UDC fixes below, this is for coming 2019.01 release. There's a lot of churn, however most are just renames.
The following changes since commit 54707a942009fae083dd78b58ff057127ba0e900:
Prepare v2019.01-rc3 (2019-01-07 22:58:17 -0500)
git://git.denx.de/u-boot-usb.git master
for you to fetch changes up to b3c518a88278619b1e109de114c450237d03e032:
dm: usb: gadget: Fix boot breakage on sunxi platforms (2019-01-10 18:53:03 +0100)
---------------------------------------------------------------- Jean-Jacques Hiblot (5): dm: usb: udc: Use SEQ_ALIAS to index the USB gadget ports ARM: dts: define USB aliases for all omap5 platforms Kconfig: rename CONFIG_SPL_USB_GADGET_SUPPORT as CONFIG_SPL_USB_GADGET usb: Make compiling gadget support optional dm: usb: gadget: Fix boot breakage on sunxi platforms
Ye Li (1): usb: xhci-mem: Fix scratchpad array issue
Makefile | 4 ++-- arch/arm/dts/omap5-u-boot.dtsi | 5 +++++ arch/arm/mach-imx/mx6/Kconfig | 2 +- arch/arm/mach-imx/spl.c | 2 +- common/spl/Kconfig | 4 ++-- configs/am335x_boneblack_vboot_defconfig | 2 +- configs/am335x_evm_usbspl_defconfig | 2 +- configs/am43xx_evm_defconfig | 2 +- configs/am43xx_hs_evm_defconfig | 2 +- configs/apalis_imx6_defconfig | 2 +- configs/cm_t3517_defconfig | 1 + configs/cm_t35_defconfig | 1 + configs/colibri_imx6_defconfig | 2 +- configs/display5_factory_defconfig | 2 +- configs/duovero_defconfig | 1 + configs/igep0032_defconfig | 1 + configs/igep00x0_defconfig | 1 + configs/imx6q_logic_defconfig | 2 +- configs/mx6memcal_defconfig | 2 +- configs/mx6sabresd_defconfig | 2 +- configs/omap3_zoom1_defconfig | 1 + configs/omap4_panda_defconfig | 1 + configs/omap4_sdp4430_defconfig | 1 + configs/pico-hobbit-imx6ul_defconfig | 2 +- configs/pico-hobbit-imx7d_defconfig | 2 +- configs/pico-imx6ul_defconfig | 2 +- configs/pico-imx7d_defconfig | 2 +- configs/pico-pi-imx6ul_defconfig | 2 +- configs/pico-pi-imx7d_defconfig | 2 +- configs/spear300_usbtty_defconfig | 2 ++ configs/spear300_usbtty_nand_defconfig | 2 ++ configs/spear310_usbtty_defconfig | 2 ++ configs/spear310_usbtty_nand_defconfig | 2 ++ configs/spear310_usbtty_pnor_defconfig | 2 ++ configs/spear320_usbtty_defconfig | 2 ++ configs/spear320_usbtty_nand_defconfig | 2 ++ configs/spear320_usbtty_pnor_defconfig | 2 ++ configs/spear600_usbtty_defconfig | 2 ++ configs/spear600_usbtty_nand_defconfig | 2 ++ drivers/Makefile | 6 +++--- drivers/usb/gadget/Makefile | 2 +- drivers/usb/gadget/udc/Makefile | 3 ++- drivers/usb/gadget/udc/udc-uclass.c | 7 +++++-- drivers/usb/host/xhci-mem.c | 3 +++ scripts/Makefile.spl | 2 +- 45 files changed, 70 insertions(+), 30 deletions(-)
