[PATCH] rockchip: rk3399: boot_devices: fix eMMC node name
From: Quentin Schulz quentin.schulz@theobroma-systems.com
When idbloader.img is flashed on the eMMC, the SPL still tries to load from SPI-NOR first.
This is due to an incorrect look-up in the Device Tree. Since commit 822556a93459 ("arm: dts: sync the Rockhip 3399 SoCs from Linux"), the node name (but not label) changed from sdhci@fe330000 to mmc@fe330000 meaning U-Boot SPL is not looking for the correct node name anymore and fails to find the "same-as-spl" node when eMMC is the medium from which the SPL booted.
Fixes: 822556a93459 ("arm: dts: sync the Rockhip 3399 SoCs from Linux") Cc: Quentin Schulz foss+u-boot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- arch/arm/mach-rockchip/rk3399/rk3399.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3399/rk3399.c b/arch/arm/mach-rockchip/rk3399/rk3399.c index 01a05599cd..de11a3fa30 100644 --- a/arch/arm/mach-rockchip/rk3399/rk3399.c +++ b/arch/arm/mach-rockchip/rk3399/rk3399.c @@ -27,7 +27,7 @@ DECLARE_GLOBAL_DATA_PTR; #define GRF_BASE 0xff770000
const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1] = { - [BROM_BOOTSOURCE_EMMC] = "/sdhci@fe330000", + [BROM_BOOTSOURCE_EMMC] = "/mmc@fe330000", [BROM_BOOTSOURCE_SPINOR] = "/spi@ff1d0000/flash@0", [BROM_BOOTSOURCE_SD] = "/mmc@fe320000", }; @@ -181,7 +181,7 @@ const char *spl_decode_boot_device(u32 boot_device) const char *ofpath; } spl_boot_devices_tbl[] = { { BOOT_DEVICE_MMC1, "/mmc@fe320000" }, - { BOOT_DEVICE_MMC2, "/sdhci@fe330000" }, + { BOOT_DEVICE_MMC2, "/mmc@fe330000" }, { BOOT_DEVICE_SPI, "/spi@ff1d0000" }, };
Is any news on this fix to merge? it certainly breaks eMMC boot on the last rc1.
Jagan.
Reviewed-by: Jagan Teki jagan@amarulasolutions.com
Tom, can you apply this on master?
Jagan.
Kever, should I be expecting a rockchip PR soon? There's a lot of outstanding changes at the moment.
Jagan Teki
Quentin Schulz
