[U-Boot] [PATCH] fsl-ddr: update the bit mask for DDR3 controller
According to the latest 8572 UM, the DDR3 controller is expanding the bit mask, and we use the extend ACTTOPRE mode when tRAS more than 19 MCLK.
Signed-off-by: Dave Liu daveliu@freescale.com --- cpu/mpc8xxx/ddr/ctrl_regs.c | 12 ++++++++---- 1 files changed, 8 insertions(+), 4 deletions(-)
diff --git a/cpu/mpc8xxx/ddr/ctrl_regs.c b/cpu/mpc8xxx/ddr/ctrl_regs.c index 1783e92..d5cdc36 100644 --- a/cpu/mpc8xxx/ddr/ctrl_regs.c +++ b/cpu/mpc8xxx/ddr/ctrl_regs.c @@ -185,10 +185,14 @@ static void set_timing_cfg_3(fsl_ddr_cfg_regs_t *ddr, unsigned int ext_caslat = 0; /* Extended MCAS latency from READ cmd */ unsigned int cntl_adj = 0; /* Control Adjust */
+ /* If the tRAS > 19 MCLK, we use the ext mode */ + if (picos_to_mclk(common_dimm->tRAS_ps) > 0x13) + ext_acttopre = 1; + ext_refrec = (picos_to_mclk(common_dimm->tRFC_ps) - 8) >> 4; ddr->timing_cfg_3 = (0 | ((ext_acttopre & 0x1) << 24) - | ((ext_refrec & 0x7) << 16) + | ((ext_refrec & 0xF) << 16) | ((ext_caslat & 0x1) << 12) | ((cntl_adj & 0x7) << 0) ); @@ -251,12 +255,12 @@ static void set_timing_cfg_1(fsl_ddr_cfg_regs_t *ddr, wrtord_mclk = picos_to_mclk(common_dimm->tWTR_ps);
ddr->timing_cfg_1 = (0 - | ((pretoact_mclk & 0x07) << 28) + | ((pretoact_mclk & 0x0F) << 28) | ((acttopre_mclk & 0x0F) << 24) - | ((acttorw_mclk & 0x7) << 20) + | ((acttorw_mclk & 0xF) << 20) | ((caslat_ctrl & 0xF) << 16) | ((refrec_ctrl & 0xF) << 12) - | ((wrrec_mclk & 0x07) << 8) + | ((wrrec_mclk & 0x0F) << 8) | ((acttoact_mclk & 0x07) << 4) | ((wrtord_mclk & 0x07) << 0) );
Wolfgang,
Please ignore the patch, I will resend it in the next patch sets. Sorry for that.
Thanks, Dave
-----Original Message----- From: Liu Dave-R63238 Sent: 2008?11?21? 7:51 AM To: u-boot@lists.denx.de Cc: wd@denx.de; Liu Dave-R63238 Subject: [PATCH] fsl-ddr: update the bit mask for DDR3 controller
- /* If the tRAS > 19 MCLK, we use the ext mode */
- if (picos_to_mclk(common_dimm->tRAS_ps) > 0x13)
ext_acttopre = 1;
- ext_refrec = (picos_to_mclk(common_dimm->tRFC_ps) - 8) >> 4; ddr->timing_cfg_3 = (0 | ((ext_acttopre & 0x1) << 24)
| ((ext_caslat & 0x1) << 12) | ((cntl_adj & 0x7) << 0) );| ((ext_refrec & 0xF) << 16)
| ((acttopre_mclk & 0x0F) << 24)| ((pretoact_mclk & 0x0F) << 28)
| ((caslat_ctrl & 0xF) << 16) | ((refrec_ctrl & 0xF) << 12)| ((acttorw_mclk & 0xF) << 20)
| ((acttoact_mclk & 0x07) << 4) | ((wrtord_mclk & 0x07) << 0) );| ((wrrec_mclk & 0x0F) << 8)
-- 1.5.4
Dave Liu
Liu Dave
