Re: [U-Boot-Users] Altera Stratix II support
This patch adds my corp board along with an example of the Alter Stratix board specific implementation
Alas, it is larger than 40k and will be rejected...
here is a temporary link till I will find a better place.
http://download.yousendit.com/9380CEAB68FA66F3
If anyone experience problem accessing, mail me.
Liberty
+/* FIXME: if tsec does not work try thorwing this in (remove the if 0)*/ +int last_stage_init(void) +{ + /* TSEC0 register the first phy so we dont */ + tsec_initialize(gd->bd, 1, "2"); + tsec_initialize(gd->bd, 2, "3"); + tsec_initialize(gd->bd, 3, "4"); + tsec_initialize(gd->bd, 4, "5"); + tsec_initialize(gd->bd, 5, "6"); + tsec_initialize(gd->bd, 6, "7"); + tsec_initialize(gd->bd, 7, "8"); + tsec_initialize(gd->bd, 8, "9"); + tsec_initialize(gd->bd, 9, "10"); + tsec_initialize(gd->bd, 10, "11"); + + return 0; +}
Huh? How can you be initializing 10 tsecs? What part is this?
+static void cds_pci_fixup(void *blob) +{
Um...you probably want to rename this. Also, are you sure this is a function you want? This is only if your cpu is hooked up to the pci devices through a PCI slot.
* reads a little further. Does some math*
+ slot = 1; + + for (i=0;i<len;i+=7) { + /* We rotate the interrupt pins so that the mapping + * changes depending on the slot the carrier card is in. + */ + map[3] = ((map[3] + slot - 2) % 4) + 1; + + map+=7; + }
Do you realize the net effect of this is nothing? Pins 1-4 will remain 1-4, respectively. Delete this function altogether and (of course) the call to it.
+#define LAWBAR1 ((CFG_PCI1_MEM_BASE>>12) & 0xfffff) +#define LAWAR1 (LAWAR_EN | LAWAR_TRGT_IF_PCI1 | (LAWAR_SIZE & LAWAR_SIZE_512M)) + +#define LAWBAR2 ((CFG_PCI2_MEM_BASE>>12) & 0xfffff) +#define LAWAR2 (LAWAR_EN | LAWAR_TRGT_IF_PCI2 | (LAWAR_SIZE & LAWAR_SIZE_512M))
These should be CFG_PCIn_MEM_PHYS instead of CFG_PCIn_MEM_BASE. They're defined to be the same thing, but it is the cpu-physical address we want, not the PCI address.
+COBJS := $(BOARD).o \ + ft_board.o \ + fpga.o \ + ../../cds/common/eeprom.o \ + ../../cds/common/via.o
Um....that seems shady. Maybe we need to move the via.c code into drivers/ Are you sure you have a VIA chip?
static struct tsec_info_struct tsec_info[] = { +#if defined CONFIG_EXSW6000 + {TSEC1_PHY_ADDR, TSEC_GIGABIT, TSEC1_PHYIDX}, + {2, TSEC_GIGABIT, 1}, + {3, TSEC_GIGABIT, 2}, + {4, TSEC_GIGABIT, 3}, + {5, TSEC_GIGABIT, 4}, + {6, TSEC_GIGABIT, 5}, + {7, TSEC_GIGABIT, 6}, + {8, TSEC_GIGABIT, 7}, + {9, TSEC_GIGABIT, 8}, + {10, TSEC_GIGABIT, 9}, + {11, TSEC_GIGABIT, 10}, +#else
Are you sure about this? You are claiming that you have 11 TSECs, and that all of them use their own registers to access their PHY.
+#if defined(CONFIG_EXSW6000) + priv->regs = (volatile tsec_t *)(TSEC_BASE_ADDR); + priv->phyregs = (volatile tsec_t *)(TSEC_BASE_ADDR); +#else priv->regs = (volatile tsec_t *)(TSEC_BASE_ADDR + index * TSEC_SIZE); priv->phyregs = (volatile tsec_t *)(TSEC_BASE_ADDR + - tsec_info[index].phyregidx * - TSEC_SIZE); + tsec_info[index].phyregidx * + TSEC_SIZE); +#endif
1) Random, bad whitespace change. 2) I am *very* confused by what you did, here. Now it looks like you have set the phyregs back to what would happen if your phyregidx had been 0. And all of your TSECs share a single register set. It looks like you have one TSEC and 11 PHYs. What's going on?
Most of what you have chosen to comment on is part of my new board. some of it is still dirty work as it is all on progress and would love to get code review on, but keep in mind its fairly young code.
I can and i do. :)
- reads a little further. Does some math*
slot = 1;
map+=7;
this code is not mine (i have not wrote it), I will re look if i need it...
ft_board.o \
fpga.o \
I need to remove both eeprom.o via.o. I do not use them.. but as it is right now, removing them breaks the build. It is in my todo list.
+#else
I thought i am doing something shady as well stacking all mdio on the register of tsec0... but then i moved on to linux and saw they do exactly the same. :)
TSEC_SIZE);
TSEC_SIZE);
- Random, bad whitespace change.
would fix this
- I am *very* confused by what you did, here. Now it looks like you
very simple. All mdio are accessed via the same registers. the one that are in the memory space of eTSEC0
thanks for the in depth review. I appreciate the time you took to provide these insight.
Liberty
I can and i do. :)
I still debate that point. The 8548 has *4* eTSECs. Not 11. At best, you've created 11 virtual tsecs, each with a different PHY. Though how you configure which one is physically connected is beyond me.
ft_board.o \
fpga.o \
Ok, good
+#else
Yes, because only tsec0's MDIO pins are exposed from the package. The others only connect to the internal TBI PHY, which is useful for certain things, but that's not what you've done here.
Yes, that's what phyregidx is for. It defines which registers are used for PHY accesses. But you've also set up 11 tsecs all using the same register space. That's overkill. It looks like you have one tsec, and you want to be able to choose which PHY it is using by creating one driver instances for each PHY. So all you really need is one driver instance, and the ability to change which PHY the tsec configures. That shouldn't be too difficult.
If I'm wrong, then I'm still confused as to what the code changes to tsec are doing.
Andy
I can and i do. :)
ft_board.o \
fpga.o \
Ok, good
+#else
Andy
you are not entirely wrong... but not entirely right either.
I do have 1 Tsec which connects via phy 0. I also have 10 more Ethernet phys which will be used by my hardware (not Tsec), which i need to access and configure. The slick solution was to write an my own device with miiphy_read & write callback and not to register a complete TSEC for each one. (indeed an over kill)
Yet, I lose nothing doing just that and got it up and running... so i am happy with it as it is.
hope i made myself clearer.
Liberty
Andy Fleming
eran liberty
