[U-Boot] [PATCH] sandbox: Expand list of IO accessors
The setbits/clrbits/clrsetbits macros are used widely across the tree, let's provide implementation for them in the sandbox.
Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com --- arch/sandbox/include/asm/io.h | 47 +++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 47 insertions(+)
diff --git a/arch/sandbox/include/asm/io.h b/arch/sandbox/include/asm/io.h index a6856356df19..3ece70d09dd1 100644 --- a/arch/sandbox/include/asm/io.h +++ b/arch/sandbox/include/asm/io.h @@ -56,6 +56,53 @@ void outl(unsigned int value, unsigned int addr); void outw(unsigned int value, unsigned int addr); void outb(unsigned int value, unsigned int addr);
+#define out_arch(type,endian,a,v) write##type(cpu_to_##endian(v),a) +#define in_arch(type,endian,a) endian##_to_cpu(read##type(a)) + +#define out_le32(a,v) out_arch(l,le32,a,v) +#define out_le16(a,v) out_arch(w,le16,a,v) + +#define in_le32(a) in_arch(l,le32,a) +#define in_le16(a) in_arch(w,le16,a) + +#define out_be32(a,v) out_arch(l,be32,a,v) +#define out_be16(a,v) out_arch(w,be16,a,v) + +#define in_be32(a) in_arch(l,be32,a) +#define in_be16(a) in_arch(w,be16,a) + +#define out_8(a,v) writeb(v,a) +#define in_8(a) readb(a) + +#define clrbits(type, addr, clear) \ + out_##type((addr), in_##type(addr) & ~(clear)) + +#define setbits(type, addr, set) \ + out_##type((addr), in_##type(addr) | (set)) + +#define clrsetbits(type, addr, clear, set) \ + out_##type((addr), (in_##type(addr) & ~(clear)) | (set)) + +#define clrbits_be32(addr, clear) clrbits(be32, addr, clear) +#define setbits_be32(addr, set) setbits(be32, addr, set) +#define clrsetbits_be32(addr, clear, set) clrsetbits(be32, addr, clear, set) + +#define clrbits_le32(addr, clear) clrbits(le32, addr, clear) +#define setbits_le32(addr, set) setbits(le32, addr, set) +#define clrsetbits_le32(addr, clear, set) clrsetbits(le32, addr, clear, set) + +#define clrbits_be16(addr, clear) clrbits(be16, addr, clear) +#define setbits_be16(addr, set) setbits(be16, addr, set) +#define clrsetbits_be16(addr, clear, set) clrsetbits(be16, addr, clear, set) + +#define clrbits_le16(addr, clear) clrbits(le16, addr, clear) +#define setbits_le16(addr, set) setbits(le16, addr, set) +#define clrsetbits_le16(addr, clear, set) clrsetbits(le16, addr, clear, set) + +#define clrbits_8(addr, clear) clrbits(8, addr, clear) +#define setbits_8(addr, set) setbits(8, addr, set) +#define clrsetbits_8(addr, clear, set) clrsetbits(8, addr, clear, set) + static inline void _insw(volatile u16 *port, void *buf, int ns) { }
Maxime Ripard
