[U-Boot] [PATCH 0/1] imx: support for conga-QMX8 board
Hello list,
this patch adds support for the congatec QMX8 Qseven board.
Oliver
Oliver Graute (1): imx: support for conga-QMX8 board
arch/arm/dts/Makefile | 1 + arch/arm/dts/imx8qm-cgtqmx8.dts | 427 +++++++++++++++++++++++++ arch/arm/mach-imx/Makefile | 2 - arch/arm/mach-imx/imx8/Kconfig | 7 + board/congatec/cgtqmx8/Kconfig | 14 + board/congatec/cgtqmx8/MAINTAINERS | 6 + board/congatec/cgtqmx8/Makefile | 11 + board/congatec/cgtqmx8/README | 15 + board/congatec/cgtqmx8/cgtqmx8.c | 478 ++++++++++++++++++++++++++++ board/congatec/cgtqmx8/imximage.cfg | 21 ++ board/congatec/cgtqmx8/spl.c | 75 +++++ board/congatec/common/Kconfig | 48 +++ board/congatec/common/Makefile | 23 ++ board/congatec/common/mmc.c | 50 +++ configs/cgtqmx8_defconfig | 79 +++++ include/configs/cgtqmx8.h | 167 ++++++++++ 16 files changed, 1422 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/imx8qm-cgtqmx8.dts create mode 100644 board/congatec/cgtqmx8/Kconfig create mode 100644 board/congatec/cgtqmx8/MAINTAINERS create mode 100644 board/congatec/cgtqmx8/Makefile create mode 100644 board/congatec/cgtqmx8/README create mode 100644 board/congatec/cgtqmx8/cgtqmx8.c create mode 100644 board/congatec/cgtqmx8/imximage.cfg create mode 100644 board/congatec/cgtqmx8/spl.c create mode 100644 board/congatec/common/Kconfig create mode 100644 board/congatec/common/Makefile create mode 100644 board/congatec/common/mmc.c create mode 100644 configs/cgtqmx8_defconfig create mode 100644 include/configs/cgtqmx8.h
Add i.MX8QM qmx8 congatec board support
Boot log as below: U-Boot 2019.10-00002-gfe063598db (Oct 10 2019 - 10:29:07 +0200)
CPU: NXP i.MX8QM RevB A53 at 1200 MHz
Model: congatec QMX8 Board: conga-QMX8 Build: SCFW 65afe5f6 Boot: SD2 DRAM: 6 GiB MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2 Loading Environment from MMC... *** Warning - bad CRC, using default environment
In: serial@5a060000 Out: serial@5a060000 Err: serial@5a060000 switch to partitions #0, OK mmc2 is current device Net: Error: ethernet@5b040000 address not set. eth-1: ethernet@5b040000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc2 is current device
Signed-off-by: Oliver Graute oliver.graute@kococonnector.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: Peng Fan peng.fan@nxp.com Cc: Simon Glass sjg@chromium.org Cc: Ye Li ye.li@nxp.com Cc: uboot-imx uboot-imx@nxp.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/imx8qm-cgtqmx8.dts | 427 +++++++++++++++++++++++++ arch/arm/mach-imx/Makefile | 2 - arch/arm/mach-imx/imx8/Kconfig | 7 + board/congatec/cgtqmx8/Kconfig | 14 + board/congatec/cgtqmx8/MAINTAINERS | 6 + board/congatec/cgtqmx8/Makefile | 11 + board/congatec/cgtqmx8/README | 15 + board/congatec/cgtqmx8/cgtqmx8.c | 478 ++++++++++++++++++++++++++++ board/congatec/cgtqmx8/imximage.cfg | 21 ++ board/congatec/cgtqmx8/spl.c | 75 +++++ board/congatec/common/Kconfig | 48 +++ board/congatec/common/Makefile | 23 ++ board/congatec/common/mmc.c | 50 +++ configs/cgtqmx8_defconfig | 79 +++++ include/configs/cgtqmx8.h | 167 ++++++++++ 16 files changed, 1422 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/imx8qm-cgtqmx8.dts create mode 100644 board/congatec/cgtqmx8/Kconfig create mode 100644 board/congatec/cgtqmx8/MAINTAINERS create mode 100644 board/congatec/cgtqmx8/Makefile create mode 100644 board/congatec/cgtqmx8/README create mode 100644 board/congatec/cgtqmx8/cgtqmx8.c create mode 100644 board/congatec/cgtqmx8/imximage.cfg create mode 100644 board/congatec/cgtqmx8/spl.c create mode 100644 board/congatec/common/Kconfig create mode 100644 board/congatec/common/Makefile create mode 100644 board/congatec/common/mmc.c create mode 100644 configs/cgtqmx8_defconfig create mode 100644 include/configs/cgtqmx8.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 2c86b293a8..9541ee614f 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -638,6 +638,7 @@ dtb-$(CONFIG_ARCH_MX7ULP) += imx7ulp-evk.dtb dtb-$(CONFIG_ARCH_IMX8) += \ fsl-imx8qm-apalis.dtb \ fsl-imx8qm-mek.dtb \ + imx8qm-cgtqmx8.dtb \ fsl-imx8qxp-colibri.dtb \ fsl-imx8qxp-mek.dtb
diff --git a/arch/arm/dts/imx8qm-cgtqmx8.dts b/arch/arm/dts/imx8qm-cgtqmx8.dts new file mode 100644 index 0000000000..79a99ddb10 --- /dev/null +++ b/arch/arm/dts/imx8qm-cgtqmx8.dts @@ -0,0 +1,427 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Freescale Semiconductor, Inc. + * Copyright 2017 NXP + * Copyright 2017 congatec AG + * Copyright (C) 2019 Oliver Graute oliver.graute@kococonnector.com + */ + +/dts-v1/; + +/* First 128KB is for PSCI ATF. */ +/memreserve/ 0x80000000 0x00020000; + +#include "fsl-imx8qm.dtsi" + +/ { + model = "Congatec QMX8 Qseven series"; + compatible = "fsl,imx8qm-qmx8", "fsl,imx8qm"; + + chosen { + bootargs = "console=ttyLP0,115200 earlycon=lpuart32,0x5a060000,115200"; + stdout-path = &lpuart0; + }; + + regulators { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + reg_usdhc2_vmmc: usdhc2_vmmc { + compatible = "regulator-fixed"; + regulator-name = "sw-3p3-sd1"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio4 7 GPIO_ACTIVE_HIGH>; + enable-active-high; + off-on-delay-us = <3000>; + }; + + reg_usdhc3_vmmc: usdhc3_vmmc { + compatible = "regulator-fixed"; + regulator-name = "sw-3p3-sd2"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio4 9 GPIO_ACTIVE_HIGH>; + enable-active-high; + off-on-delay-us = <3000>; + }; + }; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec1>; + phy-mode = "rgmii"; + phy-handle = <ðphy0>; + fsl,magic-packet; + fsl,rgmii_txc_dly; + fsl,rgmii_rxc_dly; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <6>; + at803x,eee-disabled; + at803x,vddio-1p8v; + }; + }; +}; + +&gpio2 { + status = "okay"; +}; + +&gpio5 { + status = "okay"; +}; + +&i2c0 { + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lpi2c0>; + clock-frequency = <100000>; + status = "okay"; + + rtc_ext: m41t62@68 { + compatible = "st,m41t62"; + reg = <0x68>; + }; +}; + +&i2c1 { + #address-cells = <1>; + #size-cells = <0>; + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lpi2c1>; + status = "okay"; + + wm8904: wm8904@1a { + compatible = "wlf,wm8904"; + reg = <0x1a>; + + clocks = <&clk IMX8QM_AUD_MCLKOUT0>; + clock-names = "mclk"; + wlf,shared-lrclk; + /* power-domains = <&pd_mclk_out0>; */ + + assigned-clocks = <&clk IMX8QM_AUD_PLL0_DIV>, + <&clk IMX8QM_AUD_ACM_AUD_PLL_CLK0_DIV>, + <&clk IMX8QM_AUD_ACM_AUD_REC_CLK0_DIV>, + <&clk IMX8QM_AUD_MCLKOUT0>; + + assigned-clock-rates = <786432000>, <49152000>, <24576000>; + }; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog>; + + imx8qm-qmx8 { + + pinctrl_hog: hoggrp{ + fsl,pins = < + SC_P_M40_GPIO0_01_LSIO_GPIO0_IO09 0x00000021 + SC_P_USB_SS3_TC1_LSIO_GPIO4_IO04 0x00000021 + SC_P_M40_GPIO0_00_LSIO_GPIO0_IO08 0x00000021 + SC_P_ESAI1_SCKT_LSIO_GPIO2_IO07 0x00000021 + SC_P_SPDIF0_TX_LSIO_GPIO2_IO15 0x00000021 + SC_P_FLEXCAN1_RX_LSIO_GPIO3_IO31 0x00000021 + SC_P_ESAI1_TX0_LSIO_GPIO2_IO08 0x00000021 + SC_P_FLEXCAN1_TX_LSIO_GPIO4_IO00 0x00000021 + SC_P_ESAI1_TX1_LSIO_GPIO2_IO09 0x00000021 + >; + }; + + pinctrl_fec1: fec1grp { + fsl,pins = < + SC_P_ENET0_MDC_CONN_ENET0_MDC 0x06000020 + SC_P_ENET0_MDIO_CONN_ENET0_MDIO 0x06000020 + SC_P_ENET0_RGMII_TX_CTL_CONN_ENET0_RGMII_TX_CTL 0x06000020 + SC_P_ENET0_RGMII_TXC_CONN_ENET0_RGMII_TXC 0x06000020 + SC_P_ENET0_RGMII_TXD0_CONN_ENET0_RGMII_TXD0 0x06000020 + SC_P_ENET0_RGMII_TXD1_CONN_ENET0_RGMII_TXD1 0x06000020 + SC_P_ENET0_RGMII_TXD2_CONN_ENET0_RGMII_TXD2 0x06000020 + SC_P_ENET0_RGMII_TXD3_CONN_ENET0_RGMII_TXD3 0x06000020 + SC_P_ENET0_RGMII_RXC_CONN_ENET0_RGMII_RXC 0x06000020 + SC_P_ENET0_RGMII_RX_CTL_CONN_ENET0_RGMII_RX_CTL 0x06000020 + SC_P_ENET0_RGMII_RXD0_CONN_ENET0_RGMII_RXD0 0x06000020 + SC_P_ENET0_RGMII_RXD1_CONN_ENET0_RGMII_RXD1 0x06000020 + SC_P_ENET0_RGMII_RXD2_CONN_ENET0_RGMII_RXD2 0x06000020 + SC_P_ENET0_RGMII_RXD3_CONN_ENET0_RGMII_RXD3 0x06000020 + >; + }; + + pinctrl_lpi2c0: lpi2c0grp { + fsl,pins = < + SC_P_HDMI_TX0_TS_SCL_DMA_I2C0_SCL 0xc600004c + SC_P_HDMI_TX0_TS_SDA_DMA_I2C0_SDA 0xc600004c + >; + }; + + pinctrl_lpi2c1: lpi2c1grp { + fsl,pins = < + SC_P_GPT0_CLK_DMA_I2C1_SCL 0xc600004c + SC_P_GPT0_CAPTURE_DMA_I2C1_SDA 0xc600004c + >; + }; + + pinctrl_lpuart0: lpuart0grp { + fsl,pins = < + SC_P_UART0_RX_DMA_UART0_RX 0x06000020 + SC_P_UART0_TX_DMA_UART0_TX 0x06000020 + >; + }; + + pinctrl_lpuart1: lpuart1grp { + fsl,pins = < + SC_P_UART1_RX_DMA_UART1_RX 0x06000020 + SC_P_UART1_TX_DMA_UART1_TX 0x06000020 + SC_P_UART1_CTS_B_DMA_UART1_CTS_B 0x06000020 + SC_P_UART1_RTS_B_DMA_UART1_RTS_B 0x06000020 + >; + }; + + pinctrl_lpuart3: lpuart3grp { + fsl,pins = < + SC_P_M41_GPIO0_00_DMA_UART3_RX 0x06000020 + SC_P_M41_GPIO0_01_DMA_UART3_TX 0x06000020 + >; + }; + + pinctrl_mlb: mlbgrp { + fsl,pins = < + SC_P_MLB_SIG_CONN_MLB_SIG 0x21 + SC_P_MLB_CLK_CONN_MLB_CLK 0x21 + SC_P_MLB_DATA_CONN_MLB_DATA 0x21 + >; + }; + + pinctrl_isl29023: isl29023grp { + fsl,pins = < + SC_P_ADC_IN2_LSIO_GPIO3_IO20 0x00000021 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + SC_P_EMMC0_CLK_CONN_EMMC0_CLK 0x06000041 + SC_P_EMMC0_CMD_CONN_EMMC0_CMD 0x00000021 + SC_P_EMMC0_DATA0_CONN_EMMC0_DATA0 0x00000021 + SC_P_EMMC0_DATA1_CONN_EMMC0_DATA1 0x00000021 + SC_P_EMMC0_DATA2_CONN_EMMC0_DATA2 0x00000021 + SC_P_EMMC0_DATA3_CONN_EMMC0_DATA3 0x00000021 + SC_P_EMMC0_DATA4_CONN_EMMC0_DATA4 0x00000021 + SC_P_EMMC0_DATA5_CONN_EMMC0_DATA5 0x00000021 + SC_P_EMMC0_DATA6_CONN_EMMC0_DATA6 0x00000021 + SC_P_EMMC0_DATA7_CONN_EMMC0_DATA7 0x00000021 + SC_P_EMMC0_STROBE_CONN_EMMC0_STROBE 0x00000041 + SC_P_EMMC0_RESET_B_CONN_EMMC0_RESET_B 0x00000021 + >; + }; + + pinctrl_usdhc1_100mhz: usdhc1grp100mhz { + fsl,pins = < + SC_P_EMMC0_CLK_CONN_EMMC0_CLK 0x06000040 + SC_P_EMMC0_CMD_CONN_EMMC0_CMD 0x00000020 + SC_P_EMMC0_DATA0_CONN_EMMC0_DATA0 0x00000020 + SC_P_EMMC0_DATA1_CONN_EMMC0_DATA1 0x00000020 + SC_P_EMMC0_DATA2_CONN_EMMC0_DATA2 0x00000020 + SC_P_EMMC0_DATA3_CONN_EMMC0_DATA3 0x00000020 + SC_P_EMMC0_DATA4_CONN_EMMC0_DATA4 0x00000020 + SC_P_EMMC0_DATA5_CONN_EMMC0_DATA5 0x00000020 + SC_P_EMMC0_DATA6_CONN_EMMC0_DATA6 0x00000020 + SC_P_EMMC0_DATA7_CONN_EMMC0_DATA7 0x00000020 + SC_P_EMMC0_STROBE_CONN_EMMC0_STROBE 0x00000040 + SC_P_EMMC0_RESET_B_CONN_EMMC0_RESET_B 0x00000020 + >; + }; + + pinctrl_usdhc1_200mhz: usdhc1grp200mhz { + fsl,pins = < + SC_P_EMMC0_CLK_CONN_EMMC0_CLK 0x06000040 + SC_P_EMMC0_CMD_CONN_EMMC0_CMD 0x00000020 + SC_P_EMMC0_DATA0_CONN_EMMC0_DATA0 0x00000020 + SC_P_EMMC0_DATA1_CONN_EMMC0_DATA1 0x00000020 + SC_P_EMMC0_DATA2_CONN_EMMC0_DATA2 0x00000020 + SC_P_EMMC0_DATA3_CONN_EMMC0_DATA3 0x00000020 + SC_P_EMMC0_DATA4_CONN_EMMC0_DATA4 0x00000020 + SC_P_EMMC0_DATA5_CONN_EMMC0_DATA5 0x00000020 + SC_P_EMMC0_DATA6_CONN_EMMC0_DATA6 0x00000020 + SC_P_EMMC0_DATA7_CONN_EMMC0_DATA7 0x00000020 + SC_P_EMMC0_STROBE_CONN_EMMC0_STROBE 0x00000040 + SC_P_EMMC0_RESET_B_CONN_EMMC0_RESET_B 0x00000020 + >; + }; + + pinctrl_usdhc2_gpio: usdhc2grpgpio { + fsl,pins = < + SC_P_USDHC1_DATA6_LSIO_GPIO5_IO21 0x00000021 + SC_P_USDHC1_DATA7_LSIO_GPIO5_IO22 0x00000021 + SC_P_USDHC1_RESET_B_LSIO_GPIO4_IO07 0x00000021 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + SC_P_USDHC1_CLK_CONN_USDHC1_CLK 0x06000041 + SC_P_USDHC1_CMD_CONN_USDHC1_CMD 0x00000021 + SC_P_USDHC1_DATA0_CONN_USDHC1_DATA0 0x00000021 + SC_P_USDHC1_DATA1_CONN_USDHC1_DATA1 0x00000021 + SC_P_USDHC1_DATA2_CONN_USDHC1_DATA2 0x00000021 + SC_P_USDHC1_DATA3_CONN_USDHC1_DATA3 0x00000021 + SC_P_USDHC1_VSELECT_CONN_USDHC1_VSELECT 0x00000021 + >; + }; + + pinctrl_usdhc2_100mhz: usdhc2grp100mhz { + fsl,pins = < + SC_P_USDHC1_CLK_CONN_USDHC1_CLK 0x06000040 + SC_P_USDHC1_CMD_CONN_USDHC1_CMD 0x00000020 + SC_P_USDHC1_DATA0_CONN_USDHC1_DATA0 0x00000020 + SC_P_USDHC1_DATA1_CONN_USDHC1_DATA1 0x00000020 + SC_P_USDHC1_DATA2_CONN_USDHC1_DATA2 0x00000020 + SC_P_USDHC1_DATA3_CONN_USDHC1_DATA3 0x00000020 + SC_P_USDHC1_VSELECT_CONN_USDHC1_VSELECT 0x00000020 + >; + }; + + pinctrl_usdhc2_200mhz: usdhc2grp200mhz { + fsl,pins = < + SC_P_USDHC1_CLK_CONN_USDHC1_CLK 0x06000040 + SC_P_USDHC1_CMD_CONN_USDHC1_CMD 0x00000020 + SC_P_USDHC1_DATA0_CONN_USDHC1_DATA0 0x00000020 + SC_P_USDHC1_DATA1_CONN_USDHC1_DATA1 0x00000020 + SC_P_USDHC1_DATA2_CONN_USDHC1_DATA2 0x00000020 + SC_P_USDHC1_DATA3_CONN_USDHC1_DATA3 0x00000020 + SC_P_USDHC1_VSELECT_CONN_USDHC1_VSELECT 0x00000020 + >; + }; + + pinctrl_usdhc3_gpio: usdhc3grpgpio { + fsl,pins = < + SC_P_USDHC2_RESET_B_LSIO_GPIO4_IO09 0x00000021 + SC_P_USDHC2_CD_B_LSIO_GPIO4_IO12 0x00000021 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + SC_P_USDHC2_CLK_CONN_USDHC2_CLK 0x06000041 + SC_P_USDHC2_CMD_CONN_USDHC2_CMD 0x00000021 + SC_P_USDHC2_DATA0_CONN_USDHC2_DATA0 0x00000021 + SC_P_USDHC2_DATA1_CONN_USDHC2_DATA1 0x00000021 + SC_P_USDHC2_DATA2_CONN_USDHC2_DATA2 0x00000021 + SC_P_USDHC2_DATA3_CONN_USDHC2_DATA3 0x00000021 + SC_P_USDHC2_VSELECT_CONN_USDHC2_VSELECT 0x00000021 + >; + }; + + pinctrl_usdhc3_100mhz: usdhc3grp100mhz { + fsl,pins = < + SC_P_USDHC2_CLK_CONN_USDHC2_CLK 0x06000040 + SC_P_USDHC2_CMD_CONN_USDHC2_CMD 0x00000020 + SC_P_USDHC2_DATA0_CONN_USDHC2_DATA0 0x00000020 + SC_P_USDHC2_DATA1_CONN_USDHC2_DATA1 0x00000020 + SC_P_USDHC2_DATA2_CONN_USDHC2_DATA2 0x00000020 + SC_P_USDHC2_DATA3_CONN_USDHC2_DATA3 0x00000020 + SC_P_USDHC2_VSELECT_CONN_USDHC2_VSELECT 0x00000020 + >; + }; + + pinctrl_usdhc3_200mhz: usdhc3grp200mhz { + fsl,pins = < + SC_P_USDHC2_CLK_CONN_USDHC2_CLK 0x06000040 + SC_P_USDHC2_CMD_CONN_USDHC2_CMD 0x00000020 + SC_P_USDHC2_DATA0_CONN_USDHC2_DATA0 0x00000020 + SC_P_USDHC2_DATA1_CONN_USDHC2_DATA1 0x00000020 + SC_P_USDHC2_DATA2_CONN_USDHC2_DATA2 0x00000020 + SC_P_USDHC2_DATA3_CONN_USDHC2_DATA3 0x00000020 + SC_P_USDHC2_VSELECT_CONN_USDHC2_VSELECT 0x00000020 + >; + }; +/* + pinctrl_usbotg1: usbotg1 { + fsl,pins = < + SC_P_USB_SS3_TC0_CONN_USB_OTG1_PWR 0x00000021 + >; + }; +*/ + }; +}; + +&lpuart0 { /* console */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lpuart0>; + status = "okay"; +}; + +&lpuart1 { /* Q7 connector */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lpuart1>; + status = "okay"; +}; + +&pd_dma_lpuart0 { + debug_console; +}; + +&usdhc1 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc1>; + pinctrl-1 = <&pinctrl_usdhc1_100mhz>; + pinctrl-2 = <&pinctrl_usdhc1_200mhz>; + bus-width = <8>; + non-removable; + status = "okay"; +}; + +&usdhc2 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; + pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>; + pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>; + bus-width = <4>; + cd-gpios = <&gpio5 22 GPIO_ACTIVE_LOW>; + wp-gpios = <&gpio5 21 GPIO_ACTIVE_HIGH>; + vmmc-supply = <®_usdhc2_vmmc>; + fsl,tuning-start-tap = <20>; + fsl,tuning-step= <2>; + status = "okay"; +}; + +&usdhc3 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc3>, <&pinctrl_usdhc3_gpio>; + pinctrl-1 = <&pinctrl_usdhc3_100mhz>, <&pinctrl_usdhc3_gpio>; + pinctrl-2 = <&pinctrl_usdhc3_200mhz>, <&pinctrl_usdhc3_gpio>; + bus-width = <4>; + cd-gpios = <&gpio4 12 GPIO_ACTIVE_LOW>; + vmmc-supply = <®_usdhc3_vmmc>; + fsl,tuning-start-tap = <20>; + fsl,tuning-step= <2>; + status = "okay"; +}; +/* +&usbotg1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usbotg1>; + srp-disable; + hnp-disable; + adp-disable; + power-polarity-active-high; + disable-over-current; + status = "okay"; +}; + +&usb2 { + status = "okay"; +}; +*/ diff --git a/arch/arm/mach-imx/Makefile b/arch/arm/mach-imx/Makefile index fbd99a3499..891631055a 100644 --- a/arch/arm/mach-imx/Makefile +++ b/arch/arm/mach-imx/Makefile @@ -152,10 +152,8 @@ ifeq ($(DEPFILE_EXISTS),0) endif
flash.bin: spl/u-boot-spl-ddr.bin u-boot.itb FORCE -ifeq ($(DEPFILE_EXISTS),0) $(call if_changed,mkimage) endif -endif
ifeq ($(CONFIG_ARCH_IMX8), y) SPL: diff --git a/arch/arm/mach-imx/imx8/Kconfig b/arch/arm/mach-imx/imx8/Kconfig index d17760e333..d47946d744 100644 --- a/arch/arm/mach-imx/imx8/Kconfig +++ b/arch/arm/mach-imx/imx8/Kconfig @@ -55,6 +55,12 @@ config TARGET_IMX8QM_MEK select BOARD_LATE_INIT select IMX8QM
+config TARGET_CONGA_QMX8 + bool "Support congatec conga-QMX8 board" + select BOARD_LATE_INIT + select SUPPORT_SPL + select IMX8QM + config TARGET_IMX8QXP_MEK bool "Support i.MX8QXP MEK board" select BOARD_LATE_INIT @@ -64,6 +70,7 @@ endchoice
source "board/freescale/imx8qm_mek/Kconfig" source "board/freescale/imx8qxp_mek/Kconfig" +source "board/congatec/cgtqmx8/Kconfig" source "board/toradex/apalis-imx8/Kconfig" source "board/toradex/colibri-imx8x/Kconfig"
diff --git a/board/congatec/cgtqmx8/Kconfig b/board/congatec/cgtqmx8/Kconfig new file mode 100644 index 0000000000..7273039261 --- /dev/null +++ b/board/congatec/cgtqmx8/Kconfig @@ -0,0 +1,14 @@ +if TARGET_CONGA_QMX8 + +config SYS_BOARD + default "cgtqmx8" + +config SYS_VENDOR + default "congatec" + +config SYS_CONFIG_NAME + default "cgtqmx8" + +source "board/congatec/common/Kconfig" + +endif diff --git a/board/congatec/cgtqmx8/MAINTAINERS b/board/congatec/cgtqmx8/MAINTAINERS new file mode 100644 index 0000000000..a242e534c8 --- /dev/null +++ b/board/congatec/cgtqmx8/MAINTAINERS @@ -0,0 +1,6 @@ +i.MX8QM CGTQMX8 BOARD +M: Oliver Graute oliver.graute@kococonnector.com +S: Maintained +F: board/congatec/cgtqmx8/ +F: include/configs/cgtqmx8.h +F: configs/cgtqmx8_defconfig diff --git a/board/congatec/cgtqmx8/Makefile b/board/congatec/cgtqmx8/Makefile new file mode 100644 index 0000000000..4b59dbb6bc --- /dev/null +++ b/board/congatec/cgtqmx8/Makefile @@ -0,0 +1,11 @@ +# +# Copyright 2017 NXP +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += cgtqmx8.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +endif diff --git a/board/congatec/cgtqmx8/README b/board/congatec/cgtqmx8/README new file mode 100644 index 0000000000..5724eb89f7 --- /dev/null +++ b/board/congatec/cgtqmx8/README @@ -0,0 +1,15 @@ +Build U-Boot +============ + +$ export ATF_LOAD_ADDR=0x80000000 +$ export BL33_LOAD_ADDR=0x80020000 +$ make cgtqmx8_defconfig +$ make u-boot.bin +$ make flash.bin + +Flash the binary into the SD card +================================= + +Burn the flash.bin binary to SD card offset 32KB: + +$ sudo dd if=flash.bin of=/dev/sd[x] bs=1k seek=32 conv=fsync diff --git a/board/congatec/cgtqmx8/cgtqmx8.c b/board/congatec/cgtqmx8/cgtqmx8.c new file mode 100644 index 0000000000..d0f5f62c41 --- /dev/null +++ b/board/congatec/cgtqmx8/cgtqmx8.c @@ -0,0 +1,478 @@ +//SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 congatec AG + * Copyright (C) 2019 Oliver Graute oliver.graute@kococonnector.com + */ +#include <common.h> +#include <errno.h> +#include <linux/libfdt.h> +#include <fsl_esdhc.h> + +#include <asm/io.h> +#include <asm/gpio.h> +#include <asm/arch/clock.h> +#include <asm/arch/sci/sci.h> +#include <asm/arch/imx8-pins.h> +#include <usb.h> +#include <asm/arch/iomux.h> +#include <asm/arch/sys_proto.h> +#include <power-domain.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define ESDHC_PAD_CTRL ((SC_PAD_CONFIG_NORMAL << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define ESDHC_CLK_PAD_CTRL ((SC_PAD_CONFIG_OUT_IN << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define ENET_INPUT_PAD_CTRL ((SC_PAD_CONFIG_OD_IN << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_18V_10MA << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define ENET_NORMAL_PAD_CTRL ((SC_PAD_CONFIG_NORMAL << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_18V_10MA << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define FSPI_PAD_CTRL ((SC_PAD_CONFIG_NORMAL << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define GPIO_PAD_CTRL ((SC_PAD_CONFIG_NORMAL << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define I2C_PAD_CTRL ((SC_PAD_CONFIG_OUT_IN << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_LOW << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define UART_PAD_CTRL ((SC_PAD_CONFIG_OUT_IN << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +static iomux_cfg_t uart0_pads[] = { + SC_P_UART0_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + SC_P_UART0_TX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static void setup_iomux_uart(void) +{ + imx8_iomux_setup_multiple_pads(uart0_pads, ARRAY_SIZE(uart0_pads)); +} + +int board_early_init_f(void) +{ + /* sc_ipc_t ipcHndl = 0; */ + sc_err_t sciErr = 0; + + /* When start u-boot in XEN VM, directly return */ + /* if (IS_ENABLED(CONFIG_XEN)) */ + /* return 0; */ + + /* ipcHndl = gd->arch.ipc_channel_handle; */ + + /* Power up UART0, this is very early while power domain is not working */ + sciErr = sc_pm_set_resource_power_mode(-1, SC_R_UART_0, SC_PM_PW_MODE_ON); + if (sciErr != SC_ERR_NONE) + return 0; + + /* Set UART0 clock root to 80 MHz */ + sc_pm_clock_rate_t rate = 80000000; + sciErr = sc_pm_set_clock_rate(-1, SC_R_UART_0, 2, &rate); + if (sciErr != SC_ERR_NONE) + return 0; + + /* Enable UART0 clock root */ + sciErr = sc_pm_clock_enable(-1, SC_R_UART_0, 2, true, false); + if (sciErr != SC_ERR_NONE) + return 0; + + setup_iomux_uart(); + + return 0; +} + +#ifdef CONFIG_FSL_ESDHC + +#define USDHC1_CD_GPIO IMX_GPIO_NR(5, 22) +#define USDHC2_CD_GPIO IMX_GPIO_NR(4, 12) + +static struct fsl_esdhc_cfg usdhc_cfg[CONFIG_SYS_FSL_USDHC_NUM] = { + {USDHC1_BASE_ADDR, 0, 8}, + {USDHC2_BASE_ADDR, 0, 4}, + {USDHC3_BASE_ADDR, 0, 4}, +}; + +static iomux_cfg_t emmc0[] = { + SC_P_EMMC0_CLK | MUX_PAD_CTRL(ESDHC_CLK_PAD_CTRL), + SC_P_EMMC0_CMD | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA0 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA1 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA2 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA3 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA4 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA5 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA6 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_DATA7 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_RESET_B | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_EMMC0_STROBE | MUX_PAD_CTRL(ESDHC_PAD_CTRL), +}; + +static iomux_cfg_t usdhc1_sd[] = { + SC_P_USDHC1_CLK | MUX_PAD_CTRL(ESDHC_CLK_PAD_CTRL), + SC_P_USDHC1_CMD | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC1_DATA0 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC1_DATA1 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC1_DATA2 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC1_DATA3 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC1_DATA6 | MUX_MODE_ALT(2) | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC1_DATA7 | MUX_MODE_ALT(3) | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC1_RESET_B | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC1_VSELECT | MUX_PAD_CTRL(ESDHC_PAD_CTRL), +}; + +static iomux_cfg_t usdhc2_sd[] = { + SC_P_USDHC2_CLK | MUX_PAD_CTRL(ESDHC_CLK_PAD_CTRL), + SC_P_USDHC2_CMD | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_DATA0 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_DATA1 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_DATA2 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_DATA3 | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_RESET_B | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_VSELECT | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_WP | MUX_PAD_CTRL(ESDHC_PAD_CTRL), + SC_P_USDHC2_CD_B | MUX_MODE_ALT(3) | MUX_PAD_CTRL(ESDHC_PAD_CTRL), +}; + +int board_mmc_init(bd_t *bis) +{ + int i, ret; + struct power_domain pd; + + /* + * According to the board_mmc_init() the following map is done: + * (U-Boot device node) (Physical Port) + * mmc0 (onboard eMMC) USDHC1 + * mmc1 (external SD card) USDHC2 + * mmc2 (onboard µSD) USDHC3 + */ + for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { + switch (i) { + case 0: + /* onboard eMMC */ + if (!power_domain_lookup_name("conn_sdhc0", &pd)) + power_domain_on(&pd); + + imx8_iomux_setup_multiple_pads(emmc0, ARRAY_SIZE(emmc0)); + init_clk_usdhc(0); + usdhc_cfg[i].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); + break; + case 1: + /* external SD card */ + if (!power_domain_lookup_name("conn_sdhc1", &pd)) + power_domain_on(&pd); + + imx8_iomux_setup_multiple_pads(usdhc1_sd, ARRAY_SIZE(usdhc1_sd)); + init_clk_usdhc(1); + usdhc_cfg[i].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); + gpio_request(USDHC1_CD_GPIO, "sd1_cd"); + gpio_direction_input(USDHC1_CD_GPIO); + break; + case 2: + /* onboard µSD */ + if (!power_domain_lookup_name("conn_sdhc2", &pd)) + power_domain_on(&pd); + + imx8_iomux_setup_multiple_pads(usdhc2_sd, ARRAY_SIZE(usdhc2_sd)); + init_clk_usdhc(2); + usdhc_cfg[i].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + gpio_request(USDHC2_CD_GPIO, "sd2_cd"); + gpio_direction_input(USDHC2_CD_GPIO); + break; + default: + printf("Warning: you configured more USDHC controllers" + "(%d) than supported by the board\n", i + 1); + return 0; + } + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + if (ret) { + printf("Warning: failed to initialize mmc dev %d\n", i); + return ret; + } + } + + return 0; +} + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC1_BASE_ADDR: + ret = 1; + break; + case USDHC2_BASE_ADDR: + ret = !gpio_get_value(USDHC1_CD_GPIO); + break; + case USDHC3_BASE_ADDR: + ret = !gpio_get_value(USDHC2_CD_GPIO); + break; + } + + return ret; +} + +#endif /* CONFIG_FSL_ESDHC */ + +#ifdef CONFIG_FEC_MXC +#include <miiphy.h> + +static iomux_cfg_t pad_enet0[] = { + SC_P_ENET0_RGMII_RX_CTL | MUX_PAD_CTRL(ENET_INPUT_PAD_CTRL), + SC_P_ENET0_RGMII_RXD0 | MUX_PAD_CTRL(ENET_INPUT_PAD_CTRL), + SC_P_ENET0_RGMII_RXD1 | MUX_PAD_CTRL(ENET_INPUT_PAD_CTRL), + SC_P_ENET0_RGMII_RXD2 | MUX_PAD_CTRL(ENET_INPUT_PAD_CTRL), + SC_P_ENET0_RGMII_RXD3 | MUX_PAD_CTRL(ENET_INPUT_PAD_CTRL), + SC_P_ENET0_RGMII_RXC | MUX_PAD_CTRL(ENET_INPUT_PAD_CTRL), + SC_P_ENET0_RGMII_TX_CTL | MUX_PAD_CTRL(ENET_NORMAL_PAD_CTRL), + SC_P_ENET0_RGMII_TXD0 | MUX_PAD_CTRL(ENET_NORMAL_PAD_CTRL), + SC_P_ENET0_RGMII_TXD1 | MUX_PAD_CTRL(ENET_NORMAL_PAD_CTRL), + SC_P_ENET0_RGMII_TXD2 | MUX_PAD_CTRL(ENET_NORMAL_PAD_CTRL), + SC_P_ENET0_RGMII_TXD3 | MUX_PAD_CTRL(ENET_NORMAL_PAD_CTRL), + SC_P_ENET0_RGMII_TXC | MUX_PAD_CTRL(ENET_NORMAL_PAD_CTRL), + SC_P_ENET0_MDC | MUX_PAD_CTRL(ENET_NORMAL_PAD_CTRL), + SC_P_ENET0_MDIO | MUX_PAD_CTRL(ENET_NORMAL_PAD_CTRL), +}; + +static void setup_iomux_fec(void) +{ + imx8_iomux_setup_multiple_pads(pad_enet0, ARRAY_SIZE(pad_enet0)); +} + +static void enet_device_phy_reset(void) +{ + gpio_set_value(FEC0_RESET, 0); + udelay(50); + gpio_set_value(FEC0_RESET, 1); + + /* The board has a long delay for this reset to become stable */ + mdelay(200); +} + +int board_eth_init(bd_t *bis) +{ + int ret; + struct power_domain pd0; + + /* if (!power_domain_lookup_name(FEC0_PDOMAIN, &pd0)) */ + /* power_domain_on(&pd0); */ + + setup_iomux_fec(); + + /* ret = fecmxc_initialize_multi(bis, CONFIG_FEC_ENET_DEV, */ + /* CONFIG_FEC_MXC_PHYADDR, IMX_FEC_BASE); */ + if (ret) + printf("FEC0 MXC: %s:failed\n", __func__); + + return ret; +} + +int board_phy_config(struct phy_device *phydev) +{ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x8); + + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x00); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x82ee); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100); + + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} + +static int setup_fec(void) +{ + /* Reset ENET PHY */ + enet_device_phy_reset(); + + return 0; +} +#endif + +#ifdef CONFIG_MXC_GPIO + +#define LVDS_ENABLE IMX_GPIO_NR(1, 6) +#define BKL_ENABLE IMX_GPIO_NR(1, 7) + +static iomux_cfg_t board_gpios[] = { + SC_P_LVDS0_I2C0_SCL | MUX_MODE_ALT(3) | MUX_PAD_CTRL(GPIO_PAD_CTRL), + SC_P_LVDS0_I2C0_SDA | MUX_MODE_ALT(3) | MUX_PAD_CTRL(GPIO_PAD_CTRL), + SC_P_ESAI1_FST | MUX_MODE_ALT(3) | MUX_PAD_CTRL(GPIO_PAD_CTRL), +}; + +static void board_gpio_init(void) +{ + imx8_iomux_setup_multiple_pads(board_gpios, ARRAY_SIZE(board_gpios)); + + /* enable LVDS */ + gpio_request(LVDS_ENABLE, "lvds_enable"); + gpio_direction_output(LVDS_ENABLE, 1); + + /* enable backlight */ + gpio_request(BKL_ENABLE, "bkl_enable"); + gpio_direction_output(BKL_ENABLE, 1); + + /* ethernet reset */ + gpio_request(FEC0_RESET, "enet0_reset"); + gpio_direction_output(FEC0_RESET, 1); +} +#endif + +int checkboard(void) +{ + puts("Board: conga-QMX8\n"); + + build_info(); + print_bootinfo(); + + /* Note: After reloc, ipcHndl will no longer be valid. If handle + * returned by sc_ipc_open matches SC_IPC_CH, use this + * macro (valid after reloc) for subsequent SCI calls. + */ + /* + if (gd->arch.ipc_channel_handle != SC_IPC_CH) { + printf("\nSCI error! Invalid handle\n"); + } + */ + + return 0; +} + +int board_init(void) +{ + if (IS_ENABLED(CONFIG_XEN)) + return 0; + +#ifdef CONFIG_MXC_GPIO + board_gpio_init(); +#endif + +#ifdef CONFIG_FEC_MXC + setup_fec(); +#endif + + return 0; +} + +void detail_board_ddr_info(void) +{ + puts("\nDDR "); +} + +/* + * Board specific reset that is system reset. + */ +void reset_cpu(ulong addr) +{ +/* + puts("SCI reboot request"); + sc_pm_reboot(SC_IPC_CH, SC_PM_RESET_TYPE_COLD); + while (1) + putc('.'); +*/ + /* TODO */ +} + + +#ifdef CONFIG_OF_BOARD_SETUP +int ft_board_setup(void *blob, bd_t *bd) +{ + return 0; +} +#endif + +int board_mmc_get_env_dev(int devno) +{ + /* Use EMMC */ + if (IS_ENABLED(CONFIG_XEN)) + return 0; + + return devno; +} + +int mmc_map_to_kernel_blk(int dev_no) +{ + /* Use EMMC */ + if (IS_ENABLED(CONFIG_XEN)) + return 0; + + return dev_no; +} + +extern uint32_t _end_ofs; +int board_late_init(void) +{ +#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + env_set("board_name", "QMX8"); + env_set("board_rev", "iMX8QM"); +#endif + + env_set("sec_boot", "no"); +#ifdef CONFIG_AHAB_BOOT + env_set("sec_boot", "yes"); +#endif + +#ifdef CONFIG_ENV_IS_IN_MMC + board_late_mmc_env_init(); +#endif + +#ifdef IMX_LOAD_HDMI_FIMRWARE + char *end_of_uboot; + char command[256]; + end_of_uboot = (char *)(ulong)(CONFIG_SYS_TEXT_BASE + _end_ofs + fdt_totalsize(gd->fdt_blob)); + end_of_uboot += 9; + + /* load hdmitxfw.bin and hdmirxfw.bin*/ + memcpy(IMX_HDMI_FIRMWARE_LOAD_ADDR, end_of_uboot, + IMX_HDMITX_FIRMWARE_SIZE + IMX_HDMIRX_FIRMWARE_SIZE); + + sprintf(command, "hdp load 0x%x", IMX_HDMI_FIRMWARE_LOAD_ADDR); + run_command(command, 0); + + sprintf(command, "hdprx load 0x%x", + IMX_HDMI_FIRMWARE_LOAD_ADDR + IMX_HDMITX_FIRMWARE_SIZE); + run_command(command, 0); +#endif + + return 0; +} + +#ifdef CONFIG_FSL_FASTBOOT +#ifdef CONFIG_ANDROID_RECOVERY +int is_recovery_key_pressing(void) +{ + return 0; /*TODO*/ +} +#endif /*CONFIG_ANDROID_RECOVERY*/ +#endif /*CONFIG_FSL_FASTBOOT*/ + +/* Only Enable USB3 resources currently */ +int board_usb_init(int index, enum usb_init_type init) +{ + return 0; +} diff --git a/board/congatec/cgtqmx8/imximage.cfg b/board/congatec/cgtqmx8/imximage.cfg new file mode 100644 index 0000000000..e324c7ca37 --- /dev/null +++ b/board/congatec/cgtqmx8/imximage.cfg @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2018 NXP + */ + +#define __ASSEMBLY__ + +/* Boot from SD, sector size 0x400 */ +BOOT_FROM SD 0x400 +/* SoC type IMX8QM */ +SOC_TYPE IMX8QM +/* Append seco container image */ +APPEND mx8qm-ahab-container.img +/* Create the 2nd container */ +CONTAINER +/* Add scfw image with exec attribute */ +IMAGE SCU mx8qm-val-scfw-tcm.bin +/* Add ATF image with exec attribute */ +IMAGE A35 bl31.bin 0x80000000 +/* Add U-Boot image with load attribute */ +DATA A35 u-boot-dtb.bin 0x80020000 diff --git a/board/congatec/cgtqmx8/spl.c b/board/congatec/cgtqmx8/spl.c new file mode 100644 index 0000000000..95ce9f37e8 --- /dev/null +++ b/board/congatec/cgtqmx8/spl.c @@ -0,0 +1,75 @@ +/* + * Copyright 2018 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <spl.h> +#include <dm/uclass.h> +#include <dm/device.h> +#include <dm/uclass-internal.h> +#include <dm/device-internal.h> +#include <dm/lists.h> + +DECLARE_GLOBAL_DATA_PTR; + +void spl_board_init(void) +{ + struct udevice *dev; + int offset; + + uclass_find_first_device(UCLASS_MISC, &dev); + + for (; dev; uclass_find_next_device(&dev)) { + if (device_probe(dev)) + continue; + } + + offset = fdt_node_offset_by_compatible(gd->fdt_blob, -1, "nxp,imx8-pd"); + while (offset != -FDT_ERR_NOTFOUND) { + lists_bind_fdt(gd->dm_root, offset_to_ofnode(offset), + NULL, true); + offset = fdt_node_offset_by_compatible(gd->fdt_blob, offset, + "nxp,imx8-pd"); + } + + uclass_find_first_device(UCLASS_POWER_DOMAIN, &dev); + + for (; dev; uclass_find_next_device(&dev)) { + if (device_probe(dev)) + continue; + } + + arch_cpu_init(); + + board_early_init_f(); + + timer_init(); + + preloader_console_init(); + + puts("Normal Boot\n"); +} + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + /* Just empty function now - can't decide what to choose */ + debug("%s: %s\n", __func__, name); + + return 0; +} +#endif + +void board_init_f(ulong dummy) +{ + /* Clear global data */ + memset((void *)gd, 0, sizeof(gd_t)); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + board_init_r(NULL, 0); +} diff --git a/board/congatec/common/Kconfig b/board/congatec/common/Kconfig new file mode 100644 index 0000000000..5c205bd830 --- /dev/null +++ b/board/congatec/common/Kconfig @@ -0,0 +1,48 @@ +if !ARCH_IMX8M && !ARCH_IMX8 + +config CHAIN_OF_TRUST + depends on !FIT_SIGNATURE && SECURE_BOOT + imply CMD_BLOB + imply CMD_HASH if ARM + select FSL_CAAM + select SPL_BOARD_INIT if (ARM && SPL) + select SHA_HW_ACCEL + select SHA_PROG_HW_ACCEL + select ENV_IS_NOWHERE + select CMD_EXT4 if ARM + select CMD_EXT4_WRITE if ARM + bool + default y + +config CMD_ESBC_VALIDATE + bool "Enable the 'esbc_validate' and 'esbc_halt' commands" + default y if CHAIN_OF_TRUST + help + This option enables two commands used for secure booting: + + esbc_validate - validate signature using RSA verification + esbc_halt - put the core in spin loop (Secure Boot Only) + +endif + +config VOL_MONITOR_LTC3882_READ + depends on VID + bool "Enable the LTC3882 voltage monitor read" + default n + help + This option enables LTC3882 voltage monitor read + functionality. It is used by common VID driver. + +config VOL_MONITOR_LTC3882_SET + depends on VID + bool "Enable the LTC3882 voltage monitor set" + default n + help + This option enables LTC3882 voltage monitor set + functionality. It is used by common VID driver. + +config USB_TCPC + bool "USB Typec port controller simple driver" + default n + help + Enable USB type-c port controller (TCPC) driver diff --git a/board/congatec/common/Makefile b/board/congatec/common/Makefile new file mode 100644 index 0000000000..d4ddfbf971 --- /dev/null +++ b/board/congatec/common/Makefile @@ -0,0 +1,23 @@ +# +# (C) Copyright 2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +MINIMAL= + +ifdef CONFIG_SPL_BUILD +ifdef CONFIG_SPL_INIT_MINIMAL +MINIMAL=y +endif +endif + +ifdef MINIMAL +# necessary to create built-in.o +obj- := __dummy__.o +else + +obj-y += mmc.o + +endif diff --git a/board/congatec/common/mmc.c b/board/congatec/common/mmc.c new file mode 100644 index 0000000000..9fc3e68728 --- /dev/null +++ b/board/congatec/common/mmc.c @@ -0,0 +1,50 @@ +/* + * Copyright (C) 2016 Freescale Semiconductor, Inc. + * Copyright 2018 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <asm/arch/sys_proto.h> +#include <linux/errno.h> +#include <asm/io.h> +#include <stdbool.h> +#include <mmc.h> + +static int check_mmc_autodetect(void) +{ + char *autodetect_str = env_get("mmcautodetect"); + + if ((autodetect_str != NULL) && + (strcmp(autodetect_str, "yes") == 0)) { + return 1; + } + + return 0; +} + +/* This should be defined for each board */ +__weak int mmc_map_to_kernel_blk(int dev_no) +{ + return dev_no; +} + +void board_late_mmc_env_init(void) +{ + char cmd[32]; + char mmcblk[32]; + u32 dev_no = mmc_get_env_dev(); + + if (!check_mmc_autodetect()) + return; + + env_set_ulong("mmcdev", dev_no); + + /* Set mmcblk env */ + sprintf(mmcblk, "/dev/mmcblk%dp2 rootwait rw", + mmc_map_to_kernel_blk(dev_no)); + env_set("mmcroot", mmcblk); + + sprintf(cmd, "mmc dev %d", dev_no); + run_command(cmd, 0); +} diff --git a/configs/cgtqmx8_defconfig b/configs/cgtqmx8_defconfig new file mode 100644 index 0000000000..1245403fbf --- /dev/null +++ b/configs/cgtqmx8_defconfig @@ -0,0 +1,79 @@ +CONFIG_ARM=y +CONFIG_SPL_SYS_ICACHE_OFF=y +CONFIG_SPL_SYS_DCACHE_OFF=y +CONFIG_ARCH_IMX8=y +CONFIG_SYS_TEXT_BASE=0x80020000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_TARGET_CONGA_QMX8=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=3 +CONFIG_SPL=y +CONFIG_FIT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/congatec/cgtqmx8/imximage.cfg" +CONFIG_BOOTDELAY=3 +CONFIG_LOG=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_HUSH_PARSER=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_SPL_POWER_DOMAIN=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_CMD_CPU=y +# CONFIG_BOOTM_NETBSD is not set +# CONFIG_CMD_IMPORTENV is not set +CONFIG_CMD_CLK=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_FAT=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx8qm-cgtqmx8" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_DM=y +CONFIG_SPL_CLK=y +CONFIG_CLK_IMX8=y +CONFIG_CPU=y +CONFIG_DM_GPIO=y +CONFIG_MXC_GPIO=y +CONFIG_DM_PCA953X=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_IMX_LPI2C=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_FSL_USDHC=y +CONFIG_PHYLIB=y +CONFIG_PHY_ADDR_ENABLE=y +CONFIG_PHY_ATHEROS=y +CONFIG_DM_ETH=y +CONFIG_PHY_GIGE=y +CONFIG_FEC_MXC_SHARE_MDIO=y +CONFIG_FEC_MXC_MDIO_BASE=0x5B040000 +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8_POWER_DOMAIN=y +CONFIG_DM_REGULATOR=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_SPL_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y +CONFIG_FSL_LPUART=y +CONFIG_SPL_TINY_MEMSET=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/cgtqmx8.h b/include/configs/cgtqmx8.h new file mode 100644 index 0000000000..f29e144d9a --- /dev/null +++ b/include/configs/cgtqmx8.h @@ -0,0 +1,167 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2017-2018 NXP + * Copyright 2018 congatec AG + * + */ + +#ifndef __CGTQMX8_H +#define __CGTQMX8_H + +#include <linux/sizes.h> +#include <asm/arch/imx-regs.h> + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_TEXT_BASE 0x0 +#define CONFIG_SPL_MAX_SIZE (124 * 1024) +#define CONFIG_SYS_MONITOR_LEN (1024 * 1024) +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x800 +#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 0 + +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" +#define CONFIG_SPL_STACK 0x013E000 +#define CONFIG_SPL_BSS_START_ADDR 0x00128000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x1000 /* 4 KB */ +#define CONFIG_SYS_SPL_MALLOC_START 0x00120000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x3000 /* 12 KB */ +#define CONFIG_SERIAL_LPUART_BASE 0x5a060000 +#define CONFIG_MALLOC_F_ADDR 0x00120000 + +#define CONFIG_SPL_RAW_IMAGE_ARM_TRUSTED_FIRMWARE + +#define CONFIG_SPL_ABORT_ON_RAW_IMAGE + +#define CONFIG_OF_EMBED +#endif + +#define CONFIG_REMAKE_ELF + +#define CONFIG_BOARD_EARLY_INIT_F + +/* Flat Device Tree Definitions */ +#define CONFIG_OF_BOARD_SETUP + +#undef CONFIG_CMD_EXPORTENV +#undef CONFIG_CMD_IMPORTENV +#undef CONFIG_CMD_IMLS + +#undef CONFIG_CMD_CRC32 + +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define USDHC1_BASE_ADDR 0x5B010000 +#define USDHC2_BASE_ADDR 0x5B020000 +#define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */ + +#define CONFIG_ENV_OVERWRITE + +#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + +#define FEC0_RESET IMX_GPIO_NR(2, 5) +#define FEC0_PDOMAIN "conn_enet0" + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "script=boot.scr\0" \ + "image=Image\0" \ + "panel=NULL\0" \ + "console=ttyLP0\0" \ + "fdt_addr=0x83000000\0" \ + "fdt_high=0xffffffffffffffff\0" \ + "boot_fdt=try\0" \ + "fdt_file=imx8qm-cgt-qmx8.dtb\0" \ + "initrd_addr=0x83800000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "mmcdev="__stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \ + "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \ + "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \ + "mmcautodetect=yes\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} root=${mmcroot} earlycon\0 " \ + "loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "booti ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "else " \ + "echo wait for boot; " \ + "fi;\0" \ + "netargs=setenv bootargs console=${console},${baudrate} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp rw earlycon\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${loadaddr} ${image}; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "booti ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "else " \ + "booti; " \ + "fi;\0" + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loadimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "else booti ${loadaddr} - ${fdt_addr}; fi" + +/* Link Definitions */ +#define CONFIG_LOADADDR 0x80280000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_SYS_INIT_SP_ADDR 0x80200000 + +/* Default environment is in SD */ +#define CONFIG_ENV_SIZE 0x1000 +#define CONFIG_ENV_OFFSET (64 * SZ_64K) +#define CONFIG_SYS_MMC_ENV_PART 0 /* user area */ + +#define CONFIG_SYS_MMC_IMG_LOAD_PART 1 + +/* On LPDDR4 board, USDHC1 is for eMMC, USDHC2 is for SD on CPU board */ +#define CONFIG_SYS_MMC_ENV_DEV 1 /* USDHC2 */ +#define CONFIG_MMCROOT "/dev/mmcblk1p2" /* USDHC2 */ +#define CONFIG_SYS_FSL_USDHC_NUM 2 + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN ((CONFIG_ENV_SIZE + (32 * 1024)) * 1024) + +#define CONFIG_SYS_SDRAM_BASE 0x80000000 +#define PHYS_SDRAM_1 0x80000000 +#define PHYS_SDRAM_2 0x880000000 +#define PHYS_SDRAM_1_SIZE 0x80000000 /* 2 GB */ +#define PHYS_SDRAM_2_SIZE 0x100000000 /* 4 GB */ + +/* Serial */ +#define CONFIG_BAUDRATE 115200 + +/* Generic Timer Definitions */ +#define COUNTER_FREQUENCY 8000000 /* 8MHz */ + +/* Networking */ +#define CONFIG_FEC_XCV_TYPE RGMII +#define FEC_QUIRK_ENET_MAC + +#endif /* __CGTQMX8_H */
Oliver Graute
