[U-Boot] [PATCH 3/3] omap2: i2c: remove redundant header definitions
Remove the register offset and common defines which are already present in drivers/i2c/omap24xx.h. All of these defines carry the same value even.
Cc: Steve Sakoman steve@sakoman.com Cc: Heiko hs@denx.de Cc: Sandeep Paulraj s-paulraj@ti.com Cc: Wolfang Denk wd@denx.de
Signed-off-by: Nishanth Menon nm@ti.com --- arch/arm/include/asm/arch-omap24xx/i2c.h | 106 ------------------------------ 1 files changed, 0 insertions(+), 106 deletions(-)
diff --git a/arch/arm/include/asm/arch-omap24xx/i2c.h b/arch/arm/include/asm/arch-omap24xx/i2c.h index 418a432..6f64519 100644 --- a/arch/arm/include/asm/arch-omap24xx/i2c.h +++ b/arch/arm/include/asm/arch-omap24xx/i2c.h @@ -65,110 +65,4 @@ struct i2c {
#define I2C_BUS_MAX 2
-/* I2C masks */ - -/* I2C Interrupt Enable Register (I2C_IE): */ -#define I2C_IE_GC_IE (1 << 5) -#define I2C_IE_XRDY_IE (1 << 4) /* Transmit data ready interrupt enable */ -#define I2C_IE_RRDY_IE (1 << 3) /* Receive data ready interrupt enable */ -#define I2C_IE_ARDY_IE (1 << 2) /* Register access ready interrupt enable */ -#define I2C_IE_NACK_IE (1 << 1) /* No acknowledgment interrupt enable */ -#define I2C_IE_AL_IE (1 << 0) /* Arbitration lost interrupt enable */ - -/* I2C Status Register (I2C_STAT): */ - -#define I2C_STAT_SBD (1 << 15) /* Single byte data */ -#define I2C_STAT_BB (1 << 12) /* Bus busy */ -#define I2C_STAT_ROVR (1 << 11) /* Receive overrun */ -#define I2C_STAT_XUDF (1 << 10) /* Transmit underflow */ -#define I2C_STAT_AAS (1 << 9) /* Address as slave */ -#define I2C_STAT_GC (1 << 5) -#define I2C_STAT_XRDY (1 << 4) /* Transmit data ready */ -#define I2C_STAT_RRDY (1 << 3) /* Receive data ready */ -#define I2C_STAT_ARDY (1 << 2) /* Register access ready */ -#define I2C_STAT_NACK (1 << 1) /* No acknowledgment interrupt enable */ -#define I2C_STAT_AL (1 << 0) /* Arbitration lost interrupt enable */ - - -/* I2C Interrupt Code Register (I2C_INTCODE): */ - -#define I2C_INTCODE_MASK 7 -#define I2C_INTCODE_NONE 0 -#define I2C_INTCODE_AL 1 /* Arbitration lost */ -#define I2C_INTCODE_NAK 2 /* No acknowledgement/general call */ -#define I2C_INTCODE_ARDY 3 /* Register access ready */ -#define I2C_INTCODE_RRDY 4 /* Rcv data ready */ -#define I2C_INTCODE_XRDY 5 /* Xmit data ready */ - -/* I2C Buffer Configuration Register (I2C_BUF): */ - -#define I2C_BUF_RDMA_EN (1 << 15) /* Receive DMA channel enable */ -#define I2C_BUF_XDMA_EN (1 << 7) /* Transmit DMA channel enable */ - -/* I2C Configuration Register (I2C_CON): */ - -#define I2C_CON_EN (1 << 15) /* I2C module enable */ -#define I2C_CON_BE (1 << 14) /* Big endian mode */ -#define I2C_CON_STB (1 << 11) /* Start byte mode (master mode only) */ -#define I2C_CON_MST (1 << 10) /* Master/slave mode */ -#define I2C_CON_TRX (1 << 9) /* Transmitter/receiver mode (master mode only) */ -#define I2C_CON_XA (1 << 8) /* Expand address */ -#define I2C_CON_STP (1 << 1) /* Stop condition (master mode only) */ -#define I2C_CON_STT (1 << 0) /* Start condition (master mode only) */ - -/* I2C System Test Register (I2C_SYSTEST): */ - -#define I2C_SYSTEST_ST_EN (1 << 15) /* System test enable */ -#define I2C_SYSTEST_FREE (1 << 14) /* Free running mode (on breakpoint) */ -#define I2C_SYSTEST_TMODE_MASK (3 << 12) /* Test mode select */ -#define I2C_SYSTEST_TMODE_SHIFT (12) /* Test mode select */ -#define I2C_SYSTEST_SCL_I (1 << 3) /* SCL line sense input value */ -#define I2C_SYSTEST_SCL_O (1 << 2) /* SCL line drive output value */ -#define I2C_SYSTEST_SDA_I (1 << 1) /* SDA line sense input value */ -#define I2C_SYSTEST_SDA_O (1 << 0) /* SDA line drive output value */ - -/* These values were copied from omap3, include/asm-arm/arch-omap3/i2c.h. */ -#define OMAP_I2C_STANDARD 100000 -#define OMAP_I2C_FAST_MODE 400000 -#define OMAP_I2C_HIGH_SPEED 3400000 - -#define SYSTEM_CLOCK_12 12000000 -#define SYSTEM_CLOCK_13 13000000 -#define SYSTEM_CLOCK_192 19200000 -#define SYSTEM_CLOCK_96 96000000 - -#ifndef I2C_IP_CLK -#define I2C_IP_CLK SYSTEM_CLOCK_96 -#endif - -#ifndef I2C_INTERNAL_SAMPLING_CLK -#define I2C_INTERNAL_SAMPLING_CLK 19200000 -#endif - -/* These are the trim values for standard and fast speed */ -#ifndef I2C_FASTSPEED_SCLL_TRIM -#define I2C_FASTSPEED_SCLL_TRIM 6 -#endif -#ifndef I2C_FASTSPEED_SCLH_TRIM -#define I2C_FASTSPEED_SCLH_TRIM 6 -#endif - -/* These are the trim values for high speed */ -#ifndef I2C_HIGHSPEED_PHASE_ONE_SCLL_TRIM -#define I2C_HIGHSPEED_PHASE_ONE_SCLL_TRIM I2C_FASTSPEED_SCLL_TRIM -#endif -#ifndef I2C_HIGHSPEED_PHASE_ONE_SCLH_TRIM -#define I2C_HIGHSPEED_PHASE_ONE_SCLH_TRIM I2C_FASTSPEED_SCLH_TRIM -#endif -#ifndef I2C_HIGHSPEED_PHASE_TWO_SCLL_TRIM -#define I2C_HIGHSPEED_PHASE_TWO_SCLL_TRIM I2C_FASTSPEED_SCLL_TRIM -#endif -#ifndef I2C_HIGHSPEED_PHASE_TWO_SCLH_TRIM -#define I2C_HIGHSPEED_PHASE_TWO_SCLH_TRIM I2C_FASTSPEED_SCLH_TRIM -#endif - -#define I2C_PSC_MAX 0x0f -#define I2C_PSC_MIN 0x00 - - #endif
Acked-by: Steve Sakoman steve@sakoman.com
Steve
-/* I2C masks */
#endif
Nishanth Menon
Steve Sakoman
