[PATCH] arm64: zynqmp: Change compatible strings for cadence uart
Based on Linux kernel DT binding there should be different compatible strings used that's why align zynqmp.dtsi with it.
arch/arm/dts/zynqmp.dtsi | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/zynqmp.dtsi b/arch/arm/dts/zynqmp.dtsi index 015a582d7a79..300a2189f6eb 100644 --- a/arch/arm/dts/zynqmp.dtsi +++ b/arch/arm/dts/zynqmp.dtsi @@ -824,7 +824,7 @@
uart0: serial@ff000000 { u-boot,dm-pre-reloc; - compatible = "cdns,uart-r1p12", "xlnx,xuartps"; + compatible = "xlnx,zynqmp-uart", "cdns,uart-r1p12"; status = "disabled"; interrupt-parent = <&gic>; interrupts = <0 21 4>; @@ -835,7 +835,7 @@
uart1: serial@ff010000 { u-boot,dm-pre-reloc; - compatible = "cdns,uart-r1p12", "xlnx,xuartps"; + compatible = "xlnx,zynqmp-uart", "cdns,uart-r1p12"; status = "disabled"; interrupt-parent = <&gic>; interrupts = <0 22 4>;
pá 14. 1. 2022 v 12:43 odesílatel Michal Simek michal.simek@xilinx.com napsal:
@@ -835,7 +835,7 @@
-- 2.34.1
Applied. M
Michal Simek
Michal Simek
