OMAP3_MMC 1 +#define CONFIG_DOS_PARTITION 1 + +/* DDR */ +#define CONFIG_OMAP3_NUMONYX_DDR 1 + +/* USB */ +#define CONFIG_MUSB_UDC 1 +#define CONFIG_USB_OMAP3 1 +#define CONFIG_TWL4030_USB 1 + +/* USB device configuration */ +#define CONFIG_USB_DEVICE 1 +#define CONFIG_USB_TTY 1 +#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 + +/* Change these to suit your needs */ +#define CONFIG_USBD_VENDORID 0x0451 +#define CONFIG_USBD_PRODUCTID 0x5678 +#define CONFIG_USBD_MANUFACTURER "Texas Instruments" +#define CONFIG_USBD_PRODUCT_NAME "IGEP" + +/* commands to include */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_EXT2 /* EXT2 Support */ +#define CONFIG_CMD_FAT /* FAT support */ +#define CONFIG_CMD_I2C /* I2C serial bus support */ +#define CONFIG_CMD_MMC /* MMC support */ +#define CONFIG_CMD_ONENAND /* ONENAND support */ +#define CONFIG_CMD_NET /* bootp, tftpboot, rarpboot */ +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING +#define CONFIG_CMD_NFS /* NFS support */ +#define CONFIG_CMD_MTDPARTS /* Enable MTD parts commands */ +#define CONFIG_MTD_DEVICE + +#undef CONFIG_CMD_FLASH /* flinfo, erase, protect */ +#undef CONFIG_CMD_IMLS /* List all found images */ + +#define CONFIG_SYS_NO_FLASH +#define CONFIG_HARD_I2C 1 +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C_SLAVE 1 +#define CONFIG_SYS_I2C_BUS 0 +#define CONFIG_SYS_I2C_BUS_SELECT 1 +#define CONFIG_DRIVER_OMAP34XX_I2C 1 + +/* + * TWL4030 + */ +#define CONFIG_TWL4030_POWER 1 + +/* Environment information */ +#define CONFIG_BOOTCOMMAND \ + "mmc init 0 ; fatload mmc 0 0x80000000 setup.ini ; source \0" + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "usbtty=cdc_acm\0" + +#define CONFIG_AUTO_COMPLETE 1 + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_PROMPT "U-Boot # " +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE (CONFIG_SYS_CBSIZE) + +#define CONFIG_SYS_MEMTEST_START (OMAP34XX_SDRC_CS0) /* memtest */ + /* works on */ +#define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + \ + 0x01F00000) /* 31MB */ + +#define CONFIG_SYS_LOAD_ADDR (OMAP34XX_SDRC_CS0) /* default */ + /* load address */ + +#define CONFIG_SYS_MONITOR_LEN (256 << 10) + +/* + * OMAP3 has 12 GP timers, they can be driven by the system clock + * (12/13/16.8/19.2/38.4MHz) or by 32KHz clock. We use 13MHz (V_SCLK). + * This rate is divided by a local divisor. + */ +#define CONFIG_SYS_TIMERBASE (OMAP34XX_GPT2) +#define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */ +#define CONFIG_SYS_HZ 1000 + +/* + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128 << 10) /* regular stack 128 KiB */ + +/* + * Physical Memory Map + * + */ +#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */ +#define PHYS_SDRAM_1 OMAP34XX_SDRC_CS0 +#define PHYS_SDRAM_1_SIZE (32 << 20) /* at least 32 meg */ +#define PHYS_SDRAM_2 OMAP34XX_SDRC_CS1 + +/* SDRAM Bank Allocation method */ +#define SDRC_R_B_C 1 + +/* + * FLASH and environment organization + */ + +#define PISMO1_ONEN_SIZE GPMC_SIZE_128M /* Configure the PISMO */ + +#define CONFIG_SYS_ONENAND_BASE ONENAND_MAP + +#define ONENAND_ENV_OFFSET 0x260000 /* environment starts here */ + +#define CONFIG_ENV_IS_IN_ONENAND 1 +#define CONFIG_ENV_SIZE (512 << 10) /* Total Size Environment */ +#define CONFIG_ENV_ADDR ONENAND_ENV_OFFSET + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (128 << 10)) +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes for initial data */ + +/* + * SMSC911x Ethernet + */ +#if defined(CONFIG_CMD_NET) +#define CONFIG_NET_MULTI +#define CONFIG_SMC911X +#define CONFIG_SMC911X_32_BIT +#define CONFIG_SMC911X_BASE 0x2C000000 +#endif /* (CONFIG_CMD_NET) */ + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR (LOW_LEVEL_SRAM_STACK - CONFIG_SYS_GBL_DATA_SIZE) + +#endif /* __CONFIG_H */
Entry to MAINTAINERS missing.
Enric Balletbò i Serra
