[U-Boot] [PATCH RESEND] gpio: spear_gpio: Fix gpio_set_value() implementation
In current gpio_set_value() implementation, it always sets the gpio control bit no matter the value argument is 0 or 1. Thus the GPIOs never set to low. This patch fixes this bug.
Signed-off-by: Axel Lin axel.lin@ingics.com Acked-by: Stefan Roese sr@denx.de Reviewed-by: Vipin Kumar vipin.kumar@st.com --- This patch was sent on http://lists.denx.de/pipermail/u-boot/2013-June/156861.html
Has Stefan's Ack: http://lists.denx.de/pipermail/u-boot/2013-June/156864.html
Vipin says the code is fine, so I add Vipin's review-by. http://lists.denx.de/pipermail/u-boot/2013-June/156966.html
Michael confirms it works: http://lists.denx.de/pipermail/u-boot/2013-August/160652.html
No body picks up this patch, so here is a resend. Although I think this is a bug fix, but I'll let maintainers to determinate if this is the material for v2013.10. Anyway, can someone at least let me know if this patch is ok for apply at some point? I have no idea who is maintaining this file.
Regards, Axel
drivers/gpio/spear_gpio.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/gpio/spear_gpio.c b/drivers/gpio/spear_gpio.c index 367b670..6fb4117 100644 --- a/drivers/gpio/spear_gpio.c +++ b/drivers/gpio/spear_gpio.c @@ -36,7 +36,10 @@ int gpio_set_value(unsigned gpio, int value) { struct gpio_regs *regs = (struct gpio_regs *)CONFIG_GPIO_BASE;
- writel(1 << gpio, ®s->gpiodata[DATA_REG_ADDR(gpio)]); + if (value) + writel(1 << gpio, ®s->gpiodata[DATA_REG_ADDR(gpio)]); + else + writel(0, ®s->gpiodata[DATA_REG_ADDR(gpio)]);
return 0; }
Hi Axel,
Regards, Axel
if (value)
else
Despite discussions in the previous thread and the confirmations that this code is functionally equivalent to the Linux code, I still believe this code is incorrect for both writing and reading.
From the doc, writing to GPIODATA will obviously copy each of bits 7 to 0 of the written value into the actuals GPIO mapped to bits 7 to 0 of this register (assuming they are configured as outputs, of course). Based on this, the code above:
- when setting a single GPIO, sets *but clears up to seven other GPIOs*; - when clearing a single GPIO, clears it *and up to seven other GPIOs*.
This code may have been tested only for a single active GPIO at a time, for which this code would behave correctly; but as soon as two GPIOs from the same bank must be set at the same time, it fails.
Please fix this code so that setting or clearing a GPIO does not set or clear any other GPIO, and perform an actual test to confirm this works before submitting V2.
BTW: if (as the previous thread seemed to imply) no one around has the hardware to test this change, then why exactly is it needed?
Amicalement,
Hi Albert
On Sat, Sep 14, 2013 at 11:10 AM, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Axel,
Regards, Axel
if (value)
else
writel(0, ®s->gpiodata[DATA_REG_ADDR(gpio)]); return 0;
As I understand from the documentation (read some weeks ago), it uses the address in clear operation not only the value
Michael
Amicalement,
Albert.
2013/9/14 Albert ARIBAUD albert.u.boot@aribaud.net:
Hi Axel,
Regards, Axel
if (value)
else
No. Some people (Marek, and *Michael*) asked this question in original discussion thread. The datasheet says each GPIO is controlled by *different* register. (Well, it's unusual.) And that is why we don't need a read-write-update operation. Simply write 0 to the register does work. ( *Michael* replied it works )
Amicalement,
Albert.
Hi Axel
Hi Axel,
Regards, Axel
if (value)
else
Yes it's a strange implementation but looking at the documentation seems correct
Michael
Amicalement,
Albert.
Hi Michael,
On Sat, 14 Sep 2013 11:38:02 +0200, Michael Trimarchi michael@amarulasolutions.com wrote:
Hi Axel
Hi Axel,
Regards, Axel
if (value)
else
Ok-- I got the "masking address" trick this time, thanks. It is indeed unusual, and the code is indeed correct. However, I would like the patch to include a few lines of comment to explain how and why it works, for the benefit of its future readers who might find it weird too.
Michael
Amicalement,
Hi
On Sun, Sep 15, 2013 at 5:20 PM, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Michael,
Hi Axel
Hi Axel,
Regards, Axel
if (value)
else
I think that patch need to have a better description
Michael
Michael
Amicalement,
Albert.
Albert ARIBAUD
Axel Lin
Michael Trimarchi
