[U-Boot-Users] mail not added in mailing list, what's wrong?
Hi Wolfgang,
I am Arun, new in U-Boot, I have some queries regarding U-Boot, and to get the answers I sent a mail on Aug. 17, 2007, but that mail is not listed in mailing list. But when I am searching for that mail using particular string, I found that.
Can I know why this happen, and not included in list?
So, Again I am resending same mail.
---------- Forwarded message ---------- From: Arun Bothe group.arun@gmail.com Date: Aug 17, 2007 5:26 PM Subject: Hi, I am new to U-Boot, how do I get started? To: u-boot-users@lists.sourceforge.net
I am new to U-Boot. Currently I am working for adm5120 board. I read "readme" file, and "DULG.pdf", & U-Boot mailing archive also.
ADM5120 / ADM5120P Specs:
* 175MHz/227MIPS 4Kc CPU with an embedded cache, 8K-byte I-cache and 8K D-cache MIPS32 * 5 IEEE 802.e Fast Ethernet PHY interfaces and 1 GMII/MII interface * Two SDRAM banks (each bank 1M-32 up to 32Mx32Bit)(support upto 2Mx32Bytes) * Two Flash banks up to 4MB(NOR Flash and Nand Flash), and many more.
I have few questions regarding this, are
My "config.mk" file contains #ROM version TEXT_BASE = 0x80100000 PRE_TEXT_BASE = 0xBFC00000
Q1: TEXT_BASE is the location of U-Boot in RAM, means TEXT_BASE points to SDRAM perticular location? or tell more about TEXT_BASE. Q2: In my board setting CFG_MONITOR_BASE=TEXT_BASE, means my boot monitor code reading from EEPROM? ***************************** For my board setting #define CFG_SDRAM_BASE 0x80000000 and #define CFG_MEMTEST_START 0x80100000 #define CFG_MEMTEST_END 0x81000000
Q3: CFG_MEMTEST_START, and CFG_MEMTEST_END are simple memory test area, but I don't understand purpose of this test or which test and purpose? ***************************** In my board setting /* addresses for switch descriptors and buffers * reason for those fixed address is that the adm5120 switch * engine can only deploy descriptors and packet buffers * @ address < 16MB. * 0x80000000 ~ 0x80100000 is now reserved, so it SHOULD be safe * to put the addresses within this area */ #define CFG_PKTBUF_ADDR 0x800C0000 #define CFG_ARPBUF_ADDR 0x800D0000 #define CFG_DESC_ADDR 0x800F0000 Q4: means?
Q5: Which are the other important configuration macro's I've to study? or I've to pay more attention?
Q6: Where I get more help of U-Boot for ADM5120, excepts the above mentioned files?
Thanks
In message b92ccf4a0708180558t67c58862n344d140fa12f3bec@mail.gmail.com you wrote:
What makes you think so? I received your message just fine.
When you registered with the mailing list, you selected the "nodupes" option, whioch means that you asked the mailing list not to send you copies of your own messages. So you got exactly what you asked for.
Sending the same message again and again doesn't make you friends here...
------=_Part_44755_28186859.1187441915208 Content-Type: text/html; charset=ISO-8859-1 Content-Transfer-Encoding: 7bit Content-Disposition: inline
...especially since HTML is strictly forbidden, and HTML postings have a high change of being ignored.
Arun Bothe
