[U-Boot] [PATCH u-boot 0/5] Aspeed I2C driver, using Driver Model.
This series of patches is only meant for openbmc/u-boot tree. It adds basic support for aspeed i2c. Only single master mode is supported with synchronous transfer.
The style is inconsistent with U-Boot style guide in few places, but follows local style in those files.
Maxim Sloyko (5): aspeed/g5: Device Tree for ast2500, copied from openbmc/linux (include file), plus minimal device tree configuration for ast2500 eval board. aspeed: Fixed incosistency in some SCU registers naming. aspeed: Added function to calculate APB Clock frequency. aspeed: Added function to configure pins for I2C devices. aspeed: I2C driver.
arch/arm/dts/Makefile | 2 + arch/arm/dts/aspeed-g5-evb.dts | 28 + arch/arm/dts/aspeed-g5.dtsi | 1278 +++++++++++++++++++++++++++ arch/arm/include/asm/arch-aspeed/ast_scu.h | 6 + arch/arm/include/asm/arch-aspeed/regs-scu.h | 73 +- arch/arm/mach-aspeed/ast-scu.c | 41 +- drivers/i2c/Kconfig | 7 + drivers/i2c/Makefile | 1 + drivers/i2c/ast_i2c.c | 305 +++++++ drivers/i2c/ast_i2c.h | 143 +++ 10 files changed, 1851 insertions(+), 33 deletions(-) create mode 100644 arch/arm/dts/aspeed-g5-evb.dts create mode 100644 arch/arm/dts/aspeed-g5.dtsi create mode 100644 drivers/i2c/ast_i2c.c create mode 100644 drivers/i2c/ast_i2c.h
-- 2.8.0.rc3.226.g39d4020
aspeed-g5.dtsi include file is copied from https://github.com/openbmc/linux/blob/c5682cb/arch/arm/boot/dts/aspeed-g5.dt...
Signed-off-by: Maxim Sloyko maxims@google.com --- arch/arm/dts/Makefile | 2 + arch/arm/dts/aspeed-g5-evb.dts | 28 + arch/arm/dts/aspeed-g5.dtsi | 1278 ++++++++++++++++++++++++++++++++++++++++ 3 files changed, 1308 insertions(+) create mode 100644 arch/arm/dts/aspeed-g5-evb.dts create mode 100644 arch/arm/dts/aspeed-g5.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index ef573ec..333bf3b 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -262,6 +262,8 @@ dtb-$(CONFIG_SOC_KEYSTONE) += k2hk-evm.dtb \ k2e-evm.dtb \ k2g-evm.dtb
+dtb-$(CONFIG_TARGET_AST_G5) += aspeed-g5-evb.dtb + targets += $(dtb-y)
# Add any required device tree compiler flags here diff --git a/arch/arm/dts/aspeed-g5-evb.dts b/arch/arm/dts/aspeed-g5-evb.dts new file mode 100644 index 0000000..95dc77a --- /dev/null +++ b/arch/arm/dts/aspeed-g5-evb.dts @@ -0,0 +1,28 @@ +/dts-v1/; + +#include "aspeed-g5.dtsi" + +/ { + memory { + device_type = "memory"; + reg = <0x80000000 0x20000000>; + }; + + aliases { + i2c1 = &i2c0; + i2c4 = &i2c3; + i2c8 = &i2c7; + }; +}; + +&i2c0 { + status = "okay"; +}; + +&i2c3 { + status = "okay"; +}; + +&i2c7 { + status = "okay"; +}; diff --git a/arch/arm/dts/aspeed-g5.dtsi b/arch/arm/dts/aspeed-g5.dtsi new file mode 100644 index 0000000..eb87728 --- /dev/null +++ b/arch/arm/dts/aspeed-g5.dtsi @@ -0,0 +1,1278 @@ +/* This device tree is copied from + * https://github.com/openbmc/linux/blob/c5682cb/arch/arm/boot/dts/aspeed-g5.dt... + */ + +#include "skeleton.dtsi" + +/ { + model = "Aspeed BMC"; + compatible = "aspeed,ast2500"; + #address-cells = <1>; + #size-cells = <1>; + interrupt-parent = <&vic>; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + compatible = "arm,arm1176jzf-s"; + device_type = "cpu"; + reg = <0>; + }; + }; + + ahb { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + fmc: flash-controller@1e620000 { + reg = < 0x1e620000 0xc4 + 0x20000000 0x10000000 >; + #address-cells = <1>; + #size-cells = <0>; + compatible = "aspeed,ast2500-fmc"; + status = "disabled"; + aspeed,fmc-has-dma; + interrupts = <19>; + flash@0 { + reg = < 0 >; + compatible = "jedec,spi-nor"; + status = "disabled"; + }; + flash@1 { + reg = < 1 >; + compatible = "jedec,spi-nor"; + status = "disabled"; + }; + flash@2 { + reg = < 2 >; + compatible = "jedec,spi-nor"; + // compatible = "cfi,flash", "jedec,flash"; + status = "disabled"; + }; + }; + + spi1: flash-controller@1e630000 { + reg = < 0x1e630000 0xc4 + 0x30000000 0x08000000 >; + #address-cells = <1>; + #size-cells = <0>; + compatible = "aspeed,ast2500-smc"; + status = "disabled"; + flash@0 { + reg = < 0 >; + compatible = "jedec,spi-nor"; + status = "disabled"; + }; + flash@1 { + reg = < 1 >; + compatible = "jedec,spi-nor"; + status = "disabled"; + }; + }; + + spi2: flash-controller@1e631000 { + reg = < 0x1e631000 0xc4 + 0x38000000 0x08000000 >; + #address-cells = <1>; + #size-cells = <0>; + compatible = "aspeed,ast2500-smc"; + status = "disabled"; + flash@0 { + reg = < 0 >; + compatible = "jedec,spi-nor"; + status = "disabled"; + }; + flash@1 { + reg = < 1 >; + compatible = "jedec,spi-nor"; + status = "disabled"; + }; + }; + + vic: interrupt-controller@1e6c0080 { + compatible = "aspeed,ast2400-vic"; + interrupt-controller; + #interrupt-cells = <1>; + valid-sources = <0xfefff7ff 0x0807ffff>; + reg = <0x1e6c0080 0x80>; + }; + + mac0: ethernet@1e660000 { + compatible = "faraday,ftgmac100"; + reg = <0x1e660000 0x180>; + interrupts = <2>; + no-hw-checksum; + status = "disabled"; + }; + + mac1: ethernet@1e680000 { + compatible = "faraday,ftgmac100"; + reg = <0x1e680000 0x180>; + interrupts = <3>; + no-hw-checksum; + status = "disabled"; + }; + + apb { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + clk_clkin: clk_clkin@1e6e2070 { + #clock-cells = <0>; + compatible = "aspeed,g5-clkin-clock"; + reg = <0x1e6e2070 0x04>; + }; + + syscon: syscon@1e6e2000 { + compatible = "aspeed,g5-scu", "syscon", "simple-mfd"; + reg = <0x1e6e2000 0x1a8>; + + pinctrl: pinctrl@1e6e2000 { + compatible = "aspeed,g5-pinctrl"; + + pinctrl_acpi_default: acpi_default { + function = "ACPI"; + groups = "ACPI"; + }; + + pinctrl_adc0_default: adc0_default { + function = "ADC0"; + groups = "ADC0"; + }; + + pinctrl_adc1_default: adc1_default { + function = "ADC1"; + groups = "ADC1"; + }; + + pinctrl_adc10_default: adc10_default { + function = "ADC10"; + groups = "ADC10"; + }; + + pinctrl_adc11_default: adc11_default { + function = "ADC11"; + groups = "ADC11"; + }; + + pinctrl_adc12_default: adc12_default { + function = "ADC12"; + groups = "ADC12"; + }; + + pinctrl_adc13_default: adc13_default { + function = "ADC13"; + groups = "ADC13"; + }; + + pinctrl_adc14_default: adc14_default { + function = "ADC14"; + groups = "ADC14"; + }; + + pinctrl_adc15_default: adc15_default { + function = "ADC15"; + groups = "ADC15"; + }; + + pinctrl_adc2_default: adc2_default { + function = "ADC2"; + groups = "ADC2"; + }; + + pinctrl_adc3_default: adc3_default { + function = "ADC3"; + groups = "ADC3"; + }; + + pinctrl_adc4_default: adc4_default { + function = "ADC4"; + groups = "ADC4"; + }; + + pinctrl_adc5_default: adc5_default { + function = "ADC5"; + groups = "ADC5"; + }; + + pinctrl_adc6_default: adc6_default { + function = "ADC6"; + groups = "ADC6"; + }; + + pinctrl_adc7_default: adc7_default { + function = "ADC7"; + groups = "ADC7"; + }; + + pinctrl_adc8_default: adc8_default { + function = "ADC8"; + groups = "ADC8"; + }; + + pinctrl_adc9_default: adc9_default { + function = "ADC9"; + groups = "ADC9"; + }; + + pinctrl_bmcint_default: bmcint_default { + function = "BMCINT"; + groups = "BMCINT"; + }; + + pinctrl_ddcclk_default: ddcclk_default { + function = "DDCCLK"; + groups = "DDCCLK"; + }; + + pinctrl_ddcdat_default: ddcdat_default { + function = "DDCDAT"; + groups = "DDCDAT"; + }; + + pinctrl_espi_default: espi_default { + function = "ESPI"; + groups = "ESPI"; + }; + + pinctrl_fwspics1_default: fwspics1_default { + function = "FWSPICS1"; + groups = "FWSPICS1"; + }; + + pinctrl_fwspics2_default: fwspics2_default { + function = "FWSPICS2"; + groups = "FWSPICS2"; + }; + + pinctrl_gpid0_default: gpid0_default { + function = "GPID0"; + groups = "GPID0"; + }; + + pinctrl_gpid2_default: gpid2_default { + function = "GPID2"; + groups = "GPID2"; + }; + + pinctrl_gpid4_default: gpid4_default { + function = "GPID4"; + groups = "GPID4"; + }; + + pinctrl_gpid6_default: gpid6_default { + function = "GPID6"; + groups = "GPID6"; + }; + + pinctrl_gpie0_default: gpie0_default { + function = "GPIE0"; + groups = "GPIE0"; + }; + + pinctrl_gpie2_default: gpie2_default { + function = "GPIE2"; + groups = "GPIE2"; + }; + + pinctrl_gpie4_default: gpie4_default { + function = "GPIE4"; + groups = "GPIE4"; + }; + + pinctrl_gpie6_default: gpie6_default { + function = "GPIE6"; + groups = "GPIE6"; + }; + + pinctrl_i2c10_default: i2c10_default { + function = "I2C10"; + groups = "I2C10"; + }; + + pinctrl_i2c11_default: i2c11_default { + function = "I2C11"; + groups = "I2C11"; + }; + + pinctrl_i2c12_default: i2c12_default { + function = "I2C12"; + groups = "I2C12"; + }; + + pinctrl_i2c13_default: i2c13_default { + function = "I2C13"; + groups = "I2C13"; + }; + + pinctrl_i2c14_default: i2c14_default { + function = "I2C14"; + groups = "I2C14"; + }; + + pinctrl_i2c3_default: i2c3_default { + function = "I2C3"; + groups = "I2C3"; + }; + + pinctrl_i2c4_default: i2c4_default { + function = "I2C4"; + groups = "I2C4"; + }; + + pinctrl_i2c5_default: i2c5_default { + function = "I2C5"; + groups = "I2C5"; + }; + + pinctrl_i2c6_default: i2c6_default { + function = "I2C6"; + groups = "I2C6"; + }; + + pinctrl_i2c7_default: i2c7_default { + function = "I2C7"; + groups = "I2C7"; + }; + + pinctrl_i2c8_default: i2c8_default { + function = "I2C8"; + groups = "I2C8"; + }; + + pinctrl_i2c9_default: i2c9_default { + function = "I2C9"; + groups = "I2C9"; + }; + + pinctrl_lad0_default: lad0_default { + function = "LAD0"; + groups = "LAD0"; + }; + + pinctrl_lad1_default: lad1_default { + function = "LAD1"; + groups = "LAD1"; + }; + + pinctrl_lad2_default: lad2_default { + function = "LAD2"; + groups = "LAD2"; + }; + + pinctrl_lad3_default: lad3_default { + function = "LAD3"; + groups = "LAD3"; + }; + + pinctrl_lclk_default: lclk_default { + function = "LCLK"; + groups = "LCLK"; + }; + + pinctrl_lframe_default: lframe_default { + function = "LFRAME"; + groups = "LFRAME"; + }; + + pinctrl_lpchc_default: lpchc_default { + function = "LPCHC"; + groups = "LPCHC"; + }; + + pinctrl_lpcpd_default: lpcpd_default { + function = "LPCPD"; + groups = "LPCPD"; + }; + + pinctrl_lpcplus_default: lpcplus_default { + function = "LPCPLUS"; + groups = "LPCPLUS"; + }; + + pinctrl_lpcpme_default: lpcpme_default { + function = "LPCPME"; + groups = "LPCPME"; + }; + + pinctrl_lpcrst_default: lpcrst_default { + function = "LPCRST"; + groups = "LPCRST"; + }; + + pinctrl_lpcsmi_default: lpcsmi_default { + function = "LPCSMI"; + groups = "LPCSMI"; + }; + + pinctrl_lsirq_default: lsirq_default { + function = "LSIRQ"; + groups = "LSIRQ"; + }; + + pinctrl_mac1link_default: mac1link_default { + function = "MAC1LINK"; + groups = "MAC1LINK"; + }; + + pinctrl_mac2link_default: mac2link_default { + function = "MAC2LINK"; + groups = "MAC2LINK"; + }; + + pinctrl_mdio1_default: mdio1_default { + function = "MDIO1"; + groups = "MDIO1"; + }; + + pinctrl_mdio2_default: mdio2_default { + function = "MDIO2"; + groups = "MDIO2"; + }; + + pinctrl_ncts1_default: ncts1_default { + function = "NCTS1"; + groups = "NCTS1"; + }; + + pinctrl_ncts2_default: ncts2_default { + function = "NCTS2"; + groups = "NCTS2"; + }; + + pinctrl_ncts3_default: ncts3_default { + function = "NCTS3"; + groups = "NCTS3"; + }; + + pinctrl_ncts4_default: ncts4_default { + function = "NCTS4"; + groups = "NCTS4"; + }; + + pinctrl_ndcd1_default: ndcd1_default { + function = "NDCD1"; + groups = "NDCD1"; + }; + + pinctrl_ndcd2_default: ndcd2_default { + function = "NDCD2"; + groups = "NDCD2"; + }; + + pinctrl_ndcd3_default: ndcd3_default { + function = "NDCD3"; + groups = "NDCD3"; + }; + + pinctrl_ndcd4_default: ndcd4_default { + function = "NDCD4"; + groups = "NDCD4"; + }; + + pinctrl_ndsr1_default: ndsr1_default { + function = "NDSR1"; + groups = "NDSR1"; + }; + + pinctrl_ndsr2_default: ndsr2_default { + function = "NDSR2"; + groups = "NDSR2"; + }; + + pinctrl_ndsr3_default: ndsr3_default { + function = "NDSR3"; + groups = "NDSR3"; + }; + + pinctrl_ndsr4_default: ndsr4_default { + function = "NDSR4"; + groups = "NDSR4"; + }; + + pinctrl_ndtr1_default: ndtr1_default { + function = "NDTR1"; + groups = "NDTR1"; + }; + + pinctrl_ndtr2_default: ndtr2_default { + function = "NDTR2"; + groups = "NDTR2"; + }; + + pinctrl_ndtr3_default: ndtr3_default { + function = "NDTR3"; + groups = "NDTR3"; + }; + + pinctrl_ndtr4_default: ndtr4_default { + function = "NDTR4"; + groups = "NDTR4"; + }; + + pinctrl_nri1_default: nri1_default { + function = "NRI1"; + groups = "NRI1"; + }; + + pinctrl_nri2_default: nri2_default { + function = "NRI2"; + groups = "NRI2"; + }; + + pinctrl_nri3_default: nri3_default { + function = "NRI3"; + groups = "NRI3"; + }; + + pinctrl_nri4_default: nri4_default { + function = "NRI4"; + groups = "NRI4"; + }; + + pinctrl_nrts1_default: nrts1_default { + function = "NRTS1"; + groups = "NRTS1"; + }; + + pinctrl_nrts2_default: nrts2_default { + function = "NRTS2"; + groups = "NRTS2"; + }; + + pinctrl_nrts3_default: nrts3_default { + function = "NRTS3"; + groups = "NRTS3"; + }; + + pinctrl_nrts4_default: nrts4_default { + function = "NRTS4"; + groups = "NRTS4"; + }; + + pinctrl_oscclk_default: oscclk_default { + function = "OSCCLK"; + groups = "OSCCLK"; + }; + + pinctrl_pewake_default: pewake_default { + function = "PEWAKE"; + groups = "PEWAKE"; + }; + + pinctrl_pnor_default: pnor_default { + function = "PNOR"; + groups = "PNOR"; + }; + + pinctrl_pwm0_default: pwm0_default { + function = "PWM0"; + groups = "PWM0"; + }; + + pinctrl_pwm1_default: pwm1_default { + function = "PWM1"; + groups = "PWM1"; + }; + + pinctrl_pwm2_default: pwm2_default { + function = "PWM2"; + groups = "PWM2"; + }; + + pinctrl_pwm3_default: pwm3_default { + function = "PWM3"; + groups = "PWM3"; + }; + + pinctrl_pwm4_default: pwm4_default { + function = "PWM4"; + groups = "PWM4"; + }; + + pinctrl_pwm5_default: pwm5_default { + function = "PWM5"; + groups = "PWM5"; + }; + + pinctrl_pwm6_default: pwm6_default { + function = "PWM6"; + groups = "PWM6"; + }; + + pinctrl_pwm7_default: pwm7_default { + function = "PWM7"; + groups = "PWM7"; + }; + + pinctrl_rgmii1_default: rgmii1_default { + function = "RGMII1"; + groups = "RGMII1"; + }; + + pinctrl_rgmii2_default: rgmii2_default { + function = "RGMII2"; + groups = "RGMII2"; + }; + + pinctrl_rmii1_default: rmii1_default { + function = "RMII1"; + groups = "RMII1"; + }; + + pinctrl_rmii2_default: rmii2_default { + function = "RMII2"; + groups = "RMII2"; + }; + + pinctrl_rxd1_default: rxd1_default { + function = "RXD1"; + groups = "RXD1"; + }; + + pinctrl_rxd2_default: rxd2_default { + function = "RXD2"; + groups = "RXD2"; + }; + + pinctrl_rxd3_default: rxd3_default { + function = "RXD3"; + groups = "RXD3"; + }; + + pinctrl_rxd4_default: rxd4_default { + function = "RXD4"; + groups = "RXD4"; + }; + + pinctrl_salt1_default: salt1_default { + function = "SALT1"; + groups = "SALT1"; + }; + + pinctrl_salt10_default: salt10_default { + function = "SALT10"; + groups = "SALT10"; + }; + + pinctrl_salt11_default: salt11_default { + function = "SALT11"; + groups = "SALT11"; + }; + + pinctrl_salt12_default: salt12_default { + function = "SALT12"; + groups = "SALT12"; + }; + + pinctrl_salt13_default: salt13_default { + function = "SALT13"; + groups = "SALT13"; + }; + + pinctrl_salt14_default: salt14_default { + function = "SALT14"; + groups = "SALT14"; + }; + + pinctrl_salt2_default: salt2_default { + function = "SALT2"; + groups = "SALT2"; + }; + + pinctrl_salt3_default: salt3_default { + function = "SALT3"; + groups = "SALT3"; + }; + + pinctrl_salt4_default: salt4_default { + function = "SALT4"; + groups = "SALT4"; + }; + + pinctrl_salt5_default: salt5_default { + function = "SALT5"; + groups = "SALT5"; + }; + + pinctrl_salt6_default: salt6_default { + function = "SALT6"; + groups = "SALT6"; + }; + + pinctrl_salt7_default: salt7_default { + function = "SALT7"; + groups = "SALT7"; + }; + + pinctrl_salt8_default: salt8_default { + function = "SALT8"; + groups = "SALT8"; + }; + + pinctrl_salt9_default: salt9_default { + function = "SALT9"; + groups = "SALT9"; + }; + + pinctrl_scl1_default: scl1_default { + function = "SCL1"; + groups = "SCL1"; + }; + + pinctrl_scl2_default: scl2_default { + function = "SCL2"; + groups = "SCL2"; + }; + + pinctrl_sd1_default: sd1_default { + function = "SD1"; + groups = "SD1"; + }; + + pinctrl_sd2_default: sd2_default { + function = "SD2"; + groups = "SD2"; + }; + + pinctrl_sda1_default: sda1_default { + function = "SDA1"; + groups = "SDA1"; + }; + + pinctrl_sda2_default: sda2_default { + function = "SDA2"; + groups = "SDA2"; + }; + + pinctrl_sgps1_default: sgps1_default { + function = "SGPS1"; + groups = "SGPS1"; + }; + + pinctrl_sgps2_default: sgps2_default { + function = "SGPS2"; + groups = "SGPS2"; + }; + + pinctrl_sioonctrl_default: sioonctrl_default { + function = "SIOONCTRL"; + groups = "SIOONCTRL"; + }; + + pinctrl_siopbi_default: siopbi_default { + function = "SIOPBI"; + groups = "SIOPBI"; + }; + + pinctrl_siopbo_default: siopbo_default { + function = "SIOPBO"; + groups = "SIOPBO"; + }; + + pinctrl_siopwreq_default: siopwreq_default { + function = "SIOPWREQ"; + groups = "SIOPWREQ"; + }; + + pinctrl_siopwrgd_default: siopwrgd_default { + function = "SIOPWRGD"; + groups = "SIOPWRGD"; + }; + + pinctrl_sios3_default: sios3_default { + function = "SIOS3"; + groups = "SIOS3"; + }; + + pinctrl_sios5_default: sios5_default { + function = "SIOS5"; + groups = "SIOS5"; + }; + + pinctrl_siosci_default: siosci_default { + function = "SIOSCI"; + groups = "SIOSCI"; + }; + + pinctrl_spi1_default: spi1_default { + function = "SPI1"; + groups = "SPI1"; + }; + + pinctrl_spi1cs1_default: spi1cs1_default { + function = "SPI1CS1"; + groups = "SPI1CS1"; + }; + + pinctrl_spi1debug_default: spi1debug_default { + function = "SPI1DEBUG"; + groups = "SPI1DEBUG"; + }; + + pinctrl_spi1passthru_default: spi1passthru_default { + function = "SPI1PASSTHRU"; + groups = "SPI1PASSTHRU"; + }; + + pinctrl_spi2ck_default: spi2ck_default { + function = "SPI2CK"; + groups = "SPI2CK"; + }; + + pinctrl_spi2cs0_default: spi2cs0_default { + function = "SPI2CS0"; + groups = "SPI2CS0"; + }; + + pinctrl_spi2cs1_default: spi2cs1_default { + function = "SPI2CS1"; + groups = "SPI2CS1"; + }; + + pinctrl_spi2miso_default: spi2miso_default { + function = "SPI2MISO"; + groups = "SPI2MISO"; + }; + + pinctrl_spi2mosi_default: spi2mosi_default { + function = "SPI2MOSI"; + groups = "SPI2MOSI"; + }; + + pinctrl_timer3_default: timer3_default { + function = "TIMER3"; + groups = "TIMER3"; + }; + + pinctrl_timer4_default: timer4_default { + function = "TIMER4"; + groups = "TIMER4"; + }; + + pinctrl_timer5_default: timer5_default { + function = "TIMER5"; + groups = "TIMER5"; + }; + + pinctrl_timer6_default: timer6_default { + function = "TIMER6"; + groups = "TIMER6"; + }; + + pinctrl_timer7_default: timer7_default { + function = "TIMER7"; + groups = "TIMER7"; + }; + + pinctrl_timer8_default: timer8_default { + function = "TIMER8"; + groups = "TIMER8"; + }; + + pinctrl_txd1_default: txd1_default { + function = "TXD1"; + groups = "TXD1"; + }; + + pinctrl_txd2_default: txd2_default { + function = "TXD2"; + groups = "TXD2"; + }; + + pinctrl_txd3_default: txd3_default { + function = "TXD3"; + groups = "TXD3"; + }; + + pinctrl_txd4_default: txd4_default { + function = "TXD4"; + groups = "TXD4"; + }; + + pinctrl_uart6_default: uart6_default { + function = "UART6"; + groups = "UART6"; + }; + + pinctrl_usbcki_default: usbcki_default { + function = "USBCKI"; + groups = "USBCKI"; + }; + + pinctrl_vgabiosrom_default: vgabiosrom_default { + function = "VGABIOSROM"; + groups = "VGABIOSROM"; + }; + + pinctrl_vgahs_default: vgahs_default { + function = "VGAHS"; + groups = "VGAHS"; + }; + + pinctrl_vgavs_default: vgavs_default { + function = "VGAVS"; + groups = "VGAVS"; + }; + + pinctrl_vpi24_default: vpi24_default { + function = "VPI24"; + groups = "VPI24"; + }; + + pinctrl_vpo_default: vpo_default { + function = "VPO"; + groups = "VPO"; + }; + + pinctrl_wdtrst1_default: wdtrst1_default { + function = "WDTRST1"; + groups = "WDTRST1"; + }; + + pinctrl_wdtrst2_default: wdtrst2_default { + function = "WDTRST2"; + groups = "WDTRST2"; + }; + + }; + }; + + clk_hpll: clk_hpll@1e6e2024 { + #clock-cells = <0>; + compatible = "aspeed,g5-hpll-clock"; + reg = <0x1e6e2024 0x4>; + clocks = <&clk_clkin>; + }; + + clk_ahb: clk_ahb@1e6e2070 { + #clock-cells = <0>; + compatible = "aspeed,g5-ahb-clock"; + reg = <0x1e6e2070 0x4>; + clocks = <&clk_hpll>; + }; + + clk_apb: clk_apb@1e6e2008 { + #clock-cells = <0>; + compatible = "aspeed,g5-apb-clock"; + reg = <0x1e6e2008 0x4>; + clocks = <&clk_hpll>; + }; + + clk_uart: clk_uart@1e6e2008 { + #clock-cells = <0>; + compatible = "aspeed,uart-clock"; + reg = <0x1e6e202c 0x4>; + }; + + sram@1e720000 { + compatible = "mmio-sram"; + reg = <0x1e720000 0x9000>; // 36K + }; + + gpio: gpio@1e780000 { + #gpio-cells = <2>; + gpio-controller; + compatible = "aspeed,ast2500-gpio"; + reg = <0x1e780000 0x1000>; + interrupts = <20>; + gpio-ranges = <&pinctrl 0 0 220>; + }; + + timer: timer@1e782000 { + compatible = "aspeed,ast2400-timer"; + reg = <0x1e782000 0x90>; + // The moxart_timer driver registers only one + // interrupt and assumes it's for timer 1 + //interrupts = <16 17 18 35 36 37 38 39>; + interrupts = <16>; + clocks = <&clk_apb>; + }; + + ibt: ibt@1e789140 { + compatible = "aspeed,bt-host"; + reg = <0x1e789140 0x18>; + interrupts = <8>; + }; + + wdt1: wdt@1e785000 { + compatible = "aspeed,ast2500-wdt"; + reg = <0x1e785000 0x1c>; + }; + + wdt2: wdt@1e785020 { + compatible = "aspeed,ast2500-wdt"; + reg = <0x1e785020 0x1c>; + status = "disabled"; + }; + + wdt3: wdt@1e785040 { + compatible = "aspeed,wdt"; + reg = <0x1e785074 0x1c>; + status = "disabled"; + }; + + uart1: serial@1e783000 { + compatible = "ns16550a"; + reg = <0x1e783000 0x1000>; + reg-shift = <2>; + interrupts = <9>; + clocks = <&clk_uart>; + no-loopback-test; + status = "disabled"; + }; + + uart2: serial@1e78d000 { + compatible = "ns16550a"; + reg = <0x1e78d000 0x1000>; + reg-shift = <2>; + interrupts = <32>; + clocks = <&clk_uart>; + no-loopback-test; + status = "disabled"; + }; + + uart3: serial@1e78e000 { + compatible = "ns16550a"; + reg = <0x1e78e000 0x1000>; + reg-shift = <2>; + interrupts = <33>; + clocks = <&clk_uart>; + no-loopback-test; + status = "disabled"; + }; + + uart4: serial@1e78f000 { + compatible = "ns16550a"; + reg = <0x1e78f000 0x1000>; + reg-shift = <2>; + interrupts = <34>; + clocks = <&clk_uart>; + no-loopback-test; + status = "disabled"; + }; + + uart5: serial@1e784000 { + compatible = "ns16550a"; + reg = <0x1e784000 0x1000>; + reg-shift = <2>; + interrupts = <10>; + clocks = <&clk_uart>; + current-speed = <38400>; + no-loopback-test; + status = "disabled"; + }; + + vuart: vuart@1e787000 { + compatible = "aspeed,vuart"; + reg = <0x1e787000 0x1000>; + reg-shift = <2>; + interrupts = <8>; + clocks = <&clk_uart>; + no-loopback-test; + status = "disabled"; + }; + + i2c: i2c@1e78a000 { + #address-cells = <1>; + #size-cells = <1>; + #interrupt-cells = <1>; + + compatible = "aspeed,ast2400-i2c-controller"; + reg = <0x1e78a000 0x40>; + ranges = <0 0x1e78a000 0x1000>; + interrupts = <12>; + clocks = <&clk_apb>; + clock-ranges; + interrupt-controller; + + i2c0: i2c-bus@40 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x40 0x40>; + compatible = "aspeed,ast2400-i2c-bus"; + bus = <0>; + clock-frequency = <100000>; + status = "disabled"; + interrupts = <0>; + interrupt-parent = <&i2c>; + }; + + i2c1: i2c-bus@80 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x80 0x40>; + compatible = "aspeed,ast2400-i2c-bus"; + bus = <1>; + clock-frequency = <100000>; + status = "disabled"; + interrupts = <1>; + }; + + i2c2: i2c-bus@c0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0xC0 0x40>; + compatible = "aspeed,ast2400-i2c-bus"; + bus = <2>; + clock-frequency = <100000>; + status = "disabled"; + interrupts = <2>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3_default>; + }; + + i2c3: i2c-bus@100 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x100 0x40>; + compatible = "aspeed,ast2400-i2c-bus"; + bus = <3>; + clock-frequency = <100000>; + status = "disabled"; + interrupts = <3>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c4_default>; + }; + + i2c4: i2c-bus@140 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x140 0x40>; + compatible = "aspeed,ast2400-i2c-bus"; + bus = <4>; + clock-frequency = <100000>; + status = "disabled"; + interrupts = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c5_default>; + }; + + i2c5: i2c-bus@180 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x180 0x40>; + compatible = "aspeed,ast2400-i2c-bus"; + bus = <5>; + clock-frequency = <100000>; + status = "disabled"; + interrupts = <5>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c6_default>; + }; + + i2c6: i2c-bus@1c0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x1C0 0x40>; + compatible = "aspeed,ast2400-i2c-bus"; + bus = <6>; + clock-frequency = <100000>; + status = "disabled"; + interrupts = <6>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c7_default>; + }; + + i2c7: i2c-bus@300 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x300 0x40>; + compatible = "aspeed,ast2400-i2c-bus"; + bus = <7>; + clock-frequency = <100000>; + status = "disabled"; + interrupts = <7>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c8_default>; + }; + + i2c8: i2c-bus@340 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x340 0x40>; + compatible = "aspeed,ast2400-i2c-bus"; + bus = <8>; + clock-frequency = <100000>; + status = "disabled"; + interrupts = <8>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c9_default>; + }; + + i2c9: i2c-bus@380 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x380 0x40>; + compatible = "aspeed,ast2400-i2c-bus"; + bus = <9>; + clock-frequency = <100000>; + status = "disabled"; + interrupts = <9>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c10_default>; + }; + + i2c10: i2c-bus@3c0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x3c0 0x40>; + compatible = "aspeed,ast2400-i2c-bus"; + bus = <10>; + clock-frequency = <100000>; + status = "disabled"; + interrupts = <10>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c11_default>; + }; + + i2c11: i2c-bus@400 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x400 0x40>; + compatible = "aspeed,ast2400-i2c-bus"; + bus = <11>; + clock-frequency = <100000>; + status = "disabled"; + interrupts = <11>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c12_default>; + }; + + i2c12: i2c-bus@440 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x440 0x40>; + compatible = "aspeed,ast2400-i2c-bus"; + bus = <12>; + clock-frequency = <100000>; + status = "disabled"; + interrupts = <12>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c13_default>; + }; + + i2c13: i2c-bus@480 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x480 0x40>; + compatible = "aspeed,ast2400-i2c-bus"; + bus = <13>; + clock-frequency = <100000>; + status = "disabled"; + interrupts = <13>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c14_default>; + }; + + }; + + }; + }; +};
[resend from correct address]
Basically fixed FUC/FUN typo that went out of hand.
Signed-off-by: Maxim Sloyko maxims@google.com --- arch/arm/include/asm/arch-aspeed/regs-scu.h | 73 ++++++++++++++++------------- arch/arm/mach-aspeed/ast-scu.c | 2 +- 2 files changed, 42 insertions(+), 33 deletions(-)
diff --git a/arch/arm/include/asm/arch-aspeed/regs-scu.h b/arch/arm/include/asm/arch-aspeed/regs-scu.h index b714fa9..6cb4d0d 100644 --- a/arch/arm/include/asm/arch-aspeed/regs-scu.h +++ b/arch/arm/include/asm/arch-aspeed/regs-scu.h @@ -830,49 +830,53 @@ /* AST_SCU_FUN_PIN_CTRL5 0x90 - Multi-function Pin Control#5 */ #define SCU_FUN_PIN_SPICS1 (0x1 << 31) #define SCU_FUN_PIN_LPC_PLUS (0x1 << 30) -#define SCU_FUC_PIN_USB20_HOST (0x1 << 29) -#define SCU_FUC_PIN_USB11_PORT4 (0x1 << 28) -#define SCU_FUC_PIN_I2C14 (0x1 << 27) -#define SCU_FUC_PIN_I2C13 (0x1 << 26) -#define SCU_FUC_PIN_I2C12 (0x1 << 25) -#define SCU_FUC_PIN_I2C11 (0x1 << 24) -#define SCU_FUC_PIN_I2C10 (0x1 << 23) -#define SCU_FUC_PIN_I2C9 (0x1 << 22) -#define SCU_FUC_PIN_I2C8 (0x1 << 21) -#define SCU_FUC_PIN_I2C7 (0x1 << 20) -#define SCU_FUC_PIN_I2C6 (0x1 << 19) -#define SCU_FUC_PIN_I2C5 (0x1 << 18) -#define SCU_FUC_PIN_I2C4 (0x1 << 17) -#define SCU_FUC_PIN_I2C3 (0x1 << 16) -#define SCU_FUC_PIN_MII2_RX_DWN_DIS (0x1 << 15) -#define SCU_FUC_PIN_MII2_TX_DWN_DIS (0x1 << 14) -#define SCU_FUC_PIN_MII1_RX_DWN_DIS (0x1 << 13) -#define SCU_FUC_PIN_MII1_TX_DWN_DIS (0x1 << 12) - -#define SCU_FUC_PIN_MII2_TX_DRIV(x) (x << 10) -#define SCU_FUC_PIN_MII2_TX_DRIV_MASK (0x3 << 10) -#define SCU_FUC_PIN_MII1_TX_DRIV(x) (x << 8) -#define SCU_FUC_PIN_MII1_TX_DRIV_MASK (0x3 << 8) +#define SCU_FUN_PIN_USB20_HOST (0x1 << 29) +#define SCU_FUN_PIN_USB11_PORT4 (0x1 << 28) +#define SCU_FUN_PIN_I2C14 (0x1 << 27) +#define SCU_FUN_PIN_I2C13 (0x1 << 26) +#define SCU_FUN_PIN_I2C12 (0x1 << 25) +#define SCU_FUN_PIN_I2C11 (0x1 << 24) +#define SCU_FUN_PIN_I2C10 (0x1 << 23) +#define SCU_FUN_PIN_I2C9 (0x1 << 22) +#define SCU_FUN_PIN_I2C8 (0x1 << 21) +#define SCU_FUN_PIN_I2C7 (0x1 << 20) +#define SCU_FUN_PIN_I2C6 (0x1 << 19) +#define SCU_FUN_PIN_I2C5 (0x1 << 18) +#define SCU_FUN_PIN_I2C4 (0x1 << 17) +#define SCU_FUN_PIN_I2C3 (0x1 << 16) +#define SCU_FUN_PIN_I2C(n) (0x1 << (16 + (n) - 3)) +#define SCU_FUN_PIN_MII2_RX_DWN_DIS (0x1 << 15) +#define SCU_FUN_PIN_MII2_TX_DWN_DIS (0x1 << 14) +#define SCU_FUN_PIN_MII1_RX_DWN_DIS (0x1 << 13) +#define SCU_FUN_PIN_MII1_TX_DWN_DIS (0x1 << 12) + +#define SCU_I2C_MIN_BUS_NUM (1) +#define SCU_I2C_MAX_BUS_NUM (14) + +#define SCU_FUN_PIN_MII2_TX_DRIV(x) (x << 10) +#define SCU_FUN_PIN_MII2_TX_DRIV_MASK (0x3 << 10) +#define SCU_FUN_PIN_MII1_TX_DRIV(x) (x << 8) +#define SCU_FUN_PIN_MII1_TX_DRIV_MASK (0x3 << 8)
#define MII_NORMAL_DRIV 0x0 #define MII_HIGH_DRIV 0x2
-#define SCU_FUC_PIN_UART6 (0x1 << 7) -#define SCU_FUC_PIN_ROM_16BIT (0x1 << 6) -#define SCU_FUC_PIN_DIGI_V_OUT(x) (x) -#define SCU_FUC_PIN_DIGI_V_OUT_MASK (0x3) +#define SCU_FUN_PIN_UART6 (0x1 << 7) +#define SCU_FUN_PIN_ROM_16BIT (0x1 << 6) +#define SCU_FUN_PIN_DIGI_V_OUT(x) (x) +#define SCU_FUN_PIN_DIGI_V_OUT_MASK (0x3)
#define VIDEO_DISABLE 0x0 #define VIDEO_12BITS 0x1 #define VIDEO_24BITS 0x2 //#define VIDEO_DISABLE 0x3
-#define SCU_FUC_PIN_USB11_PORT2 (0x1 << 3) -#define SCU_FUC_PIN_SD1_8BIT (0x1 << 3) +#define SCU_FUN_PIN_USB11_PORT2 (0x1 << 3) +#define SCU_FUN_PIN_SD1_8BIT (0x1 << 3)
-#define SCU_FUC_PIN_MAC1_MDIO (0x1 << 2) -#define SCU_FUC_PIN_SD2 (0x1 << 1) -#define SCU_FUC_PIN_SD1 (0x1 << 0) +#define SCU_FUN_PIN_MAC1_MDIO (0x1 << 2) +#define SCU_FUN_PIN_SD2 (0x1 << 1) +#define SCU_FUN_PIN_SD1 (0x1 << 0)
/* AST_SCU_FUN_PIN_CTRL6 0x94 - Multi-function Pin Control#6*/ @@ -914,6 +918,11 @@ #define SCU_FUN_PIN_ROMA4 (0x1 << 18) #define SCU_FUN_PIN_ROMA3 (0x1 << 17) #define SCU_FUN_PIN_ROMA2 (0x1 << 16) +/* AST2500 only */ +#define SCU_FUN_PIN_SDA2 (0x1 << 15) +#define SCU_FUN_PIN_SCL2 (0x1 << 14) +#define SCU_FUN_PIN_SDA1 (0x1 << 13) +#define SCU_FUN_PIN_SCL1 (0x1 << 12)
/* AST_SCU_FUN_PIN_CTRL9 0xA8 - Multi-function Pin Control#9 */ #define SCU_FUN_PIN_ROMA21 (0x1 << 3) diff --git a/arch/arm/mach-aspeed/ast-scu.c b/arch/arm/mach-aspeed/ast-scu.c index 0cc0d67..280c421 100644 --- a/arch/arm/mach-aspeed/ast-scu.c +++ b/arch/arm/mach-aspeed/ast-scu.c @@ -394,7 +394,7 @@ void ast_scu_multi_func_eth(u8 num) AST_SCU_FUN_PIN_CTRL1);
ast_scu_write(ast_scu_read(AST_SCU_FUN_PIN_CTRL5) | - SCU_FUC_PIN_MAC1_MDIO, + SCU_FUN_PIN_MAC1_MDIO, AST_SCU_FUN_PIN_CTRL5);
break;
Hi Maxim,
This looks like a mix of whiltespace changes and other changes? If so, can you split it into two patches?
Hi Maxim,
This is needed by I2C driver.
Signed-off-by: Maxim Sloyko maxims@google.com --- arch/arm/include/asm/arch-aspeed/ast_scu.h | 1 + arch/arm/mach-aspeed/ast-scu.c | 11 +++++++++++ 2 files changed, 12 insertions(+)
diff --git a/arch/arm/include/asm/arch-aspeed/ast_scu.h b/arch/arm/include/asm/arch-aspeed/ast_scu.h index d248416..eb5aaa2 100644 --- a/arch/arm/include/asm/arch-aspeed/ast_scu.h +++ b/arch/arm/include/asm/arch-aspeed/ast_scu.h @@ -38,6 +38,7 @@ extern void ast_scu_get_who_init_dram(void); extern u32 ast_get_clk_source(void); extern u32 ast_get_h_pll_clk(void); extern u32 ast_get_ahbclk(void); +extern u32 ast_get_apbclk(void);
extern u32 ast_scu_get_vga_memsize(void);
diff --git a/arch/arm/mach-aspeed/ast-scu.c b/arch/arm/mach-aspeed/ast-scu.c index 280c421..e00dbe2 100644 --- a/arch/arm/mach-aspeed/ast-scu.c +++ b/arch/arm/mach-aspeed/ast-scu.c @@ -318,6 +318,17 @@ u32 ast_get_ahbclk(void)
#endif /* AST_SOC_G5 */
+u32 ast_get_apbclk(void) +{ + u32 h_pll = ast_get_h_pll_clk(); + /* The formula for converting the bit pattern to divisor is + * (4 + 4 * DIV), according to datasheet + */ + u32 apb_div = 4 + 4 * SCU_GET_PCLK_DIV(ast_scu_read(AST_SCU_CLK_SEL)); + return h_pll / apb_div; +} + + void ast_scu_show_system_info(void) {
Hi Maxim,
For the subject, 'Add' rather than 'Added' (we use present tense)
Please add a comment as to what this does and what it returns.
Can this be ulong, or is there a reason it has to be exactly 32 bits?
blank line here (between declarations and code)
/* * The formula... * ... */
Hi Maxim,
- The formula...
In the absence of pinmux driver, I2C driver will be configuring pins directly.
Signed-off-by: Maxim Sloyko maxims@google.com --- arch/arm/include/asm/arch-aspeed/ast_scu.h | 5 +++++ arch/arm/mach-aspeed/ast-scu.c | 28 ++++++++++++++++++++++++++++ 2 files changed, 33 insertions(+)
diff --git a/arch/arm/include/asm/arch-aspeed/ast_scu.h b/arch/arm/include/asm/arch-aspeed/ast_scu.h index eb5aaa2..80ebd6f 100644 --- a/arch/arm/include/asm/arch-aspeed/ast_scu.h +++ b/arch/arm/include/asm/arch-aspeed/ast_scu.h @@ -46,4 +46,9 @@ extern void ast_scu_init_eth(u8 num); extern void ast_scu_multi_func_eth(u8 num); extern void ast_scu_multi_func_romcs(u8 num);
+/* Enable I2C controller and pins for a particular device. + * Device numbering starts at 1 + */ +extern void ast_scu_enable_i2c(u8 num); + #endif diff --git a/arch/arm/mach-aspeed/ast-scu.c b/arch/arm/mach-aspeed/ast-scu.c index e00dbe2..b5aa8bf 100644 --- a/arch/arm/mach-aspeed/ast-scu.c +++ b/arch/arm/mach-aspeed/ast-scu.c @@ -507,3 +507,31 @@ void ast_scu_get_who_init_dram(void) break; } } + +void ast_scu_enable_i2c(u8 bus_num) +{ + if (bus_num > SCU_I2C_MAX_BUS_NUM) { + debug("%s: bus_num is out of range, must be [%d - %d]\n", + __func__, SCU_I2C_MIN_BUS_NUM, SCU_I2C_MAX_BUS_NUM); + return; + } + + if (bus_num == 0) { + /* Enable I2C Controllers */ + clrbits_le32(AST_SCU_BASE + AST_SCU_RESET, SCU_RESET_I2C); + } else if (bus_num >= 3) { + setbits_le32(AST_SCU_BASE + AST_SCU_FUN_PIN_CTRL5, + SCU_FUN_PIN_I2C(bus_num)); + /* In earlier versions of the SoC these pins are always assigned to + * respective I2C buses and require no configuration. + */ +#ifdef AST_SOC_G5 + } else if (bus_num == 1) { + setbits_le32(AST_SCU_BASE + AST_SCU_FUN_PIN_CTRL8, + SCU_FUN_PIN_SDA1 | SCU_FUN_PIN_SCL1); + } else if (bus_num == 2) { + setbits_le32(AST_SCU_BASE + AST_SCU_FUN_PIN_CTRL8, + SCU_FUN_PIN_SDA2 | SCU_FUN_PIN_SCL2); +#endif + } +}
Hi Maxim,
Commit subject s/Added/Add/
and please remove the '.' at the end.
- Device numbering starts at 1
I suspect this should be done as a pinctrl driver. See for drivers/pinctrl for examples.
return;
if (bus_num == 0) {
+#ifdef AST_SOC_G5
Hi Maxim,
return;
if (bus_num == 0) {
+#ifdef AST_SOC_G5
The driver is very limited: only single master mode is supported and only byte-by-byte synchronous reads and writes are supported, no Pool Buffers or DMA.
Signed-off-by: Maxim Sloyko maxims@google.com --- drivers/i2c/Kconfig | 7 ++ drivers/i2c/Makefile | 1 + drivers/i2c/ast_i2c.c | 305 ++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/i2c/ast_i2c.h | 143 +++++++++++++++++++++++ 4 files changed, 456 insertions(+) create mode 100644 drivers/i2c/ast_i2c.c create mode 100644 drivers/i2c/ast_i2c.h
diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index 6e22bba..720c475 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -90,6 +90,13 @@ config SYS_I2C_DW_ENABLE_STATUS_UNSUPPORTED enable status register. This config option can be enabled in such cases.
+config SYS_I2C_AST + bool "Aspeed I2C Controller" + depends on DM_I2C + help + Say yes here to select Aspeed I2C Host Controller. The driver + supports AST2500 and AST2400 controllers. + config SYS_I2C_INTEL bool "Intel I2C/SMBUS driver" depends on DM_I2C diff --git a/drivers/i2c/Makefile b/drivers/i2c/Makefile index 167424d..89e046e 100644 --- a/drivers/i2c/Makefile +++ b/drivers/i2c/Makefile @@ -16,6 +16,7 @@ obj-$(CONFIG_PCA9564_I2C) += pca9564_i2c.o obj-$(CONFIG_TSI108_I2C) += tsi108_i2c.o obj-$(CONFIG_SH_SH7734_I2C) += sh_sh7734_i2c.o obj-$(CONFIG_SYS_I2C) += i2c_core.o +obj-$(CONFIG_SYS_I2C_AST) += ast_i2c.o obj-$(CONFIG_SYS_I2C_CADENCE) += i2c-cdns.o obj-$(CONFIG_SYS_I2C_DAVINCI) += davinci_i2c.o obj-$(CONFIG_SYS_I2C_DW) += designware_i2c.o diff --git a/drivers/i2c/ast_i2c.c b/drivers/i2c/ast_i2c.c new file mode 100644 index 0000000..f2c132e --- /dev/null +++ b/drivers/i2c/ast_i2c.c @@ -0,0 +1,305 @@ +/* + * Copyright (C) 2012-2020 ASPEED Technology Inc. + * Copyright 2016 IBM Corporation + * Copyright 2016 Google, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <fdtdec.h> +#include <i2c.h> + +#include <asm/arch/ast_scu.h> +#include <asm/arch/regs-scu.h> +#include <asm/io.h> + +#include "ast_i2c.h" + +#define I2C_TIMEOUT_US (100000) +#define I2C_SLEEP_STEP (20) +#define EI2C_TIMEOUT (1001) + +DECLARE_GLOBAL_DATA_PTR; + +struct ast_i2c { + u32 id; + struct ast_i2c_regs *regs; + int speed; +}; + +static u32 get_clk_reg_val(u32 divider_ratio) +{ + unsigned int inc = 0, div; + u32 scl_low, scl_high, data; + + for (div = 0; divider_ratio >= 16; div++) { + inc |= (divider_ratio & 1); + divider_ratio >>= 1; + } + divider_ratio += inc; + scl_low = (divider_ratio >> 1) - 1; + scl_high = divider_ratio - scl_low - 2; + data = 0x77700300 | (scl_high << 16) | (scl_low << 12) | div; + return data; +} + +static inline void ast_i2c_clear_interrupts(struct ast_i2c_regs *i2c_base) +{ + writel(~0, &i2c_base->isr); +} + +static void ast_i2c_init_bus(struct ast_i2c *i2c_bus) +{ + /* Reset device */ + writel(0, &i2c_bus->regs->fcr); + /* Enable Master Mode. Assuming single-master. */ + debug("Enable Master for %p\n", i2c_bus->regs); + writel(AST_I2CD_MASTER_EN + | AST_I2CD_M_SDA_LOCK_EN + | AST_I2CD_MULTI_MASTER_DIS | AST_I2CD_M_SCL_DRIVE_EN, + &i2c_bus->regs->fcr); + debug("FCR: %p\n", &i2c_bus->regs->fcr); + /* Enable Interrupts */ + writel(AST_I2CD_INTR_TX_ACK + | AST_I2CD_INTR_TX_NAK + | AST_I2CD_INTR_RX_DONE + | AST_I2CD_INTR_BUS_RECOVER_DONE + | AST_I2CD_INTR_NORMAL_STOP + | AST_I2CD_INTR_ABNORMAL, &i2c_bus->regs->icr); +} + +static int ast_i2c_probe(struct udevice *dev) +{ + struct ast_i2c *i2c_bus = dev_get_priv(dev); + + debug("Enabling I2C%u\n", dev->seq); + ast_scu_enable_i2c(dev->seq); + + i2c_bus->id = dev->seq; + struct ast_i2c_regs *i2c_base = + (struct ast_i2c_regs *)dev_get_addr(dev); + i2c_bus->regs = i2c_base; + + ast_i2c_init_bus(i2c_bus); + return 0; +} + +static inline int ast_i2c_wait_isr(struct ast_i2c_regs *i2c_base, u32 flag) +{ + int timeout = I2C_TIMEOUT_US; + while (!(readl(&i2c_base->isr) & flag) && timeout > 0) { + udelay(I2C_SLEEP_STEP); + timeout -= I2C_SLEEP_STEP; + } + + ast_i2c_clear_interrupts(i2c_base); + if (timeout <= 0) + return -EI2C_TIMEOUT; + return 0; +} + +static inline int ast_i2c_send_stop(struct ast_i2c_regs *i2c_base) +{ + writel(AST_I2CD_M_STOP_CMD, &i2c_base->csr); + return ast_i2c_wait_isr(i2c_base, AST_I2CD_INTR_NORMAL_STOP); +} + +static inline int ast_i2c_wait_tx(struct ast_i2c_regs *i2c_base) +{ + int timeout = I2C_TIMEOUT_US; + u32 flag = AST_I2CD_INTR_TX_ACK | AST_I2CD_INTR_TX_NAK; + u32 status = readl(&i2c_base->isr) & flag; + while (!status && timeout > 0) { + status = readl(&i2c_base->isr) & flag; + udelay(I2C_SLEEP_STEP); + timeout -= I2C_SLEEP_STEP; + } + + int ret = 0; + if (status == AST_I2CD_INTR_TX_NAK) + ret = -EREMOTEIO; + + if (timeout <= 0) + ret = -EI2C_TIMEOUT; + + ast_i2c_clear_interrupts(i2c_base); + return ret; +} + +static inline int ast_i2c_start_txn(struct ast_i2c_regs *i2c_base, u8 devaddr) +{ + /* Start and Send Device Address */ + writel(devaddr, &i2c_base->trbbr); + writel(AST_I2CD_M_START_CMD | AST_I2CD_M_TX_CMD, &i2c_base->csr); + return ast_i2c_wait_tx(i2c_base); +} + +static int ast_i2c_read_data(struct ast_i2c *i2c_bus, u8 chip_addr, u8 *buffer, + size_t len, bool send_stop) +{ + struct ast_i2c_regs *i2c_base = i2c_bus->regs; + + int i2c_error = + ast_i2c_start_txn(i2c_base, (chip_addr << 1) | I2C_M_RD); + if (i2c_error < 0) + return i2c_error; + + u32 i2c_cmd = AST_I2CD_M_RX_CMD; + for (; len > 0; len--, buffer++) { + if (len == 1) + i2c_cmd |= AST_I2CD_M_S_RX_CMD_LAST; + writel(i2c_cmd, &i2c_base->csr); + i2c_error = ast_i2c_wait_isr(i2c_base, AST_I2CD_INTR_RX_DONE); + if (i2c_error < 0) + return i2c_error; + *buffer = AST_I2CD_RX_DATA_BUF_GET(readl(&i2c_base->trbbr)); + } + ast_i2c_clear_interrupts(i2c_base); + + if (send_stop) + return ast_i2c_send_stop(i2c_base); + + return 0; +} + +static int ast_i2c_write_data(struct ast_i2c *i2c_bus, u8 chip_addr, u8 + *buffer, size_t len, bool send_stop) +{ + struct ast_i2c_regs *i2c_base = i2c_bus->regs; + + int i2c_error = ast_i2c_start_txn(i2c_base, (chip_addr << 1)); + if (i2c_error < 0) + return i2c_error; + + for (; len > 0; len--, buffer++) { + writel(*buffer, &i2c_base->trbbr); + writel(AST_I2CD_M_TX_CMD, &i2c_base->csr); + i2c_error = ast_i2c_wait_tx(i2c_base); + if (i2c_error < 0) + return i2c_error; + } + + if (send_stop) + return ast_i2c_send_stop(i2c_base); + + return 0; +} + +static int ast_i2c_deblock(struct udevice *dev) +{ + struct ast_i2c *i2c_bus = dev_get_priv(dev); + struct ast_i2c_regs *i2c_base = i2c_bus->regs; + + u32 csr = readl(&i2c_base->csr); + + int deblock_error = 0; + bool sda_high = csr & AST_I2CD_SDA_LINE_STS; + bool scl_high = csr & AST_I2CD_SCL_LINE_STS; + if (sda_high && scl_high) { + /* Bus is idle, no deblocking needed. */ + return 0; + } else if (sda_high) { + /* Send stop command */ + debug("Unterminated TXN in (%x), sending stop\n", csr); + deblock_error = ast_i2c_send_stop(i2c_base); + } else if (scl_high) { + /* Possibly stuck slave */ + debug("Bus stuck (%x), attempting recovery\n", csr); + writel(AST_I2CD_BUS_RECOVER_CMD, &i2c_base->csr); + deblock_error = ast_i2c_wait_isr( + i2c_base, AST_I2CD_INTR_BUS_RECOVER_DONE); + } else { + /* Just try to reinit the device. */ + ast_i2c_init_bus(i2c_bus); + } + + return deblock_error; +} + +static int ast_i2c_xfer(struct udevice *dev, struct i2c_msg *msg, int nmsgs) +{ + struct ast_i2c *i2c_bus = dev_get_priv(dev); + int ret; + + (void)ast_i2c_deblock(dev); + debug("i2c_xfer: %d messages\n", nmsgs); + for (; nmsgs > 0; nmsgs--, msg++) { + if (msg->flags & I2C_M_RD) { + debug("i2c_read: chip=0x%x, len=0x%x, flags=0x%x\n", + msg->addr, msg->len, msg->flags); + ret = + ast_i2c_read_data(i2c_bus, msg->addr, msg->buf, + msg->len, (nmsgs == 1)); + } else { + debug("i2c_write: chip=0x%x, len=0x%x, flags=0x%x\n", + msg->addr, msg->len, msg->flags); + ret = + ast_i2c_write_data(i2c_bus, msg->addr, msg->buf, + msg->len, (nmsgs == 1)); + } + if (ret) { + debug("%s: error (%d)\n", __func__, ret); + return -EREMOTEIO; + } + } + + return 0; +} + +static int ast_i2c_set_speed(struct udevice *dev, unsigned int speed) +{ + debug("Setting speed ofr I2C%d to <%u>\n", dev->seq, speed); + if (!speed) { + debug("No valid speed specified.\n"); + return -EINVAL; + } + struct ast_i2c *i2c_bus = dev_get_priv(dev); + + i2c_bus->speed = speed; + /* TODO: get this from device tree */ + u32 pclk = ast_get_apbclk(); + u32 divider = pclk / speed; + + struct ast_i2c_regs *i2c_base = i2c_bus->regs; + if (speed > 400000) { + debug("Enabling High Speed\n"); + setbits_le32(&i2c_base->fcr, AST_I2CD_M_HIGH_SPEED_EN + | AST_I2CD_M_SDA_DRIVE_1T_EN + | AST_I2CD_SDA_DRIVE_1T_EN); + writel(0x3, &i2c_base->cactcr2); + writel(get_clk_reg_val(divider), &i2c_base->cactcr1); + } else { + debug("Enabling Normal Speed\n"); + writel(get_clk_reg_val(divider), &i2c_base->cactcr1); + writel(AST_NO_TIMEOUT_CTRL, &i2c_base->cactcr2); + } + + ast_i2c_clear_interrupts(i2c_base); + return 0; +} + +static const struct dm_i2c_ops ast_i2c_ops = { + .xfer = ast_i2c_xfer, + .set_bus_speed = ast_i2c_set_speed, + .deblock = ast_i2c_deblock, +}; + +static const struct udevice_id ast_i2c_ids[] = { + {.compatible = "aspeed,ast2400-i2c-controller",}, + {.compatible = "aspeed,ast2400-i2c-bus",}, + {}, +}; + +/* Tell GNU Indent to keep this as is: */ +/* *INDENT-OFF* */ +U_BOOT_DRIVER(i2c_aspeed) = { + .name = "i2c_aspeed", + .id = UCLASS_I2C, + .of_match = ast_i2c_ids, + .probe = ast_i2c_probe, + .priv_auto_alloc_size = sizeof(struct ast_i2c), + .ops = &ast_i2c_ops, +}; +/* *INDENT-ON* */ diff --git a/drivers/i2c/ast_i2c.h b/drivers/i2c/ast_i2c.h new file mode 100644 index 0000000..8926fd2 --- /dev/null +++ b/drivers/i2c/ast_i2c.h @@ -0,0 +1,143 @@ +/* + * Copyright (C) 2012-2020 ASPEED Technology Inc. + * Copyright 2016 IBM Corporation + * Copyright 2016 Google, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef __AST_I2C_H_ +#define __AST_I2C_H_ + +struct ast_i2c_regs { + uint32_t fcr; + uint32_t cactcr1; + uint32_t cactcr2; + uint32_t icr; + uint32_t isr; + uint32_t csr; + uint32_t sdar; + uint32_t pbcr; + uint32_t trbbr; +#ifdef CONFIG_TARGET_AST_G5 + uint32_t dma_mbar; + uint32_t dma_tlr; +#endif +}; + +/* Device Register Definition */ +/* 0x00 : I2CD Function Control Register */ +#define AST_I2CD_BUFF_SEL_MASK (0x7 << 20) +#define AST_I2CD_BUFF_SEL(x) (x << 20) +#define AST_I2CD_M_SDA_LOCK_EN (0x1 << 16) +#define AST_I2CD_MULTI_MASTER_DIS (0x1 << 15) +#define AST_I2CD_M_SCL_DRIVE_EN (0x1 << 14) +#define AST_I2CD_MSB_STS (0x1 << 9) +#define AST_I2CD_SDA_DRIVE_1T_EN (0x1 << 8) +#define AST_I2CD_M_SDA_DRIVE_1T_EN (0x1 << 7) +#define AST_I2CD_M_HIGH_SPEED_EN (0x1 << 6) +#define AST_I2CD_DEF_ADDR_EN (0x1 << 5) +#define AST_I2CD_DEF_ALERT_EN (0x1 << 4) +#define AST_I2CD_DEF_ARP_EN (0x1 << 3) +#define AST_I2CD_DEF_GCALL_EN (0x1 << 2) +#define AST_I2CD_SLAVE_EN (0x1 << 1) +#define AST_I2CD_MASTER_EN (0x1) + +/* 0x04 : I2CD Clock and AC Timing Control Register #1 */ +#define AST_I2CD_tBUF (0x1 << 28) +#define AST_I2CD_tHDSTA (0x1 << 24) +#define AST_I2CD_tACST (0x1 << 20) +#define AST_I2CD_tCKHIGH (0x1 << 16) +#define AST_I2CD_tCKLOW (0x1 << 12) +#define AST_I2CD_tHDDAT (0x1 << 10) +#define AST_I2CD_CLK_TO_BASE_DIV (0x1 << 8) +#define AST_I2CD_CLK_BASE_DIV (0x1) + +/* 0x08 : I2CD Clock and AC Timing Control Register #2 */ +#define AST_I2CD_tTIMEOUT (0x1) +#define AST_NO_TIMEOUT_CTRL 0x0 + +/* 0x0c : I2CD Interrupt Control Register & + * 0x10 : I2CD Interrupt Status Register + * + * These share bit definitions, so use the same values for the enable & + * status bits. + */ +#define AST_I2CD_INTR_SDA_DL_TIMEOUT (0x1 << 14) +#define AST_I2CD_INTR_BUS_RECOVER_DONE (0x1 << 13) +#define AST_I2CD_INTR_SMBUS_ALERT (0x1 << 12) +#define AST_I2CD_INTR_SMBUS_ARP_ADDR (0x1 << 11) +#define AST_I2CD_INTR_SMBUS_DEV_ALERT_ADDR (0x1 << 10) +#define AST_I2CD_INTR_SMBUS_DEF_ADDR (0x1 << 9) +#define AST_I2CD_INTR_GCALL_ADDR (0x1 << 8) +#define AST_I2CD_INTR_SLAVE_MATCH (0x1 << 7) +#define AST_I2CD_INTR_SCL_TIMEOUT (0x1 << 6) +#define AST_I2CD_INTR_ABNORMAL (0x1 << 5) +#define AST_I2CD_INTR_NORMAL_STOP (0x1 << 4) +#define AST_I2CD_INTR_ARBIT_LOSS (0x1 << 3) +#define AST_I2CD_INTR_RX_DONE (0x1 << 2) +#define AST_I2CD_INTR_TX_NAK (0x1 << 1) +#define AST_I2CD_INTR_TX_ACK (0x1 << 0) + +/* 0x14 : I2CD Command/Status Register */ +#define AST_I2CD_SDA_OE (0x1 << 28) +#define AST_I2CD_SDA_O (0x1 << 27) +#define AST_I2CD_SCL_OE (0x1 << 26) +#define AST_I2CD_SCL_O (0x1 << 25) +#define AST_I2CD_TX_TIMING (0x1 << 24) +#define AST_I2CD_TX_STATUS (0x1 << 23) + +/* Tx State Machine */ +#define AST_I2CD_IDLE 0x0 +#define AST_I2CD_MACTIVE 0x8 +#define AST_I2CD_MSTART 0x9 +#define AST_I2CD_MSTARTR 0xa +#define AST_I2CD_MSTOP 0xb +#define AST_I2CD_MTXD 0xc +#define AST_I2CD_MRXACK 0xd +#define AST_I2CD_MRXD 0xe +#define AST_I2CD_MTXACK 0xf +#define AST_I2CD_SWAIT 0x1 +#define AST_I2CD_SRXD 0x4 +#define AST_I2CD_STXACK 0x5 +#define AST_I2CD_STXD 0x6 +#define AST_I2CD_SRXACK 0x7 +#define AST_I2CD_RECOVER 0x3 + +#define AST_I2CD_SCL_LINE_STS (0x1 << 18) +#define AST_I2CD_SDA_LINE_STS (0x1 << 17) +#define AST_I2CD_BUS_BUSY_STS (0x1 << 16) +#define AST_I2CD_SDA_OE_OUT_DIR (0x1 << 15) +#define AST_I2CD_SDA_O_OUT_DIR (0x1 << 14) +#define AST_I2CD_SCL_OE_OUT_DIR (0x1 << 13) +#define AST_I2CD_SCL_O_OUT_DIR (0x1 << 12) +#define AST_I2CD_BUS_RECOVER_CMD (0x1 << 11) +#define AST_I2CD_S_ALT_EN (0x1 << 10) +#define AST_I2CD_RX_DMA_ENABLE (0x1 << 9) +#define AST_I2CD_TX_DMA_ENABLE (0x1 << 8) + +/* Command Bit */ +#define AST_I2CD_RX_BUFF_ENABLE (0x1 << 7) +#define AST_I2CD_TX_BUFF_ENABLE (0x1 << 6) +#define AST_I2CD_M_STOP_CMD (0x1 << 5) +#define AST_I2CD_M_S_RX_CMD_LAST (0x1 << 4) +#define AST_I2CD_M_RX_CMD (0x1 << 3) +#define AST_I2CD_S_TX_CMD (0x1 << 2) +#define AST_I2CD_M_TX_CMD (0x1 << 1) +#define AST_I2CD_M_START_CMD (0x1) + +/* 0x18 : I2CD Slave Device Address Register */ + +/* 0x1C : I2CD Pool Buffer Control Register */ +#define AST_I2CD_RX_BUF_ADDR_GET(x) (((x) >> 24) & 0xff) +#define AST_I2CD_RX_BUF_END_ADDR_SET(x) ((x) << 16) +#define AST_I2CD_TX_DATA_BUF_END_SET(x) (((x) & 0xff) << 8) +#define AST_I2CD_RX_DATA_BUF_GET(x) (((x) >> 8) & 0xff) +#define AST_I2CD_BUF_BASE_ADDR_SET(x) ((x) & 0x3f) + +/* 0x20 : I2CD Transmit/Receive Byte Buffer Register */ +#define AST_I2CD_GET_MODE(x) (((x) >> 8) & 0x1) + +#define AST_I2CD_RX_BYTE_BUFFER (0xff << 8) +#define AST_I2CD_TX_BYTE_BUFFER (0xff) + +#endif /* __AST_I2C_H_ */
Hi Maxim,
Please add that into the Kconfig help too.
+config SYS_I2C_AST
depends on DM_I2C
help
- Copyright (C) 2012-2020 ASPEED Technology Inc.
- Copyright 2016 IBM Corporation
- Copyright 2016 Google, Inc.
I2C_SLEEP_STEP_US
EI2C_TIMEOUT_US
Please drop the () on those
+struct ast_i2c {
Please add a struct comment with member info.
u32 id;
int speed;
Function comment. Consider returning ulong.
blank link here. What is the magic 0x77700300 for? Should either have a comment or a #define
return data;
/* Reset device */
nit: Please avoid '.' at end of comments
Can you use dev_get_addr_ptr()? Need to check for NULL and return -EINVAL. Also, reading the device tree should really be in the ofdata_to_platdata() method, not probe().
blank line here
if (timeout <= 0)
return -ETIMEDOUT
blank line (please do this before each return)
blank line (please do this after all decl blocks)
int ret = 0;
Move this to top of function. Declarations should all be at the start of the block.
ret = -EREMOTEIO;
if (timeout <= 0)
return ret;
Why inline? The compiler will do that anyway so I think you can drop it. Also please use int or uint for devaddr - particularly on ARM it isn't good to have non-register-sized parameters and return values.
int i2c_error =
if (i2c_error < 0)
return i2c_error;
if (len == 1)
if (i2c_error < 0)
return i2c_error;
Instead of AST_I2CD_RX_DATA_BUF_GET(), please define something like AST_I2CD_RX_DATA_SHIFT and _MASK and use then here.
#define AST_I2CD_RX_DATA_SHIFT 8 #define AST_I2CD_RX_DATA_MASK (0xff << AST_I2CD_RX_DATA_SHIFT)
if (send_stop)
if (i2c_error < 0)
return i2c_error;
if (i2c_error < 0)
return i2c_error;
if (send_stop)
Just 'ret' is good enough.
} else {
int ret;
ret =
Can you break the line in the parameters instead of at '=' ?
} else {
ret =
if (ret) {
return -EREMOTEIO;
if (!speed) {
Drop '.'
return -EINVAL;
} else {
.id = UCLASS_I2C,
uint32_t fcr;
uint32_t cactcr1;
uint32_t cactcr2;
uint32_t icr;
uint32_t isr;
uint32_t csr;
uint32_t sdar;
uint32_t pbcr;
uint32_t trbbr;
uint32_t dma_mbar;
uint32_t dma_tlr;
+#endif +};
It's fine to have the AST_I2CD_ prefix if you want it. But it does make things longer, and this header will only be included in one file. So feel free to prune to AST_ if you like.
Avoid brackets around simple constants
- 0x10 : I2CD Interrupt Status Register
- These share bit definitions, so use the same values for the enable &
- status bits.
Just use simple shift and mask values, and put the logic in your C code.
Hi Maxim,
+config SYS_I2C_AST
depends on DM_I2C
help
I2C_SLEEP_STEP_US
EI2C_TIMEOUT_US
+struct ast_i2c {
u32 id;
int speed;
return data;
/* Reset device */
blank line here
if (timeout <= 0)
return -ETIMEDOUT
int ret = 0;
ret = -EREMOTEIO;
if (timeout <= 0)
return ret;
int i2c_error =
if (i2c_error < 0)
return i2c_error;
if (len == 1)
if (i2c_error < 0)
return i2c_error;
if (send_stop)
if (i2c_error < 0)
return i2c_error;
if (i2c_error < 0)
return i2c_error;
if (send_stop)
} else {
int ret;
ret =
} else {
ret =
if (ret) {
return -EREMOTEIO;
if (!speed) {
Drop '.'
return -EINVAL;
} else {
.id = UCLASS_I2C,
uint32_t fcr;
uint32_t cactcr1;
uint32_t cactcr2;
uint32_t icr;
uint32_t isr;
uint32_t csr;
uint32_t sdar;
uint32_t pbcr;
uint32_t trbbr;
uint32_t dma_mbar;
uint32_t dma_tlr;
+#endif +};
- status bits.
Hello Maxim,
Am 23.11.2016 um 00:56 schrieb maxims@google.com:
If this series is not for U-Boot mainline, why do you post this patches on the U-Boot Mailinglist?
bye, Heiko
Sorry, this was by mistake, please ignore.
On Wed, Nov 23, 2016 at 4:28 AM, Heiko Schocher hs@denx.de wrote:
Hello Maxim,
bye, Heiko
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany
Hello Maxim,
Am 23.11.2016 um 17:40 schrieb Maxim Sloyko:
no problem at all!
bye, Heiko
On Wed, Nov 23, 2016 at 4:28 AM, Heiko Schocher <hs@denx.de mailto:hs@denx.de> wrote:
Hello Maxim, Am 23.11.2016 um 00:56 schrieb maxims@google.com <mailto:maxims@google.com>: From: Maxim Sloyko <maxims@google.com <mailto:maxims@google.com>> This series of patches is only meant for openbmc/u-boot tree. If this series is not for U-Boot mainline, why do you post this patches on the U-Boot Mailinglist? bye, Heiko It adds basic support for aspeed i2c. Only single master mode is supported with synchronous transfer. The style is inconsistent with U-Boot style guide in few places, but follows local style in those files. Maxim Sloyko (5): aspeed/g5: Device Tree for ast2500, copied from openbmc/linux (include file), plus minimal device tree configuration for ast2500 eval board. aspeed: Fixed incosistency in some SCU registers naming. aspeed: Added function to calculate APB Clock frequency. aspeed: Added function to configure pins for I2C devices. aspeed: I2C driver. arch/arm/dts/Makefile | 2 + arch/arm/dts/aspeed-g5-evb.dts | 28 + arch/arm/dts/aspeed-g5.dtsi | 1278 +++++++++++++++++++++++++++ arch/arm/include/asm/arch-aspeed/ast_scu.h | 6 + arch/arm/include/asm/arch-aspeed/regs-scu.h | 73 +- arch/arm/mach-aspeed/ast-scu.c | 41 +- drivers/i2c/Kconfig | 7 + drivers/i2c/Makefile | 1 + drivers/i2c/ast_i2c.c | 305 +++++++ drivers/i2c/ast_i2c.h | 143 +++ 10 files changed, 1851 insertions(+), 33 deletions(-) create mode 100644 arch/arm/dts/aspeed-g5-evb.dts create mode 100644 arch/arm/dts/aspeed-g5.dtsi create mode 100644 drivers/i2c/ast_i2c.c create mode 100644 drivers/i2c/ast_i2c.h -- 2.8.0.rc3.226.g39d4020 _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de <mailto:U-Boot@lists.denx.de> http://lists.denx.de/mailman/listinfo/u-boot <http://lists.denx.de/mailman/listinfo/u-boot> -- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany
-- *M*axim *S*loyko
participants (5)
Heiko Schocher
Maxim Sloyko
maxims@google.com
