[U-Boot] [PATCH] powerpc/85xx: Add additional p4080 platform related defines/structs
* Added PCIE4 address, offset, DEVDISR & LAW target ID * Added new p4080 DDR registers and defines to immap * Add missing corenet platform DEVDISR related defines * Updated ccsr_gur to include LIODN registers * Add RCWSR defines * Added Basic qman, pme, bman immap structs * Added SATA related offsets & addresses * Added Frame Manager 1/2 offsets & addresses * Renamed CONFIG_SYS_TSEC1_OFFSET to CONFIG_SYS_FSL_FM1_DTSEC1_OFFSET * Added various offsets and addresses that where missing
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/include/asm/immap_85xx.h | 172 +++++++++++++++++++++++++++++---- 1 files changed, 154 insertions(+), 18 deletions(-)
diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index e65d665..a5e56d8 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -1646,6 +1646,8 @@ typedef struct ccsr_gur { #define FSL_CORENET_DEVDISR_DDR2 0x00080000 #define FSL_CORENET_DEVDISR_DBG 0x00010000 #define FSL_CORENET_DEVDISR_NAL 0x00008000 +#define FSL_CORENET_DEVDISR_SATA1 0x00004000 +#define FSL_CORENET_DEVDISR_SATA2 0x00002000 #define FSL_CORENET_DEVDISR_ELBC 0x00001000 #define FSL_CORENET_DEVDISR_USB1 0x00000800 #define FSL_CORENET_DEVDISR_USB2 0x00000400 @@ -1666,12 +1668,14 @@ typedef struct ccsr_gur { #define FSL_CORENET_DEVDISR2_DTSEC1_2 0x00400000 #define FSL_CORENET_DEVDISR2_DTSEC1_3 0x00200000 #define FSL_CORENET_DEVDISR2_DTSEC1_4 0x00100000 +#define FSL_CORENET_DEVDISR2_DTSEC1_5 0x00080000 #define FSL_CORENET_DEVDISR2_FM2 0x00020000 #define FSL_CORENET_DEVDISR2_10GEC2 0x00010000 #define FSL_CORENET_DEVDISR2_DTSEC2_1 0x00008000 #define FSL_CORENET_DEVDISR2_DTSEC2_2 0x00004000 #define FSL_CORENET_DEVDISR2_DTSEC2_3 0x00002000 #define FSL_CORENET_DEVDISR2_DTSEC2_4 0x00001000 +#define FSL_CORENET_NUM_DEVDISR 2 u8 res7[8]; u32 powmgtcsr; /* Power management status & control */ u8 res8[12]; @@ -1700,9 +1704,18 @@ typedef struct ccsr_gur { #define FSL_CORENET_RCWSR5_DDR_SYNC 0x00000080 #define FSL_CORENET_RCWSR5_DDR_SYNC_SHIFT 7 #define FSL_CORENET_RCWSR5_SRDS_EN 0x00002000 +#define FSL_CORENET_RCWSRn_SRDS_LPD_B2 0x3c000000 /* bits 162..165 */ +#define FSL_CORENET_RCWSRn_SRDS_LPD_B3 0x003c0000 /* bits 170..173 */ #define FSL_CORENET_RCWSR7_MCK_TO_PLAT_RAT 0x00400000 #define FSL_CORENET_RCWSR8_HOST_AGT_B1 0x00e00000 #define FSL_CORENET_RCWSR8_HOST_AGT_B2 0x00100000 +#define FSL_CORENET_RCWSR11_EC1 0x00c00000 /* bits 360..361 */ +#define FSL_CORENET_RCWSR11_EC1_FM1_DTSEC1 0x00000000 +#define FSL_CORENET_RCWSR11_EC1_FM1_USB1 0x00800000 +#define FSL_CORENET_RCWSR11_EC2 0x001c0000 /* bits 363..365 */ +#define FSL_CORENET_RCWSR11_EC2_FM2_DTSEC1 0x00000000 +#define FSL_CORENET_RCWSR11_EC2_FM1_DTSEC2 0x00080000 +#define FSL_CORENET_RCWSR11_EC2_USB2 0x00100000 u8 res18[192]; u32 scratchrw[4]; /* Scratch Read/Write */ u8 res19[240]; @@ -1726,10 +1739,15 @@ typedef struct ccsr_gur { u32 sdmmc2liodnr; /* SD/MMC 2 LIODN */ u32 sdmmc3liodnr; /* SD/MMC 3 LIODN */ u32 sdmmc4liodnr; /* SD/MMC 4 LIODN */ - u32 rmuliodnr; /* RIO Message Unit LIODN */ - u32 rduliodnr; /* RIO Doorbell Unit LIODN */ - u32 rpwuliodnr; /* RIO Port Write Unit LIODN */ - u8 res22[52]; + u32 rio1maintliodnr;/* RIO 1 Maintenance LIODN */ + u32 rio2maintliodnr;/* RIO 2 Maintenance LIODN */ + u32 rio3maintliodnr;/* RIO 3 Maintenance LIODN */ + u32 rio4maintliodnr;/* RIO 4 Maintenance LIODN */ + u32 sata1liodnr; /* SATA 1 LIODN */ + u32 sata2liodnr; /* SATA 2 LIODN */ + u32 sata3liodnr; /* SATA 3 LIODN */ + u32 sata4liodnr; /* SATA 4 LIODN */ + u8 res22[32]; u32 dma1liodnr; /* DMA 1 LIODN */ u32 dma2liodnr; /* DMA 2 LIODN */ u32 dma3liodnr; /* DMA 3 LIODN */ @@ -1764,6 +1782,12 @@ typedef struct ccsr_gur { u8 res37[380]; } ccsr_gur_t;
+/* + * On p4080 we have an LIODN for msg unit (rmu) but not maintenance + * everything after has RMan thus msg unit LIODN is used for maintenance + */ +#define rmuliodnr rio1maintliodnr + typedef struct ccsr_clk { u32 clkc0csr; /* Core 0 Clock control/status */ u8 res1[0x1c]; @@ -2032,38 +2056,125 @@ enum { /* Security Engine Block (MS = Most Sig., LS = Least Sig.) */ #if CONFIG_SYS_FSL_SEC_COMPAT >= 4 typedef struct ccsr_sec { - u8 res1[0xfa0]; + u32 res0; + u32 mcfgr; /* Master CFG Register */ + u8 res1[0x8]; + struct { + u32 ms; /* Job Ring LIODN Register, MS */ + u32 ls; /* Job Ring LIODN Register, LS */ + } jqliodnr[4]; + u8 res2[0x30]; + struct { + u32 ms; /* RTIC LIODN Register, MS */ + u32 ls; /* RTIC LIODN Register, LS */ + } rticliodnr[4]; + u8 res3[0x1c]; + u32 decorr; /* DECO Request Register */ + struct { + u32 ms; /* DECO LIODN Register, MS */ + u32 ls; /* DECO LIODN Register, LS */ + } decoliodnr[5]; + u8 res4[0x58]; + u32 dar; /* DECO Avail Register */ + u32 drr; /* DECO Reset Register */ + u8 res5[0xe78]; u32 crnr_ms; /* CHA Revision Number Register, MS */ u32 crnr_ls; /* CHA Revision Number Register, LS */ u32 ctpr_ms; /* Compile Time Parameters Register, MS */ -#define SEC_CTPR_MS_AXI_LIODN 0x08000000 -#define SEC_CTPR_MS_QI 0x02000000 u32 ctpr_ls; /* Compile Time Parameters Register, LS */ - u8 res2[0x10]; + u8 res6[0x10]; u32 far_ms; /* Fault Address Register, MS */ u32 far_ls; /* Fault Address Register, LS */ u32 falr; /* Fault Address LIODN Register */ u32 fadr; /* Fault Address Detail Register */ - u8 res3[0x4]; + u8 res7[0x4]; u32 csta; /* CAAM Status Register */ - u8 res4[0x8]; + u8 res8[0x8]; u32 rvid; /* Run Time Integrity Checking Version ID Reg.*/ -#define SEC_RVID_MA 0x0f000000 u32 ccbvid; /* CHA Cluster Block Version ID Register */ u32 chavid_ms; /* CHA Version ID Register, MS */ u32 chavid_ls; /* CHA Version ID Register, LS */ u32 chanum_ms; /* CHA Number Register, MS */ + u32 chanum_ls; /* CHA Number Register, LS */ + u32 secvid_ms; /* SEC Version ID Register, MS */ + u32 secvid_ls; /* SEC Version ID Register, LS */ + u8 res9[0x6020]; + u32 qilcr_ms; /* Queue Interface LIODN CFG Register, MS */ + u32 qilcr_ls; /* Queue Interface LIODN CFG Register, LS */ + u8 res10[0x8fd8]; +} ccsr_sec_t; + +#define SEC_CTPR_MS_AXI_LIODN 0x08000000 +#define SEC_CTPR_MS_QI 0x02000000 +#define SEC_RVID_MA 0x0f000000 #define SEC_CHANUM_MS_JQNUM_MASK 0xf0000000 #define SEC_CHANUM_MS_JQNUM_SHIFT 28 #define SEC_CHANUM_MS_DECONUM_MASK 0x0f000000 #define SEC_CHANUM_MS_DECONUM_SHIFT 24 - u32 chanum_ls; /* CHA Number Register, LS */ - u32 caamvid_ms; /* CAAM Version ID Register, MS */ - u32 caamvid_ls; /* CAAM Version ID Register, LS */ - u8 res5[0xf000]; -} ccsr_sec_t; #endif
+typedef struct ccsr_qman { + struct { + u32 qcsp_lio_cfg; /* 0x0 - SW Portal n LIO cfg */ + u32 qcsp_io_cfg; /* 0x4 - SW Portal n IO cfg */ + u32 res; + u32 qcsp_dd_cfg; /* 0xc - SW Portal n Dynamic Debug cfg */ + } qcsp[32]; + + /* Not actually reserved, but irrelevant to u-boot */ + u8 res[0xbf8 - 0x200]; + u32 ip_rev_1; + u32 ip_rev_2; + u32 fqd_bare; /* FQD Extended Base Addr Register */ + u32 fqd_bar; /* FQD Base Addr Register */ + u8 res1[0x8]; + u32 fqd_ar; /* FQD Attributes Register */ + u8 res2[0xc]; + u32 pfdr_bare; /* PFDR Extended Base Addr Register */ + u32 pfdr_bar; /* PFDR Base Addr Register */ + u8 res3[0x8]; + u32 pfdr_ar; /* PFDR Attributes Register */ + u8 res4[0x4c]; + u32 qcsp_bare; /* QCSP Extended Base Addr Register */ + u32 qcsp_bar; /* QCSP Base Addr Register */ + u8 res5[0x78]; + u32 ci_sched_cfg; /* Initiator Scheduling Configuration */ + u32 srcidr; /* Source ID Register */ + u32 liodnr; /* LIODN Register */ + u8 res6[4]; + u32 ci_rlm_cfg; /* Initiator Read Latency Monitor Cfg */ + u32 ci_rlm_avg; /* Initiator Read Latency Monitor Avg */ + u8 res7[0x2e8]; +} ccsr_qman_t; + +typedef struct ccsr_bman { + /* Not actually reserved, but irrelevant to u-boot */ + u8 res[0xbf8]; + u32 ip_rev_1; + u32 ip_rev_2; + u32 fbpr_bare; /* FBPR Extended Base Addr Register */ + u32 fbpr_bar; /* FBPR Base Addr Register */ + u8 res1[0x8]; + u32 fbpr_ar; /* FBPR Attributes Register */ + u8 res2[0xf0]; + u32 srcidr; /* Source ID Register */ + u32 liodnr; /* LIODN Register */ + u8 res7[0x2f4]; +} ccsr_bman_t; + +typedef struct ccsr_pme { + u8 res0[0x804]; + u32 liodnbr; /* LIODN Base Register */ + u8 res1[0x1f8]; + u32 srcidr; /* Source ID Register */ + u8 res2[8]; + u32 liodnr; /* LIODN Register */ + u8 res3[0x1e8]; + u32 pm_ip_rev_1; /* PME IP Block Revision Reg 1*/ + u32 pm_ip_rev_2; /* PME IP Block Revision Reg 1*/ + u8 res4[0x400]; +} ccsr_pme_t; + #ifdef CONFIG_FSL_CORENET #define CONFIG_SYS_FSL_CORENET_CCM_OFFSET 0x0000 #define CONFIG_SYS_MPC85xx_DDR_OFFSET 0x8000 @@ -2072,20 +2183,41 @@ typedef struct ccsr_sec { #define CONFIG_SYS_FSL_CORENET_RCPM_OFFSET 0xE2000 #define CONFIG_SYS_FSL_CORENET_SERDES_OFFSET 0xEA000 #define CONFIG_SYS_FSL_CPC_OFFSET 0x10000 -#define CONFIG_SYS_MPC85xx_DMA_OFFSET 0x100000 +#define CONFIG_SYS_MPC85xx_DMA1_OFFSET 0x100000 +#define CONFIG_SYS_MPC85xx_DMA2_OFFSET 0x101000 +#define CONFIG_SYS_MPC85xx_DMA_OFFSET CONFIG_SYS_MPC85xx_DMA1_OFFSET #define CONFIG_SYS_MPC85xx_ESPI_OFFSET 0x110000 #define CONFIG_SYS_MPC85xx_ESDHC_OFFSET 0x114000 #define CONFIG_SYS_MPC85xx_LBC_OFFSET 0x124000 #define CONFIG_SYS_MPC85xx_GPIO_OFFSET 0x130000 -#define CONFIG_SYS_MPC85xx_USB_OFFSET 0x210000 +#define CONFIG_SYS_MPC85xx_PCIE1_OFFSET 0x200000 +#define CONFIG_SYS_MPC85xx_PCIE2_OFFSET 0x201000 +#define CONFIG_SYS_MPC85xx_PCIE3_OFFSET 0x202000 +#define CONFIG_SYS_MPC85xx_PCIE4_OFFSET 0x203000 +#define CONFIG_SYS_MPC85xx_USB1_OFFSET 0x210000 +#define CONFIG_SYS_MPC85xx_USB2_OFFSET 0x211000 +#define CONFIG_SYS_MPC85xx_USB_OFFSET CONFIG_SYS_MPC85xx_USB1_OFFSET #define CONFIG_SYS_MPC85xx_SATA1_OFFSET 0x220000 #define CONFIG_SYS_MPC85xx_SATA2_OFFSET 0x221000 #define CONFIG_SYS_FSL_SEC_OFFSET 0x300000 +#define CONFIG_SYS_FSL_CORENET_PME_OFFSET 0x316000 #define CONFIG_SYS_FSL_CORENET_QMAN_OFFSET 0x318000 #define CONFIG_SYS_FSL_CORENET_BMAN_OFFSET 0x31a000 #define CONFIG_SYS_FSL_FM1_OFFSET 0x400000 +#define CONFIG_SYS_FSL_FM1_RX0_1G_OFFSET 0x488000 +#define CONFIG_SYS_FSL_FM1_RX1_1G_OFFSET 0x489000 +#define CONFIG_SYS_FSL_FM1_RX2_1G_OFFSET 0x48a000 +#define CONFIG_SYS_FSL_FM1_RX3_1G_OFFSET 0x48b000 +#define CONFIG_SYS_FSL_FM1_RX4_1G_OFFSET 0x48c000 +#define CONFIG_SYS_FSL_FM1_RX0_10G_OFFSET 0x490000 #define CONFIG_SYS_FSL_FM1_DTSEC1_OFFSET 0x4e0000 #define CONFIG_SYS_FSL_FM2_OFFSET 0x500000 +#define CONFIG_SYS_FSL_FM2_RX0_1G_OFFSET 0x588000 +#define CONFIG_SYS_FSL_FM2_RX1_1G_OFFSET 0x589000 +#define CONFIG_SYS_FSL_FM2_RX2_1G_OFFSET 0x58a000 +#define CONFIG_SYS_FSL_FM2_RX3_1G_OFFSET 0x58b000 +#define CONFIG_SYS_FSL_FM2_RX4_1G_OFFSET 0x58c000 +#define CONFIG_SYS_FSL_FM2_RX0_10G_OFFSET 0x590000 #else #define CONFIG_SYS_MPC85xx_ECM_OFFSET 0x0000 #define CONFIG_SYS_MPC85xx_DDR_OFFSET 0x2000 @@ -2130,6 +2262,8 @@ typedef struct ccsr_sec { (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CORENET_QMAN_OFFSET) #define CONFIG_SYS_FSL_CORENET_BMAN_ADDR \ (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CORENET_BMAN_OFFSET) +#define CONFIG_SYS_FSL_CORENET_PME_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CORENET_PME_OFFSET) #define CONFIG_SYS_MPC85xx_GUTS_ADDR \ (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_GUTS_OFFSET) #define CONFIG_SYS_FSL_CORENET_CCM_ADDR \ @@ -2195,6 +2329,8 @@ typedef struct ccsr_sec { (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_PCIE2_OFFSET) #define CONFIG_SYS_PCIE3_ADDR \ (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_PCIE3_OFFSET) +#define CONFIG_SYS_PCIE4_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_PCIE4_OFFSET)
#define TSEC_BASE_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_TSEC1_OFFSET) #define MDIO_BASE_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MDIO1_OFFSET)
Add basic structures for Frame Manager on P4080/P3041/P5020 devices
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/include/asm/fsl_fman.h | 212 +++++++++++++++++++++++++++++++++ arch/powerpc/include/asm/immap_85xx.h | 1 + 2 files changed, 213 insertions(+), 0 deletions(-) create mode 100644 arch/powerpc/include/asm/fsl_fman.h
diff --git a/arch/powerpc/include/asm/fsl_fman.h b/arch/powerpc/include/asm/fsl_fman.h new file mode 100644 index 0000000..6c01ffc --- /dev/null +++ b/arch/powerpc/include/asm/fsl_fman.h @@ -0,0 +1,212 @@ +/* + * MPC85xx Internal Memory Map + * + * Copyright 2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __FSL_FMAN_H__ +#define __FSL_FMAN_H__ + +#include <asm/types.h> + +typedef struct fm_bmi_common { + u32 fmbm_init; /* BMI initialization */ + u32 fmbm_cfg1; /* BMI configuration1 */ + u32 fmbm_cfg2; /* BMI configuration2 */ + u32 res0[0x5]; + u32 fmbm_ievr; /* interrupt event register */ + u32 fmbm_ier; /* interrupt enable register */ + u32 fmbm_ifr; /* interrupt force register */ + u32 res1[0x5]; + u32 fmbm_arb[0x8]; /* BMI arbitration */ + u32 res2[0x28]; + u32 fmbm_gde; /* global debug enable */ + u32 fmbm_pp[0x3f]; /* BMI port parameters */ + u32 res3; + u32 fmbm_pfs[0x3f]; /* BMI port FIFO size */ + u32 res4; + u32 fmbm_ppid[0x3f];/* port partition ID */ +} fm_bmi_common_t; + +typedef struct fm_qmi_common { + u32 fmqm_gc; /* general configuration register */ + u32 res0; + u32 fmqm_eie; /* error interrupt event register */ + u32 fmqm_eien; /* error interrupt enable register */ + u32 fmqm_eif; /* error interrupt force register */ + u32 fmqm_ie; /* interrupt event register */ + u32 fmqm_ien; /* interrupt enable register */ + u32 fmqm_if; /* interrupt force register */ + u32 fmqm_gs; /* global status register */ + u32 fmqm_ts; /* task status register */ + u32 fmqm_etfc; /* enqueue total frame counter */ + u32 fmqm_dtfc; /* dequeue total frame counter */ + u32 fmqm_dc0; /* dequeue counter 0 */ + u32 fmqm_dc1; /* dequeue counter 1 */ + u32 fmqm_dc2; /* dequeue counter 2 */ + u32 fmqm_dc3; /* dequeue counter 3 */ + u32 fmqm_dfnoc; /* dequeue FQID not override counter */ + u32 fmqm_dfcc; /* dequeue FQID from context counter */ + u32 fmqm_dffc; /* dequeue FQID from FD counter */ + u32 fmqm_dcc; /* dequeue confirm counter */ + u32 res1[0xc]; + u32 fmqm_dtrc; /* debug trap configuration register */ + u32 fmqm_efddd; /* enqueue frame descriptor dynamic debug */ + u32 res3[0x2]; + u32 res4[0xdc]; /* missing debug regs */ +} fm_qmi_common_t; + +typedef struct fm_bmi { + u8 res[1024]; +} fm_bmi_t; + +typedef struct fm_qmi { + u8 res[1024]; +} fm_qmi_t; + +typedef struct fm_parser { + u8 res[1024]; +} fm_parser_t; + +typedef struct fm_policer { + u8 res[4*1024]; +} fm_policer_t; + +typedef struct fm_keygen { + u8 res[4*1024]; +} fm_keygen_t; + +typedef struct fm_dma { + u32 fmdmsr; /* status register */ + u32 fmdmmr; /* mode register */ + u32 fmdmtr; /* bus threshold register */ + u32 fmdmhy; /* bus hysteresis register */ + u32 fmdmsetr; /* SOS emergency threshold register */ + u32 fmdmtah; /* transfer bus address high register */ + u32 fmdmtal; /* transfer bus address low register */ + u32 fmdmtcid; /* transfer bus communication ID register */ + u32 fmdmra; /* DMA bus internal ram address register */ + u32 fmdmrd; /* DMA bus internal ram data register */ + u32 res0[0xb]; + u32 fmdmdcr; /* debug counter */ + u32 fmdmemsr; /* emrgency smoother register */ + u32 res1; + u32 fmdmplr[32]; /* FM DMA PID-LIODN # register */ + u32 res[0x3c8]; +} fm_dma_t; + +typedef struct fm_fpm { + u32 fpmtnc; /* TNUM control */ + u32 fpmprc; /* Port_ID control */ + u32 res0; + u32 fpmflc; /* flush control */ + u32 fpmdis1; /* dispatch thresholds1 */ + u32 fpmdis2; /* dispatch thresholds2 */ + u32 fmepi; /* error pending interrupts */ + u32 fmrie; /* rams interrupt enable */ + u32 fpmfcevent[0x4];/* FMan controller event 0-3 */ + u32 res1[0x4]; + u32 fpmfcmask[0x4]; /* FMan controller mask 0-3 */ + u32 res2[0x4]; + u32 fpmtsc1; /* timestamp control1 */ + u32 fpmtsc2; /* timestamp control2 */ + u32 fpmtsp; /* time stamp */ + u32 fpmtsf; /* time stamp fraction */ + u32 fpmrcr; /* rams control and event */ + u32 res3[0x3]; + u32 fpmdrd[0x4]; /* data_ram data 0-3 */ + u32 res4[0xc]; + u32 fpmdra; /* data ram access */ + u32 fm_ip_rev_1; /* IP block revision 1 */ + u32 fm_ip_rev_2; /* IP block revision 2 */ + u32 fmrstc; /* reset command */ + u32 fmcld; /* classifier debug control */ + u32 fmnpi; /* normal pending interrupts */ + u32 res5; + u32 fmnee; /* event and enable */ + u32 fpmcev[0x4]; /* CPU event 0-3 */ + u32 res6[0x4]; + u32 fmfp_ps[0x40]; /* port status */ + u32 res7[0x260]; + u32 fpmts[0x80]; /* task status */ + u32 res8[0xa0]; +} fm_fpm_t; + +typedef struct fm_imem { + u8 res[4*1024]; +} fm_imem_t; + +typedef struct fm_soft_parser { + u8 res[4*1024]; +} fm_soft_parser_t; + +typedef struct fm_dtesc { + u8 res[4*1024]; +} fm_dtsec_t; + +typedef struct fm_mdio { + u8 res[4*1024]; +} fm_mdio_t; + +typedef struct fm_10gec { + u8 res[4*1024]; +} fm_10gec_t; + +typedef struct fm_10gec_mdio { + u8 res[4*1024]; +} fm_10gec_mdio_t; + +typedef struct fm_1588 { + u8 res[4*1024]; +} fm_1588_t; + +typedef struct ccsr_fman { + u8 muram[0x80000]; + fm_bmi_common_t fm_bmi_common; + fm_qmi_common_t fm_qmi_common; + u8 res0[2048]; + struct { + fm_bmi_t fm_bmi; + fm_qmi_t fm_qmi; + fm_parser_t fm_parser; + u8 res[1024]; + } port[63]; + fm_policer_t fm_policer; + fm_keygen_t fm_keygen; + fm_dma_t fm_dma; + fm_fpm_t fm_fpm; + fm_imem_t fm_imem; + u8 res1[8*1024]; + fm_soft_parser_t fm_soft_parser; + u8 res2[96*1024]; + struct { + fm_dtsec_t fm_dtesc; + fm_mdio_t fm_mdio; + } mac[4]; + u8 res3[32*1024]; + fm_10gec_t fm_10gec; + fm_10gec_mdio_t fm_10gec_mdio; + u8 res4[48*1024]; + fm_1588_t fm_1588; + u8 res5[4*1024]; +} ccsr_fman_t; + +#endif /*__FSL_FMAN_H__*/ diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index a5e56d8..f109e8c 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -32,6 +32,7 @@ #include <asm/fsl_dma.h> #include <asm/fsl_i2c.h> #include <asm/fsl_lbc.h> +#include <asm/fsl_fman.h>
typedef struct ccsr_local { u32 ccsrbarh; /* CCSR Base Addr High */
Move to using fdt_node_offset_by_compat_reg to find the node offsets we want to update instead of using aliases.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/fdt.c | 19 +++++++++++-------- 1 files changed, 11 insertions(+), 8 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/fdt.c b/arch/powerpc/cpu/mpc85xx/fdt.c index 2628cc5..b4354f9 100644 --- a/arch/powerpc/cpu/mpc85xx/fdt.c +++ b/arch/powerpc/cpu/mpc85xx/fdt.c @@ -298,17 +298,17 @@ void fdt_add_enet_stashing(void *fdt) }
#if defined(CONFIG_SYS_DPAA_FMAN) || defined(CONFIG_SYS_DPAA_PME) -static void ft_fixup_clks(void *blob, const char *alias, unsigned long freq) +static void ft_fixup_clks(void *blob, const char *compat, u32 offset, + unsigned long freq) { - const char *path = fdt_get_alias(blob, alias); - - int off = fdt_path_offset(blob, path); + phys_addr_t phys = offset + CONFIG_SYS_CCSRBAR_PHYS; + int off = fdt_node_offset_by_compat_reg(blob, compat, phys);
if (off >= 0) { off = fdt_setprop_cell(blob, off, "clock-frequency", freq); if (off > 0) printf("WARNING enable to set clock-frequency " - "for %s: %s\n", alias, fdt_strerror(off)); + "for %s: %s\n", compat, fdt_strerror(off)); } }
@@ -317,14 +317,17 @@ static void ft_fixup_dpaa_clks(void *blob) sys_info_t sysinfo;
get_sys_info(&sysinfo); - ft_fixup_clks(blob, "fman0", sysinfo.freqFMan[0]); + ft_fixup_clks(blob, "fsl,fman", CONFIG_SYS_FSL_FM1_OFFSET, + sysinfo.freqFMan[0]);
#if (CONFIG_SYS_NUM_FMAN == 2) - ft_fixup_clks(blob, "fman1", sysinfo.freqFMan[1]); + ft_fixup_clks(blob, "fsl,fman", CONFIG_SYS_FSL_FM2_OFFSET, + sysinfo.freqFMan[1]); #endif
#ifdef CONFIG_SYS_DPAA_PME - ft_fixup_clks(blob, "pme", sysinfo.freqPME); + do_fixup_by_compat_u32(blob, "fsl,pme", + "clock-frequency", sysinfo.freqPME, 1); #endif } #else
On QorIQ CoreNet based devices we have a global clocking block. We want to keep track of SYSCLK frequency as it is what is used to derive all other frequencies in the SoC
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/fdt.c | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/fdt.c b/arch/powerpc/cpu/mpc85xx/fdt.c index b4354f9..932466e 100644 --- a/arch/powerpc/cpu/mpc85xx/fdt.c +++ b/arch/powerpc/cpu/mpc85xx/fdt.c @@ -403,6 +403,11 @@ void ft_cpu_setup(void *blob, bd_t *bd) "clock-frequency", bd->bi_brgfreq, 1); #endif
+#ifdef CONFIG_FSL_CORENET + do_fixup_by_compat_u32(blob, "fsl,qoriq-clockgen-1.0", + "clock-frequency", CONFIG_SYS_CLK_FREQ, 1); +#endif + fdt_fixup_memory(blob, (u64)bd->bi_memstart, (u64)bd->bi_memsize);
#ifdef CONFIG_MP
The user manual refers to FMAN1 and FMAN2 not 0 and 1.
Signed-off-by: Emil Medve Emilian.Medve@Freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/cpu.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu.c b/arch/powerpc/cpu/mpc85xx/cpu.c index fe2b52d..f15d43c 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu.c +++ b/arch/powerpc/cpu/mpc85xx/cpu.c @@ -179,7 +179,7 @@ int checkcpu (void)
#ifdef CONFIG_SYS_DPAA_FMAN for (i = 0; i < CONFIG_SYS_NUM_FMAN; i++) { - printf(" FMAN%d: %s MHz\n", i, + printf(" FMAN%d: %s MHz\n", i + 1, strmhz(buf1, sysinfo.freqFMan[i])); } #endif
There are various locations that we have chip specific info:
* Makefile for which ddr code to build * Added p5020 & p5010 to cpu_type_list and SVR list * Added number of LAWs for p5020 * Set CONFIG_MAX_CPUS to 2 for p5020
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/Makefile | 1 + arch/powerpc/cpu/mpc8xxx/cpu.c | 4 ++++ arch/powerpc/include/asm/config.h | 2 ++ arch/powerpc/include/asm/processor.h | 4 ++++ drivers/misc/fsl_law.c | 2 +- 5 files changed, 12 insertions(+), 1 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/Makefile b/arch/powerpc/cpu/mpc85xx/Makefile index 4ee0e9a..2656dde 100644 --- a/arch/powerpc/cpu/mpc85xx/Makefile +++ b/arch/powerpc/cpu/mpc85xx/Makefile @@ -59,6 +59,7 @@ COBJS-$(CONFIG_P1022) += ddr-gen3.o COBJS-$(CONFIG_P2010) += ddr-gen3.o COBJS-$(CONFIG_P2020) += ddr-gen3.o COBJS-$(CONFIG_PPC_P4080) += ddr-gen3.o +COBJS-$(CONFIG_PPC_P5020) += ddr-gen3.o
COBJS-$(CONFIG_CPM2) += ether_fcc.o COBJS-$(CONFIG_OF_LIBFDT) += fdt.o diff --git a/arch/powerpc/cpu/mpc8xxx/cpu.c b/arch/powerpc/cpu/mpc8xxx/cpu.c index 22f3423..570ddb6 100644 --- a/arch/powerpc/cpu/mpc8xxx/cpu.c +++ b/arch/powerpc/cpu/mpc8xxx/cpu.c @@ -84,6 +84,10 @@ struct cpu_type cpu_type_list [] = { CPU_TYPE_ENTRY(P4040, P4040_E, 4), CPU_TYPE_ENTRY(P4080, P4080, 8), CPU_TYPE_ENTRY(P4080, P4080_E, 8), + CPU_TYPE_ENTRY(P5010, P5010, 1), + CPU_TYPE_ENTRY(P5010, P5010_E, 1), + CPU_TYPE_ENTRY(P5020, P5020, 2), + CPU_TYPE_ENTRY(P5020, P5020_E, 2), #elif defined(CONFIG_MPC86xx) CPU_TYPE_ENTRY(8610, 8610, 1), CPU_TYPE_ENTRY(8641, 8641, 2), diff --git a/arch/powerpc/include/asm/config.h b/arch/powerpc/include/asm/config.h index d88c282..f2f4188 100644 --- a/arch/powerpc/include/asm/config.h +++ b/arch/powerpc/include/asm/config.h @@ -46,6 +46,8 @@ #define CONFIG_MAX_CPUS 2 #elif defined(CONFIG_PPC_P4080) #define CONFIG_MAX_CPUS 8 +#elif defined(CONFIG_PPC_P5020) +#define CONFIG_MAX_CPUS 2 #else #define CONFIG_MAX_CPUS 1 #endif diff --git a/arch/powerpc/include/asm/processor.h b/arch/powerpc/include/asm/processor.h index 844552c..5e6364a 100644 --- a/arch/powerpc/include/asm/processor.h +++ b/arch/powerpc/include/asm/processor.h @@ -1056,6 +1056,10 @@ #define SVR_P4040_E 0x820900 #define SVR_P4080 0x820000 #define SVR_P4080_E 0x820800 +#define SVR_P5010 0x822100 +#define SVR_P5010_E 0x822900 +#define SVR_P5020 0x822000 +#define SVR_P5020_E 0x822800
#define SVR_8610 0x80A000 #define SVR_8641 0x809000 diff --git a/drivers/misc/fsl_law.c b/drivers/misc/fsl_law.c index 628bd59..22270f1 100644 --- a/drivers/misc/fsl_law.c +++ b/drivers/misc/fsl_law.c @@ -43,7 +43,7 @@ DECLARE_GLOBAL_DATA_PTR; defined(CONFIG_P1013) || defined(CONFIG_P1022) || \ defined(CONFIG_P2010) || defined(CONFIG_P2020) #define FSL_HW_NUM_LAWS 12 -#elif defined(CONFIG_PPC_P4080) +#elif defined(CONFIG_PPC_P4080) || defined(CONFIG_PPC_P5020) #define FSL_HW_NUM_LAWS 32 #else #error FSL_HW_NUM_LAWS not defined for this platform
* Makefile for which ddr code to build * Added p3041 to cpu_type_list and SVR list * Added number of LAWs for p3041 * Set CONFIG_MAX_CPUS to 4 for p3041
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/Makefile | 1 + arch/powerpc/cpu/mpc8xxx/cpu.c | 2 ++ arch/powerpc/include/asm/config.h | 2 ++ arch/powerpc/include/asm/processor.h | 2 ++ drivers/misc/fsl_law.c | 3 ++- 5 files changed, 9 insertions(+), 1 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/Makefile b/arch/powerpc/cpu/mpc85xx/Makefile index 2656dde..fe851f1 100644 --- a/arch/powerpc/cpu/mpc85xx/Makefile +++ b/arch/powerpc/cpu/mpc85xx/Makefile @@ -58,6 +58,7 @@ COBJS-$(CONFIG_P1021) += ddr-gen3.o COBJS-$(CONFIG_P1022) += ddr-gen3.o COBJS-$(CONFIG_P2010) += ddr-gen3.o COBJS-$(CONFIG_P2020) += ddr-gen3.o +COBJS-$(CONFIG_PPC_P3041) += ddr-gen3.o COBJS-$(CONFIG_PPC_P4080) += ddr-gen3.o COBJS-$(CONFIG_PPC_P5020) += ddr-gen3.o
diff --git a/arch/powerpc/cpu/mpc8xxx/cpu.c b/arch/powerpc/cpu/mpc8xxx/cpu.c index 570ddb6..dc3da16 100644 --- a/arch/powerpc/cpu/mpc8xxx/cpu.c +++ b/arch/powerpc/cpu/mpc8xxx/cpu.c @@ -80,6 +80,8 @@ struct cpu_type cpu_type_list [] = { CPU_TYPE_ENTRY(P2010, P2010_E, 1), CPU_TYPE_ENTRY(P2020, P2020, 2), CPU_TYPE_ENTRY(P2020, P2020_E, 2), + CPU_TYPE_ENTRY(P3041, P3041, 4), + CPU_TYPE_ENTRY(P3041, P3041_E, 4), CPU_TYPE_ENTRY(P4040, P4040, 4), CPU_TYPE_ENTRY(P4040, P4040_E, 4), CPU_TYPE_ENTRY(P4080, P4080, 8), diff --git a/arch/powerpc/include/asm/config.h b/arch/powerpc/include/asm/config.h index f2f4188..f70699d 100644 --- a/arch/powerpc/include/asm/config.h +++ b/arch/powerpc/include/asm/config.h @@ -44,6 +44,8 @@ defined(CONFIG_P1021) || defined(CONFIG_P1022) || \ defined(CONFIG_P2020) || defined(CONFIG_MPC8641) #define CONFIG_MAX_CPUS 2 +#elif defined(CONFIG_PPC_P3041) +#define CONFIG_MAX_CPUS 4 #elif defined(CONFIG_PPC_P4080) #define CONFIG_MAX_CPUS 8 #elif defined(CONFIG_PPC_P5020) diff --git a/arch/powerpc/include/asm/processor.h b/arch/powerpc/include/asm/processor.h index 5e6364a..89f283a 100644 --- a/arch/powerpc/include/asm/processor.h +++ b/arch/powerpc/include/asm/processor.h @@ -1052,6 +1052,8 @@ #define SVR_P2010_E 0x80EB00 #define SVR_P2020 0x80E200 #define SVR_P2020_E 0x80EA00 +#define SVR_P3041 0x821103 +#define SVR_P3041_E 0x821903 #define SVR_P4040 0x820100 #define SVR_P4040_E 0x820900 #define SVR_P4080 0x820000 diff --git a/drivers/misc/fsl_law.c b/drivers/misc/fsl_law.c index 22270f1..6589076 100644 --- a/drivers/misc/fsl_law.c +++ b/drivers/misc/fsl_law.c @@ -43,7 +43,8 @@ DECLARE_GLOBAL_DATA_PTR; defined(CONFIG_P1013) || defined(CONFIG_P1022) || \ defined(CONFIG_P2010) || defined(CONFIG_P2020) #define FSL_HW_NUM_LAWS 12 -#elif defined(CONFIG_PPC_P4080) || defined(CONFIG_PPC_P5020) +#elif defined(CONFIG_PPC_P3041) || defined(CONFIG_PPC_P4080) || \ + defined(CONFIG_PPC_P5020) #define FSL_HW_NUM_LAWS 32 #else #error FSL_HW_NUM_LAWS not defined for this platform
- Makefile for which ddr code to build
- Added p3041 to cpu_type_list and SVR list
- Added number of LAWs for p3041
- Set CONFIG_MAX_CPUS to 4 for p3041
applied to 85xx
- k
- Added p5020 & p5010 to cpu_type_list and SVR list
- Added number of LAWs for p5020
- Set CONFIG_MAX_CPUS to 2 for p5020
applied to 85xx
- k
applied to 85xx
- k
applied to 85xx
- k
applied to 85xx
- k
applied to 85xx
- k
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- * Previous version wasn't complete
arch/powerpc/include/asm/fsl_law.h | 3 +- arch/powerpc/include/asm/immap_85xx.h | 216 +++++++++++++++++++++++++++++--- 2 files changed, 197 insertions(+), 22 deletions(-)
diff --git a/arch/powerpc/include/asm/fsl_law.h b/arch/powerpc/include/asm/fsl_law.h index 12ba1a6..0e255ff 100644 --- a/arch/powerpc/include/asm/fsl_law.h +++ b/arch/powerpc/include/asm/fsl_law.h @@ -1,5 +1,5 @@ /* - * Copyright 2008-2009 Freescale Semiconductor, Inc. + * Copyright 2008-2010 Freescale Semiconductor, Inc. * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License @@ -54,6 +54,7 @@ enum law_trgt_if { LAW_TRGT_IF_PCIE_1 = 0x00, LAW_TRGT_IF_PCIE_2 = 0x01, LAW_TRGT_IF_PCIE_3 = 0x02, + LAW_TRGT_IF_PCIE_4 = 0x03, LAW_TRGT_IF_RIO_1 = 0x08, LAW_TRGT_IF_RIO_2 = 0x09,
diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index b1d219b..a5e56d8 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -172,7 +172,17 @@ typedef struct ccsr_ddr { u32 ddr_sr_cntr; /* self refresh counter */ u32 ddr_sdram_rcw_1; /* Control Words 1 */ u32 ddr_sdram_rcw_2; /* Control Words 2 */ - u8 res8_1b[2456]; + u8 reg_1ab[8]; + u32 ddr_wrlvl_cntl_2; /* write leveling control 2 */ + u32 ddr_wrlvl_cntl_3; /* write leveling control 3 */ + u8 res8_1b[104]; + u32 sdram_mode_3; /* SDRAM Mode Configuration 3 */ + u32 sdram_mode_4; /* SDRAM Mode Configuration 4 */ + u32 sdram_mode_5; /* SDRAM Mode Configuration 5 */ + u32 sdram_mode_6; /* SDRAM Mode Configuration 6 */ + u32 sdram_mode_7; /* SDRAM Mode Configuration 7 */ + u32 sdram_mode_8; /* SDRAM Mode Configuration 8 */ + u8 res8_1ba[0x908]; u32 ddr_dsr1; /* Debug Status 1 */ u32 ddr_dsr2; /* Debug Status 2 */ u32 ddr_cdr1; /* Control Driver 1 */ @@ -180,7 +190,21 @@ typedef struct ccsr_ddr { u8 res8_1c[200]; u32 ip_rev1; /* IP Block Revision 1 */ u32 ip_rev2; /* IP Block Revision 2 */ - u8 res8_2[512]; + u32 eor; /* Enhanced Optimization Register */ + u8 res8_2[252]; + u32 mtcr; /* Memory Test Control Register */ + u8 res8_3[28]; + u32 mtp1; /* Memory Test Pattern 1 */ + u32 mtp2; /* Memory Test Pattern 2 */ + u32 mtp3; /* Memory Test Pattern 3 */ + u32 mtp4; /* Memory Test Pattern 4 */ + u32 mtp5; /* Memory Test Pattern 5 */ + u32 mtp6; /* Memory Test Pattern 6 */ + u32 mtp7; /* Memory Test Pattern 7 */ + u32 mtp8; /* Memory Test Pattern 8 */ + u32 mtp9; /* Memory Test Pattern 9 */ + u32 mtp10; /* Memory Test Pattern 10 */ + u8 res8_4[184]; u32 data_err_inject_hi; /* Data Path Err Injection Mask High */ u32 data_err_inject_lo; /* Data Path Err Injection Mask Low */ u32 ecc_err_inject; /* Data Path Err Injection Mask ECC */ @@ -218,6 +242,9 @@ typedef struct ccsr_ddr { u8 res12[184]; } ccsr_ddr_t;
+#define DDR_EOR_RD_BDW_OPT_DIS 0x80000000 /* Read BDW Opt. disable */ +#define DDR_EOR_ADDR_HASH_EN 0x40000000 /* Address hash enabled */ + /* I2C Registers */ typedef struct ccsr_i2c { struct fsl_i2c i2c[1]; @@ -1609,6 +1636,7 @@ typedef struct ccsr_gur { #define FSL_CORENET_DEVDISR_PCIE1 0x80000000 #define FSL_CORENET_DEVDISR_PCIE2 0x40000000 #define FSL_CORENET_DEVDISR_PCIE3 0x20000000 +#define FSL_CORENET_DEVDISR_PCIE4 0x10000000 #define FSL_CORENET_DEVDISR_RMU 0x08000000 #define FSL_CORENET_DEVDISR_SRIO1 0x04000000 #define FSL_CORENET_DEVDISR_SRIO2 0x02000000 @@ -1618,6 +1646,8 @@ typedef struct ccsr_gur { #define FSL_CORENET_DEVDISR_DDR2 0x00080000 #define FSL_CORENET_DEVDISR_DBG 0x00010000 #define FSL_CORENET_DEVDISR_NAL 0x00008000 +#define FSL_CORENET_DEVDISR_SATA1 0x00004000 +#define FSL_CORENET_DEVDISR_SATA2 0x00002000 #define FSL_CORENET_DEVDISR_ELBC 0x00001000 #define FSL_CORENET_DEVDISR_USB1 0x00000800 #define FSL_CORENET_DEVDISR_USB2 0x00000400 @@ -1638,12 +1668,14 @@ typedef struct ccsr_gur { #define FSL_CORENET_DEVDISR2_DTSEC1_2 0x00400000 #define FSL_CORENET_DEVDISR2_DTSEC1_3 0x00200000 #define FSL_CORENET_DEVDISR2_DTSEC1_4 0x00100000 +#define FSL_CORENET_DEVDISR2_DTSEC1_5 0x00080000 #define FSL_CORENET_DEVDISR2_FM2 0x00020000 #define FSL_CORENET_DEVDISR2_10GEC2 0x00010000 #define FSL_CORENET_DEVDISR2_DTSEC2_1 0x00008000 #define FSL_CORENET_DEVDISR2_DTSEC2_2 0x00004000 #define FSL_CORENET_DEVDISR2_DTSEC2_3 0x00002000 #define FSL_CORENET_DEVDISR2_DTSEC2_4 0x00001000 +#define FSL_CORENET_NUM_DEVDISR 2 u8 res7[8]; u32 powmgtcsr; /* Power management status & control */ u8 res8[12]; @@ -1672,9 +1704,18 @@ typedef struct ccsr_gur { #define FSL_CORENET_RCWSR5_DDR_SYNC 0x00000080 #define FSL_CORENET_RCWSR5_DDR_SYNC_SHIFT 7 #define FSL_CORENET_RCWSR5_SRDS_EN 0x00002000 +#define FSL_CORENET_RCWSRn_SRDS_LPD_B2 0x3c000000 /* bits 162..165 */ +#define FSL_CORENET_RCWSRn_SRDS_LPD_B3 0x003c0000 /* bits 170..173 */ #define FSL_CORENET_RCWSR7_MCK_TO_PLAT_RAT 0x00400000 #define FSL_CORENET_RCWSR8_HOST_AGT_B1 0x00e00000 #define FSL_CORENET_RCWSR8_HOST_AGT_B2 0x00100000 +#define FSL_CORENET_RCWSR11_EC1 0x00c00000 /* bits 360..361 */ +#define FSL_CORENET_RCWSR11_EC1_FM1_DTSEC1 0x00000000 +#define FSL_CORENET_RCWSR11_EC1_FM1_USB1 0x00800000 +#define FSL_CORENET_RCWSR11_EC2 0x001c0000 /* bits 363..365 */ +#define FSL_CORENET_RCWSR11_EC2_FM2_DTSEC1 0x00000000 +#define FSL_CORENET_RCWSR11_EC2_FM1_DTSEC2 0x00080000 +#define FSL_CORENET_RCWSR11_EC2_USB2 0x00100000 u8 res18[192]; u32 scratchrw[4]; /* Scratch Read/Write */ u8 res19[240]; @@ -1698,10 +1739,15 @@ typedef struct ccsr_gur { u32 sdmmc2liodnr; /* SD/MMC 2 LIODN */ u32 sdmmc3liodnr; /* SD/MMC 3 LIODN */ u32 sdmmc4liodnr; /* SD/MMC 4 LIODN */ - u32 rmuliodnr; /* RIO Message Unit LIODN */ - u32 rduliodnr; /* RIO Doorbell Unit LIODN */ - u32 rpwuliodnr; /* RIO Port Write Unit LIODN */ - u8 res22[52]; + u32 rio1maintliodnr;/* RIO 1 Maintenance LIODN */ + u32 rio2maintliodnr;/* RIO 2 Maintenance LIODN */ + u32 rio3maintliodnr;/* RIO 3 Maintenance LIODN */ + u32 rio4maintliodnr;/* RIO 4 Maintenance LIODN */ + u32 sata1liodnr; /* SATA 1 LIODN */ + u32 sata2liodnr; /* SATA 2 LIODN */ + u32 sata3liodnr; /* SATA 3 LIODN */ + u32 sata4liodnr; /* SATA 4 LIODN */ + u8 res22[32]; u32 dma1liodnr; /* DMA 1 LIODN */ u32 dma2liodnr; /* DMA 2 LIODN */ u32 dma3liodnr; /* DMA 3 LIODN */ @@ -1736,6 +1782,12 @@ typedef struct ccsr_gur { u8 res37[380]; } ccsr_gur_t;
+/* + * On p4080 we have an LIODN for msg unit (rmu) but not maintenance + * everything after has RMan thus msg unit LIODN is used for maintenance + */ +#define rmuliodnr rio1maintliodnr + typedef struct ccsr_clk { u32 clkc0csr; /* Core 0 Clock control/status */ u8 res1[0x1c]; @@ -2004,38 +2056,125 @@ enum { /* Security Engine Block (MS = Most Sig., LS = Least Sig.) */ #if CONFIG_SYS_FSL_SEC_COMPAT >= 4 typedef struct ccsr_sec { - u8 res1[0xfa0]; + u32 res0; + u32 mcfgr; /* Master CFG Register */ + u8 res1[0x8]; + struct { + u32 ms; /* Job Ring LIODN Register, MS */ + u32 ls; /* Job Ring LIODN Register, LS */ + } jqliodnr[4]; + u8 res2[0x30]; + struct { + u32 ms; /* RTIC LIODN Register, MS */ + u32 ls; /* RTIC LIODN Register, LS */ + } rticliodnr[4]; + u8 res3[0x1c]; + u32 decorr; /* DECO Request Register */ + struct { + u32 ms; /* DECO LIODN Register, MS */ + u32 ls; /* DECO LIODN Register, LS */ + } decoliodnr[5]; + u8 res4[0x58]; + u32 dar; /* DECO Avail Register */ + u32 drr; /* DECO Reset Register */ + u8 res5[0xe78]; u32 crnr_ms; /* CHA Revision Number Register, MS */ u32 crnr_ls; /* CHA Revision Number Register, LS */ u32 ctpr_ms; /* Compile Time Parameters Register, MS */ -#define SEC_CTPR_MS_AXI_LIODN 0x08000000 -#define SEC_CTPR_MS_QI 0x02000000 u32 ctpr_ls; /* Compile Time Parameters Register, LS */ - u8 res2[0x10]; + u8 res6[0x10]; u32 far_ms; /* Fault Address Register, MS */ u32 far_ls; /* Fault Address Register, LS */ u32 falr; /* Fault Address LIODN Register */ u32 fadr; /* Fault Address Detail Register */ - u8 res3[0x4]; + u8 res7[0x4]; u32 csta; /* CAAM Status Register */ - u8 res4[0x8]; + u8 res8[0x8]; u32 rvid; /* Run Time Integrity Checking Version ID Reg.*/ -#define SEC_RVID_MA 0x0f000000 u32 ccbvid; /* CHA Cluster Block Version ID Register */ u32 chavid_ms; /* CHA Version ID Register, MS */ u32 chavid_ls; /* CHA Version ID Register, LS */ u32 chanum_ms; /* CHA Number Register, MS */ + u32 chanum_ls; /* CHA Number Register, LS */ + u32 secvid_ms; /* SEC Version ID Register, MS */ + u32 secvid_ls; /* SEC Version ID Register, LS */ + u8 res9[0x6020]; + u32 qilcr_ms; /* Queue Interface LIODN CFG Register, MS */ + u32 qilcr_ls; /* Queue Interface LIODN CFG Register, LS */ + u8 res10[0x8fd8]; +} ccsr_sec_t; + +#define SEC_CTPR_MS_AXI_LIODN 0x08000000 +#define SEC_CTPR_MS_QI 0x02000000 +#define SEC_RVID_MA 0x0f000000 #define SEC_CHANUM_MS_JQNUM_MASK 0xf0000000 #define SEC_CHANUM_MS_JQNUM_SHIFT 28 #define SEC_CHANUM_MS_DECONUM_MASK 0x0f000000 #define SEC_CHANUM_MS_DECONUM_SHIFT 24 - u32 chanum_ls; /* CHA Number Register, LS */ - u32 caamvid_ms; /* CAAM Version ID Register, MS */ - u32 caamvid_ls; /* CAAM Version ID Register, LS */ - u8 res5[0xf000]; -} ccsr_sec_t; #endif
+typedef struct ccsr_qman { + struct { + u32 qcsp_lio_cfg; /* 0x0 - SW Portal n LIO cfg */ + u32 qcsp_io_cfg; /* 0x4 - SW Portal n IO cfg */ + u32 res; + u32 qcsp_dd_cfg; /* 0xc - SW Portal n Dynamic Debug cfg */ + } qcsp[32]; + + /* Not actually reserved, but irrelevant to u-boot */ + u8 res[0xbf8 - 0x200]; + u32 ip_rev_1; + u32 ip_rev_2; + u32 fqd_bare; /* FQD Extended Base Addr Register */ + u32 fqd_bar; /* FQD Base Addr Register */ + u8 res1[0x8]; + u32 fqd_ar; /* FQD Attributes Register */ + u8 res2[0xc]; + u32 pfdr_bare; /* PFDR Extended Base Addr Register */ + u32 pfdr_bar; /* PFDR Base Addr Register */ + u8 res3[0x8]; + u32 pfdr_ar; /* PFDR Attributes Register */ + u8 res4[0x4c]; + u32 qcsp_bare; /* QCSP Extended Base Addr Register */ + u32 qcsp_bar; /* QCSP Base Addr Register */ + u8 res5[0x78]; + u32 ci_sched_cfg; /* Initiator Scheduling Configuration */ + u32 srcidr; /* Source ID Register */ + u32 liodnr; /* LIODN Register */ + u8 res6[4]; + u32 ci_rlm_cfg; /* Initiator Read Latency Monitor Cfg */ + u32 ci_rlm_avg; /* Initiator Read Latency Monitor Avg */ + u8 res7[0x2e8]; +} ccsr_qman_t; + +typedef struct ccsr_bman { + /* Not actually reserved, but irrelevant to u-boot */ + u8 res[0xbf8]; + u32 ip_rev_1; + u32 ip_rev_2; + u32 fbpr_bare; /* FBPR Extended Base Addr Register */ + u32 fbpr_bar; /* FBPR Base Addr Register */ + u8 res1[0x8]; + u32 fbpr_ar; /* FBPR Attributes Register */ + u8 res2[0xf0]; + u32 srcidr; /* Source ID Register */ + u32 liodnr; /* LIODN Register */ + u8 res7[0x2f4]; +} ccsr_bman_t; + +typedef struct ccsr_pme { + u8 res0[0x804]; + u32 liodnbr; /* LIODN Base Register */ + u8 res1[0x1f8]; + u32 srcidr; /* Source ID Register */ + u8 res2[8]; + u32 liodnr; /* LIODN Register */ + u8 res3[0x1e8]; + u32 pm_ip_rev_1; /* PME IP Block Revision Reg 1*/ + u32 pm_ip_rev_2; /* PME IP Block Revision Reg 1*/ + u8 res4[0x400]; +} ccsr_pme_t; + #ifdef CONFIG_FSL_CORENET #define CONFIG_SYS_FSL_CORENET_CCM_OFFSET 0x0000 #define CONFIG_SYS_MPC85xx_DDR_OFFSET 0x8000 @@ -2044,16 +2183,41 @@ typedef struct ccsr_sec { #define CONFIG_SYS_FSL_CORENET_RCPM_OFFSET 0xE2000 #define CONFIG_SYS_FSL_CORENET_SERDES_OFFSET 0xEA000 #define CONFIG_SYS_FSL_CPC_OFFSET 0x10000 -#define CONFIG_SYS_MPC85xx_DMA_OFFSET 0x100000 +#define CONFIG_SYS_MPC85xx_DMA1_OFFSET 0x100000 +#define CONFIG_SYS_MPC85xx_DMA2_OFFSET 0x101000 +#define CONFIG_SYS_MPC85xx_DMA_OFFSET CONFIG_SYS_MPC85xx_DMA1_OFFSET #define CONFIG_SYS_MPC85xx_ESPI_OFFSET 0x110000 #define CONFIG_SYS_MPC85xx_ESDHC_OFFSET 0x114000 #define CONFIG_SYS_MPC85xx_LBC_OFFSET 0x124000 #define CONFIG_SYS_MPC85xx_GPIO_OFFSET 0x130000 -#define CONFIG_SYS_MPC85xx_USB_OFFSET 0x210000 +#define CONFIG_SYS_MPC85xx_PCIE1_OFFSET 0x200000 +#define CONFIG_SYS_MPC85xx_PCIE2_OFFSET 0x201000 +#define CONFIG_SYS_MPC85xx_PCIE3_OFFSET 0x202000 +#define CONFIG_SYS_MPC85xx_PCIE4_OFFSET 0x203000 +#define CONFIG_SYS_MPC85xx_USB1_OFFSET 0x210000 +#define CONFIG_SYS_MPC85xx_USB2_OFFSET 0x211000 +#define CONFIG_SYS_MPC85xx_USB_OFFSET CONFIG_SYS_MPC85xx_USB1_OFFSET +#define CONFIG_SYS_MPC85xx_SATA1_OFFSET 0x220000 +#define CONFIG_SYS_MPC85xx_SATA2_OFFSET 0x221000 #define CONFIG_SYS_FSL_SEC_OFFSET 0x300000 +#define CONFIG_SYS_FSL_CORENET_PME_OFFSET 0x316000 #define CONFIG_SYS_FSL_CORENET_QMAN_OFFSET 0x318000 #define CONFIG_SYS_FSL_CORENET_BMAN_OFFSET 0x31a000 -#define CONFIG_SYS_TSEC1_OFFSET 0x4e0000 /* FM1@DTSEC0 */ +#define CONFIG_SYS_FSL_FM1_OFFSET 0x400000 +#define CONFIG_SYS_FSL_FM1_RX0_1G_OFFSET 0x488000 +#define CONFIG_SYS_FSL_FM1_RX1_1G_OFFSET 0x489000 +#define CONFIG_SYS_FSL_FM1_RX2_1G_OFFSET 0x48a000 +#define CONFIG_SYS_FSL_FM1_RX3_1G_OFFSET 0x48b000 +#define CONFIG_SYS_FSL_FM1_RX4_1G_OFFSET 0x48c000 +#define CONFIG_SYS_FSL_FM1_RX0_10G_OFFSET 0x490000 +#define CONFIG_SYS_FSL_FM1_DTSEC1_OFFSET 0x4e0000 +#define CONFIG_SYS_FSL_FM2_OFFSET 0x500000 +#define CONFIG_SYS_FSL_FM2_RX0_1G_OFFSET 0x588000 +#define CONFIG_SYS_FSL_FM2_RX1_1G_OFFSET 0x589000 +#define CONFIG_SYS_FSL_FM2_RX2_1G_OFFSET 0x58a000 +#define CONFIG_SYS_FSL_FM2_RX3_1G_OFFSET 0x58b000 +#define CONFIG_SYS_FSL_FM2_RX4_1G_OFFSET 0x58c000 +#define CONFIG_SYS_FSL_FM2_RX0_10G_OFFSET 0x590000 #else #define CONFIG_SYS_MPC85xx_ECM_OFFSET 0x0000 #define CONFIG_SYS_MPC85xx_DDR_OFFSET 0x2000 @@ -2098,6 +2262,8 @@ typedef struct ccsr_sec { (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CORENET_QMAN_OFFSET) #define CONFIG_SYS_FSL_CORENET_BMAN_ADDR \ (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CORENET_BMAN_OFFSET) +#define CONFIG_SYS_FSL_CORENET_PME_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CORENET_PME_OFFSET) #define CONFIG_SYS_MPC85xx_GUTS_ADDR \ (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_GUTS_OFFSET) #define CONFIG_SYS_FSL_CORENET_CCM_ADDR \ @@ -2146,6 +2312,12 @@ typedef struct ccsr_sec { (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_USB_OFFSET) #define CONFIG_SYS_FSL_SEC_ADDR \ (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_SEC_OFFSET) +#define CONFIG_SYS_FSL_FM1_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_FM1_OFFSET) +#define CONFIG_SYS_FSL_FM1_DTSEC1_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_FM1_DTSEC1_OFFSET) +#define CONFIG_SYS_FSL_FM2_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_FM2_OFFSET)
#define CONFIG_SYS_PCI1_ADDR \ (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_PCI1_OFFSET) @@ -2157,6 +2329,8 @@ typedef struct ccsr_sec { (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_PCIE2_OFFSET) #define CONFIG_SYS_PCIE3_ADDR \ (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_PCIE3_OFFSET) +#define CONFIG_SYS_PCIE4_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_PCIE4_OFFSET)
On Jul 21, 2010, at 12:42 AM, Kumar Gala wrote:
- Added PCIE4 address, offset, DEVDISR & LAW target ID
- Added new p4080 DDR registers and defines to immap
- Add missing corenet platform DEVDISR related defines
- Updated ccsr_gur to include LIODN registers
- Add RCWSR defines
- Added Basic qman, pme, bman immap structs
- Added SATA related offsets & addresses
- Added Frame Manager 1/2 offsets & addresses
- Renamed CONFIG_SYS_TSEC1_OFFSET to CONFIG_SYS_FSL_FM1_DTSEC1_OFFSET
- Added various offsets and addresses that where missing
- Previous version wasn't complete
applied to 85xx
- k
Kumar Gala
