[U-Boot] [PATCH] arm: ls1028a: define the integrated PCI bus (ECAM)
LS1028A includes an integrated PCI bus with 8M of ECAM space plus register space for the integrated devices. This integrated PCI bus is driven using the generic ECAM driver.
Signed-off-by: Alex Marginean alexm.osslist@gmail.com --- arch/arm/dts/fsl-ls1028a.dtsi | 10 ++++++++++ arch/arm/include/asm/arch-fsl-layerscape/cpu.h | 2 ++ arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h | 2 ++ configs/ls1028aqds_tfa_defconfig | 1 + configs/ls1028ardb_tfa_defconfig | 1 + 5 files changed, 16 insertions(+)
diff --git a/arch/arm/dts/fsl-ls1028a.dtsi b/arch/arm/dts/fsl-ls1028a.dtsi index e6a443aa77..263c29af23 100644 --- a/arch/arm/dts/fsl-ls1028a.dtsi +++ b/arch/arm/dts/fsl-ls1028a.dtsi @@ -108,6 +108,16 @@ 0x82000000 0x0 0x40000000 0x88 0x40000000 0x0 0x40000000>; /* non-prefetchable memory */ };
+ pcie@1f0000000 { + compatible = "pci-host-ecam-generic"; + reg = <0x01 0xf0000000 0x0 0x100000>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0x0>; + ranges= <0x82000000 0x0 0x00000000 0x1 0xf8000000 0x0 0x160000>; + }; + i2c0: i2c@2000000 { compatible = "fsl,vf610-i2c"; #address-cells = <1>; diff --git a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h index bdeb62576c..7759acdb8f 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h @@ -42,7 +42,9 @@ #else #define CONFIG_SYS_PCIE1_PHYS_SIZE 0x800000000 #define CONFIG_SYS_PCIE2_PHYS_SIZE 0x800000000 +#ifndef CONFIG_SYS_PCIE3_PHYS_SIZE #define CONFIG_SYS_PCIE3_PHYS_SIZE 0x800000000 +#endif #define CONFIG_SYS_PCIE4_PHYS_SIZE 0x800000000 #define SYS_PCIE5_PHYS_SIZE 0x800000000 #define SYS_PCIE6_PHYS_SIZE 0x800000000 diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index 24c1b0e482..273157230f 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -186,6 +186,8 @@ #elif CONFIG_ARCH_LS1028A #define CONFIG_SYS_PCIE1_PHYS_ADDR 0x8000000000ULL #define CONFIG_SYS_PCIE2_PHYS_ADDR 0x8800000000ULL +#define CONFIG_SYS_PCIE3_PHYS_ADDR 0x01f0000000ULL +#define CONFIG_SYS_PCIE3_PHYS_SIZE 0x0010000000ULL #else #define CONFIG_SYS_PCIE1_PHYS_ADDR 0x1000000000ULL #define CONFIG_SYS_PCIE2_PHYS_ADDR 0x1200000000ULL diff --git a/configs/ls1028aqds_tfa_defconfig b/configs/ls1028aqds_tfa_defconfig index 717b810523..7982ce4157 100644 --- a/configs/ls1028aqds_tfa_defconfig +++ b/configs/ls1028aqds_tfa_defconfig @@ -48,6 +48,7 @@ CONFIG_E1000=y CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_ECAM_GENERIC=y CONFIG_PCIE_LAYERSCAPE=y CONFIG_SCSI=y CONFIG_DM_SCSI=y diff --git a/configs/ls1028ardb_tfa_defconfig b/configs/ls1028ardb_tfa_defconfig index a8e4ddb7a8..c65e37df79 100644 --- a/configs/ls1028ardb_tfa_defconfig +++ b/configs/ls1028ardb_tfa_defconfig @@ -48,6 +48,7 @@ CONFIG_E1000=y CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_ECAM_GENERIC=y CONFIG_PCIE_LAYERSCAPE=y CONFIG_SCSI=y CONFIG_DM_SCSI=y
Hi Alex,
On Fri, May 31, 2019 at 12:27 AM Alex Marginean alexm.osslist@gmail.com wrote:
pcie@1f0000000 {
#size-cells = <2>;
I think this should be <0x0 0x7> since you mentioned in the commit message that only an 8M ECAM space is allocated.
DT says the size is 0x100000. This does not match.
These macros really look to me this platform is still using lots of non-DM approaches when it comes to driver support. These hard coded values should really be dropped and retrieved from DT instead via proper DM drivers.
#else #define CONFIG_SYS_PCIE1_PHYS_ADDR 0x1000000000ULL #define CONFIG_SYS_PCIE2_PHYS_ADDR 0x1200000000ULL diff --git a/configs/ls1028aqds_tfa_defconfig b/configs/ls1028aqds_tfa_defconfig index 717b810523..7982ce4157 100644 --- a/configs/ls1028aqds_tfa_defconfig +++ b/configs/ls1028aqds_tfa_defconfig @@ -48,6 +48,7 @@ CONFIG_E1000=y CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_ECAM_GENERIC=y CONFIG_PCIE_LAYERSCAPE=y CONFIG_SCSI=y CONFIG_DM_SCSI=y diff --git a/configs/ls1028ardb_tfa_defconfig b/configs/ls1028ardb_tfa_defconfig index a8e4ddb7a8..c65e37df79 100644 --- a/configs/ls1028ardb_tfa_defconfig +++ b/configs/ls1028ardb_tfa_defconfig @@ -48,6 +48,7 @@ CONFIG_E1000=y CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_ECAM_GENERIC=y CONFIG_PCIE_LAYERSCAPE=y CONFIG_SCSI=y CONFIG_DM_SCSI=y --
Regards, Bin
Hi Bin,
On 6/2/2019 5:22 PM, Bin Meng wrote:
Hi Alex,
pcie@1f0000000 {
#size-cells = <2>;
I think I was looking at the wrong spec, it seems the platform actually has 256MB of address space reserved for ECAM. It's not all implemented of course, in fact all the devices we care about in u-boot are on bus 0. Anyway, I can just remove bus-range, the default is 0-255 and that does match the HW.
I'll extend reg to 256MB along with removing bus-range.
ECAM is driven by the ecam generic host driver and it doesn't care about these macros. These are used int arch/arm/cpu/armv8/fsl-layerscape/cpu.c to set up the MMU at boot though, accessing ECAM doesn't work without them.
Regards, Bin
Thank you! Alex
Hi Alex,
On Tue, Jun 4, 2019 at 9:59 PM Alex Marginean alexm.osslist@gmail.com wrote:
Hi Bin,
Hi Alex,
pcie@1f0000000 {
#size-cells = <2>;
Yes, but what I was trying to say that with driver model things like register base and size should be retrieved from DT. Can we consider doing an ARMv8 DM MMU driver that reads DT and set up the page table for everything?
Simon/Tom, do you have any better ideas?
Regards, Bin
On 6/5/2019 4:09 AM, Bin Meng wrote:
Hi Alex,
Hi Bin,
Hi Alex,
pcie@1f0000000 {
#size-cells = <2>;
I've dug a bit more into the address ranges used here, there is indeed a 256MB space but that's not just for ECAM. In fact 2nd half contains device registers for the devices presented as PCI through ECAM. Given than only bus 0 is populated I kept bus-range = <0x0 0x0>.
On the other hand both ECAM and device registers have to be mapped in MMU, so I didn't change the 256MB size macro.
I agree the existing solution for mapping in MMU isn't great, since it duplicates information between dts and code. I'm not sure what would be a good alternative. Mapping based on dts could work, but the code would have to deal with various corner cases. Some nodes don't use reg for addresses, for integrated PCI with EA mapping ECAM alone is not sufficient, we also need the BAR equivalents mapped, those kind of things. That means more knowledge added one way or another to the arm MMU code, I'm not sure that would end up being so much cleaner than what is there now.
Thanks! Alex
Regards, Bin
Hi Alex,
On Fri, Jun 7, 2019 at 10:41 PM Alex Marginean alexm.osslist@gmail.com wrote:
Hi Alex,
Hi Bin,
Hi Alex,
pcie@1f0000000 {
#size-cells = <2>;
Yep, I believe this is not an NXP specific problem. It applies to other ARM platforms, so I was hoping Tom or Simon could give some generic solution.
Regards, Bin
LS1028A includes an integrated PCI bus with 11 PCI functions residing on bus 0. ECAM plus the device register space takes up 256MB of address space.
Changes in v2: - added comments to dts, PCIE3_PHYS_SIZE, rewrote patch description
arch/arm/dts/fsl-ls1028a.dtsi | 11 +++++++++++ arch/arm/include/asm/arch-fsl-layerscape/cpu.h | 2 ++ .../arm/include/asm/arch-fsl-layerscape/immap_lsch3.h | 3 +++ configs/ls1028aqds_tfa_defconfig | 1 + configs/ls1028ardb_tfa_defconfig | 1 + 5 files changed, 18 insertions(+)
diff --git a/arch/arm/dts/fsl-ls1028a.dtsi b/arch/arm/dts/fsl-ls1028a.dtsi index e6a443aa77..b2b55398bb 100644 --- a/arch/arm/dts/fsl-ls1028a.dtsi +++ b/arch/arm/dts/fsl-ls1028a.dtsi @@ -108,6 +108,17 @@ 0x82000000 0x0 0x40000000 0x88 0x40000000 0x0 0x40000000>; /* non-prefetchable memory */ };
+ pcie@1f0000000 { + compatible = "pci-host-ecam-generic"; + /* ECAM bus 0, HW has more space reserved but not populated */ + bus-range = <0x0 0x0>; + reg = <0x01 0xf0000000 0x0 0x100000>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + ranges= <0x82000000 0x0 0x00000000 0x1 0xf8000000 0x0 0x160000>; + }; + i2c0: i2c@2000000 { compatible = "fsl,vf610-i2c"; #address-cells = <1>; diff --git a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h index bdeb62576c..7759acdb8f 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h @@ -42,7 +42,9 @@ #else #define CONFIG_SYS_PCIE1_PHYS_SIZE 0x800000000 #define CONFIG_SYS_PCIE2_PHYS_SIZE 0x800000000 +#ifndef CONFIG_SYS_PCIE3_PHYS_SIZE #define CONFIG_SYS_PCIE3_PHYS_SIZE 0x800000000 +#endif #define CONFIG_SYS_PCIE4_PHYS_SIZE 0x800000000 #define SYS_PCIE5_PHYS_SIZE 0x800000000 #define SYS_PCIE6_PHYS_SIZE 0x800000000 diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index 24c1b0e482..06bc08760f 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -186,6 +186,9 @@ #elif CONFIG_ARCH_LS1028A #define CONFIG_SYS_PCIE1_PHYS_ADDR 0x8000000000ULL #define CONFIG_SYS_PCIE2_PHYS_ADDR 0x8800000000ULL +#define CONFIG_SYS_PCIE3_PHYS_ADDR 0x01f0000000ULL +/* this is used by integrated PCI on LS1028, includes ECAM and register space */ +#define CONFIG_SYS_PCIE3_PHYS_SIZE 0x0010000000ULL #else #define CONFIG_SYS_PCIE1_PHYS_ADDR 0x1000000000ULL #define CONFIG_SYS_PCIE2_PHYS_ADDR 0x1200000000ULL diff --git a/configs/ls1028aqds_tfa_defconfig b/configs/ls1028aqds_tfa_defconfig index 717b810523..7982ce4157 100644 --- a/configs/ls1028aqds_tfa_defconfig +++ b/configs/ls1028aqds_tfa_defconfig @@ -48,6 +48,7 @@ CONFIG_E1000=y CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_ECAM_GENERIC=y CONFIG_PCIE_LAYERSCAPE=y CONFIG_SCSI=y CONFIG_DM_SCSI=y diff --git a/configs/ls1028ardb_tfa_defconfig b/configs/ls1028ardb_tfa_defconfig index a8e4ddb7a8..c65e37df79 100644 --- a/configs/ls1028ardb_tfa_defconfig +++ b/configs/ls1028ardb_tfa_defconfig @@ -48,6 +48,7 @@ CONFIG_E1000=y CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_ECAM_GENERIC=y CONFIG_PCIE_LAYERSCAPE=y CONFIG_SCSI=y CONFIG_DM_SCSI=y
On Fri, Jun 7, 2019 at 10:03 PM Alex Marginean alexm.osslist@gmail.com wrote:
-----Original Message----- From: Alex Marginean alexm.osslist@gmail.com Sent: Thursday, May 30, 2019 9:56 PM To: u-boot@lists.denx.de Cc: Sudhanshu Gupta sudhanshu.gupta@nxp.com; Harninder Rai harninder.rai@nxp.com; Rajesh Bhagat rajesh.bhagat@nxp.com; Andy Tang andy.tang@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Priyanka Jain priyanka.jain@nxp.com; Albert Aribaud albert.u.boot@aribaud.net; Alex Marginean alexm.osslist@gmail.com Subject: [PATCH] arm: ls1028a: define the integrated PCI bus (ECAM)
This patch has been applied to fsl-qoriq master, awaiting upstream.
--pk
Alex Marginean
Bin Meng
Prabhakar Kushwaha
