[PATCH v2 00/12] virtio: Harden and test vring
Continuing the theme of making the virtio code resilient against corruption of the buffers shared with the device, this series focusses on the vring.
It follows the example of Linux by keeping a private copy of the descriptors and metadata for state tracking and only ever writing to the descriptors that are shared with the device. I was able to test these hardening steps in the sandbox by simulating device writes to the queues.
From v1:
- Fix build errors on SPL by making dependency on virtio drivers explicit
Andrew Scull (12): virtio_ring: Merge identical variables virtio_ring: Add helper to attach vring descriptor virtio_ring: Maintain a shadow copy of descriptors virtio_ring: Check used descriptors are chain heads dm: test: virtio: Test the virtio ring virtio: sandbox: Fix device features bitfield test: dm: virtio: Test notify before del_vqs test: dm: virtio: Split out virtio device tests virtio: sandbox: Bind RNG rather than block device test: dm: virtio: Test virtio device driver probing virtio: rng: Check length before copying test: dm: virtio_rng: Test virtio-rng with faked device
drivers/virtio/virtio_ring.c | 90 ++++++++++----- drivers/virtio/virtio_rng.c | 3 + drivers/virtio/virtio_sandbox.c | 4 +- include/virtio_ring.h | 12 ++ test/dm/Makefile | 6 +- test/dm/virtio.c | 99 ---------------- test/dm/virtio_device.c | 195 ++++++++++++++++++++++++++++++++ test/dm/virtio_rng.c | 52 +++++++++ 8 files changed, 328 insertions(+), 133 deletions(-) create mode 100644 test/dm/virtio_device.c create mode 100644 test/dm/virtio_rng.c
The variables `total_sg` and `descs_used` have the same value. Replace the few uses of `total_sg` with `descs_used` to simplify the situation.
Signed-off-by: Andrew Scull ascull@google.com Reviewed-by: Simon Glass sjg@chromium.org --- drivers/virtio/virtio_ring.c | 7 +++---- 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/drivers/virtio/virtio_ring.c b/drivers/virtio/virtio_ring.c index 7f1cbc5932..a6922ce1b8 100644 --- a/drivers/virtio/virtio_ring.c +++ b/drivers/virtio/virtio_ring.c @@ -20,17 +20,16 @@ int virtqueue_add(struct virtqueue *vq, struct virtio_sg *sgs[], unsigned int out_sgs, unsigned int in_sgs) { struct vring_desc *desc; - unsigned int total_sg = out_sgs + in_sgs; - unsigned int i, n, avail, descs_used, uninitialized_var(prev); + unsigned int descs_used = out_sgs + in_sgs; + unsigned int i, n, avail, uninitialized_var(prev); int head;
- WARN_ON(total_sg == 0); + WARN_ON(descs_used == 0);
head = vq->free_head;
desc = vq->vring.desc; i = head; - descs_used = total_sg;
if (vq->num_free < descs_used) { debug("Can't add buf len %i - avail = %i\n",
Move the logic for attaching a descriptor to its own function.
Signed-off-by: Andrew Scull ascull@google.com Reviewed-by: Simon Glass sjg@chromium.org --- drivers/virtio/virtio_ring.c | 30 +++++++++++++++--------------- 1 file changed, 15 insertions(+), 15 deletions(-)
diff --git a/drivers/virtio/virtio_ring.c b/drivers/virtio/virtio_ring.c index a6922ce1b8..8e0cb3d666 100644 --- a/drivers/virtio/virtio_ring.c +++ b/drivers/virtio/virtio_ring.c @@ -16,6 +16,18 @@ #include <linux/bug.h> #include <linux/compat.h>
+static unsigned int virtqueue_attach_desc(struct virtqueue *vq, unsigned int i, + struct virtio_sg *sg, u16 flags) +{ + struct vring_desc *desc = &vq->vring.desc[i]; + + desc->addr = cpu_to_virtio64(vq->vdev, (u64)(uintptr_t)sg->addr); + desc->len = cpu_to_virtio32(vq->vdev, sg->length); + desc->flags = cpu_to_virtio16(vq->vdev, flags); + + return virtio16_to_cpu(vq->vdev, desc->next); +} + int virtqueue_add(struct virtqueue *vq, struct virtio_sg *sgs[], unsigned int out_sgs, unsigned int in_sgs) { @@ -45,26 +57,14 @@ int virtqueue_add(struct virtqueue *vq, struct virtio_sg *sgs[], }
for (n = 0; n < out_sgs; n++) { - struct virtio_sg *sg = sgs[n]; - - desc[i].flags = cpu_to_virtio16(vq->vdev, VRING_DESC_F_NEXT); - desc[i].addr = cpu_to_virtio64(vq->vdev, (u64)(size_t)sg->addr); - desc[i].len = cpu_to_virtio32(vq->vdev, sg->length); - prev = i; - i = virtio16_to_cpu(vq->vdev, desc[i].next); + i = virtqueue_attach_desc(vq, i, sgs[n], VRING_DESC_F_NEXT); } for (; n < (out_sgs + in_sgs); n++) { - struct virtio_sg *sg = sgs[n]; - - desc[i].flags = cpu_to_virtio16(vq->vdev, VRING_DESC_F_NEXT | - VRING_DESC_F_WRITE); - desc[i].addr = cpu_to_virtio64(vq->vdev, - (u64)(uintptr_t)sg->addr); - desc[i].len = cpu_to_virtio32(vq->vdev, sg->length); + u16 flags = VRING_DESC_F_NEXT | VRING_DESC_F_WRITE;
prev = i; - i = virtio16_to_cpu(vq->vdev, desc[i].next); + i = virtqueue_attach_desc(vq, i, sgs[n], flags); } /* Last one doesn't continue */ desc[prev].flags &= cpu_to_virtio16(vq->vdev, ~VRING_DESC_F_NEXT);
prev = i;
u16 flags = VRING_DESC_F_NEXT | VRING_DESC_F_WRITE; prev = i;
The above 2 for loops can be further merged into one loop:
u16 flags = VRING_DESC_F_NEXT; for (n = 0; n < (out_sgs + in_sgs); n++) { if (n >= out_sgs) flags |= VRING_DESC_F_WRITE; prev = i; i = virtqueue_attach_desc(vq, i, sgs[n], flags); }
Regards, Bin
The shared descriptors should only be written by the guest driver, however, the device is still able to overwrite and corrupt them. Maintain a private shadow copy of the descriptors for the driver to use for state tracking, removing the need to read from the shared descriptors.
Signed-off-by: Andrew Scull ascull@google.com Reviewed-by: Simon Glass sjg@chromium.org --- drivers/virtio/virtio_ring.c | 49 ++++++++++++++++++++++++------------ include/virtio_ring.h | 10 ++++++++ 2 files changed, 43 insertions(+), 16 deletions(-)
diff --git a/drivers/virtio/virtio_ring.c b/drivers/virtio/virtio_ring.c index 8e0cb3d666..69fd8c6aa0 100644 --- a/drivers/virtio/virtio_ring.c +++ b/drivers/virtio/virtio_ring.c @@ -19,13 +19,21 @@ static unsigned int virtqueue_attach_desc(struct virtqueue *vq, unsigned int i, struct virtio_sg *sg, u16 flags) { + struct vring_desc_shadow *desc_shadow = &vq->vring_desc_shadow[i]; struct vring_desc *desc = &vq->vring.desc[i];
- desc->addr = cpu_to_virtio64(vq->vdev, (u64)(uintptr_t)sg->addr); - desc->len = cpu_to_virtio32(vq->vdev, sg->length); - desc->flags = cpu_to_virtio16(vq->vdev, flags); + /* Update the shadow descriptor. */ + desc_shadow->addr = (u64)(uintptr_t)sg->addr; + desc_shadow->len = sg->length; + desc_shadow->flags = flags;
- return virtio16_to_cpu(vq->vdev, desc->next); + /* Update the shared descriptor to match the shadow. */ + desc->addr = cpu_to_virtio64(vq->vdev, desc_shadow->addr); + desc->len = cpu_to_virtio32(vq->vdev, desc_shadow->len); + desc->flags = cpu_to_virtio16(vq->vdev, desc_shadow->flags); + desc->next = cpu_to_virtio16(vq->vdev, desc_shadow->next); + + return desc_shadow->next; }
int virtqueue_add(struct virtqueue *vq, struct virtio_sg *sgs[], @@ -67,7 +75,8 @@ int virtqueue_add(struct virtqueue *vq, struct virtio_sg *sgs[], i = virtqueue_attach_desc(vq, i, sgs[n], flags); } /* Last one doesn't continue */ - desc[prev].flags &= cpu_to_virtio16(vq->vdev, ~VRING_DESC_F_NEXT); + vq->vring_desc_shadow[prev].flags &= ~VRING_DESC_F_NEXT; + desc[prev].flags = cpu_to_virtio16(vq->vdev, vq->vring_desc_shadow[prev].flags);
/* We're using some buffers from the free list. */ vq->num_free -= descs_used; @@ -136,17 +145,16 @@ void virtqueue_kick(struct virtqueue *vq) static void detach_buf(struct virtqueue *vq, unsigned int head) { unsigned int i; - __virtio16 nextflag = cpu_to_virtio16(vq->vdev, VRING_DESC_F_NEXT);
/* Put back on free list: unmap first-level descriptors and find end */ i = head;
- while (vq->vring.desc[i].flags & nextflag) { - i = virtio16_to_cpu(vq->vdev, vq->vring.desc[i].next); + while (vq->vring_desc_shadow[i].flags & VRING_DESC_F_NEXT) { + i = vq->vring_desc_shadow[i].next; vq->num_free++; }
- vq->vring.desc[i].next = cpu_to_virtio16(vq->vdev, vq->free_head); + vq->vring_desc_shadow[i].next = vq->free_head; vq->free_head = head;
/* Plus final descriptor */ @@ -199,8 +207,7 @@ void *virtqueue_get_buf(struct virtqueue *vq, unsigned int *len) virtio_store_mb(&vring_used_event(&vq->vring), cpu_to_virtio16(vq->vdev, vq->last_used_idx));
- return (void *)(uintptr_t)virtio64_to_cpu(vq->vdev, - vq->vring.desc[i].addr); + return (void *)(uintptr_t)vq->vring_desc_shadow[i].addr; }
static struct virtqueue *__vring_new_virtqueue(unsigned int index, @@ -209,6 +216,7 @@ static struct virtqueue *__vring_new_virtqueue(unsigned int index, { unsigned int i; struct virtqueue *vq; + struct vring_desc_shadow *vring_desc_shadow; struct virtio_dev_priv *uc_priv = dev_get_uclass_priv(udev); struct udevice *vdev = uc_priv->vdev;
@@ -216,10 +224,17 @@ static struct virtqueue *__vring_new_virtqueue(unsigned int index, if (!vq) return NULL;
+ vring_desc_shadow = calloc(vring.num, sizeof(struct vring_desc_shadow)); + if (!vring_desc_shadow) { + free(vq); + return NULL; + } + vq->vdev = vdev; vq->index = index; vq->num_free = vring.num; vq->vring = vring; + vq->vring_desc_shadow = vring_desc_shadow; vq->last_used_idx = 0; vq->avail_flags_shadow = 0; vq->avail_idx_shadow = 0; @@ -237,7 +252,7 @@ static struct virtqueue *__vring_new_virtqueue(unsigned int index, /* Put everything in free lists */ vq->free_head = 0; for (i = 0; i < vring.num - 1; i++) - vq->vring.desc[i].next = cpu_to_virtio16(vdev, i + 1); + vq->vring_desc_shadow[i].next = i + 1;
return vq; } @@ -290,6 +305,7 @@ struct virtqueue *vring_create_virtqueue(unsigned int index, unsigned int num, void vring_del_virtqueue(struct virtqueue *vq) { free(vq->vring.desc); + free(vq->vring_desc_shadow); list_del(&vq->list); free(vq); } @@ -335,11 +351,12 @@ void virtqueue_dump(struct virtqueue *vq) printf("\tlast_used_idx %u, avail_flags_shadow %u, avail_idx_shadow %u\n", vq->last_used_idx, vq->avail_flags_shadow, vq->avail_idx_shadow);
- printf("Descriptor dump:\n"); + printf("Shadow descriptor dump:\n"); for (i = 0; i < vq->vring.num; i++) { - printf("\tdesc[%u] = { 0x%llx, len %u, flags %u, next %u }\n", - i, vq->vring.desc[i].addr, vq->vring.desc[i].len, - vq->vring.desc[i].flags, vq->vring.desc[i].next); + struct vring_desc_shadow *desc = &vq->vring_desc_shadow[i]; + + printf("\tdesc_shadow[%u] = { 0x%llx, len %u, flags %u, next %u }\n", + i, desc->addr, desc->len, desc->flags, desc->next); }
printf("Avail ring dump:\n"); diff --git a/include/virtio_ring.h b/include/virtio_ring.h index 6fc0593b14..52cbe77c0a 100644 --- a/include/virtio_ring.h +++ b/include/virtio_ring.h @@ -55,6 +55,14 @@ struct vring_desc { __virtio16 next; };
+/* Shadow of struct vring_desc in guest byte order. */ +struct vring_desc_shadow { + u64 addr; + u32 len; + u16 flags; + u16 next; +}; + struct vring_avail { __virtio16 flags; __virtio16 idx; @@ -89,6 +97,7 @@ struct vring { * @index: the zero-based ordinal number for this queue * @num_free: number of elements we expect to be able to fit * @vring: actual memory layout for this queue + * @vring_desc_shadow: guest-only copy of descriptors * @event: host publishes avail event idx * @free_head: head of free buffer list * @num_added: number we've added since last sync @@ -102,6 +111,7 @@ struct virtqueue { unsigned int index; unsigned int num_free; struct vring vring; + struct vring_desc_shadow *vring_desc_shadow; bool event; unsigned int free_head; unsigned int num_added;
When the device returns used buffers, it should refer to the descriptor that is the head of the descriptor chain for that buffer. Confirm this to be the case by tracking the head of descriptor chains that have been made available to the device.
Signed-off-by: Andrew Scull ascull@google.com Reviewed-by: Simon Glass sjg@chromium.org --- drivers/virtio/virtio_ring.c | 12 ++++++++++++ include/virtio_ring.h | 2 ++ 2 files changed, 14 insertions(+)
diff --git a/drivers/virtio/virtio_ring.c b/drivers/virtio/virtio_ring.c index 69fd8c6aa0..383d574cb0 100644 --- a/drivers/virtio/virtio_ring.c +++ b/drivers/virtio/virtio_ring.c @@ -84,6 +84,9 @@ int virtqueue_add(struct virtqueue *vq, struct virtio_sg *sgs[], /* Update free pointer */ vq->free_head = i;
+ /* Mark the descriptor as the head of a chain. */ + vq->vring_desc_shadow[head].chain_head = true; + /* * Put entry in available array (but don't update avail->idx * until they do sync). @@ -146,6 +149,9 @@ static void detach_buf(struct virtqueue *vq, unsigned int head) { unsigned int i;
+ /* Unmark the descriptor as the head of a chain. */ + vq->vring_desc_shadow[head].chain_head = false; + /* Put back on free list: unmap first-level descriptors and find end */ i = head;
@@ -196,6 +202,12 @@ void *virtqueue_get_buf(struct virtqueue *vq, unsigned int *len) return NULL; }
+ if (unlikely(!vq->vring_desc_shadow[i].chain_head)) { + printf("(%s.%d): id %u is not a head\n", + vq->vdev->name, vq->index, i); + return NULL; + } + detach_buf(vq, i); vq->last_used_idx++; /* diff --git a/include/virtio_ring.h b/include/virtio_ring.h index 52cbe77c0a..c77c212cff 100644 --- a/include/virtio_ring.h +++ b/include/virtio_ring.h @@ -61,6 +61,8 @@ struct vring_desc_shadow { u32 len; u16 flags; u16 next; + /* Metadata about the descriptor. */ + bool chain_head; };
The virtio ring is the basis of virtio communication. Test its basic functionality and its resilience against corruption from the device.
Signed-off-by: Andrew Scull ascull@google.com Reviewed-by: Simon Glass sjg@chromium.org --- test/dm/virtio.c | 72 ++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 72 insertions(+)
diff --git a/test/dm/virtio.c b/test/dm/virtio.c index 9a7e658cce..adef10592c 100644 --- a/test/dm/virtio.c +++ b/test/dm/virtio.c @@ -130,3 +130,75 @@ static int dm_test_virtio_remove(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_virtio_remove, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT); + +/* Test all of the virtio ring */ +static int dm_test_virtio_ring(struct unit_test_state *uts) +{ + struct udevice *bus, *dev; + struct virtio_dev_priv *uc_priv; + struct virtqueue *vq; + struct virtio_sg sg[2]; + struct virtio_sg *sgs[2]; + unsigned int len; + u8 buffer[2][32]; + + /* check probe success */ + ut_assertok(uclass_first_device(UCLASS_VIRTIO, &bus)); + ut_assertnonnull(bus); + + /* check the child virtio-blk device is bound */ + ut_assertok(device_find_first_child(bus, &dev)); + ut_assertnonnull(dev); + + /* + * fake the virtio device probe by filling in uc_priv->vdev + * which is used by virtio_find_vqs/virtio_del_vqs. + */ + uc_priv = dev_get_uclass_priv(bus); + ut_assertnonnull(uc_priv); + uc_priv->vdev = dev; + + /* prepare the scatter-gather buffer */ + sg[0].addr = buffer[0]; + sg[0].length = sizeof(buffer[0]); + sg[1].addr = buffer[1]; + sg[1].length = sizeof(buffer[1]); + sgs[0] = &sg[0]; + sgs[1] = &sg[1]; + + /* read a buffer and report written size from device */ + ut_assertok(virtio_find_vqs(dev, 1, &vq)); + ut_assertok(virtqueue_add(vq, sgs, 0, 1)); + vq->vring.used->idx = 1; + vq->vring.used->ring[0].id = 0; + vq->vring.used->ring[0].len = 0x53355885; + ut_asserteq_ptr(buffer, virtqueue_get_buf(vq, &len)); + ut_asserteq(0x53355885, len); + ut_assertok(virtio_del_vqs(dev)); + + /* rejects used descriptors that aren't a chain head */ + ut_assertok(virtio_find_vqs(dev, 1, &vq)); + ut_assertok(virtqueue_add(vq, sgs, 0, 2)); + vq->vring.used->idx = 1; + vq->vring.used->ring[0].id = 1; + vq->vring.used->ring[0].len = 0x53355885; + ut_assertnull(virtqueue_get_buf(vq, &len)); + ut_assertok(virtio_del_vqs(dev)); + + /* device changes to descriptor are ignored */ + ut_assertok(virtio_find_vqs(dev, 1, &vq)); + ut_assertok(virtqueue_add(vq, sgs, 0, 1)); + vq->vring.desc[0].addr = cpu_to_virtio64(dev, 0xbadbad11); + vq->vring.desc[0].len = cpu_to_virtio32(dev, 0x11badbad); + vq->vring.desc[0].flags = cpu_to_virtio16(dev, VRING_DESC_F_NEXT); + vq->vring.desc[0].next = cpu_to_virtio16(dev, U16_MAX); + vq->vring.used->idx = 1; + vq->vring.used->ring[0].id = 0; + vq->vring.used->ring[0].len = 6; + ut_asserteq_ptr(buffer, virtqueue_get_buf(vq, &len)); + ut_asserteq(6, len); + ut_assertok(virtio_del_vqs(dev)); + + return 0; +} +DM_TEST(dm_test_virtio_ring, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT);
The virtio sandbox transport was setting the device features value to the bit index rather than shifting a bit to the right index. Fix this using the bit manipulation macros.
Signed-off-by: Andrew Scull ascull@google.com Reviewed-by: Simon Glass sjg@chromium.org --- drivers/virtio/virtio_sandbox.c | 2 +- test/dm/virtio.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/virtio/virtio_sandbox.c b/drivers/virtio/virtio_sandbox.c index aafb7beb94..a73b123454 100644 --- a/drivers/virtio/virtio_sandbox.c +++ b/drivers/virtio/virtio_sandbox.c @@ -160,7 +160,7 @@ static int virtio_sandbox_probe(struct udevice *udev) struct virtio_dev_priv *uc_priv = dev_get_uclass_priv(udev);
/* fake some information for testing */ - priv->device_features = VIRTIO_F_VERSION_1; + priv->device_features = BIT_ULL(VIRTIO_F_VERSION_1); uc_priv->device = VIRTIO_ID_BLOCK; uc_priv->vendor = ('u' << 24) | ('b' << 16) | ('o' << 8) | 't';
diff --git a/test/dm/virtio.c b/test/dm/virtio.c index adef10592c..aa4e3d778e 100644 --- a/test/dm/virtio.c +++ b/test/dm/virtio.c @@ -77,7 +77,7 @@ static int dm_test_virtio_all_ops(struct unit_test_state *uts) ut_assertok(virtio_get_status(dev, &status)); ut_asserteq(0, status); ut_assertok(virtio_get_features(dev, &features)); - ut_asserteq(VIRTIO_F_VERSION_1, features); + ut_asserteq_64(BIT_ULL(VIRTIO_F_VERSION_1), features); ut_assertok(virtio_set_features(dev)); ut_assertok(virtio_find_vqs(dev, nvqs, vqs)); ut_assertok(virtio_del_vqs(dev));
The virtqueue is passed to virtio_notify() so move the virtqueue deletion to the end of the test when it's no longer needed. This wasn't causing any problems because the sandbox virtio transport driver doesn't do anything for notifications, but it could cause problems if things change and it was a bad example.
Signed-off-by: Andrew Scull ascull@google.com Reviewed-by: Simon Glass sjg@chromium.org --- test/dm/virtio.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/test/dm/virtio.c b/test/dm/virtio.c index aa4e3d778e..ff1dea323c 100644 --- a/test/dm/virtio.c +++ b/test/dm/virtio.c @@ -80,8 +80,8 @@ static int dm_test_virtio_all_ops(struct unit_test_state *uts) ut_asserteq_64(BIT_ULL(VIRTIO_F_VERSION_1), features); ut_assertok(virtio_set_features(dev)); ut_assertok(virtio_find_vqs(dev, nvqs, vqs)); - ut_assertok(virtio_del_vqs(dev)); ut_assertok(virtio_notify(dev, vqs[0])); + ut_assertok(virtio_del_vqs(dev));
return 0; }
Virtio tests that find a child device require the virtio device driver to be included in the build so it can probe. The sandbox virtio transport driver currently reports a virtio-blk device so make sure the corresponding driver is built before running tests that need it.
Signed-off-by: Andrew Scull ascull@google.com --- test/dm/Makefile | 5 +- test/dm/virtio.c | 171 ------------------------------------ test/dm/virtio_device.c | 186 ++++++++++++++++++++++++++++++++++++++++ 3 files changed, 190 insertions(+), 172 deletions(-) create mode 100644 test/dm/virtio_device.c
diff --git a/test/dm/Makefile b/test/dm/Makefile index d46552fbf3..fa54f7cba3 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -106,7 +106,10 @@ obj-$(CONFIG_TEE) += tee.o obj-$(CONFIG_TIMER) += timer.o obj-$(CONFIG_DM_USB) += usb.o obj-$(CONFIG_DM_VIDEO) += video.o -obj-$(CONFIG_VIRTIO_SANDBOX) += virtio.o +ifeq ($(CONFIG_VIRTIO_SANDBOX),y) +obj-y += virtio.o +obj-$(CONFIG_VIRTIO_BLK) += virtio_device.o +endif ifeq ($(CONFIG_WDT_GPIO)$(CONFIG_WDT_SANDBOX),yy) obj-y += wdt.o endif diff --git a/test/dm/virtio.c b/test/dm/virtio.c index ff1dea323c..3e108cdc35 100644 --- a/test/dm/virtio.c +++ b/test/dm/virtio.c @@ -7,7 +7,6 @@ #include <dm.h> #include <virtio_types.h> #include <virtio.h> -#include <virtio_ring.h> #include <dm/device-internal.h> #include <dm/root.h> #include <dm/test.h> @@ -15,78 +14,6 @@ #include <test/test.h> #include <test/ut.h>
-/* Basic test of the virtio uclass */ -static int dm_test_virtio_base(struct unit_test_state *uts) -{ - struct udevice *bus, *dev; - u8 status; - - /* check probe success */ - ut_assertok(uclass_first_device(UCLASS_VIRTIO, &bus)); - ut_assertnonnull(bus); - - /* check the child virtio-blk device is bound */ - ut_assertok(device_find_first_child(bus, &dev)); - ut_assertnonnull(dev); - ut_assertok(strcmp(dev->name, "virtio-blk#0")); - - /* check driver status */ - ut_assertok(virtio_get_status(dev, &status)); - ut_asserteq(VIRTIO_CONFIG_S_ACKNOWLEDGE, status); - - return 0; -} -DM_TEST(dm_test_virtio_base, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT); - -/* Test all of the virtio uclass ops */ -static int dm_test_virtio_all_ops(struct unit_test_state *uts) -{ - struct udevice *bus, *dev; - struct virtio_dev_priv *uc_priv; - uint offset = 0, len = 0, nvqs = 1; - void *buffer = NULL; - u8 status; - u32 counter; - u64 features; - struct virtqueue *vqs[2]; - - /* check probe success */ - ut_assertok(uclass_first_device(UCLASS_VIRTIO, &bus)); - ut_assertnonnull(bus); - - /* check the child virtio-blk device is bound */ - ut_assertok(device_find_first_child(bus, &dev)); - ut_assertnonnull(dev); - - /* - * fake the virtio device probe by filling in uc_priv->vdev - * which is used by virtio_find_vqs/virtio_del_vqs. - */ - uc_priv = dev_get_uclass_priv(bus); - ut_assertnonnull(uc_priv); - uc_priv->vdev = dev; - - /* test virtio_xxx APIs */ - ut_assertok(virtio_get_config(dev, offset, buffer, len)); - ut_assertok(virtio_set_config(dev, offset, buffer, len)); - ut_asserteq(-ENOSYS, virtio_generation(dev, &counter)); - ut_assertok(virtio_set_status(dev, VIRTIO_CONFIG_S_DRIVER_OK)); - ut_assertok(virtio_get_status(dev, &status)); - ut_asserteq(VIRTIO_CONFIG_S_DRIVER_OK, status); - ut_assertok(virtio_reset(dev)); - ut_assertok(virtio_get_status(dev, &status)); - ut_asserteq(0, status); - ut_assertok(virtio_get_features(dev, &features)); - ut_asserteq_64(BIT_ULL(VIRTIO_F_VERSION_1), features); - ut_assertok(virtio_set_features(dev)); - ut_assertok(virtio_find_vqs(dev, nvqs, vqs)); - ut_assertok(virtio_notify(dev, vqs[0])); - ut_assertok(virtio_del_vqs(dev)); - - return 0; -} -DM_TEST(dm_test_virtio_all_ops, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT); - /* Test of the virtio driver that does not have required driver ops */ static int dm_test_virtio_missing_ops(struct unit_test_state *uts) { @@ -104,101 +31,3 @@ static int dm_test_virtio_missing_ops(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_virtio_missing_ops, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT); - -/* Test removal of virtio device driver */ -static int dm_test_virtio_remove(struct unit_test_state *uts) -{ - struct udevice *bus, *dev; - - /* check probe success */ - ut_assertok(uclass_first_device(UCLASS_VIRTIO, &bus)); - ut_assertnonnull(bus); - - /* check the child virtio-blk device is bound */ - ut_assertok(device_find_first_child(bus, &dev)); - ut_assertnonnull(dev); - - /* set driver status to VIRTIO_CONFIG_S_DRIVER_OK */ - ut_assertok(virtio_set_status(dev, VIRTIO_CONFIG_S_DRIVER_OK)); - - /* check the device can be successfully removed */ - dev_or_flags(dev, DM_FLAG_ACTIVATED); - ut_asserteq(-EKEYREJECTED, device_remove(bus, DM_REMOVE_ACTIVE_ALL)); - - ut_asserteq(false, device_active(dev)); - - return 0; -} -DM_TEST(dm_test_virtio_remove, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT); - -/* Test all of the virtio ring */ -static int dm_test_virtio_ring(struct unit_test_state *uts) -{ - struct udevice *bus, *dev; - struct virtio_dev_priv *uc_priv; - struct virtqueue *vq; - struct virtio_sg sg[2]; - struct virtio_sg *sgs[2]; - unsigned int len; - u8 buffer[2][32]; - - /* check probe success */ - ut_assertok(uclass_first_device(UCLASS_VIRTIO, &bus)); - ut_assertnonnull(bus); - - /* check the child virtio-blk device is bound */ - ut_assertok(device_find_first_child(bus, &dev)); - ut_assertnonnull(dev); - - /* - * fake the virtio device probe by filling in uc_priv->vdev - * which is used by virtio_find_vqs/virtio_del_vqs. - */ - uc_priv = dev_get_uclass_priv(bus); - ut_assertnonnull(uc_priv); - uc_priv->vdev = dev; - - /* prepare the scatter-gather buffer */ - sg[0].addr = buffer[0]; - sg[0].length = sizeof(buffer[0]); - sg[1].addr = buffer[1]; - sg[1].length = sizeof(buffer[1]); - sgs[0] = &sg[0]; - sgs[1] = &sg[1]; - - /* read a buffer and report written size from device */ - ut_assertok(virtio_find_vqs(dev, 1, &vq)); - ut_assertok(virtqueue_add(vq, sgs, 0, 1)); - vq->vring.used->idx = 1; - vq->vring.used->ring[0].id = 0; - vq->vring.used->ring[0].len = 0x53355885; - ut_asserteq_ptr(buffer, virtqueue_get_buf(vq, &len)); - ut_asserteq(0x53355885, len); - ut_assertok(virtio_del_vqs(dev)); - - /* rejects used descriptors that aren't a chain head */ - ut_assertok(virtio_find_vqs(dev, 1, &vq)); - ut_assertok(virtqueue_add(vq, sgs, 0, 2)); - vq->vring.used->idx = 1; - vq->vring.used->ring[0].id = 1; - vq->vring.used->ring[0].len = 0x53355885; - ut_assertnull(virtqueue_get_buf(vq, &len)); - ut_assertok(virtio_del_vqs(dev)); - - /* device changes to descriptor are ignored */ - ut_assertok(virtio_find_vqs(dev, 1, &vq)); - ut_assertok(virtqueue_add(vq, sgs, 0, 1)); - vq->vring.desc[0].addr = cpu_to_virtio64(dev, 0xbadbad11); - vq->vring.desc[0].len = cpu_to_virtio32(dev, 0x11badbad); - vq->vring.desc[0].flags = cpu_to_virtio16(dev, VRING_DESC_F_NEXT); - vq->vring.desc[0].next = cpu_to_virtio16(dev, U16_MAX); - vq->vring.used->idx = 1; - vq->vring.used->ring[0].id = 0; - vq->vring.used->ring[0].len = 6; - ut_asserteq_ptr(buffer, virtqueue_get_buf(vq, &len)); - ut_asserteq(6, len); - ut_assertok(virtio_del_vqs(dev)); - - return 0; -} -DM_TEST(dm_test_virtio_ring, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT); diff --git a/test/dm/virtio_device.c b/test/dm/virtio_device.c new file mode 100644 index 0000000000..46f4798fc2 --- /dev/null +++ b/test/dm/virtio_device.c @@ -0,0 +1,186 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com + */ + +#include <common.h> +#include <dm.h> +#include <virtio_types.h> +#include <virtio.h> +#include <virtio_ring.h> +#include <dm/device-internal.h> +#include <dm/root.h> +#include <dm/test.h> +#include <dm/uclass-internal.h> +#include <test/test.h> +#include <test/ut.h> + +/* Basic test of the virtio uclass */ +static int dm_test_virtio_base(struct unit_test_state *uts) +{ + struct udevice *bus, *dev; + u8 status; + + /* check probe success */ + ut_assertok(uclass_first_device(UCLASS_VIRTIO, &bus)); + ut_assertnonnull(bus); + + /* check the child virtio-blk device is bound */ + ut_assertok(device_find_first_child(bus, &dev)); + ut_assertnonnull(dev); + ut_assertok(strcmp(dev->name, "virtio-blk#0")); + + /* check driver status */ + ut_assertok(virtio_get_status(dev, &status)); + ut_asserteq(VIRTIO_CONFIG_S_ACKNOWLEDGE, status); + + return 0; +} +DM_TEST(dm_test_virtio_base, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT); + +/* Test all of the virtio uclass ops */ +static int dm_test_virtio_all_ops(struct unit_test_state *uts) +{ + struct udevice *bus, *dev; + struct virtio_dev_priv *uc_priv; + uint offset = 0, len = 0, nvqs = 1; + void *buffer = NULL; + u8 status; + u32 counter; + u64 features; + struct virtqueue *vqs[2]; + + /* check probe success */ + ut_assertok(uclass_first_device(UCLASS_VIRTIO, &bus)); + ut_assertnonnull(bus); + + /* check the child virtio-rng device is bound */ + ut_assertok(device_find_first_child(bus, &dev)); + ut_assertnonnull(dev); + + /* + * fake the virtio device probe by filling in uc_priv->vdev + * which is used by virtio_find_vqs/virtio_del_vqs. + */ + uc_priv = dev_get_uclass_priv(bus); + ut_assertnonnull(uc_priv); + uc_priv->vdev = dev; + + /* test virtio_xxx APIs */ + ut_assertok(virtio_get_config(dev, offset, buffer, len)); + ut_assertok(virtio_set_config(dev, offset, buffer, len)); + ut_asserteq(-ENOSYS, virtio_generation(dev, &counter)); + ut_assertok(virtio_set_status(dev, VIRTIO_CONFIG_S_DRIVER_OK)); + ut_assertok(virtio_get_status(dev, &status)); + ut_asserteq(VIRTIO_CONFIG_S_DRIVER_OK, status); + ut_assertok(virtio_reset(dev)); + ut_assertok(virtio_get_status(dev, &status)); + ut_asserteq(0, status); + ut_assertok(virtio_get_features(dev, &features)); + ut_asserteq_64(BIT_ULL(VIRTIO_F_VERSION_1), features); + ut_assertok(virtio_set_features(dev)); + ut_assertok(virtio_find_vqs(dev, nvqs, vqs)); + ut_assertok(virtio_notify(dev, vqs[0])); + ut_assertok(virtio_del_vqs(dev)); + + return 0; +} +DM_TEST(dm_test_virtio_all_ops, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT); + +/* Test removal of virtio device driver */ +static int dm_test_virtio_remove(struct unit_test_state *uts) +{ + struct udevice *bus, *dev; + + /* check probe success */ + ut_assertok(uclass_first_device(UCLASS_VIRTIO, &bus)); + ut_assertnonnull(bus); + + /* check the child virtio-rng device is bound */ + ut_assertok(device_find_first_child(bus, &dev)); + ut_assertnonnull(dev); + + /* set driver status to VIRTIO_CONFIG_S_DRIVER_OK */ + ut_assertok(virtio_set_status(dev, VIRTIO_CONFIG_S_DRIVER_OK)); + + /* check the device can be successfully removed */ + dev_or_flags(dev, DM_FLAG_ACTIVATED); + ut_asserteq(-EKEYREJECTED, device_remove(bus, DM_REMOVE_ACTIVE_ALL)); + + ut_asserteq(false, device_active(dev)); + + return 0; +} +DM_TEST(dm_test_virtio_remove, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT); + +/* Test all of the virtio ring */ +static int dm_test_virtio_ring(struct unit_test_state *uts) +{ + struct udevice *bus, *dev; + struct virtio_dev_priv *uc_priv; + struct virtqueue *vq; + struct virtio_sg sg[2]; + struct virtio_sg *sgs[2]; + unsigned int len; + u8 buffer[2][32]; + + /* check probe success */ + ut_assertok(uclass_first_device(UCLASS_VIRTIO, &bus)); + ut_assertnonnull(bus); + + /* check the child virtio-blk device is bound */ + ut_assertok(device_find_first_child(bus, &dev)); + ut_assertnonnull(dev); + + /* + * fake the virtio device probe by filling in uc_priv->vdev + * which is used by virtio_find_vqs/virtio_del_vqs. + */ + uc_priv = dev_get_uclass_priv(bus); + ut_assertnonnull(uc_priv); + uc_priv->vdev = dev; + + /* prepare the scatter-gather buffer */ + sg[0].addr = buffer[0]; + sg[0].length = sizeof(buffer[0]); + sg[1].addr = buffer[1]; + sg[1].length = sizeof(buffer[1]); + sgs[0] = &sg[0]; + sgs[1] = &sg[1]; + + /* read a buffer and report written size from device */ + ut_assertok(virtio_find_vqs(dev, 1, &vq)); + ut_assertok(virtqueue_add(vq, sgs, 0, 1)); + vq->vring.used->idx = 1; + vq->vring.used->ring[0].id = 0; + vq->vring.used->ring[0].len = 0x53355885; + ut_asserteq_ptr(buffer, virtqueue_get_buf(vq, &len)); + ut_asserteq(0x53355885, len); + ut_assertok(virtio_del_vqs(dev)); + + /* rejects used descriptors that aren't a chain head */ + ut_assertok(virtio_find_vqs(dev, 1, &vq)); + ut_assertok(virtqueue_add(vq, sgs, 0, 2)); + vq->vring.used->idx = 1; + vq->vring.used->ring[0].id = 1; + vq->vring.used->ring[0].len = 0x53355885; + ut_assertnull(virtqueue_get_buf(vq, &len)); + ut_assertok(virtio_del_vqs(dev)); + + /* device changes to descriptor are ignored */ + ut_assertok(virtio_find_vqs(dev, 1, &vq)); + ut_assertok(virtqueue_add(vq, sgs, 0, 1)); + vq->vring.desc[0].addr = cpu_to_virtio64(dev, 0xbadbad11); + vq->vring.desc[0].len = cpu_to_virtio32(dev, 0x11badbad); + vq->vring.desc[0].flags = cpu_to_virtio16(dev, VRING_DESC_F_NEXT); + vq->vring.desc[0].next = cpu_to_virtio16(dev, U16_MAX); + vq->vring.used->idx = 1; + vq->vring.used->ring[0].id = 0; + vq->vring.used->ring[0].len = 6; + ut_asserteq_ptr(buffer, virtqueue_get_buf(vq, &len)); + ut_asserteq(6, len); + ut_assertok(virtio_del_vqs(dev)); + + return 0; +} +DM_TEST(dm_test_virtio_ring, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT);
The virtio-rng driver is extremely simple, making it suitable for testing more of the virtio uclass logic. Have the sandbox driver bind the virtio-rng driver rather than the virtio-blk driver so it can be used in tests.
Signed-off-by: Andrew Scull ascull@google.com Reviewed-by: Simon Glass sjg@chromium.org --- drivers/virtio/virtio_sandbox.c | 2 +- test/dm/Makefile | 2 +- test/dm/virtio_device.c | 4 ++-- 3 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/virtio/virtio_sandbox.c b/drivers/virtio/virtio_sandbox.c index a73b123454..5484ae3a1a 100644 --- a/drivers/virtio/virtio_sandbox.c +++ b/drivers/virtio/virtio_sandbox.c @@ -161,7 +161,7 @@ static int virtio_sandbox_probe(struct udevice *udev)
/* fake some information for testing */ priv->device_features = BIT_ULL(VIRTIO_F_VERSION_1); - uc_priv->device = VIRTIO_ID_BLOCK; + uc_priv->device = VIRTIO_ID_RNG; uc_priv->vendor = ('u' << 24) | ('b' << 16) | ('o' << 8) | 't';
return 0; diff --git a/test/dm/Makefile b/test/dm/Makefile index fa54f7cba3..6c467b145e 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -108,7 +108,7 @@ obj-$(CONFIG_DM_USB) += usb.o obj-$(CONFIG_DM_VIDEO) += video.o ifeq ($(CONFIG_VIRTIO_SANDBOX),y) obj-y += virtio.o -obj-$(CONFIG_VIRTIO_BLK) += virtio_device.o +obj-$(CONFIG_VIRTIO_RNG) += virtio_device.o endif ifeq ($(CONFIG_WDT_GPIO)$(CONFIG_WDT_SANDBOX),yy) obj-y += wdt.o diff --git a/test/dm/virtio_device.c b/test/dm/virtio_device.c index 46f4798fc2..f5f2349750 100644 --- a/test/dm/virtio_device.c +++ b/test/dm/virtio_device.c @@ -25,10 +25,10 @@ static int dm_test_virtio_base(struct unit_test_state *uts) ut_assertok(uclass_first_device(UCLASS_VIRTIO, &bus)); ut_assertnonnull(bus);
- /* check the child virtio-blk device is bound */ + /* check the child virtio-rng device is bound */ ut_assertok(device_find_first_child(bus, &dev)); ut_assertnonnull(dev); - ut_assertok(strcmp(dev->name, "virtio-blk#0")); + ut_asserteq_str("virtio-rng#0", dev->name);
/* check driver status */ ut_assertok(virtio_get_status(dev, &status));
Once the virtio-rng driver has been bound, probe it to trigger the pre and post child probe hooks of the virtio uclass driver. Check the status of the virtio device to confirm it reached the expected state.
Signed-off-by: Andrew Scull ascull@google.com Reviewed-by: Simon Glass sjg@chromium.org --- test/dm/virtio_device.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/test/dm/virtio_device.c b/test/dm/virtio_device.c index f5f2349750..d0195e6bf0 100644 --- a/test/dm/virtio_device.c +++ b/test/dm/virtio_device.c @@ -34,6 +34,15 @@ static int dm_test_virtio_base(struct unit_test_state *uts) ut_assertok(virtio_get_status(dev, &status)); ut_asserteq(VIRTIO_CONFIG_S_ACKNOWLEDGE, status);
+ /* probe the virtio-rng driver */ + ut_assertok(device_probe(dev)); + + /* check the device was reset and the driver picked up the device */ + ut_assertok(virtio_get_status(dev, &status)); + ut_asserteq(VIRTIO_CONFIG_S_DRIVER | + VIRTIO_CONFIG_S_DRIVER_OK | + VIRTIO_CONFIG_S_FEATURES_OK, status); + return 0; } DM_TEST(dm_test_virtio_base, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT);
Check the length of data written by the device is consistent with the size of the buffers to avoid out-of-bounds memory accesses in case values aren't consistent.
Signed-off-by: Andrew Scull ascull@google.com Cc: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Simon Glass sjg@chromium.org --- drivers/virtio/virtio_rng.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/virtio/virtio_rng.c b/drivers/virtio/virtio_rng.c index 9314c0a03e..b85545c2ee 100644 --- a/drivers/virtio/virtio_rng.c +++ b/drivers/virtio/virtio_rng.c @@ -41,6 +41,9 @@ static int virtio_rng_read(struct udevice *dev, void *data, size_t len) while (!virtqueue_get_buf(priv->rng_vq, &rsize)) ;
+ if (rsize > sg.length) + return -EIO; + memcpy(ptr, buf, rsize); len -= rsize; ptr += rsize;
Add a regression test for virtio-rng reading beyond the end of its buffer if the virtio device provides an invalid length.
Signed-off-by: Andrew Scull ascull@google.com Reviewed-by: Simon Glass sjg@chromium.org --- test/dm/Makefile | 1 + test/dm/virtio_rng.c | 52 ++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 53 insertions(+) create mode 100644 test/dm/virtio_rng.c
diff --git a/test/dm/Makefile b/test/dm/Makefile index 6c467b145e..ba08c19515 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -109,6 +109,7 @@ obj-$(CONFIG_DM_VIDEO) += video.o ifeq ($(CONFIG_VIRTIO_SANDBOX),y) obj-y += virtio.o obj-$(CONFIG_VIRTIO_RNG) += virtio_device.o +obj-$(CONFIG_VIRTIO_RNG) += virtio_rng.o endif ifeq ($(CONFIG_WDT_GPIO)$(CONFIG_WDT_SANDBOX),yy) obj-y += wdt.o diff --git a/test/dm/virtio_rng.c b/test/dm/virtio_rng.c new file mode 100644 index 0000000000..ff5646b4e1 --- /dev/null +++ b/test/dm/virtio_rng.c @@ -0,0 +1,52 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2022 Google, Inc. + * Written by Andrew Scull ascull@google.com + */ + +#include <common.h> +#include <dm.h> +#include <virtio_types.h> +#include <virtio.h> +#include <virtio_ring.h> +#include <dm/device-internal.h> +#include <dm/test.h> +#include <rng.h> +#include <test/test.h> +#include <test/ut.h> + +/* This is a brittle means of getting access to the virtqueue */ +struct virtio_rng_priv { + struct virtqueue *rng_vq; +}; + +/* Test the virtio-rng driver validates the used size */ +static int dm_test_virtio_rng_check_len(struct unit_test_state *uts) +{ + struct udevice *bus, *dev; + struct virtio_rng_priv *priv; + u8 buffer[16]; + + /* check probe success */ + ut_assertok(uclass_first_device(UCLASS_VIRTIO, &bus)); + ut_assertnonnull(bus); + + /* check the child virtio-rng device is bound */ + ut_assertok(device_find_first_child(bus, &dev)); + ut_assertnonnull(dev); + + /* probe the virtio-rng driver */ + ut_assertok(device_probe(dev)); + + /* simulate the device returning the buffer with too much data */ + priv = dev_get_priv(dev); + priv->rng_vq->vring.used->idx = 1; + priv->rng_vq->vring.used->ring[0].id = 0; + priv->rng_vq->vring.used->ring[0].len = U32_MAX; + + /* check the driver gracefully handles the error */ + ut_asserteq(-EIO, dm_rng_read(dev, buffer, sizeof(buffer))); + + return 0; +} +DM_TEST(dm_test_virtio_rng_check_len, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT);
Andrew Scull
Bin Meng
