[U-Boot] [PATCH v2 1/2] x86: Move i8254_init() to x86_cpu_init_f()
Right now i8254_init() is called from timer_init() in the tsc timer driver. But actually i8254 and tsc are completely different things. Since tsc timer has been converted to driver model, we should find a new place that is appropriate for U-Boot to call i8254_init(), which is now x86_cpu_init_f().
Signed-off-by: Bin Meng bmeng.cn@gmail.com Acked-by: Simon Glass sjg@chromium.org
Changes in v2: - Rebase on top of u-boot/master - Reorder the patches so that patch#2 in v1 comes first in v2
arch/x86/cpu/cpu.c | 5 +++++ drivers/timer/tsc_timer.c | 10 ---------- 2 files changed, 5 insertions(+), 10 deletions(-)
diff --git a/arch/x86/cpu/cpu.c b/arch/x86/cpu/cpu.c index 1707993..381d835 100644 --- a/arch/x86/cpu/cpu.c +++ b/arch/x86/cpu/cpu.c @@ -399,6 +399,11 @@ int x86_cpu_init_f(void) } }
+#ifdef CONFIG_I8254_TIMER + /* Set up the i8254 timer if required */ + i8254_init(); +#endif + return 0; }
diff --git a/drivers/timer/tsc_timer.c b/drivers/timer/tsc_timer.c index 6aa2437..5c4ec00 100644 --- a/drivers/timer/tsc_timer.c +++ b/drivers/timer/tsc_timer.c @@ -325,16 +325,6 @@ void __udelay(unsigned long usec) #endif }
-int timer_init(void) -{ -#ifdef CONFIG_I8254_TIMER - /* Set up the i8254 timer if required */ - i8254_init(); -#endif - - return 0; -} - static int tsc_timer_get_count(struct udevice *dev, u64 *count) { u64 now_tick = rdtsc();
With driver model timer support, there should not be an explict call to timer_init(). Remove this call for x86.
Changes in v2: None
common/board_f.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/board_f.c b/common/board_f.c index eac7c5e..b407354 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -825,7 +825,7 @@ static init_fnc_t init_sequence_f[] = { /* TODO: can we rename this to timer_init()? */ init_timebase, #endif -#if defined(CONFIG_X86) || defined(CONFIG_ARM) || defined(CONFIG_MIPS) || \ +#if defined(CONFIG_ARM) || defined(CONFIG_MIPS) || \ defined(CONFIG_BLACKFIN) || defined(CONFIG_NDS32) || \ defined(CONFIG_SPARC) timer_init, /* initialize timer */
applied to u-boot-x86/master, thanks!
Bin Meng
