[PATCH] Add support for an owned buffer
When passing a data buffer back from a function, it is not always clear who owns the buffer, i.e. who is responsible for freeing the memory used. An example of this is where multiple files are decompressed from the firmware image, using a temporary buffer for reading (since the compressed data has to live somewhere) and producing a temporary or permanent buffer with the resuilts.
Where the firmware image can be memory-mapped, as on x86, the compressed data does not need to be buffered, but the complexity of having a buffer which is either allocated or not, makes the code hard to understand.
Introduce a new 'abuf' which supports simple buffer operations:
- encapsulating a buffer and its size - either allocated with malloc() or not - able to be reliably freed if necessary - able to be converted to an allocated buffer if needed
This simple API makes it easier to deal with allocated and memory-mapped buffers.
include/abuf.h | 137 +++++++++++++++++++++++ lib/Makefile | 1 + lib/abuf.c | 97 ++++++++++++++++ test/lib/Makefile | 1 + test/lib/abuf.c | 280 ++++++++++++++++++++++++++++++++++++++++++++++ 5 files changed, 516 insertions(+) create mode 100644 include/abuf.h create mode 100644 lib/abuf.c create mode 100644 test/lib/abuf.c
diff --git a/include/abuf.h b/include/abuf.h new file mode 100644 index 00000000000..90b6c9695d0 --- /dev/null +++ b/include/abuf.h @@ -0,0 +1,137 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Handles a buffer that can be allocated and freed + * + * Copyright 2021 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#ifndef __ABUF_H +#define __ABUF_H + +#include <linux/types.h> + +/** + * struct abuf - buffer that can be allocated and freed + * + * This is useful for a block of data which may be allocated with malloc(), or + * not, so that it needs to be freed correctly when finished with. + * + * For now it has a very simple purpose. + * + * Using memset() to zero all fields is guaranteed to be equivalent to + * abuf_init(). + * + * @data: Pointer to data + * @size: Size of data in bytes + * @alloced: true if allocated with malloc(), so must be freed after use + */ +struct abuf { + void *data; + size_t size; + bool alloced; +}; + +static inline void *abuf_data(struct abuf *abuf) +{ + return abuf->data; +} + +static inline size_t abuf_size(struct abuf *abuf) +{ + return abuf->size; +} + +/** + * abuf_set() - set the (unallocated) data in a buffer + * + * This simply makes the abuf point to the supplied data, which must be live + * for the lifetime of the abuf. It is not alloced. + * + * Any existing data in the abuf is freed and the alloced member is set to + * false. + * + * @abuf: abuf to adjust + * @data: New contents of abuf + * @size: New size of abuf + */ +void abuf_set(struct abuf *abuf, void *data, size_t size); + +/** + * abuf_map_sysmem() - calls map_sysmem() to set up an abuf + * + * This is equivalent to abuf_set(abuf, map_sysmem(addr, size), size) + * + * Any existing data in the abuf is freed and the alloced member is set to + * false. + * + * @abuf: abuf to adjust + * @addr: Address to set the abuf to + * @size: New size of abuf + */ +void abuf_map_sysmem(struct abuf *abuf, ulong addr, size_t size); + +/** + * abuf_realloc() - Change the size of a buffer + * + * This uses realloc() to change the size of the buffer, with the same semantics + * as that function. If the abuf is not currently alloced, then it will alloc + * it if the size needs to increase (i.e. set the alloced member to true) + * + * @abuf: abuf to adjust + * @new_size: new size in bytes. + * if 0, the abuf is freed + * if greater than the current size, the abuf is extended and the new + * space is not inited. The alloced member is set to true + * if less than the current size, the abuf is contracted and the data at + * the end is lost. If @new_size is 0, this sets the alloced member to + * false + * @return true if OK, false if out of memory + */ +bool abuf_realloc(struct abuf *abuf, size_t new_size); + +/** + * abuf_uninit_move() - Return the allocated contents and uninit the abuf + * + * This returns the abuf data to the caller, allocating it if necessary, so that + * the caller receives data that it can be sure will hang around. The caller is + * responsible for freeing the data. + * + * If the abuf has allocated data, it is returned. If the abuf has data but it + * is not allocated, then it is first allocated, then returned. + * + * If the abuf size is 0, this returns NULL + * + * The abuf is uninited as part of this, except if the allocation fails, in + * which NULL is returned and the abuf remains untouched. + * + * The abuf must be inited before this can be called. + * + * @abuf: abuf to uninit + * @sizep: if non-NULL, returns the size of the returned data + * @return data contents, allocated with malloc(), or NULL if the data could not + * be allocated, or the data size is 0 + */ +void *abuf_uninit_move(struct abuf *abuf, size_t *sizep); + +/** + * abuf_uninit() - Free any memory used by an abuf + * + * The buffer must be inited before this can be called. + * + * @abuf: abuf to uninit + */ +void abuf_uninit(struct abuf *abuf); + +/** + * abuf_init() - Set up a new abuf + * + * This initially has no data and alloced is set to false. This is equivalent to + * setting all fields to 0, e.g. with memset(), so callers can do that instead + * if desired. + * + * @abuf: abuf to set up + */ +void abuf_init(struct abuf *abuf); + +#endif diff --git a/lib/Makefile b/lib/Makefile index c42d4e12335..abb9b3c935c 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -131,6 +131,7 @@ obj-$(CONFIG_OID_REGISTRY) += oid_registry.o obj-$(CONFIG_SSCANF) += sscanf.o endif
+obj-y += abuf.o obj-y += date.o obj-$(CONFIG_LIB_ELF) += elf.o
diff --git a/lib/abuf.c b/lib/abuf.c new file mode 100644 index 00000000000..b6bde3053e8 --- /dev/null +++ b/lib/abuf.c @@ -0,0 +1,97 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Handles a buffer that can be allocated and freed + * + * Copyright 2021 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#include <common.h> +#include <abuf.h> +#include <malloc.h> +#include <mapmem.h> +#include <string.h> + +void abuf_set(struct abuf *abuf, void *data, size_t size) +{ + abuf_uninit(abuf); + abuf->data = data; + abuf->size = size; +} + +void abuf_map_sysmem(struct abuf *abuf, ulong addr, size_t size) +{ + abuf_set(abuf, map_sysmem(addr, size), size); +} + +bool abuf_realloc(struct abuf *abuf, size_t new_size) +{ + void *ptr; + + if (!new_size) { + /* easy case, just need to uninit, freeing any allocation */ + abuf_uninit(abuf); + } else if (abuf->alloced) { + /* currently allocated, so need to reallocate */ + ptr = realloc(abuf->data, new_size); + if (!ptr) + return false; + abuf->data = ptr; + abuf->size = new_size; + } else if (new_size <= abuf->size) { + /* + * not currently alloced and new size is no larger. Just update + * it. Data is lost off the end if new_size < abuf->size + */ + abuf->size = new_size; + } else { + /* not currently allocated and new size is larger. Alloc and + * copy in data. The new space is not inited. + */ + ptr = malloc(new_size); + if (!ptr) + return false; + memcpy(ptr, abuf->data, min(new_size, abuf->size)); + abuf->data = ptr; + abuf->size = new_size; + abuf->alloced = true; + } + + return true; +} + +void *abuf_uninit_move(struct abuf *abuf, size_t *sizep) +{ + void *ptr; + + if (sizep) + *sizep = abuf->size; + if (!abuf->size) + return NULL; + if (abuf->alloced) { + ptr = abuf->data; + } else { + ptr = malloc(abuf->size); + if (!ptr) + return NULL; + memcpy(ptr, abuf->data, abuf->size); + } + /* Clear everything out so there is no record of the data */ + abuf_init(abuf); + + return ptr; +} + +void abuf_uninit(struct abuf *abuf) +{ + if (abuf->alloced) + free(abuf->data); + abuf_init(abuf); +} + +void abuf_init(struct abuf *abuf) +{ + abuf->data = NULL; + abuf->size = 0; + abuf->alloced = false; +} diff --git a/test/lib/Makefile b/test/lib/Makefile index 97c11e35a88..cc885afbbc0 100644 --- a/test/lib/Makefile +++ b/test/lib/Makefile @@ -3,6 +3,7 @@ # (C) Copyright 2018 # Mario Six, Guntermann & Drunck GmbH, mario.six@gdsys.cc obj-y += cmd_ut_lib.o +obj-y += abuf.o obj-$(CONFIG_EFI_LOADER) += efi_device_path.o obj-$(CONFIG_EFI_SECURE_BOOT) += efi_image_region.o obj-y += hexdump.o diff --git a/test/lib/abuf.c b/test/lib/abuf.c new file mode 100644 index 00000000000..b1424ab2a94 --- /dev/null +++ b/test/lib/abuf.c @@ -0,0 +1,280 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2021 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#include <common.h> +#include <abuf.h> +#include <mapmem.h> +#include <test/lib.h> +#include <test/test.h> +#include <test/ut.h> + +static char test_data[] = "1234"; +#define TEST_DATA_LEN sizeof(test_data) + +/* Test abuf_set() */ +static int lib_test_abuf_set(struct unit_test_state *uts) +{ + struct abuf buf; + ulong start; + + start = ut_check_free(); + + abuf_init(&buf); + abuf_set(&buf, test_data, TEST_DATA_LEN); + ut_asserteq_ptr(test_data, buf.data); + ut_asserteq(TEST_DATA_LEN, buf.size); + ut_asserteq(false, buf.alloced); + + /* Force it to allocate */ + ut_asserteq(true, abuf_realloc(&buf, TEST_DATA_LEN + 1)); + ut_assertnonnull(buf.data); + ut_asserteq(TEST_DATA_LEN + 1, buf.size); + ut_asserteq(true, buf.alloced); + + /* Now set it again, to force it to free */ + abuf_set(&buf, test_data, TEST_DATA_LEN); + ut_asserteq_ptr(test_data, buf.data); + ut_asserteq(TEST_DATA_LEN, buf.size); + ut_asserteq(false, buf.alloced); + + /* Check for memory leaks */ + ut_assertok(ut_check_delta(start)); + + return 0; +} +LIB_TEST(lib_test_abuf_set, 0); + +/* Test abuf_map_sysmem() */ +static int lib_test_abuf_map_sysmem(struct unit_test_state *uts) +{ + struct abuf buf; + ulong addr; + + abuf_init(&buf); + addr = 0x100; + abuf_map_sysmem(&buf, addr, TEST_DATA_LEN); + + ut_asserteq_ptr(map_sysmem(0x100, 0), buf.data); + ut_asserteq(TEST_DATA_LEN, buf.size); + ut_asserteq(false, buf.alloced); + + return 0; +} +LIB_TEST(lib_test_abuf_map_sysmem, 0); + +/* Test abuf_realloc() */ +static int lib_test_abuf_realloc(struct unit_test_state *uts) +{ + struct abuf buf; + ulong start; + void *ptr; + + start = ut_check_free(); + + abuf_init(&buf); + + /* Allocate an empty buffer */ + ut_asserteq(true, abuf_realloc(&buf, 0)); + ut_assertnull(buf.data); + ut_asserteq(0, buf.size); + ut_asserteq(false, buf.alloced); + + /* Allocate a non-empty abuf */ + ut_asserteq(true, abuf_realloc(&buf, TEST_DATA_LEN)); + ut_assertnonnull(buf.data); + ut_asserteq(TEST_DATA_LEN, buf.size); + ut_asserteq(true, buf.alloced); + ptr = buf.data; + + /* Make it smaller; the pointer should remain the same */ + ut_asserteq(true, abuf_realloc(&buf, TEST_DATA_LEN - 1)); + ut_asserteq(TEST_DATA_LEN - 1, buf.size); + ut_asserteq(true, buf.alloced); + ut_asserteq_ptr(ptr, buf.data); + + /* Make it larger, forcing reallocation */ + ut_asserteq(true, abuf_realloc(&buf, 0x1000)); + ut_assert(buf.data != ptr); + ut_asserteq(0x1000, buf.size); + ut_asserteq(true, buf.alloced); + + /* Free it */ + ut_asserteq(true, abuf_realloc(&buf, 0)); + ut_assertnull(buf.data); + ut_asserteq(0, buf.size); + ut_asserteq(false, buf.alloced); + + /* Check for memory leaks */ + ut_assertok(ut_check_delta(start)); + + return 0; +} +LIB_TEST(lib_test_abuf_realloc, 0); + +/* Test handling of buffers that are too large */ +static int lib_test_abuf_large(struct unit_test_state *uts) +{ + struct abuf buf; + ulong start; + size_t size; + int delta; + void *ptr; + + start = ut_check_free(); + + /* Try an impossible size */ + abuf_init(&buf); + ut_asserteq(false, abuf_realloc(&buf, CONFIG_SYS_MALLOC_LEN)); + ut_assertnull(buf.data); + ut_asserteq(0, buf.size); + ut_asserteq(false, buf.alloced); + + abuf_uninit(&buf); + ut_assertnull(buf.data); + ut_asserteq(0, buf.size); + ut_asserteq(false, buf.alloced); + + /* Start with a normal size then try to increase it, to check realloc */ + ut_asserteq(true, abuf_realloc(&buf, TEST_DATA_LEN)); + ut_assertnonnull(buf.data); + ut_asserteq(TEST_DATA_LEN, buf.size); + ut_asserteq(true, buf.alloced); + ptr = buf.data; + delta = ut_check_delta(start); + ut_assert(delta > 0); + + /* try to increase it */ + ut_asserteq(false, abuf_realloc(&buf, CONFIG_SYS_MALLOC_LEN)); + ut_asserteq_ptr(ptr, buf.data); + ut_asserteq(TEST_DATA_LEN, buf.size); + ut_asserteq(true, buf.alloced); + ut_asserteq(delta, ut_check_delta(start)); + + /* Check for memory leaks */ + abuf_uninit(&buf); + ut_assertok(ut_check_delta(start)); + + /* Start with a huge unallocated buf and try to move it */ + abuf_init(&buf); + abuf_map_sysmem(&buf, 0, CONFIG_SYS_MALLOC_LEN); + ut_asserteq(CONFIG_SYS_MALLOC_LEN, buf.size); + ut_asserteq(false, buf.alloced); + ut_assertnull(abuf_uninit_move(&buf, &size)); + + /* Check for memory leaks */ + abuf_uninit(&buf); + ut_assertok(ut_check_delta(start)); + + return 0; +} +LIB_TEST(lib_test_abuf_large, 0); + +/* Test abuf_uninit_move() */ +static int lib_test_abuf_uninit_move(struct unit_test_state *uts) +{ + void *ptr, *orig_ptr; + struct abuf buf; + size_t size; + ulong start; + int delta; + + start = ut_check_free(); + + /* Move an empty buffer */ + abuf_init(&buf); + ut_assertnull(abuf_uninit_move(&buf, &size)); + ut_asserteq(0, size); + ut_assertnull(abuf_uninit_move(&buf, NULL)); + + /* Move an unallocated buffer */ + abuf_set(&buf, test_data, TEST_DATA_LEN); + ut_assertok(ut_check_delta(start)); + ptr = abuf_uninit_move(&buf, &size); + ut_asserteq(TEST_DATA_LEN, size); + ut_asserteq_str(ptr, test_data); + ut_assertnonnull(ptr); + ut_assertnull(buf.data); + ut_asserteq(0, buf.size); + ut_asserteq(false, buf.alloced); + + /* Check that freeing it frees the only allocation */ + delta = ut_check_delta(start); + ut_assert(delta > 0); + free(ptr); + ut_assertok(ut_check_delta(start)); + + /* Move an allocated buffer */ + ut_asserteq(true, abuf_realloc(&buf, TEST_DATA_LEN)); + orig_ptr = buf.data; + strcpy(orig_ptr, test_data); + + delta = ut_check_delta(start); + ut_assert(delta > 0); + ptr = abuf_uninit_move(&buf, &size); + ut_asserteq(TEST_DATA_LEN, size); + ut_assertnonnull(ptr); + ut_asserteq_ptr(ptr, orig_ptr); + ut_asserteq_str(ptr, test_data); + ut_assertnull(buf.data); + ut_asserteq(0, buf.size); + ut_asserteq(false, buf.alloced); + + /* Check there was no new allocation */ + ut_asserteq(delta, ut_check_delta(start)); + + /* Check that freeing it frees the only allocation */ + free(ptr); + ut_assertok(ut_check_delta(start)); + + /* Move an unallocated buffer, without the size */ + abuf_set(&buf, test_data, TEST_DATA_LEN); + ut_assertok(ut_check_delta(start)); + ptr = abuf_uninit_move(&buf, NULL); + ut_asserteq_str(ptr, test_data); + + return 0; +} +LIB_TEST(lib_test_abuf_uninit_move, 0); + +/* Test abuf_uninit() */ +static int lib_test_abuf_uninit(struct unit_test_state *uts) +{ + struct abuf buf; + + /* Nothing in the buffer */ + abuf_init(&buf); + abuf_uninit(&buf); + ut_assertnull(buf.data); + ut_asserteq(0, buf.size); + ut_asserteq(false, buf.alloced); + + /* Not allocated */ + abuf_set(&buf, test_data, TEST_DATA_LEN); + abuf_uninit(&buf); + ut_assertnull(buf.data); + ut_asserteq(0, buf.size); + ut_asserteq(false, buf.alloced); + + return 0; +} +LIB_TEST(lib_test_abuf_uninit, 0); + +/* Test abuf_init() */ +static int lib_test_abuf_init(struct unit_test_state *uts) +{ + struct abuf buf; + + buf.data = &buf; + buf.size = 123; + buf.alloced = true; + abuf_init(&buf); + ut_assertnull(buf.data); + ut_asserteq(0, buf.size); + ut_asserteq(false, buf.alloced); + + return 0; +} +LIB_TEST(lib_test_abuf_init, 0);
