[PATCH] rockchip: sdhci: rk3568: fix clock setting logic
mmc->tran_speed is max clock, but currently rk3568_sdhci_set_ios_post uses it if its != 0, regardless of mmc->clock value, and it breaks eMMC controller.
Without this patch 'mmc dev 0; mmc dev 1; mmc dev 0' is enough for breaking eMMC, since first initialization sets mmc->mmc_tran speed to non-zero value (26MHz in my case), and on subsequent re-init when mmc layer asks for 400KHz it sets 26MHz instead.
Fix it by using MAX(mmc->tran_speed, mmc->clock)
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com --- drivers/mmc/rockchip_sdhci.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/mmc/rockchip_sdhci.c b/drivers/mmc/rockchip_sdhci.c index 9608770d4e..1ac95f32b3 100644 --- a/drivers/mmc/rockchip_sdhci.c +++ b/drivers/mmc/rockchip_sdhci.c @@ -394,11 +394,11 @@ static int rk3568_sdhci_set_enhanced_strobe(struct sdhci_host *host) static int rk3568_sdhci_set_ios_post(struct sdhci_host *host) { struct mmc *mmc = host->mmc; - uint clock = mmc->tran_speed; + uint clock = mmc->clock; u32 reg, vendor_reg;
- if (!clock) - clock = mmc->clock; + if (mmc->tran_speed && mmc->clock > mmc->tran_speed) + clock = mmc->tran_speed;
rk3568_sdhci_emmc_set_clock(host, clock);
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- uint clock = mmc->clock; u32 reg, vendor_reg;
- if (!clock)
clock = mmc->clock;
Kever Yang
Vasily Khoruzhick
