[U-Boot] [PATCH] mpc85xx: use LCRR_DBYP define instead of raw constant
Using the raw value of 0x80000000 directly in the code can lead to "count the zeros" bugs like that fixed in commit 718e9d13b98 ("MPC85xxCDS: Fix missing LCRR_DBYP bits for 66-133MHz LBC")
Change all existing raw values to use the symbolic value of LCRR_DBYP instead.
Cc: Kumar Gala galak@kernel.crashing.org Cc: Scott Wood scottwood@freescale.com Signed-off-by: Paul Gortmaker paul.gortmaker@windriver.com
diff --git a/board/freescale/mpc8540ads/mpc8540ads.c b/board/freescale/mpc8540ads/mpc8540ads.c index c75585e..a275d3a 100644 --- a/board/freescale/mpc8540ads/mpc8540ads.c +++ b/board/freescale/mpc8540ads/mpc8540ads.c @@ -87,10 +87,10 @@ local_bus_init(void) lbc_hz = sysinfo.freqSystemBus / 1000000 / clkdiv;
if (lbc_hz < 66) { - lbc->lcrr = CONFIG_SYS_LBC_LCRR | 0x80000000; /* DLL Bypass */ + lbc->lcrr = CONFIG_SYS_LBC_LCRR | LCRR_DBYP; /* DLL Bypass */
} else if (lbc_hz >= 133) { - lbc->lcrr = CONFIG_SYS_LBC_LCRR & (~0x80000000); /* DLL Enabled */ + lbc->lcrr = CONFIG_SYS_LBC_LCRR & (~LCRR_DBYP); /* DLL Enabled */
} else { /* @@ -105,7 +105,7 @@ local_bus_init(void) lbc->lcrr = 0x10000004; }
- lbc->lcrr = CONFIG_SYS_LBC_LCRR & (~0x80000000); /* DLL Enabled */ + lbc->lcrr = CONFIG_SYS_LBC_LCRR & (~LCRR_DBYP); /* DLL Enabled */ udelay(200);
/* diff --git a/board/freescale/mpc8541cds/mpc8541cds.c b/board/freescale/mpc8541cds/mpc8541cds.c index 532d32a..13ca84b 100644 --- a/board/freescale/mpc8541cds/mpc8541cds.c +++ b/board/freescale/mpc8541cds/mpc8541cds.c @@ -269,13 +269,13 @@ local_bus_init(void) lbc_hz = sysinfo.freqSystemBus / 1000000 / clkdiv;
if (lbc_hz < 66) { - lbc->lcrr |= 0x80000000; /* DLL Bypass */ + lbc->lcrr |= LCRR_DBYP; /* DLL Bypass */
} else if (lbc_hz >= 133) { - lbc->lcrr &= (~0x80000000); /* DLL Enabled */ + lbc->lcrr &= (~LCRR_DBYP); /* DLL Enabled */
} else { - lbc->lcrr &= (~0x80000000); /* DLL Enabled */ + lbc->lcrr &= (~LCRR_DBYP); /* DLL Enabled */ udelay(200);
/* diff --git a/board/freescale/mpc8555cds/mpc8555cds.c b/board/freescale/mpc8555cds/mpc8555cds.c index 3361614..4cfd61c 100644 --- a/board/freescale/mpc8555cds/mpc8555cds.c +++ b/board/freescale/mpc8555cds/mpc8555cds.c @@ -267,13 +267,13 @@ local_bus_init(void) lbc_hz = sysinfo.freqSystemBus / 1000000 / clkdiv;
/* diff --git a/board/freescale/mpc8560ads/mpc8560ads.c b/board/freescale/mpc8560ads/mpc8560ads.c index 1a165bf..285edbc 100644 --- a/board/freescale/mpc8560ads/mpc8560ads.c +++ b/board/freescale/mpc8560ads/mpc8560ads.c @@ -292,10 +292,10 @@ local_bus_init(void) lbc_hz = sysinfo.freqSystemBus / 1000000 / clkdiv;
} else { /* @@ -310,7 +310,7 @@ local_bus_init(void) lbc->lcrr = 0x10000004; }
- lbc->lcrr = CONFIG_SYS_LBC_LCRR & (~0x80000000);/* DLL Enabled */ + lbc->lcrr = CONFIG_SYS_LBC_LCRR & (~LCRR_DBYP);/* DLL Enabled */ udelay(200);
Paul Gortmaker
