[PATCH] pxe_utils: Fix arguments to x86 zboot
bootm and zboot accept different arguments:
bootm [addr [arg ...]]
- boot application image stored in memory passing arguments 'arg ...'; when booting a Linux kernel, 'arg' can be the address of an initrd image
zboot [addr] [size] [initrd addr] [initrd size] [setup] [cmdline] addr - The optional starting address of the bzimage. If not set it defaults to the environment variable "fileaddr". size - The optional size of the bzimage. Defaults to zero. initrd addr - The address of the initrd image to use, if any. initrd size - The size of the initrd image to use, if any.
In the zboot flow, the current code will reuse the bootm args and attempt to pass the initrd arg (argv[2]) as the kernel size (should be argv[3]). zboot also expects the initrd address and size to be separate arguments.
Let's untangle them and have separate argv/argc locals.
Signed-off-by: Zhaofeng Li hello@zhaofeng.li Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com
diff --git a/cmd/pxe_utils.c b/cmd/pxe_utils.c index 067c24e5ff..78ebfdcc79 100644 --- a/cmd/pxe_utils.c +++ b/cmd/pxe_utils.c @@ -441,11 +441,14 @@ skip_overlay: static int label_boot(struct cmd_tbl *cmdtp, struct pxe_label *label) { char *bootm_argv[] = { "bootm", NULL, NULL, NULL, NULL }; + char *zboot_argv[] = { "zboot", NULL, "0", NULL, NULL }; char initrd_str[28]; + char initrd_filesize[10]; char mac_str[29] = ""; char ip_str[68] = ""; char *fit_addr = NULL; int bootm_argc = 2; + int zboot_argc = 3; int len = 0; ulong kernel_addr; void *buf; @@ -478,6 +481,11 @@ static int label_boot(struct cmd_tbl *cmdtp, struct pxe_label *label) strcat(bootm_argv[2], ":"); strncat(bootm_argv[2], env_get("filesize"), 9); bootm_argc = 3; + + strncpy(initrd_filesize, env_get("filesize"), 9); + zboot_argv[3] = env_get("ramdisk_addr_r"); + zboot_argv[4] = initrd_filesize; + zboot_argc = 5; }
if (get_relfile_envaddr(cmdtp, label->kernel, "kernel_addr_r") < 0) { @@ -529,6 +537,8 @@ static int label_boot(struct cmd_tbl *cmdtp, struct pxe_label *label) }
bootm_argv[1] = env_get("kernel_addr_r"); + zboot_argv[1] = env_get("kernel_addr_r"); + /* for FIT, append the configuration identifier */ if (label->config) { int len = strlen(bootm_argv[1]) + strlen(label->config) + 1; @@ -665,7 +675,7 @@ static int label_boot(struct cmd_tbl *cmdtp, struct pxe_label *label) do_bootz(cmdtp, 0, bootm_argc, bootm_argv); /* Try booting an x86_64 Linux kernel image */ else if (IS_ENABLED(CONFIG_CMD_ZBOOT)) - do_zboot_parent(cmdtp, 0, bootm_argc, bootm_argv, NULL); + do_zboot_parent(cmdtp, 0, zboot_argc, zboot_argv, NULL);
unmap_sysmem(buf);
Hi Zhaofeng,
zboot_argc = 5; } if (get_relfile_envaddr(cmdtp, label->kernel, "kernel_addr_r") < 0) {
do_zboot_parent(cmdtp, 0, zboot_argc, zboot_argv, NULL); unmap_sysmem(buf);
-- 2.33.0
The real fix here will be when we can call the boot/zimage code more directly, rather than via the CLI.
Would it be worth adding more local variables for the strings being created? We already have initrd_str and mac_str, for example. We could add one for kernel_addr and ramdisk_addr:
char *ramdisk_addr
ramdisk_addr = env_get("ramdisk_addr_r")
It means that the bootm_argv[1] and bootm_argv[2] references would be replaced by local variables.
Then, at the end of the function, create the bootm_argv or zboot array:
bootm_argv[1] = kernel_addr; bootm_argv[2] = ramdisk_addr
Maybe this is too painful and we should just wait for a change to directly call the API?
So I'll add my review tag since I think this patch is reasonable.
Regards, SImon
Zhaofeng Li
