RE: [U-Boot-Users] BUBINGA405EP Platform
Bruce,
The problem may be caused by the CPU core reset within "pll_wait", which was from IBM's referenc code, I found it would cause system crashed.
Below is the modified code blocking the reset, which seems working fine.
Best regards, Taian
/* ! Wait min of 100us for PLL to lock. ! See CMOS 27E databook for more info. ! At 200MHz, that means waiting 20,000 instructions */ addi r3,0,20000 /* 2000 = 0x4e20 */ mtctr r3 pll_wait: bdnz pll_wait
andis. r3, r3, 0x0 /* to clear PCI reset bit */ mtdcr CPC0_SRR, r3
oris r5,r5,0x8000 /* Enable PLL */ mtdcr CPC0_PLLMR1,r5 /* Engage */ blr; /*no reset*/ /* * Reset CPU to guarantee timings are OK * Not sure if this is needed... */ #if 0 addis r3,0,0x1000 mtspr dbcr0,r3 /* This will cause a CPU core reset, and */ /* execution will continue from the poweron */ /* vector of 0xfffffffc */ #endif #endif /* CONFIG_405EP */
-----Original Message----- From: Bruce Boettjer [mailto:bruceb@momenco.com] Sent: Monday, December 08, 2003 5:10 PM To: u-boot-users@lists.sourceforge.net Subject: [U-Boot-Users] BUBINGA405EP Platform
It's me, again...
I have a bubinga 405 reference platform, and it behaves very well with the PROM from IBM, but I am unable to get u-boot running on it.
It takes an exception to either 0700 or 0200 after executing very early in the bootloader. The ppc405ep_init function just starts, and actually causes a machine exception on the 5th assy line... andi. R6,r5,8 which looks completely valid to me... At this point in the game, icache and dcache have been invalidated, and not much else has been done.
If someone has worked with the RISCwatch on this board, would you please send me your startup.cmd file?
Any ideas would be welcome...
Regards,
Bruce Boettjer Sr Hardware Design Engineer Momentum Computer 1815 Aston Ave Suite 107 Carlsbad, CA 92008 (760)-431-8663
------------------------------------------------------- This SF.net email is sponsored by: IBM Linux Tutorials. Become an expert in LINUX or just sharpen your skills. Sign up for IBM's Free Linux Tutorials. Learn everything from the bash shell to sys admin. Click now! http://ads.osdn.com/?ad_id=1278&alloc_id=3371&op=click _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Taian Su
