[U-Boot] [BUG] cmd : 'env exists envvar' does not display the existence of environment variable
u-boot Version: 2019.10 H/W Board : Beaglebone Black
'env exists env_varName' does not display the existance status of 'env_varName' environment variable.
----------------------------------------- => help env env - environment handling commands
Usage: env ask name [message] [size] - ask for environment variable env default [-f] -a - [forcibly] reset default environment env default [-f] var [...] - [forcibly] reset variable(s) to their default values env delete [-f] var [...] - [forcibly] delete variable(s) env edit name - edit environment variable env exists name - tests for existence of variable env export [-t | -b | -c] [-s size] addr [var ...] - export environment env import [-d] [-t [-r] | -b | -c] addr [size] [var ...] - import environment env print [-a | name ...] - print environment env print -e [name ...] - print UEFI environment env run var [...] - run commands in an environment variable env save - save environment env set -e name [arg ...] - set UEFI variable; unset if 'arg' not specified env set [-f] name [arg ...]
=> printenv ver ver=U-Boot 2019.10 (Oct 14 2019 - 00:47:50 -0700) => env exists ver => -----------------------------------------
What is the expected Output and where is the result updated??
-Adarsh
https://www.avast.com/en-in/recommend?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=default3&tag=263e577d-8a0d-4805-aed0-c94705b9fd3a I’m protected online with Avast Free Antivirus. Get it here — it’s free forever. https://www.avast.com/en-in/recommend?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=default3&tag=263e577d-8a0d-4805-aed0-c94705b9fd3a <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
Dear Adarsh Babu Kalepalli,
you should not flag your postings with a BUG marker if you simply domn't understand how to use the tools. Please do this only when you are really sure there is a misbehaviour.
In message CAJgxa7cv2GiQpS3HwMgC=uAN88Z0KM5b7Frei_gEik1xC=nqyg@mail.gmail.com you wrote:
Which part of the documention states that it should _display_ such a status?
This says it "tests", but it does say nothing obout outputting any such information. The command to output such information is "env print".
Above behaviour is absolutely correct. The command returns a proper status which can be used in conditionals etc., for example:
U-Boot> env exists foo ; echo RC=$? RC=1 U-Boot> if env exists bootdelay ; then echo BOOTDELAY exists ; else echo BOOTDELAY does not exist ; fi BOOTDELAY exists U-Boot> if env exists bootdelay ; then echo BOOTDELAZ exists ; else echo BOOTDELAZ does not exist ; fi BOOTDELAZ exists U-Boot> env exists bootdelay && printenv bootdelay bootdelay=3
There is no bug.
Hello Wolfgang Denk,
It's my mistake to tag this observation as a bug. I will take care such thing does not repeat .
Could you *please clarify* couple of my queries* regarding posting questions* to the mailing list.
+ Most of the postings in the mailing list are observed to be code patches. Could we also post our observations/opinions on the code/commands/issues on a particular u-boot release and discuss with other u-boot contributors?? If yes, is there any specific string (similar to [PATCH] for a patch or a [BUG] for a bug etc) to be mentioned in the subject line??
I posted the below two queries earlier (first one yesterday and second one during last month)
1.[U-Boot] cmd: clarification on 'env ask' command execution 2.Unable to delete the hush shell local variables
Both of them were not forwarded by the moderator (not sure what was wrong ). I re-sent the second query yesterday to the mailing list with subject line "*[U-Boot] [BUG] cmd : Local Hush Variable Could not be deleted* " and it got forwarded.
So, any specific guidelines to post queries/observations/bugs for discussion will be definitely helpful and keep us going.
+ For newbies, could you suggest any pre-requisites, initial documents or guidelines to follow while they explore u-boot ( from user/tester/developer perspective ).
Regards, Adarsh
https://www.avast.com/en-in/recommend?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=default3&tag=263e577d-8a0d-4805-aed0-c94705b9fd3a I’m protected online with Avast Free Antivirus. Get it here — it’s free forever. https://www.avast.com/en-in/recommend?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=default3&tag=263e577d-8a0d-4805-aed0-c94705b9fd3a <#m_6203331441722922600_m_-6344178679015369129_m_4688685467448139936_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
In message <CAJgxa7cv2GiQpS3HwMgC=uAN88Z0KM5b7Frei_gEik1xC= nqyg@mail.gmail.com> you wrote:
There is no bug.
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de You don't need a weatherman to know which way the wind blows. - Bob Dylan
https://www.avast.com/en-in/recommend?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=default3&tag=263e577d-8a0d-4805-aed0-c94705b9fd3a I’m protected online with Avast Free Antivirus. Get it here — it’s free forever. https://www.avast.com/en-in/recommend?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=default3&tag=263e577d-8a0d-4805-aed0-c94705b9fd3a <#m_6203331441722922600_m_-6344178679015369129_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
Dear Adarsh,
In message CAJgxa7ev2Zao61SDjOt+2k5qJfDxiY1bwTqmcFg=G4iSk-u7KQ@mail.gmail.com you wrote:
I can try...
- Most of the postings in the mailing list are observed to be code patches.
Of course you can also just ask questions. But as you probably see, this is a pretty high volume mailing list, so there is always a chance that such messages may be missed.
No, there is no such tag. But it is always a good idea to add the custodian for the affected sub-system on Cc: ; normally you can find such information in the MAINTAINERS file, or try using the scripts/get_maintainer.pl tool. in case of environment code you just have bad luck, as the entry for MAINTAINERS has not been added yet to mainline (but it was seen on the mailing list).
I can see 1. at https://lists.denx.de/pipermail/u-boot/2019-October/386682.html
You can avoid that your messages need a maintainer's attention by subscribing to the mailing list. there is tons of spam messages that need to get manually cleaned up, and it's easy to miss a regular posting, especially if the subject line is not clear enough.
- For newbies, could you suggest any pre-requisites, initial documents or
I found it always useful to read and remember the recommendations posted in [1].
[1] http://www.catb.org/%7eesr/faqs/smart-questions.html
