[U-Boot] [PATCH V2] imx: mx6 move TARGET_xx Kconfig option to mx6 specific Kconfig file
Move TARGET_xx Kconfig option based on mx6 to arch/arm/cpu/armv7/mx6/Kconfig. Add enable "CONFIG_ARCH_MX6" for boards based on mx6. Then we can choose target boards using "make ARCH=arm menuconfig" with ARCH_MX6 defined.
If using original way, we have no chance to enable ARCH_MX6 when "make menuconfig". Even define CONFIG_ARCH_MX6=y in xx_defconfig, kconfig will complains "arch/../configs/platinum_titanium_defconfig:3: warning: override: TARGET_PLATINUM_TITANIUM changes choice state"
Signed-off-by: Peng Fan Peng.Fan@freescale.com Cc: Stefano Babic sbabic@denx.de Cc: Heiko Schocher hs@denx.de Cc: Tim Harvey tharvey@gateworks.com Cc: Eric Bénard eric@eukrea.com Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Eric Nelson eric.nelson@boundarydevices.com Cc: Marek Vasut marex@denx.de Cc: Christian Gmeiner christian.gmeiner@gmail.com Cc: Stefan Roese sr@denx.de Cc: Soeren Moch smoch@web.de Cc: Otavio Salvador otavio@ossystems.com.br Acked-by: Stefano Babic sbabic@denx.de Acked-by: Soeren Moch smoch@web.de ---
Changes v2: Sort the TARGET option and included files from 'source' alphabetically, using "sed -ne '/TARGET/'p arch/arm/cpu/armv7/mx6/Kconfig | sort". Included files are sorted using same way using 'source' to replace 'TARGET' in command. Discard "Support" Add Acked-by from Stefano and Soeren. Pass building using "./MAKEALL -s mx6"
arch/arm/Kconfig | 128 ---------------------------------- arch/arm/cpu/armv7/mx6/Kconfig | 132 +++++++++++++++++++++++++++++++++++- configs/aristainetos2_defconfig | 1 + configs/aristainetos_defconfig | 1 + configs/cgtqmx6qeval_defconfig | 1 + configs/gwventana_defconfig | 1 + configs/marsboard_defconfig | 1 + configs/mx6cuboxi_defconfig | 1 + configs/mx6dlarm2_defconfig | 1 + configs/mx6dlarm2_lpddr2_defconfig | 1 + configs/mx6dlsabreauto_defconfig | 1 + configs/mx6dlsabresd_defconfig | 1 + configs/mx6qarm2_defconfig | 1 + configs/mx6qarm2_lpddr2_defconfig | 1 + configs/mx6qpsabreauto_defconfig | 1 + configs/mx6qsabreauto_defconfig | 1 + configs/mx6qsabrelite_defconfig | 1 + configs/mx6qsabresd_defconfig | 1 + configs/mx6sabresd_spl_defconfig | 1 + configs/mx6slevk_defconfig | 1 + configs/mx6slevk_spinor_defconfig | 1 + configs/mx6sxsabresd_defconfig | 1 + configs/mx6sxsabresd_spl_defconfig | 1 + configs/mx6ul_14x14_evk_defconfig | 1 + configs/nitrogen6dl2g_defconfig | 1 + configs/nitrogen6dl_defconfig | 1 + configs/nitrogen6q2g_defconfig | 1 + configs/nitrogen6q_defconfig | 1 + configs/nitrogen6s1g_defconfig | 1 + configs/nitrogen6s_defconfig | 1 + configs/novena_defconfig | 1 + configs/ot1200_defconfig | 1 + configs/ot1200_spl_defconfig | 1 + configs/platinum_picon_defconfig | 1 + configs/platinum_titanium_defconfig | 1 + configs/riotboard_defconfig | 1 + configs/tbs2910_defconfig | 1 + configs/udoo_defconfig | 1 + configs/wandboard_defconfig | 1 + configs/warp_defconfig | 1 + 40 files changed, 168 insertions(+), 130 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 5d54604..d28b50b 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -508,113 +508,6 @@ config TARGET_VISION2 bool "Support vision2" select CPU_V7
-config TARGET_UDOO - bool "Support udoo" - select CPU_V7 - select SUPPORT_SPL - -config TARGET_WANDBOARD - bool "Support wandboard" - select CPU_V7 - select SUPPORT_SPL - -config TARGET_WARP - bool "Support WaRP" - select CPU_V7 - -config TARGET_TITANIUM - bool "Support titanium" - select CPU_V7 - -config TARGET_NITROGEN6X - bool "Support nitrogen6x" - select CPU_V7 - -config TARGET_CGTQMX6EVAL - bool "Support cgtqmx6eval" - select CPU_V7 - -config TARGET_EMBESTMX6BOARDS - bool "Support embestmx6boards" - select CPU_V7 - -config TARGET_ARISTAINETOS - bool "Support aristainetos" - select CPU_V7 - -config TARGET_ARISTAINETOS2 - bool "Support aristainetos2" - select CPU_V7 - -config TARGET_MX6QARM2 - bool "Support mx6qarm2" - select CPU_V7 - -config TARGET_MX6QSABREAUTO - bool "Support mx6qsabreauto" - select CPU_V7 - select DM - select DM_THERMAL - -config TARGET_MX6SABRESD - bool "Support mx6sabresd" - select CPU_V7 - select SUPPORT_SPL - select DM - select DM_THERMAL - -config TARGET_MX6CUBOXI - bool "Support Solid-run mx6 boards" - select CPU_V7 - select SUPPORT_SPL - -config TARGET_MX6SLEVK - bool "Support mx6slevk" - select CPU_V7 - -config TARGET_MX6SXSABRESD - bool "Support mx6sxsabresd" - select CPU_V7 - select SUPPORT_SPL - select DM - select DM_THERMAL - -config TARGET_MX6UL_14X14_EVK - bool "Support mx6ul_14x14_evk" - select CPU_V7 - select DM - select DM_THERMAL - select SUPPORT_SPL - -config TARGET_GW_VENTANA - bool "Support gw_ventana" - select CPU_V7 - select SUPPORT_SPL - -config TARGET_KOSAGI_NOVENA - bool "Support Kosagi Novena" - select CPU_V7 - select SUPPORT_SPL - -config TARGET_TBS2910 - bool "Support tbs2910" - select CPU_V7 - -config TARGET_OT1200 - bool "Bachmann OT1200" - select CPU_V7 - select SUPPORT_SPL - -config TARGET_PLATINUM_PICON - bool "Support platinum-picon" - select CPU_V7 - select SUPPORT_SPL - -config TARGET_PLATINUM_TITANIUM - bool "Support platinum-titanium" - select CPU_V7 - select SUPPORT_SPL - config OMAP34XX bool "OMAP34XX SoC" select CPU_V7 @@ -869,7 +762,6 @@ source "arch/arm/cpu/armv8/Kconfig"
source "arch/arm/imx-common/Kconfig"
-source "board/aristainetos/Kconfig" source "board/BuR/kwb/Kconfig" source "board/BuR/tseries/Kconfig" source "board/CarMediaLab/flea3/Kconfig" @@ -880,24 +772,17 @@ source "board/Marvell/gplugd/Kconfig" source "board/armadeus/apf27/Kconfig" source "board/armltd/vexpress/Kconfig" source "board/armltd/vexpress64/Kconfig" -source "board/bachmann/ot1200/Kconfig" source "board/balloon3/Kconfig" -source "board/barco/platinum/Kconfig" -source "board/barco/titanium/Kconfig" source "board/bluegiga/apx4devkit/Kconfig" -source "board/boundary/nitrogen6x/Kconfig" source "board/broadcom/bcm28155_ap/Kconfig" source "board/broadcom/bcmcygnus/Kconfig" source "board/broadcom/bcmnsp/Kconfig" source "board/cirrus/edb93xx/Kconfig" source "board/compulab/cm_t335/Kconfig" -source "board/compulab/cm_fx6/Kconfig" -source "board/congatec/cgtqmx6eval/Kconfig" source "board/creative/xfi3/Kconfig" source "board/davedenx/qong/Kconfig" source "board/denx/m28evk/Kconfig" source "board/denx/m53evk/Kconfig" -source "board/embest/mx6boards/Kconfig" source "board/esg/ima3-mx53/Kconfig" source "board/freescale/ls2085a/Kconfig" source "board/freescale/ls2085aqds/Kconfig" @@ -915,14 +800,7 @@ source "board/freescale/mx53ard/Kconfig" source "board/freescale/mx53evk/Kconfig" source "board/freescale/mx53loco/Kconfig" source "board/freescale/mx53smd/Kconfig" -source "board/freescale/mx6qarm2/Kconfig" -source "board/freescale/mx6qsabreauto/Kconfig" -source "board/freescale/mx6sabresd/Kconfig" -source "board/freescale/mx6slevk/Kconfig" -source "board/freescale/mx6sxsabresd/Kconfig" -source "board/freescale/mx6ul_14x14_evk/Kconfig" source "board/freescale/vf610twr/Kconfig" -source "board/gateworks/gw_ventana/Kconfig" source "board/genesi/mx51_efikamx/Kconfig" source "board/gumstix/pepper/Kconfig" source "board/h2200/Kconfig" @@ -932,7 +810,6 @@ source "board/imx31_phycore/Kconfig" source "board/isee/igep0033/Kconfig" source "board/jornada/Kconfig" source "board/karo/tx25/Kconfig" -source "board/kosagi/novena/Kconfig" source "board/logicpd/imx27lite/Kconfig" source "board/logicpd/imx31_litekit/Kconfig" source "board/maxbcm/Kconfig" @@ -952,7 +829,6 @@ source "board/siemens/draco/Kconfig" source "board/siemens/pxm2/Kconfig" source "board/siemens/rut/Kconfig" source "board/silica/pengwyn/Kconfig" -source "board/solidrun/mx6cuboxi/Kconfig" source "board/spear/spear300/Kconfig" source "board/spear/spear310/Kconfig" source "board/spear/spear320/Kconfig" @@ -964,7 +840,6 @@ source "board/st/stm32f429-discovery/Kconfig" source "board/st/stv0991/Kconfig" source "board/sunxi/Kconfig" source "board/syteco/zmx25/Kconfig" -source "board/tbs/tbs2910/Kconfig" source "board/ti/am335x/Kconfig" source "board/ti/am43xx/Kconfig" source "board/birdland/bav335x/Kconfig" @@ -975,11 +850,8 @@ source "board/toradex/colibri_pxa270/Kconfig" source "board/toradex/colibri_vf/Kconfig" source "board/trizepsiv/Kconfig" source "board/ttcontrol/vision2/Kconfig" -source "board/udoo/Kconfig" source "board/vpac270/Kconfig" source "board/vscom/baltos/Kconfig" -source "board/wandboard/Kconfig" -source "board/warp/Kconfig" source "board/woodburn/Kconfig" source "board/work-microwave/work_92105/Kconfig" source "board/xaeniax/Kconfig" diff --git a/arch/arm/cpu/armv7/mx6/Kconfig b/arch/arm/cpu/armv7/mx6/Kconfig index dce7ffc..c43cea8 100644 --- a/arch/arm/cpu/armv7/mx6/Kconfig +++ b/arch/arm/cpu/armv7/mx6/Kconfig @@ -33,25 +33,153 @@ choice prompt "MX6 board select" optional
+config TARGET_ARISTAINETOS + bool "aristainetos" + select CPU_V7 + +config TARGET_ARISTAINETOS2 + bool "aristainetos2" + select CPU_V7 + +config TARGET_CGTQMX6EVAL + bool "cgtqmx6eval" + select CPU_V7 + config TARGET_CM_FX6 - bool "Support CM-FX6" + bool "CM-FX6" select SUPPORT_SPL select DM select DM_SERIAL select DM_GPIO
+config TARGET_EMBESTMX6BOARDS + bool "embestmx6boards" + select CPU_V7 + +config TARGET_GW_VENTANA + bool "gw_ventana" + select CPU_V7 + select SUPPORT_SPL + +config TARGET_KOSAGI_NOVENA + bool "Kosagi Novena" + select CPU_V7 + select SUPPORT_SPL + +config TARGET_MX6CUBOXI + bool "Solid-run mx6 boards" + select CPU_V7 + select SUPPORT_SPL + +config TARGET_MX6QARM2 + bool "mx6qarm2" + select CPU_V7 + +config TARGET_MX6QSABREAUTO + bool "mx6qsabreauto" + select CPU_V7 + select DM + select DM_THERMAL + +config TARGET_MX6SABRESD + bool "mx6sabresd" + select CPU_V7 + select SUPPORT_SPL + select DM + select DM_THERMAL + +config TARGET_MX6SLEVK + bool "mx6slevk" + select CPU_V7 + +config TARGET_MX6SXSABRESD + bool "mx6sxsabresd" + select CPU_V7 + select SUPPORT_SPL + select DM + select DM_THERMAL + +config TARGET_MX6UL_14X14_EVK + bool "mx6ul_14x14_evk" + select CPU_V7 + select DM + select DM_THERMAL + select SUPPORT_SPL + +config TARGET_NITROGEN6X + bool "nitrogen6x" + select CPU_V7 + +config TARGET_OT1200 + bool "Bachmann OT1200" + select CPU_V7 + select SUPPORT_SPL + +config TARGET_PLATINUM_PICON + bool "platinum-picon" + select CPU_V7 + select SUPPORT_SPL + +config TARGET_PLATINUM_TITANIUM + bool "platinum-titanium" + select CPU_V7 + select SUPPORT_SPL + config TARGET_SECOMX6 - bool "Support secomx6 boards" + bool "secomx6 boards" + +config TARGET_TBS2910 + bool "tbs2910" + select CPU_V7 + +config TARGET_TITANIUM + bool "titanium" + select CPU_V7
config TARGET_TQMA6 bool "TQ Systems TQMa6 board"
+config TARGET_UDOO + bool "udoo" + select CPU_V7 + select SUPPORT_SPL + +config TARGET_WANDBOARD + bool "wandboard" + select CPU_V7 + select SUPPORT_SPL + +config TARGET_WARP + bool "WaRP" + select CPU_V7 + endchoice
config SYS_SOC default "mx6"
+source "board/aristainetos/Kconfig" +source "board/bachmann/ot1200/Kconfig" +source "board/barco/platinum/Kconfig" +source "board/barco/titanium/Kconfig" +source "board/boundary/nitrogen6x/Kconfig" +source "board/compulab/cm_fx6/Kconfig" +source "board/congatec/cgtqmx6eval/Kconfig" +source "board/embest/mx6boards/Kconfig" +source "board/freescale/mx6qarm2/Kconfig" +source "board/freescale/mx6qsabreauto/Kconfig" +source "board/freescale/mx6sabresd/Kconfig" +source "board/freescale/mx6slevk/Kconfig" +source "board/freescale/mx6sxsabresd/Kconfig" +source "board/freescale/mx6ul_14x14_evk/Kconfig" +source "board/gateworks/gw_ventana/Kconfig" +source "board/kosagi/novena/Kconfig" source "board/seco/Kconfig" +source "board/solidrun/mx6cuboxi/Kconfig" +source "board/tbs/tbs2910/Kconfig" source "board/tqc/tqma6/Kconfig" +source "board/udoo/Kconfig" +source "board/wandboard/Kconfig" +source "board/warp/Kconfig"
endif diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig index e676f0e..e43f6eb 100644 --- a/configs/aristainetos2_defconfig +++ b/configs/aristainetos2_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_ARISTAINETOS2=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg,MX6DL" # CONFIG_CMD_IMLS is not set diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig index f5b0b6b..e6affed 100644 --- a/configs/aristainetos_defconfig +++ b/configs/aristainetos_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_ARISTAINETOS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos.cfg,MX6DL" # CONFIG_CMD_IMLS is not set diff --git a/configs/cgtqmx6qeval_defconfig b/configs/cgtqmx6qeval_defconfig index 6fd29a0..a6ccd7a 100644 --- a/configs/cgtqmx6qeval_defconfig +++ b/configs/cgtqmx6qeval_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_CGTQMX6EVAL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/congatec/cgtqmx6eval/imximage.cfg,MX6Q" CONFIG_CMD_NET=y diff --git a/configs/gwventana_defconfig b/configs/gwventana_defconfig index 401f77e..82d7206 100644 --- a/configs/gwventana_defconfig +++ b/configs/gwventana_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_GW_VENTANA=y CONFIG_SPL=y CONFIG_SPL_STACK_R=y diff --git a/configs/marsboard_defconfig b/configs/marsboard_defconfig index 5ea278f..0707f0d 100644 --- a/configs/marsboard_defconfig +++ b/configs/marsboard_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_EMBESTMX6BOARDS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024,ENV_IS_IN_SPI_FLASH" # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index 27fe22e..59362c6 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6CUBOXI=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" diff --git a/configs/mx6dlarm2_defconfig b/configs/mx6dlarm2_defconfig index 6c1ba33..e1bdaaf 100644 --- a/configs/mx6dlarm2_defconfig +++ b/configs/mx6dlarm2_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QARM2=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qarm2/imximage_mx6dl.cfg,MX6DL,DDR_MB=2048" # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6dlarm2_lpddr2_defconfig b/configs/mx6dlarm2_lpddr2_defconfig index 4624a09..a37c254 100644 --- a/configs/mx6dlarm2_lpddr2_defconfig +++ b/configs/mx6dlarm2_lpddr2_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QARM2=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qarm2/imximage_mx6dl.cfg,MX6DL,MX6DL_LPDDR2,DDR_MB=512" # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6dlsabreauto_defconfig b/configs/mx6dlsabreauto_defconfig index 756e5db..17d1b96 100644 --- a/configs/mx6dlsabreauto_defconfig +++ b/configs/mx6dlsabreauto_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QSABREAUTO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/mx6dl.cfg,MX6DL" # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6dlsabresd_defconfig b/configs/mx6dlsabresd_defconfig index de99998..6610a0c 100644 --- a/configs/mx6dlsabresd_defconfig +++ b/configs/mx6dlsabresd_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SABRESD=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sabresd/mx6dlsabresd.cfg,MX6DL" # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6qarm2_defconfig b/configs/mx6qarm2_defconfig index 42dbded..5cd78cd 100644 --- a/configs/mx6qarm2_defconfig +++ b/configs/mx6qarm2_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QARM2=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qarm2/imximage.cfg,MX6Q,DDR_MB=2048" # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6qarm2_lpddr2_defconfig b/configs/mx6qarm2_lpddr2_defconfig index 5f9105f..89c42b8 100644 --- a/configs/mx6qarm2_lpddr2_defconfig +++ b/configs/mx6qarm2_lpddr2_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QARM2=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qarm2/imximage.cfg,MX6Q,MX6DQ_LPDDR2,DDR_MB=512" # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6qpsabreauto_defconfig b/configs/mx6qpsabreauto_defconfig index 293e3f2..2cbbc32 100644 --- a/configs/mx6qpsabreauto_defconfig +++ b/configs/mx6qpsabreauto_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QSABREAUTO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/mx6qp.cfg,MX6Q" CONFIG_SPI_FLASH=y diff --git a/configs/mx6qsabreauto_defconfig b/configs/mx6qsabreauto_defconfig index 9343bcc..11ded40 100644 --- a/configs/mx6qsabreauto_defconfig +++ b/configs/mx6qsabreauto_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QSABREAUTO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg,MX6Q" # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index 427fbee..1a2bb22 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024,SABRELITE" # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6qsabresd_defconfig b/configs/mx6qsabresd_defconfig index 732c1dc..6cbe1cf 100644 --- a/configs/mx6qsabresd_defconfig +++ b/configs/mx6qsabresd_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SABRESD=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg,MX6Q" # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6sabresd_spl_defconfig b/configs/mx6sabresd_spl_defconfig index d93a40d..bfd371a 100644 --- a/configs/mx6sabresd_spl_defconfig +++ b/configs/mx6sabresd_spl_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SABRESD=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6Q" diff --git a/configs/mx6slevk_defconfig b/configs/mx6slevk_defconfig index dcc3296..ae9912b 100644 --- a/configs/mx6slevk_defconfig +++ b/configs/mx6slevk_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SLEVK=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL" # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6slevk_spinor_defconfig b/configs/mx6slevk_spinor_defconfig index 964a147..3904616 100644 --- a/configs/mx6slevk_spinor_defconfig +++ b/configs/mx6slevk_spinor_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SLEVK=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL,SYS_BOOT_SPINOR" # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6sxsabresd_defconfig b/configs/mx6sxsabresd_defconfig index e6e4db5..a582905 100644 --- a/configs/mx6sxsabresd_defconfig +++ b/configs/mx6sxsabresd_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SXSABRESD=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sxsabresd/imximage.cfg,MX6SX" # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6sxsabresd_spl_defconfig b/configs/mx6sxsabresd_spl_defconfig index df34894..3f19659 100644 --- a/configs/mx6sxsabresd_spl_defconfig +++ b/configs/mx6sxsabresd_spl_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SXSABRESD=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6SX" diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index 87ba686..250f3f2 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -1,5 +1,6 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6UL" CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6UL_14X14_EVK=y CONFIG_SPL=y CONFIG_CMD_NET=y diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index 6cbc0e3..2044fc9 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl2g.cfg,MX6DL,DDR_MB=2048" # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index 055266c..c90c8c9 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024" # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index 7b5ccc7..90ef17e 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048" # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index 5cc245e..798467e 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024" # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index b613a49..e8eca1b 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024" # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index b7cd09a..d142ebc 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512" # CONFIG_CMD_IMLS is not set diff --git a/configs/novena_defconfig b/configs/novena_defconfig index aca98b7..60d6658 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_KOSAGI_NOVENA=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" diff --git a/configs/ot1200_defconfig b/configs/ot1200_defconfig index ea78934..17022a4 100644 --- a/configs/ot1200_defconfig +++ b/configs/ot1200_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_OT1200=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/bachmann/ot1200/mx6q_4x_mt41j128.cfg,MX6Q" # CONFIG_CMD_IMLS is not set diff --git a/configs/ot1200_spl_defconfig b/configs/ot1200_spl_defconfig index 3c7346b..dbbea35 100644 --- a/configs/ot1200_spl_defconfig +++ b/configs/ot1200_spl_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_OT1200=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" diff --git a/configs/platinum_picon_defconfig b/configs/platinum_picon_defconfig index 3484c46..446a726 100644 --- a/configs/platinum_picon_defconfig +++ b/configs/platinum_picon_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_PLATINUM_PICON=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6DL" diff --git a/configs/platinum_titanium_defconfig b/configs/platinum_titanium_defconfig index 6a2cacf..01cbb08 100644 --- a/configs/platinum_titanium_defconfig +++ b/configs/platinum_titanium_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_PLATINUM_TITANIUM=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" diff --git a/configs/riotboard_defconfig b/configs/riotboard_defconfig index fd18e2d..859b143 100644 --- a/configs/riotboard_defconfig +++ b/configs/riotboard_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_EMBESTMX6BOARDS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024,ENV_IS_IN_MMC" # CONFIG_CMD_IMLS is not set diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index f0e5106..1e20d29 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_TBS2910=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q" # CONFIG_CMD_IMLS is not set diff --git a/configs/udoo_defconfig b/configs/udoo_defconfig index 9fe30d3..e4f1d8d 100644 --- a/configs/udoo_defconfig +++ b/configs/udoo_defconfig @@ -1,5 +1,6 @@ CONFIG_SPL=y CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_DM=y CONFIG_DM_THERMAL=y CONFIG_TARGET_UDOO=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 62666ff..595e4be 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_WANDBOARD=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" diff --git a/configs/warp_defconfig b/configs/warp_defconfig index dacb432..423f820 100644 --- a/configs/warp_defconfig +++ b/configs/warp_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_ARCH_MX6=y CONFIG_TARGET_WARP=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL" # CONFIG_CMD_IMLS is not set
Acked-by: Otavio Salvador otavio@ossystems.com.br
-config TARGET_UDOO
bool "Support udoo"
select CPU_V7
select SUPPORT_SPL
select CPU_V7
select SUPPORT_SPL
-config TARGET_WARP
bool "Support WaRP"
select CPU_V7
select CPU_V7
select CPU_V7
select CPU_V7
select CPU_V7
select CPU_V7
select CPU_V7
select CPU_V7
select CPU_V7
select DM
select DM_THERMAL
select CPU_V7
select SUPPORT_SPL
select DM
select DM_THERMAL
select CPU_V7
select SUPPORT_SPL
select CPU_V7
select CPU_V7
select SUPPORT_SPL
select DM
select DM_THERMAL
select CPU_V7
select DM
select DM_THERMAL
select SUPPORT_SPL
select CPU_V7
select SUPPORT_SPL
select CPU_V7
select SUPPORT_SPL
select CPU_V7
select CPU_V7
select SUPPORT_SPL
select CPU_V7
select SUPPORT_SPL
select CPU_V7
select SUPPORT_SPL
bool "aristainetos"
select CPU_V7
select CPU_V7
bool "cgtqmx6eval"
select CPU_V7
select CPU_V7
bool "gw_ventana"
select CPU_V7
select SUPPORT_SPL
select CPU_V7
select SUPPORT_SPL
select CPU_V7
select SUPPORT_SPL
bool "mx6qarm2"
select CPU_V7
select CPU_V7
select DM
select DM_THERMAL
bool "mx6sabresd"
select CPU_V7
select SUPPORT_SPL
select DM
select DM_THERMAL
bool "mx6slevk"
select CPU_V7
bool "mx6sxsabresd"
select CPU_V7
select SUPPORT_SPL
select DM
select DM_THERMAL
select CPU_V7
select DM
select DM_THERMAL
select SUPPORT_SPL
bool "nitrogen6x"
select CPU_V7
select CPU_V7
select SUPPORT_SPL
select CPU_V7
select SUPPORT_SPL
select CPU_V7
select SUPPORT_SPL
bool "tbs2910"
select CPU_V7
bool "titanium"
select CPU_V7
+config TARGET_UDOO
bool "udoo"
select CPU_V7
select SUPPORT_SPL
bool "wandboard"
select CPU_V7
select SUPPORT_SPL
+config TARGET_WARP
bool "WaRP"
select CPU_V7
endchoice
1.8.4
Acked-by: Christian Gmeiner christian.gmeiner@gmail.com
Best regards, Stefano Babic
Christian Gmeiner
Otavio Salvador
Peng Fan
Stefano Babic
