[PATCH v2 0/2] doc: event: document all events
Document all events and add event.h to the HTML documentation.
Heinrich Schuchardt (2): dm: event: document all events doc: add events.h to documentation
doc/api/event.rst | 9 +++++ doc/api/index.rst | 1 + include/event.h | 97 ++++++++++++++++++++++++++++++++++++++++++++--- 3 files changed, 101 insertions(+), 6 deletions(-) create mode 100644 doc/api/event.rst
Provide Sphinx documentation for all events.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- v2: remove non-printing comments from num event_t correct texts according to Simon's suggestions --- include/event.h | 97 ++++++++++++++++++++++++++++++++++++++++++++++--- 1 file changed, 91 insertions(+), 6 deletions(-)
diff --git a/include/event.h b/include/event.h index bb38ba98e7..f5c5d30a64 100644 --- a/include/event.h +++ b/include/event.h @@ -19,29 +19,114 @@ * @EVT_DM_PRE_PROBE: Device is about to be probed */ enum event_t { - EVT_NONE, + /** + * @EVT_NONE: This zero value is not used for events. + */ + EVT_NONE = 0, + + /** + * @EVT_TEST: This event is used in unit tests. + */ EVT_TEST,
- /* Events related to driver model */ + /** + * @EVT_DM_POST_INIT_F: + * This event is triggered after pre-relocation initialization of the + * driver model. Its parameter is NULL. + * A non-zero return code from the event handler let's the boot process + * fail. + */ EVT_DM_POST_INIT_F, + + /** + * @EVT_DM_POST_INIT_R: + * This event is triggered after post-relocation initialization of the + * driver model. Its parameter is NULL. + * A non-zero return code from the event handler let's the boot process + * fail. + */ EVT_DM_POST_INIT_R, + + /** + * @EVT_DM_PRE_PROBE: + * This event is triggered before probing a device. Its parameter is the + * device to be probed. + * A non-zero return code from the event handler lets the device not + * being probed. + */ EVT_DM_PRE_PROBE, + + /** + * @EVT_DM_POST_PROBE: + * This event is triggered after probing a device. Its parameter is the + * device that was probed. + * A non-zero return code from the event handler leaves the device in + * the unprobed state and therefore not usable. + */ EVT_DM_POST_PROBE, + + /** + * @EVT_DM_PRE_REMOVE: + * This event is triggered after removing a device. Its parameter is + * the device to be removed. + * A non-zero return code from the event handler stops the removal of + * the device before any changes. + */ EVT_DM_PRE_REMOVE, + + /** + * @EVT_DM_POST_REMOVE: + * This event is triggered before removing a device. Its parameter is + * the device that was removed. + * A non-zero return code stops from the event handler the removal of + * the device after all removal changes. The previous state is not + * restored. All children will be gone and the device may not be + * functional. + */ EVT_DM_POST_REMOVE,
- /* Init hooks */ + /** + * @EVT_MISC_INIT_F: + * This event is triggered during the initialization sequence before + * relocation. Its parameter is NULL. + * A non-zero return code from the event handler let's the boot process + * fail. + */ EVT_MISC_INIT_F,
- /* Fpga load hook */ + /** + * @EVT_FPGA_LOAD: + * The FPGA load hook is called after loading an FPGA with a new binary. + * Its parameter is of type struct event_fpga_load and contains + * information about the loaded image. + */ EVT_FPGA_LOAD,
- /* Device tree fixups before booting */ + /** + * @EVT_FT_FIXUP: + * This event is triggered during device-tree fix up after all + * other device-tree fixups have been executed. + * Its parameter is of type struct event_ft_fixup which contains + * the address of the device-tree to fix up and the list of images to be + * booted. + * A non-zero return code from the event handler let's booting the + * images fail. + */ EVT_FT_FIXUP,
- /* To be called once, before calling main_loop() */ + /** + * @EVT_MAIN_LOOP: + * This event is triggered immediately before calling main_loop() which + * is the entry point of the command line. Its parameter is NULL. + * A non-zero return value causes the boot to fail. + */ EVT_MAIN_LOOP,
+ /** + * @EVT_COUNT: + * This constants holds the maximum event number + 1 and is used when + * looping over all event classes. + */ EVT_COUNT };
On Mon, 28 Aug 2023 at 13:12, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Thanks!
Add the events.h include to the API documentation.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com Reviewed-by: Simon Glass sjg@chromium.org --- v2: no change --- doc/api/event.rst | 9 +++++++++ doc/api/index.rst | 1 + 2 files changed, 10 insertions(+) create mode 100644 doc/api/event.rst
diff --git a/doc/api/event.rst b/doc/api/event.rst new file mode 100644 index 0000000000..8a57d43832 --- /dev/null +++ b/doc/api/event.rst @@ -0,0 +1,9 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Events +====== + +The concept of events is decribed :doc:`here <../develop/event>`. + +.. kernel-doc:: include/event.h + :internal: diff --git a/doc/api/index.rst b/doc/api/index.rst index 3a80ae0635..2f0218c47a 100644 --- a/doc/api/index.rst +++ b/doc/api/index.rst @@ -10,6 +10,7 @@ U-Boot API documentation dfu dm efi + event getopt linker_lists lmb
