[U-Boot] [PATCH] rpi: remove redundant board files
Now that rpi_*defconfig and Kconfig rather than the config header file, provide the identify of the build, we don't need to separate config headers and board directories for each RPi variant. Set CONFIG_SYS_BOARD and CONFIG_SYS_CONFIG_NAME so that we can get rid of the duplication. This requires a tiny number of extra ifdefs in the config header.
The only disadvantage of this approach is that the $board/$board_name environment variables aren't as descriptive as they used to be. This isn't really an issue because those only exist to allow scripts to create DTB filenames at runtime. However, the RPi board code already sets $fdtfile to something more accurate based on FW-reported board ID anyway.
While at it, unify some Kconfig select options, and add a MAINTAINERS entry for bcm283x too.
Partially-suggested-by: Tom Rini trini@konsulko.com Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- MAINTAINERS | 10 ++ arch/arm/mach-bcm283x/Kconfig | 36 +++--- arch/arm/mach-bcm283x/Makefile | 2 +- board/raspberrypi/rpi/MAINTAINERS | 2 +- board/raspberrypi/rpi_2/MAINTAINERS | 6 - board/raspberrypi/rpi_2/Makefile | 7 -- board/raspberrypi/rpi_3/MAINTAINERS | 6 - board/raspberrypi/rpi_3/Makefile | 7 -- board/raspberrypi/rpi_3_32b/MAINTAINERS | 6 - board/raspberrypi/rpi_3_32b/Makefile | 7 -- include/configs/rpi-common.h | 206 -------------------------------- include/configs/rpi.h | 206 +++++++++++++++++++++++++++++++- include/configs/rpi_2.h | 15 --- include/configs/rpi_3.h | 14 --- include/configs/rpi_3_32b.h | 15 --- 15 files changed, 236 insertions(+), 309 deletions(-) delete mode 100644 board/raspberrypi/rpi_2/MAINTAINERS delete mode 100644 board/raspberrypi/rpi_2/Makefile delete mode 100644 board/raspberrypi/rpi_3/MAINTAINERS delete mode 100644 board/raspberrypi/rpi_3/Makefile delete mode 100644 board/raspberrypi/rpi_3_32b/MAINTAINERS delete mode 100644 board/raspberrypi/rpi_3_32b/Makefile delete mode 100644 include/configs/rpi-common.h delete mode 100644 include/configs/rpi_2.h delete mode 100644 include/configs/rpi_3.h delete mode 100644 include/configs/rpi_3_32b.h
diff --git a/MAINTAINERS b/MAINTAINERS index 87e0c2ed36d0..383a4ffc3aef 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -78,6 +78,16 @@ S: Maintained T: git git://git.denx.de/u-boot-atmel.git F: arch/arm/mach-at91/
+ARM BROADCOM BCM283X +M: Stephen Warren swarren@wwwdotorg.org +S: Maintained +F: arch/arm/mach-bcm283x/ +F: drivers/gpio/bcm2835_gpio.c +F: drivers/mmc/bcm2835_sdhci.c +F: drivers/serial/serial_bcm283x_mu.c +F: drivers/video/bcm2835.c +F: include/dm/platform_data/serial_bcm283x_mu.h + ARM FREESCALE IMX M: Stefano Babic sbabic@denx.de S: Maintained diff --git a/arch/arm/mach-bcm283x/Kconfig b/arch/arm/mach-bcm283x/Kconfig index f4c9502b3f1f..69f7a4663cfd 100644 --- a/arch/arm/mach-bcm283x/Kconfig +++ b/arch/arm/mach-bcm283x/Kconfig @@ -1,15 +1,31 @@ config BCM2835 bool "Broadcom BCM2835 SoC support" depends on ARCH_BCM283X + select CPU_ARM1176
config BCM2836 bool "Broadcom BCM2836 SoC support" depends on ARCH_BCM283X + select ARMV7_LPAE + select CPU_V7
config BCM2837 bool "Broadcom BCM2837 SoC support" depends on ARCH_BCM283X
+config BCM2837_32B + bool "Broadcom BCM2837 SoC 32-bit support" + depends on ARCH_BCM283X + select BCM2837 + select ARMV7_LPAE + select CPU_V7 + +config BCM2837_64B + bool "Broadcom BCM2837 SoC 64-bit support" + depends on ARCH_BCM283X + select BCM2837 + select ARM64 + menu "Broadcom BCM283X family" depends on ARCH_BCM283X
@@ -27,7 +43,6 @@ config TARGET_RPI
This option creates a build targetting the ARM1176 ISA. select BCM2835 - select CPU_ARM1176
config TARGET_RPI_2 bool "Raspberry Pi 2" @@ -50,9 +65,7 @@ config TARGET_RPI_2 https://github.com/raspberrypi/firmware/issues/572".
This option creates a build targetting the ARMv7/AArch32 ISA. - select ARMV7_LPAE select BCM2836 - select CPU_V7
config TARGET_RPI_3_32B bool "Raspberry Pi 3 32-bit build" @@ -68,9 +81,7 @@ config TARGET_RPI_3_32B about the HDMI/usbkbd console.
This option creates a build targetting the ARMv7/AArch32 ISA. - select ARMV7_LPAE - select BCM2837 - select CPU_V7 + select BCM2837_32B
config TARGET_RPI_3 bool "Raspberry Pi 3 64-bit build" @@ -98,16 +109,12 @@ config TARGET_RPI_3 https://github.com/raspberrypi/firmware/issues/579.
This option creates a build targetting the ARMv8/AArch64 ISA. - select ARM64 - select BCM2837 + select BCM2837_64B
endchoice
config SYS_BOARD - default "rpi" if TARGET_RPI - default "rpi_2" if TARGET_RPI_2 - default "rpi_3_32b" if TARGET_RPI_3_32B - default "rpi_3" if TARGET_RPI_3 + default "rpi"
config SYS_VENDOR default "raspberrypi" @@ -116,9 +123,6 @@ config SYS_SOC default "bcm283x"
config SYS_CONFIG_NAME - default "rpi" if TARGET_RPI - default "rpi_2" if TARGET_RPI_2 - default "rpi_3_32b" if TARGET_RPI_3_32B - default "rpi_3" if TARGET_RPI_3 + default "rpi"
endmenu diff --git a/arch/arm/mach-bcm283x/Makefile b/arch/arm/mach-bcm283x/Makefile index f0dadd0dbde9..5cb1b2fe94b1 100644 --- a/arch/arm/mach-bcm283x/Makefile +++ b/arch/arm/mach-bcm283x/Makefile @@ -4,5 +4,5 @@ # SPDX-License-Identifier: GPL-2.0 #
-obj-$(CONFIG_TARGET_RPI) += lowlevel_init.o +obj-$(CONFIG_BCM2835) += lowlevel_init.o obj-y += init.o reset.o mbox.o phys2bus.o diff --git a/board/raspberrypi/rpi/MAINTAINERS b/board/raspberrypi/rpi/MAINTAINERS index 6dcb7bd24ecd..98c3758a9480 100644 --- a/board/raspberrypi/rpi/MAINTAINERS +++ b/board/raspberrypi/rpi/MAINTAINERS @@ -3,4 +3,4 @@ M: Stephen Warren swarren@wwwdotorg.org S: Maintained F: board/raspberrypi/rpi/ F: include/configs/rpi.h -F: configs/rpi_defconfig +F: configs/rpi_*defconfig diff --git a/board/raspberrypi/rpi_2/MAINTAINERS b/board/raspberrypi/rpi_2/MAINTAINERS deleted file mode 100644 index 85a480c9d1b0..000000000000 --- a/board/raspberrypi/rpi_2/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -RPI_2 BOARD -M: Stephen Warren swarren@wwwdotorg.org -S: Maintained -F: board/raspberrypi/rpi_2/ -F: include/configs/rpi_2.h -F: configs/rpi_2_defconfig diff --git a/board/raspberrypi/rpi_2/Makefile b/board/raspberrypi/rpi_2/Makefile deleted file mode 100644 index d82cd21f4cf7..000000000000 --- a/board/raspberrypi/rpi_2/Makefile +++ /dev/null @@ -1,7 +0,0 @@ -# -# (C) Copyright 2012,2015 Stephen Warren -# -# SPDX-License-Identifier: GPL-2.0 -# - -obj-y := ../rpi/rpi.o diff --git a/board/raspberrypi/rpi_3/MAINTAINERS b/board/raspberrypi/rpi_3/MAINTAINERS deleted file mode 100644 index 26ecd99e16fa..000000000000 --- a/board/raspberrypi/rpi_3/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -RPI_3_BOARD -M: Stephen Warren swarren@wwwdotorg.org -S: Maintained -F: board/raspberrypi/rpi_3/ -F: include/configs/rpi_3.h -F: configs/rpi_3_defconfig diff --git a/board/raspberrypi/rpi_3/Makefile b/board/raspberrypi/rpi_3/Makefile deleted file mode 100644 index 78e287487cd4..000000000000 --- a/board/raspberrypi/rpi_3/Makefile +++ /dev/null @@ -1,7 +0,0 @@ -# -# (C) Copyright 2012-2016 Stephen Warren swarren@wwwdotorg.org -# -# SPDX-License-Identifier: GPL-2.0 -# - -obj-y := ../rpi/rpi.o diff --git a/board/raspberrypi/rpi_3_32b/MAINTAINERS b/board/raspberrypi/rpi_3_32b/MAINTAINERS deleted file mode 100644 index bc9df87f03d4..000000000000 --- a/board/raspberrypi/rpi_3_32b/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -RPI_3_32B BOARD -M: Stephen Warren swarren@wwwdotorg.org -S: Maintained -F: board/raspberrypi/rpi_3_32b/ -F: include/configs/rpi_3_32b.h -F: configs/rpi_3_32b_defconfig diff --git a/board/raspberrypi/rpi_3_32b/Makefile b/board/raspberrypi/rpi_3_32b/Makefile deleted file mode 100644 index 78e287487cd4..000000000000 --- a/board/raspberrypi/rpi_3_32b/Makefile +++ /dev/null @@ -1,7 +0,0 @@ -# -# (C) Copyright 2012-2016 Stephen Warren swarren@wwwdotorg.org -# -# SPDX-License-Identifier: GPL-2.0 -# - -obj-y := ../rpi/rpi.o diff --git a/include/configs/rpi-common.h b/include/configs/rpi-common.h deleted file mode 100644 index 9aca1ace2c0b..000000000000 --- a/include/configs/rpi-common.h +++ /dev/null @@ -1,206 +0,0 @@ -/* - * (C) Copyright 2012-2016 Stephen Warren - * - * SPDX-License-Identifier: GPL-2.0 - */ - -#ifndef _RPI_COMMON_H_ -#define _RPI_COMMON_H_ - -#include <linux/sizes.h> -#include <asm/arch/timer.h> - -/* Architecture, CPU, etc.*/ -#define CONFIG_ARCH_CPU_INIT - -/* Use SoC timer for AArch32, but architected timer for AArch64 */ -#ifndef CONFIG_ARM64 -#define CONFIG_SYS_TIMER_RATE 1000000 -#define CONFIG_SYS_TIMER_COUNTER \ - (&((struct bcm2835_timer_regs *)BCM2835_TIMER_PHYSADDR)->clo) -#endif - -/* - * 2835 is a SKU in a series for which the 2708 is the first or primary SoC, - * so 2708 has historically been used rather than a dedicated 2835 ID. - * - * We don't define a machine type for bcm2709/bcm2836 since the RPi Foundation - * chose to use someone else's previously registered machine ID (3139, MX51_GGC) - * rather than obtaining a valid ID:-/ - * - * For the bcm2837, hopefully a machine type is not needed, since everything - * is DT. - */ -#ifdef CONFIG_BCM2835 -#define CONFIG_MACH_TYPE MACH_TYPE_BCM2708 -#endif - -/* Memory layout */ -#define CONFIG_NR_DRAM_BANKS 1 -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_TEXT_BASE 0x00008000 -#define CONFIG_SYS_UBOOT_BASE CONFIG_SYS_TEXT_BASE -/* - * The board really has 256M. However, the VC (VideoCore co-processor) shares - * the RAM, and uses a configurable portion at the top. We tell U-Boot that a - * smaller amount of RAM is present in order to avoid stomping on the area - * the VC uses. - */ -#define CONFIG_SYS_SDRAM_SIZE SZ_128M -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + \ - CONFIG_SYS_SDRAM_SIZE - \ - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_MALLOC_LEN SZ_4M -#define CONFIG_SYS_MEMTEST_START 0x00100000 -#define CONFIG_SYS_MEMTEST_END 0x00200000 -#define CONFIG_LOADADDR 0x00200000 - -/* Flash */ -#define CONFIG_SYS_NO_FLASH - -/* Devices */ -/* GPIO */ -#define CONFIG_BCM2835_GPIO -/* LCD */ -#define CONFIG_LCD -#define CONFIG_LCD_DT_SIMPLEFB -#define LCD_BPP LCD_COLOR16 -/* - * Prevent allocation of RAM for FB; the real FB address is queried - * dynamically from the VideoCore co-processor, and comes from RAM - * not owned by the ARM CPU. - */ -#define CONFIG_FB_ADDR 0 -#define CONFIG_VIDEO_BCM2835 -#define CONFIG_SYS_WHITE_ON_BLACK -#define CONFIG_CONSOLE_SCROLL_LINES 10 - -/* SD/MMC configuration */ -#define CONFIG_GENERIC_MMC -#define CONFIG_MMC -#define CONFIG_SDHCI -#define CONFIG_MMC_SDHCI_IO_ACCESSORS -#define CONFIG_BCM2835_SDHCI - -#define CONFIG_CMD_USB -#ifdef CONFIG_CMD_USB -#define CONFIG_USB_DWC2 -#ifndef CONFIG_BCM2835 -#define CONFIG_USB_DWC2_REG_ADDR 0x3f980000 -#else -#define CONFIG_USB_DWC2_REG_ADDR 0x20980000 -#endif -#define CONFIG_USB_STORAGE -#define CONFIG_USB_HOST_ETHER -#define CONFIG_USB_ETHER_SMSC95XX -#define CONFIG_MISC_INIT_R -#define CONFIG_USB_KEYBOARD -#define CONFIG_SYS_USB_EVENT_POLL -#define CONFIG_SYS_STDIO_DEREGISTER -#endif - -/* Console UART */ -#ifdef CONFIG_BCM2837 -#define CONFIG_BCM283X_MU_SERIAL -#else -#define CONFIG_PL01X_SERIAL -#endif -#define CONFIG_CONS_INDEX 0 -#define CONFIG_BAUDRATE 115200 - -/* Console configuration */ -#define CONFIG_SYS_CBSIZE 1024 -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ - sizeof(CONFIG_SYS_PROMPT) + 16) - -/* Environment */ -#define CONFIG_ENV_SIZE SZ_16K -#define CONFIG_ENV_IS_IN_FAT -#define FAT_ENV_INTERFACE "mmc" -#define FAT_ENV_DEVICE_AND_PART "0:1" -#define FAT_ENV_FILE "uboot.env" -#define CONFIG_FAT_WRITE -#define CONFIG_ENV_VARS_UBOOT_CONFIG -#define CONFIG_SYS_LOAD_ADDR 0x1000000 -#define CONFIG_CONSOLE_MUX -#define CONFIG_SYS_CONSOLE_IS_IN_ENV -#define CONFIG_PREBOOT "usb start" - -/* Shell */ -#define CONFIG_SYS_MAXARGS 16 -#define CONFIG_COMMAND_HISTORY - -/* Commands */ -#define CONFIG_CMD_MMC -#define CONFIG_PARTITION_UUIDS -#define CONFIG_CMD_PART - -/* ATAGs support for bootm/bootz */ -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_CMDLINE_TAG -#define CONFIG_INITRD_TAG - -#include <config_distro_defaults.h> - -/* Environment */ -#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG -#define ENV_DEVICE_SETTINGS \ - "stdin=serial,usbkbd\0" \ - "stdout=serial,lcd\0" \ - "stderr=serial,lcd\0" - -/* - * Memory layout for where various images get loaded by boot scripts: - * - * I suspect address 0 is used as the SMP pen on the RPi2, so avoid this. - * - * fdt_addr_r simply shouldn't overlap anything else. However, the RPi's - * binary firmware loads a DT to address 0x100, so we choose this address to - * match it. This allows custom boot scripts to pass this DT on to Linux - * simply by not over-writing the data at this address. When using U-Boot, - * U-Boot (and scripts it executes) typicaly ignore the DT loaded by the FW - * and loads its own DT from disk (triggered by boot.scr or extlinux.conf). - * - * pxefile_addr_r can be pretty much anywhere that doesn't conflict with - * something else. Put it low in memory to avoid conflicts. - * - * kernel_addr_r must be within the first 128M of RAM in order for the - * kernel's CONFIG_AUTO_ZRELADDR option to work. Since the kernel will - * decompress itself to 0x8000 after the start of RAM, kernel_addr_r - * should not overlap that area, or the kernel will have to copy itself - * somewhere else before decompression. Similarly, the address of any other - * data passed to the kernel shouldn't overlap the start of RAM. Pushing - * this up to 16M allows for a sizable kernel to be decompressed below the - * compressed load address. - * - * scriptaddr can be pretty much anywhere that doesn't conflict with something - * else. Choosing 32M allows for the compressed kernel to be up to 16M. - * - * ramdisk_addr_r simply shouldn't overlap anything else. Choosing 33M allows - * for any boot script to be up to 1M, which is hopefully plenty. - */ -#define ENV_MEM_LAYOUT_SETTINGS \ - "fdt_high=ffffffff\0" \ - "initrd_high=ffffffff\0" \ - "fdt_addr_r=0x00000100\0" \ - "pxefile_addr_r=0x00100000\0" \ - "kernel_addr_r=0x01000000\0" \ - "scriptaddr=0x02000000\0" \ - "ramdisk_addr_r=0x02100000\0" \ - -#define BOOT_TARGET_DEVICES(func) \ - func(MMC, mmc, 0) \ - func(USB, usb, 0) \ - func(PXE, pxe, na) \ - func(DHCP, dhcp, na) -#include <config_distro_bootcmd.h> - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "dhcpuboot=usb start; dhcp u-boot.uimg; bootm\0" \ - ENV_DEVICE_SETTINGS \ - ENV_MEM_LAYOUT_SETTINGS \ - BOOTENV - -#define CONFIG_BOOTDELAY 2 - -#endif diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 86422e390da2..b83d622b9784 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -1,5 +1,5 @@ /* - * (C) Copyright 2012,2015 Stephen Warren + * (C) Copyright 2012-2016 Stephen Warren * * SPDX-License-Identifier: GPL-2.0 */ @@ -7,8 +7,210 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#include <linux/sizes.h> +#include <asm/arch/timer.h> + +#if defined(CONFIG_TARGET_RPI_2) || defined(CONFIG_TARGET_RPI_3_32B) +#define CONFIG_SKIP_LOWLEVEL_INIT +#endif + +#ifdef CONFIG_BCM2835 #define CONFIG_SYS_CACHELINE_SIZE 32 +#else +#define CONFIG_SYS_CACHELINE_SIZE 64 +#endif + +/* Architecture, CPU, etc.*/ +#define CONFIG_ARCH_CPU_INIT + +/* Use SoC timer for AArch32, but architected timer for AArch64 */ +#ifndef CONFIG_ARM64 +#define CONFIG_SYS_TIMER_RATE 1000000 +#define CONFIG_SYS_TIMER_COUNTER \ + (&((struct bcm2835_timer_regs *)BCM2835_TIMER_PHYSADDR)->clo) +#endif + +/* + * 2835 is a SKU in a series for which the 2708 is the first or primary SoC, + * so 2708 has historically been used rather than a dedicated 2835 ID. + * + * We don't define a machine type for bcm2709/bcm2836 since the RPi Foundation + * chose to use someone else's previously registered machine ID (3139, MX51_GGC) + * rather than obtaining a valid ID:-/ + * + * For the bcm2837, hopefully a machine type is not needed, since everything + * is DT. + */ +#ifdef CONFIG_BCM2835 +#define CONFIG_MACH_TYPE MACH_TYPE_BCM2708 +#endif + +/* Memory layout */ +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_SDRAM_BASE 0x00000000 +#define CONFIG_SYS_TEXT_BASE 0x00008000 +#define CONFIG_SYS_UBOOT_BASE CONFIG_SYS_TEXT_BASE +/* + * The board really has 256M. However, the VC (VideoCore co-processor) shares + * the RAM, and uses a configurable portion at the top. We tell U-Boot that a + * smaller amount of RAM is present in order to avoid stomping on the area + * the VC uses. + */ +#define CONFIG_SYS_SDRAM_SIZE SZ_128M +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + \ + CONFIG_SYS_SDRAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_MALLOC_LEN SZ_4M +#define CONFIG_SYS_MEMTEST_START 0x00100000 +#define CONFIG_SYS_MEMTEST_END 0x00200000 +#define CONFIG_LOADADDR 0x00200000 + +/* Flash */ +#define CONFIG_SYS_NO_FLASH + +/* Devices */ +/* GPIO */ +#define CONFIG_BCM2835_GPIO +/* LCD */ +#define CONFIG_LCD +#define CONFIG_LCD_DT_SIMPLEFB +#define LCD_BPP LCD_COLOR16 +/* + * Prevent allocation of RAM for FB; the real FB address is queried + * dynamically from the VideoCore co-processor, and comes from RAM + * not owned by the ARM CPU. + */ +#define CONFIG_FB_ADDR 0 +#define CONFIG_VIDEO_BCM2835 +#define CONFIG_SYS_WHITE_ON_BLACK +#define CONFIG_CONSOLE_SCROLL_LINES 10 + +/* SD/MMC configuration */ +#define CONFIG_GENERIC_MMC +#define CONFIG_MMC +#define CONFIG_SDHCI +#define CONFIG_MMC_SDHCI_IO_ACCESSORS +#define CONFIG_BCM2835_SDHCI + +#define CONFIG_CMD_USB +#ifdef CONFIG_CMD_USB +#define CONFIG_USB_DWC2 +#ifndef CONFIG_BCM2835 +#define CONFIG_USB_DWC2_REG_ADDR 0x3f980000 +#else +#define CONFIG_USB_DWC2_REG_ADDR 0x20980000 +#endif +#define CONFIG_USB_STORAGE +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_SMSC95XX +#define CONFIG_MISC_INIT_R +#define CONFIG_USB_KEYBOARD +#define CONFIG_SYS_USB_EVENT_POLL +#define CONFIG_SYS_STDIO_DEREGISTER +#endif + +/* Console UART */ +#ifdef CONFIG_BCM2837 +#define CONFIG_BCM283X_MU_SERIAL +#else +#define CONFIG_PL01X_SERIAL +#endif +#define CONFIG_CONS_INDEX 0 +#define CONFIG_BAUDRATE 115200 + +/* Console configuration */ +#define CONFIG_SYS_CBSIZE 1024 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) + +/* Environment */ +#define CONFIG_ENV_SIZE SZ_16K +#define CONFIG_ENV_IS_IN_FAT +#define FAT_ENV_INTERFACE "mmc" +#define FAT_ENV_DEVICE_AND_PART "0:1" +#define FAT_ENV_FILE "uboot.env" +#define CONFIG_FAT_WRITE +#define CONFIG_ENV_VARS_UBOOT_CONFIG +#define CONFIG_SYS_LOAD_ADDR 0x1000000 +#define CONFIG_CONSOLE_MUX +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define CONFIG_PREBOOT "usb start" + +/* Shell */ +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_COMMAND_HISTORY + +/* Commands */ +#define CONFIG_CMD_MMC +#define CONFIG_PARTITION_UUIDS +#define CONFIG_CMD_PART + +/* ATAGs support for bootm/bootz */ +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_CMDLINE_TAG +#define CONFIG_INITRD_TAG + +#include <config_distro_defaults.h> + +/* Environment */ +#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG +#define ENV_DEVICE_SETTINGS \ + "stdin=serial,usbkbd\0" \ + "stdout=serial,lcd\0" \ + "stderr=serial,lcd\0" + +/* + * Memory layout for where various images get loaded by boot scripts: + * + * I suspect address 0 is used as the SMP pen on the RPi2, so avoid this. + * + * fdt_addr_r simply shouldn't overlap anything else. However, the RPi's + * binary firmware loads a DT to address 0x100, so we choose this address to + * match it. This allows custom boot scripts to pass this DT on to Linux + * simply by not over-writing the data at this address. When using U-Boot, + * U-Boot (and scripts it executes) typicaly ignore the DT loaded by the FW + * and loads its own DT from disk (triggered by boot.scr or extlinux.conf). + * + * pxefile_addr_r can be pretty much anywhere that doesn't conflict with + * something else. Put it low in memory to avoid conflicts. + * + * kernel_addr_r must be within the first 128M of RAM in order for the + * kernel's CONFIG_AUTO_ZRELADDR option to work. Since the kernel will + * decompress itself to 0x8000 after the start of RAM, kernel_addr_r + * should not overlap that area, or the kernel will have to copy itself + * somewhere else before decompression. Similarly, the address of any other + * data passed to the kernel shouldn't overlap the start of RAM. Pushing + * this up to 16M allows for a sizable kernel to be decompressed below the + * compressed load address. + * + * scriptaddr can be pretty much anywhere that doesn't conflict with something + * else. Choosing 32M allows for the compressed kernel to be up to 16M. + * + * ramdisk_addr_r simply shouldn't overlap anything else. Choosing 33M allows + * for any boot script to be up to 1M, which is hopefully plenty. + */ +#define ENV_MEM_LAYOUT_SETTINGS \ + "fdt_high=ffffffff\0" \ + "initrd_high=ffffffff\0" \ + "fdt_addr_r=0x00000100\0" \ + "pxefile_addr_r=0x00100000\0" \ + "kernel_addr_r=0x01000000\0" \ + "scriptaddr=0x02000000\0" \ + "ramdisk_addr_r=0x02100000\0" \ + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(USB, usb, 0) \ + func(PXE, pxe, na) \ + func(DHCP, dhcp, na) +#include <config_distro_bootcmd.h> + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "dhcpuboot=usb start; dhcp u-boot.uimg; bootm\0" \ + ENV_DEVICE_SETTINGS \ + ENV_MEM_LAYOUT_SETTINGS \ + BOOTENV
-#include "rpi-common.h" +#define CONFIG_BOOTDELAY 2
#endif diff --git a/include/configs/rpi_2.h b/include/configs/rpi_2.h deleted file mode 100644 index 0917e8650864..000000000000 --- a/include/configs/rpi_2.h +++ /dev/null @@ -1,15 +0,0 @@ -/* - * (C) Copyright 2012,2015 Stephen Warren - * - * SPDX-License-Identifier: GPL-2.0 - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -#define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_SYS_CACHELINE_SIZE 64 - -#include "rpi-common.h" - -#endif diff --git a/include/configs/rpi_3.h b/include/configs/rpi_3.h deleted file mode 100644 index 0dd9e7e40aa0..000000000000 --- a/include/configs/rpi_3.h +++ /dev/null @@ -1,14 +0,0 @@ -/* - * (C) Copyright 2012-2016 Stephen Warren swarren@wwwdotorg.org - * - * SPDX-License-Identifier: GPL-2.0 - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -#define CONFIG_SYS_CACHELINE_SIZE 64 - -#include "rpi-common.h" - -#endif diff --git a/include/configs/rpi_3_32b.h b/include/configs/rpi_3_32b.h deleted file mode 100644 index c00379b9aa4d..000000000000 --- a/include/configs/rpi_3_32b.h +++ /dev/null @@ -1,15 +0,0 @@ -/* - * (C) Copyright 2012-2016 Stephen Warren swarren@wwwdotorg.org - * - * SPDX-License-Identifier: GPL-2.0 - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -#define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_SYS_CACHELINE_SIZE 64 - -#include "rpi-common.h" - -#endif
Thanks!
Am 03.04.2016 um 05:56 schrieb Stephen Warren:
"rpi*_defconfig"?
Also the sentence seems to be missing a verb - "Now that we use ..."?
"identity"?
Regards, Andreas
"rpi*_defconfig"?
Both regexes match the same set of files at present, but I prefer the one I wrote, since it guarantees that it only matches the word "rpi" at the start, not "rpi" followed by anything, which perhaps makes it slightly less likely to accidentally match any other board in the future.
"provide" is the verb. There should have been a command after "Kconfig" in the first line, or the comma before "provide" could be removed.
Am 04.04.2016 um 17:36 schrieb Stephen Warren:
"rpi*_defconfig"?
Sorry, missed the underscore in _2, we strip that in our package name.
Sure, makes sense.
Cheers, Andreas
Andreas Färber
Stephen Warren
