[U-Boot] Questions about mx31ads.h
I am trying to understand the settings in mx31ads.h, but got some questions:
1. I didn't see where CONFIG_ENV_OFFSET is defined.
2. #define CONFIG_LOADADDR 0x80800000 /* loadaddr env var */ Is this the address where env var are loaded to the RAM? Why pick this particular address 0x80800000?
3. #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE /* Monitor at beginning of flash */ Why the monitor is in flash? Shouldn't it be in RAM?
4. #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_ENV_SECT_SIZE) If env var are stored after the monitor. Should it be at CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_SIZE ?
In general, is there a documentation on what configuration parameters are available and what's their meaning?
Thanks a lot Yong
Yong Yang
