Re: [U-Boot] [PATCH v4 03/10] Exynos542x: Add workaround for ARM errata 798870
On 13:27-20150220, Akshay Saraswat wrote:
This patch adds workaround for ARM errata 798870 which says "If back-to-back speculative cache line fills (fill A and fill B) are issued from the L1 data cache of a CPU to the L2 cache, the second request (fill B) is then cancelled, and the second request would have detected a hazard against a recent write or eviction (write B) to the same cache line as fill B then the L2 logic might deadlock."
Signed-off-by: Kimoon Kim kimoon.kim@samsung.com Signed-off-by: Akshay Saraswat akshay.s@samsung.com Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org
Changes since v3:
- Added errata number in comment.
- Moved changes to arm generic armv7.h
Changes since v2:
- No change.
Changes since v1:
- Added Reviewed-by & Tested-by.
- Added space before */ on line # 40.
arch/arm/include/asm/armv7.h | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/arch/arm/include/asm/armv7.h b/arch/arm/include/asm/armv7.h index a13da23..a2040b7 100644 --- a/arch/arm/include/asm/armv7.h +++ b/arch/arm/include/asm/armv7.h @@ -69,6 +69,22 @@ #define CP15DSB asm volatile ("mcr p15, 0, %0, c7, c10, 4" : : "r" (0)) #define CP15DMB asm volatile ("mcr p15, 0, %0, c7, c10, 5" : : "r" (0))
- Workaround for ARM errata # 798870
- Set L2ACTLR[7] to reissue any memory transaction in the L2 that has been
- stalled for 1024 cycles to verify that its hazard condition still exists.
+static inline void v7_enable_l2_hazard_detect(void) +{
- uint32_t val;
- /* L2ACTLR[7]: Enable hazard detect timeout */
- asm volatile ("mrc p15, 1, %0, c15, c0, 0\n\t" : "=r"(val));
- val |= (1 << 7);
- asm volatile ("mcr p15, 1, %0, c15, c0, 0\n\t" : : "r"(val));
This wont work for us in DRA7/OMAP5 L2ACTLR cannot be modified by u-boot. has to go to secure world using smc call.
If you dont want to execute it, don't call it. As simple as that. :) If you want to execute it from secure world, then call it from your SMC handler. Does it make sense?
+void v7_en_l2_hazard_detect(void); void v7_outer_cache_enable(void); void v7_outer_cache_disable(void); void v7_outer_cache_flush_all(void);
How about this - using the series: https://patchwork.ozlabs.org/patch/443261/ https://patchwork.ozlabs.org/patch/443264/ https://patchwork.ozlabs.org/patch/443268/ https://patchwork.ozlabs.org/patch/443265/ https://patchwork.ozlabs.org/patch/443263/ https://patchwork.ozlabs.org/patch/443262/ https://patchwork.ozlabs.org/patch/443267/ https://patchwork.ozlabs.org/patch/443266/ https://patchwork.ozlabs.org/patch/443260/ -- Regards, Nishanth Menon
Regards, Akshay Saraswat
Akshay Saraswat
