[U-Boot-Users] PATCH: MPC8220 update in flash.c
- Print out KB or MB in flash
Regards, TsiChung Liew
Signed-off by: TsiChung LiewTsi-Chung.Liew@freescale.com
diff -rupN u-boot-all.git/board/alaska/flash.c u-boot-all-8220- flash/board/alaska/flash.c --- u-boot-all.git/board/alaska/flash.c 2007-04-03 19:18:56.000000000 -0500 +++ u-boot-all-8220-flash/board/alaska/flash.c 2007-05-10 15:40:56.000000000 -0500 @@ -27,7 +27,6 @@ #include <common.h> #include <linux/byteorder/swab.h>
- flash_info_t flash_info[CFG_MAX_FLASH_BANKS]; /* info for FLASH chips */
/* Board support for 1 or 2 flash devices */ @@ -213,8 +212,12 @@ void flash_print_info (flash_info_t * in break; }
+ if (info->size > 0x100000) printf (" Size: %ld MB in %d Sectors\n", info->size >> 20, info->sector_count); + else + printf(" Size: %ld KB in %d Sectors\n", + info->size >> 10, info->sector_count);
printf (" Sector Start Addresses:"); for (i = 0; i < info->sector_count; ++i) { @@ -308,7 +311,6 @@ static ulong flash_get_size (FPW * addr, return (info->size); }
- /* * This function gets the u-boot flash sector protection status * (flash_info_t.protect[]) in sync with the sector protection @@ -331,7 +333,6 @@ static void flash_sync_real_protect (fla } }
- /* * checks if "sector" in bank "info" is protected. Should work on intel * strata flash chips 28FxxxJ3x in 8-bit mode. @@ -384,7 +385,6 @@ static unsigned char intel_sector_protec return ret; }
- /* * Checks if "bank1" and "bank2" are on the same chip. Returns 1 if they * are and 0 otherwise. @@ -400,7 +400,6 @@ static unsigned char same_chip_banks (in return same_chip[bank1][bank2]; }
- /*----------------------------------------------------------------------- */ int flash_erase (flash_info_t * info, int s_first, int s_last)
TsiChung Liew
