[PATCH v5] mtd: spi-nor: Fix the spi_nor_read() when config SPI_STACKED_PARALLEL is enabled
Update the spi_nor_read() function based on the config SPI_FLASH_BAR and update the length and bank calculation by spliting the memory of 16MB size banks only when the address width is 3byte. Fix the read issue for 4byte address width by passing the entire length to the read function. Also update the size when the configuration is stacked.
Fixes: 5d40b3d384 ("mtd: spi-nor: Add parallel and stacked memories support") Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com --- Changes in v2: - Update the nor read for parallel configuration and for other case keep the code as is. - Fixed the commit description. - Tested the changes with s25fl128s flash Zynq> sf probe 0 0 0 SF: Detected s25fl128s with page size 256 Bytes, erase size 64 KiB, total 16 MiB Zynq> time sf erase 0x0 0x1000000;mw.b 0x8000 aabbccdd 0x1000000;time Zynq> sf write 0x8000 0x0 0x1000000;mw.b 0x8008000 0x0 0x1000000;time Zynq> sf read 0x8008000 0x0 0x1000000;cmp.b 0x8000 0x8008000 0x1000000 SF: 16777216 bytes @ 0x0 Erased: OK
time: 32.464 seconds device 0 whole chip SF: 16777216 bytes @ 0x0 Written: OK
time: 15.515 seconds device 0 whole chip SF: 16777216 bytes @ 0x0 Read: OK
time: 1.557 seconds Total of 16777216 byte(s) were the same
Changes in v3: - Compile out the parallel code in spi_nor_erase() if the SPI_STACKED_PARALLEL is enabled.
Changes in v4: - Update the bank calculation only when SPL_FLASH_BAR is enabled.
Changes in v5: - Update the parallel code in the spi_nor_read() only if the SPI_STACKED_PARALLEL config is enabled. --- drivers/mtd/spi/spi-nor-core.c | 76 ++++++++++++++++++++-------------- 1 file changed, 46 insertions(+), 30 deletions(-)
diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index ec841fb13bd..2e41cf74430 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -1130,17 +1130,19 @@ static int spi_nor_erase(struct mtd_info *mtd, struct erase_info *instr) goto erase_err; } offset = addr; - if (nor->flags & SNOR_F_HAS_PARALLEL) - offset /= 2; - - if (nor->flags & SNOR_F_HAS_STACKED) { - if (offset >= (mtd->size / 2)) - nor->spi->flags |= SPI_XFER_U_PAGE; - else - nor->spi->flags &= ~SPI_XFER_U_PAGE; + if (CONFIG_IS_ENABLED(SPI_STACKED_PARALLEL)) { + if (nor->flags & SNOR_F_HAS_PARALLEL) + offset /= 2; + + if (nor->flags & SNOR_F_HAS_STACKED) { + if (offset >= (mtd->size / 2)) + nor->spi->flags |= SPI_XFER_U_PAGE; + else + nor->spi->flags &= ~SPI_XFER_U_PAGE; + } } #ifdef CONFIG_SPI_FLASH_BAR - ret = write_bar(nor, addr); + ret = write_bar(nor, offset); if (ret < 0) goto erase_err; #endif @@ -1152,7 +1154,7 @@ static int spi_nor_erase(struct mtd_info *mtd, struct erase_info *instr) !(nor->flags & SNOR_F_NO_OP_CHIP_ERASE)) { ret = spi_nor_erase_chip(nor); } else { - ret = spi_nor_erase_sector(nor, addr); + ret = spi_nor_erase_sector(nor, offset); } if (ret < 0) goto erase_err; @@ -1576,11 +1578,12 @@ static int spi_nor_read(struct mtd_info *mtd, loff_t from, size_t len, size_t *retlen, u_char *buf) { struct spi_nor *nor = mtd_to_spi_nor(mtd); - int ret; loff_t offset = from; - u32 read_len = 0; u32 rem_bank_len = 0; + u32 stack_shift = 0; + size_t read_len; u8 bank; + int ret; bool is_ofst_odd = false;
dev_dbg(nor->dev, "from 0x%08x, len %zd\n", (u32)from, len); @@ -1593,35 +1596,48 @@ static int spi_nor_read(struct mtd_info *mtd, loff_t from, size_t len, }
while (len) { - bank = (u32)from / SZ_16M; - if (nor->flags & SNOR_F_HAS_PARALLEL) - bank /= 2; - - rem_bank_len = SZ_16M * (bank + 1); - if (nor->flags & SNOR_F_HAS_PARALLEL) - rem_bank_len *= 2; - rem_bank_len -= from; - + read_len = len; offset = from;
- if (nor->flags & SNOR_F_HAS_STACKED) { - if (offset >= (mtd->size / 2)) { - offset = offset - (mtd->size / 2); - nor->spi->flags |= SPI_XFER_U_PAGE; - } else { - nor->spi->flags &= ~SPI_XFER_U_PAGE; + if (CONFIG_IS_ENABLED(SPI_FLASH_BAR)) { + bank = (u32)from / SZ_16M; + if (CONFIG_IS_ENABLED(SPI_STACKED_PARALLEL)) { + if (nor->flags & SNOR_F_HAS_PARALLEL) + bank /= 2; + } + rem_bank_len = SZ_16M * (bank + 1); + if (CONFIG_IS_ENABLED(SPI_STACKED_PARALLEL)) { + if (nor->flags & SNOR_F_HAS_PARALLEL) + rem_bank_len *= 2; } + rem_bank_len -= from; }
- if (nor->flags & SNOR_F_HAS_PARALLEL) - offset /= 2; + if (CONFIG_IS_ENABLED(SPI_STACKED_PARALLEL)) { + if (nor->flags & SNOR_F_HAS_STACKED) { + stack_shift = 1; + if (offset >= (mtd->size / 2)) { + offset = offset - (mtd->size / 2); + nor->spi->flags |= SPI_XFER_U_PAGE; + } else { + nor->spi->flags &= ~SPI_XFER_U_PAGE; + } + } + } + + if (nor->addr_width == 4) + rem_bank_len = (mtd->size >> stack_shift) - offset; + + if (CONFIG_IS_ENABLED(SPI_STACKED_PARALLEL)) { + if (nor->flags & SNOR_F_HAS_PARALLEL) + offset /= 2; + }
#ifdef CONFIG_SPI_FLASH_BAR ret = write_bar(nor, offset); if (ret < 0) return log_ret(ret); #endif - if (len < rem_bank_len) read_len = len; else
I don't think you've run this through CI? https://source.denx.de/u-boot/u-boot/-/jobs/984698#L289 and similar on all sandbox targets, and Azure shows it too.
Hi Tom,
-----Original Message----- From: Tom Rini trini@konsulko.com Sent: Friday, December 27, 2024 11:53 PM To: Abbarapu, Venkatesh venkatesh.abbarapu@amd.com Cc: u-boot@lists.denx.de; tudor.ambarus@linaro.org; j-humphreys@ti.com; marex@denx.de; Simek, Michal michal.simek@amd.com; jagan@amarulasolutions.com; vigneshr@ti.com; u-kumar1@ti.com; seanga2@gmail.com; caleb.connolly@linaro.org; sjg@chromium.org; william.zhang@broadcom.com; stefan_b@posteo.net; quentin.schulz@cherry.de; Takahiro.Kuwano@infineon.com; p-mantena@ti.com; git (AMD-Xilinx) git@amd.com Subject: Re: [PATCH v5] mtd: spi-nor: Fix the spi_nor_read() when config SPI_STACKED_PARALLEL is enabled
Ok...Could you please run the CI on the "v3 patch" once, as this patch is entirely separated the parallel code with the default one.
[PATCH v3] mtd: spi-nor: Fix the spi_nor_read() when config SPI_STACKED_PARALLEL is enabled
Thanks Venkatesh
-- Tom
On Sat, Dec 28, 2024 at 04:29:39AM +0000, Abbarapu, Venkatesh wrote:
Hi Tom,
Yes, v3 passes CI. Does the help with what you need to do for v6 then?
Hi Tom,
-----Original Message----- From: Tom Rini trini@konsulko.com Sent: Sunday, December 29, 2024 10:06 PM To: Abbarapu, Venkatesh venkatesh.abbarapu@amd.com Cc: u-boot@lists.denx.de; tudor.ambarus@linaro.org; j-humphreys@ti.com; marex@denx.de; Simek, Michal michal.simek@amd.com; jagan@amarulasolutions.com; vigneshr@ti.com; u-kumar1@ti.com; seanga2@gmail.com; caleb.connolly@linaro.org; sjg@chromium.org; william.zhang@broadcom.com; stefan_b@posteo.net; quentin.schulz@cherry.de; Takahiro.Kuwano@infineon.com; p-mantena@ti.com; git (AMD-Xilinx) git@amd.com Subject: Re: [PATCH v5] mtd: spi-nor: Fix the spi_nor_read() when config SPI_STACKED_PARALLEL is enabled
Hi Tom,
Thanks for running CI with v3. I sent v6 patch considering the v3 related changes and mostly this should pass the CI. If there are any issues seen with v6 then we need to consider v3 patch as the comment is only with the additional #ifdef statement for the parallel configuration.
Thanks Venkatesh
-- Tom
Abbarapu, Venkatesh
