[U-Boot] [Patch V5 0/4] add mips64 cpus support
This patch add mips64 cpu support. In this version, I have tested it both when configured running in ram version and running in rom version.
qemu-system-mips64 -M mips -cpu MIPS64R2-generic -bios u-boot.bin -nographic
U-Boot 2012.07-00146-g42c7773 (Sep 04 2012 - 21:56:46)
Board: Qemu -M mips CPU: unknown proc_id=0x10000 DRAM: 128 MiB Using default environment
In: serial Out: serial Err: serial Net: NE2000 qemu-mips64 #
Changes in V5: - omit camel-case style - avoid running "git bisect" failed - some code style problem corrected Changes in V4: - Add both big-endian and little-endian support - Remove cache probe - Add standalone support for mips64 Changes in V3: - merge related files into one patch, no longer one file one patch. - add detailed commit message. - remove standalone example. it's too complicate.
Zhizhou Zhang (4): MIPS: Don't use camel-case style MIPS: change address related header files MIPS: don't define CONFIG_SYS_TEXT_BASE in config.mk MIPS: add board qemu-mips64 support
arch/mips/cpu/mips32/cache.S | 10 +- arch/mips/cpu/mips32/cpu.c | 8 +- arch/mips/cpu/mips64/Makefile | 45 ++++++ arch/mips/cpu/mips64/cache.S | 229 +++++++++++++++++++++++++++++++ arch/mips/cpu/mips64/config.mk | 40 ++++++ arch/mips/cpu/mips64/cpu.c | 111 +++++++++++++++ arch/mips/cpu/mips64/interrupts.c | 34 +++++ arch/mips/cpu/mips64/start.S | 256 +++++++++++++++++++++++++++++++++++ arch/mips/cpu/mips64/time.c | 87 ++++++++++++ arch/mips/cpu/xburst/cpu.c | 12 +- arch/mips/cpu/xburst/start.S | 4 +- arch/mips/include/asm/addrspace.h | 2 +- arch/mips/include/asm/asm.h | 2 +- arch/mips/include/asm/cacheops.h | 82 +++++------ arch/mips/include/asm/io.h | 16 +++ arch/mips/include/asm/posix_types.h | 6 + board/qemu-mips/config.mk | 10 -- board/qemu-mips/u-boot.lds | 8 ++ boards.cfg | 2 + examples/standalone/mips64.lds | 59 ++++++++ include/configs/qemu-mips.h | 1 + include/configs/qemu-mips64.h | 171 +++++++++++++++++++++++ 22 files changed, 1125 insertions(+), 70 deletions(-) create mode 100644 arch/mips/cpu/mips64/Makefile create mode 100644 arch/mips/cpu/mips64/cache.S create mode 100644 arch/mips/cpu/mips64/config.mk create mode 100644 arch/mips/cpu/mips64/cpu.c create mode 100644 arch/mips/cpu/mips64/interrupts.c create mode 100644 arch/mips/cpu/mips64/start.S create mode 100644 arch/mips/cpu/mips64/time.c delete mode 100644 board/qemu-mips/config.mk create mode 100644 examples/standalone/mips64.lds create mode 100644 include/configs/qemu-mips64.h
Replace camel-case style with upper-case style globally.
Signed-off-by: Zhizhou Zhang etou.zh@gmail.com --- arch/mips/cpu/mips32/cache.S | 10 ++--- arch/mips/cpu/mips32/cpu.c | 8 ++-- arch/mips/cpu/xburst/cpu.c | 12 +++--- arch/mips/cpu/xburst/start.S | 4 +- arch/mips/include/asm/cacheops.h | 82 +++++++++++++++++++------------------- 5 files changed, 58 insertions(+), 58 deletions(-)
diff --git a/arch/mips/cpu/mips32/cache.S b/arch/mips/cpu/mips32/cache.S index e683e8b..64dfad0 100644 --- a/arch/mips/cpu/mips32/cache.S +++ b/arch/mips/cpu/mips32/cache.S @@ -85,17 +85,17 @@ LEAF(mips_init_icache) /* clear tag to invalidate */ PTR_LI t0, INDEX_BASE PTR_ADDU t1, t0, a1 -1: cache_op Index_Store_Tag_I t0 +1: cache_op INDEX_STORE_TAG_I t0 PTR_ADDU t0, a2 bne t0, t1, 1b /* fill once, so data field parity is correct */ PTR_LI t0, INDEX_BASE -2: cache_op Fill t0 +2: cache_op FILL t0 PTR_ADDU t0, a2 bne t0, t1, 2b /* invalidate again - prudent but not strictly neccessary */ PTR_LI t0, INDEX_BASE -1: cache_op Index_Store_Tag_I t0 +1: cache_op INDEX_STORE_TAG_I t0 PTR_ADDU t0, a2 bne t0, t1, 1b 9: jr ra @@ -110,7 +110,7 @@ LEAF(mips_init_dcache) /* clear all tags */ PTR_LI t0, INDEX_BASE PTR_ADDU t1, t0, a1 -1: cache_op Index_Store_Tag_D t0 +1: cache_op INDEX_STORE_TAG_D t0 PTR_ADDU t0, a2 bne t0, t1, 1b /* load from each line (in cached space) */ @@ -120,7 +120,7 @@ LEAF(mips_init_dcache) bne t0, t1, 2b /* clear all tags */ PTR_LI t0, INDEX_BASE -1: cache_op Index_Store_Tag_D t0 +1: cache_op INDEX_STORE_TAG_D t0 PTR_ADDU t0, a2 bne t0, t1, 1b 9: jr ra diff --git a/arch/mips/cpu/mips32/cpu.c b/arch/mips/cpu/mips32/cpu.c index 7b49e1b..50bb248 100644 --- a/arch/mips/cpu/mips32/cpu.c +++ b/arch/mips/cpu/mips32/cpu.c @@ -61,8 +61,8 @@ void flush_cache(ulong start_addr, ulong size) return;
while (1) { - cache_op(Hit_Writeback_Inv_D, addr); - cache_op(Hit_Invalidate_I, addr); + cache_op(HIT_WRITEBACK_INV_D, addr); + cache_op(HIT_INVALIDATE_I, addr); if (addr == aend) break; addr += lsize; @@ -76,7 +76,7 @@ void flush_dcache_range(ulong start_addr, ulong stop) unsigned long aend = (stop - 1) & ~(lsize - 1);
while (1) { - cache_op(Hit_Writeback_Inv_D, addr); + cache_op(HIT_WRITEBACK_INV_D, addr); if (addr == aend) break; addr += lsize; @@ -90,7 +90,7 @@ void invalidate_dcache_range(ulong start_addr, ulong stop) unsigned long aend = (stop - 1) & ~(lsize - 1);
while (1) { - cache_op(Hit_Invalidate_D, addr); + cache_op(HIT_INVALIDATE_D, addr); if (addr == aend) break; addr += lsize; diff --git a/arch/mips/cpu/xburst/cpu.c b/arch/mips/cpu/xburst/cpu.c index ddcbfaa..cc190df 100644 --- a/arch/mips/cpu/xburst/cpu.c +++ b/arch/mips/cpu/xburst/cpu.c @@ -84,8 +84,8 @@ void flush_cache(ulong start_addr, ulong size) unsigned long aend = (start_addr + size - 1) & ~(lsize - 1);
for (; addr <= aend; addr += lsize) { - cache_op(Hit_Writeback_Inv_D, addr); - cache_op(Hit_Invalidate_I, addr); + cache_op(HIT_WRITEBACK_INV_D, addr); + cache_op(HIT_INVALIDATE_I, addr); } }
@@ -96,7 +96,7 @@ void flush_dcache_range(ulong start_addr, ulong stop) unsigned long aend = (stop - 1) & ~(lsize - 1);
for (; addr <= aend; addr += lsize) - cache_op(Hit_Writeback_Inv_D, addr); + cache_op(HIT_WRITEBACK_INV_D, addr); }
void invalidate_dcache_range(ulong start_addr, ulong stop) @@ -106,7 +106,7 @@ void invalidate_dcache_range(ulong start_addr, ulong stop) unsigned long aend = (stop - 1) & ~(lsize - 1);
for (; addr <= aend; addr += lsize) - cache_op(Hit_Invalidate_D, addr); + cache_op(HIT_INVALIDATE_D, addr); }
void flush_icache_all(void) @@ -118,7 +118,7 @@ void flush_icache_all(void)
for (addr = CKSEG0; addr < CKSEG0 + CONFIG_SYS_ICACHE_SIZE; addr += CONFIG_SYS_CACHELINE_SIZE) { - cache_op(Index_Store_Tag_I, addr); + cache_op(INDEX_STORE_TAG_I, addr); }
/* invalidate btb */ @@ -139,7 +139,7 @@ void flush_dcache_all(void)
for (addr = CKSEG0; addr < CKSEG0 + CONFIG_SYS_DCACHE_SIZE; addr += CONFIG_SYS_CACHELINE_SIZE) { - cache_op(Index_Writeback_Inv_D, addr); + cache_op(INDEX_WRITEBACK_INV_D, addr); }
__asm__ __volatile__("sync"); diff --git a/arch/mips/cpu/xburst/start.S b/arch/mips/cpu/xburst/start.S index d846104..3a8280c 100644 --- a/arch/mips/cpu/xburst/start.S +++ b/arch/mips/cpu/xburst/start.S @@ -96,7 +96,7 @@ relocate_code: li t0, KSEG0 addi t1, t0, CONFIG_SYS_DCACHE_SIZE 2: - cache Index_Writeback_Inv_D, 0(t0) + cache INDEX_WRITEBACK_INV_D, 0(t0) bne t0, t1, 2b addi t0, CONFIG_SYS_CACHELINE_SIZE
@@ -106,7 +106,7 @@ relocate_code: li t0, KSEG0 addi t1, t0, CONFIG_SYS_ICACHE_SIZE 3: - cache Index_Invalidate_I, 0(t0) + cache INDEX_INVALIDATE_I, 0(t0) bne t0, t1, 3b addi t0, CONFIG_SYS_CACHELINE_SIZE
diff --git a/arch/mips/include/asm/cacheops.h b/arch/mips/include/asm/cacheops.h index 70bcad7..6464250 100644 --- a/arch/mips/include/asm/cacheops.h +++ b/arch/mips/include/asm/cacheops.h @@ -14,54 +14,54 @@ /* * Cache Operations available on all MIPS processors with R4000-style caches */ -#define Index_Invalidate_I 0x00 -#define Index_Writeback_Inv_D 0x01 -#define Index_Load_Tag_I 0x04 -#define Index_Load_Tag_D 0x05 -#define Index_Store_Tag_I 0x08 -#define Index_Store_Tag_D 0x09 +#define INDEX_INVALIDATE_I 0x00 +#define INDEX_WRITEBACK_INV_D 0x01 +#define INDEX_LOAD_TAG_I 0x04 +#define INDEX_LOAD_TAG_D 0x05 +#define INDEX_STORE_TAG_I 0x08 +#define INDEX_STORE_TAG_D 0x09 #if defined(CONFIG_CPU_LOONGSON2) -#define Hit_Invalidate_I 0x00 +#define HIT_INVALIDATE_I 0x00 #else -#define Hit_Invalidate_I 0x10 +#define HIT_INVALIDATE_I 0x10 #endif -#define Hit_Invalidate_D 0x11 -#define Hit_Writeback_Inv_D 0x15 +#define HIT_INVALIDATE_D 0x11 +#define HIT_WRITEBACK_INV_D 0x15
/* * R4000-specific cacheops */ -#define Create_Dirty_Excl_D 0x0d -#define Fill 0x14 -#define Hit_Writeback_I 0x18 -#define Hit_Writeback_D 0x19 +#define CREATE_DIRTY_EXCL_D 0x0d +#define FILL 0x14 +#define HIT_WRITEBACK_I 0x18 +#define HIT_WRITEBACK_D 0x19
/* * R4000SC and R4400SC-specific cacheops */ -#define Index_Invalidate_SI 0x02 -#define Index_Writeback_Inv_SD 0x03 -#define Index_Load_Tag_SI 0x06 -#define Index_Load_Tag_SD 0x07 -#define Index_Store_Tag_SI 0x0A -#define Index_Store_Tag_SD 0x0B -#define Create_Dirty_Excl_SD 0x0f -#define Hit_Invalidate_SI 0x12 -#define Hit_Invalidate_SD 0x13 -#define Hit_Writeback_Inv_SD 0x17 -#define Hit_Writeback_SD 0x1b -#define Hit_Set_Virtual_SI 0x1e -#define Hit_Set_Virtual_SD 0x1f +#define INDEX_INVALIDATE_SI 0x02 +#define INDEX_WRITEBACK_INV_SD 0x03 +#define INDEX_LOAD_TAG_SI 0x06 +#define INDEX_LOAD_TAG_SD 0x07 +#define INDEX_STORE_TAG_SI 0x0A +#define INDEX_STORE_TAG_SD 0x0B +#define CREATE_DIRTY_EXCL_SD 0x0f +#define HIT_INVALIDATE_SI 0x12 +#define HIT_INVALIDATE_SD 0x13 +#define HIT_WRITEBACK_INV_SD 0x17 +#define HIT_WRITEBACK_SD 0x1b +#define HIT_SET_VIRTUAL_SI 0x1e +#define HIT_SET_VIRTUAL_SD 0x1f
/* * R5000-specific cacheops */ -#define R5K_Page_Invalidate_S 0x17 +#define R5K_PAGE_INVALIDATE_S 0x17
/* * RM7000-specific cacheops */ -#define Page_Invalidate_T 0x16 +#define PAGE_INVALIDATE_T 0x16
/* * R10000-specific cacheops @@ -69,17 +69,17 @@ * Cacheops 0x02, 0x06, 0x0a, 0x0c-0x0e, 0x16, 0x1a and 0x1e are unused. * Most of the _S cacheops are identical to the R4000SC _SD cacheops. */ -#define Index_Writeback_Inv_S 0x03 -#define Index_Load_Tag_S 0x07 -#define Index_Store_Tag_S 0x0B -#define Hit_Invalidate_S 0x13 -#define Cache_Barrier 0x14 -#define Hit_Writeback_Inv_S 0x17 -#define Index_Load_Data_I 0x18 -#define Index_Load_Data_D 0x19 -#define Index_Load_Data_S 0x1b -#define Index_Store_Data_I 0x1c -#define Index_Store_Data_D 0x1d -#define Index_Store_Data_S 0x1f +#define INDEX_WRITEBACK_INV_S 0x03 +#define INDEX_LOAD_TAG_S 0x07 +#define INDEX_STORE_TAG_S 0x0B +#define HIT_INVALIDATE_S 0x13 +#define CACHE_BARRIER 0x14 +#define HIT_WRITEBACK_INV_S 0x17 +#define INDEX_LOAD_DATA_I 0x18 +#define INDEX_LOAD_DATA_D 0x19 +#define INDEX_LOAD_DATA_S 0x1b +#define INDEX_STORE_DATA_I 0x1c +#define INDEX_STORE_DATA_D 0x1d +#define INDEX_STORE_DATA_S 0x1f
#endif /* __ASM_CACHEOPS_H */
Prepare for upcoming mips64 support. This patch add mips64 address space support.
Signed-off-by: Zhizhou Zhang etou.zh@gmail.com --- arch/mips/include/asm/addrspace.h | 2 +- arch/mips/include/asm/asm.h | 2 +- arch/mips/include/asm/io.h | 16 ++++++++++++++++ arch/mips/include/asm/posix_types.h | 6 ++++++ 4 files changed, 24 insertions(+), 2 deletions(-)
diff --git a/arch/mips/include/asm/addrspace.h b/arch/mips/include/asm/addrspace.h index 3a1e6d6..b768bb5 100644 --- a/arch/mips/include/asm/addrspace.h +++ b/arch/mips/include/asm/addrspace.h @@ -136,7 +136,7 @@ cannot access physical memory directly from core */ #define UNCACHED_SDRAM(a) (((unsigned long)(a)) | 0x20000000) #else /* !CONFIG_SOC_AU1X00 */ -#define UNCACHED_SDRAM(a) KSEG1ADDR(a) +#define UNCACHED_SDRAM(a) CKSEG1ADDR(a) #endif /* CONFIG_SOC_AU1X00 */ #endif /* __ASSEMBLY__ */
diff --git a/arch/mips/include/asm/asm.h b/arch/mips/include/asm/asm.h index 608cfcf..933ccb1 100644 --- a/arch/mips/include/asm/asm.h +++ b/arch/mips/include/asm/asm.h @@ -401,7 +401,7 @@ symbol = value #ifdef CONFIG_SGI_IP28 /* Inhibit speculative stores to volatile (e.g.DMA) or invalid addresses. */ #include <asm/cacheops.h> -#define R10KCBARRIER(addr) cache Cache_Barrier, addr; +#define R10KCBARRIER(addr) cache CACHE_BARRIER, addr; #else #define R10KCBARRIER(addr) #endif diff --git a/arch/mips/include/asm/io.h b/arch/mips/include/asm/io.h index 025012a..80eab75 100644 --- a/arch/mips/include/asm/io.h +++ b/arch/mips/include/asm/io.h @@ -120,12 +120,20 @@ static inline void set_io_port_base(unsigned long base) */ extern inline phys_addr_t virt_to_phys(volatile void * address) { +#ifndef CONFIG_64BIT return CPHYSADDR(address); +#else + return XPHYSADDR(address); +#endif }
extern inline void * phys_to_virt(unsigned long address) { +#ifndef CONFIG_64BIT return (void *)KSEG0ADDR(address); +#else + return (void *)CKSEG0ADDR(address); +#endif }
/* @@ -133,12 +141,20 @@ extern inline void * phys_to_virt(unsigned long address) */ extern inline unsigned long virt_to_bus(volatile void * address) { +#ifndef CONFIG_64BIT return CPHYSADDR(address); +#else + return XPHYSADDR(address); +#endif }
extern inline void * bus_to_virt(unsigned long address) { +#ifndef CONFIG_64BIT return (void *)KSEG0ADDR(address); +#else + return (void *)CKSEG0ADDR(address); +#endif }
/* diff --git a/arch/mips/include/asm/posix_types.h b/arch/mips/include/asm/posix_types.h index 879aae2..6566ad0 100644 --- a/arch/mips/include/asm/posix_types.h +++ b/arch/mips/include/asm/posix_types.h @@ -24,9 +24,15 @@ typedef int __kernel_pid_t; typedef int __kernel_ipc_pid_t; typedef int __kernel_uid_t; typedef int __kernel_gid_t; +#ifndef CONFIG_MIPS64 typedef unsigned int __kernel_size_t; typedef int __kernel_ssize_t; typedef int __kernel_ptrdiff_t; +#else +typedef unsigned long __kernel_size_t; +typedef long __kernel_ssize_t; +typedef long __kernel_ptrdiff_t; +#endif typedef long __kernel_time_t; typedef long __kernel_suseconds_t; typedef long __kernel_clock_t;
2012/9/4 Zhizhou Zhang etou.zh@gmail.com:
this change is unrelated to this patch. I guess this belongs to patch 1/4
+#endif }
+#endif }
+#endif }
+#endif }
/* diff --git a/arch/mips/include/asm/posix_types.h b/arch/mips/include/asm/posix_types.h index 879aae2..6566ad0 100644 --- a/arch/mips/include/asm/posix_types.h +++ b/arch/mips/include/asm/posix_types.h @@ -24,9 +24,15 @@ typedef int __kernel_pid_t; typedef int __kernel_ipc_pid_t; typedef int __kernel_uid_t; typedef int __kernel_gid_t; +#ifndef CONFIG_MIPS64 typedef unsigned int __kernel_size_t; typedef int __kernel_ssize_t; typedef int __kernel_ptrdiff_t; +#else +typedef unsigned long __kernel_size_t; +typedef long __kernel_ssize_t; +typedef long __kernel_ptrdiff_t; +#endif typedef long __kernel_time_t; typedef long __kernel_suseconds_t; typedef long __kernel_clock_t; -- 1.7.9.5
On Wed, Sep 5, 2012 at 6:25 AM, Daniel Schwierzeck < daniel.schwierzeck@gmail.com> wrote:
addresses. */
I'm so careless! Then what should I do now? need I resend these once
again? I think that's not good..
base)
+#endif }
+#endif }
address)
+#endif }
+#endif }
-- Best regards, Daniel
We define CONFIG_SYS_TEXT_BASE in board's specified header file. So config.mk is useless, then remove it.
Signed-off-by: Zhizhou Zhang etou.zh@gmail.com --- board/qemu-mips/config.mk | 10 ---------- include/configs/qemu-mips.h | 1 + 2 files changed, 1 insertion(+), 10 deletions(-) delete mode 100644 board/qemu-mips/config.mk
diff --git a/board/qemu-mips/config.mk b/board/qemu-mips/config.mk deleted file mode 100644 index 27cd34a..0000000 --- a/board/qemu-mips/config.mk +++ /dev/null @@ -1,10 +0,0 @@ -# -# Qemu -M mips system emulator -# See http://fabrice.bellard.free.fr/qemu -# - -# ROM version -CONFIG_SYS_TEXT_BASE = 0xbfc00000 - -# RAM version -#CONFIG_SYS_TEXT_BASE = 0x80001000 diff --git a/include/configs/qemu-mips.h b/include/configs/qemu-mips.h index b8b9705..f45f78b 100644 --- a/include/configs/qemu-mips.h +++ b/include/configs/qemu-mips.h @@ -137,6 +137,7 @@ */
/* The following #defines are needed to get flash environment right */ +#define CONFIG_SYS_TEXT_BASE 0xbfc00000 /* Rom version */ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_MONITOR_LEN (192 << 10)
Both big-endian and little-endian are tested with below commands: Rom version: (Default, Now we config it as rom version) qemu-system-mips64el -M mips -bios u-boot.bin -cpu MIPS64R2-generic -nographic qemu-system-mips64 -M mips -bios u-boot.bin -cpu MIPS64R2-generic -nographic Ram version: qemu-system-mips64el -M mips -cpu MIPS64R2-generic -kernel u-boot -nographic qemu-system-mips64 -M mips -cpu MIPS64R2-generic -kernel u-boot -nographic
Signed-off-by: Zhizhou Zhang etou.zh@gmail.com --- arch/mips/cpu/mips64/Makefile | 45 +++++++ arch/mips/cpu/mips64/cache.S | 229 +++++++++++++++++++++++++++++++++ arch/mips/cpu/mips64/config.mk | 40 ++++++ arch/mips/cpu/mips64/cpu.c | 111 ++++++++++++++++ arch/mips/cpu/mips64/interrupts.c | 34 +++++ arch/mips/cpu/mips64/start.S | 256 +++++++++++++++++++++++++++++++++++++ arch/mips/cpu/mips64/time.c | 87 +++++++++++++ board/qemu-mips/u-boot.lds | 8 ++ boards.cfg | 2 + examples/standalone/mips64.lds | 59 +++++++++ include/configs/qemu-mips64.h | 171 +++++++++++++++++++++++++ 11 files changed, 1042 insertions(+) create mode 100644 arch/mips/cpu/mips64/Makefile create mode 100644 arch/mips/cpu/mips64/cache.S create mode 100644 arch/mips/cpu/mips64/config.mk create mode 100644 arch/mips/cpu/mips64/cpu.c create mode 100644 arch/mips/cpu/mips64/interrupts.c create mode 100644 arch/mips/cpu/mips64/start.S create mode 100644 arch/mips/cpu/mips64/time.c create mode 100644 examples/standalone/mips64.lds create mode 100644 include/configs/qemu-mips64.h
diff --git a/arch/mips/cpu/mips64/Makefile b/arch/mips/cpu/mips64/Makefile new file mode 100644 index 0000000..be38664 --- /dev/null +++ b/arch/mips/cpu/mips64/Makefile @@ -0,0 +1,45 @@ +# +# (C) Copyright 2003-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(CPU).o + +START = start.o +COBJS-y = cpu.o interrupts.o time.o cache.o + +SRCS := $(START:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) +START := $(addprefix $(obj),$(START)) + +all: $(obj).depend $(START) $(LIB) + +$(LIB): $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend diff --git a/arch/mips/cpu/mips64/cache.S b/arch/mips/cpu/mips64/cache.S new file mode 100644 index 0000000..036f035 --- /dev/null +++ b/arch/mips/cpu/mips64/cache.S @@ -0,0 +1,229 @@ +/* + * Cache-handling routined for MIPS CPUs + * + * Copyright (c) 2003 Wolfgang Denk wd@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <asm-offsets.h> +#include <config.h> +#include <asm/asm.h> +#include <asm/regdef.h> +#include <asm/mipsregs.h> +#include <asm/addrspace.h> +#include <asm/cacheops.h> + +#define RA t9 + +/* + * 16kB is the maximum size of instruction and data caches on MIPS 4K, + * 64kB is on 4KE, 24K, 5K, etc. Set bigger size for convenience. + * + * Note that the above size is the maximum size of primary cache. U-Boot + * doesn't have L2 cache support for now. + */ +#define MIPS_MAX_CACHE_SIZE 0x10000 + +#define INDEX_BASE CKSEG0 + + .macro cache_op op addr + .set push + .set noreorder + .set mips3 + cache \op, 0(\addr) + .set pop + .endm + + .macro f_fill64 dst, offset, val + LONG_S \val, (\offset + 0 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 1 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 2 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 3 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 4 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 5 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 6 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 7 * LONGSIZE)(\dst) +#if LONGSIZE == 4 + LONG_S \val, (\offset + 8 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 9 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 10 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 11 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 12 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 13 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 14 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 15 * LONGSIZE)(\dst) +#endif + .endm + +/* + * mips_init_icache(uint PRId, ulong icache_size, unchar icache_linesz) + */ +LEAF(mips_init_icache) + blez a1, 9f + mtc0 zero, CP0_TAGLO + /* clear tag to invalidate */ + PTR_LI t0, INDEX_BASE + PTR_ADDU t1, t0, a1 +1: cache_op INDEX_STORE_TAG_I t0 + PTR_ADDU t0, a2 + bne t0, t1, 1b + /* fill once, so data field parity is correct */ + PTR_LI t0, INDEX_BASE +2: cache_op FILL t0 + PTR_ADDU t0, a2 + bne t0, t1, 2b + /* invalidate again - prudent but not strictly neccessary */ + PTR_LI t0, INDEX_BASE +1: cache_op INDEX_STORE_TAG_I t0 + PTR_ADDU t0, a2 + bne t0, t1, 1b +9: jr ra + END(mips_init_icache) + +/* + * mips_init_dcache(uint PRId, ulong dcache_size, unchar dcache_linesz) + */ +LEAF(mips_init_dcache) + blez a1, 9f + mtc0 zero, CP0_TAGLO + /* clear all tags */ + PTR_LI t0, INDEX_BASE + PTR_ADDU t1, t0, a1 +1: cache_op INDEX_STORE_TAG_D t0 + PTR_ADDU t0, a2 + bne t0, t1, 1b + /* load from each line (in cached space) */ + PTR_LI t0, INDEX_BASE +2: LONG_L zero, 0(t0) + PTR_ADDU t0, a2 + bne t0, t1, 2b + /* clear all tags */ + PTR_LI t0, INDEX_BASE +1: cache_op INDEX_STORE_TAG_D t0 + PTR_ADDU t0, a2 + bne t0, t1, 1b +9: jr ra + END(mips_init_dcache) + +/* + * mips_cache_reset - low level initialisation of the primary caches + * + * This routine initialises the primary caches to ensure that they have good + * parity. It must be called by the ROM before any cached locations are used + * to prevent the possibility of data with bad parity being written to memory. + * + * To initialise the instruction cache it is essential that a source of data + * with good parity is available. This routine will initialise an area of + * memory starting at location zero to be used as a source of parity. + * + * RETURNS: N/A + * + */ +NESTED(mips_cache_reset, 0, ra) + move RA, ra + li t2, CONFIG_SYS_ICACHE_SIZE + li t3, CONFIG_SYS_DCACHE_SIZE + li t8, CONFIG_SYS_CACHELINE_SIZE + + li v0, MIPS_MAX_CACHE_SIZE + + /* + * Now clear that much memory starting from zero. + */ + PTR_LI a0, CKSEG1 + PTR_ADDU a1, a0, v0 +2: PTR_ADDIU a0, 64 + f_fill64 a0, -64, zero + bne a0, a1, 2b + + /* + * The caches are probably in an indeterminate state, + * so we force good parity into them by doing an + * invalidate, load/fill, invalidate for each line. + */ + + /* + * Assume bottom of RAM will generate good parity for the cache. + */ + + /* + * Initialize the I-cache first, + */ + move a1, t2 + move a2, t8 + PTR_LA v1, mips_init_icache + jalr v1 + + /* + * then initialize D-cache. + */ + move a1, t3 + move a2, t8 + PTR_LA v1, mips_init_dcache + jalr v1 + + jr RA + END(mips_cache_reset) + +/* + * dcache_status - get cache status + * + * RETURNS: 0 - cache disabled; 1 - cache enabled + * + */ +LEAF(dcache_status) + mfc0 t0, CP0_CONFIG + li t1, CONF_CM_UNCACHED + andi t0, t0, CONF_CM_CMASK + move v0, zero + beq t0, t1, 2f + li v0, 1 +2: jr ra + END(dcache_status) + +/* + * dcache_disable - disable cache + * + * RETURNS: N/A + * + */ +LEAF(dcache_disable) + mfc0 t0, CP0_CONFIG + li t1, -8 + and t0, t0, t1 + ori t0, t0, CONF_CM_UNCACHED + mtc0 t0, CP0_CONFIG + jr ra + END(dcache_disable) + +/* + * dcache_enable - enable cache + * + * RETURNS: N/A + * + */ +LEAF(dcache_enable) + mfc0 t0, CP0_CONFIG + ori t0, CONF_CM_CMASK + xori t0, CONF_CM_CMASK + ori t0, CONF_CM_CACHABLE_NONCOHERENT + mtc0 t0, CP0_CONFIG + jr ra + END(dcache_enable) diff --git a/arch/mips/cpu/mips64/config.mk b/arch/mips/cpu/mips64/config.mk new file mode 100644 index 0000000..ebc1ceb --- /dev/null +++ b/arch/mips/cpu/mips64/config.mk @@ -0,0 +1,40 @@ +# +# (C) Copyright 2003 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +# +# Default optimization level for MIPS64 +# +# Note: Toolchains with binutils prior to v2.16 +# are no longer supported by U-Boot MIPS tree! +# +MIPSFLAGS = -march=mips64 + +PLATFORM_CPPFLAGS += $(MIPSFLAGS) +PLATFORM_CPPFLAGS += -mabi=64 -DCONFIG_64BIT +ifdef CONFIG_SYS_BIG_ENDIAN +PLATFORM_LDFLAGS += -m elf64btsmip +else +PLATFORM_LDFLAGS += -m elf64ltsmip +endif + +CONFIG_STANDALONE_LOAD_ADDR ?= 0xffffffff80200000 -T mips64.lds diff --git a/arch/mips/cpu/mips64/cpu.c b/arch/mips/cpu/mips64/cpu.c new file mode 100644 index 0000000..2a38d0c --- /dev/null +++ b/arch/mips/cpu/mips64/cpu.c @@ -0,0 +1,111 @@ +/* + * (C) Copyright 2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <netdev.h> +#include <asm/mipsregs.h> +#include <asm/cacheops.h> +#include <asm/reboot.h> + +#define cache_op(op, addr) \ + __asm__ __volatile__( \ + " .set push\n" \ + " .set noreorder\n" \ + " .set mips64\n" \ + " cache %0, %1\n" \ + " .set pop\n" \ + : \ + : "i" (op), "R" (*(unsigned char *)(addr))) + +void __attribute__((weak)) _machine_restart(void) +{ + fprintf(stderr, "*** reset failed ***\n"); + + while (1) + /* NOP */; +} + +int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + _machine_restart(); + + return 0; +} + +void flush_cache(ulong start_addr, ulong size) +{ + unsigned long lsize = CONFIG_SYS_CACHELINE_SIZE; + unsigned long addr = start_addr & ~(lsize - 1); + unsigned long aend = (start_addr + size - 1) & ~(lsize - 1); + + /* aend will be miscalculated when size is zero, so we return here */ + if (size == 0) + return; + + while (1) { + cache_op(HIT_WRITEBACK_INV_D, addr); + cache_op(HIT_INVALIDATE_I, addr); + if (addr == aend) + break; + addr += lsize; + } +} + +void flush_dcache_range(ulong start_addr, ulong stop) +{ + unsigned long lsize = CONFIG_SYS_CACHELINE_SIZE; + unsigned long addr = start_addr & ~(lsize - 1); + unsigned long aend = (stop - 1) & ~(lsize - 1); + + while (1) { + cache_op(HIT_WRITEBACK_INV_D, addr); + if (addr == aend) + break; + addr += lsize; + } +} + +void invalidate_dcache_range(ulong start_addr, ulong stop) +{ + unsigned long lsize = CONFIG_SYS_CACHELINE_SIZE; + unsigned long addr = start_addr & ~(lsize - 1); + unsigned long aend = (stop - 1) & ~(lsize - 1); + + while (1) { + cache_op(HIT_INVALIDATE_D, addr); + if (addr == aend) + break; + addr += lsize; + } +} + +void write_one_tlb(int index, u32 pagemask, u32 hi, u32 low0, u32 low1) +{ + write_c0_entrylo0(low0); + write_c0_pagemask(pagemask); + write_c0_entrylo1(low1); + write_c0_entryhi(hi); + write_c0_index(index); + tlb_write_indexed(); +} diff --git a/arch/mips/cpu/mips64/interrupts.c b/arch/mips/cpu/mips64/interrupts.c new file mode 100644 index 0000000..e4e9aae --- /dev/null +++ b/arch/mips/cpu/mips64/interrupts.c @@ -0,0 +1,34 @@ +/* + * (C) Copyright 2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/mipsregs.h> + +void enable_interrupts(void) +{ +} + +int disable_interrupts(void) +{ + return 0; +} diff --git a/arch/mips/cpu/mips64/start.S b/arch/mips/cpu/mips64/start.S new file mode 100644 index 0000000..dc941b8 --- /dev/null +++ b/arch/mips/cpu/mips64/start.S @@ -0,0 +1,256 @@ +/* + * Startup Code for MIPS64 CPU-core + * + * Copyright (c) 2003 Wolfgang Denk wd@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any dlater version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICUdlaR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Pdlace, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <asm-offsets.h> +#include <config.h> +#include <asm/regdef.h> +#include <asm/mipsregs.h> + +#ifndef CONFIG_SYS_MIPS_CACHE_MODE +#define CONFIG_SYS_MIPS_CACHE_MODE CONF_CM_CACHABLE_NONCOHERENT +#endif + + /* + * For the moment disable interrupts, mark the kernel mode and + * set ST0_KX so that the CPU does not spit fire when using + * 64-bit addresses. + */ + .macro setup_c0_status set clr + .set push + mfc0 t0, CP0_STATUS + or t0, ST0_CU0 | \set | 0x1f | \clr + xor t0, 0x1f | \clr + mtc0 t0, CP0_STATUS + .set noreorder + sll zero, 3 # ehb + .set pop + .endm + + .set noreorder + + .globl _start + .text +_start: + .org 0x000 + b reset + nop + .org 0x080 + b romReserved + nop + .org 0x100 + b romReserved + nop + .org 0x180 + b romReserved + nop + .org 0x200 + b romReserved + nop + .org 0x280 + b romReserved + nop + .org 0x300 + b romReserved + nop + .org 0x380 + b romReserved + nop + .org 0x480 + b romReserved + nop + + /* + * We hope there are no more reserved vectors! + * 128 * 8 == 1024 == 0x400 + * so this is address R_VEC+0x400 == 0xbfc00400 + */ + .org 0x500 + .align 4 +reset: + + /* Clear watch registers */ + dmtc0 zero, CP0_WATCHLO + dmtc0 zero, CP0_WATCHHI + + /* WP(Watch Pending), SW0/1 should be cleared */ + mtc0 zero, CP0_CAUSE + + setup_c0_status ST0_KX 0 + + /* Init Timer */ + mtc0 zero, CP0_COUNT + mtc0 zero, CP0_COMPARE + +#ifndef CONFIG_SKIP_LOWLEVEL_INIT + /* CONFIG0 register */ + li t0, CONF_CM_UNCACHED + mtc0 t0, CP0_CONFIG +#endif + + /* Initialize $gp */ + bal 1f + nop + .dword _gp +1: + ld gp, 0(ra) + +#ifndef CONFIG_SKIP_LOWLEVEL_INIT + /* Initialize any external memory */ + dla t9, lowlevel_init + jalr t9 + nop + + /* Initialize caches... */ + dla t9, mips_cache_reset + jalr t9 + nop + + /* ... and enable them */ + li t0, CONFIG_SYS_MIPS_CACHE_MODE + mtc0 t0, CP0_CONFIG +#endif + + /* Set up temporary stack */ + li t0, CONFIG_SYS_SDRAM_BASE + CONFIG_SYS_INIT_SP_OFFSET + dla sp, 0(t0) + + dla t9, board_init_f + jr t9 + nop + +/* + * void relocate_code (addr_sp, gd, addr_moni) + * + * This "function" does not return, instead it continues in RAM + * after relocating the monitor code. + * + * a0 = addr_sp + * a1 = gd + * a2 = destination address + */ + .globl relocate_code + .ent relocate_code +relocate_code: + move sp, a0 # set new stack pointer + + li t0, CONFIG_SYS_MONITOR_BASE + dla t3, in_ram + ld t2, -24(t3) # t2 <-- uboot_end_data + move t1, a2 + move s2, a2 # s2 <-- destination address + + /* + * Fix $gp: + * + * New $gp = (Old $gp - CONFIG_SYS_MONITOR_BASE) + Destination Address + */ + move t8, gp + dsub gp, CONFIG_SYS_MONITOR_BASE + dadd gp, a2 # gp now adjusted + dsub s1, gp, t8 # s1 <-- relocation offset + + /* + * t0 = source address + * t1 = target address + * t2 = source end address + */ + + /* + * Save destination address and size for dlater usage in flush_cache() + */ + move s0, a1 # save gd in s0 + move a0, t1 # a0 <-- destination addr + dsub a1, t2, t0 # a1 <-- size + +1: + lw t3, 0(t0) + sw t3, 0(t1) + daddu t0, 4 + ble t0, t2, 1b + daddu t1, 4 + + /* If caches were enabled, we would have to flush them here. */ + + /* a0 & a1 are already set up for flush_cache(start, size) */ + dla t9, flush_cache + jalr t9 + nop + + /* Jump to where we've relocated ourselves */ + daddi t0, s2, in_ram - _start + jr t0 + nop + + .dword _gp + .dword _GLOBAL_OFFSET_TABLE_ + .dword uboot_end_data + .dword uboot_end + .dword num_got_entries + +in_ram: + /* + * Now we want to update GOT. + * + * GOT[0] is reserved. GOT[1] is also reserved for the dynamic object + * generated by GNU ld. Skip these reserved entries from relocation. + */ + ld t3, -8(t0) # t3 <-- num_got_entries + ld t8, -32(t0) # t8 <-- _GLOBAL_OFFSET_TABLE_ + ld t9, -40(t0) # t9 <-- _gp + dsub t8, t9 # compute offset + dadd t8, t8, gp # t8 now holds relocated _G_O_T_ + daddi t8, t8, 16 # skipping first two entries + li t2, 2 +1: + ld t1, 0(t8) + beqz t1, 2f + dadd t1, s1 + sd t1, 0(t8) +2: + daddi t2, 1 + blt t2, t3, 1b + daddi t8, 8 + + /* Clear BSS */ + ld t1, -24(t0) # t1 <-- uboot_end_data + ld t2, -16(t0) # t2 <-- uboot_end + dadd t1, s1 # adjust pointers + dadd t2, s1 + + dsub t1, 8 +1: + daddi t1, 8 + bltl t1, t2, 1b + sd zero, 0(t1) + + move a0, s0 # a0 <-- gd + dla t9, board_init_r + jr t9 + move a1, s2 + + .end relocate_code + + /* Exception handlers */ +romReserved: + b romReserved diff --git a/arch/mips/cpu/mips64/time.c b/arch/mips/cpu/mips64/time.c new file mode 100644 index 0000000..5154280 --- /dev/null +++ b/arch/mips/cpu/mips64/time.c @@ -0,0 +1,87 @@ +/* + * (C) Copyright 2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/mipsregs.h> + +static unsigned long timestamp; + +/* how many counter cycles in a jiffy */ +#define CYCLES_PER_JIFFY \ + (CONFIG_SYS_MIPS_TIMER_FREQ + CONFIG_SYS_HZ / 2) / CONFIG_SYS_HZ + +/* + * timer without interrupts + */ + +int timer_init(void) +{ + /* Set up the timer for the first expiration. */ + timestamp = 0; + write_c0_compare(read_c0_count() + CYCLES_PER_JIFFY); + + return 0; +} + +ulong get_timer(ulong base) +{ + unsigned int count; + unsigned int expirelo = read_c0_compare(); + + /* Check to see if we have missed any timestamps. */ + count = read_c0_count(); + while ((count - expirelo) < 0x7fffffff) { + expirelo += CYCLES_PER_JIFFY; + timestamp++; + } + write_c0_compare(expirelo); + + return timestamp - base; +} + +void __udelay(unsigned long usec) +{ + unsigned int tmo; + + tmo = read_c0_count() + (usec * (CONFIG_SYS_MIPS_TIMER_FREQ / 1000000)); + while ((tmo - read_c0_count()) < 0x7fffffff) + /*NOP*/; +} + +/* + * This function is derived from PowerPC code (read timebase as long long). + * On MIPS it just returns the timer value. + */ +unsigned long long get_ticks(void) +{ + return get_timer(0); +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On MIPS it returns the number of timer ticks per second. + */ +ulong get_tbclk(void) +{ + return CONFIG_SYS_HZ; +} diff --git a/board/qemu-mips/u-boot.lds b/board/qemu-mips/u-boot.lds index 9460b20..4d9580f 100644 --- a/board/qemu-mips/u-boot.lds +++ b/board/qemu-mips/u-boot.lds @@ -24,7 +24,11 @@ /* OUTPUT_FORMAT("elf32-bigmips", "elf32-bigmips", "elf32-bigmips") */ +#if defined(CONFIG_64BIT) +OUTPUT_FORMAT("elf64-tradbigmips", "elf64-tradbigmips", "elf64-tradlittlemips") +#else OUTPUT_FORMAT("elf32-tradbigmips", "elf32-tradbigmips", "elf32-tradlittlemips") +#endif OUTPUT_ARCH(mips) ENTRY(_start) SECTIONS @@ -63,7 +67,11 @@ SECTIONS }
uboot_end_data = .; +#if defined(CONFIG_64BIT) + num_got_entries = (__got_end - __got_start) >> 3; +#else num_got_entries = (__got_end - __got_start) >> 2; +#endif
. = ALIGN(4); .sbss : { *(.sbss*) } diff --git a/boards.cfg b/boards.cfg index 6b54941..ff4bb0c 100644 --- a/boards.cfg +++ b/boards.cfg @@ -380,6 +380,8 @@ M5485HFE m68k mcf547x_8x m548xevb freescale - microblaze-generic microblaze microblaze microblaze-generic xilinx qemu_mips mips mips32 qemu-mips - - qemu-mips:SYS_BIG_ENDIAN qemu_mipsel mips mips32 qemu-mips - - qemu-mips:SYS_LITTLE_ENDIAN +qemu_mips64 mips mips64 qemu-mips - - qemu-mips64:SYS_BIG_ENDIAN +qemu_mips64el mips mips64 qemu-mips - - qemu-mips64:SYS_LITTLE_ENDIAN vct_platinum mips mips32 vct micronas - vct:VCT_PLATINUM vct_platinumavc mips mips32 vct micronas - vct:VCT_PLATINUMAVC vct_platinumavc_onenand mips mips32 vct micronas - vct:VCT_PLATINUMAVC,VCT_ONENAND diff --git a/examples/standalone/mips64.lds b/examples/standalone/mips64.lds new file mode 100644 index 0000000..9b27ef4 --- /dev/null +++ b/examples/standalone/mips64.lds @@ -0,0 +1,59 @@ +/* + * (C) Copyright 2003 + * Wolfgang Denk Engineering, wd@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* +OUTPUT_FORMAT("elf32-bigmips", "elf32-bigmips", "elf32-bigmips") +*/ +OUTPUT_FORMAT("elf64-tradbigmips", "elf64-tradbigmips", "elf64-tradlittlemips") +OUTPUT_ARCH(mips) +SECTIONS +{ + .text : + { + *(.text*) + } + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + + . = ALIGN(4); + .data : { *(.data*) } + + . = .; + _gp = ALIGN(16) + 0x7ff0; + + .got : { + __got_start = .; + *(.got) + __got_end = .; + } + + .sdata : { *(.sdata*) } + + . = ALIGN(4); + __bss_start = .; + .sbss (NOLOAD) : { *(.sbss*) } + .bss (NOLOAD) : { *(.bss*) . = ALIGN(4); } + + _end = .; +} diff --git a/include/configs/qemu-mips64.h b/include/configs/qemu-mips64.h new file mode 100644 index 0000000..216326d --- /dev/null +++ b/include/configs/qemu-mips64.h @@ -0,0 +1,171 @@ +/* + * (C) Copyright 2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * This file contains the configuration parameters for qemu-mips64 target. + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_MIPS64 /* MIPS64 CPU core */ +#define CONFIG_QEMU_MIPS1 +#define CONFIG_MISC_INIT_R + +#define CONFIG_BOOTDELAY 10 /* autoboot after 10 seconds */ + +#define CONFIG_BAUDRATE 115200 + +/* valid baudrates */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +#define CONFIG_TIMESTAMP /* Print image info with timestamp */ +#undef CONFIG_BOOTARGS + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "addmisc=setenv bootargs ${bootargs} " \ + "console=ttyS0,${baudrate} " \ + "panic=1\0" \ + "bootfile=/tftpboot/vmlinux\0" \ + "load=tftp ffffffff80500000 ${u-boot}\0" \ + "" + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#define CONFIG_DP83902A + +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 +#undef CONFIG_CMD_LOADB +#undef CONFIG_CMD_LOADS +#define CONFIG_CMD_DHCP + +#define CONFIG_DRIVER_NE2000 +#define CONFIG_DRIVER_NE2000_BASE 0xffffffffb4000300 + +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK 115200 +#define CONFIG_SYS_NS16550_COM1 (0xffffffffb40003f8) +#define CONFIG_CONS_INDEX 1 + +#define CONFIG_CMD_IDE +#define CONFIG_DOS_PARTITION + +#define CONFIG_SYS_IDE_MAXBUS 2 +#define CONFIG_SYS_ATA_IDE0_OFFSET (0x1f0) +#define CONFIG_SYS_ATA_IDE1_OFFSET (0x170) +#define CONFIG_SYS_ATA_DATA_OFFSET (0) +#define CONFIG_SYS_ATA_REG_OFFSET (0) +#define CONFIG_SYS_ATA_BASE_ADDR (0xffffffffb4000000) + +#define CONFIG_SYS_IDE_MAXDEVICE (4) + +#define CONFIG_CMD_RARP + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ + +/* Monitor Command Prompt */ +#if defined(CONFIG_SYS_LITTLE_ENDIAN) +#define CONFIG_SYS_PROMPT "qemu-mips64el # " +#else +#define CONFIG_SYS_PROMPT "qemu-mips64 # " +#endif + +#define CONFIG_AUTO_COMPLETE +#define CONFIG_CMDLINE_EDITING +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +/* Console I/O Buffer Size */ +#define CONFIG_SYS_CBSIZE 256 +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +/* max number of command args */ +#define CONFIG_SYS_MAXARGS 16 + +#define CONFIG_SYS_MALLOC_LEN 128*1024 + +#define CONFIG_SYS_BOOTPARAMS_LEN 128*1024 + +#define CONFIG_SYS_MHZ 132 + +#define CONFIG_SYS_MIPS_TIMER_FREQ (CONFIG_SYS_MHZ * 1000000) + +#define CONFIG_SYS_HZ 1000 + +/* Cached addr */ +#define CONFIG_SYS_SDRAM_BASE 0xffffffff80000000 + +/* default load address */ +#define CONFIG_SYS_LOAD_ADDR 0xffffffff81000000 + +#define CONFIG_SYS_MEMTEST_START 0xffffffff80100000 +#define CONFIG_SYS_MEMTEST_END 0xffffffff80800000 + +/*----------------------------------------------------------------------- + * FLASH and environment organization + */ +#define CONFIG_CMD_NO_FLASH +#define CONFIG_SYS_NO_FLASH +#undef CONFIG_CMD_IMLS + +/* The following #defines are needed to get flash environment right */ +#undef CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_TEXT_BASE 0xffffffffbfc00000 /* ROM Version */ +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE + +#define CONFIG_SYS_INIT_SP_OFFSET 0x400000 +#define CONFIG_ENV_IS_NOWHERE + +/* Address and size of Primary Environment Sector */ +#define CONFIG_ENV_SIZE 0x8000 + +#define CONFIG_ENV_OVERWRITE + +#define MEM_SIZE 128 + +#define CONFIG_LZA + +/*----------------------------------------------------------------------- + * Cache Configuration + */ +#define CONFIG_SYS_DCACHE_SIZE 16384 +#define CONFIG_SYS_ICACHE_SIZE 16384 +#define CONFIG_SYS_CACHELINE_SIZE 32 + +#endif /* __CONFIG_H */
- (C) Copyright 2003
- Wolfgang Denk, DENX Software Engineering, wd@denx.de.
- project.
- MA 02111-1307 USA
- This file contains the configuration parameters for qemu-mips64 target.
arch/mips/lib/config.mk depends on that config option
"panic=1\0" \
- BOOTP options
- Command line configuration.
- Miscellaneous configurable options
- FLASH and environment organization
+#define CONFIG_LZA
- Cache Configuration
1.7.9.5
- project.
- MA 02111-1307 USA
"panic=1\0" \
why have you omitted this?
#define CONFIG_BOOTCOMMAND "bootp;bootelf"
#define CONFIG_CMD_ELF
- BOOTP options
why have you omitted the flash support? qemu-system-mips supports flash emulation with the option -pflash. It already works with a qemu_mips32 U-boot.
drop this line
+#define CONFIG_LZA
#define CONFIG_LZMA
1.7.9.5
On Wed, Sep 5, 2012 at 7:12 AM, Daniel Schwierzeck < daniel.schwierzeck@gmail.com> wrote:
-nographic
-nographic
-nographic
-nographic
- project.
- MA 02111-1307 USA
target.
115200 }
timestamp */
"panic=1\0" \
Because I haven't tested `bootelf' command. I'm not should it work or not.
Another reason is that when I configure CONFIG_CMD_ELF I will get lots of warning such as: cmd_elf.c: In function 'load_elf_image_phdr': cmd_elf.c:289:15: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] cmd_elf.c: In function 'load_elf_image_shdr': cmd_elf.c:343:12: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] cmd_elf.c:346:12: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
- BOOTP options
Yes, I have tested with -pflash in qemu_mips64 either. I have forgot why I
omit it now. By the way, which commit should I base on of my next patch?
drop this line
Version */
+#define CONFIG_LZA
#define CONFIG_LZMA
Thanks, I will put more attention on checking this file.
1.7.9.5
2012/9/5 Zhi-zhou Zhang etou.zh@gmail.com: [...]
Because I haven't tested `bootelf' command. I'm not should it work or not. Another reason is that when I configure CONFIG_CMD_ELF I will get lots of warning such as: cmd_elf.c: In function 'load_elf_image_phdr': cmd_elf.c:289:15: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] cmd_elf.c: In function 'load_elf_image_shdr': cmd_elf.c:343:12: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] cmd_elf.c:346:12: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
ok but there are similar warnings in other files too. We can fix those files later. My point is that all qemu_mips variants should be configured with the same options.
Yes, I have tested with -pflash in qemu_mips64 either. I have forgot why I omit it now. By the way, which commit should I base on of my next patch?
it is still git://git.denx.de/u-boot-mips.git master
Daniel Schwierzeck
Zhi-zhou Zhang
Zhizhou Zhang
