[U-Boot] [PATCH] at91sam9260ek: move board id setup to config header
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com Cc: Bo Shen voice.shen@atmel.com --- board/atmel/at91sam9260ek/at91sam9260ek.c | 12 ------------ include/configs/at91sam9260ek.h | 20 ++++++++++++++++++++ 2 files changed, 20 insertions(+), 12 deletions(-)
diff --git a/board/atmel/at91sam9260ek/at91sam9260ek.c b/board/atmel/at91sam9260ek/at91sam9260ek.c index 3aa394a..049b3d7 100644 --- a/board/atmel/at91sam9260ek/at91sam9260ek.c +++ b/board/atmel/at91sam9260ek/at91sam9260ek.c @@ -157,18 +157,6 @@ int board_early_init_f(void)
int board_init(void) { -#ifdef CONFIG_AT91SAM9G20EK_2MMC - /* arch number of AT91SAM9G20EK_2MMC-Board */ - gd->bd->bi_arch_number = MACH_TYPE_AT91SAM9G20EK_2MMC; -#else -#ifdef CONFIG_AT91SAM9G20EK - /* arch number of AT91SAM9G20EK-Board */ - gd->bd->bi_arch_number = MACH_TYPE_AT91SAM9G20EK; -#else - /* arch number of AT91SAM9260EK-Board */ - gd->bd->bi_arch_number = MACH_TYPE_AT91SAM9260EK; -#endif -#endif /* adress of boot parameters */ gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index 02696b3..2d2efb2 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -125,6 +125,26 @@ (ATMEL_BASE_SRAM1 + 0x1000 - GENERATED_GBL_DATA_SIZE) #endif
+/* + * The (arm)linux board id set by generic code depending on configured board + * (see boards.cfg for different boards) + */ +#ifdef CONFIG_AT91SAM9G20 + /* the sam9g20 variants have two different board ids */ +# ifdef CONFIG_AT91SAM9G20EK_2MMC + /* we may be setup for the 2MMC variant of at91sam9g20ek */ +# define CONFIG_MACH_TYPE MACH_TYPE_AT91SAM9G20EK_2MMC +# else +# ifdef CONFIG_AT91SAM9G20EK + /* or the normal at91sam9g20ek */ +# define CONFIG_MACH_TYPE MACH_TYPE_AT91SAM9G20EK +# endif +# endif +#else + /* otherwise default to good old at91sam9260ek */ +# define CONFIG_MACH_TYPE MACH_TYPE_AT91SAM9260EK +#endif + /* DataFlash */ #ifndef CONFIG_AT91SAM9G20EK_2MMC #define CONFIG_ATMEL_DATAFLASH_SPI
Acked-by: Bo Shen voice.shen@atmel.com
-#else
- The (arm)linux board id set by generic code depending on configured board
- (see boards.cfg for different boards)
- /* the sam9g20 variants have two different board ids */
- /* we may be setup for the 2MMC variant of at91sam9g20ek */
- /* or the normal at91sam9g20ek */
- /* otherwise default to good old at91sam9260ek */
- /* DataFlash */ #ifndef CONFIG_AT91SAM9G20EK_2MMC #define CONFIG_ATMEL_DATAFLASH_SPI
Hi Bo,
<snip>
configured board
I think I'll generate a v2 here. It is safer to have:
#ifdef AT91SAM9G20 #ifdef 2MMC // 2MMC #else // default for SAM9G20 #endif #else // default for SAM9260 #endif
Best regards
Andreas Bießmann
Hi Andreas,
On 3/14/2013 16:44, Andreas Bießmann wrote:
Hi Bo,
<snip>
configured board
I agree.
Best regards
Andreas Bießmann
Best Regards, Bo Shen
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com Acked-by: Bo Shen voice.shen@atmel.com --- Changes in v2: * use only one ifdef for sam9G variants
board/atmel/at91sam9260ek/at91sam9260ek.c | 12 ------------ include/configs/at91sam9260ek.h | 18 ++++++++++++++++++ 2 files changed, 18 insertions(+), 12 deletions(-)
diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index ebcc69a..39a8fc2 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -128,6 +128,24 @@ (ATMEL_BASE_SRAM1 + 0x1000 - GENERATED_GBL_DATA_SIZE) #endif
+/* + * The (arm)linux board id set by generic code depending on configured board + * (see boards.cfg for different boards) + */ +#ifdef CONFIG_AT91SAM9G20 + /* the sam9g20 variants have two different board ids */ +# ifdef CONFIG_AT91SAM9G20EK_2MMC + /* we may be setup for the 2MMC variant of at91sam9g20ek */ +# define CONFIG_MACH_TYPE MACH_TYPE_AT91SAM9G20EK_2MMC +# else + /* or the normal at91sam9g20ek */ +# define CONFIG_MACH_TYPE MACH_TYPE_AT91SAM9G20EK +# endif +#else + /* otherwise default to good old at91sam9260ek */ +# define CONFIG_MACH_TYPE MACH_TYPE_AT91SAM9260EK +#endif + /* DataFlash */ #ifndef CONFIG_AT91SAM9G20EK_2MMC #define CONFIG_ATMEL_DATAFLASH_SPI
Andreas Bießmann
Bo Shen
