[U-Boot] [PATCH v4 0/4] add command env erase
sometimes it is needed to erase the non-volatile environment e.g. for boot-up with builtin-environment or after resizing env
this series add basic functionality for erasing environment from storage as a first storage-driver mmc is introduced, other needs to be added later
changes since v3: - fixes - Kconfig-option as suggested by Simon Goldschmidt - including CONFIG_ENV_OFFSET_REDUND (4/4 is RFC)
Frank Wunderlich (4): env: register erase command env: mmc: add erase-function env: add option to use redundant offset [RFC] env: call env_erase twice if CONFIG_ENV_OFFSET_REDUND is set
cmd/Kconfig | 8 ++++++++ cmd/nvedit.c | 26 ++++++++++++++++++++++++++ env/env.c | 30 ++++++++++++++++++++++++++++++ env/mmc.c | 36 ++++++++++++++++++++++++++++++++++++ include/environment.h | 17 +++++++++++++++++ 5 files changed, 117 insertions(+)
-- 2.17.1
this patch adds basic changes for adding a erase-subcommand to env
with this command the environment stored on non-volatile storage written by saveenv can be cleared.
Signed-off-by: Frank Wunderlich frank-w@public-files.de
squashed fixes - start message with "Erasing" - mark erase-function as optional - env: separate eraseenv from saveenv
Suggested-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com --- cmd/Kconfig | 8 ++++++++ cmd/nvedit.c | 19 +++++++++++++++++++ env/env.c | 30 ++++++++++++++++++++++++++++++ include/environment.h | 17 +++++++++++++++++ 4 files changed, 74 insertions(+)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 0b07b3b9d7..e8a99cb5a3 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -397,6 +397,14 @@ config CMD_SAVEENV Save all environment variables into the compiled-in persistent storage.
+config CMD_ERASEENV + bool "eraseenv" + default n + depends on CMD_SAVEENV + help + Erase environment variables from the compiled-in persistent + storage. + config CMD_ENV_EXISTS bool "env exists" default y diff --git a/cmd/nvedit.c b/cmd/nvedit.c index 24a6cf7824..0cbd8e8984 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -761,6 +761,19 @@ U_BOOT_CMD( "save environment variables to persistent storage", "" ); + +#if defined(CONFIG_CMD_ERASEENV) +static int do_env_erase(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + return env_erase() ? 1 : 0; +} +U_BOOT_CMD( + eraseenv, 1, 0, do_env_erase, + "erase environment variables from persistent storage", + "" +); +#endif #endif #endif /* CONFIG_SPL_BUILD */
@@ -1207,6 +1220,9 @@ static cmd_tbl_t cmd_env_sub[] = { #endif #if defined(CONFIG_CMD_SAVEENV) && !defined(CONFIG_ENV_IS_NOWHERE) U_BOOT_CMD_MKENT(save, 1, 0, do_env_save, "", ""), +#if defined(CONFIG_CMD_ERASEENV) + U_BOOT_CMD_MKENT(erase, 1, 0, do_env_erase, "", ""), +#endif #endif U_BOOT_CMD_MKENT(set, CONFIG_SYS_MAXARGS, 0, do_env_set, "", ""), #if defined(CONFIG_CMD_ENV_EXISTS) @@ -1282,6 +1298,9 @@ static char env_help_text[] = #endif #if defined(CONFIG_CMD_SAVEENV) && !defined(CONFIG_ENV_IS_NOWHERE) "env save - save environment\n" +#if defined(CONFIG_CMD_ERASEENV) + "env erase - erase environment\n" +#endif #endif #if defined(CONFIG_CMD_NVEDIT_EFI) "env set -e name [arg ...] - set UEFI variable; unset if 'arg' not specified\n" diff --git a/env/env.c b/env/env.c index 4b417b90a2..d3cbe2f915 100644 --- a/env/env.c +++ b/env/env.c @@ -24,6 +24,8 @@ void env_fix_drivers(void) entry->load += gd->reloc_off; if (entry->save) entry->save += gd->reloc_off; + if (entry->erase) + entry->erase += gd->reloc_off; if (entry->init) entry->init += gd->reloc_off; } @@ -254,6 +256,34 @@ int env_save(void) return -ENODEV; }
+int env_erase(void) +{ + struct env_driver *drv; + + drv = env_driver_lookup(ENVOP_ERASE, gd->env_load_prio); + if (drv) { + int ret; + + if (!drv->erase) + return -ENODEV; + + if (!env_has_inited(drv->location)) + return -ENODEV; + + printf("Erasing Environment on %s... ", drv->name); + ret = drv->erase(); + if (ret) + printf("Failed (%d)\n", ret); + else + printf("OK\n"); + + if (!ret) + return 0; + } + + return -ENODEV; +} + int env_init(void) { struct env_driver *drv; diff --git a/include/environment.h b/include/environment.h index cd96676141..de67cf4f0e 100644 --- a/include/environment.h +++ b/include/environment.h @@ -200,6 +200,7 @@ enum env_operation { ENVOP_INIT, /* we want to call the init function */ ENVOP_LOAD, /* we want to call the load function */ ENVOP_SAVE, /* we want to call the save function */ + ENVOP_ERASE, /* we want to call the erase function */ };
struct env_driver { @@ -225,6 +226,15 @@ struct env_driver { */ int (*save)(void);
+ /** + * erase() - Erase the environment on storage + * + * This method is optional and required for 'eraseenv' to work. + * + * @return 0 if OK, -ve on error + */ + int (*erase)(void); + /** * init() - Set up the initial pre-relocation environment * @@ -303,6 +313,13 @@ int env_load(void); */ int env_save(void);
+/** + * env_erase() - Erase the environment on storage + * + * @return 0 if OK, -ve on error + */ +int env_erase(void); + /** * env_fix_drivers() - Updates envdriver as per relocation */ -- 2.17.1
Am 28.04.2019 um 10:51 schrieb Frank Wunderlich:
Reviewed-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com
However, due to changes, this doesn't apply any more, so a v5 is needed.
squashed fixes
Suggested-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com =2D-- cmd/Kconfig | 8 ++++++++ cmd/nvedit.c | 19 +++++++++++++++++++ env/env.c | 30 ++++++++++++++++++++++++++++++ include/environment.h | 17 +++++++++++++++++ 4 files changed, 74 insertions(+)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 0b07b3b9d7..e8a99cb5a3 100644 =2D-- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -397,6 +397,14 @@ config CMD_SAVEENV Save all environment variables into the compiled-in persistent storage.
- bool "eraseenv"
- default n
- depends on CMD_SAVEENV
- help
storage.
- config CMD_ENV_EXISTS bool "env exists" default y
diff --git a/cmd/nvedit.c b/cmd/nvedit.c index 24a6cf7824..0cbd8e8984 100644 =2D-- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -761,6 +761,19 @@ U_BOOT_CMD( "save environment variables to persistent storage", "" );
- return env_erase() ? 1 : 0;
+} +U_BOOT_CMD(
- eraseenv, 1, 0, do_env_erase,
- "erase environment variables from persistent storage",
@@ -1207,6 +1220,9 @@ static cmd_tbl_t cmd_env_sub[] =3D { #endif #if defined(CONFIG_CMD_SAVEENV) && !defined(CONFIG_ENV_IS_NOWHERE) U_BOOT_CMD_MKENT(save, 1, 0, do_env_save, "", ""), +#if defined(CONFIG_CMD_ERASEENV)
- U_BOOT_CMD_MKENT(erase, 1, 0, do_env_erase, "", ""),
+#endif #endif U_BOOT_CMD_MKENT(set, CONFIG_SYS_MAXARGS, 0, do_env_set, "", ""), #if defined(CONFIG_CMD_ENV_EXISTS) @@ -1282,6 +1298,9 @@ static char env_help_text[] =3D #endif #if defined(CONFIG_CMD_SAVEENV) && !defined(CONFIG_ENV_IS_NOWHERE) "env save - save environment\n" +#if defined(CONFIG_CMD_ERASEENV)
- "env erase - erase environment\n"
+#endif #endif #if defined(CONFIG_CMD_NVEDIT_EFI) "env set -e name [arg ...] - set UEFI variable; unset if 'arg' not speci= fied\n" diff --git a/env/env.c b/env/env.c index 4b417b90a2..d3cbe2f915 100644 =2D-- a/env/env.c +++ b/env/env.c @@ -24,6 +24,8 @@ void env_fix_drivers(void) entry->load +=3D gd->reloc_off; if (entry->save) entry->save +=3D gd->reloc_off;
if (entry->erase)
if (entry->init) entry->init +=3D gd->reloc_off; }entry->erase +=3D gd->reloc_off;
- struct env_driver *drv;
- drv =3D env_driver_lookup(ENVOP_ERASE, gd->env_load_prio);
- if (drv) {
int ret;
if (!drv->erase)
return -ENODEV;
return -ENODEV;
ret =3D drv->erase();
if (ret)
else
printf("OK\n");
if (!ret)
- return -ENODEV;
- int env_init(void) { struct env_driver *drv;
diff --git a/include/environment.h b/include/environment.h index cd96676141..de67cf4f0e 100644 =2D-- a/include/environment.h +++ b/include/environment.h @@ -200,6 +200,7 @@ enum env_operation { ENVOP_INIT, /* we want to call the init function */ ENVOP_LOAD, /* we want to call the load function */ ENVOP_SAVE, /* we want to call the save function */
struct env_driver {
- int (*erase)(void);
- init() - Set up the initial pre-relocation environment
- env_erase() - Erase the environment on storage
- @return 0 if OK, -ve on error
- env_fix_drivers() - Updates envdriver as per relocation
=2D- 2.17.1
this adds erase environment for mmc storage
squashed fixes: - fix bogus indent - add CONFIG_CMD_ERASEENV
Suggested-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com --- env/mmc.c | 31 +++++++++++++++++++++++++++++++ 1 file changed, 31 insertions(+)
diff --git a/env/mmc.c b/env/mmc.c index c3cf35d01b..9ae9b1a66a 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -242,6 +242,34 @@ fini: fini_mmc_for_env(mmc); return ret; } + +#if defined(CONFIG_CMD_ERASEENV) +static int env_mmc_erase(void) +{ + int dev = mmc_get_env_dev(); + struct mmc *mmc = find_mmc_device(dev); + int n, blk, cnt; + + if (!mmc) + return CMD_RET_FAILURE; + + blk = CONFIG_ENV_OFFSET / mmc->read_bl_len; + cnt = CONFIG_ENV_SIZE / mmc->read_bl_len; + + printf("\nMMC erase env: dev # %d, block # %d (0x%x), count %d (0x%x)\n", + dev, blk, blk * mmc->read_bl_len, + cnt, cnt * mmc->read_bl_len); + + if (mmc_getwp(mmc) == 1) { + printf("Error: card is write protected!\n"); + return CMD_RET_FAILURE; + } + n = blk_derase(mmc_get_blk_desc(mmc), blk, cnt); + printf("%d blocks erased: %s\n", n, (n == cnt) ? "OK" : "ERROR"); + + return (n == cnt) ? CMD_RET_SUCCESS : CMD_RET_FAILURE; +} +#endif /* CONFIG_CMD_ERASEENV */ #endif /* CONFIG_CMD_SAVEENV && !CONFIG_SPL_BUILD */
static inline int read_env(struct mmc *mmc, unsigned long size, @@ -351,5 +379,8 @@ U_BOOT_ENV_LOCATION(mmc) = { .load = env_mmc_load, #ifndef CONFIG_SPL_BUILD .save = env_save_ptr(env_mmc_save), +#if defined(CONFIG_CMD_ERASEENV) + .erase = env_mmc_erase, +#endif #endif }; -- 2.17.1
I think this is still too complex.
I'd drop patches 3/4 and 4/4 and just erase both redundant storages here in env/mmc.c by calling the actual erase function twice.
To do that, it would help to do as I suggested in response to v3: copy the 2-function style used by the save env code, then you can just call that 2nd function twice with a different offset (all in env/mmc.c).
squashed fixes:
- fix bogus indent
Suggested-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com =2D-- env/mmc.c | 31 +++++++++++++++++++++++++++++++ 1 file changed, 31 insertions(+)
diff --git a/env/mmc.c b/env/mmc.c index c3cf35d01b..9ae9b1a66a 100644 =2D-- a/env/mmc.c +++ b/env/mmc.c @@ -242,6 +242,34 @@ fini: fini_mmc_for_env(mmc); return ret; }
- int dev =3D mmc_get_env_dev();
- struct mmc *mmc =3D find_mmc_device(dev);
- int n, blk, cnt;
- if (!mmc)
- blk =3D CONFIG_ENV_OFFSET / mmc->read_bl_len;
- cnt =3D CONFIG_ENV_SIZE / mmc->read_bl_len;
- printf("\nMMC erase env: dev # %d, block # %d (0x%x), count %d (0x%x)\n"=
- if (mmc_getwp(mmc) =3D=3D 1) {
- n =3D blk_derase(mmc_get_blk_desc(mmc), blk, cnt);
- printf("%d blocks erased: %s\n", n, (n =3D=3D cnt) ? "OK" : "ERROR");
- return (n =3D=3D cnt) ? CMD_RET_SUCCESS : CMD_RET_FAILURE;
static inline int read_env(struct mmc *mmc, unsigned long size, @@ -351,5 +379,8 @@ U_BOOT_ENV_LOCATION(mmc) =3D { .load =3D env_mmc_load, #ifndef CONFIG_SPL_BUILD .save =3D env_save_ptr(env_mmc_save), +#if defined(CONFIG_CMD_ERASEENV)
- .erase =3D env_mmc_erase,
+#endif #endif }; =2D- 2.17.1
You mean passing the offset (normal/redundant) instead of a bool?
Am 24. Juni 2019 21:40:36 MESZ schrieb Simon Goldschmidt simon.k.r.goldschmidt@gmail.com:
squashed fixes:
- fix bogus indent
- int n, blk, cnt;
- if (!mmc)
(0x%x)\n"=
"ERROR");
Frank Wunderlich frank-w@public-files.de schrieb am Mo., 24. Juni 2019, 22:09:
Would you mind keeping the mail style of this list and stop top-responses please?
I don't care where you make the difference between bool and actual offset, but you should keep all this as a changeset to env/mmc.c only to keep it consistent to existing redundant env code. Don't expose the bool to the env driver interface or the command file.
Am 24. Juni 2019 21:40:36 MESZ schrieb Simon Goldschmidt < simon.k.r.goldschmidt@gmail.com>:
squashed fixes:
- fix bogus indent
- int n, blk, cnt;
- if (!mmc)
(0x%x)\n"=
"ERROR");
allow env erase on secondary offset using CONFIG_ENV_OFFSET_REDUND
Suggested-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Signed-off-by: Frank Wunderlich frank-w@public-files.de --- cmd/nvedit.c | 2 +- env/env.c | 4 ++-- env/mmc.c | 9 +++++++-- include/environment.h | 4 ++-- 4 files changed, 12 insertions(+), 7 deletions(-)
diff --git a/cmd/nvedit.c b/cmd/nvedit.c index 0cbd8e8984..2071bcf443 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -766,7 +766,7 @@ U_BOOT_CMD( static int do_env_erase(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - return env_erase() ? 1 : 0; + return env_erase(false) ? 1 : 0; } U_BOOT_CMD( eraseenv, 1, 0, do_env_erase, diff --git a/env/env.c b/env/env.c index d3cbe2f915..bf7f3b9684 100644 --- a/env/env.c +++ b/env/env.c @@ -256,7 +256,7 @@ int env_save(void) return -ENODEV; }
-int env_erase(void) +int env_erase(bool use_redund) { struct env_driver *drv;
@@ -271,7 +271,7 @@ int env_erase(void) return -ENODEV;
printf("Erasing Environment on %s... ", drv->name); - ret = drv->erase(); + ret = drv->erase(use_redund); if (ret) printf("Failed (%d)\n", ret); else diff --git a/env/mmc.c b/env/mmc.c index 9ae9b1a66a..647bc693fa 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -244,7 +244,7 @@ fini: }
#if defined(CONFIG_CMD_ERASEENV) -static int env_mmc_erase(void) +static int env_mmc_erase(bool use_redund) { int dev = mmc_get_env_dev(); struct mmc *mmc = find_mmc_device(dev); @@ -253,7 +253,12 @@ static int env_mmc_erase(void) if (!mmc) return CMD_RET_FAILURE;
- blk = CONFIG_ENV_OFFSET / mmc->read_bl_len; +#ifdef CONFIG_ENV_OFFSET_REDUND + if (use_redund) + blk = CONFIG_ENV_OFFSET_REDUND / mmc->read_bl_len; + else +#endif + blk = CONFIG_ENV_OFFSET / mmc->read_bl_len; cnt = CONFIG_ENV_SIZE / mmc->read_bl_len;
printf("\nMMC erase env: dev # %d, block # %d (0x%x), count %d (0x%x)\n", diff --git a/include/environment.h b/include/environment.h index de67cf4f0e..a823948da2 100644 --- a/include/environment.h +++ b/include/environment.h @@ -233,7 +233,7 @@ struct env_driver { * * @return 0 if OK, -ve on error */ - int (*erase)(void); + int (*erase)(bool use_redund);
/** * init() - Set up the initial pre-relocation environment @@ -318,7 +318,7 @@ int env_save(void); * * @return 0 if OK, -ve on error */ -int env_erase(void); +int env_erase(bool use_redund);
/** * env_fix_drivers() - Updates envdriver as per relocation -- 2.17.1
erase also the redundant environment location if offset is defined
this is a possible implementation without adding additional parameter to env erase command
Signed-off-by: Frank Wunderlich frank-w@public-files.de --- cmd/nvedit.c | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/cmd/nvedit.c b/cmd/nvedit.c index 2071bcf443..f11972e8f1 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -766,8 +766,15 @@ U_BOOT_CMD( static int do_env_erase(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - return env_erase(false) ? 1 : 0; + int ret; + + ret = env_erase(false) ? 1 : 0; + #ifdef CONFIG_ENV_OFFSET_REDUND + ret = ret || (env_erase(true) ? 1 : 0); + #endif + return ret; } + U_BOOT_CMD( eraseenv, 1, 0, do_env_erase, "erase environment variables from persistent storage", -- 2.17.1
Just a friendly reminder.
Any comments on my patches?
Regards Frank
Am 28. April 2019 10:51:24 MESZ schrieb Frank Wunderlich frank-w@public-files.de:
changes since v3:
- fixes
-- 2.17.1
no opinion about the last version?
regards Frank
changes since v3:
- fixes
-- 2.17.1
regards Frank
changes since v3:
- fixes
Seems like a reasonable concept and I believe I looked it over and everything new is under a CONFIG guard, so, thanks!
Hi Frank,
Am 24.06.2019 um 12:30 schrieb Frank Wunderlich:
Sorry, I tried multiple times to review this but failed to find the time. Seems like I found the time now ;-)
I'll reply to the original patch mails.
regards Frank
changes since v3:
- fixes
-- 2.17.1
Frank Wunderlich
Simon Goldschmidt
