[PATCH v4 00/13] x86: cbfs: Various clean-ups to CBFS implementation
This code is very old and has not had much of a clean-up since it was written. This series aims to tidy it up to use error codes, avoid using BSS when not necessary and to add a few more features.
Changes in v4: - Stick with US spelling - Fix 'his' typo
Changes in v3: - Fix typo in commit message
Changes in v2: - Fix incorrect function comments - Fix s/u8/void/ in find_uncached() - Fix setting of start in file_cbfs_find_uncached() - Add more comments on @node in file_cbfs_find_uncached() - Use void * instead of u8 * in file_cbfs_find_uncached_base() - Fix and expand comments in file_cbfs_find_uncached_base() - Rebase to master (with x86/master cherry-picked in too) - Resending as some comments / reviews were missed
Simon Glass (13): cbfs: Rename the result variable cbfs: Use ulong consistently cbfs: Use bool type for whether initialised cbfs: Adjust return value of file_cbfs_next_file() cbfs: Adjust file_cbfs_load_header() to use cbfs_priv cbfs: Adjust cbfs_load_header_ptr() to use cbfs_priv cbfs: Unify the two header loaders cbfs: Use void * for the position pointers cbfs: Record the start address in cbfs_priv cbfs: Return the error code from file_cbfs_init() cbfs: Change file_cbfs_find_uncached() to return an error cbfs: Allow reading a file from a CBFS given its base addr cbfs: Don't require the CBFS size with cbfs_init_mem()
arch/x86/lib/fsp2/fsp_init.c | 3 +- cmd/cbfs.c | 3 +- fs/cbfs/cbfs.c | 240 ++++++++++++++++++++++------------- include/cbfs.h | 40 ++++-- 4 files changed, 182 insertions(+), 104 deletions(-)
At present the result variable in the cbfs_priv is called 'result' as is the local variable in a few functions. Change the latter to 'ret' which is more common in U-Boot and avoids confusion.
Reviewed-by: Bin Meng bmeng.cn@gmail.com Signed-off-by: Simon Glass sjg@chromium.org ---
Changes in v4: None Changes in v3: None Changes in v2: None
fs/cbfs/cbfs.c | 20 ++++++++++---------- 1 file changed, 10 insertions(+), 10 deletions(-)
diff --git a/fs/cbfs/cbfs.c b/fs/cbfs/cbfs.c index 1aa6f8ee84..70440aa80b 100644 --- a/fs/cbfs/cbfs.c +++ b/fs/cbfs/cbfs.c @@ -145,18 +145,18 @@ static void file_cbfs_fill_cache(struct cbfs_priv *priv, u8 *start, u32 size, priv->file_cache = NULL;
while (size >= align) { - int result; + int ret; u32 used;
new_node = (struct cbfs_cachenode *) malloc(sizeof(struct cbfs_cachenode)); - result = file_cbfs_next_file(priv, start, size, align, new_node, - &used); + ret = file_cbfs_next_file(priv, start, size, align, new_node, + &used);
- if (result < 0) { + if (ret < 0) { free(new_node); return; - } else if (result == 0) { + } else if (ret == 0) { free(new_node); break; } @@ -341,15 +341,15 @@ const struct cbfs_cachenode *file_cbfs_find_uncached(uintptr_t end_of_rom, align = priv->header.align;
- result = file_cbfs_next_file(priv, start, size, align, &node, - &used); + ret = file_cbfs_next_file(priv, start, size, align, &node, + &used);
- if (result < 0) + if (ret < 0) return NULL; - else if (result == 0) + else if (ret == 0) break;
if (!strcmp(name, node.name))
U-Boot uses ulong for addresses but there are a few places in this driver that don't use it. Convert this driver over to follow this convention fully.
fs/cbfs/cbfs.c | 9 ++++----- include/cbfs.h | 4 ++-- 2 files changed, 6 insertions(+), 7 deletions(-)
diff --git a/fs/cbfs/cbfs.c b/fs/cbfs/cbfs.c index 70440aa80b..846102dce3 100644 --- a/fs/cbfs/cbfs.c +++ b/fs/cbfs/cbfs.c @@ -170,8 +170,7 @@ static void file_cbfs_fill_cache(struct cbfs_priv *priv, u8 *start, u32 size, }
/* Get the CBFS header out of the ROM and do endian conversion. */ -static int file_cbfs_load_header(uintptr_t end_of_rom, - struct cbfs_header *header) +static int file_cbfs_load_header(ulong end_of_rom, struct cbfs_header *header) { struct cbfs_header *header_in_rom; int32_t offset = *(u32 *)(end_of_rom - 3); @@ -204,7 +203,7 @@ static int cbfs_load_header_ptr(struct cbfs_priv *priv, ulong base, return 0; }
-static void cbfs_init(struct cbfs_priv *priv, uintptr_t end_of_rom) +static void cbfs_init(struct cbfs_priv *priv, ulong end_of_rom) { u8 *start_of_rom;
@@ -221,7 +220,7 @@ static void cbfs_init(struct cbfs_priv *priv, uintptr_t end_of_rom) priv->initialized = 1; }
-void file_cbfs_init(uintptr_t end_of_rom) +void file_cbfs_init(ulong end_of_rom) { cbfs_init(&cbfs_s, end_of_rom); } @@ -324,7 +323,7 @@ const struct cbfs_cachenode *file_cbfs_find(const char *name) return cbfs_find_file(&cbfs_s, name); }
-const struct cbfs_cachenode *file_cbfs_find_uncached(uintptr_t end_of_rom, +const struct cbfs_cachenode *file_cbfs_find_uncached(ulong end_of_rom, const char *name) { struct cbfs_priv *priv = &cbfs_s; diff --git a/include/cbfs.h b/include/cbfs.h index d18001da76..07bbcfd2cf 100644 --- a/include/cbfs.h +++ b/include/cbfs.h @@ -101,7 +101,7 @@ enum cbfs_result cbfs_get_result(void); * @end_of_rom: Points to the end of the ROM the CBFS should be read * from. */ -void file_cbfs_init(uintptr_t end_of_rom); +void file_cbfs_init(ulong end_of_rom);
/** * file_cbfs_get_header() - Get the header structure for the current CBFS. @@ -170,7 +170,7 @@ int cbfs_init_mem(ulong base, ulong size, struct cbfs_priv **privp); * * @return A handle to the file, or NULL on error. */ -const struct cbfs_cachenode *file_cbfs_find_uncached(uintptr_t end_of_rom, +const struct cbfs_cachenode *file_cbfs_find_uncached(ulong end_of_rom, const char *name);
At present this uses an int type. U-Boot now supports bool so use this instead.
fs/cbfs/cbfs.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/fs/cbfs/cbfs.c b/fs/cbfs/cbfs.c index 846102dce3..91d7af0493 100644 --- a/fs/cbfs/cbfs.c +++ b/fs/cbfs/cbfs.c @@ -12,7 +12,7 @@ static const u32 good_magic = 0x4f524243; static const u8 good_file_magic[] = "LARCHIVE";
struct cbfs_priv { - int initialized; + bool initialized; struct cbfs_header header; struct cbfs_cachenode *file_cache; enum cbfs_result result; @@ -207,7 +207,7 @@ static void cbfs_init(struct cbfs_priv *priv, ulong end_of_rom) { u8 *start_of_rom;
- priv->initialized = 0; + priv->initialized = false;
if (file_cbfs_load_header(end_of_rom, &priv->header)) return; @@ -217,7 +217,7 @@ static void cbfs_init(struct cbfs_priv *priv, ulong end_of_rom) file_cbfs_fill_cache(priv, start_of_rom, priv->header.rom_size, priv->header.align); if (priv->result == CBFS_SUCCESS) - priv->initialized = 1; + priv->initialized = true; }
void file_cbfs_init(ulong end_of_rom) @@ -244,7 +244,7 @@ int cbfs_init_mem(ulong base, ulong size, struct cbfs_priv **privp) if (priv->result != CBFS_SUCCESS) return -EINVAL;
- priv->initialized = 1; + priv->initialized = true; priv = malloc(sizeof(priv_s)); if (!priv) return -ENOMEM;
Changes in v4:
At present this uses a true return to indicate it found a file. Adjust it to use 0 for this, so it is consistent with other functions.
Update its callers accordingly and add a check for malloc() failure in file_cbfs_fill_cache().
Changes in v4: - Fix 'his' typo
Changes in v2: None
fs/cbfs/cbfs.c | 43 +++++++++++++++++++++++-------------------- 1 file changed, 23 insertions(+), 20 deletions(-)
diff --git a/fs/cbfs/cbfs.c b/fs/cbfs/cbfs.c index 91d7af0493..c17f6d6250 100644 --- a/fs/cbfs/cbfs.c +++ b/fs/cbfs/cbfs.c @@ -77,11 +77,12 @@ static void swap_file_header(struct cbfs_fileheader *dest, * @param used A pointer to the count of of bytes scanned through, * including the file if one is found. * - * @return 1 if a file is found, 0 if one isn't. + * @return 0 if a file is found, -ENOENT if one isn't, -EBADF if a bad header + * is found. */ -static int file_cbfs_next_file(struct cbfs_priv *priv, u8 *start, u32 size, - u32 align, struct cbfs_cachenode *new_node, - u32 *used) +static int file_cbfs_next_file(struct cbfs_priv *priv, u8 *start, int size, + int align, struct cbfs_cachenode *new_node, + int *used) { struct cbfs_fileheader header;
@@ -105,7 +106,7 @@ static int file_cbfs_next_file(struct cbfs_priv *priv, u8 *start, u32 size, swap_file_header(&header, file_header); if (header.offset < sizeof(struct cbfs_fileheader)) { priv->result = CBFS_BAD_FILE; - return -1; + return -EBADF; } new_node->next = NULL; new_node->type = header.type; @@ -122,14 +123,15 @@ static int file_cbfs_next_file(struct cbfs_priv *priv, u8 *start, u32 size, step = step + align - step % align;
*used += step; - return 1; + return 0; } - return 0; + + return -ENOENT; }
/* Look through a CBFS instance and copy file metadata into regular memory. */ -static void file_cbfs_fill_cache(struct cbfs_priv *priv, u8 *start, u32 size, - u32 align) +static int file_cbfs_fill_cache(struct cbfs_priv *priv, u8 *start, u32 size, + u32 align) { struct cbfs_cachenode *cache_node; struct cbfs_cachenode *new_node; @@ -145,20 +147,21 @@ static void file_cbfs_fill_cache(struct cbfs_priv *priv, u8 *start, u32 size, priv->file_cache = NULL;
while (size >= align) { + int used; int ret; - u32 used;
new_node = (struct cbfs_cachenode *) malloc(sizeof(struct cbfs_cachenode)); + if (!new_node) + return -ENOMEM; ret = file_cbfs_next_file(priv, start, size, align, new_node, &used);
if (ret < 0) { free(new_node); - return; - } else if (ret == 0) { - free(new_node); - break; + if (ret == -ENOENT) + break; + return ret; } *cache_tail = new_node; cache_tail = &new_node->next; @@ -167,6 +170,8 @@ static void file_cbfs_fill_cache(struct cbfs_priv *priv, u8 *start, u32 size, start += used; } priv->result = CBFS_SUCCESS; + + return 0; }
/* Get the CBFS header out of the ROM and do endian conversion. */ @@ -341,16 +346,14 @@ const struct cbfs_cachenode *file_cbfs_find_uncached(ulong end_of_rom,
while (size >= align) { int ret; - u32 used; + int used;
ret = file_cbfs_next_file(priv, start, size, align, &node, &used); - - if (ret < 0) - return NULL; - else if (ret == 0) + if (ret == -ENOENT) break; - + else if (ret) + return NULL; if (!strcmp(name, node.name)) return &node;
This function is strange at the moment in that it takes a header pointer but then accesses the cbfs_s global. Currently clients have their own priv pointer, so update the function to take that as a parameter instead.
fs/cbfs/cbfs.c | 9 +++++---- 1 file changed, 5 insertions(+), 4 deletions(-)
diff --git a/fs/cbfs/cbfs.c b/fs/cbfs/cbfs.c index c17f6d6250..c08fcb14a5 100644 --- a/fs/cbfs/cbfs.c +++ b/fs/cbfs/cbfs.c @@ -175,8 +175,9 @@ static int file_cbfs_fill_cache(struct cbfs_priv *priv, u8 *start, u32 size, }
/* Get the CBFS header out of the ROM and do endian conversion. */ -static int file_cbfs_load_header(ulong end_of_rom, struct cbfs_header *header) +static int file_cbfs_load_header(struct cbfs_priv *priv, ulong end_of_rom) { + struct cbfs_header *header = &priv->header; struct cbfs_header *header_in_rom; int32_t offset = *(u32 *)(end_of_rom - 3);
@@ -185,7 +186,7 @@ static int file_cbfs_load_header(ulong end_of_rom, struct cbfs_header *header)
if (header->magic != good_magic || header->offset > header->rom_size - header->boot_block_size) { - cbfs_s.result = CBFS_BAD_HEADER; + priv->result = CBFS_BAD_HEADER; return 1; } return 0; @@ -214,7 +215,7 @@ static void cbfs_init(struct cbfs_priv *priv, ulong end_of_rom)
- if (file_cbfs_load_header(end_of_rom, &priv->header)) + if (file_cbfs_load_header(priv, end_of_rom)) return;
start_of_rom = (u8 *)(end_of_rom + 1 - priv->header.rom_size); @@ -337,7 +338,7 @@ const struct cbfs_cachenode *file_cbfs_find_uncached(ulong end_of_rom, u32 align; static struct cbfs_cachenode node;
- if (file_cbfs_load_header(end_of_rom, &priv->header)) + if (file_cbfs_load_header(priv, end_of_rom)) return NULL;
start = (u8 *)(end_of_rom + 1 - priv->header.rom_size);
fs/cbfs/cbfs.c | 9 ++++++--- 1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/fs/cbfs/cbfs.c b/fs/cbfs/cbfs.c index c08fcb14a5..f3fcdab1a7 100644 --- a/fs/cbfs/cbfs.c +++ b/fs/cbfs/cbfs.c @@ -8,6 +8,9 @@ #include <malloc.h> #include <asm/byteorder.h>
+/* Offset of master header from the start of a coreboot ROM */ +#define MASTER_HDR_OFFSET 0x38 + static const u32 good_magic = 0x4f524243; static const u8 good_file_magic[] = "LARCHIVE";
@@ -192,9 +195,9 @@ static int file_cbfs_load_header(struct cbfs_priv *priv, ulong end_of_rom) return 0; }
-static int cbfs_load_header_ptr(struct cbfs_priv *priv, ulong base, - struct cbfs_header *header) +static int cbfs_load_header_ptr(struct cbfs_priv *priv, ulong base) { + struct cbfs_header *header = &priv->header; struct cbfs_header *header_in_rom;
header_in_rom = (struct cbfs_header *)base; @@ -241,7 +244,7 @@ int cbfs_init_mem(ulong base, ulong size, struct cbfs_priv **privp) * valid. Assume that a master header appears at the start, at offset * 0x38. */ - ret = cbfs_load_header_ptr(priv, base + 0x38, &priv->header); + ret = cbfs_load_header_ptr(priv, base + MASTER_HDR_OFFSET); if (ret) return ret;
These two functions have mostly the same code. Pull this out into a common function.
Also make this function zero the private data so that callers don't have to do it. Finally, update cbfs_load_header_ptr() to take the base of the ROM as its parameter, which makes more sense than passing the address of the header within the ROM.
Changes in v4: None Changes in v3: None Changes in v2: - Fix incorrect function comments
fs/cbfs/cbfs.c | 59 +++++++++++++++++++++++++++++++------------------- 1 file changed, 37 insertions(+), 22 deletions(-)
diff --git a/fs/cbfs/cbfs.c b/fs/cbfs/cbfs.c index f3fcdab1a7..a42c3a51d5 100644 --- a/fs/cbfs/cbfs.c +++ b/fs/cbfs/cbfs.c @@ -177,47 +177,63 @@ static int file_cbfs_fill_cache(struct cbfs_priv *priv, u8 *start, u32 size, return 0; }
-/* Get the CBFS header out of the ROM and do endian conversion. */ -static int file_cbfs_load_header(struct cbfs_priv *priv, ulong end_of_rom) +/** + * load_header() - Load the CBFS header + * + * Get the CBFS header out of the ROM and do endian conversion. + * + * @priv: Private data, which is inited by this function + * @addr: Address of CBFS header in memory-mapped SPI flash + * @return 0 if OK, -ENXIO if the header is bad + */ +static int load_header(struct cbfs_priv *priv, ulong addr) { struct cbfs_header *header = &priv->header; struct cbfs_header *header_in_rom; - int32_t offset = *(u32 *)(end_of_rom - 3);
- header_in_rom = (struct cbfs_header *)(end_of_rom + offset + 1); + memset(priv, '\0', sizeof(*priv)); + header_in_rom = (struct cbfs_header *)addr; swap_header(header, header_in_rom);
if (header->magic != good_magic || header->offset > header->rom_size - header->boot_block_size) { priv->result = CBFS_BAD_HEADER; - return 1; + return -ENXIO; } + return 0; }
-static int cbfs_load_header_ptr(struct cbfs_priv *priv, ulong base) +/** + * file_cbfs_load_header() - Get the CBFS header out of the ROM, given the end + * + * @priv: Private data, which is inited by this function + * @end_of_rom: Address of the last byte of the ROM (typically 0xffffffff) + * @return 0 if OK, -ENXIO if the header is bad + */ +static int file_cbfs_load_header(struct cbfs_priv *priv, ulong end_of_rom) { - struct cbfs_header *header = &priv->header; - struct cbfs_header *header_in_rom; - - header_in_rom = (struct cbfs_header *)base; - swap_header(header, header_in_rom); + int offset = *(u32 *)(end_of_rom - 3);
- if (header->magic != good_magic || header->offset > - header->rom_size - header->boot_block_size) { - priv->result = CBFS_BAD_HEADER; - return -EFAULT; - } + return load_header(priv, end_of_rom + offset + 1); +}
- return 0; +/** + * cbfs_load_header_ptr() - Get the CBFS header out of the ROM, given the base + * + * @priv: Private data, which is inited by this function + * @base: Address of the first byte of the ROM (e.g. 0xff000000) + * @return 0 if OK, -ENXIO if the header is bad + */ +static int cbfs_load_header_ptr(struct cbfs_priv *priv, ulong base) +{ + return load_header(priv, base + MASTER_HDR_OFFSET); }
- priv->initialized = false; - if (file_cbfs_load_header(priv, end_of_rom)) return;
@@ -241,10 +257,9 @@ int cbfs_init_mem(ulong base, ulong size, struct cbfs_priv **privp)
/* * Use a local variable to start with until we know that the CBFS is - * valid. Assume that a master header appears at the start, at offset - * 0x38. + * valid. */ - ret = cbfs_load_header_ptr(priv, base + MASTER_HDR_OFFSET); + ret = cbfs_load_header_ptr(priv, base); if (ret) return ret;
It doesn't make sense to use u8 * as the pointer type for accessing the CBFS since we do not access it as bytes, but via structures. Change it to void *, which allows us to avoid a cast.
fs/cbfs/cbfs.c | 17 ++++++++--------- 1 file changed, 8 insertions(+), 9 deletions(-)
diff --git a/fs/cbfs/cbfs.c b/fs/cbfs/cbfs.c index a42c3a51d5..40198ae7e7 100644 --- a/fs/cbfs/cbfs.c +++ b/fs/cbfs/cbfs.c @@ -83,7 +83,7 @@ static void swap_file_header(struct cbfs_fileheader *dest, * @return 0 if a file is found, -ENOENT if one isn't, -EBADF if a bad header * is found. */ -static int file_cbfs_next_file(struct cbfs_priv *priv, u8 *start, int size, +static int file_cbfs_next_file(struct cbfs_priv *priv, void *start, int size, int align, struct cbfs_cachenode *new_node, int *used) { @@ -92,8 +92,7 @@ static int file_cbfs_next_file(struct cbfs_priv *priv, u8 *start, int size, *used = 0;
while (size >= align) { - const struct cbfs_fileheader *file_header = - (const struct cbfs_fileheader *)start; + const struct cbfs_fileheader *file_header = start; u32 name_len; u32 step;
@@ -133,7 +132,7 @@ static int file_cbfs_next_file(struct cbfs_priv *priv, u8 *start, int size, }
/* Look through a CBFS instance and copy file metadata into regular memory. */ -static int file_cbfs_fill_cache(struct cbfs_priv *priv, u8 *start, u32 size, +static int file_cbfs_fill_cache(struct cbfs_priv *priv, void *start, u32 size, u32 align) { struct cbfs_cachenode *cache_node; @@ -232,12 +231,12 @@ static int cbfs_load_header_ptr(struct cbfs_priv *priv, ulong base)
static void cbfs_init(struct cbfs_priv *priv, ulong end_of_rom) { - u8 *start_of_rom; + void *start_of_rom;
- start_of_rom = (u8 *)(end_of_rom + 1 - priv->header.rom_size); + start_of_rom = (void *)(end_of_rom + 1 - priv->header.rom_size);
file_cbfs_fill_cache(priv, start_of_rom, priv->header.rom_size, priv->header.align); @@ -263,7 +262,7 @@ int cbfs_init_mem(ulong base, ulong size, struct cbfs_priv **privp) if (ret) return ret;
- file_cbfs_fill_cache(priv, (u8 *)base, priv->header.rom_size, + file_cbfs_fill_cache(priv, (void *)base, priv->header.rom_size, priv->header.align); if (priv->result != CBFS_SUCCESS) return -EINVAL; @@ -351,7 +350,7 @@ const struct cbfs_cachenode *file_cbfs_find_uncached(ulong end_of_rom, const char *name) { struct cbfs_priv *priv = &cbfs_s; - u8 *start; + void *start; u32 size; u32 align; static struct cbfs_cachenode node; @@ -359,7 +358,7 @@ const struct cbfs_cachenode *file_cbfs_find_uncached(ulong end_of_rom, if (file_cbfs_load_header(priv, end_of_rom)) return NULL;
- start = (u8 *)(end_of_rom + 1 - priv->header.rom_size); + start = (void *)(end_of_rom + 1 - priv->header.rom_size); size = priv->header.rom_size; align = priv->header.align;
The start address of the CBFS is used when scanning for files. It makes sense to put this in our cbfs_priv struct and calculate it when we read the header.
Update the code accordingly.
fs/cbfs/cbfs.c | 44 +++++++++++++++++++++++++++++++------------- 1 file changed, 31 insertions(+), 13 deletions(-)
diff --git a/fs/cbfs/cbfs.c b/fs/cbfs/cbfs.c index 40198ae7e7..dc9789fcb8 100644 --- a/fs/cbfs/cbfs.c +++ b/fs/cbfs/cbfs.c @@ -14,8 +14,18 @@ static const u32 good_magic = 0x4f524243; static const u8 good_file_magic[] = "LARCHIVE";
+/** + * struct cbfs_priv - Private data for this driver + * + * @initialised: true if this CBFS has been inited + * @start: Start position of CBFS in memory, typically memory-mapped SPI flash + * @header: Header read from the CBFS, byte-swapped so U-Boot can access it + * @file_cache: List of file headers read from CBFS + * @result: Success/error result + */ struct cbfs_priv { bool initialized; + void *start; struct cbfs_header header; struct cbfs_cachenode *file_cache; enum cbfs_result result; @@ -132,12 +142,12 @@ static int file_cbfs_next_file(struct cbfs_priv *priv, void *start, int size, }
/* Look through a CBFS instance and copy file metadata into regular memory. */ -static int file_cbfs_fill_cache(struct cbfs_priv *priv, void *start, u32 size, - u32 align) +static int file_cbfs_fill_cache(struct cbfs_priv *priv, int size, int align) { struct cbfs_cachenode *cache_node; struct cbfs_cachenode *new_node; struct cbfs_cachenode **cache_tail = &priv->file_cache; + void *start;
/* Clear out old information. */ cache_node = priv->file_cache; @@ -148,6 +158,7 @@ static int file_cbfs_fill_cache(struct cbfs_priv *priv, void *start, u32 size, } priv->file_cache = NULL;
+ start = priv->start; while (size >= align) { int used; int ret; @@ -213,8 +224,14 @@ static int load_header(struct cbfs_priv *priv, ulong addr) static int file_cbfs_load_header(struct cbfs_priv *priv, ulong end_of_rom) { int offset = *(u32 *)(end_of_rom - 3); + int ret; + + ret = load_header(priv, end_of_rom + offset + 1); + if (ret) + return ret; + priv->start = (void *)(end_of_rom + 1 - priv->header.rom_size);
- return load_header(priv, end_of_rom + offset + 1); + return 0; }
/** @@ -226,20 +243,22 @@ static int file_cbfs_load_header(struct cbfs_priv *priv, ulong end_of_rom) */ static int cbfs_load_header_ptr(struct cbfs_priv *priv, ulong base) { - return load_header(priv, base + MASTER_HDR_OFFSET); + int ret; + + ret = load_header(priv, base + MASTER_HDR_OFFSET); + if (ret) + return ret; + priv->start = (void *)base; + + return 0; }
static void cbfs_init(struct cbfs_priv *priv, ulong end_of_rom) { - void *start_of_rom; - if (file_cbfs_load_header(priv, end_of_rom)) return;
- start_of_rom = (void *)(end_of_rom + 1 - priv->header.rom_size); - - file_cbfs_fill_cache(priv, start_of_rom, priv->header.rom_size, - priv->header.align); + file_cbfs_fill_cache(priv, priv->header.rom_size, priv->header.align); if (priv->result == CBFS_SUCCESS) priv->initialized = true; } @@ -262,8 +281,7 @@ int cbfs_init_mem(ulong base, ulong size, struct cbfs_priv **privp) if (ret) return ret;
- file_cbfs_fill_cache(priv, (void *)base, priv->header.rom_size, - priv->header.align); + file_cbfs_fill_cache(priv, priv->header.rom_size, priv->header.align); if (priv->result != CBFS_SUCCESS) return -EINVAL;
@@ -358,7 +376,7 @@ const struct cbfs_cachenode *file_cbfs_find_uncached(ulong end_of_rom, if (file_cbfs_load_header(priv, end_of_rom)) return NULL;
- start = (void *)(end_of_rom + 1 - priv->header.rom_size); + start = priv->start; size = priv->header.rom_size; align = priv->header.align;
We may as well return the error code and use it directly in the command code. CBFS still uses its own error enum which we may be able to remove, but leave it for now.
cmd/cbfs.c | 3 +-- fs/cbfs/cbfs.c | 23 +++++++++++++++-------- include/cbfs.h | 6 +++--- 3 files changed, 19 insertions(+), 13 deletions(-)
diff --git a/cmd/cbfs.c b/cmd/cbfs.c index 8e91d4bb8c..10c2c929c3 100644 --- a/cmd/cbfs.c +++ b/cmd/cbfs.c @@ -28,8 +28,7 @@ static int do_cbfs_init(struct cmd_tbl *cmdtp, int flag, int argc, return 1; } } - file_cbfs_init(end_of_rom); - if (cbfs_get_result() != CBFS_SUCCESS) { + if (file_cbfs_init(end_of_rom)) { printf("%s.\n", file_cbfs_error()); return 1; } diff --git a/fs/cbfs/cbfs.c b/fs/cbfs/cbfs.c index dc9789fcb8..73fe3b3624 100644 --- a/fs/cbfs/cbfs.c +++ b/fs/cbfs/cbfs.c @@ -253,19 +253,26 @@ static int cbfs_load_header_ptr(struct cbfs_priv *priv, ulong base) return 0; }
-static void cbfs_init(struct cbfs_priv *priv, ulong end_of_rom) +static int cbfs_init(struct cbfs_priv *priv, ulong end_of_rom) { - if (file_cbfs_load_header(priv, end_of_rom)) - return; + int ret;
- file_cbfs_fill_cache(priv, priv->header.rom_size, priv->header.align); - if (priv->result == CBFS_SUCCESS) - priv->initialized = true; + ret = file_cbfs_load_header(priv, end_of_rom); + if (ret) + return ret; + + ret = file_cbfs_fill_cache(priv, priv->header.rom_size, + priv->header.align); + if (ret) + return ret; + priv->initialized = true; + + return 0; }
-void file_cbfs_init(ulong end_of_rom) +int file_cbfs_init(ulong end_of_rom) { - cbfs_init(&cbfs_s, end_of_rom); + return cbfs_init(&cbfs_s, end_of_rom); }
int cbfs_init_mem(ulong base, ulong size, struct cbfs_priv **privp) diff --git a/include/cbfs.h b/include/cbfs.h index 07bbcfd2cf..962b3e848b 100644 --- a/include/cbfs.h +++ b/include/cbfs.h @@ -98,10 +98,10 @@ enum cbfs_result cbfs_get_result(void); /** * file_cbfs_init() - Initialize the CBFS driver and load metadata into RAM. * - * @end_of_rom: Points to the end of the ROM the CBFS should be read - * from. + * @end_of_rom: Points to the end of the ROM the CBFS should be read from + * @return 0 if OK, -ve on error */ -void file_cbfs_init(ulong end_of_rom); +int file_cbfs_init(ulong end_of_rom);
This function currently returns a node pointer so there is no way to know the error code. Also it uses data in BSS which seems unnecessary since the caller might prefer to use a local variable.
Update the function and split its body out into a separate function so we can use it later.
Changes in v4: None Changes in v3: None Changes in v2: - Fix s/u8/void/ in find_uncached() - Fix setting of start in file_cbfs_find_uncached() - Add more comments on @node in file_cbfs_find_uncached()
fs/cbfs/cbfs.c | 48 +++++++++++++++++++++++++++--------------------- include/cbfs.h | 17 +++++++++-------- 2 files changed, 36 insertions(+), 29 deletions(-)
diff --git a/fs/cbfs/cbfs.c b/fs/cbfs/cbfs.c index 73fe3b3624..ba903d16a0 100644 --- a/fs/cbfs/cbfs.c +++ b/fs/cbfs/cbfs.c @@ -371,40 +371,46 @@ const struct cbfs_cachenode *file_cbfs_find(const char *name) return cbfs_find_file(&cbfs_s, name); }
-const struct cbfs_cachenode *file_cbfs_find_uncached(ulong end_of_rom, - const char *name) +static int find_uncached(struct cbfs_priv *priv, const char *name, void *start, + struct cbfs_cachenode *node) { - struct cbfs_priv *priv = &cbfs_s; - void *start; - u32 size; - u32 align; - static struct cbfs_cachenode node; - - if (file_cbfs_load_header(priv, end_of_rom)) - return NULL; - - start = priv->start; - size = priv->header.rom_size; - align = priv->header.align; + int size = priv->header.rom_size; + int align = priv->header.align;
while (size >= align) { - int ret; int used; + int ret;
- ret = file_cbfs_next_file(priv, start, size, align, &node, + ret = file_cbfs_next_file(priv, start, size, align, node, &used); if (ret == -ENOENT) break; else if (ret) - return NULL; - if (!strcmp(name, node.name)) - return &node; + return ret; + if (!strcmp(name, node->name)) + return 0;
size -= used; start += used; } - cbfs_s.result = CBFS_FILE_NOT_FOUND; - return NULL; + priv->result = CBFS_FILE_NOT_FOUND; + + return -ENOENT; +} + +int file_cbfs_find_uncached(ulong end_of_rom, const char *name, + struct cbfs_cachenode *node) +{ + struct cbfs_priv priv; + void *start; + int ret; + + ret = file_cbfs_load_header(&priv, end_of_rom); + if (ret) + return ret; + start = priv.start; + + return find_uncached(&priv, name, start, node); }
const char *file_cbfs_name(const struct cbfs_cachenode *file) diff --git a/include/cbfs.h b/include/cbfs.h index 962b3e848b..5a248781c3 100644 --- a/include/cbfs.h +++ b/include/cbfs.h @@ -161,17 +161,18 @@ int cbfs_init_mem(ulong base, ulong size, struct cbfs_priv **privp); /***************************************************************************/
/** - * file_cbfs_find_uncached() - Find a file with a particular name in CBFS - * without using the heap. + * file_cbfs_find_uncached() - Find a file in CBFS given the end of the ROM * - * @end_of_rom: Points to the end of the ROM the CBFS should be read - * from. - * @name: The name to search for. + * Note that @node should be declared by the caller. This design is to avoid + * the need for allocation here. * - * @return A handle to the file, or NULL on error. + * @end_of_rom: Points to the end of the ROM the CBFS should be read from + * @name: The name to search for + * @node: Returns the contents of the node if found (i.e. copied into *node) + * @return 0 on success, -ENOENT if not found, -EFAULT on bad header */ -const struct cbfs_cachenode *file_cbfs_find_uncached(ulong end_of_rom, - const char *name); +int file_cbfs_find_uncached(ulong end_of_rom, const char *name, + struct cbfs_cachenode *node);
/** * file_cbfs_name() - Get the name of a file in CBFS.
Currently we support reading a file from CBFS given the address of the end of the ROM. Sometimes we only know the start of the CBFS. Add a function to find a file given that.
Changes in v4: None Changes in v3: None Changes in v2: - Use void * instead of u8 * in file_cbfs_find_uncached_base() - Fix and expand comments in file_cbfs_find_uncached_base()
fs/cbfs/cbfs.c | 13 +++++++++++++ include/cbfs.h | 14 ++++++++++++++ 2 files changed, 27 insertions(+)
diff --git a/fs/cbfs/cbfs.c b/fs/cbfs/cbfs.c index ba903d16a0..d3c3722c48 100644 --- a/fs/cbfs/cbfs.c +++ b/fs/cbfs/cbfs.c @@ -413,6 +413,19 @@ int file_cbfs_find_uncached(ulong end_of_rom, const char *name, return find_uncached(&priv, name, start, node); }
+int file_cbfs_find_uncached_base(ulong base, const char *name, + struct cbfs_cachenode *node) +{ + struct cbfs_priv priv; + int ret; + + ret = cbfs_load_header_ptr(&priv, base); + if (ret) + return ret; + + return find_uncached(&priv, name, (void *)base, node); +} + const char *file_cbfs_name(const struct cbfs_cachenode *file) { cbfs_s.result = CBFS_SUCCESS; diff --git a/include/cbfs.h b/include/cbfs.h index 5a248781c3..1aff110acb 100644 --- a/include/cbfs.h +++ b/include/cbfs.h @@ -174,6 +174,20 @@ int cbfs_init_mem(ulong base, ulong size, struct cbfs_priv **privp); int file_cbfs_find_uncached(ulong end_of_rom, const char *name, struct cbfs_cachenode *node);
+/** + * file_cbfs_find_uncached_base() - Find a file in CBFS given the base address + * + * Note that @node should be declared by the caller. This design is to avoid + * the need for allocation here. + * + * @base: Points to the base of the CBFS + * @name: The name to search for + * @node: Returns the contents of the node if found (i.e. copied into *node) + * @return 0 on success, -ENOENT if not found, -EFAULT on bad header + */ +int file_cbfs_find_uncached_base(ulong base, const char *name, + struct cbfs_cachenode *node); + /** * file_cbfs_name() - Get the name of a file in CBFS. *
The size is not actually used since it is present in the header. Drop this parameter. Also tidy up error handling while we are here.
Changes in v4: None Changes in v3: None Changes in v2: - Rebase to master (with x86/master cherry-picked in too) - Resending as some comments / reviews were missed
arch/x86/lib/fsp2/fsp_init.c | 3 +-- fs/cbfs/cbfs.c | 10 ++++++---- include/cbfs.h | 3 +-- 3 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/arch/x86/lib/fsp2/fsp_init.c b/arch/x86/lib/fsp2/fsp_init.c index 8c577902b2..85cae54a0c 100644 --- a/arch/x86/lib/fsp2/fsp_init.c +++ b/arch/x86/lib/fsp2/fsp_init.c @@ -81,11 +81,10 @@ static int get_cbfs_fsp(enum fsp_type_t type, ulong map_base, * 'COREBOOT' (CBFS, size 1814528, offset 2117632). */ ulong cbfs_base = 0x205000; - ulong cbfs_size = 0x1bb000; struct cbfs_priv *cbfs; int ret;
- ret = cbfs_init_mem(map_base + cbfs_base, cbfs_size, &cbfs); + ret = cbfs_init_mem(map_base + cbfs_base, &cbfs); if (ret) return ret; if (!ret) { diff --git a/fs/cbfs/cbfs.c b/fs/cbfs/cbfs.c index d3c3722c48..9007aa7d15 100644 --- a/fs/cbfs/cbfs.c +++ b/fs/cbfs/cbfs.c @@ -5,6 +5,7 @@
#include <common.h> #include <cbfs.h> +#include <log.h> #include <malloc.h> #include <asm/byteorder.h>
@@ -275,7 +276,7 @@ int file_cbfs_init(ulong end_of_rom) return cbfs_init(&cbfs_s, end_of_rom); }
-int cbfs_init_mem(ulong base, ulong size, struct cbfs_priv **privp) +int cbfs_init_mem(ulong base, struct cbfs_priv **privp) { struct cbfs_priv priv_s, *priv = &priv_s; int ret; @@ -288,9 +289,10 @@ int cbfs_init_mem(ulong base, ulong size, struct cbfs_priv **privp) if (ret) return ret;
- file_cbfs_fill_cache(priv, priv->header.rom_size, priv->header.align); - if (priv->result != CBFS_SUCCESS) - return -EINVAL; + ret = file_cbfs_fill_cache(priv, priv->header.rom_size, + priv->header.align); + if (ret) + return log_msg_ret("fill", ret);
priv->initialized = true; priv = malloc(sizeof(priv_s)); diff --git a/include/cbfs.h b/include/cbfs.h index 1aff110acb..5f296d6a37 100644 --- a/include/cbfs.h +++ b/include/cbfs.h @@ -149,11 +149,10 @@ const struct cbfs_cachenode *cbfs_find_file(struct cbfs_priv *cbfs, * cbfs_init_mem() - Set up a new CBFS * * @base: Base address of CBFS - * @size: Size of CBFS in bytes * @cbfsp: Returns a pointer to CBFS on success * @return 0 if OK, -ve on error */ -int cbfs_init_mem(ulong base, ulong size, struct cbfs_priv **privp); +int cbfs_init_mem(ulong base, struct cbfs_priv **privp);
Changes in v4:
- Fix 'his' typo
series applied to u-boot-x86, thanks!
Hi Simon,
Changes in v4:
- Fix 'his' typo
It looks there are build errors for sandbox/x86: https://dev.azure.com/bmeng/GitHub/_build/results?buildId=229&view=logs&...
Could you please take a look?
Regards, Bin
Bin Meng
