[PATCH v5 0/7] Arasan sdhci driver updates
This patch series updates/fixes below things: - Handle errors from tapdelay functions and return to set_delay() - Add ZynqMP firmware related enums which are used in sdhci driver - Replace mmio_write() with firmware call xilinx_pm_request() - Move tapdelay setting code from tap_delays.c to driver and remove tap_dealy.c and zynqmp_tap_delay.h - Change variable name from deviceid to node_id in couple of functions for consistancy - Add a workaround for sd card detect stable issue for Versal platforms - Use set_control_reg from sdhci.c
These patches are based on below microblaze U-Boot 'next' branch. https://source.denx.de/u-boot/custodians/u-boot-microblaze/-/commits/next
Changes in v5: - Added WORKAROUND in comment and elaborated the comment about issue.
Changes in v4: - Rebase to latest u-boot-microblaze custodian 'next' branch - Initialized all enum pm_ioctl_id elements with explicit values
Changes in v3: - Added new line after return at two places - As we are seeing issues with SPL flow, keep zynqmp_mmio_write method to set tapdelay's and DLL resets. Add xilinx_pm_request on top of it for regular flow. - Changed the patch title to reflect these changes - Make the changes on top of patch 4/7 to move the code to zynq_sdhci.c
Changes in v2: - Split patch 1/7 to two patches, one for zynq_sdhci and other one for sdhci - This is the second patch that has been split from 1/7 - This covers changes for sdhci driver separately - Added a debug print in case of error from set_delay() - Added comment for why 1ms delay is needed between DLL assert and release - Remove mmc->dev->seq_ and use priv->deviceid instead - Changed return error from -EIO to -ETIMEDOUT in arasan_sdhci_probe() in card detect state stable workaround
Ashok Reddy Soma (5): mmc: zynq_sdhci: Return errors from arasan_sdhci_set_tapdelay mmc: sdhci: Change prototype of set_delay to return errors mmc: zynq_sdhci: Add xilinx_pm_request() method to set tapdelays mmc: zynq_sdhci: Move setting tapdelay code to driver mmc: zynq_sdhci: Use set_control_reg from sdhci.c
T Karthik Reddy (2): zynqmp_firmware: Add zynqmp firmware related enums mmc: zynq_sdhci: Wait till sd card detect state is stable
board/xilinx/zynqmp/Makefile | 2 - board/xilinx/zynqmp/tap_delays.c | 101 ------------- drivers/mmc/sdhci.c | 10 +- drivers/mmc/zynq_sdhci.c | 244 ++++++++++++++++++++++++++----- include/sdhci.h | 2 +- include/zynqmp_firmware.h | 127 ++++++++++++++++ include/zynqmp_tap_delay.h | 21 --- 7 files changed, 340 insertions(+), 167 deletions(-) delete mode 100644 board/xilinx/zynqmp/tap_delays.c delete mode 100644 include/zynqmp_tap_delay.h
Change return type of arasan_sdhci_set_tapdelay() to int, to facilitate returning errors. Get return values from input and output set clock phase functions inside arasan_sdhci_set_tapdelay() and return those errors.
Signed-off-by: T Karthik Reddy t.karthik.reddy@xilinx.com Signed-off-by: Ashok Reddy Soma ashok.reddy.soma@xilinx.com Reviewed-by: Jaehoon Chung jh80.chung@samsung.com ---
(no changes since v3)
drivers/mmc/zynq_sdhci.c | 23 ++++++++++++++++++----- 1 file changed, 18 insertions(+), 5 deletions(-)
diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index ba87ee8dd5..1ecc2ec669 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -422,7 +422,7 @@ static int sdhci_versal_sampleclk_set_phase(struct sdhci_host *host, return 0; }
-static void arasan_sdhci_set_tapdelay(struct sdhci_host *host) +static int arasan_sdhci_set_tapdelay(struct sdhci_host *host) { struct arasan_sdhci_priv *priv = dev_get_priv(host->mmc->dev); struct arasan_sdhci_clk_data *clk_data = &priv->clk_data; @@ -431,18 +431,31 @@ static void arasan_sdhci_set_tapdelay(struct sdhci_host *host) u8 timing = mode2timing[mmc->selected_mode]; u32 iclk_phase = clk_data->clk_phase_in[timing]; u32 oclk_phase = clk_data->clk_phase_out[timing]; + int ret;
dev_dbg(dev, "%s, host:%s, mode:%d\n", __func__, host->name, timing);
if (IS_ENABLED(CONFIG_ARCH_ZYNQMP) && device_is_compatible(dev, "xlnx,zynqmp-8.9a")) { - sdhci_zynqmp_sampleclk_set_phase(host, iclk_phase); - sdhci_zynqmp_sdcardclk_set_phase(host, oclk_phase); + ret = sdhci_zynqmp_sampleclk_set_phase(host, iclk_phase); + if (ret) + return ret; + + ret = sdhci_zynqmp_sdcardclk_set_phase(host, oclk_phase); + if (ret) + return ret; } else if (IS_ENABLED(CONFIG_ARCH_VERSAL) && device_is_compatible(dev, "xlnx,versal-8.9a")) { - sdhci_versal_sampleclk_set_phase(host, iclk_phase); - sdhci_versal_sdcardclk_set_phase(host, oclk_phase); + ret = sdhci_versal_sampleclk_set_phase(host, iclk_phase); + if (ret) + return ret; + + ret = sdhci_versal_sdcardclk_set_phase(host, oclk_phase); + if (ret) + return ret; } + + return 0; }
static void arasan_dt_read_clk_phase(struct udevice *dev, unsigned char timing,
set_delay() has return type as void. If there are any errors while setting tapdelay's it won't be able to return them.
Change the prototype of set_delay() in sdhci_ops structure and return the errors from wherever it is called.
(no changes since v2)
Changes in v2: - This is the second patch that has been split from 1/7 - This covers changes for sdhci driver separately - Added a debug print in case of error from set_delay()
drivers/mmc/sdhci.c | 10 ++++++++-- include/sdhci.h | 2 +- 2 files changed, 9 insertions(+), 3 deletions(-)
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index d9ab6a0a83..a99014236a 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -366,6 +366,7 @@ int sdhci_set_clock(struct mmc *mmc, unsigned int clock) { struct sdhci_host *host = mmc->priv; unsigned int div, clk = 0, timeout; + int ret;
/* Wait max 20 ms */ timeout = 200; @@ -386,8 +387,13 @@ int sdhci_set_clock(struct mmc *mmc, unsigned int clock) if (clock == 0) return 0;
- if (host->ops && host->ops->set_delay) - host->ops->set_delay(host); + if (host->ops && host->ops->set_delay) { + ret = host->ops->set_delay(host); + if (ret) { + printf("%s: Error while setting tap delay\n", __func__); + return ret; + } + }
if (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300) { /* diff --git a/include/sdhci.h b/include/sdhci.h index 0ae9471ad7..44a0d84e5a 100644 --- a/include/sdhci.h +++ b/include/sdhci.h @@ -268,7 +268,7 @@ struct sdhci_ops { int (*set_ios_post)(struct sdhci_host *host); void (*set_clock)(struct sdhci_host *host, u32 div); int (*platform_execute_tuning)(struct mmc *host, u8 opcode); - void (*set_delay)(struct sdhci_host *host); + int (*set_delay)(struct sdhci_host *host); int (*deferred_probe)(struct sdhci_host *host); };
Add enums for pm node id's, pm ioctl id's, tapdelay types, dll reset types
Signed-off-by: T Karthik Reddy t.karthik.reddy@xilinx.com Signed-off-by: Ashok Reddy Soma ashok.reddy.soma@xilinx.com ---
(no changes since v4)
include/zynqmp_firmware.h | 127 ++++++++++++++++++++++++++++++++++++++ 1 file changed, 127 insertions(+)
diff --git a/include/zynqmp_firmware.h b/include/zynqmp_firmware.h index e2ec8f6b5a..0b068d7da2 100644 --- a/include/zynqmp_firmware.h +++ b/include/zynqmp_firmware.h @@ -67,6 +67,99 @@ enum pm_api_id { PM_API_MAX, };
+enum pm_node_id { + NODE_UNKNOWN = 0, + NODE_APU = 1, + NODE_APU_0 = 2, + NODE_APU_1 = 3, + NODE_APU_2 = 4, + NODE_APU_3 = 5, + NODE_RPU = 6, + NODE_RPU_0 = 7, + NODE_RPU_1 = 8, + NODE_PLD = 9, + NODE_FPD = 10, + NODE_OCM_BANK_0 = 11, + NODE_OCM_BANK_1 = 12, + NODE_OCM_BANK_2 = 13, + NODE_OCM_BANK_3 = 14, + NODE_TCM_0_A = 15, + NODE_TCM_0_B = 16, + NODE_TCM_1_A = 17, + NODE_TCM_1_B = 18, + NODE_L2 = 19, + NODE_GPU_PP_0 = 20, + NODE_GPU_PP_1 = 21, + NODE_USB_0 = 22, + NODE_USB_1 = 23, + NODE_TTC_0 = 24, + NODE_TTC_1 = 25, + NODE_TTC_2 = 26, + NODE_TTC_3 = 27, + NODE_SATA = 28, + NODE_ETH_0 = 29, + NODE_ETH_1 = 30, + NODE_ETH_2 = 31, + NODE_ETH_3 = 32, + NODE_UART_0 = 33, + NODE_UART_1 = 34, + NODE_SPI_0 = 35, + NODE_SPI_1 = 36, + NODE_I2C_0 = 37, + NODE_I2C_1 = 38, + NODE_SD_0 = 39, + NODE_SD_1 = 40, + NODE_DP = 41, + NODE_GDMA = 42, + NODE_ADMA = 43, + NODE_NAND = 44, + NODE_QSPI = 45, + NODE_GPIO = 46, + NODE_CAN_0 = 47, + NODE_CAN_1 = 48, + NODE_EXTERN = 49, + NODE_APLL = 50, + NODE_VPLL = 51, + NODE_DPLL = 52, + NODE_RPLL = 53, + NODE_IOPLL = 54, + NODE_DDR = 55, + NODE_IPI_APU = 56, + NODE_IPI_RPU_0 = 57, + NODE_GPU = 58, + NODE_PCIE = 59, + NODE_PCAP = 60, + NODE_RTC = 61, + NODE_LPD = 62, + NODE_VCU = 63, + NODE_IPI_RPU_1 = 64, + NODE_IPI_PL_0 = 65, + NODE_IPI_PL_1 = 66, + NODE_IPI_PL_2 = 67, + NODE_IPI_PL_3 = 68, + NODE_PL = 69, + NODE_GEM_TSU = 70, + NODE_SWDT_0 = 71, + NODE_SWDT_1 = 72, + NODE_CSU = 73, + NODE_PJTAG = 74, + NODE_TRACE = 75, + NODE_TESTSCAN = 76, + NODE_PMU = 77, + NODE_MAX = 78, +}; + +enum tap_delay_type { + PM_TAPDELAY_INPUT = 0, + PM_TAPDELAY_OUTPUT = 1, +}; + +enum dll_reset_type { + PM_DLL_RESET_ASSERT = 0, + PM_DLL_RESET_RELEASE = 1, + PM_DLL_RESET_PULSE = 2, +}; + enum pm_query_id { PM_QID_INVALID = 0, PM_QID_CLOCK_GET_NAME = 1, @@ -215,6 +308,40 @@ enum zynqmp_pm_reset { ZYNQMP_PM_RESET_END = ZYNQMP_PM_RESET_PS_PL3 };
+enum pm_ioctl_id { + IOCTL_GET_RPU_OPER_MODE = 0, + IOCTL_SET_RPU_OPER_MODE = 1, + IOCTL_RPU_BOOT_ADDR_CONFIG = 2, + IOCTL_TCM_COMB_CONFIG = 3, + IOCTL_SET_TAPDELAY_BYPASS = 4, + IOCTL_SET_SGMII_MODE = 5, + IOCTL_SD_DLL_RESET = 6, + IOCTL_SET_SD_TAPDELAY = 7, + IOCTL_SET_PLL_FRAC_MODE = 8, + IOCTL_GET_PLL_FRAC_MODE = 9, + IOCTL_SET_PLL_FRAC_DATA = 10, + IOCTL_GET_PLL_FRAC_DATA = 11, + IOCTL_WRITE_GGS = 12, + IOCTL_READ_GGS = 13, + IOCTL_WRITE_PGGS = 14, + IOCTL_READ_PGGS = 15, + /* IOCTL for ULPI reset */ + IOCTL_ULPI_RESET = 16, + /* Set healthy bit value*/ + IOCTL_SET_BOOT_HEALTH_STATUS = 17, + IOCTL_AFI = 18, + /* Probe counter read/write */ + IOCTL_PROBE_COUNTER_READ = 19, + IOCTL_PROBE_COUNTER_WRITE = 20, + IOCTL_OSPI_MUX_SELECT = 21, + /* IOCTL for USB power request */ + IOCTL_USB_SET_STATE = 22, + /* IOCTL to get last reset reason */ + IOCTL_GET_LAST_RESET_REASON = 23, + /* AIE ISR Clear */ + IOCTL_AIE_ISR_CLEAR = 24, +}; + #define PM_SIP_SVC 0xc2000000
#define ZYNQMP_PM_VERSION_MAJOR 1
Currently xilinx sdhci driver is using zynqmp_mmio_write() to set tapdelay values and DLL resets. Continue to use this for SPL and mini U-Boot where U-Boot will be executed at EL3 level.
Use firmware call xilinx_pm_request() using appropriate arguments to set input/output tapdelays and also for DLL resets in regular flow(EL2).
Host driver should explicitly request DLL reset before ITAP (assert DLL) and after OTAP (release DLL) to avoid issues in some cases. Also handle error return where possible.
Changes in v3: - As we are seeing issues with SPL flow, keep zynqmp_mmio_write method to set tapdelay's and DLL resets. Add xilinx_pm_request on top of it for regular flow. - Changed the patch title to reflect these changes
Changes in v2: - Added comment for why 1ms delay is needed between DLL assert and release - Remove mmc->dev->seq_ and use priv->deviceid instead
board/xilinx/zynqmp/tap_delays.c | 148 +++++++++++++++++-------------- drivers/mmc/zynq_sdhci.c | 73 ++++++++++++--- include/zynqmp_tap_delay.h | 25 ++++-- 3 files changed, 159 insertions(+), 87 deletions(-)
diff --git a/board/xilinx/zynqmp/tap_delays.c b/board/xilinx/zynqmp/tap_delays.c index d16bbb8eff..514f86a29a 100644 --- a/board/xilinx/zynqmp/tap_delays.c +++ b/board/xilinx/zynqmp/tap_delays.c @@ -8,94 +8,108 @@ #include <common.h> #include <zynqmp_tap_delay.h> #include <asm/arch/sys_proto.h> +#include <asm/cache.h> #include <linux/delay.h> #include <mmc.h> +#include <zynqmp_firmware.h>
#define SD_DLL_CTRL 0xFF180358 #define SD_ITAP_DLY 0xFF180314 #define SD_OTAP_DLY 0xFF180318 -#define SD0_DLL_RST_MASK 0x00000004 -#define SD0_DLL_RST 0x00000004 -#define SD1_DLL_RST_MASK 0x00040000 -#define SD1_DLL_RST 0x00040000 -#define SD0_ITAPCHGWIN_MASK 0x00000200 -#define SD0_ITAPCHGWIN 0x00000200 -#define SD1_ITAPCHGWIN_MASK 0x02000000 -#define SD1_ITAPCHGWIN 0x02000000 -#define SD0_ITAPDLYENA_MASK 0x00000100 -#define SD0_ITAPDLYENA 0x00000100 -#define SD1_ITAPDLYENA_MASK 0x01000000 -#define SD1_ITAPDLYENA 0x01000000 -#define SD0_ITAPDLYSEL_MASK 0x000000FF -#define SD1_ITAPDLYSEL_MASK 0x00FF0000 -#define SD0_OTAPDLYSEL_MASK 0x0000003F -#define SD1_OTAPDLYSEL_MASK 0x003F0000 +#define SD0_DLL_RST BIT(2) +#define SD1_DLL_RST BIT(18) +#define SD0_ITAPCHGWIN BIT(9) +#define SD1_ITAPCHGWIN BIT(25) +#define SD0_ITAPDLYENA BIT(8) +#define SD1_ITAPDLYENA BIT(24) +#define SD0_ITAPDLYSEL_MASK GENMASK(7, 0) +#define SD1_ITAPDLYSEL_MASK GENMASK(23, 16) +#define SD0_OTAPDLYSEL_MASK GENMASK(5, 0) +#define SD1_OTAPDLYSEL_MASK GENMASK(21, 16)
-void zynqmp_dll_reset(u8 deviceid) +int zynqmp_dll_reset(u8 node_id, u32 type) { - /* Issue DLL Reset */ - if (deviceid == 0) - zynqmp_mmio_write(SD_DLL_CTRL, SD0_DLL_RST_MASK, - SD0_DLL_RST); - else - zynqmp_mmio_write(SD_DLL_CTRL, SD1_DLL_RST_MASK, - SD1_DLL_RST); + if (IS_ENABLED(CONFIG_SPL_BUILD) || current_el() == 3) { + if (node_id == NODE_SD_0) + return zynqmp_mmio_write(SD_DLL_CTRL, SD0_DLL_RST, + type == PM_DLL_RESET_ASSERT ? + SD0_DLL_RST : 0);
- mdelay(1); - - /* Release DLL Reset */ - if (deviceid == 0) - zynqmp_mmio_write(SD_DLL_CTRL, SD0_DLL_RST_MASK, 0x0); - else - zynqmp_mmio_write(SD_DLL_CTRL, SD1_DLL_RST_MASK, 0x0); + return zynqmp_mmio_write(SD_DLL_CTRL, SD1_DLL_RST, + type == PM_DLL_RESET_ASSERT ? + SD1_DLL_RST : 0); + } else { + return xilinx_pm_request(PM_IOCTL, (u32)node_id, + IOCTL_SD_DLL_RESET, type, 0, NULL); + } }
-void arasan_zynqmp_set_in_tapdelay(u8 deviceid, u32 itap_delay) +int arasan_zynqmp_set_in_tapdelay(u8 node_id, u32 itap_delay) { - if (deviceid == 0) { - zynqmp_mmio_write(SD_DLL_CTRL, SD0_DLL_RST_MASK, SD0_DLL_RST); + int ret;
- /* Program ITAP delay */ - zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPCHGWIN_MASK, - SD0_ITAPCHGWIN); - zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPDLYENA_MASK, - SD0_ITAPDLYENA); - zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPDLYSEL_MASK, itap_delay); - zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPCHGWIN_MASK, 0x0); + if (IS_ENABLED(CONFIG_SPL_BUILD) || current_el() == 3) { + if (node_id == NODE_SD_0) { + ret = zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPCHGWIN, + SD0_ITAPCHGWIN); + if (ret) + return ret;
- zynqmp_mmio_write(SD_DLL_CTRL, SD0_DLL_RST_MASK, 0x0); - } else { - zynqmp_mmio_write(SD_DLL_CTRL, SD1_DLL_RST_MASK, SD1_DLL_RST); + ret = zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPDLYENA, + SD0_ITAPDLYENA); + if (ret) + return ret;
- /* Program ITAP delay */ - zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPCHGWIN_MASK, - SD1_ITAPCHGWIN); - zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPDLYENA_MASK, - SD1_ITAPDLYENA); - zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPDLYSEL_MASK, - (itap_delay << 16)); - zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPCHGWIN_MASK, 0x0); + ret = zynqmp_mmio_write(SD_ITAP_DLY, + SD0_ITAPDLYSEL_MASK, + itap_delay); + if (ret) + return ret;
- zynqmp_mmio_write(SD_DLL_CTRL, SD1_DLL_RST_MASK, 0x0); - } -} + ret = zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPCHGWIN, 0); + if (ret) + return ret; + } + ret = zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPCHGWIN, + SD1_ITAPCHGWIN); + if (ret) + return ret;
-void arasan_zynqmp_set_out_tapdelay(u8 deviceid, u32 otap_delay) -{ - if (deviceid == 0) { - zynqmp_mmio_write(SD_DLL_CTRL, SD0_DLL_RST_MASK, SD0_DLL_RST); + ret = zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPDLYENA, + SD1_ITAPDLYENA); + if (ret) + return ret;
- /* Program OTAP delay */ - zynqmp_mmio_write(SD_OTAP_DLY, SD0_OTAPDLYSEL_MASK, otap_delay); + ret = zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPDLYSEL_MASK, + (itap_delay << 16)); + if (ret) + return ret;
- zynqmp_mmio_write(SD_DLL_CTRL, SD0_DLL_RST_MASK, 0x0); + ret = zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPCHGWIN, 0); + if (ret) + return ret; } else { - zynqmp_mmio_write(SD_DLL_CTRL, SD1_DLL_RST_MASK, SD1_DLL_RST); + return xilinx_pm_request(PM_IOCTL, (u32)node_id, + IOCTL_SET_SD_TAPDELAY, + PM_TAPDELAY_INPUT, itap_delay, NULL); + } + + return 0; +}
- /* Program OTAP delay */ - zynqmp_mmio_write(SD_OTAP_DLY, SD1_OTAPDLYSEL_MASK, - (otap_delay << 16)); +int arasan_zynqmp_set_out_tapdelay(u8 node_id, u32 otap_delay) +{ + if (IS_ENABLED(CONFIG_SPL_BUILD) || current_el() == 3) { + if (node_id == NODE_SD_0) + return zynqmp_mmio_write(SD_OTAP_DLY, + SD0_OTAPDLYSEL_MASK, + otap_delay);
- zynqmp_mmio_write(SD_DLL_CTRL, SD1_DLL_RST_MASK, 0x0); + return zynqmp_mmio_write(SD_OTAP_DLY, SD1_OTAPDLYSEL_MASK, + (otap_delay << 16)); + } else { + return xilinx_pm_request(PM_IOCTL, (u32)node_id, + IOCTL_SET_SD_TAPDELAY, + PM_TAPDELAY_OUTPUT, otap_delay, NULL); } } diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index 1ecc2ec669..8397f24255 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -18,6 +18,7 @@ #include <malloc.h> #include <sdhci.h> #include <zynqmp_tap_delay.h> +#include <zynqmp_firmware.h>
#define SDHCI_ARASAN_ITAPDLY_REGISTER 0xF0F8 #define SDHCI_ARASAN_ITAPDLY_SEL_MASK GENMASK(7, 0) @@ -75,26 +76,40 @@ static const u8 mode2timing[] = { [MMC_HS_200] = MMC_TIMING_MMC_HS200, };
-static void arasan_zynqmp_dll_reset(struct sdhci_host *host, u8 deviceid) +static int arasan_zynqmp_dll_reset(struct sdhci_host *host, u8 node_id) { - u16 clk; + struct mmc *mmc = (struct mmc *)host->mmc; + struct udevice *dev = mmc->dev; unsigned long timeout; + int ret; + u16 clk;
clk = sdhci_readw(host, SDHCI_CLOCK_CONTROL); clk &= ~(SDHCI_CLOCK_CARD_EN); sdhci_writew(host, clk, SDHCI_CLOCK_CONTROL);
/* Issue DLL Reset */ - zynqmp_dll_reset(deviceid); + ret = zynqmp_dll_reset(node_id, PM_DLL_RESET_ASSERT); + if (ret) { + dev_err(dev, "dll_reset assert failed with err: %d\n", ret); + return ret; + } + + /* Allow atleast 1ms delay for proper DLL reset */ + mdelay(1); + ret = zynqmp_dll_reset(node_id, PM_DLL_RESET_RELEASE); + if (ret) { + dev_err(dev, "dll_reset release failed with err: %d\n", ret); + return ret; + }
/* Wait max 20 ms */ timeout = 100; while (!((clk = sdhci_readw(host, SDHCI_CLOCK_CONTROL)) & SDHCI_CLOCK_INT_STABLE)) { if (timeout == 0) { - dev_err(mmc_dev(host->mmc), - ": Internal clock never stabilised.\n"); - return; + dev_err(dev, ": Internal clock never stabilised.\n"); + return -EBUSY; } timeout--; udelay(1000); @@ -102,6 +117,8 @@ static void arasan_zynqmp_dll_reset(struct sdhci_host *host, u8 deviceid)
clk |= SDHCI_CLOCK_CARD_EN; sdhci_writew(host, clk, SDHCI_CLOCK_CONTROL); + + return 0; }
static int arasan_sdhci_execute_tuning(struct mmc *mmc, u8 opcode) @@ -112,12 +129,11 @@ static int arasan_sdhci_execute_tuning(struct mmc *mmc, u8 opcode) struct sdhci_host *host; struct arasan_sdhci_priv *priv = dev_get_priv(mmc->dev); char tuning_loop_counter = SDHCI_TUNING_LOOP_COUNT; - u8 deviceid; + u8 node_id = priv->deviceid ? NODE_SD_1 : NODE_SD_0;
debug("%s\n", __func__);
host = priv->host; - deviceid = priv->deviceid;
ctrl = sdhci_readw(host, SDHCI_HOST_CONTROL2); ctrl |= SDHCI_CTRL_EXEC_TUNING; @@ -125,7 +141,7 @@ static int arasan_sdhci_execute_tuning(struct mmc *mmc, u8 opcode)
mdelay(1);
- arasan_zynqmp_dll_reset(host, deviceid); + arasan_zynqmp_dll_reset(host, node_id);
sdhci_writel(host, SDHCI_INT_DATA_AVAIL, SDHCI_INT_ENABLE); sdhci_writel(host, SDHCI_INT_DATA_AVAIL, SDHCI_SIGNAL_ENABLE); @@ -171,7 +187,7 @@ static int arasan_sdhci_execute_tuning(struct mmc *mmc, u8 opcode) }
udelay(1); - arasan_zynqmp_dll_reset(host, deviceid); + arasan_zynqmp_dll_reset(host, node_id);
/* Enable only interrupts served by the SD controller */ sdhci_writel(host, SDHCI_INT_DATA_MASK | SDHCI_INT_CMD_MASK, @@ -194,10 +210,13 @@ static int arasan_sdhci_execute_tuning(struct mmc *mmc, u8 opcode) static int sdhci_zynqmp_sdcardclk_set_phase(struct sdhci_host *host, int degrees) { - struct arasan_sdhci_priv *priv = dev_get_priv(host->mmc->dev); struct mmc *mmc = (struct mmc *)host->mmc; + struct udevice *dev = mmc->dev; + struct arasan_sdhci_priv *priv = dev_get_priv(mmc->dev); + u8 node_id = priv->deviceid ? NODE_SD_1 : NODE_SD_0; u8 tap_delay, tap_max = 0; int timing = mode2timing[mmc->selected_mode]; + int ret;
/* * This is applicable for SDHCI_SPEC_300 and above @@ -233,7 +252,19 @@ static int sdhci_zynqmp_sdcardclk_set_phase(struct sdhci_host *host, /* Limit output tap_delay value to 6 bits */ tap_delay &= SDHCI_ARASAN_OTAPDLY_SEL_MASK;
- arasan_zynqmp_set_out_tapdelay(priv->deviceid, tap_delay); + /* Set the Clock Phase */ + ret = arasan_zynqmp_set_out_tapdelay(node_id, tap_delay); + if (ret) { + dev_err(dev, "Error setting output Tap Delay\n"); + return ret; + } + + /* Release DLL Reset */ + ret = zynqmp_dll_reset(node_id, PM_DLL_RESET_RELEASE); + if (ret) { + dev_err(dev, "dll_reset release failed with err: %d\n", ret); + return ret; + }
return 0; } @@ -250,10 +281,13 @@ static int sdhci_zynqmp_sdcardclk_set_phase(struct sdhci_host *host, static int sdhci_zynqmp_sampleclk_set_phase(struct sdhci_host *host, int degrees) { - struct arasan_sdhci_priv *priv = dev_get_priv(host->mmc->dev); struct mmc *mmc = (struct mmc *)host->mmc; + struct udevice *dev = mmc->dev; + struct arasan_sdhci_priv *priv = dev_get_priv(mmc->dev); + u8 node_id = priv->deviceid ? NODE_SD_1 : NODE_SD_0; u8 tap_delay, tap_max = 0; int timing = mode2timing[mmc->selected_mode]; + int ret;
/* * This is applicable for SDHCI_SPEC_300 and above @@ -263,6 +297,13 @@ static int sdhci_zynqmp_sampleclk_set_phase(struct sdhci_host *host, if (SDHCI_GET_VERSION(host) < SDHCI_SPEC_300) return 0;
+ /* Assert DLL Reset */ + ret = zynqmp_dll_reset(node_id, PM_DLL_RESET_ASSERT); + if (ret) { + dev_err(dev, "dll_reset assert failed with err: %d\n", ret); + return ret; + } + switch (timing) { case MMC_TIMING_MMC_HS: case MMC_TIMING_SD_HS: @@ -289,7 +330,11 @@ static int sdhci_zynqmp_sampleclk_set_phase(struct sdhci_host *host, /* Limit input tap_delay value to 8 bits */ tap_delay &= SDHCI_ARASAN_ITAPDLY_SEL_MASK;
- arasan_zynqmp_set_in_tapdelay(priv->deviceid, tap_delay); + ret = arasan_zynqmp_set_in_tapdelay(node_id, tap_delay); + if (ret) { + dev_err(dev, "Error setting Input Tap Delay\n"); + return ret; + }
return 0; } diff --git a/include/zynqmp_tap_delay.h b/include/zynqmp_tap_delay.h index 1c1e3e7dee..7ef172f0fa 100644 --- a/include/zynqmp_tap_delay.h +++ b/include/zynqmp_tap_delay.h @@ -8,14 +8,27 @@ #ifndef __ZYNQMP_TAP_DELAY_H__ #define __ZYNQMP_TAP_DELAY_H__
+#include <zynqmp_firmware.h> + #ifdef CONFIG_ARCH_ZYNQMP -void zynqmp_dll_reset(u8 deviceid); -void arasan_zynqmp_set_in_tapdelay(u8 device_id, u32 itap_delay); -void arasan_zynqmp_set_out_tapdelay(u8 device_id, u32 otap_delay); +int zynqmp_dll_reset(u8 node_id, u32 type); +int arasan_zynqmp_set_in_tapdelay(u8 device_id, u32 itap_delay); +int arasan_zynqmp_set_out_tapdelay(u8 device_id, u32 otap_delay); #else -inline void zynqmp_dll_reset(u8 deviceid) {} -inline void arasan_zynqmp_set_in_tapdelay(u8 device_id, u32 itap_delay) {} -inline void arasan_zynqmp_set_out_tapdelay(u8 device_id, u32 otap_delay) {} +inline int zynqmp_dll_reset(u8 deviceid, u32 type) +{ + return 0; +} + +inline int arasan_zynqmp_set_in_tapdelay(u8 device_id, u32 itap_delay) +{ + return 0; +} + +inline int arasan_zynqmp_set_out_tapdelay(u8 device_id, u32 otap_delay) +{ + return 0; +} #endif
#endif
Best Regards, Jaehoon Chung
Changes in v3:
Changes in v2:
release
SD0_DLL_RST);
- else
SD1_DLL_RST);
- if (IS_ENABLED(CONFIG_SPL_BUILD) || current_el() == 3) {
SD0_DLL_RST : 0);
- mdelay(1);
- else
SD1_DLL_RST : 0);
- } else {
- int ret;
SD0_ITAPCHGWIN);
SD0_ITAPDLYENA);
SD0_ITAPCHGWIN);
if (ret)
return ret;
- } else {
SD0_ITAPDLYENA);
if (ret)
return ret;
SD1_ITAPCHGWIN);
SD1_ITAPDLYENA);
itap_delay);
if (ret)
return ret;
if (ret)
return ret;
SD1_ITAPCHGWIN);
if (ret)
return ret;
SD1_ITAPDLYENA);
if (ret)
return ret;
if (ret)
return ret;
if (ret)
} else {return ret;
otap_delay);
- } else {
}PM_TAPDELAY_OUTPUT, otap_delay, NULL);
- u16 clk;
int ret;
u16 clk;
if (ret) {
return ret;
mdelay(1);
if (ret) {
return ret;
return;
} timeout--; udelay(1000);return -EBUSY;
- u8 deviceid;
host = priv->host;
mdelay(1);
udelay(1);
int ret;
- This is applicable for SDHCI_SPEC_300 and above
if (ret) {
return ret;
if (ret) {
return ret;
int ret;
- /* Assert DLL Reset */
- ret = zynqmp_dll_reset(node_id, PM_DLL_RESET_ASSERT);
- if (ret) {
return ret;
- switch (timing) { case MMC_TIMING_MMC_HS: case MMC_TIMING_SD_HS:
if (ret) {
return ret;
+} #endif
#endif
Move tapdelay function calls to zynq_sdhci.c and make them static inline. zynqmp_tap_delay.h has function prototypes for the functions defined in tap_delays.c, which will not be needed anymore.
Remove tap_delays.c and zynqmp_tap_delay.h files.
Changes in v3: - Make the changes on top of patch 4/7 to move the code to zynq_sdhci.c
board/xilinx/zynqmp/Makefile | 2 - board/xilinx/zynqmp/tap_delays.c | 115 ------------------------------- drivers/mmc/zynq_sdhci.c | 108 ++++++++++++++++++++++++++++- include/zynqmp_tap_delay.h | 34 --------- 4 files changed, 107 insertions(+), 152 deletions(-) delete mode 100644 board/xilinx/zynqmp/tap_delays.c delete mode 100644 include/zynqmp_tap_delay.h
diff --git a/board/xilinx/zynqmp/Makefile b/board/xilinx/zynqmp/Makefile index 7d8277ca40..a914028753 100644 --- a/board/xilinx/zynqmp/Makefile +++ b/board/xilinx/zynqmp/Makefile @@ -44,8 +44,6 @@ $(obj)/pm_cfg_obj.o: $(shell cd $(srctree); readlink -f $(CONFIG_ZYNQMP_SPL_PM_C endif endif
-obj-$(CONFIG_MMC_SDHCI_ZYNQ) += tap_delays.o - ifndef CONFIG_SPL_BUILD obj-$(CONFIG_CMD_ZYNQMP) += cmds.o endif diff --git a/board/xilinx/zynqmp/tap_delays.c b/board/xilinx/zynqmp/tap_delays.c deleted file mode 100644 index 514f86a29a..0000000000 --- a/board/xilinx/zynqmp/tap_delays.c +++ /dev/null @@ -1,115 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Xilinx ZynqMP SoC Tap Delay Programming - * - * Copyright (C) 2018 Xilinx, Inc. - */ - -#include <common.h> -#include <zynqmp_tap_delay.h> -#include <asm/arch/sys_proto.h> -#include <asm/cache.h> -#include <linux/delay.h> -#include <mmc.h> -#include <zynqmp_firmware.h> - -#define SD_DLL_CTRL 0xFF180358 -#define SD_ITAP_DLY 0xFF180314 -#define SD_OTAP_DLY 0xFF180318 -#define SD0_DLL_RST BIT(2) -#define SD1_DLL_RST BIT(18) -#define SD0_ITAPCHGWIN BIT(9) -#define SD1_ITAPCHGWIN BIT(25) -#define SD0_ITAPDLYENA BIT(8) -#define SD1_ITAPDLYENA BIT(24) -#define SD0_ITAPDLYSEL_MASK GENMASK(7, 0) -#define SD1_ITAPDLYSEL_MASK GENMASK(23, 16) -#define SD0_OTAPDLYSEL_MASK GENMASK(5, 0) -#define SD1_OTAPDLYSEL_MASK GENMASK(21, 16) - -int zynqmp_dll_reset(u8 node_id, u32 type) -{ - if (IS_ENABLED(CONFIG_SPL_BUILD) || current_el() == 3) { - if (node_id == NODE_SD_0) - return zynqmp_mmio_write(SD_DLL_CTRL, SD0_DLL_RST, - type == PM_DLL_RESET_ASSERT ? - SD0_DLL_RST : 0); - - return zynqmp_mmio_write(SD_DLL_CTRL, SD1_DLL_RST, - type == PM_DLL_RESET_ASSERT ? - SD1_DLL_RST : 0); - } else { - return xilinx_pm_request(PM_IOCTL, (u32)node_id, - IOCTL_SD_DLL_RESET, type, 0, NULL); - } -} - -int arasan_zynqmp_set_in_tapdelay(u8 node_id, u32 itap_delay) -{ - int ret; - - if (IS_ENABLED(CONFIG_SPL_BUILD) || current_el() == 3) { - if (node_id == NODE_SD_0) { - ret = zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPCHGWIN, - SD0_ITAPCHGWIN); - if (ret) - return ret; - - ret = zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPDLYENA, - SD0_ITAPDLYENA); - if (ret) - return ret; - - ret = zynqmp_mmio_write(SD_ITAP_DLY, - SD0_ITAPDLYSEL_MASK, - itap_delay); - if (ret) - return ret; - - ret = zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPCHGWIN, 0); - if (ret) - return ret; - } - ret = zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPCHGWIN, - SD1_ITAPCHGWIN); - if (ret) - return ret; - - ret = zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPDLYENA, - SD1_ITAPDLYENA); - if (ret) - return ret; - - ret = zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPDLYSEL_MASK, - (itap_delay << 16)); - if (ret) - return ret; - - ret = zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPCHGWIN, 0); - if (ret) - return ret; - } else { - return xilinx_pm_request(PM_IOCTL, (u32)node_id, - IOCTL_SET_SD_TAPDELAY, - PM_TAPDELAY_INPUT, itap_delay, NULL); - } - - return 0; -} - -int arasan_zynqmp_set_out_tapdelay(u8 node_id, u32 otap_delay) -{ - if (IS_ENABLED(CONFIG_SPL_BUILD) || current_el() == 3) { - if (node_id == NODE_SD_0) - return zynqmp_mmio_write(SD_OTAP_DLY, - SD0_OTAPDLYSEL_MASK, - otap_delay); - - return zynqmp_mmio_write(SD_OTAP_DLY, SD1_OTAPDLYSEL_MASK, - (otap_delay << 16)); - } else { - return xilinx_pm_request(PM_IOCTL, (u32)node_id, - IOCTL_SET_SD_TAPDELAY, - PM_TAPDELAY_OUTPUT, otap_delay, NULL); - } -} diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index 8397f24255..9a1693940a 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -15,9 +15,9 @@ #include <dm/device_compat.h> #include <linux/err.h> #include <linux/libfdt.h> +#include <asm/cache.h> #include <malloc.h> #include <sdhci.h> -#include <zynqmp_tap_delay.h> #include <zynqmp_firmware.h>
#define SDHCI_ARASAN_ITAPDLY_REGISTER 0xF0F8 @@ -31,6 +31,20 @@ #define SDHCI_TUNING_LOOP_COUNT 40 #define MMC_BANK2 0x2
+#define SD_DLL_CTRL 0xFF180358 +#define SD_ITAP_DLY 0xFF180314 +#define SD_OTAP_DLY 0xFF180318 +#define SD0_DLL_RST BIT(2) +#define SD1_DLL_RST BIT(18) +#define SD0_ITAPCHGWIN BIT(9) +#define SD1_ITAPCHGWIN BIT(25) +#define SD0_ITAPDLYENA BIT(8) +#define SD1_ITAPDLYENA BIT(24) +#define SD0_ITAPDLYSEL_MASK GENMASK(7, 0) +#define SD1_ITAPDLYSEL_MASK GENMASK(23, 16) +#define SD0_OTAPDLYSEL_MASK GENMASK(5, 0) +#define SD1_OTAPDLYSEL_MASK GENMASK(21, 16) + struct arasan_sdhci_clk_data { int clk_phase_in[MMC_TIMING_MMC_HS400 + 1]; int clk_phase_out[MMC_TIMING_MMC_HS400 + 1]; @@ -49,6 +63,12 @@ struct arasan_sdhci_priv { u8 no_1p8; };
+/* For Versal platforms zynqmp_mmio_write() won't be available */ +__weak int zynqmp_mmio_write(const u32 address, const u32 mask, const u32 value) +{ + return 0; +} + #if defined(CONFIG_ARCH_ZYNQMP) || defined(CONFIG_ARCH_VERSAL) /* Default settings for ZynqMP Clock Phases */ static const u32 zynqmp_iclk_phases[] = {0, 63, 63, 0, 63, 0, @@ -76,6 +96,92 @@ static const u8 mode2timing[] = { [MMC_HS_200] = MMC_TIMING_MMC_HS200, };
+static inline int arasan_zynqmp_set_in_tapdelay(u8 node_id, u32 itap_delay) +{ + int ret; + + if (IS_ENABLED(CONFIG_SPL_BUILD) || current_el() == 3) { + if (node_id == NODE_SD_0) { + ret = zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPCHGWIN, + SD0_ITAPCHGWIN); + if (ret) + return ret; + + ret = zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPDLYENA, + SD0_ITAPDLYENA); + if (ret) + return ret; + + ret = zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPDLYSEL_MASK, + itap_delay); + if (ret) + return ret; + + ret = zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPCHGWIN, 0); + if (ret) + return ret; + } + ret = zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPCHGWIN, + SD1_ITAPCHGWIN); + if (ret) + return ret; + + ret = zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPDLYENA, + SD1_ITAPDLYENA); + if (ret) + return ret; + + ret = zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPDLYSEL_MASK, + (itap_delay << 16)); + if (ret) + return ret; + + ret = zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPCHGWIN, 0); + if (ret) + return ret; + } else { + return xilinx_pm_request(PM_IOCTL, (u32)node_id, + IOCTL_SET_SD_TAPDELAY, + PM_TAPDELAY_INPUT, itap_delay, NULL); + } + + return 0; +} + +static inline int arasan_zynqmp_set_out_tapdelay(u8 node_id, u32 otap_delay) +{ + if (IS_ENABLED(CONFIG_SPL_BUILD) || current_el() == 3) { + if (node_id == NODE_SD_0) + return zynqmp_mmio_write(SD_OTAP_DLY, + SD0_OTAPDLYSEL_MASK, + otap_delay); + + return zynqmp_mmio_write(SD_OTAP_DLY, SD1_OTAPDLYSEL_MASK, + (otap_delay << 16)); + } else { + return xilinx_pm_request(PM_IOCTL, (u32)node_id, + IOCTL_SET_SD_TAPDELAY, + PM_TAPDELAY_OUTPUT, otap_delay, NULL); + } +} + +static inline int zynqmp_dll_reset(u8 node_id, u32 type) +{ + if (IS_ENABLED(CONFIG_SPL_BUILD) || current_el() == 3) { + if (node_id == NODE_SD_0) + return zynqmp_mmio_write(SD_DLL_CTRL, SD0_DLL_RST, + type == PM_DLL_RESET_ASSERT ? + SD0_DLL_RST : 0); + + return zynqmp_mmio_write(SD_DLL_CTRL, SD1_DLL_RST, + type == PM_DLL_RESET_ASSERT ? + SD1_DLL_RST : 0); + } else { + return xilinx_pm_request(PM_IOCTL, (u32)node_id, + IOCTL_SD_DLL_RESET, type, 0, NULL); + } +} + static int arasan_zynqmp_dll_reset(struct sdhci_host *host, u8 node_id) { struct mmc *mmc = (struct mmc *)host->mmc; diff --git a/include/zynqmp_tap_delay.h b/include/zynqmp_tap_delay.h deleted file mode 100644 index 7ef172f0fa..0000000000 --- a/include/zynqmp_tap_delay.h +++ /dev/null @@ -1,34 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Xilinx ZynqMP SoC Tap Delay Programming - * - * Copyright (C) 2018 Xilinx, Inc. - */ - -#ifndef __ZYNQMP_TAP_DELAY_H__ -#define __ZYNQMP_TAP_DELAY_H__ - -#include <zynqmp_firmware.h> - -#ifdef CONFIG_ARCH_ZYNQMP -int zynqmp_dll_reset(u8 node_id, u32 type); -int arasan_zynqmp_set_in_tapdelay(u8 device_id, u32 itap_delay); -int arasan_zynqmp_set_out_tapdelay(u8 device_id, u32 otap_delay); -#else -inline int zynqmp_dll_reset(u8 deviceid, u32 type) -{ - return 0; -} - -inline int arasan_zynqmp_set_in_tapdelay(u8 device_id, u32 itap_delay) -{ - return 0; -} - -inline int arasan_zynqmp_set_out_tapdelay(u8 device_id, u32 otap_delay) -{ - return 0; -} -#endif - -#endif
Changes in v3:
- Xilinx ZynqMP SoC Tap Delay Programming
- Copyright (C) 2018 Xilinx, Inc.
SD0_DLL_RST : 0);
SD1_DLL_RST : 0);
- } else {
- int ret;
SD0_ITAPCHGWIN);
if (ret)
return ret;
SD0_ITAPDLYENA);
if (ret)
return ret;
itap_delay);
if (ret)
return ret;
if (ret)
return ret;
SD1_ITAPCHGWIN);
if (ret)
return ret;
SD1_ITAPDLYENA);
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
- } else {
otap_delay);
- } else {
- int ret;
SD0_ITAPCHGWIN);
if (ret)
return ret;
SD0_ITAPDLYENA);
if (ret)
return ret;
itap_delay);
if (ret)
return ret;
if (ret)
return ret;
SD1_ITAPCHGWIN);
if (ret)
return ret;
SD1_ITAPDLYENA);
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
- } else {
otap_delay);
- } else {
SD0_DLL_RST : 0);
SD1_DLL_RST : 0);
- } else {
-} -#endif
-#endif
As per SD spec when SD host controller is reset, it takes 1000msec to detect the card state. In case, if we enable the sd bus voltage & card detect state is not stable, then host controller will disable the sd bus voltage.
In case of warm/subsystem reboot, due to unstable card detect state host controller is disabling the sd bus voltage to sd card causing sd card timeout error. So we wait for a maximum of 1000msec to get the card detect state stable before we enable the sd bus voltage.
This current fix is workaround for now, this needs to be analysed further. Zynqmp platform should behave the same as Versal, but we did not encounter this issue as of now. So we are fixing it for Versal only.
Changes in v2: - Changed return error from -EIO to -ETIMEDOUT in arasan_sdhci_probe() in card detect state stable workaround
drivers/mmc/zynq_sdhci.c | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+)
diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index 9a1693940a..4a877b4ce8 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -776,6 +776,25 @@ static int arasan_sdhci_probe(struct udevice *dev) return ret; upriv->mmc = host->mmc;
+ /* + * WORKAROUND: Versal platforms have an issue with card detect state. + * Due to this, host controller is switching off voltage to sd card + * causing sd card timeout error. Workaround this by adding a wait for + * 1000msec till the card detect state gets stable. + */ + if (IS_ENABLED(CONFIG_ARCH_VERSAL)) { + u32 timeout = 1000; + + while (((sdhci_readl(host, SDHCI_PRESENT_STATE) & + SDHCI_CARD_STATE_STABLE) == 0) && timeout--) { + mdelay(1); + } + if (!timeout) { + dev_err(dev, "Sdhci card detect state not stable\n"); + return -ETIMEDOUT; + } + } + return sdhci_probe(dev); }
Since set_control_reg is available in sdhci.c, use it and remove arasan_sdhci_set_control_reg().
(no changes since v1)
drivers/mmc/zynq_sdhci.c | 21 +-------------------- 1 file changed, 1 insertion(+), 20 deletions(-)
diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index 4a877b4ce8..c94825dceb 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -690,29 +690,10 @@ static void arasan_dt_parse_clk_phases(struct udevice *dev) "clk-phase-mmc-hs400"); }
-static void arasan_sdhci_set_control_reg(struct sdhci_host *host) -{ - struct mmc *mmc = (struct mmc *)host->mmc; - u32 reg; - - if (!IS_SD(mmc)) - return; - - if (mmc->signal_voltage == MMC_SIGNAL_VOLTAGE_180) { - reg = sdhci_readw(host, SDHCI_HOST_CONTROL2); - reg |= SDHCI_CTRL_VDD_180; - sdhci_writew(host, reg, SDHCI_HOST_CONTROL2); - } - - if (mmc->selected_mode > SD_HS && - mmc->selected_mode <= MMC_HS_200) - sdhci_set_uhs_timing(host); -} - static const struct sdhci_ops arasan_ops = { .platform_execute_tuning = &arasan_sdhci_execute_tuning, .set_delay = &arasan_sdhci_set_tapdelay, - .set_control_reg = &arasan_sdhci_set_control_reg, + .set_control_reg = &sdhci_set_control_reg, }; #endif
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
release
Applied. M
Ashok Reddy Soma
Jaehoon Chung
Michal Simek
